path: root/arch/arm/mach-at91/generic.h
2011-05-25at91: drop at572d940hf supportJean-Christophe PLAGNIOL-VILLARD
no-one use it and it's nearly impossible get a board to work on it and the Mainline implementation was never finished Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com> Cc: Andrew Victor <linux@maxim.org.za>
2011-05-25at91rm9200: introduce at91rm9200_set_type to specficy cpu packageJean-Christophe PLAGNIOL-VILLARD
as we can not detect it by defaut the type will be bga introduce cpu_is_at91rm9200_bga and cpu_is_at91rm9200_pqfp Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
2011-05-25at91: switch to CLKDEV_LOOKUPJean-Christophe PLAGNIOL-VILLARD
we do not change the clock naming convention so does not need to switch the AVR32 yet Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
2011-05-25at91: fix map_io init usageJean-Christophe PLAGNIOL-VILLARD
switch early init to init_early and introduce soc map_io with this Patch we will not do any more early device setup during the map io tks to Russell to point the new call back Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Andrew Victor <linux@maxim.org.za>
2010-10-26AT91: reset: extend alternate reset procedure to several chipsNicolas Ferre
Several at91sam9 chips need the alternate reset procedure to be sure to halt SDRAM smoothly before resetting the chip. This is an extension of previous patch "Fix AT91SAM9G20 reset" to all chips affected. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2010-01-20ARM: 5850/1: [AT91] AT572D940HF processor supportAndrew Victor
Add support for the Atmel AT572D940HF processor (DIOPSIS range). This processor integrates an ARM926 core, a DSP and the SoC peripherals usually found on an AT91 processor (USART, SSC, SPI, TWI, CAN, etc) Signed-off-by: Antonio R. Costa <costa.antonior@gmail.com> Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-06-27[ARM] 5572/1: at91: Support for at91sam9g45 series: core chip & board supportNicolas Ferre
Here are the at91 specific files dedicated to the at91sam9g45 series. They mimic the traditional at91 way of managing chips & boards. The first board that embeds at91sam9g45 chip is the AT91SAM9G45-EKES. In the future, the main board for this 9g45 series will be the AT91SAM9M10G45-EK (I choose this last name for the board file). Simple drivers are enabled in _devices and board- files. Newer peripheral support will be added in future patches. Incuded peripherals support (for now): - USART - SPI - Ethernet - NAND flash - LCD - gpio/joystick/buttons - leds and pwm Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-12[ARM] 5373/2: Add gpiolib support to AT91Ryan Mallon
Add support for gpiolib, including debugfs output, to the AT91 family. The at91_get/set_gpio_value calls still exist since they are used by the atmel serial driver. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4739/1: at91sam9263: make gpio bank C and D irqs workDavid Brownell
On the at91sam9263, IRQs for GPIO banks C and D don't currently work. This is because banks C, D, and E share one clock and toplevel IRQ, but the AT91 code setting up and handling GPIO IRQs expects no sharing. This patch: - Fixes GPIO IRQ setup and handling to cope with GPIO banks that are shared like on sam9263 chips, by setting up a list of those banks and making the IRQ dispatching logic scan that list. - Precomputes the address of each bank's registers, saving it with other per-bank data so that it no longer needs to be constantly recomputed during IRQs and other GPIO operations. That shrinks hot-path code, while helping the GPIO bank irq updates. - Fixes a minor bug where IRQ_TYPE_NONE was wrongly rejected (it just means "use the default", which is "both edges" here). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] 4764/1: [AT91] AT91CAP9 core supportAndrew Victor
Add support for Atmel's AT91CAP9 Customizable Microcontroller family. <http://www.atmel.com/products/AT91CAP/Default.asp> Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] 4535/1: AT91x40 function prototypesGreg Ungerer
Prototypes for the at91x40 CPU support functions. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-11[ARM] 4370/3: AT91: Support for Atmel AT91SAM9RL processors.Andrew Victor
Add support for Atmel's new AT91SAM9RL range of processors. Includes similar peripherals as other AT91SAM9 processors, but with a High-speed USB controller and various sizes of internal SRAM. Signed-off-by: Nicolas Ferre <nicolas.ferre@rfo.atmel.com> Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-08[ARM] 4145/2: AT91: Add support for AT91SAM9263 processorAndrew Victor
Add support for the Atmel AT91SAM9263 processor. It is similar to the AT91SAM9260 but with more integrated peripherals, 5 GPIO banks, etc. Original patch from Nicolas Ferre. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-08[ARM] 4124/1: Rename mach-at91rm9200 and arch-at91rm9200 directoriesAndrew Victor
Now that Linux includes support for the Atmel AT91SAM9260 and AT91SAM9261 processors in addition to the original Atmel AT91RM9200 (with support for more AT91 processors pending), the "mach-at91rm9200" and "arch-at91rm9200" directories should be renamed to indicate their more generic nature. The following git commands should be run BEFORE applying this patch: git-mv arch/arm/mach-at91rm9200 arch/arm/mach-at91 git-mv include/asm-arm/arch-at91rm9200 include/asm-arm/arch-at91 Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
