path: root/arch/arm/mach-ixp4xx
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-27[ARM] 5179/1: Replace obsolete IRQT_* and __IRQT_* values with IRQ_TYPE_*Dmitry Baryshkov
IRQT_* and __IRQT_* were obsoleted long ago by patch [3692/1]. Remove them completely. Sed script for the reference: s/__IRQT_RISEDGE/IRQ_TYPE_EDGE_RISING/g s/__IRQT_FALEDGE/IRQ_TYPE_EDGE_FALLING/g s/__IRQT_LOWLVL/IRQ_TYPE_LEVEL_LOW/g s/__IRQT_HIGHLVL/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_RISING/IRQ_TYPE_EDGE_RISING/g s/IRQT_FALLING/IRQ_TYPE_EDGE_FALLING/g s/IRQT_BOTHEDGE/IRQ_TYPE_EDGE_BOTH/g s/IRQT_LOW/IRQ_TYPE_LEVEL_LOW/g s/IRQT_HIGH/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_PROBE/IRQ_TYPE_PROBE/g s/IRQT_NOEDGE/IRQ_TYPE_NONE/g Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-14[ARM] Merge most of the PXA work for initial mergeRussell King
This includes PXA work up to the SPI changes for the initial merge, since e172274ccc55d20536fbdceb6131f38e288541e0 depends on the SPI tree being merged. Conflicts: arch/arm/configs/em_x270_defconfig arch/arm/configs/xm_x270_defconfig
2008-07-10Merge branches 'at91', 'dyntick', 'ep93xx', 'iop', 'ixp', 'misc', 'orion', ↵Russell King
'omap-reviewed', 'rpc', 'rtc' and 's3c' into devel
2008-07-09[ARM] 5120/1: pxa: correct platform driver names for PXA25x and PXA27x UDC ↵Philipp Zabel
drivers The pxa2xx_udc.c driver is renamed to pxa25x_udc.c (the platform driver name changes from pxa2xx-udc to pxa25x-udc) and the platform driver name of pxa27x_udc.c is fixed to pxa27x-udc. pxa_device_udc in devices.c is split into pxa25x and pxa27x flavors and the pxa27x_device_udc is enabled in pxa27x.c. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Acked-by: Nicolas Pitre <nico@cam.org> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Including from Ian Molton: Fixes for mistakes left over from the PXA2{5,7}X UDC split. Signed-off-by: Ian Molton <spyro@f2s.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (53 commits) tcp: Overflow bug in Vegas [IPv4] UFO: prevent generation of chained skb destined to UFO device iwlwifi: move the selects to the tristate drivers ipv4: annotate a few functions __init in ipconfig.c atm: ambassador: vcc_sf semaphore to mutex MAINTAINERS: The socketcan-core list is subscribers-only. netfilter: nf_conntrack: padding breaks conntrack hash on ARM ipv4: Update MTU to all related cache entries in ip_rt_frag_needed() sch_sfq: use del_timer_sync() in sfq_destroy() net: Add compat support for getsockopt (MCAST_MSFILTER) net: Several cleanups for the setsockopt compat support. ipvs: fix oops in backup for fwmark conn templates bridge: kernel panic when unloading bridge module bridge: fix error handling in br_add_if() netfilter: {nfnetlink,ip,ip6}_queue: fix skb_over_panic when enlarging packets netfilter: x_tables: fix net namespace leak when reading /proc/net/xxx_tables_names netfilter: xt_TCPOPTSTRIP: signed tcphoff for ipv6_skip_exthdr() retval tcp: Limit cwnd growth when deferring for GSO tcp: Allow send-limited cwnd to grow up to max_burst when gso disabled [netdrvr] gianfar: Determine TBIPA value dynamically ...
2008-04-29i2c: Convert most new-style drivers to use module aliasingJean Delvare
Based on earlier work by Jon Smirl and Jochen Friedrich. Update most new-style i2c drivers to use standard module aliasing instead of the old driver_name/type driver matching scheme. I've left the video drivers apart (except for SoC camera drivers) as they're a bit more diffcult to deal with, they'll have their own patch later. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jon Smirl <jonsmirl@gmail.com> Cc: Jochen Friedrich <jochen@scram.de>
2008-04-29Driver for IXP4xx built-in Ethernet portsKrzysztof Halasa
Adds a driver for built-in IXP4xx Ethernet ports. Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-04[ARM] 4874/2: ixp4xx: Add support for the Freecom FSG-3 boardRod Whitby
The Freecom-FSG3 is a small network-attached-storage device with the following feature set: * Intel IXP422 * 4MB Flash (ixp4xx flash driver) * 64MB RAM * 4 USB 2.0 host ports (ehci and ohci drivers) * 1 WAN (eth1) and 3 LAN (eth0) ethernet ports * Supported by the open source ixp4xx ethernet driver * Via VT6421 disk controller (libata and sata-via drivers) * Internal hard disk (PATA supported, SATA not yet supported) * External SATA port (not yet supported) * ISL1208 RTC chip * Winbond 83782 temp sensor and fan controller * MiniPCI slot The ixp4xx_defconfig is also updated to support this device (the leds-fsg driver is to be submitted separately via the leds tree after this initial support is merged, as it depends on header gpio defines). Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-03-06[ARM] replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-07leds: Standardise LED naming schemeRichard Purdie
As discussed on LKML some notion of 'function' is needed in LED naming. This patch adds this to the documentation and standardises existing LED drivers. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2008-02-04[ARM] 4809/2: ixp4xx: Merge dsmg600-power.c into dsmg600-setup.cRod Whitby
There is no reason to have power control in a separate file from the board setup code. Merge it back into the board setup file and remove superfluous header includes. -- Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4808/2: ixp4xx: Merge nas100d-power.c into nas100d-setup.cRod Whitby
2008-02-04[ARM] 4807/2: ixp4xx: Merge nslu2-power.c into nslu2-setup.cRod Whitby
There is no reason to have power control in a separate file from the board setup code. Merge it back into the board setup file, removing superfluous header includes and removing superfluous constants from the machine header file. -- Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4806/1: ixp4xx: Ethernet support for the nslu2 and nas100d boardsRod Whitby
Enables the new ixp4xx qmgr and npe drivers in ixp4xx_defconfig. Sets up the corresponding platform data for the nslu2 and nas100d boards, and reads the ethernet MAC address from the internal flash. Tested on both little-endian and big-endian kernels. Tested-by: Tom King <tom@websb.net> Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Michael Westerhof <mwester@dls.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4805/1: ixp4xx: Use leds-gpio driver instead of IXP4XX-GPIO-LED driverRod Whitby
These are the only three boards to use the IXP4XX-GPIO-LED driver, and they can all use the new leds-gpio driver instead with no change in functionality. -- Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4715/2: Ethernet support for IXDP425 boardsRod Whitby
Adds IXDP425 platform support for two built-in 10/100 Ethernet ports. This patch will do nothing until the actual Ethernet driver is also included. Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4713/3: Adds drivers for IXP4xx QMgr and NPE featuresKrzysztof Halasa
This patch adds drivers for IXP4xx hardware Queue Manager and for Network Processor Engines. Requires patch #4712 (reading/writing CPU feature (aka fuse) bits). Posted to linux-arm-kernel on 2 Dec 2007 and revised. Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4774/2: ixp4xx: Register dsmg600 rtc i2c_board_infoRod Whitby
Register the i2c board info related to the RTC chip on the dsmg600 board to allow it to be found automatically on boot. Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4773/2: ixp4xx: Register nas100d rtc i2c_board_infoRod Whitby
Register the i2c board info related to the RTC chip on the nas100d board to allow it to be found automatically on boot. Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4772/2: ixp4xx: Register nslu2 rtc i2c_board_infoRod Whitby
Register the i2c board info related to the RTC chip on the nslu2 board to allow it to be found automatically on boot. Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4769/2: ixp4xx: Button updates for the dsmg600 boardRod Whitby
* Remove the superfluous declaration of ctrl_alt_del(). * Convert GPIO and IRQ handling to use the <asm/gpio.h> api. * Perform the reset on the release of the power button, so that NAS devices which have been set to auto-power-on (by solder bridging the power button) do not continuously power cycle. * Remove all superflous constants from dsmg600.h Signed-off-by: Rod Whitby <rod@whitby.id.au> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4768/2: ixp4xx: Button and LED updates for the nas100d boardRod Whitby
* Convert GPIO and IRQ handling to use the <asm/gpio.h> api. * Perform the reset only after the power button has been held down for at least two seconds. Do the reset on the release of the power button, so that NAS devices which have been set to auto-power-on (by solder bridging the power button) do not continuously power cycle. * Remove all superflous constants from nas100d.h * Add LED constants to nas100d.h while we're there. * Update the board LED setup code to use those constants. Signed-off-by: Rod Whitby <rod@whitby.id.au> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-28Merge branches 'at91', 'ep93xx', 'iop', 'kprobes', 'ks8695', 'misc', 'msm', ↵Russell King
's3c2410', 'sa1100' and 'vfp' into devel * at91: (24 commits) [ARM] 4615/4: sam926[13]ek buttons updated [ARM] 4765/1: [AT91] AT91CAP9A-DK board support [ARM] 4764/1: [AT91] AT91CAP9 core support [ARM] 4738/1: at91sam9261: Remove udc pullup enabling in board initialisation [ARM] 4761/1: [AT91] Board-support for NEW_LEDs [ARM] 4760/1: [AT91] SPI CS0 errata on AT91RM9200 [ARM] 4759/1: [AT91] Buttons on CSB300 [ARM] 4758/1: [AT91] LEDs [ARM] 4757/1: [AT91] UART initialization [ARM] 4756/1: [AT91] Makefile cleanup [ARM] 4755/1: [AT91] NAND update [ARM] 4754/1: [AT91] SSC library support [ARM] 4753/1: [AT91] Use DMA_BIT_MASK [ARM] 4752/1: [AT91] RTT, RTC and WDT peripherals on SAM9 [ARM] 4751/1: [AT91] ISI peripheral on SAM9263 [ARM] 4750/1: [AT91] STN LCD displays on SAM9261 [ARM] 4734/1: at91sam9263ek: include IRQ for Ethernet PHY [ARM] 4646/1: AT91: configurable HZ, default to 128 [ARM] 4688/1: at91: speed-up irq processing [ARM] 4657/1: AT91: Header definition update ... * ep93xx: [ARM] 4671/1: ep93xx: remove obsolete gpio_line_* operations [ARM] 4670/1: ep93xx: implement IRQT_BOTHEDGE gpio irq sense type [ARM] 4669/1: ep93xx: simplify GPIO code and cleanups [ARM] 4668/1: ep93xx: implement new GPIO API * iop: [ARM] 4770/1: GLAN Tank: correct physmap_flash_data width field [ARM] 4732/1: GLAN Tank: register rtc-rs5c372 i2c device [ARM] 4708/1: iop: update defconfigs for 2.6.24 * kprobes: ARM kprobes: let's enable it ARM kprobes: special hook for the kprobes breakpoint handler ARM kprobes: prevent some functions involved with kprobes from being probed ARM kprobes: don't let a single-stepped stmdb corrupt the exception stack ARM kprobes: add the kprobes hook to the page fault handler ARM kprobes: core code ARM kprobes: instruction single-stepping support * ks8695: [ARM] 4603/1: KS8695: debugfs interface to view pin state [ARM] 4601/1: KS8695: PCI support * misc: [ARM] remove duplicate includes [ARM] CONFIG_DEBUG_STACK_USAGE [ARM] 4689/1: small comment wrap fix [ARM] 4687/1: Trivial arch/arm/kernel/entry-common.S comment fix [ARM] 4666/1: ixp4xx: fix sparse warnings in include/asm-arm/arch-ixp4xx/io.h [ARM] remove reference to non-existent MTD_OBSOLETE_CHIPS [SERIAL] 21285: Report baud rate back via termios [ARM] Remove pointless casts from void pointers, [ARM] Misc minor interrupt handler cleanups [ARM] Remove at91_lcdc.h [ARM] ARRAY_SIZE() cleanup [ARM] Update mach-types * msm: [ARM] msm: dma support for MSM7X00A [ARM] msm: board file for MACH_HALIBUT (QCT MSM7200A) [ARM] msm: irq and timer support for ARCH_MSM7X00A [ARM] msm: core platform support for ARCH_MSM7X00A * s3c2410: (33 commits) [ARM] 4795/1: S3C244X: Add armclk and setparent call [ARM] 4794/1: S3C24XX: Comonise S3C2440 and S3C2442 clock code [ARM] 4793/1: S3C24XX: Add IRQ->GPIO pin mapping function [ARM] 4792/1: S3C24XX: Remove warnings from debug-macro.S [ARM] 4791/1: S3C2412: Make fclk a parent of msysclk [ARM] 4790/1: S3C2412: Fix parent selection for msysclk. [ARM] 4789/1: S3C2412: Add missing CLKDIVN register values [ARM] 4788/1: S3C24XX: Fix paramet to s3c2410_dma_ctrl if S3C2410_DMAF_AUTOSTART used. [ARM] 4787/1: S3C24XX: s3c2410_dma_request() should return the allocated channel number [ARM] 4786/1: S3C2412: Add SPI FIFO controll constants [ARM] 4785/1: S3C24XX: Add _SHIFT definitions for S3C2410_BANKCON registers [ARM] 4784/1: S3C24XX: Fix GPIO restore glitches [ARM] 4783/1: S3C24XX: Add s3c2410_gpio_getpull() [ARM] 4782/1: S3C24XX: Define FIQ_START for any FIQ users [ARM] 4781/1: S3C24XX: DMA suspend and resume support [ARM] 4780/1: S3C2412: Allow for seperate DMA channels for TX and RX [ARM] 4779/1: S3C2412: Add s3c2412_gpio_set_sleepcfg() call [ARM] 4778/1: S3C2412: Add armclk and init from DVS state [ARM] 4777/1: S3C24XX: Ensure clk_set_rate() checks the set_rate method for the clk [ARM] 4775/1: s3c2410: fix compilation error if only s3c2442 cpu is selected ... * sa1100: [ARM] sa1100: add clock source support * vfp: [ARM] 4584/2: ARMv7: Add Advanced SIMD (NEON) extension support [ARM] 4583/1: ARMv7: Add VFPv3 support [ARM] 4582/2: Add support for the common VFP subarchitecture
2008-01-27ixp4xx-i2c-gpioMichael-Luke Jones
Migrate all ixp4xx devices to the bitbanging I2C bus driver utilizing the arch-neutral GPIO API (linux/i2c-gpio.h). Tested by the nslu2-linux and openwrt projects in public firmware releases. Signed-off-by: Michael-Luke Jones <mlj28@cam.ac.uk> Acked-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-26[ARM] remove duplicate includesLucas Woods
Signed-off-by: Lucas Woods <woodzy@gmail.com> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-12-17[ARM] 4694/1: IXP4xx: Update clockevent support for shutdown and resumeKevin Hilman
Add proper support for CLOCK_EVT_MODE_RESUME and in the process fix CLOCK_EVT_MODE_SHUTDOWN so that only the enable bits are toggled for both. Signed-off-by: Kevin Hilman <khilman@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-22Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (60 commits) [ARM] 4524/1: S3C: Move register out of include/asm-arm/arch-s3c2410 [ARM] 4523/1: S3C: Remove FIFO_MAX from uncompression headers [ARM] 4522/1: S3C: split include/asm-arm/arch/memory.h [ARM] 4521/2: S3C: Reorganise VA mapping headers [ARM] 4520/1: S3C: Remove old VA values from static map [ARM] 4519/1: S3C: split S3C2400 values out of S3C24XX map.h [ARM] 4518/1: S3C: Rename watchdog configuration options [ARM] 4517/1: S3C: Fix debug macros for ARM926 output [ARM] 4516/1: S3C: Fix uncompressor serial output for ARM926 [ARM] 4515/1: S3C: Move uncompress code to plat-s3c [ARM] 4514/1: S3C: Rename DEBUG_S3C2410_PORT and DEBUG_S3C_UART [ARM] 4513/1: S3C: Rename CONFIG_S3C2410_LOWLEVEL_UART_PORT [ARM] 4512/1: S3C: rename the debug macros for per-cpu updates [ARM] 4511/1: S3C: updated LLSERIAL Kconfig defines for CPU support [ARM] 4510/1: S3C: split debug-macro support into plat-s3c [ARM] 4509/1: S3C: Create initial arch/arm/plat-s3c [ARM] 4508/1: S3C: Move items to include/asm-arm/plat-s3c [ARM] 4461/1: MXC platform and i.MX31ADS core support [ARM] 4507/1: pxa2xx clock_event_device [ARM] 4497/1: Only allow safe cache configurations on ARMv6 and later ...
2007-07-21clockevents: fix resume logicThomas Gleixner
We need to make sure, that the clockevent devices are resumed, before the tick is resumed. The current resume logic does not guarantee this. Add CLOCK_EVT_MODE_RESUME and call the set mode functions of the clock event devices before resuming the tick / oneshot functionality. Fixup the existing users. Thanks to Nigel Cunningham for tracking down a long standing thinko, which affected the jinxed VAIO. [akpm@linux-foundation.org: xen build fix] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-20[ARM] ixp4xx: fix IRQ GPIO direction configuration for GPIOs >= 8Tim Harvey
I believe that the following patch is necessary to properly configure GPIO line configuration for IRQ's which are mapped to a GPIO line >= 8 (without this patch the wrong GPIO is configured as an input.) Signed-off-by: Tim Harvey <tim_harvey@yahoo.com> Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-12[ARM] If linux/irq.h is included, asm/irq.h is not requiredRussell King
2007-07-12[ARM] 4408/2: Fixup support for gtwx5715 ixp4xx boardMichael-Luke Jones
This patch fixes up compiling of the gtwx5715 board setup code, which has apparently been broken since 2.6.18 and the generic IRQ changes. In addition it removes some unecessary extern declarations in the gtwx5715-pci.c file. Signed-off-by: Michael-Luke Jones <mlj28@cam.ac.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-12[ARM] 4426/2: Netgear WG302 v2 and WAG302 v2 supportImre Kaloz
This patch provides support for the Netgear WG302 v2 and WAG302 v2 AccessPoint series. This patch relies on the patch "Gateway 7001 series support" minimally, as they only have UART2 connected. Updated to stay below the 80 char limit in uncompress.h Signed-off-by: Imre Kaloz <kaloz@openwrt.org> Signed-off-by: Deepak Saxena <dsaxena@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-12[ARM] 4425/2: Gateway 7001 series supportImre Kaloz
This patch provides support for the Gateway 7001 AccessPoint series. Updated to stay below the 80 char limit in uncompress.h Signed-off-by: Imre Kaloz <kaloz@openwrt.org> Signed-off-by: Deepak Saxena <dsaxena@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-12[ARM] 4385/2: ixdp425: NAND supportVladimir Barinov
IXDP425 NAND support (arch specific part). The generic platform driver that is used by ixdp425 platfrom is already in upstream kernel in 2.6.22-rc1. Signed-off-by: Vladimir Barinov <vbarinov@ru.mvista.com> Signed-off-by: Ruslan Sushko <rsushko@ru.mvista.com> Signed-off-by: Deepak Saxena <dsaxena@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-30[ARM] 4410/1: Remove extern declarations in coyote/ixdpg425-pci.cMichael-Luke Jones
This patch removes apparently unnecessary extern declarations in coyote-pci.c and ixdpg425-pci.c within arch/arm/mach-ixp4xx and has been compile-tested without producing warnings or errors. Kernel coding style forbids the use of extern declarations within .c files. Signed-off-by: Michael-Luke Jones <mlj28@cam.ac.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-26[ARM] 4406/1: Trivial NSLU2 / NAS-100D header & setup code cleanupMichael-Luke Jones
This trivial patch updates the nslu2 and nas-100d headers to remove pointless GPIO defines, and updates nslu2-setup.c accordingly. In addition minor style cleanups to some comments are included. Signed-off-by: Michael-Luke Jones <mlj28@cam.ac.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-26[ARM] 4405/1: NSLU2, DSM-G600 frequency fixup codeMichael-Luke Jones
This patch is required as the frequency fixup in nslu2_init does not run sufficiently early in the boot sequence to take effect. In addition the dsmg600 setup code behaviour has been improved such that a 'fixup' routine is avoided. Signed-off-by: Michael-Luke Jones <mlj28@cam.ac.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-26[ARM] 4404/1: Trivial IXP42x Kconfig cleanupMichael-Luke Jones
Avila and IXDP4xx support were separated in 2.6.21 so this comment isn't correct any more. Signed-off-by: Michael-Luke Jones <mlj28@cam.ac.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-20[ARM] spelling fixesSimon Arlott
Spelling fixes in arch/arm/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-08Add IRQF_IRQPOLL flag on armBernhard Walle
Add IRQF_IRQPOLL for each timer interrupt. Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-06Merge branch 'ixp4xx' into develRussell King
Conflicts: include/asm-arm/arch-ixp4xx/io.h
2007-05-05[ARM] 4318/2: DSM-G600 Board SupportMichael-Luke Jones
This patch adds support for the D-Link DSM-G600 Rev A. This is an ARM XScale IXP4xx system relatively similar to the NSLU2 and NAS-100D already supported by mainline. An important difference is Gigabit Ethernet support using the Via Velocity chipset. This patch is the combined work of Michael Westerhof and Alessandro Zummo, with contributions from Michael-Luke Jones. This version addresses review comments from rmk and Deepak Saxena. Signed-off-by: Michael-Luke Jones <mlj28@cam.ac.uk> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Michael Westerhof <mwester@dls.net> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-04-21[ARM] 4259/1: clockevent support for ixp4xx platformKevin Hilman
Update ixp4xx timer support to use new clockevent infrastructure. Signed-off-by: Kevin Hilman <khilman@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-04-21[ARM] 4311/1: ixp4xx: add KIXRP435 platformRuslan V. Sushko
Add Intel KIXRP435 Reference Platform based on IXP43x processor. Fixed after review : access to cp15 removed in identification functions, used access to global processor_id instead Signed-off-by: Vladimir Barinov <vbarinov@ru.mvista.com> Signed-off-by: Ruslan Sushko <rsushko@ru.mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-04-21[ARM] 4275/1: generic gpio layer for ixp4xxMilan Svoboda
This patch brings generic gpio layer support to ixp4xx. It creates functions needed for gpio->irq and irq->gpio translation. It expects and initial value to be passed to gpio_direction_output() which has been introduced by commit 28735a7253a6c24364765e80a5428b4a151fccc2 in Linus git tree. Generic gpio layer is going to be used by pxa2xx_udc driver. Signed-off-by: Milan Svoboda <msvoboda@ra.rockwell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-19Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (117 commits) [ARM] 4058/2: iop32x: set ->broken_parity_status on n2100 onboard r8169 ports [ARM] 4140/1: AACI stability add ac97 timeout and retries [ARM] 4139/1: AACI record support [ARM] 4138/1: AACI: multiple channel support for IRQ handling [ARM] 4211/1: Provide a defconfig for ns9xxx [ARM] 4210/1: base for new machine type "NetSilicon NS9360" [ARM] 4222/1: S3C2443: Remove reference to missing S3C2443_PM [ARM] 4221/1: S3C2443: DMA support [ARM] 4220/1: S3C24XX: DMA system initialised from sysdev [ARM] 4219/1: S3C2443: DMA source definitions [ARM] 4218/1: S3C2412: fix CONFIG_CPU_S3C2412_ONLY wrt to S3C2443 [ARM] 4217/1: S3C24XX: remove the dma channel show at startup [ARM] 4090/2: avoid clash between PXA and SA1111 defines [ARM] 4216/1: add .gitignore entries for ARM specific files [ARM] 4214/2: S3C2410: Add Armzone QT2410 [ARM] 4215/1: s3c2410 usb device: per-platform vbus_draw [ARM] 4213/1: S3C2410 - Update definition of ADCTSC_XY_PST [ARM] 4098/1: ARM: rtc_lock only used with rtc_cmos [ARM] 4137/1: Add kexec support [ARM] 4201/1: SMP barriers pair needed for the secondary boot process ... Fix up conflict due to typedef removal in sound/arm/aaci.h
2007-02-16[PATCH] clocksource: fixup is_continous changes on ARMThomas Gleixner
Fixup the is_contionous replacement by a flag field. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Russell King <rmk@arm.linux.org.uk> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-06[ARM] 4032/1: Add platform resources required for CF driverMichael-Luke Jones
This patch adds the platform resources required to support the ixp4xx-pata-cf libata driver on Avila Gateworks boards. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Michael-Luke Jones <mlj28@cam.ac.uk> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-06[ARM] 4033/1: Add separate Avila board setup codeMichael-Luke Jones
This patch adds support for the Gateworks Avila Network Platform in a separate set of setup files to the IXDP425. This is necessary now that a driver for the Avila CF card slot is available. It also adds support for a minor variant on the Avila board known as the Loft, which has a different number of maximum PCI devices. Signed-off-by: Michael-Luke Jones <mlj28@cam.ac.uk> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
