path: root/arch/arm/mach-ep93xx/Makefile
2015-07-08ARM: ep93xx: move timer to its own fileLinus Walleij
This breaks the timer code out of the core file in preparation for refactoring. Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com> Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-10-02kbuild: remove unnecessary variable initializaionsMasahiro Yamada
Clearing obj-y, obj-m, obj-n, obj- in each Makefile is a useless habit. They are non-exported variables; therefore they are always empty whenever descending into each subdirectory. (Moreorver, obj-y and obj-m are also set to empty at the beginning of scripts/Makefile.build) Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Peter Foley <pefoley2@pefoley.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-03-14ep93xx: Move crunch code to mach-ep93xx directoryRyan Mallon
The crunch code in arch/arm/kernel is specific to the EP93xx. Move it to the mach-ep93xx directory. This removes the need for the EP93XX_SYSCON defines to be exported to arch/arm/kernel. Signed-off-by: Ryan Mallon <rmallon@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Reviewed-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: Hartley Sweeten <hsweeten@visionengravers.com>
2011-10-17ep93xx: add support Vision EP9307 SoMHartley Sweeten
Add support for Vision Engraving Systems EP9307 based SoM. Signed-off-by: Hartley Sweeten <hartleys@visionengravers.com> Acked-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-07-22Merge branch 'spi/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'spi/next' of git://git.secretlab.ca/git/linux-2.6: (34 commits) spi/imx: add device tree probe support spi/imx: copy gpio number passed by platform data into driver private data spi/imx: use soc name in spi device type naming scheme spi/imx: merge type SPI_IMX_VER_0_7 into SPI_IMX_VER_0_4 spi/imx: do not use spi_imx2_3 to name SPI_IMX_VER_2_3 function and macro spi/imx: use mx21 to name SPI_IMX_VER_0_0 function and macro spi/imx: do not make copy of spi_imx_devtype_data spi/dw: Add spi number into spi irq desc spi/tegra: Use engineering names in DT compatible property spi/fsl_spi: fix CPM spi driver mach-s3c2410: remove unused spi-gpio.h file spi: remove obsolete spi-s3c24xx-gpio driver mach-gta2: remove unused spi-gpio.h include mach-qt2410: convert to spi_gpio mach-jive: convert to spi_gpio spi/pxa2xx: Remove unavailable ssp_type from documentation spi/bfin_spi: uninline fat queue funcs spi/bfin_spi: constify pin array spi/bfin_spi: use structs for accessing hardware regs spi/topcliff-pch: Support new device ML7223 IOH ... Fix up trivial conflict in arch/arm/mach-ep93xx/Makefile
2011-06-08ep93xx: remove the old M2P DMA codeMika Westerberg
Since we have converted all existing users of the old DMA API to use the DMA engine API the old code can be dropped. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: Ryan Mallon <rmallon@gmail.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-08ep93xx: add dmaengine platform codeMika Westerberg
Add platform support code for the new EP93xx dmaengine driver. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Signed-off-by: Ryan Mallon <rmallon@gmail.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-06gpio/ep93xx: move driver to drivers/gpioH Hartley Sweeten
The GPIO driver should reside in drivers/gpio. v3: Change Kconfig option to def_bool y v2: Make the Kconfig symbol a silent option, dependent on ARCH_EP93XX Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-02-15ARM: 5937/1: Add support for EP9315 based Snapper CL15 boardRyan Mallon
Add support for Bluewater Systems EP9315 based Snapper CL15 single board computer module. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> Acked-by: Hartley Sweeten <hartleys@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-01-25ARM: 5892/1: ep93xx: Add support for Simplemachines Sim.One boardRyan Mallon
Add support for the Simplemachines EP9307 based Sim.One board. Cc: Hartley Sweeten <hartleys@visionengravers.com> Cc: Sergio Sorrenti <sergio.sorrenti@gmail.com> Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> Acked-by: Hartley Sweeten <hartleys@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-05-15[ARM] 5504/1: ep93xx: Merge all edb93xx platformsHartley Sweeten
The Cirrus Logic EDB93xx development board platform init files share redundant code. The only differences are in the flash memory configuration, MACH_TYPE, and additional on-board I2C devices. This patch merges all of them into one file. Cc: Lennert Buytenhek <buytenh@wantstofly.org> Cc: Herbert Valerio Riedel <hvr@gnu.org> Cc: Toufeeq Hussain <toufeeq_hussain@infosys.com> Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-03-03[ARM] 5414/2: ep93xx m2p dma coreRyan Mallon
Add m2p dma support to the ep93xx Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-12-01[ARM] 5309/1: ep93xx: add edb9307a platformHartley Sweeten
Add Cirrus Logic EDB9307A Dev Board to arch/arm/mach-ep93xx Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] 4988/1: Add GPIO lib support to the EP93xxRyan Mallon
Adds support for the generic GPIO lib to the EP93xx family. The gpio handling code has been moved from core.c to a new file called gpio.c. The GPIO based IRQ code has not been changed. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] 4572/1: ep93xx: add cirrus logic edb9307 supportHerbert Valerio Riedel
This patch adds support for the Cirrus Logic EDB9307, an evaluation board based on the Cirrus Logic EP9307 SoC, which features amongst other things 64M RAM, 32M NOR flash, 3 USB host ports, audio in/out, two serial ports and a 10/100 ethernet interface. Signed-off-by: Herbert Valerio Riedel <hvr@gnu.org> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-06[ARM] 4047/1: Add initial board support for Contec Hypercontrol Micro9 boards.Manfred Gruber
Contec Micro9 (H/M/L) boards based on Cirrus Logic ep93xx (ep9315/ep9307/ep9302). Signed-off-by: Manfred Gruber <m.gruber@tirol.com> Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-07[ARM] 3993/1: ep93xx: add cirrus logic edb9302a supportLennert Buytenhek
Add support for the Cirrus Logic EDB9302A Evaluation Board. Confirmed to work by Chase Douglas. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-01[ARM] 3964/1: ep93xx: add ads sphere supportLennert Buytenhek
Add initial board support for the ADS Sphere board. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-25[ARM] 3811/1: ep93xx: add cirrus logic edb9312 supportLennert Buytenhek
Add Cirrus Logic EDB9312 support. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-01[ARM] 3706/2: ep93xx: add cirrus logic edb9315a supportLennert Buytenhek
Patch from Lennert Buytenhek This patch adds support for the Cirrus Logic EDB9315A, an evaluation board based on the Cirrus Logic EP9315 SoC, with 64M RAM, two USB host ports, audio in/out, three serial ports, 10/100 ethernet, and IDE, VGA, and LCD interfaces. The EDB9315A is a low-cost version of the EDB9315, and has only 16M of NOR flash, while the EDB9315 has 32M. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-29[ARM] 3674/1: ep93xx: add cirrus logic edb9302 supportLennert Buytenhek
Patch from Lennert Buytenhek This patch adds support for the Cirrus Logic EDB9302, an evaluation board based on the Cirrus Logic EP9302 SoC, with 32M RAM, one USB host port, audio in/out, two serial ports and a 10/100 ethernet interface. George Kashperko submitted the original patch, this patch is a rewrite using the newer physmap platform driver. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-28[ARM] 3671/1: ep93xx: add cirrus logic edb9315 supportLennert Buytenhek
Patch from Lennert Buytenhek This patch adds support for the Cirrus Logic EDB9315, an evaluation board based on the Cirrus Logic EP9315 SoC, with 64M RAM, two USB host ports, audio in/out, three serial ports, 10/100 ethernet, and IDE, VGA, and LCD interfaces. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-24[ARM] 3634/1: ep93xx: initial implementation of the clk_* APILennert Buytenhek
Patch from Lennert Buytenhek Add an initial implementation of the clk_* API for the cirrus ep93xx to the tree. The initial implementation is somewhat minimal, with the intention of extending it as we go along. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] 3369/1: ep93xx: add core cirrus ep93xx supportLennert Buytenhek
Patch from Lennert Buytenhek This patch adds support for the Cirrus ep93xx series of CPUs. The ep93xx is an ARM920T based CPU with two VICs, PL010 based UARTs, IrDA, MaverickCrunch floating point coprocessor, between 24 and 64 GPIOs, ethernet, OHCI USB and, depending on the model, pcmcia, raster engine, graphics accelerator, IDE controller and a bunch of other stuff. This patch adds the core ep93xx support code, and support for the Glomation GESBC-9312-sx and the Technologic Systems TS-72xx SBCs. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
