path: root/arch/arm/mach-imx/cpufreq.c
2009-05-07[ARM] remove arch-imxSascha Hauer
arch-imx is superseeded by the MXC architecture support. This patch removes arch/arm/mach-imx from the kernel. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-05IMX: introduce clock APISascha Hauer
This patch introduces the clock API for i.MX and converts all in-Kernel drivers to use it. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2007-10-04[CPUFREQ] move policy's governor initialisation out of low-level drivers ↵Thomas Renninger
into cpufreq core Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Andi Kleen <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Jones <davej@redhat.com>
2007-05-20[ARM] spelling fixesSimon Arlott
Spelling fixes in arch/arm/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-03-12[ARM] 4255/1: i.MX/MX1 Correct MPU PLL reference clock value.Pavel Pisa
Only System PLL clock source is selectable by CSCR_SYSTEM_SEL bit. MPU PLL is driven by 512*CLK32 for each case. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-03-12[ARM] 4254/1: i.MX/MX1 CPU Frequency scaling honor boot loader set BCLK_DIV.Pavel Pisa
The minimal bus clock prescaler should be kept at value selected by the board / boot loader designer. Switching frequency above startup limit could lead to the external memory/devices misbehave. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-01-24[ARM] 4092/1: i.MX/MX1 CPU Frequency scaling latency definitionPavel Pisa
The transition latency has to be defined and reasonably small to allow on-demand and conservative governors. The value has been defined according to manual. The imx_set_target() protected against seen out of range requests now. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-13[ARM] 3992/1: i.MX/MX1 CPU Frequency scaling supportPavel Pisa
Support to change MX1 CPU frequency at runtime. Tested on PiKRON's PiMX1 board and seems to be fully stable up to 200 MHz end even as low as 8 MHz. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
