path: root/arch/arm/mach-exynos4/setup-i2c5.c
2011-11-06ARM: EXYNOS: Add ARCH_EXYNOS and reorganize arch/arm/mach-exynosKukjin Kim
The arch/arm/mach-exynos4 directory (CONFIG_ARCH_EXYNOS4) has made for plaforms based on EXYNOS4 SoCs. But since upcoming Samsung's SoCs such as EXYNOS5 (ARM Cortex A15) can reuse most codes in current mach-exynos4, one mach-exynos directory will be used for them. This patch changes to CONFIG_ARCH_EXYNOS (arch/arm/mach-exynos) but keeps original CONFIG_ARCH_EXYNOS4 in mach-exynos/Kconfig to avoid changing in driver side. Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-02-22ARM: EXYNOS4: Update device supportKukjin Kim
This patch updates device support of EXYNOS4 according to the change of ARCH name, EXYNOS4. Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
