path: root/arch/arm/mach-imx/generic.c
2006-05-04[ARM] 3490/1: i.MX: move uart resources to board filesSascha Hauer
Patch from Sascha Hauer This patch moves the i.MX uart resources and the gpio pin setup to the board files. This allows the boards to decide how many internal uarts are connected to the outside world and whether they use rts/cts or not. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-04-02[ARM] 3457/1: i.MX: SD/MMC support for i.MX/MX1Pavel Pisa
Patch from Pavel Pisa This patch adds support of i.MX/MX1 SD/MMC controller. It has been significantly redesigned from the original Sascha Hauer's version to support scatter-gather DMA, to conform to latest Pierre Ossman's and Russell King's MMC-SD Linux 2.6.x infrastructure. The handling of all events has been moved to the softirq context and is designed with no busy-looping in mind. Unfortunately some controller bugs has to be overcome by limited looping about 2-20 usec but these are observed only for initial card recognition phase. There are still some missing/missed IRQs problems under heavy load. Help of somebody with access to the full SDHC design information is probably necessary. Regenerated against 2.6.16-git-060402 to solve clash with other patches. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-31Merge master.kernel.org:/home/rmk/linux-2.6-drvmodelLinus Torvalds
Manual #include fixups for clashes - there may be some unnecessary
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[ARM] 3000/1: Replace map_desc.physical with map_desc.pfn: iMXDeepak Saxena
Patch from Deepak Saxena iMX map_desc.pfn conversion Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-04[ARM] 2950/1: i.MX gpio setup functionSascha Hauer
Patch from Sascha Hauer Current implementation of imx_gpio_mode does not allow to configure all alternate routing possibilities of the i.MX. With this patch every bit in the gpio setup registers has a corresponding bit in the gpio_mode parameter, so every routing should be possible now. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-05-03[PATCH] ARM: 2661/1: imxfb includeSascha Hauer
Patch from Sascha Hauer This patch adds the missing include files for the i.MX framebuffer driver. Signed-off-by: Sascha Hauer Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
