path: root/arch/arm/mach-at91/at91sam9263.c
2007-05-03[ARM] 4351/1: AT91: Define rest of peripheral clocksAndrew Victor
Define and register the remaining peripheral clocks for the AT91 processors. AT91SAM9261 clocks patch by Ivan Zhakov. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-22[ARM] 4231/1: AT91: Merge and typo fixes.Andrew Victor
The duplicate file "include/asm-arm/arch-at91rm9200/entry-macro.S" can be removed - it was already moved to include/asm-arm/arch-at91/. Fix 3 small typo's - two in comments, and the incorrect clock was specified for the LCD device. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-14[ARM] 4189/1: AT91: MACB Ethernet clockAndrew Victor
The MACB Ethernet driver searches for a "macb_clk" clock, so rename the "ether_clk" on the SAM9260 and SAM9263 to "macb_clk". Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-08[ARM] 4145/2: AT91: Add support for AT91SAM9263 processorAndrew Victor
Add support for the Atmel AT91SAM9263 processor. It is similar to the AT91SAM9260 but with more integrated peripherals, 5 GPIO banks, etc. Original patch from Nicolas Ferre. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
