path: root/arch/arm/kernel
2006-03-25[ARM] 3030/2: fix permission check in the obscur cmpxchg syscallNicolas Pitre
Patch from Nicolas Pitre Quoting RMK: |pte_write() just says that the page _may_ be writable. It doesn't say |that the MMU is programmed to allow writes. If pte_dirty() doesn't |return true, that means that the page is _not_ writable from userspace. |If you write to it from kernel mode (without using put_user) you'll |bypass the MMU read-only protection and may end up writing to a page |owned by two separate processes. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-25Merge nommu treeRussell King
Fix merge conflict in arch/arm/mm/proc-xscale.S Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-25[ARM] SMP: don't set cpu_*_map in smp_prepare_boot_cpuRussell King
The recent addition of boot_cpu_init() implements the initialisation of the online, present and possible cpu maps for the boot CPU, so there is no reason to duplicate this in the architecture smp_prepare_boot_cpu() hook. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-23[ARM] Move enable_irq and disable_irq to assembler.hRussell King
5d25ac038a317d454a4321cba955f756400835a5 broke VFP builds due to enable_irq not being defined as an assembly macro. Move it to assembler.h so everyone can use it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-22[ARM] Quieten spurious IRQ detectionRussell King
Only issue a "nobody cared" warning after 99900 spurious interrupts. This avoids the occasional spurious interrupt causing warnings, as per x86. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] Convert kmalloc+memset to kzallocRussell King
Convert all uses of kmalloc followed by memset to use kzalloc instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] 3261/2: remove phys_ram from struct machine_desc (part 3)Nicolas Pitre
Patch from Nicolas Pitre This field is redundent since it must be equal to PHYS_OFFSET anyway. There is no reference to it anymore so remove it at last. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] Move IRQ enable after coprocessor number decodeRussell King
Allow the individual coprocessor handlers to decide when to enable interrupts, rather than unconditionally enabling them. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] Remove unnecessary asm/hardware.h includesRussell King
asm/hardware.h is not required for the majority of processor support files, ioremap support, mm initialisation, acorn IO support, nor the debug code (which picks up its machine specific includes via debug-macros.S) Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] Move read of processor ID out of lookup_processor_type()Russell King
Read the processor ID at boot, and save it in "processor_id" as we did before. Later, when we re-parse the CPU type in the setup.c code, re-use the value stored in "processor_id". This allows a cleaner work-around for noMMU devices without CP#15. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] noMMU: block sys_fork in nommu modeHyok S. Choi
The sys_fork is not supported in nommu mode. The other syscalls that is not supported in nommu mode are to be defined as cond_signal in kernel/sys_ni.c. Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-15[ARM] 3362/1: [cleanup] - duplicate decleration of mem_fclk_21285Ben Dooks
Patch from Ben Dooks arch/arm/kernel/setup.c declares mem_fclk_21285 when this is already declared in include/asm-arm/system.h Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-15[ARM] 3365/1: [cleanup] header for compat.c exported functionsBen Dooks
Patch from Ben Dooks arch/arm/kernel/compat.c exports two functions, convert_to_tag_list and squash_mem_tags which are not defined in any header files, and not used outside arch/arm/kernel. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-15[ARM] 3363/1: [cleanup] process.c - fix warningsBen Dooks
Patch from Ben Dooks Fix the following warnings from sparse: arch/arm/kernel/process.c:86:6: warning: symbol 'default_idle' was not declared. Should it be static? arch/arm/kernel/process.c:378:5: warning: symbol 'dump_fpu' was not declared. Should it be static? Include <linux/elfcore.h> for dump_fpu() decleration, and make default_idle() static as it is not used outside the file. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-15[ARM] Fix "thead" typoRussell King
2006-03-12[ARM] iwmmxt thread state alignmentRussell King
This patch removes the reliance of iwmmxt on hand coded alignments. Since thread_info is always 8K aligned, specifying that fpstate is 8-byte aligned achieves the same effect without needing to resort to hand coded alignments. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-06[PATCH] fix next_timer_interrupt() for hrtimerTony Lindgren
Also from Thomas Gleixner <tglx@linutronix.de> Function next_timer_interrupt() got broken with a recent patch 6ba1b91213e81aa92b5cf7539f7d2a94ff54947c as sys_nanosleep() was moved to hrtimer. This broke things as next_timer_interrupt() did not check hrtimer tree for next event. Function next_timer_interrupt() is needed with dyntick (CONFIG_NO_IDLE_HZ, VST) implementations, as the system can be in idle when next hrtimer event was supposed to happen. At least ARM and S390 currently use next_timer_interrupt(). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-22[ARM] CONFIG_CPU_MPCORE -> CONFIG_CPU_32v6KRussell King
CONFIG_CPU_MPCORE has never been a configuration symbol - it should be CONFIG_CPU_32v6K. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-02-22[ARM] Add panic-on-oops supportRussell King
Although you could ask the kernel for panic-on-oops, it remained non-functional because the architecture specific code fragment had not been implemented. Add it, so it works as advertised. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-02-16[ARM] 3338/1: old ABI compat: sys_socketcallNicolas Pitre
Patch from Nicolas Pitre Commit 99595d0237926b5aba1fe4c844a011a1ba1ee1f8 forgot to intercept sys_socketcall as well. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-02-16[ARM] Fix SMP initialisation oopsRussell King
A change to the SMP initialisation caused the following oops: CPU1: Booted secondary processor CPU1: D VIPT write-back cache CPU1: I cache: 32768 bytes, associativity 4, 32 byte lines, 256 sets CPU1: D cache: 32768 bytes, associativity 4, 32 byte lines, 256 sets <7>Calibrating delay loop... 83.14 BogoMIPS (lpj=415744) <1>Unable to handle kernel NULL pointer dereference at virtual address 0000001c ... PC is at enqueue_task+0x1c/0x64 LR is at activate_task+0xcc/0xe4 SMP initialisation now requires cpu_possible_map to be initialised in setup_arch(). Move this from smp_prepare_cpus() to smp_init_cpus() and call it from our setup_arch() if CONFIG_SMP is enabled. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-02-08[ARM] 3310/1: add a comment about the possible __kuser_cmpxchg transient falseNicolas Pitre
negative Patch from Nicolas Pitre The pre ARMv5 implementation can be aborted if an exception occurs in the middle of it. Because of that, the ARMv6 implementation doesn't re-attempt the operation on a failed strex either. Let's make this transient nature of such a false positive more explicit in the definition. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-02-08[ARM] 3309/1: disable the pre-ARMv5 NPTL kernel helper in the non MMU caseNicolas Pitre
Patch from Nicolas Pitre The cmpxchg emulation on pre-ARMv5 relies on user code executed from a kernel address. If the operation cannot complete atomically, it is aborted from the usr_entry macro by clearing the Z flag. This clearing of the Z flag is done whenever the user pc is above TASK_SIZE. However this "pc >= TASK_SIZE" test cannot work in the non MMU case. Worse: the current code will corrupt the Z flag on every entry to the kernel. Let's disable it in the non MMU case for now. Using NPTL on non MMU targets needs to be worked out anyway. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-02-08[ARM] 3308/1: old ABI compat: struct sockaddr_unNicolas Pitre
Patch from Nicolas Pitre struct sockaddr_un loses its padding with EABI. Since the size of the structure is used as a validation test in unix_mkname(), we need to change the length argument to 110 whenever it is 112. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-19[ARM] safer handling of syscall table paddingAl Viro
ARM entry-common.S needs to know syscall table size; in itself that would not be a problem, but there's an additional constraint - some of the instructions using it want a constant that would be a multiple of 4. So we have to pad syscall table with sys_ni_syscall and that's where the trouble begins. .rept pseudo-op wants a constant expression for number of repetitions and subtraction of two labels (before and after syscall table) doesn't always get simplified to constant early enough for .rept. If labels end up in different frags, we lose. And while the frag size is large enough (slightly below 4Kb), the syscall table is about 1/3 of that. We used to get away with that, but the recent changes had been enough to trigger the breakage. Proper fix is simple: have a macro (CALL(x)) to populate the table instead of using explicit .long x and the first time we include calls.S have it defined to .equ NR_syscalls,NR_syscalls+1. Then we can find the proper amount of padding on the first inclusion simply by looking at NR_syscalls at that time. And that will be constant, no matter what. Moreover, the same trick kills the need of having an estimate of padded NR_syscalls - it will be calculated for free at the same time. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-18[ARM] 3271/1: ARM EABI: fix calling of cmpxchg syscall emulationNicolas Pitre
Patch from Nicolas Pitre This is kernel provided user space code. Since a syscall is used, it has to be updated to work with EABI. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-18[ARM] 3270/1: ARM EABI: fix sigreturn and rt_sigreturnNicolas Pitre
Patch from Nicolas Pitre The signal return path consists of user code provided by the kernel. Since a syscall is used, it has to be updated to work with EABI. Noticed by Daniel Jacobowitz. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-14Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
2006-01-14[ARM] 3262/4: allow ptraced syscalls to be overridenNicolas Pitre
Patch from Nicolas Pitre This is needed by strace to properly handle the tracing of some system calls. It could be useful for other applications as well. Based on an earlier patch from Daniel Jacobowitz. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Daniel Jacobowitz <dan@debian.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-14[ARM] 3110/5: old ABI compat: multi-ABI syscall entry supportNicolas Pitre
Patch from Nicolas Pitre This patch adds the required code to support both user space ABIs at the same time. A second syscall table is created to include legacy ABI syscalls that need an ABI compat wrapper. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-14[ARM] 3109/1: old ABI compat: syscall wrappers for ABI impedance matchingNicolas Pitre
Patch from Nicolas Pitre The difference between EABI and the legacy ABI may affect either structure member alignment and/or argument register selection. The patch has the details. Included are wrappers for the following syscalls: sys_stat64 sys_lstat64 sys_fstat64 sys_fcntl64 sys_epoll_ctl sys_epoll_wait sys_ipc sys_semop sys_semtimedop sys_pread64 sys_pwrite64 sys_truncate64 sys_ftruncate64 sys_readahead Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-14[ARM] 3108/2: old ABI compat: statfs64 and fstatfs64Nicolas Pitre
Patch from Nicolas Pitre struct statfs64 has extra padding with EABI growing its size from 84 to 88. This struct is now __attribute__((packed,aligned(4))) with a small assembly wrapper to force the sz argument to 84 if it is 88 to avoid copying the extra padding over user space memory unexpecting it. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-14[ARM] 3105/4: ARM EABI: new syscall entry conventionNicolas Pitre
Patch from Nicolas Pitre For a while we wanted to change the way syscalls were called on ARM. Instead of encoding the syscall number in the swi instruction which requires reading back the instruction from memory to extract that number and polluting the data cache, it was decided that simply storing the syscall number into r7 would be more efficient. Since this represents an ABI change then making that change at the same time as EABI support is the right thing to do. It is now expected that EABI user space binaries put the syscall number into r7 and use "swi 0" to call the kernel. Syscall register argument are also expected to have "EABI arrangement" i.e. 64-bit arguments should be put in a pair of registers from an even register number. Example with long ftruncate64(unsigned int fd, loff_t length): legacy ABI: - put fd into r0 - put length into r1-r2 - use "swi #(0x900000 + 194)" to call the kernel new ARM EABI: - put fd into r0 - put length into r2-r3 (skipping over r1) - put 194 into r7 - use "swi 0" to call the kernel Note that it is important to use 0 for the swi argument as backward compatibility with legacy ABI user space relies on this. The syscall macros in asm-arm/unistd.h were also updated to support both ABIs and implement the right call method automatically. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-14[ARM] 3104/1: ARM EABI: new helper function namesNicolas Pitre
Patch from Nicolas Pitre The ARM EABI defines new names for GCC helper functions. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-14[ARM] 3103/1: ARM EABI: stack pointer must be 64-bit aligned (part 2)Nicolas Pitre
Patch from Nicolas Pitre We must make sure that assembly code that modifies the stack pointer before calling a C function does it so it remains 64-bit aligned. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-14[ARM] 3102/1: ARM EABI: stack pointer must be 64-bit aligned after a CPU ↵Nicolas Pitre
exception Patch from Nicolas Pitre The ARM EABI says that the stack pointer has to be 64-bit aligned for reasons already mentioned in patch #3101 when calling C functions. We therefore must verify and adjust sp accordingly when taking an exception from kernel mode since sp might not necessarily be 64-bit aligned if the exception occurs in the middle of a kernel function. If the exception occurs while in user mode then no sp fixup is needed as long as sizeof(struct pt_regs) as well as any additional syscall data stack space remain multiples of 8. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-13[ARM] Support register switch in nommu modeHyok S. Choi
This patch adds register switch support in nommu mode. Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-13[ARM] 3259/1: remove phys_ram from struct machine_desc (part 1)Nicolas Pitre
Patch from Nicolas Pitre This field is redundent since it must be equal to PHYS_OFFSET anyway. First, let's use PHYS_OFFSET directly instead. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-13[PATCH] Add ecard_bus_type probe/remove/shutdown methodsRussell King
Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-12Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
2006-01-12[ARM] Convert some arm semaphores to mutexesArjan van de Ven
The arm clock semaphores are strict mutexes, convert them to the new mutex implementation Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-12[PATCH] arm: task_stack_page()Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] arm: end_of_stack()Al Viro
2006-01-12[PATCH] arm: task_pt_regs()Al Viro
2006-01-12[PATCH] arm: task_thread_info()Al Viro
2006-01-12[ARM] 3256/1: Make the function-returning ldm's use sp as the base registerCatalin Marinas
Patch from Catalin Marinas If the low interrupt latency mode is enabled for the CPU (from ARMv6 onwards), the ldm/stm instructions are no longer atomic. An ldm instruction restoring the sp and pc registers can be interrupted immediately after sp was updated but before the pc. If this happens, the CPU restores the base register to the value before the ldm instruction but if the base register is not sp, the interrupt routine will corrupt the stack and the restarted ldm instruction will load garbage. Note that future ARM cores might always run in the low interrupt latency mode. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-12[ARM] 3234/1: Update cpu_architecture() to deal with the new ID formatCatalin Marinas
Patch from Catalin Marinas Since ARM1176, the CPU ID format has changed and it will also be used for future ARM architectures. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-11[PATCH] capable/capability.h (arch/)Randy Dunlap
arch: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[ARM] Only call set_type method in setup_irq if it's definedRussell King
2006-01-08[PATCH] remove gcc-2 checksAndrew Morton
Remove various things which were checking for gcc-1.x and gcc-2.x compilers. From: Adrian Bunk <bunk@stusta.de> Some documentation updates and removes some code paths for gcc < 3.2. Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
