commit 985626564eedc470ce2866e53938303368ad41b7 upstream.
adjust_lowmem_bounds is responsible for setting up the boundary for
lowmem/highmem. This needs to be setup before memblock reservations can
occur. At the time memblock reservations can occur, memory can also be
removed from the system. The lowmem/highmem boundary and end of memory
may be affected by this but it is currently not recalculated. On some
systems this may be harmless, on others this may result in incorrect
ranges being passed to the main memory allocator. Correct this by
recalculating the lowmem/highmem boundary after all reservations have
been made.
Tested-by: Magnus Lilja <lilja.magnus@gmail.com>
Signed-off-by: Laura Abbott <labbott@redhat.com>
Cc: Julien Grall <julien.grall@arm.com>
commit 374d446d25d6271ee615952a3b7f123ba4983c35 upstream.
The logic for sanity_check_meminfo has become difficult to
follow. Clean up the code so it's more obvious what the code
is actually trying to do. Additionally, meminfo is now removed
so rename the function to better describe its purpose.
Reviewed-by: Nicolas Pitre <nico@linaro.org>
Signed-off-by: Laura Abbott <lauraa@codeaurora.org>
With the addition of caches to the V7M Architecture a new Cache Type
Register (CTR) is defined at 0xE000ED7C. This register serves the same
purpose as the V7A/R version and accessed via the read_cpuid_cachetype.
Signed-off-by: Jonathan Austin <jonathan.austin@arm.com>
Signed-off-by: Vladimir Murzin <vladimir.murzin@arm.com>
Tested-by: Andras Szemzo <sza@esh.hu>
Tested-by: Joachim Eastwood <manabian@gmail.com>
Tested-by: Alexandre TORGUE <alexandre.torgue@st.com>
Currently we use raw cp15 operations to access the cache setup data.
This patch abstracts the CSSELR and CCSIDR accessors out to a header so
that the implementation for them can be switched out as we do with other
cpu/cachetype operations.
Guided by grsecurity's analogous __read_only markings in arch/arm,
this applies several uses of __ro_after_init to structures that are
only updated during __init.
Advertise the location of bootable RAM to kexec-tools. kexec needs to
know where it can place the kernel in RAM, and so be executable when the
system needs to jump into it.
Advertise these areas in /proc/iomem with a "System RAM (boot alias)"
tag.
Link: http://lkml.kernel.org/r/E1b8ko4-0004HA-GF@rmk-PC.armlinux.org.uk
Reviewed-by: Pratyush Anand <panand@redhat.com>
Cc: Baoquan He <bhe@redhat.com>
Cc: Keerthy <j-keerthy@ti.com>
Cc: Vitaly Andrianov <vitalya@ti.com>
Cc: Eric Biederman <ebiederm@xmission.com>
Cc: Dave Young <dyoung@redhat.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
Cc: Simon Horman <horms@verge.net.au>
Advertise a resource which describes where the crash kernel is located
in the boot view of RAM. This allows kexec-tools to have this vital
information.
Link: http://lkml.kernel.org/r/E1b8knz-0004H4-Bd@rmk-PC.armlinux.org.uk
Cc: Pratyush Anand <panand@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull DeviceTree updates from Rob Herring:
- remove most of_platform_populate() calls in arch code. Now the DT
core code calls it in the default case and platforms only need to
call it if they have special needs
- use pr_fmt on all the DT core print statements
- CoreSight binding doc improvements to block name descriptions
- add dt_to_config script which can parse dts files and list
corresponding kernel config options
- fix memory leak hit with a PowerMac DT
- correct a bunch of STMicro compatible strings to use the correct
vendor prefix
- fix DA9052 PMIC binding doc to match what is actually used in dts
files
* tag 'devicetree-for-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (35 commits)
documentation: da9052: Update regulator bindings names to match DA9052/53 DTS expectations
xtensa: Partially Revert "xtensa: Remove unnecessary of_platform_populate with default match table"
xtensa: Fix build error due to missing include file
MIPS: ath79: Add missing include file
Fix spelling errors in Documentation/devicetree
ARM: dts: fix STMicroelectronics compatible strings
powerpc/dts: fix STMicroelectronics compatible strings
Documentation: dt: i2c: use correct STMicroelectronics vendor prefix
scripts/dtc: dt_to_config - kernel config options for a devicetree
of: fdt: mark unflattened tree as detached
of: overlay: add resolver error prints
coresight: document binding acronyms
Documentation/devicetree: document cavium-pip rx-delay/tx-delay properties
of: use pr_fmt prefix for all console printing
of/irq: Mark initialised interrupt controllers as populated
of: fix memory leak related to safe_name()
Revert "of/platform: export of_default_bus_match_table"
of: unittest: use of_platform_default_populate() to populate default bus
memory: omap-gpmc: use of_platform_default_populate() to populate default bus
bus: uniphier-system-bus: use of_platform_default_populate() to populate default bus
Pull ARM updates from Russell King:
"Included in this update are:
- Patches from Gregory Clement to fix the coherent DMA cases in our
dma-mapping code.
- A number of CPU errata updates and fixes.
- ARM cpuidle improvements from Jisheng Zhang.
- Fix from Kees for the location of _etext.
- Cleanups from Masahiro Yamada to avoid duplicated messages during
the kernel build, and remove CONFIG_ARCH_HAS_BARRIERS.
- Remove a udelay loop limitation, allowing for faster CPUs to
calibrate the delay correctly.
- Cleanup some left-overs from the SW PAN implementation.
- Ensure that a modified address limit is not visible to exception
handlers"
* 'for-linus' of git://git.armlinux.org.uk/~rmk/linux-arm: (21 commits)
ARM: 8586/1: cpuidle: make arm_cpuidle_suspend() a bit more efficient
ARM: 8585/1: cpuidle: fix !cpuidle_ops[cpu].init case during init
ARM: 8561/4: dma-mapping: Fix the coherent case when iommu is used
ARM: 8561/3: dma-mapping: Don't use outer_flush_range when the L2C is coherent
ARM: 8560/1: errata: Workaround errata A12 825619 / A17 852421
ARM: 8559/1: errata: Workaround erratum A12 821420
ARM: 8558/1: errata: Workaround errata A12 818325/852422 A17 852423
ARM: save and reset the address limit when entering an exception
ARM: 8577/1: Fix Cortex-A15 798181 errata initialization
ARM: 8584/1: floppy: avoid gcc-6 warning
ARM: 8583/1: mm: fix location of _etext
ARM: 8582/1: remove unused CONFIG_ARCH_HAS_BARRIERS
ARM: 8306/1: loop_udelay: remove bogomips value limitation
ARM: 8581/1: add missing <asm/prom.h> to arch/arm/kernel/devtree.c
ARM: 8576/1: avoid duplicating "Kernel: arch/arm/boot/*Image is ready"
ARM: 8556/1: on a generic DT system: do not touch l2x0
ARM: uaccess: remove put_user() code duplication
ARM: 8580/1: Remove orphaned __addr_ok() definition
ARM: get rid of horrible *(unsigned int *)(regs + 1)
ARM: introduce svc_pt_regs structure
Move xen_early_init() before efi_init(), then when calling efi_init()
could initialize Xen specific UEFI.
Check if it runs on Xen hypervisor through the flat dts.
Signed-off-by: Shannon Zhao <shannon.zhao@linaro.org>
Reviewed-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Reviewed-by: Julien Grall <julien.grall@arm.com>
Tested-by: Julien Grall <julien.grall@arm.com>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
The _etext position is defined to be the end of the kernel text code,
and should not include any part of the data segments. This interferes
with things that might check memory ranges and expect executable code
up to _etext. Just to be conservative, leave the kernel resource as
it was, using __init_begin instead of _etext as the end mark.
After patch "of/platform: Add common method to populate default bus",
it is possible for arch code to remove unnecessary callers of
of_platform_populate with default match table.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Ray Jui <rjui@broadcom.com>
Cc: Lee Jones <lee@kernel.org>
Cc: Krzysztof Halasa <khalasa@piap.pl>
Cc: Kukjin Kim <kgene@kernel.org>
Cc: Rob Herring <robh@kernel.org>
Cc: Shawn Guo <shawnguo@kernel.org>
Cc: Santosh Shilimkar <ssantosh@kernel.org>
Cc: Roland Stigge <stigge@antcom.de>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: Heiko Stuebner <heiko@sntech.de>
Cc: Viresh Kumar <vireshk@kernel.org>
Cc: Shiraz Hashim <shiraz.linux.kernel@gmail.com>
Cc: Tony Prisk <linux@prisktech.co.nz>
Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Signed-off-by: Rob Herring <robh@kernel.org>
The of_iommu_init() is called multiple times by arch code,
make it postcore_initcall_sync, then we can drop relevant
calls fully.
Note, the IOMMUs should have a chance to perform some basic
initialisation before we start adding masters to them. So
postcore_initcall_sync is good choice, it ensures of_iommu_init()
called before of_platform_populate.
Acked-by: Rich Felker <dalias@libc.org>
Tested-by: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Rich Felker <dalias@libc.org>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Robin Murphy <robin.murphy@arm.com>
Acked-by: Joerg Roedel <jroedel@suse.de>
"Changes included in this pull request:
- revert pxa2xx-flash back to using ioremap_cached() and switch
memremap() to use arch_memremap_wb()
- remove pci=firmware command line argument handling
- remove unnecessary arm_dma_set_mask() implementation, the generic
implementation will do for ARM
- removal of the ARM kallsyms "hack" to work around mode switching
veneers and vectors located below PAGE_OFFSET
- tidy up build system output a little
- add L2 cache power management DT bindings
- remove duplicated local_irq_disable() in reboot paths
- handle AMBA primecell devices better at registration time with PM
domains (needed for Samsung SoCs)
- ARM specific preparation to support Keystone II kexec"
ARM: 8567/1: cache-uniphier: activate ways for secondary CPUs
ARM: 8570/2: Documentation: devicetree: Add PL310 PM bindings
ARM: 8569/1: pl2x0: Add OF control of cache power management
ARM: 8568/1: reboot: remove duplicated local_irq_disable()
ARM: 8566/1: drivers: amba: properly handle devices with power domains
ARM: provide arm_has_idmap_alias() helper
ARM: kexec: remove 512MB restriction on kexec crashdump
ARM: provide improved virt_to_idmap() functionality
ARM: kexec: fix crashkernel= handling
ARM: 8557/1: specify install, zinstall, and uinstall as PHONY targets
ARM: 8562/1: suppress "include/generated/mach-types.h is up to date."
ARM: 8553/1: kallsyms: remove --page-offset command line option
ARM: 8552/1: kallsyms: remove special lower address limit for CONFIG_ARM
ARM: 8555/1: kallsyms: ignore ARM mode switching veneers
ARM: 8548/1: dma-mapping: remove arm_dma_set_mask()
ARM: 8554/1: kernel: pci: remove pci=firmware command line parameter handling
ARM: memremap: implement arch_memremap_wb()
memremap: add arch specific hook for MEMREMAP_WB mappings
mtd: pxa2xx-flash: switch back from memremap to ioremap_cached
ARM: reintroduce ioremap_cached() for creating cached I/O mappings
for-linus
The real limit is the top of the visible physical address space with
the MMU turned off. Hence, we need to limit the crash kernel allocation
running-view physical address of the top of the boot-view physical
address space.
When the kernel crashkernel parameter is specified with just a size, we
are supposed to allocate a region from RAM to store the crashkernel.
However, ARM merely reserves physical address zero with no checking that
there is even RAM there.
Fix this by lifting similar code from x86, importing it to ARM with the
ARM specific parameters added. In the absence of any platform specific
information, we allocate the crashkernel region from the first 512MB of
physical memory.
Update the kdump documentation to reflect this change.
In order to hand over the framebuffer described by the GOP protocol and
discovered by the UEFI stub, make struct screen_info accessible by the
stub. This involves allocating a loader data buffer and passing it to the
kernel proper via a UEFI Configuration Table, since the UEFI stub executes
in the context of the decompressor, and cannot access the kernel's copy of
struct screen_info directly.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk>
Cc: David Herrmann <dh.herrmann@gmail.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Peter Jones <pjones@redhat.com>
Cc: linux-efi@vger.kernel.org
Link: http://lkml.kernel.org/r/1461614832-17633-22-git-send-email-matt@codeblueprint.co.uk
Commit b8c9592 "ARM: 8318/1: treat CPU feature register fields as signed
quantities" accidentally altered cpuid register used to demote
HWCAP_SWP.
ARM ARM says that SyncPrim_instrs bits in ID_ISAR3 should be used with
SynchPrim_instrs_frac from ID_ISAR4. So, follow this rule.
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
It was reported that a kernel with CONFIG_ARM_PATCH_IDIV=y stopped
booting when compiled with the upcoming gcc 6. Turns out that turning
a function address into a writable array is undefined and gcc 6 decided
it was OK to omit the store to the first word of the function while
still preserving the store to the second word.
Even though gcc 6 is now fixed to behave more coherently, it is a
mystery that gcc 4 and gcc 5 actually produce wanted code in the kernel.
And in fact the reduced test case to illustrate the issue does indeed
break with gcc < 6 as well.
In any case, let's guard the kernel against undefined compiler behavior
by hiding the nature of the array location as suggested by gcc
developers.
Reference: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=70128
Signed-off-by: Nicolas Pitre <nico@linaro.org>
Reported-by: Marcin Juszkiewicz <mjuszkiewicz@redhat.com>
Cc: stable@vger.kernel.org # v4.5
Set IORESOURCE_SYSTEM_RAM in flags of resource ranges with
"System RAM", "Kernel code", "Kernel data", and "Kernel bss".
Note that:
- IORESOURCE_SYSRAM (i.e. modifier bit) is set in flags when
IORESOURCE_MEM is already set. IORESOURCE_SYSTEM_RAM is defined
as (IORESOURCE_MEM|IORESOURCE_SYSRAM).
- Some archs do not set 'flags' for children nodes, such as
"Kernel code". This patch does not change 'flags' in this
case.
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Luis R. Rodriguez <mcgrof@suse.com>
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: linux-mips@linux-mips.org
Cc: linux-mm <linux-mm@kvack.org>
Cc: linux-parisc@vger.kernel.org
Cc: linux-s390@vger.kernel.org
Cc: linux-sh@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Cc: sparclinux@vger.kernel.org
Link: http://lkml.kernel.org/r/1453841853-11383-7-git-send-email-bp@alien8.de
The ARM compiler inserts calls to __aeabi_idiv() and
__aeabi_uidiv() when it needs to perform division on signed and
unsigned integers. If a processor has support for the sdiv and
udiv instructions, the kernel may overwrite the beginning of those
functions with those instructions and a "bx lr" to get better
performance.
To ensure that those functions are aligned to a 32-bit word for easier
patching (which might not always be the case in Thumb mode) and that
the two patched instructions end up in the same cache line, a 8-byte
alignment is enforced when ARM_PATCH_IDIV is selected.
This was heavily inspired by a previous patch from Stephen Boyd.
This adds support to the kernel proper for booting via UEFI. It shares
most of the code with arm64, so this patch mostly just wires it up for
use with ARM.
Note that this does not include the EFI stub, it is added in a subsequent
patch.
Tested-by: Ryan Harkin <ryan.harkin@linaro.org>
Reviewed-by: Matt Fleming <matt@codeblueprint.co.uk>
This enables the generic early_ioremap implementation for ARM.
It uses the fixmap region reserved for kmap. Since early_ioremap
is only supported before paging_init(), and kmap is only supported
afterwards, this is guaranteed not to cause any clashes.
drivers/perf/arm_pmu.c
Add early fixmap support, initially to support permanent, fixed
mapping support for early console. A temporary, early pte is
created which is migrated to a permanent mapping in paging_init.
This is also needed since the attributes may change as the memory
types are initialized. The 3MiB range of fixmap spans two pte
tables, but currently only one pte is created for early fixmap
support.
Re-add FIX_KMAP_BEGIN to the index calculation in highmem.c since
the index for kmap does not start at zero anymore. This reverts
4221e2e6b316 ("ARM: 8031/1: fixmap: remove FIX_KMAP_BEGIN and
FIX_KMAP_END") to some extent.
Cc: Mark Salter <msalter@redhat.com>
Cc: Laura Abbott <lauraa@codeaurora.org>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Stefan Agner <stefan@agner.ch>
Now that the common PSCI client code has been factored out to
drivers/firmware, and made safe for 32-bit use, move the 32-bit ARM code
over to it. This results in a moderate reduction of duplicated lines,
and will prevent further duplication as the PSCI client code is updated
for PSCI 1.0 and beyond.
The two legacy platform users of the PSCI invocation code are updated to
account for interface changes. In both cases the power state parameter
(which is constant) is now generated using macros, so that the
pack/unpack logic can be killed in preparation for PSCI 1.0 power state
changes.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Acked-by: Rob Herring <robh@kernel.org>
Cc: Ashwin Chaugule <ashwin.chaugule@linaro.org>
Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Writes to /sys/.../cpuX/online fail if we determine the platform
doesn't support hotplug for that CPU. Furthermore, if the cpu_die
op isn't specified the system hangs when we try to offline a CPU
and it comes right back online unexpectedly. Let's figure this
stuff out before we make the sysfs nodes so that the online file
doesn't even exist if it isn't (at least sometimes) possible to
hotplug the CPU.
Add a new 'cpu_can_disable' op and repoint all 'cpu_disable'
implementations at it because all implementers use the op to
indicate if a CPU can be hotplugged or not in a static fashion.
With PSCI we may need to add a 'cpu_disable' op so that the
secure OS can be migrated off the CPU we're trying to hotplug.
In this case, the 'cpu_can_disable' op will indicate that all
CPUs are hotpluggable by returning true, but the 'cpu_disable' op
will make a PSCI migration call and occasionally fail, denying
the hotplug of a CPU. This shouldn't be any worse than x86 where
we may indicate that all CPUs are hotpluggable but occasionally
we can't offline a CPU due to check_irq_vectors_for_cpu_disable()
failing to find a CPU to move vectors to.
Cc: Nicolas Pitre <nico@linaro.org>
Cc: Dave Martin <Dave.Martin@arm.com>
Acked-by: Simon Horman <horms@verge.net.au> [shmobile portion]
Tested-by: Simon Horman <horms@verge.net.au>
Cc: Magnus Damm <magnus.damm@gmail.com>
Cc: <linux-sh@vger.kernel.org>
Tested-by: Tyler Baker <tyler.baker@linaro.org>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen updates from David Vrabel:
"Xen features and cleanups for 4.2-rc0:
- add "make xenconfig" to assist in generating configs for Xen guests
- preparatory cleanups necessary for supporting 64 KiB pages in ARM
guests
- automatically use hvc0 as the default console in ARM guests"
* tag 'for-linus-4.2-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
block/xen-blkback: s/nr_pages/nr_segs/
block/xen-blkfront: Remove invalid comment
block/xen-blkfront: Remove unused macro MAXIMUM_OUTSTANDING_BLOCK_REQS
arm/xen: Drop duplicate define mfn_to_virt
xen/grant-table: Remove unused macro SPP
xen/xenbus: client: Fix call of virt_to_mfn in xenbus_grant_ring
xen: Include xen/page.h rather than asm/xen/page.h
kconfig: add xenconfig defconfig helper
kconfig: clarify kvmconfig is for kvm
xen/pcifront: Remove usage of struct timeval
xen/tmem: use BUILD_BUG_ON() in favor of BUG_ON()
hvc_xen: avoid uninitialized variable warning
xenbus: avoid uninitialized variable warning
xen/arm: allow console=hvc0 to be omitted for guests
arm,arm64/xen: move Xen initialization earlier
arm/xen: Correctly check if the event channel interrupt is present
Eliminate the needless nommu version of this function, and get rid of
the proc_info_list structure argument - we no longer need this in order
to fix up the page table entries.
Acked-by: Santosh Shilimkar <ssantosh@kernel.org>
Tested-by: Murali Karicheri <m-karicheri2@ti.com>
Currently, Xen is initialized/discovered in an initcall. This doesn't
allow us to support earlyprintk or choosing the preferred console when
running on Xen.
The current function xen_guest_init is now split in 2 parts:
- xen_early_init: Check if there is a Xen node in the device tree
and setup domain type
- xen_guest_init: Retrieve the information from the device node and
initialize Xen (grant table, shared page...)
The former is called in setup_arch, while the latter is an initcall.
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Signed-off-by: Julien Grall <julien.grall@linaro.org>
Acked-by: Ian Campbell <ian.campbell@citrix.com>
Acked-by: Will Deacon <will.deacon@arm.com>
This grabs the serial number shown in cpuinfo from the serial-number device-tree
property in priority. When booting with ATAGs (and without device-tree), the
provided number is still shown instead.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
arch/arm/mm/proc-macros.S
When running the 32-bit ARM kernel on ARMv8 capable bare metal (e.g.,
32-bit Android userland and kernel on a Cortex-A53), or as a KVM guest
on a 64-bit host, we should advertise the availability of the Crypto
instructions, so that userland libraries such as OpenSSL may use them.
(Support for the v8 Crypto instructions in the 32-bit build was added
to OpenSSL more than six months ago)
This adds the ID feature bit detection, and sets elf_hwcap2 accordingly.
The various CPU feature registers consist of 4-bit blocks that
represent signed quantities, whose positive values represent
incremental features, and whose negative values are reserved.
To improve forward compatibility, update the feature detection
code to take possible future higher values into account, but
ignore negative values.
Replace inline asm statement in __get_cpu_architecture() with equivalent
macro invocation, i.e. read_cpuid_ext(CPUID_EXT_MMFR0);
As an added bonus, this squashes a potential bug, described by Paul
Walmsley in commit 067e710b9a98 ("ARM: 7801/1: prevent gcc 4.5 from
reordering extended CP15 reads above is_smp() test").
Signed-off-by: Marc Gonzalez <marc_gonzalez@sigmadesigns.com>
Pull ARM fixes from Russell King:
"Another round of small ARM fixes.
restore_user_regs early stack deallocation is buggy in the presence of
FIQs which switch to SVC mode, and could lead to corrupted registers
being returned to a user process given an inopportune FIQ event.
Another bug was spotted in the ARM perf code where it could lose track
of perf counter overflows, leading to incorrect perf results.
Lastly, a bug in arm_add_memory() was spotted where the memory sizes
aren't properly rounded. As most people pass properly rounded sizes,
this hasn't been noticed"
* 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm:
ARM: 8292/1: mm: fix size rounding-down of arm_add_memory() function
ARM: 8255/1: perf: Prevent wraparound during overflow
ARM: 8266/1: Remove early stack deallocation from restore_user_regs
The current rounding of "size" is wrong:
- If "start" is sufficiently near the next page boundary, "size"
is decremented by more than enough and the last page is lost.
- If "size" is sufficiently small, it is wrapped around and gets
a bogus value.
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Commit 9fc2105aeaaf ("ARM: 7830/1: delay: don't bother reporting
bogomips in /proc/cpuinfo") breaks audio in python, and probably
elsewhere, with message
FATAL: cannot locate cpu MHz in /proc/cpuinfo
I'm not the first one to hit it, see for example
https://theredblacktree.wordpress.com/2014/08/10/fatal-cannot-locate-cpu-mhz-in-proccpuinfo/
https://devtalk.nvidia.com/default/topic/765800/workaround-for-fatal-cannot-locate-cpu-mhz-in-proc-cpuinf/?offset=1
Reading original changelog, I have to say "Stop breaking working setups.
You know who you are!".
Signed-off-by: Pavel Machek <pavel@ucw.cz>
Pull ARM SoC/iommu configuration update from Arnd Bergmann:
"The iomm-config branch contains work from Will Deacon, quoting his
description:
This series adds automatic IOMMU and DMA-mapping configuration for
OF-based DMA masters described using the generic IOMMU devicetree
bindings. Although there is plenty of future work around splitting up
iommu_ops, adding default IOMMU domains and sorting out automatic IOMMU
group creation for the platform_bus, this is already useful enough for
people to port over their IOMMU drivers and start using the new probing
infrastructure (indeed, Marek has patches queued for the Exynos IOMMU).
The branch touches core ARM and IOMMU driver files, and the respective
maintainers (Russell King and Joerg Roedel) agreed to have the
contents merged through the arm-soc tree.
The final version was ready just before the merge window, so we ended
up delaying it a bit longer than the rest, but we don't expect to see
regressions because this is just additional infrastructure that will
get used in drivers starting in 3.20 but is unused so far"
* tag 'iommu-config-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
iommu: store DT-probed IOMMU data privately
arm: dma-mapping: plumb our iommu mapping ops into arch_setup_dma_ops
arm: call iommu_init before of_platform_populate
dma-mapping: detect and configure IOMMU in of_dma_configure
iommu: fix initialization without 'add_device' callback
iommu: provide helper function to configure an IOMMU for an of master
iommu: add new iommu_ops callback for adding an OF device
dma-mapping: replace set_arch_dma_coherent_ops with arch_setup_dma_ops
iommu: provide early initialisation hook for IOMMU drivers
We need to ensure that the IOMMUs in the system have a chance to perform
some basic initialisation before we start adding masters to them.
This patch adds a call to of_iommu_init before of_platform_populate.
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: Marek Szyprowski <m.szyprowski@samsung.com>
The generic dump_stack() code provides the facility to include the
machine name in the stack dump, which can be useful information. Add
a call to dump_stack_set_arch_desc() for the generic code to print
this information.
Tested-by: Felipe Balbi <balbi@ti.com>
This patch introduces a new default FIQ handler that is structured in a
similar way to the existing ARM exception handler and result in the FIQ
being handled by C code running on the SVC stack (despite this code run
in the FIQ handler is subject to severe limitations with respect to
locking making normal interaction with the kernel impossible).
This default handler allows concepts that on x86 would be handled using
NMIs to be realized on ARM.
Credit:
This patch is a near complete re-write of a patch originally
provided by Anton Vorontsov. Today only a couple of small fragments
survive, however without Anton's work to build from this patch would
not exist. Thanks also to Russell King for spoonfeeding me a variety
of fixes during the review cycle.
Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
When the CPU has support for the byte and word exclusive operations,
userspace should use them in preference to the SWP instructions.
Detect the presence of these instructions by reading the ISAR CPU ID
registers and adjust the ELF HWCAP mask appropriately.
Note that ARM1136 < r1p0 has no ISAR4, so this is explicitly detected
and the test disabled, leaving the current situation where HWCAP_SWP
is set.
Tested-by: Tony Lindgren <tony@atomide.com>
Fix a long standing bug where, for ARMv6+, we don't fully ensure that
the C code sets the same cache policy as the assembly code. This was
introduced partially by commit 11179d8ca28d ([ARM] 4497/1: Only allow
safe cache configurations on ARMv6 and later) and also by adding SMP
support.
This patch sets the default cache policy based on the flags used by the
assembly code, and then ensures that when a cache policy command line
argument is used, we verify that on ARMv6, it matches the initial setup.
memblock is now fully integrated into the kernel and is the prefered
method for tracking memory. Rather than reinvent the wheel with
meminfo, migrate to using memblock directly instead of meminfo as
an intermediate.
Acked-by: Jason Cooper <jason@lakedaemon.net>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Tested-by: Leif Lindholm <leif.lindholm@linaro.org>
Rather than reading the cr_alignment variable, use get_cr() to read
directly from the hardware instead. We have two places where this
occurs, neither of them are performance critical.
