path: root/arch/arm/mach-at91/at91sam9rl.c
2011-07-28at91: factorize sram initJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
2011-07-28at91: move register clocks to soc generic initJean-Christophe PLAGNIOL-VILLARD
2011-07-28at91: move clock subsystem init to soc generic initJean-Christophe PLAGNIOL-VILLARD
2011-07-28at91: use structure to store the current socJean-Christophe PLAGNIOL-VILLARD
instead of reading the registers everytime the current implementation respect the following constrain: - allow 1 to n soc to be enabled - allow to have a virtual cpu type and subtype - always detect the cpu type and subtype and report it - detect if the soc support is enabled - prepare for sysfs export support - drop soc specific code via compiler when the soc not enabled (via cpu_is_xxx) Today if we read the exid we will have the same value for 9g35 and 9m11 and we will need to check the cidr too with the new implementation we just need to check the soc subtype this will also allow to have specific virtual subtype for rm9200 which the board will have to specify via at91rm9200_set_type(int) as we have no way to detect it. this implementation is inspired by the SH cpu detection support Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
2011-07-28at91: remove AT91_DBGU offset from dbgu register macroJean-Christophe PLAGNIOL-VILLARD
to make the soc base specified at runtime instead of compiled time Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2011-07-28at91: factorize at91 interrupts init to socJean-Christophe PLAGNIOL-VILLARD
they are the same except the default priority Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
2011-07-28at91: introduce commom AT91_BASE_SYSJean-Christophe PLAGNIOL-VILLARD
On all at91 except rm9200 and x40 have the System Controller starts at address 0xffffc000 and has a size of 16KiB. On rm9200 it's start at 0xfffe4000 of 111KiB with non reserved data starting at 0xfffff000 This patch removes the individual definitions of AT91_BASE_SYS and replaces them with a common version at base 0xfffffc000 and size 16KiB and map the same memory space Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
2011-06-25at91: fix udc, ehci and mmc clock device name for cap9/9g45/9rlJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2011-05-25at91: switch to CLKDEV_LOOKUPJean-Christophe PLAGNIOL-VILLARD
we do not change the clock naming convention so does not need to switch the AVR32 yet Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
2011-05-25at91: fix map_io init usageJean-Christophe PLAGNIOL-VILLARD
switch early init to init_early and introduce soc map_io with this Patch we will not do any more early device setup during the map io tks to Russell to point the new call back Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Andrew Victor <linux@maxim.org.za>
2010-10-26AT91: reset: extend alternate reset procedure to several chipsNicolas Ferre
Several at91sam9 chips need the alternate reset procedure to be sure to halt SDRAM smoothly before resetting the chip. This is an extension of previous patch "Fix AT91SAM9G20 reset" to all chips affected. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2009-01-08[ARM] fix AT91, davinci, h720x, ks8695, msm, mx2, mx3, netx, omap1, omap2, ↵Russell King
pxa, s3c arch/arm/mach-at91/at91cap9.c:337: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91rm9200.c:301: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9260.c:351: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9261.c:287: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9263.c:312: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9rl.c:304: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-h720x/h7202-eval.c:38: error: implicit declaration of function 'IRQ_CHAINED_GPIOB' arch/arm/mach-ks8695/devices.c:46: error: 'KS8695_IRQ_WAN_RX_STATUS' undeclared here (not in a function) arch/arm/mach-msm/devices.c:28: error: 'INT_UART1' undeclared here (not in a function) arch/arm/mach-mx2/devices.c:233: error: 'MXC_GPIO_IRQ_START' undeclared here (not in a function) arch/arm/mach-mx3/devices.c:128: error: 'MXC_GPIO_IRQ_START' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:140: error: 'INT_730_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:165: error: 'INT_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:200: error: 'INT_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap2/board-apollon.c:286: error: implicit declaration of function 'omap_set_gpio_direction' arch/arm/mach-omap2/mcbsp.c:154: error: 'INT_24XX_MCBSP1_IRQ_RX' undeclared here (not in a function) arch/arm/mach-omap2/mcbsp.c:181: error: 'INT_24XX_MCBSP1_IRQ_RX' undeclared here (not in a function) arch/arm/mach-pxa/e350.c:36: error: 'IRQ_BOARD_START' undeclared here (not in a function) arch/arm/plat-s3c/dev-i2c0.c:32: error: 'IRQ_IIC' undeclared here (not in a function) ... Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-21[ARM] 5258/1: [AT91] PWM controller initializationAndrew Victor
Add platform_devices and configuration of the PWM controller found on Atmel AT91CAP9, SAM9263 and SAM9RL processors. SAM9263 support by Sedji Gaouaou. Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-04[ARM] 4903/1: [AT91] SAM9/CAP9 system shutdownAndrew Victor
Enable system shutdown/power-off on AT91SAM9 and AT91CAP9 based boards. This does not require power-management to be enabled, and the pm_power_off method can be overridden in board-specific files if necessary. Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-11[ARM] 4370/3: AT91: Support for Atmel AT91SAM9RL processors.Andrew Victor
Add support for Atmel's new AT91SAM9RL range of processors. Includes similar peripherals as other AT91SAM9 processors, but with a High-speed USB controller and various sizes of internal SRAM. Signed-off-by: Nicolas Ferre <nicolas.ferre@rfo.atmel.com> Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
