path: root/arch/arm/mach-ixp4xx/nas100d-pci.c
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-12-05IXP4xx: Introduce IXP4XX_GPIO_IRQ(n) macro and convert IXP4xx platform files.Krzysztof Hałasa
Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2009-12-05IXP4xx: move NAS100D platform macros to the platform code.Krzysztof Hałasa
2008-07-27[ARM] 5179/1: Replace obsolete IRQT_* and __IRQT_* values with IRQ_TYPE_*Dmitry Baryshkov
IRQT_* and __IRQT_* were obsoleted long ago by patch [3692/1]. Remove them completely. Sed script for the reference: s/__IRQT_RISEDGE/IRQ_TYPE_EDGE_RISING/g s/__IRQT_FALEDGE/IRQ_TYPE_EDGE_FALLING/g s/__IRQT_LOWLVL/IRQ_TYPE_LEVEL_LOW/g s/__IRQT_HIGHLVL/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_RISING/IRQ_TYPE_EDGE_RISING/g s/IRQT_FALLING/IRQ_TYPE_EDGE_FALLING/g s/IRQT_BOTHEDGE/IRQ_TYPE_EDGE_BOTH/g s/IRQT_LOW/IRQ_TYPE_LEVEL_LOW/g s/IRQT_HIGH/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_PROBE/IRQ_TYPE_PROBE/g s/IRQT_NOEDGE/IRQ_TYPE_NONE/g Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-01[ARM] 3682/2: ARM: Convert ixp4xx to generic irq handlingThomas Gleixner
Patch from Thomas Gleixner From: Thomas Gleixner <tglx@linutronix.de> Fixup the conversion to generic irq subsystem. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-04[ARM] 3220/1: Remove gpio_isr_line_clear() from NAS 100dDeepak Saxena
Patch from Deepak Saxena This patch removes referneces to gpio_isr_line_clear() from the NAS 100d platform implementation. Depends on 3192/1 and 3215/1 Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-04[ARM] 3215/1: Iomega NAS 100d (MACH_NAS100D) machine supportRod Whitby
Patch from Rod Whitby This patch adds support for a new arm/ixp4xx machine - the Iomega NAS 100d network attached storage product. The NAS100D is a consumer device containing a 266MHz Intel IXP420 processor, 16MB of flash, 64MB of RAM, a 160Gb internal IDE hard disk, and 802.11b/g wireless on an Atheros mini-PCI card. Work on porting the latest 2.6.x kernel to this device is being done by the NSLU2-Linux project (the same team who maintains the port to the Linksys NSLU2 device). In particular, the majority of this patch was authored by Alessandro Zummo, based on the work done for MACH_NSLU2 support by the NSLU2-Linux core team of developers. MACH_NAS100D (as implemented by this patch) can be enabled in jumbo ixp4xx kernels without any affect on the other machines supported by that kernel. This patch applies cleanly against 2.6.15-rc7 and should be trivial to apply to later kernel versions. It does not depend upon any other patches. Modified files (and number of lines inserted): arch/arm/mach-ixp4xx/Kconfig | 8 arch/arm/mach-ixp4xx/Makefile | 1 include/asm-arm/arch-ixp4xx/hardware.h | 1 include/asm-arm/arch-ixp4xx/irqs.h | 9 include/asm-arm/arch-ixp4xx/nas100d.h | 75 arch/arm/mach-ixp4xx/nas100d-pci.c | 77 arch/arm/mach-ixp4xx/nas100d-power.c | 69 arch/arm/mach-ixp4xx/nas100d-setup.c | 133 -- Rod Whitby (NSLU2-Linux project lead) Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
