path: root/arch/arm/mach-iop13xx/pci.c
2013-01-03ARM: drivers: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-07Merge branch 'late/fixes' into fixesOlof Johansson
This is a series from Arnd that fixes a number of compiler warnings when building defconfigs on ARM. * late/fixes: ARM: footbridge: nw_gpio_lock is raw_spin_lock ARM: mv78xx0: correct addr_map_cfg __initdata annotation ARM: footbridge: remove RTC_IRQ definition ARM: soc: dependency warnings for errata ARM: ks8695: __arch_virt_to_dma type handling ARM: rpc: check device_register return code in ecard_probe ARM: davinci: don't mark da850_register_cpufreq as __init ARM: iop13xx: fix iq81340sc_atux_map_irq prototype ARM: iop13xx: mark iop13xx_scan_bus as __devinit ARM: mv78xx0: mark mv78xx0_timer_init as __init_refok ARM: s3c24xx: fix multiple section mismatch warnings ARM: at91: unused variable in at91_pm_verify_clocks ARM: at91: skip at91_io_desc definition for NOMMU ARM: pxa: work around duplicate definition of GPIO24_SSP1_SFRM ARM: pxa: remove sharpsl_fatal_check function ARM: pxa: define palmte2_pxa_keys conditionally ARM: pxa: Wunused-result warning in viper board file ARM: shark: fix shark_pci_init return code Fixed trivial conflicts in arch/arm/mach-at91/setup.c. Signed-off-by: Olof Johansson <olof@lixom.net>
2012-10-07ARM: iop13xx: mark iop13xx_scan_bus as __devinitArnd Bergmann
pci_scan_root_bus is __devinit, so iop13xx_scan_bus has to be the same in order to safely call it. This is ok because the function itself is only called from the hwpci->scan callback. WARNING: vmlinux.o(.text+0x10138): Section mismatch in reference from the function iop13xx_scan_bus() to the function .devinit.text:pci_scan_root_bus() The function iop13xx_scan_bus() references the function __devinit pci_scan_root_bus(). This is often because iop13xx_scan_bus lacks a __devinit annotation or the annotation of pci_scan_root_bus is wrong. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Lennert Buytenhek <kernel@wantstofly.org> Cc: Dan Williams <djbw@fb.com>
2012-09-22Merge branch 'cleanup/__iomem' into next/cleanupOlof Johansson
__iomem annotation cleanup branch from Arnd. * cleanup/__iomem: (21 commits) net: seeq: use __iomem pointers for MMIO video: da8xx-fb: use __iomem pointers for MMIO scsi: eesox: use __iomem pointers for MMIO serial: ks8695: use __iomem pointers for MMIO input: rpcmouse: use __iomem pointers for MMIO ARM: samsung: use __iomem pointers for MMIO ARM: spear13xx: use __iomem pointers for MMIO ARM: sa1100: use __iomem pointers for MMIO ARM: prima2: use __iomem pointers for MMIO ARM: nomadik: use __iomem pointers for MMIO ARM: msm: use __iomem pointers for MMIO ARM: lpc32xx: use __iomem pointers for MMIO ARM: ks8695: use __iomem pointers for MMIO ARM: ixp4xx: use __iomem pointers for MMIO ARM: iop32x: use __iomem pointers for MMIO ARM: iop13xx: use __iomem pointers for MMIO ARM: integrator: use __iomem pointers for MMIO ARM: imx: use __iomem pointers for MMIO ARM: ebsa110: use __iomem pointers for MMIO ARM: at91: use __iomem pointers for MMIO ... Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-19ARM: iop13xx: use __iomem pointers for MMIOArnd Bergmann
ARM is moving to stricter checks on readl/write functions, so we need to use the correct types everywhere. Cc: Rob Herring <rob.herring@calxeda.com> Cc: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-07-26ARM: iop13xx: use fixed PCI i/o mappingRob Herring
Move iop13xx PCI to fixed i/o mapping and remove io.h. This changes the PCIe bus address to start at 0x10000. Let's hope this works. If it does not, the alternative would be to revert the value we write into OIOTVR to zero and set sys->io_offset to 64K. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2012-07-26iop13xx: use more regular PCI I/O space handlingArnd Bergmann
iop13xx confuses I/O port numbers with physical addresses, which breaks legacy ISA I/O access behind PCI bridges and makes it unnecessarily hard to unify the inb/outb accessors with other platforms. This removes the special-casing and just puts all I/O ports into a single 128KB virtually mapped I/O port range starting at port zero. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-02-23arm/PCI: get rid of device resource fixupsBjorn Helgaas
Tell the PCI core about host bridge address translation so it can take care of bus-to-resource conversion for us. CC: Russell King <linux@arm.linux.org.uk> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-01-06arm/PCI: convert to pci_scan_root_bus() for correct root bus resourcesBjorn Helgaas
Convert from pci_scan_bus() to pci_scan_root_bus() and remove root bus resource fixups. This fixes the problem of "early" and "header" quirks seeing incorrect root bus resources. CC: Russell King <linux@arm.linux.org.uk> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-10-31arm: Add export.h to ARM specific files as required.Paul Gortmaker
These files all make use of one of the EXPORT_SYMBOL variants or the THIS_MODULE macro. So they will need <linux/export.h> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-07-29Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: remove printks about disabled bridge windows PCI: fold pci_calc_resource_flags() into decode_bar() PCI: treat mem BAR type "11" (reserved) as 32-bit, not 64-bit, BAR PCI: correct pcie_set_readrq write size PCI: pciehp: change wait time for valid configuration access x86/PCI: Preserve existing pci=bfsort whitelist for Dell systems PCI: ARI is a PCIe v2 feature x86/PCI: quirks: Use pci_dev->revision PCI: Make the struct pci_dev * argument of pci_fixup_irqs const. PCI hotplug: cpqphp: use pci_dev->vendor PCI hotplug: cpqphp: use pci_dev->subsystem_{vendor|device} x86/PCI: config space accessor functions should not ignore the segment argument PCI: Assign values to 'pci_obff_signal_type' enumeration constants x86/PCI: reduce severity of host bridge window conflict warnings PCI: enumerate the PCI device only removed out PCI hieratchy of OS when re-scanning PCI PCI: PCIe AER: add aer_recover_queue x86/PCI: select direct access mode for mmconfig option PCI hotplug: Rename is_ejectable which also exists in dock.c
2011-07-22PCI: Make the struct pci_dev * argument of pci_fixup_irqs const.Ralf Baechle
Aside of the usual motivation for constification, this function has a history of being abused a hook for interrupt and other fixups so I turned this function const ages ago in the MIPS code but it should be done treewide. Due to function pointer passing in varous places a few other functions had to be constified as well. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> To: Anton Vorontsov <avorontsov@mvista.com> To: Chris Metcalf <cmetcalf@tilera.com> To: Colin Cross <ccross@android.com> Acked-by: "David S. Miller" <davem@davemloft.net> To: Eric Miao <eric.y.miao@gmail.com> To: Erik Gilling <konkers@android.com> Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> To: "H. Peter Anvin" <hpa@zytor.com> To: Imre Kaloz <kaloz@openwrt.org> To: Ingo Molnar <mingo@redhat.com> To: Ivan Kokshaysky <ink@jurassic.park.msu.ru> To: Jesse Barnes <jbarnes@virtuousgeek.org> To: Krzysztof Halasa <khc@pm.waw.pl> To: Lennert Buytenhek <kernel@wantstofly.org> To: Matt Turner <mattst88@gmail.com> To: Nicolas Pitre <nico@fluxnic.net> To: Olof Johansson <olof@lixom.net> Acked-by: Paul Mundt <lethal@linux-sh.org> To: Richard Henderson <rth@twiddle.net> To: Russell King <linux@arm.linux.org.uk> To: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-alpha@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: linux-pci@vger.kernel.org Cc: linux-sh@vger.kernel.org Cc: linux-tegra@vger.kernel.org Cc: sparclinux@vger.kernel.org Cc: x86@kernel.org Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-07-12ARM: convert PCI defines to variablesRob Herring
Convert PCIBIOS_MIN_IO and PCIBIOS_MIN_MEM to variables to allow multi-platform builds. This also removes the requirement for a platform to have a mach/hardware.h. The default values for i/o and mem are 0x1000 and 0x01000000, respectively. Per Arnd Bergmann, other values are likely to be incorrect, but this commit does not try to address that issue. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2010-07-27ARM: 6269/1: Add 'code' parameter for hook_fault_code()Kirill A. Shutemov
Add one more parameter to hook_fault_code() to be able to set 'code' field of struct fsr_info. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-03-24[ARM] fix leak in iop13xx/pciAlan Cox
Another leak found by Daniel Marjamäki Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-03-06[ARM] replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-21Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: (22 commits) [ARM] spelling fixes [ARM] at91_adc parenthesis balance [ARM] 4400/1: S3C24XX: Add high-speed MMC device definition [ARM] 4399/2: S3C2443: Fix SMDK2443 nand timings [ARM] 4398/1: S3C2443: Fix watchdog IRQ number [ARM] 4397/1: S3C2443: remove SDI0/1 IRQ ambiguity [ARM] 4396/1: S3C2443: Add missing HCLK clocks [ARM] 4395/1: S3C24XX: add include of <linux/sysdev.h> to relevant machines [ARM] 4388/1: no need for arm/mm mmap range checks for non-mmu [ARM] 4387/1: fix /proc/cpuinfo formatting for pre-ARM7 parts [ARM] ARMv6: add CPU_HAS_ASID configuration [ARM] integrator: fix pci_v3 compile error with DEBUG_LL [ARM] gic: Fix gic cascade irq handling [ARM] Silence OMAP kernel configuration warning [ARM] Update ARM syscalls [ARM] 4384/1: S3C2412/13 SPI registers offset correction [ARM] 4383/1: iop: fix usage of '__init' and 'inline' in iop files [ARM] 4382/1: iop13xx: fix msi support [ARM] Remove Integrator/CP SMP platform support [ARM] 4378/1: KS8695: Serial driver fix ...
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-20[ARM] spelling fixesSimon Arlott
Spelling fixes in arch/arm/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-16[ARM] 4383/1: iop: fix usage of '__init' and 'inline' in iop filesDan Williams
WARNING: arch/arm/mach-iop13xx/built-in.o - Section mismatch: reference to .init.text:iop13xx_pcie_map_irq from .text between 'iop13xx_pci_setup' (at offset 0x7fc) and 'iop13xx_map_pci_memory' While fixing this warning I also recalled Adrian Bunk's recommendation to not use inline in .c files, as 'iop13xx_map_pci_memory' is needlessly inlined. Removing 'inline' uncovered some dead code so that is cleaned up as well. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-11[ARM] iop13xx: msi supportDaniel Wolstenholme
Enable devices to signal interrupts via PCI memory cycles. rev6: * fix enable/disable typo, Michael Ellerman rev5: * fix up ack, enable, and disable for iop13xx_msi_chip rev4: * move smp compile fix to separate patch * use dynamic_irq_init in create_irq() * hookup mask/unmask routines in iop13xx_msi_chip rev3: * change msi.c to use linux/smp.h instead of asm/smp.h * call dynamic_irq_cleanup at destroy_irq time rev2: * destroy_irq did not take the full 128 bits of msi_irq_in_use into account * added missing '&' for calls to test_and_set_bit and clear_bit [ebiederm@xmission.com: review comments/suggestions] [dan.j.williams@intel.com: cleanups/forward port to 2.6-git] Signed-off-by: Daniel Wolstenholme <daniel.e.wolstenholme@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-06Merge branches 'arm-mm', 'at91', 'clkevts', 'imx', 'iop', 'misc', 'netx', ↵Russell King
'ns9xxx', 'omap', 'pxa', 'rpc', 's3c' and 'sa1100' into devel
2007-05-05[ARM] mm 10: allow memory type to be specified with ioremapRussell King
__ioremap() took a set of page table flags (specifically the cacheable and bufferable bits) to control the mapping type. However, with the advent of ARMv6, this is far too limited. Replace the page table flags with a memory type index, so that the desired attributes can be selected from the mem_type table. Finally, to prevent silent miscompilation due to the differing arguments, rename the __ioremap() and __ioremap_pfn() functions. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-04-30[ARM] 4341/1: iop13xx: fix i/o address translationDan Williams
PCI devices were being programmed with an incorrect base address value. This patch moves I/O space into a 16-bit addressable region and corrects the i/o offset. Much thanks to Martin Michlmayr for tracking this issue and testing debug patches. Cc: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-07[ARM] 3995/1: iop13xx: add iop13xx supportDan Williams
The iop348 processor integrates an Xscale (XSC3 512KB L2 Cache) core with a Serial Attached SCSI (SAS) controller, multi-ported DDR2 memory controller, 3 Application Direct Memory Access (DMA) controllers, a 133Mhz PCI-X interface, a x8 PCI-Express interface, and other peripherals to form a system-on-a-chip RAID subsystem engine. The iop342 processor replaces the SAS controller with a second Xscale core for dual core embedded applications. The iop341 processor is the single core version of iop342. This patch supports the two Intel customer reference platforms iq81340mc for external storage and iq81340sc for direct attach (HBA) development. The developer's manual is available here: ftp://download.intel.com/design/iio/docs/31503701.pdf Changelog: * removed virtual addresses from resource definitions * cleaned up some unnecessary #include's Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
