path: root/arch/arm/kernel
2015-02-19ARM: make of_device_ids constUwe Kleine-König
of_device_ids (i.e. compatible strings and the respective data) are not supposed to change at runtime. All functions working with of_device_ids provided by <linux/of.h> work with const of_device_ids. So mark the non-const structs in arch/arm as const, too. While at it also add some __initconst annotations. Acked-by: Jason Cooper <jason@lakedameon.net> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-02-13mm: vmalloc: pass additional vm_flags to __vmalloc_node_range()Andrey Ryabinin
For instrumenting global variables KASan will shadow memory backing memory for modules. So on module loading we will need to allocate memory for shadow and map it at address in shadow that corresponds to the address allocated in module_alloc(). __vmalloc_node_range() could be used for this purpose, except it puts a guard hole after allocated area. Guard hole in shadow memory should be a problem because at some future point we might need to have a shadow memory at address occupied by guard hole. So we could fail to allocate shadow for module_alloc(). Now we have VM_NO_GUARD flag disabling guard page, so we need to pass into __vmalloc_node_range(). Add new parameter 'vm_flags' to __vmalloc_node_range() function. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Signed-off-by: Andrey Konovalov <adech.fo@gmail.com> Cc: Yuri Gribov <tetra2005@gmail.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-12all arches, signal: move restart_block to struct task_structAndy Lutomirski
If an attacker can cause a controlled kernel stack overflow, overwriting the restart block is a very juicy exploit target. This is because the restart_block is held in the same memory allocation as the kernel stack. Moving the restart block to struct task_struct prevents this exploit by making the restart_block harder to locate. Note that there are other fields in thread_info that are also easy targets, at least on some architectures. It's also a decent simplification, since the restart code is more or less identical on all architectures. [james.hogan@imgtec.com: metag: align thread_info::supervisor_stack] Signed-off-by: Andy Lutomirski <luto@amacapital.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Kees Cook <keescook@chromium.org> Cc: David Miller <davem@davemloft.net> Acked-by: Richard Weinberger <richard@nod.at> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Steven Miao <realmz6@gmail.com> Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Tested-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Chris Zankel <chris@zankel.net> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-12Merge branch 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: - clang assembly fixes from Ard - optimisations and cleanups for Aurora L2 cache support - efficient L2 cache support for secure monitor API on Exynos SoCs - debug menu cleanup from Daniel Thompson to allow better behaviour for multiplatform kernels - StrongARM SA11x0 conversion to irq domains, and pxa_timer - kprobes updates for older ARM CPUs - move probes support out of arch/arm/kernel to arch/arm/probes - add inline asm support for the rbit (reverse bits) instruction - provide an ARM mode secondary CPU entry point (for Qualcomm CPUs) - remove the unused ARMv3 user access code - add driver_override support to AMBA Primecell bus * 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (55 commits) ARM: 8256/1: driver coamba: add device binding path 'driver_override' ARM: 8301/1: qcom: Use secondary_startup_arm() ARM: 8302/1: Add a secondary_startup that assumes ARM mode ARM: 8300/1: teach __asmeq that r11 == fp and r12 == ip ARM: kprobes: Fix compilation error caused by superfluous '*' ARM: 8297/1: cache-l2x0: optimize aurora range operations ARM: 8296/1: cache-l2x0: clean up aurora cache handling ARM: 8284/1: sa1100: clear RCSR_SMR on resume ARM: 8283/1: sa1100: collie: clear PWER register on machine init ARM: 8282/1: sa1100: use handle_domain_irq ARM: 8281/1: sa1100: move GPIO-related IRQ code to gpio driver ARM: 8280/1: sa1100: switch to irq_domain_add_simple() ARM: 8279/1: sa1100: merge both GPIO irqdomains ARM: 8278/1: sa1100: split irq handling for low GPIOs ARM: 8291/1: replace magic number with PAGE_SHIFT macro in fixup_pv code ARM: 8290/1: decompressor: fix a wrong comment ARM: 8286/1: mm: Fix dma_contiguous_reserve comment ARM: 8248/1: pm: remove outdated comment ARM: 8274/1: Fix DEBUG_LL for multi-platform kernels (without PL01X) ARM: 8273/1: Seperate DEBUG_UART_PHYS from DEBUG_LL on EP93XX ...
2015-02-10Merge tag 'pm+acpi-3.20-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management updates from Rafael Wysocki: "We have a few new features this time, including a new SFI-based cpufreq driver, a new devfreq driver for Tegra Activity Monitor, a new devfreq class for providing its governors with raw utilization data and a new ACPI driver for AMD SoCs. Still, the majority of changes here are reworks of existing code to make it more straightforward or to prepare it for implementing new features on top of it. The primary example is the rework of ACPI resources handling from Jiang Liu, Thomas Gleixner and Lv Zheng with support for IOAPIC hotplug implemented on top of it, but there is quite a number of changes of this kind in the cpufreq core, ACPICA, ACPI EC driver, ACPI processor driver and the generic power domains core code too. The most active developer is Viresh Kumar with his cpufreq changes. Specifics: - Rework of the core ACPI resources parsing code to fix issues in it and make using resource offsets more convenient and consolidation of some resource-handing code in a couple of places that have grown analagous data structures and code to cover the the same gap in the core (Jiang Liu, Thomas Gleixner, Lv Zheng). - ACPI-based IOAPIC hotplug support on top of the resources handling rework (Jiang Liu, Yinghai Lu). - ACPICA update to upstream release 20150204 including an interrupt handling rework that allows drivers to install raw handlers for ACPI GPEs which then become entirely responsible for the given GPE and the ACPICA core code won't touch it (Lv Zheng, David E Box, Octavian Purdila). - ACPI EC driver rework to fix several concurrency issues and other problems related to events handling on top of the ACPICA's new support for raw GPE handlers (Lv Zheng). - New ACPI driver for AMD SoCs analogous to the LPSS (Low-Power Subsystem) driver for Intel chips (Ken Xue). - Two minor fixes of the ACPI LPSS driver (Heikki Krogerus, Jarkko Nikula). - Two new blacklist entries for machines (Samsung 730U3E/740U3E and 510R) where the native backlight interface doesn't work correctly while the ACPI one does (Hans de Goede). - Rework of the ACPI processor driver's handling of idle states to make the code more straightforward and less bloated overall (Rafael J Wysocki). - Assorted minor fixes related to ACPI and SFI (Andreas Ruprecht, Andy Shevchenko, Hanjun Guo, Jan Beulich, Rafael J Wysocki, Yaowei Bai). - PCI core power management modification to avoid resuming (some) runtime-suspended devices during system suspend if they are in the right states already (Rafael J Wysocki). - New SFI-based cpufreq driver for Intel platforms using SFI (Srinidhi Kasagar). - cpufreq core fixes, cleanups and simplifications (Viresh Kumar, Doug Anderson, Wolfram Sang). - SkyLake CPU support and other updates for the intel_pstate driver (Kristen Carlson Accardi, Srinivas Pandruvada). - cpufreq-dt driver cleanup (Markus Elfring). - Init fix for the ARM big.LITTLE cpuidle driver (Sudeep Holla). - Generic power domains core code fixes and cleanups (Ulf Hansson). - Operating Performance Points (OPP) core code cleanups and kernel documentation update (Nishanth Menon). - New dabugfs interface to make the list of PM QoS constraints available to user space (Nishanth Menon). - New devfreq driver for Tegra Activity Monitor (Tomeu Vizoso). - New devfreq class (devfreq_event) to provide raw utilization data to devfreq governors (Chanwoo Choi). - Assorted minor fixes and cleanups related to power management (Andreas Ruprecht, Krzysztof Kozlowski, Rickard Strandqvist, Pavel Machek, Todd E Brandt, Wonhong Kwon). - turbostat updates (Len Brown) and cpupower Makefile improvement (Sriram Raghunathan)" * tag 'pm+acpi-3.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (151 commits) tools/power turbostat: relax dependency on APERF_MSR tools/power turbostat: relax dependency on invariant TSC Merge branch 'pci/host-generic' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci into acpi-resources tools/power turbostat: decode MSR_*_PERF_LIMIT_REASONS tools/power turbostat: relax dependency on root permission ACPI / video: Add disable_native_backlight quirk for Samsung 510R ACPI / PM: Remove unneeded nested #ifdef USB / PM: Remove unneeded #ifdef and associated dead code intel_pstate: provide option to only use intel_pstate with HWP ACPI / EC: Add GPE reference counting debugging messages ACPI / EC: Add query flushing support ACPI / EC: Refine command storm prevention support ACPI / EC: Add command flushing support. ACPI / EC: Introduce STARTED/STOPPED flags to replace BLOCKED flag ACPI: add AMD ACPI2Platform device support for x86 system ACPI / table: remove duplicate NULL check for the handler of acpi_table_parse() ACPI / EC: Update revision due to raw handler mode. ACPI / EC: Reduce ec_poll() by referencing the last register access timestamp. ACPI / EC: Fix several GPE handling issues by deploying ACPI_GPE_DISPATCH_RAW_HANDLER mode. ACPICA: Events: Enable APIs to allow interrupt/polling adaptive request based GPE handling model ...
2015-02-10Merge tag 'pci-v3.20-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI changes from Bjorn Helgaas: "Enumeration - Move domain assignment from arm64 to generic code (Lorenzo Pieralisi) - ARM: Remove artificial dependency on pci_sys_data domain (Lorenzo Pieralisi) - ARM: Move to generic PCI domains (Lorenzo Pieralisi) - Generate uppercase hex for modalias var in uevent (Ricardo Ribalda Delgado) - Add and use generic config accessors on ARM, PowerPC (Rob Herring) Resource management - Free resources on failure in of_pci_get_host_bridge_resources() (Lorenzo Pieralisi) - Fix infinite loop with ROM image of size 0 (Michel Dänzer) PCI device hotplug - Handle surprise add even if surprise removal isn't supported (Bjorn Helgaas) Virtualization - Mark AMD/ATI VGA devices that don't reset on D3hot->D0 transition (Alex Williamson) - Add DMA alias quirk for Adaptec 3405 (Alex Williamson) - Add Wellsburg (X99) to Intel PCH root port ACS quirk (Alex Williamson) - Add ACS quirk for Emulex NICs (Vasundhara Volam) MSI - Fail MSI-X mappings if there's no space assigned to MSI-X BAR (Yijing Wang) Freescale Layerscape host bridge driver - Fix platform_no_drv_owner.cocci warnings (Julia Lawall) NVIDIA Tegra host bridge driver - Remove unnecessary tegra_pcie_fixup_bridge() (Lucas Stach) Renesas R-Car host bridge driver - Fix error handling of irq_of_parse_and_map() (Dmitry Torokhov) TI Keystone host bridge driver - Fix error handling of irq_of_parse_and_map() (Dmitry Torokhov) - Fix misspelling of current function in debug output (Julia Lawall) Xilinx AXI host bridge driver - Fix harmless format string warning (Arnd Bergmann) Miscellaneous - Use standard parsing functions for ASPM sysfs setters (Chris J Arges) - Add pci_device_to_OF_node() stub for !CONFIG_OF (Kevin Hao) - Delete unnecessary NULL pointer checks (Markus Elfring) - Add and use defines for PCIe Max_Read_Request_Size (Rafał Miłecki) - Include clk.h instead of clk-private.h (Stephen Boyd)" * tag 'pci-v3.20-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (48 commits) PCI: Add pci_device_to_OF_node() stub for !CONFIG_OF PCI: xilinx: Convert to use generic config accessors PCI: xgene: Convert to use generic config accessors PCI: tegra: Convert to use generic config accessors PCI: rcar: Convert to use generic config accessors PCI: generic: Convert to use generic config accessors powerpc/powermac: Convert PCI to use generic config accessors powerpc/fsl_pci: Convert PCI to use generic config accessors ARM: ks8695: Convert PCI to use generic config accessors ARM: sa1100: Convert PCI to use generic config accessors ARM: integrator: Convert PCI to use generic config accessors PCI: versatile: Add DT-based ARM Versatile PB PCIe host driver ARM: dts: versatile: add PCI controller binding of/pci: Free resources on failure in of_pci_get_host_bridge_resources() PCI: versatile: Add DT docs for ARM Versatile PB PCIe driver PCI: Fail MSI-X mappings if there's no space assigned to MSI-X BAR r8169: use PCI define for Max_Read_Request_Size [SCSI] esas2r: use PCI define for Max_Read_Request_Size tile: use PCI define for Max_Read_Request_Size rapidio/tsi721: use PCI define for Max_Read_Request_Size ...
2015-02-10Merge branch 'acpi-resources'Rafael J. Wysocki
* acpi-resources: (23 commits) Merge branch 'pci/host-generic' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci into acpi-resources x86/irq, ACPI: Implement ACPI driver to support IOAPIC hotplug ACPI: Add interfaces to parse IOAPIC ID for IOAPIC hotplug x86/PCI: Refine the way to release PCI IRQ resources x86/PCI/ACPI: Use common ACPI resource interfaces to simplify implementation x86/PCI: Fix the range check for IO resources PCI: Use common resource list management code instead of private implementation resources: Move struct resource_list_entry from ACPI into resource core ACPI: Introduce helper function acpi_dev_filter_resource_type() ACPI: Add field offset to struct resource_list_entry ACPI: Translate resource into master side address for bridge window resources ACPI: Return translation offset when parsing ACPI address space resources ACPI: Enforce stricter checks for address space descriptors ACPI: Set flag IORESOURCE_UNSET for unassigned resources ACPI: Normalize return value of resource parser functions ACPI: Fix a bug in parsing ACPI Memory24 resource ACPI: Add prefetch decoding to the address space parser ACPI: Move the window flag logic to the combined parser ACPI: Unify the parsing of address_space and ext_address_space ACPI: Let the parser return false for disabled resources ...
2015-02-10Merge branch 'devel-stable' into for-nextRussell King
2015-02-10Merge branches 'debug', 'fixes', 'l2c' (early part), 'misc' and 'sa1100' ↵Russell King
into for-next
2015-02-10ARM: 8302/1: Add a secondary_startup that assumes ARM modeStephen Boyd
Some platforms always enter the kernel in ARM mode even if the kernel is compiled for THUMB2. Add a small wrapper on top of secondary_startup() that switches into THUMB2 mode. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-02-05PCI: Use common resource list management code instead of private implementationJiang Liu
Use common resource list management data structure and interfaces instead of private implementation. Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Acked-by: Will Deacon <will.deacon@arm.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-04Merge branch 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "A number of ARM fixes, the biggest is fixing a regression caused by appended DT blobs exceeding 64K, causing the decompressor fixup code to fail to patch the DT blob. Another important fix is for the ASID allocator from Will Deacon which prevents some rare crashes seen on some systems. Lastly, there's a build fix for v7M systems when printk support is disabled. The last two remaining fixes are more cosmetic - the IOMMU one prevents an annoying harmless warning message, and we disable the kernel strict memory permissions on non-MMU which can't support it anyway" * 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: ARM: 8299/1: mm: ensure local active ASID is marked as allocated on rollover ARM: 8298/1: ARM_KERNMEM_PERMS only works with MMU enabled ARM: 8295/1: fix v7M build for !CONFIG_PRINTK ARM: 8294/1: ATAG_DTB_COMPAT: remove the DT workspace's hardcoded 64KB size ARM: 8288/1: dma-mapping: don't detach devices without an IOMMU during teardown
2015-01-29ARM: 8295/1: fix v7M build for !CONFIG_PRINTKRob Herring
Minimal builds for v7M are broken when printk is disabled. The caller is assembly so add the necessary ifdef around the call. Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-01-24Merge branch 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "Another round of small ARM fixes. restore_user_regs early stack deallocation is buggy in the presence of FIQs which switch to SVC mode, and could lead to corrupted registers being returned to a user process given an inopportune FIQ event. Another bug was spotted in the ARM perf code where it could lose track of perf counter overflows, leading to incorrect perf results. Lastly, a bug in arm_add_memory() was spotted where the memory sizes aren't properly rounded. As most people pass properly rounded sizes, this hasn't been noticed" * 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: ARM: 8292/1: mm: fix size rounding-down of arm_add_memory() function ARM: 8255/1: perf: Prevent wraparound during overflow ARM: 8266/1: Remove early stack deallocation from restore_user_regs
2015-01-21ARM: 8291/1: replace magic number with PAGE_SHIFT macro in fixup_pv codeMasahiro Yamada
This line converts PHYS_OFFSET into PHYS_PFN_OFFSET. It is better to use PAGE_SHIFT rather than the magic number 12. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-01-21ARM: 8248/1: pm: remove outdated commentBrian Norris
As of commit abda1bd5f4e04054ce083c298fcd68a743e9df03 __cpu_suspend() takes only 2 arguments, and those arguments are passed by the platform code. This comment thus makes no sense, as cpu_suspend() is not actually hiding any arguments. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-01-21ARM: 8292/1: mm: fix size rounding-down of arm_add_memory() functionMasahiro Yamada
The current rounding of "size" is wrong: - If "start" is sufficiently near the next page boundary, "size" is decremented by more than enough and the last page is lost. - If "size" is sufficiently small, it is wrapped around and gets a bogus value. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-01-16ARM: 8261/1: l2c: Get outer cache .write_sec callback from mach_desc only if ↵Tomasz Figa
not NULL Certain platforms (i.e. Exynos) might need to set .write_sec callback from firmware initialization which is happenning in .init_early callback of machine descriptor. However current code will overwrite the pointer with whatever is present in machine descriptor, even though it can be already set earlier. This patch fixes this by making the assignment conditional, depending on whether current .write_sec callback is NULL. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Tested-by: Nishanth Menon <nm@ti.com> Acked-by: Nishanth Menon <nm@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-01-13ARM: kprobes: enable OPTPROBES for ARM 32Wang Nan
This patch introduce kprobeopt for ARM 32. Limitations: - Currently only kernel compiled with ARM ISA is supported. - Offset between probe point and optinsn slot must not larger than 32MiB. Masami Hiramatsu suggests replacing 2 words, it will make things complex. Futher patch can make such optimization. Kprobe opt on ARM is relatively simpler than kprobe opt on x86 because ARM instruction is always 4 bytes aligned and 4 bytes long. This patch replace probed instruction by a 'b', branch to trampoline code and then calls optimized_callback(). optimized_callback() calls opt_pre_handler() to execute kprobe handler. It also emulate/simulate replaced instruction. When unregistering kprobe, the deferred manner of unoptimizer may leave branch instruction before optimizer is called. Different from x86_64, which only copy the probed insn after optprobe_template_end and reexecute them, this patch call singlestep to emulate/simulate the insn directly. Futher patch can optimize this behavior. Signed-off-by: Wang Nan <wangnan0@huawei.com> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Will Deacon <will.deacon@arm.com> Reviewed-by: Jon Medhurst (Tixy) <tixy@linaro.org> Signed-off-by: Jon Medhurst <tixy@linaro.org>
2015-01-13ARM: kprobes: disallow probing stack consuming instructionsWang Nan
This patch prohibits probing instructions for which the stack requirements are unable to be determined statically. Some test cases are found not work again after the modification, this patch also removes them. Signed-off-by: Wang Nan <wangnan0@huawei.com> Reviewed-by: Jon Medhurst <tixy@linaro.org> Signed-off-by: Jon Medhurst <tixy@linaro.org>
2015-01-12ARM: 8255/1: perf: Prevent wraparound during overflowDaniel Thompson
If the overflow threshold for a counter is set above or near the 0xffffffff boundary then the kernel may lose track of the overflow causing only events that occur *after* the overflow to be recorded. Specifically the problem occurs when the value of the performance counter overtakes its original programmed value due to wrap around. Typical solutions to this problem are either to avoid programming in values likely to be overtaken or to treat the overflow bit as the 33rd bit of the counter. Its somewhat fiddly to refactor the code to correctly handle the 33rd bit during irqsave sections (context switches for example) so instead we take the simpler approach of avoiding values likely to be overtaken. We set the limit to half of max_period because this matches the limit imposed in __hw_perf_event_init(). This causes a doubling of the interrupt rate for large threshold values, however even with a very fast counter ticking at 4GHz the interrupt rate would only be ~1Hz. Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-01-12ARM: 8266/1: Remove early stack deallocation from restore_user_regsDaniel Thompson
Currently restore_user_regs deallocates the SVC stack early in its execution and relies on no exception being taken between the deallocation and the registers being restored. The introduction of a default FIQ handler that also uses the SVC stack breaks this assumption and can result in corrupted register state. This patch works around the problem by removing the early stack deallocation and using r2 as a temporary instead. I have not found a way to do this without introducing an extra mov instruction to the macro. Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-01-11Merge branch 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "Three small fixes from over the Christmas period, and wiring up the new execveat syscall for ARM" * 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: ARM: 8275/1: mm: fix PMD_SECT_RDONLY undeclared compile error ARM: 8253/1: mm: use phys_addr_t type in map_lowmem() for kernel mem region ARM: 8249/1: mm: dump: don't skip regions ARM: wire up execveat syscall
2015-01-11Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Mostly tooling fixes, but also some kernel side fixes: uncore PMU driver fix, user regs sampling fix and an instruction decoder fix that unbreaks PEBS precise sampling" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/x86/uncore/hsw-ep: Handle systems with only two SBOXes perf/x86_64: Improve user regs sampling perf: Move task_pt_regs sampling into arch code x86: Fix off-by-one in instruction decoder perf hists browser: Fix segfault when showing callchain perf callchain: Free callchains when hist entries are deleted perf hists: Fix children sort key behavior perf diff: Fix to sort by baseline field by default perf list: Fix --raw-dump option perf probe: Fix crash in dwarf_getcfi_elf perf probe: Fix to fall back to find probe point in symbols perf callchain: Append callchains only when requested perf ui/tui: Print backtrace symbols when segfault occurs perf report: Show progress bar for output resorting
2015-01-09perf: Move task_pt_regs sampling into arch codeAndy Lutomirski
On x86_64, at least, task_pt_regs may be only partially initialized in many contexts, so x86_64 should not use it without extra care from interrupt context, let alone NMI context. This will allow x86_64 to override the logic and will supply some scratch space to use to make a cleaner copy of user regs. Tested-by: Jiri Olsa <jolsa@kernel.org> Signed-off-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: chenggang.qcg@taobao.com Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mark Salter <msalter@redhat.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Will Deacon <will.deacon@arm.com> Cc: linux-arm-kernel@lists.infradead.org Link: http://lkml.kernel.org/r/e431cd4c18c2e1c44c774f10758527fb2d1025c4.1420396372.git.luto@amacapital.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-01-09ARM: probes: move all probe code to dedicate directoryWang Nan
In discussion on LKML (https://lkml.org/lkml/2014/11/28/158), Russell King suggests to move all probe related code to arch/arm/probes. This patch does the work. Due to dependency on 'arch/arm/kernel/patch.h', this patch also moves patch.h to 'arch/arm/include/asm/patch.h', and related '#include' directives are also midified to '#include <asm/patch.h>'. Following is an overview of this patch: ./arch/arm/kernel/ ./arch/arm/probes/ |-- Makefile |-- Makefile |-- probes-arm.c ==> |-- decode-arm.c |-- probes-arm.h ==> |-- decode-arm.h |-- probes-thumb.c ==> |-- decode-thumb.c |-- probes-thumb.h ==> |-- decode-thumb.h |-- probes.c ==> |-- decode.c |-- probes.h ==> |-- decode.h | |-- kprobes | | |-- Makefile |-- kprobes-arm.c ==> | |-- actions-arm.c |-- kprobes-common.c ==> | |-- actions-common.c |-- kprobes-thumb.c ==> | |-- actions-thumb.c |-- kprobes.c ==> | |-- core.c |-- kprobes.h ==> | |-- core.h |-- kprobes-test-arm.c ==> | |-- test-arm.c |-- kprobes-test.c ==> | |-- test-core.c |-- kprobes-test.h ==> | |-- test-core.h |-- kprobes-test-thumb.c ==> | `-- test-thumb.c | `-- uprobes | |-- Makefile |-- uprobes-arm.c ==> |-- actions-arm.c |-- uprobes.c ==> |-- core.c |-- uprobes.h ==> `-- core.h | `-- patch.h ==> arch/arm/include/asm/patch.h Signed-off-by: Wang Nan <wangnan0@huawei.com> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Jon Medhurst <tixy@linaro.org>
2015-01-07ARM: wire up execveat syscallRussell King
2015-01-04Revert "ARM: 7830/1: delay: don't bother reporting bogomips in /proc/cpuinfo"Pavel Machek
Commit 9fc2105aeaaf ("ARM: 7830/1: delay: don't bother reporting bogomips in /proc/cpuinfo") breaks audio in python, and probably elsewhere, with message FATAL: cannot locate cpu MHz in /proc/cpuinfo I'm not the first one to hit it, see for example https://theredblacktree.wordpress.com/2014/08/10/fatal-cannot-locate-cpu-mhz-in-proccpuinfo/ https://devtalk.nvidia.com/default/topic/765800/workaround-for-fatal-cannot-locate-cpu-mhz-in-proc-cpuinf/?offset=1 Reading original changelog, I have to say "Stop breaking working setups. You know who you are!". Signed-off-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-27ARM/PCI: Move to generic PCI domainsLorenzo Pieralisi
Most if not all ARM PCI host controller device drivers either ignore the domain field in the pci_sys_data structure or just increment it every time a host controller is probed, using it as a domain counter. Therefore, instead of relying on pci_sys_data to stash the domain number in a standard location, ARM pcibios code can be moved to the newly introduced generic PCI domains code, implemented in commits: 41e5c0f81d3e ("of/pci: Add pci_get_new_domain_nr() and of_get_pci_domain_nr()") 670ba0c8883b ("PCI: Add generic domain handling") ARM code is made to select PCI_DOMAINS_GENERIC by default, which builds core PCI code that assigns the domain number through the generic function: void pci_bus_assign_domain_nr(...) that relies on a DT property to define the domain number or falls back to a counter according to a predefined logic; its usage replaces the current domain assignment code in PCI host controllers present in the kernel. Tested-by: Lucas Stach <l.stach@pengutronix.de> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Yijing Wang <wangyijing@huawei.com> Reviewed-By: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> # mvebu Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Lucas Stach <l.stach@pengutronix.de> Acked-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Phil Edworthy <phil.edworthy@renesas.com> Acked-by: Arnd Bergmann <arnd@arndb.de> CC: Mohit Kumar <mohit.kumar@st.com>
2014-12-18Merge tag 'pm+acpi-3.19-rc1-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull more ACPI and power management updates from Rafael Wysocki: "These are regression fixes (leds-gpio, ACPI backlight driver, operating performance points library, ACPI device enumeration messages, cpupower tool), other bug fixes (ACPI EC driver, ACPI device PM), some cleanups in the operating performance points (OPP) framework, continuation of CONFIG_PM_RUNTIME elimination, a couple of minor intel_pstate driver changes, a new MAINTAINERS entry for it and an ACPI fan driver change needed for better support of thermal management in user space. Specifics: - Fix a regression in leds-gpio introduced by a recent commit that inadvertently changed the name of one of the properties used by the driver (Fabio Estevam). - Fix a regression in the ACPI backlight driver introduced by a recent fix that missed one special case that had to be taken into account (Aaron Lu). - Drop the level of some new kernel messages from the ACPI core introduced by a recent commit to KERN_DEBUG which they should have used from the start and drop some other unuseful KERN_ERR messages printed by ACPI (Rafael J Wysocki). - Revert an incorrect commit modifying the cpupower tool (Prarit Bhargava). - Fix two regressions introduced by recent commits in the OPP library and clean up some existing minor issues in that code (Viresh Kumar). - Continue to replace CONFIG_PM_RUNTIME with CONFIG_PM throughout the tree (or drop it where that can be done) in order to make it possible to eliminate CONFIG_PM_RUNTIME (Rafael J Wysocki, Ulf Hansson, Ludovic Desroches). There will be one more "CONFIG_PM_RUNTIME removal" batch after this one, because some new uses of it have been introduced during the current merge window, but that should be sufficient to finally get rid of it. - Make the ACPI EC driver more robust against race conditions related to GPE handler installation failures (Lv Zheng). - Prevent the ACPI device PM core code from attempting to disable GPEs that it has not enabled which confuses ACPICA and makes it report errors unnecessarily (Rafael J Wysocki). - Add a "force" command line switch to the intel_pstate driver to make it possible to override the blacklisting of some systems in that driver if needed (Ethan Zhao). - Improve intel_pstate code documentation and add a MAINTAINERS entry for it (Kristen Carlson Accardi). - Make the ACPI fan driver create cooling device interfaces witn names that reflect the IDs of the ACPI device objects they are associated with, except for "generic" ACPI fans (PNP ID "PNP0C0B"). That's necessary for user space thermal management tools to be able to connect the fans with the parts of the system they are supposed to be cooling properly. From Srinivas Pandruvada" * tag 'pm+acpi-3.19-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (32 commits) MAINTAINERS: add entry for intel_pstate ACPI / video: update the skip case for acpi_video_device_in_dod() power / PM: Eliminate CONFIG_PM_RUNTIME NFC / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM SCSI / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM ACPI / EC: Fix unexpected ec_remove_handlers() invocations Revert "tools: cpupower: fix return checks for sysfs_get_idlestate_count()" tracing / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM x86 / PM: Replace CONFIG_PM_RUNTIME in io_apic.c PM: Remove the SET_PM_RUNTIME_PM_OPS() macro mmc: atmel-mci: use SET_RUNTIME_PM_OPS() macro PM / Kconfig: Replace PM_RUNTIME with PM in dependencies ARM / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM sound / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM phy / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM video / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM tty / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM spi: Replace CONFIG_PM_RUNTIME with CONFIG_PM ACPI / PM: Do not disable wakeup GPEs that have not been enabled ACPI / utils: Drop error messages from acpi_evaluate_reference() ...
2014-12-16Merge tag 'iommu-config-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC/iommu configuration update from Arnd Bergmann: "The iomm-config branch contains work from Will Deacon, quoting his description: This series adds automatic IOMMU and DMA-mapping configuration for OF-based DMA masters described using the generic IOMMU devicetree bindings. Although there is plenty of future work around splitting up iommu_ops, adding default IOMMU domains and sorting out automatic IOMMU group creation for the platform_bus, this is already useful enough for people to port over their IOMMU drivers and start using the new probing infrastructure (indeed, Marek has patches queued for the Exynos IOMMU). The branch touches core ARM and IOMMU driver files, and the respective maintainers (Russell King and Joerg Roedel) agreed to have the contents merged through the arm-soc tree. The final version was ready just before the merge window, so we ended up delaying it a bit longer than the rest, but we don't expect to see regressions because this is just additional infrastructure that will get used in drivers starting in 3.20 but is unused so far" * tag 'iommu-config-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: iommu: store DT-probed IOMMU data privately arm: dma-mapping: plumb our iommu mapping ops into arch_setup_dma_ops arm: call iommu_init before of_platform_populate dma-mapping: detect and configure IOMMU in of_dma_configure iommu: fix initialization without 'add_device' callback iommu: provide helper function to configure an IOMMU for an of master iommu: add new iommu_ops callback for adding an OF device dma-mapping: replace set_arch_dma_coherent_ops with arch_setup_dma_ops iommu: provide early initialisation hook for IOMMU drivers
2014-12-14Merge tag 'char-misc-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver updates from Greg KH: "Here's the big char/misc driver update for 3.19-rc1 Lots of little things all over the place in different drivers, and a new subsystem, "coresight" has been added. Full details are in the shortlog" * tag 'char-misc-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (73 commits) parport: parport_pc, do not remove parent devices early spmi: Remove shutdown/suspend/resume kernel-doc carma-fpga-program: drop videobuf dependency carma-fpga: drop videobuf dependency carma-fpga-program.c: fix compile errors i8k: Fix temperature bug handling in i8k_get_temp() cxl: Name interrupts in /proc/interrupt CXL: Return error to PSL if IRQ demultiplexing fails & print clearer warning coresight-replicator: remove .owner field for driver coresight: fixed comments in coresight.h coresight: fix typo in comment in coresight-priv.h coresight: bindings for coresight drivers coresight: Adding ABI documentation w1: support auto-load of w1_bq27000 module. w1: avoid potential u16 overflow cn: verify msg->len before making callback mei: export fw status registers through sysfs mei: read and print all six FW status registers mei: txe: add cherrytrail device id mei: kill cached host and me csr values ...
2014-12-13ARM / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PMRafael J. Wysocki
After commit b2b49ccbdd54 (PM: Kconfig: Set PM_RUNTIME if PM_SLEEP is selected) PM_RUNTIME is always set if PM is set, so #ifdef blocks depending on CONFIG_PM_RUNTIME may now be changed to depend on CONFIG_PM. Replace CONFIG_PM_RUNTIME with CONFIG_PM everywhere in the code under arch/arm/ (the defconfig files will be modified later). Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Nishanth Menon <nm@ti.com> Acked-by: Sekhar Nori <nsekhar@ti.com> Acked-by: Santosh Shilimkar <ssantosh@kernel.org>
2014-12-12Merge branch 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "The major updates included in this update are: - Clang compatible stack pointer accesses by Behan Webster. - SA11x0 updates from Dmitry Eremin-Solenikov. - kgdb handling of breakpoints with read-only text/modules - Support for Privileged-no-execute feature on ARMv7 to prevent userspace code execution by the kernel. - AMBA primecell bus handling of irq-safe runtime PM - Unwinding support for memset/memzero/memmove/memcpy functions - VFP fixes for Krait CPUs and improvements in detecting the VFP architecture - A number of code cleanups (using pr_*, removing or reducing the severity of a couple of kernel messages, splitting ftrace asm code out to a separate file, etc.) - Add machine name to stack dump output" * 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (62 commits) ARM: 8247/2: pcmcia: sa1100: make use of device clock ARM: 8246/2: pcmcia: sa1111: provide device clock ARM: 8245/1: pcmcia: soc-common: enable/disable socket clocks ARM: 8244/1: fbdev: sa1100fb: make use of device clock ARM: 8243/1: sa1100: add a clock alias for sa1111 pcmcia device ARM: 8242/1: sa1100: add cpu clock ARM: 8221/1: PJ4: allow building in Thumb-2 mode ARM: 8234/1: sa1100: reorder IRQ handling code ARM: 8233/1: sa1100: switch to hwirq usage ARM: 8232/1: sa1100: merge GPIO multiplexer IRQ to "normal" irq domain ARM: 8231/1: sa1100: introduce irqdomains support ARM: 8230/1: sa1100: shift IRQs by one ARM: 8229/1: sa1100: replace irq numbers with names in irq driver ARM: 8228/1: sa1100: drop entry-macro.S ARM: 8227/1: sa1100: switch to MULTI_IRQ_HANDLER ARM: 8241/1: Update processor_modes for hyp and monitor mode ARM: 8240/1: MCPM: document mcpm_sync_init() ARM: 8239/1: Introduce {set,clear}_pte_bit ARM: 8238/1: mm: Refine set_memory_* functions ARM: 8237/1: fix flush_pfn_alias ...
2014-12-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) New offloading infrastructure and example 'rocker' driver for offloading of switching and routing to hardware. This work was done by a large group of dedicated individuals, not limited to: Scott Feldman, Jiri Pirko, Thomas Graf, John Fastabend, Jamal Hadi Salim, Andy Gospodarek, Florian Fainelli, Roopa Prabhu 2) Start making the networking operate on IOV iterators instead of modifying iov objects in-situ during transfers. Thanks to Al Viro and Herbert Xu. 3) A set of new netlink interfaces for the TIPC stack, from Richard Alpe. 4) Remove unnecessary looping during ipv6 routing lookups, from Martin KaFai Lau. 5) Add PAUSE frame generation support to gianfar driver, from Matei Pavaluca. 6) Allow for larger reordering levels in TCP, which are easily achievable in the real world right now, from Eric Dumazet. 7) Add a variable of napi_schedule that doesn't need to disable cpu interrupts, from Eric Dumazet. 8) Use a doubly linked list to optimize neigh_parms_release(), from Nicolas Dichtel. 9) Various enhancements to the kernel BPF verifier, and allow eBPF programs to actually be attached to sockets. From Alexei Starovoitov. 10) Support TSO/LSO in sunvnet driver, from David L Stevens. 11) Allow controlling ECN usage via routing metrics, from Florian Westphal. 12) Remote checksum offload, from Tom Herbert. 13) Add split-header receive, BQL, and xmit_more support to amd-xgbe driver, from Thomas Lendacky. 14) Add MPLS support to openvswitch, from Simon Horman. 15) Support wildcard tunnel endpoints in ipv6 tunnels, from Steffen Klassert. 16) Do gro flushes on a per-device basis using a timer, from Eric Dumazet. This tries to resolve the conflicting goals between the desired handling of bulk vs. RPC-like traffic. 17) Allow userspace to ask for the CPU upon what a packet was received/steered, via SO_INCOMING_CPU. From Eric Dumazet. 18) Limit GSO packets to half the current congestion window, from Eric Dumazet. 19) Add a generic helper so that all drivers set their RSS keys in a consistent way, from Eric Dumazet. 20) Add xmit_more support to enic driver, from Govindarajulu Varadarajan. 21) Add VLAN packet scheduler action, from Jiri Pirko. 22) Support configurable RSS hash functions via ethtool, from Eyal Perry. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1820 commits) Fix race condition between vxlan_sock_add and vxlan_sock_release net/macb: fix compilation warning for print_hex_dump() called with skb->mac_header net/mlx4: Add support for A0 steering net/mlx4: Refactor QUERY_PORT net/mlx4_core: Add explicit error message when rule doesn't meet configuration net/mlx4: Add A0 hybrid steering net/mlx4: Add mlx4_bitmap zone allocator net/mlx4: Add a check if there are too many reserved QPs net/mlx4: Change QP allocation scheme net/mlx4_core: Use tasklet for user-space CQ completion events net/mlx4_core: Mask out host side virtualization features for guests net/mlx4_en: Set csum level for encapsulated packets be2net: Export tunnel offloads only when a VxLAN tunnel is created gianfar: Fix dma check map error when DMA_API_DEBUG is enabled cxgb4/csiostor: Don't use MASTER_MUST for fw_hello call net: fec: only enable mdio interrupt before phy device link up net: fec: clear all interrupt events to support i.MX6SX net: fec: reset fep link status in suspend function net: sock: fix access via invalid file descriptor net: introduce helper macro for_each_cmsghdr ...
2014-12-10Merge branch 'irq-irqdomain-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq domain updates from Thomas Gleixner: "The real interesting irq updates: - Support for hierarchical irq domains: For complex interrupt routing scenarios where more than one interrupt related chip is involved we had no proper representation in the generic interrupt infrastructure so far. That made people implement rather ugly constructs in their nested irq chip implementations. The main offenders are x86 and arm/gic. To distangle that mess we have now hierarchical irqdomains which seperate the various interrupt chips and connect them via the hierarchical domains. That keeps the domain specific details internal to the particular hierarchy level and removes the criss/cross referencing of chip internals. The resulting hierarchy for a complex x86 system will look like this: vector mapped: 74 msi-0 mapped: 2 dmar-ir-1 mapped: 69 ioapic-1 mapped: 4 ioapic-0 mapped: 20 pci-msi-2 mapped: 45 dmar-ir-0 mapped: 3 ioapic-2 mapped: 1 pci-msi-1 mapped: 2 htirq mapped: 0 Neither ioapic nor pci-msi know about the dmar interrupt remapping between themself and the vector domain. If interrupt remapping is disabled ioapic and pci-msi become direct childs of the vector domain. In hindsight we should have done that years ago, but in hindsight we always know better :) - Support for generic MSI interrupt domain handling We have more and more non PCI related MSI interrupts, so providing a generic infrastructure for this is better than having all affected architectures implementing their own private hacks. - Support for PCI-MSI interrupt domain handling, based on the generic MSI support. This part carries the pci/msi branch from Bjorn Helgaas pci tree to avoid a massive conflict. The PCI/MSI parts are acked by Bjorn. I have two more branches on top of this. The full conversion of x86 to hierarchical domains and a partial conversion of arm/gic" * 'irq-irqdomain-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (41 commits) genirq: Move irq_chip_write_msi_msg() helper to core PCI/MSI: Allow an msi_controller to be associated to an irq domain PCI/MSI: Provide mechanism to alloc/free MSI/MSIX interrupt from irqdomain PCI/MSI: Enhance core to support hierarchy irqdomain PCI/MSI: Move cached entry functions to irq core genirq: Provide default callbacks for msi_domain_ops genirq: Introduce msi_domain_alloc/free_irqs() asm-generic: Add msi.h genirq: Add generic msi irq domain support genirq: Introduce callback irq_chip.irq_write_msi_msg genirq: Work around __irq_set_handler vs stacked domains ordering issues irqdomain: Introduce helper function irq_domain_add_hierarchy() irqdomain: Implement a method to automatically call parent domains alloc/free genirq: Introduce helper irq_domain_set_info() to reduce duplicated code genirq: Split out flow handler typedefs into seperate header file genirq: Add IRQ_SET_MASK_OK_DONE to support stacked irqchip genirq: Introduce irq_chip.irq_compose_msi_msg() to support stacked irqchip genirq: Add more helper functions to support stacked irq_chip genirq: Introduce helper functions to support stacked irq_chip irqdomain: Do irq_find_mapping and set_type for hierarchy irqdomain in case OF ...
2014-12-09Merge tag 'drivers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Arnd Bergmann: "These are changes for drivers that are intimately tied to some SoC and for some reason could not get merged through the respective subsystem maintainer tree. The largest single change here this time around is the Tegra iommu/memory controller driver, which gets updated to the new iommu DT binding. More drivers like this are likely to follow for the following merge window, but we should be able to do those through the iommu maintainer. Other notable changes are: - reset controller drivers from the reset maintainer (socfpga, sti, berlin) - fixes for the keystone navigator driver merged last time - at91 rtc driver changes related to the at91 cleanups - ARM perf driver changes from Will Deacon - updates for the brcmstb_gisb driver" * tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (53 commits) clocksource: arch_timer: Allow the device tree to specify uninitialized timer registers clocksource: arch_timer: Fix code to use physical timers when requested memory: Add NVIDIA Tegra memory controller support bus: brcmstb_gisb: Add register offset tables for older chips bus: brcmstb_gisb: Look up register offsets in a table bus: brcmstb_gisb: Introduce wrapper functions for MMIO accesses bus: brcmstb_gisb: Make the driver buildable on MIPS of: Add NVIDIA Tegra memory controller binding ARM: tegra: Move AHB Kconfig to drivers/amba amba: Add Kconfig file clk: tegra: Implement memory-controller clock serial: samsung: Fix serial config dependencies for exynos7 bus: brcmstb_gisb: resolve section mismatch ARM: common: edma: edma_pm_resume may be unused ARM: common: edma: add suspend resume hook powerpc/iommu: Rename iommu_[un]map_sg functions rtc: at91sam9: add DT bindings documentation rtc: at91sam9: use clk API instead of relying on AT91_SLOW_CLOCK ARM: at91: add clk_lookup entry for RTT devices rtc: at91sam9: rework the Kconfig description ...
2014-12-05Merge branch 'devel-stable' into for-nextRussell King
2014-12-05Merge branches 'fixes', 'misc', 'pm' and 'sa1100' into for-nextRussell King
2014-12-03ARM: 8221/1: PJ4: allow building in Thumb-2 modeArd Biesheuvel
Two files that get included when building the multi_v7_defconfig target fail to build when selecting THUMB2_KERNEL for this configuration. In both cases, we can just build the file as ARM code, as none of its symbols are exported to modules, so there are no interworking concerns. In the iwmmxt.S case, add ENDPROC() declarations so the symbols are annotated as functions, resulting in the linker to emit the appropriate mode switches. Acked-by: Nicolas Pitre <nico@linaro.org> Tested-by: Olof Johansson <olof@lixom.net> Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-12-03ARM: 8241/1: Update processor_modes for hyp and monitor modeStephen Boyd
If the kernel is running in hypervisor mode or monitor mode we'll print UK6_32 or UK10_32 if we call into __show_regs(). Let's update these strings to indicate the new modes that didn't exist when this code was written. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-12-01arm: call iommu_init before of_platform_populateWill Deacon
We need to ensure that the IOMMUs in the system have a chance to perform some basic initialisation before we start adding masters to them. This patch adds a call to of_iommu_init before of_platform_populate. Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2014-11-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2014-11-28Merge branch 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "Another round of relatively small ARM fixes. Thomas spotted that the strex backoff delay bit was a disable bit, so it needed to be clear for this to work. Vladimir spotted that using a restart block for the cache flush operation would return -EINTR, which userspace was not expecting. Dmitry spotted that the auxiliary control register accesses for Xscale were not correct" * 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: ARM: 8226/1: cacheflush: get rid of restarting block ARM: 8222/1: mvebu: enable strex backoff delay ARM: 8216/1: xscale: correct auxiliary register in suspend/resume
2014-11-27ARM: 8226/1: cacheflush: get rid of restarting blockVladimir Murzin
We cannot restart cacheflush safely if a process provides user-defined signal handler and signal is pending. In this case -EINTR is returned and it is expected that process re-invokes syscall. However, there are a few problems with that: * looks like nobody bothers checking return value from cacheflush * but if it did, we don't provide the restart address for that, so the process has to use the same range again * ...and again, what might lead to looping forever So, remove cacheflush restarting code and terminate cache flushing as early as fatal signal is pending. Cc: stable@vger.kernel.org # 3.12+ Reported-by: Chanho Min <chanho.min@lge.com> Signed-off-by: Vladimir Murzin <vladimir.murzin@arm.com> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-11-21ARM/PCI: Remove unused pcibios_add_bus() and pcibios_remove_bus()Yijing Wang
There are no users of the struct hw_pci.add_bus() or .remove_bus() methods, so remove the pointers from hw_pci. That makes pcibios_add_bus() and pcibios_remove_bus() themselves superfluous, so remove them as well. [bhelgaas: changelog] Signed-off-by: Yijing Wang <wangyijing@huawei.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-11-21ARM/PCI: Save MSI controller in pci_sys_dataYijing Wang
Currently ARM associates an MSI controller with a PCI bus by defining pcibios_add_bus() and using it to call a struct hw_pci.add_bus() method. That method sets the struct pci_bus "msi" member. That's unwieldy and unnecessarily couples MSI with the PCI enumeration code. On ARM, all devices under the same PCI host bridge share an MSI controller, so add an msi_controller pointer to the struct pci_sys_data and implement pcibios_msi_controller() to retrieve it. This is a step toward moving the msi_controller pointer into the generic struct pci_host_bridge. [bhelgaas: changelog, take pci_dev instead of pci_bus] Signed-off-by: Yijing Wang <wangyijing@huawei.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-11-21ARM: io.c: clean up EXPORT_SYMBOL()sRussell King
Place EXPORT_SYMBOL()s after the function definition. Tested-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-11-21ARM: move ftrace assembly code to separate fileRussell King
The ftrace assembly code doesn't need to live in entry-common.S and be surrounded with #ifdef CONFIG_FUNCTION_TRACER. Instead, move it to its own file and conditionally assemble it. Tested-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-11-21ARM: add machine name to stack dump outputRussell King
The generic dump_stack() code provides the facility to include the machine name in the stack dump, which can be useful information. Add a call to dump_stack_set_arch_desc() for the generic code to print this information. Tested-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
