path: root/arch/arm/lib/io-writesl.S
2014-02-25ARM: 7990/1: asm: rename logical shift macros push pull into lspush lspullVictor Kamensky
Renames logical shift macros, 'push' and 'pull', defined in arch/arm/include/asm/assembler.h, into 'lspush' and 'lspull'. That eliminates name conflict between 'push' logical shift macro and 'push' instruction mnemonic. That allows assembler.h to be included in .S files that use 'push' instruction. Suggested-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Victor Kamensky <victor.kamensky@linaro.org> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-01[ARM] 5227/1: Add the ENDPROC declarations to the .S filesCatalin Marinas
This declaration specifies the "function" type and size for various assembly functions, mainly needed for generating the correct branch instructions in Thumb-2. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
