path: root/arch/arm/kernel/perf_event_cpu.c
2015-05-28arm: perf: unify perf_event{,_cpu}.cMark Rutland
Now that the arm_pmu framework is only used for CPU PMUs, there's no reason to keep the pseudo-generic and CPU-specific framework portions separate. This patch folds the two into perf_event.c. Signed-off-by: Mark Rutland <mark.rutland@arm.com> [will: fixed up irq cfg to match upstream] Signed-off-by: Will Deacon <will.deacon@arm.com>
2015-05-28arm: perf: factor out armv7 pmu driverMark Rutland
Now that the core arm perf code maintains no global state and all microarchitecture-specific PMU data can be fed in through the shared probe function, it's possible to use it as a library and get rid of the C file includes we have currently. This patch factors out the ARMv7-specific portions out into the ARMv7 driver. For the moment this is always built if perf event support is enabled, but the preprocessor guards will leave behind an empty file. Now that perf_event_cpu.c contains no microarchitecture-specific data, the associated probing code is removed, completing its relegation to a library file. The vestigal "arm-pmu" platform device ID is removed in this patch, as it has been unused since platform files were updated to specify a more specific PMU variant. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2015-05-28arm: perf: factor out armv6 pmu driverMark Rutland
Now that the core arm perf code maintains no global state and all microarchitecture-specific PMU data can be fed in through the shared probe function, it's possible to use it as a library and get rid of the C file includes we have currently. This patch factors out the ARMv6-specific portions out into the ARMv6 driver. For the moment this is always built if perf event support is enabled, but the preprocessor guards will leave behind an empty file. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2015-05-28arm: perf: factor out xscale pmu driverMark Rutland
Now that the core arm perf code maintains no global state and all microarchitecture-specific PMU data can be fed in through the shared probe function, it's possible to use it as a library and get rid of the C file includes we have currently. This patch factors out the xscale-specific portions out into the xscale driver. For the moment this is always built if perf event support is enabled, but the preprocessor guards will leave behind an empty file. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2015-05-28arm: perf: share arm_pmu_device_probeMark Rutland
Enable the probe function to be shared with other drivers, which will inject the appropriate of_device_id and pmu_probe_info tables. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2015-05-28arm: perf: kill off unused pm callbacksMark Rutland
Currently the arm perf code has platdata callbacks for runtime PM and irq handling, but no platform implements the hooks for the former. Kill these off. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2015-05-27arm: perf: remove singleton PMU restrictionMark Rutland
Now that we can describe PMUs in heterogeneous systems, the only item in the way of perf support for big.LITTLE is the singleton cpu_pmu variable used for OProfile compatibility. Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2015-05-27arm: perf: treat PMUs as CPU affineMark Rutland
In multi-cluster systems, the PMUs can be different across clusters, and so our logical PMU may not be able to schedule events on all CPUs. This patch adds a cpumask to encode which CPUs a PMU driver supports controlling events for, and limits the driver to scheduling events on those CPUs, and enabling and disabling the physical PMUs on those CPUs. The cpumask is built based on the interrupt-affinity property, and in the absence of such a property a homogenous system is assumed. Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2015-05-27arm: perf: make of_pmu_irq_cfg take arm_pmuMark Rutland
To support multiple PMUs we'll need to pass the arm_pmu instance around. Update of_pmu_irq_cfg to take an arm_pmu, and acquire the platform device from this. Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2015-03-24ARM: pmu: add support for interrupt-affinity propertyWill Deacon
Historically, the PMU devicetree bindings have expected SPIs to be listed in order of *logical* CPU number. This is problematic for bootloaders, especially when the boot CPU (logical ID 0) isn't listed first in the devicetree. This patch adds a new optional property, interrupt-affinity, to the PMU node which allows the interrupt affinity to be described using a list of phandled to CPU nodes, with each entry in the list corresponding to the SPI at the same index in the interrupts property. Cc: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2015-03-17ARM: perf: Add support for Scorpion PMUsStephen Boyd
Scorpion supports a set of local performance monitor event selection registers (LPM) sitting behind a cp15 based interface that extend the architected PMU events to include Scorpion CPU and Venum VFP specific events. To use these events the user is expected to program the lpm register with the event code shifted into the group they care about and then point the PMNx event at that region+group combo by writing a LPMn_GROUPx event. Add support for this hardware. Note: the raw event number is a pure software construct that allows us to map the multi-dimensional number space of regions, groups, and event codes into a flat event number space suitable for use by the perf framework. This is based on code originally written by Sheetal Sahasrabudhe, Ashwin Chaugule, and Neil Leeder [1]. [1] https://www.codeaurora.org/cgit/quic/la/kernel/msm/tree/arch/arm/kernel/perf_event_msm.c?h=msm-3.4 Cc: Mark Rutland <mark.rutland@arm.com> Cc: Neil Leeder <nleeder@codeaurora.org> Cc: Ashwin Chaugule <ashwinc@codeaurora.org> Cc: Sheetal Sahasrabudhe <sheetals@codeaurora.org> Cc: <devicetree@vger.kernel.org> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Will Deacon <will.deacon@arm.com>
2015-02-19ARM: make of_device_ids constUwe Kleine-König
of_device_ids (i.e. compatible strings and the respective data) are not supposed to change at runtime. All functions working with of_device_ids provided by <linux/of.h> work with const of_device_ids. So mark the non-const structs in arch/arm as const, too. While at it also add some __initconst annotations. Acked-by: Jason Cooper <jason@lakedameon.net> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-10-30arm: perf: fold hotplug notifier into arm_pmuMark Rutland
Handling multiple PMUs using a single hotplug notifier requires a list of PMUs to be maintained, with synchronisation in the probe, remove, and notify paths. This is error-prone and makes the code much harder to maintain. Instead of using a single notifier, we can dynamically allocate a notifier block per-PMU. The end result is the same, but the list of PMUs is implicit in the hotplug notifier list rather than within a perf-local data structure, which makes the code far easier to handle. Signed-off-by: Mark Rutland <mark.rutland at arm.com> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Will Deacon <will.deacon@arm.com>
2014-10-30arm: perf: dynamically allocate cpu hardware dataMark Rutland
To support multiple PMUs, each PMU will need its own accounting data. As we don't know how (in general) many PMUs we'll have to support at compile-time, we must allocate the data at runtime dynamically Signed-off-by: Mark Rutland <mark.rutland@arm.com> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Will Deacon <will.deacon@arm.com>
2014-10-30arm: perf: fold percpu_pmu into pmu_hw_eventsMark Rutland
Currently the percpu_pmu pointers used as percpu_irq dev_id values are defined separately from the other per-cpu accounting data, which make dynamically allocating the data (as will be required for systems with heterogeneous CPUs) difficult. This patch moves the percpu_pmu pointers into pmu_hw_events (which is itself allocated per cpu), which will allow for easier dynamic allocation. Both percpu and regular irqs are requested using percpu_pmu pointers as tokens, freeing us from having to know whether an irq is percpu within the handler, and thus avoiding a radix tree lookup on the handler path. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Reviewed-by: Will Deacon <will.deacon@arm.com> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org> Tested-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Will Deacon <will.deacon@arm.com>
2014-10-30arm: perf: kill get_hw_events()Mark Rutland
Now that the arm pmu code is limited to CPU PMUs the get_hw_events() function is superfluous, as we'll always have a set of per-cpu pmu_hw_events structures. This patch removes the get_hw_events() function, replacing it with a percpu hw_events pointer. Uses of get_hw_events are updated to use this_cpu_ptr. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Reviewed-by: Will Deacon <will.deacon@arm.com> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Will Deacon <will.deacon@arm.com>
2014-10-30arm: perf: limit size of accounting dataMark Rutland
Commit 3fc2c83087 (ARM: perf: remove event limit from pmu_hw_events) got rid of the upper limit on the number of events an arm_pmu could handle, but introduced additional complexity and places a burden on each PMU driver to allocate accounting data somehow. So far this has not generally been useful as the only users of arm_pmu are the CPU backend and the CCI driver. Now that the CCI driver plugs into the perf subsystem directly, we can remove some of the complexities that get in the way of supporting heterogeneous CPU PMUs. This patch restores the original limits on pmu_hw_events fields such that the pmu_hw_events data can be allocated as a contiguous block. This will simplify dynamic pmu_hw_events allocation in later patches. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Reviewed-by: Will Deacon <will.deacon@arm.com> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org> Tested-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Will Deacon <will.deacon@arm.com>
2014-10-30arm: perf: use IDR types for CPU PMUsMark Rutland
For systems with heterogeneous CPUs (e.g. big.LITTLE systems) the PMUs can be different in each cluster, and not all events can be migrated between clusters. To allow userspace to deal with this, it must be possible to address each PMU independently. This patch changes PMUs to be registered with dynamic (IDR) types, allowing them to be targeted individually. Each PMU's type can be found in ${SYSFS_ROOT}/bus/event_source/devices/${PMU_NAME}/type. From userspace, raw events can be targeted at a specific PMU: $ perf stat -e ${PMU_NAME}/config=V,config1=V1,.../ Doing this does not break existing tools which use existing perf types: when perf core can't find a PMU of matching type (in perf_init_event) it'll iterate over the set of all PMUs. If a compatible PMU exists, it'll be found eventually. If more than one compatible PMU exists, the event will be handled by whichever PMU happens to be earlier in the pmus list (which currently will be the last compatible PMU registered). Signed-off-by: Mark Rutland <mark.rutland@arm.com> Reviewed-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2014-10-30arm: perf: make PMU probing data-drivenMark Rutland
The current PMU probing logic consists of a single switch statement, which means that the core arm_pmu core in perf_event_cpu.c needs to know about every CPU PMU variant supported by a driver using the arm_pmu framework. This makes it rather difficult to decouple the drivers from the (otherwise generic) probing code. The patch refactors that switch statement to a table-driven lookup, separating the logic and knowledge (in the form of the table). Later patches will split the table across the relevant PMU drivers, which can pass their tables to the generic probing function. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Reviewed-by: Will Deacon <will.deacon@arm.com> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Will Deacon <will.deacon@arm.com>
2014-10-30arm: perf: add missing pr_info newlinesMark Rutland
Most of the pr_info format strings in perf_event_cpu.c are missing newlines. Currently we get away with this as the format strings for subsequent calls to printk (including all pr_* calls) begin with a log prefix, and the printk core adds the omitted newline for this case. While generates the output we expect, we probably should not rely on the format of successive printk calls in order to get legible output. This patch adds the missing newlines to pr_info format strings in perf_event_cpu.c, making them consistent with the format strings for other pr_info, warn, and pr_err calls, and preventing potentially illegible output if the next printk/pr_* format string doesn't begin with a log prefix. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Will Deacon <will.deacon@arm.com>
2014-10-30ARM: perf: use pr_* instead of printkWill Deacon
There are a few remaining uses of printk in the ARM perf code, so move them over to the pr_* variants instead. Reported-by: Russell King <linux@arm.linux.org.uk> Signed-off-by: Will Deacon <will.deacon@arm.com>
2014-10-02Merge branches 'fiq' (early part), 'fixes', 'l2c' (early part) and 'misc' ↵Russell King
into for-next
2014-09-26ARM: 8152/1: Convert pr_warning to pr_warnJoe Perches
Use the more common pr_warn. Other miscellanea: o Coalesce formats o Realign arguments Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-09-16ARM: 8149/1: perf: Don't sleep while atomic when enabling per-cpu interruptsStephen Boyd
Rob Clark reports a sleeping while atomic bug when using perf. BUG: sleeping function called from invalid context at ../kernel/locking/mutex.c:583 in_atomic(): 1, irqs_disabled(): 128, pid: 0, name: swapper/0 ------------[ cut here ]------------ WARNING: CPU: 2 PID: 4828 at ../kernel/locking/mutex.c:479 mutex_lock_nested+0x3a0/0x3e8() DEBUG_LOCKS_WARN_ON(in_interrupt()) Modules linked in: CPU: 2 PID: 4828 Comm: Xorg.bin Tainted: G W 3.17.0-rc3-00234-gd535c45-dirty #819 [<c0216690>] (unwind_backtrace) from [<c0212174>] (show_stack+0x10/0x14) [<c0212174>] (show_stack) from [<c0867cc0>] (dump_stack+0x98/0xb8) [<c0867cc0>] (dump_stack) from [<c02492a4>] (warn_slowpath_common+0x70/0x8c) [<c02492a4>] (warn_slowpath_common) from [<c02492f0>] (warn_slowpath_fmt+0x30/0x40) [<c02492f0>] (warn_slowpath_fmt) from [<c086a3f8>] (mutex_lock_nested+0x3a0/0x3e8) [<c086a3f8>] (mutex_lock_nested) from [<c0294d08>] (irq_find_host+0x20/0x9c) [<c0294d08>] (irq_find_host) from [<c0769d50>] (of_irq_get+0x28/0x48) [<c0769d50>] (of_irq_get) from [<c057d104>] (platform_get_irq+0x1c/0x8c) [<c057d104>] (platform_get_irq) from [<c021a06c>] (cpu_pmu_enable_percpu_irq+0x14/0x38) [<c021a06c>] (cpu_pmu_enable_percpu_irq) from [<c02b1634>] (flush_smp_call_function_queue+0x88/0x178) [<c02b1634>] (flush_smp_call_function_queue) from [<c0214dc0>] (handle_IPI+0x88/0x160) [<c0214dc0>] (handle_IPI) from [<c0208930>] (gic_handle_irq+0x64/0x68) [<c0208930>] (gic_handle_irq) from [<c0212d04>] (__irq_svc+0x44/0x5c) Exception stack(0xe63ddea0 to 0xe63ddee8) dea0: 00000001 00000001 00000000 c2f3b200 c16db380 c032d4a0 e63ddf40 60010013 dec0: 00000000 001fbfd4 00000100 00000000 00000001 e63ddee8 c0284770 c02a2e30 dee0: 20010013 ffffffff [<c0212d04>] (__irq_svc) from [<c02a2e30>] (ktime_get_ts64+0x1c8/0x200) [<c02a2e30>] (ktime_get_ts64) from [<c032d4a0>] (poll_select_set_timeout+0x60/0xa8) [<c032d4a0>] (poll_select_set_timeout) from [<c032df64>] (SyS_select+0xa8/0x118) [<c032df64>] (SyS_select) from [<c020e8e0>] (ret_fast_syscall+0x0/0x48) ---[ end trace 0bb583b46342da6f ]--- INFO: lockdep is turned off. We don't really need to get the platform irq again when we're enabling or disabling the per-cpu irq. Furthermore, we don't really need to set and clear bits in the active_irqs bitmask because that's only used in the non-percpu irq case to figure out when the last CPU PMU has been disabled. Just pass the irq directly to the enable/disable functions to clean all this up. This should be slightly more efficient and also fix the scheduling while atomic bug. Fixes: bbd64559376f "ARM: perf: support percpu irqs for the CPU PMU" Reported-by: Rob Clark <robdclark@gmail.com> Acked-by: Will Deacon <will.deacon@arm.com> Cc: stable@vger.kernel.org Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-08-05Merge branch 'devel-stable' into for-nextRussell King
Conflicts: arch/arm/kernel/perf_event_cpu.c
2014-07-18ARM: make it easier to check the CPU part number correctlyRussell King
Ensure that platform maintainers check the CPU part number in the right manner: the CPU part number is meaningless without also checking the CPU implement(e|o)r (choose your preferred spelling!) Provide an interface which returns both the implementer and part number together, and update the definitions to include the implementer. Mark the old function as being deprecated... indeed, using the old function with the definitions will now always evaluate as false, so people must update their un-merged code to the new function. While this could be avoided by adding new definitions, we'd also have to create new names for them which would be awkward. Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-07-02arm: perf: add more specific platform device IDsMark Rutland
When described in DT, PMUs are given specific compatible strings (e.g. "arm,cortex-a15-pmu") which makes it very easy to reorganise the way individual PMUs are handled (i.e. we can easily split them into separate drivers). The same is not true of PMUs described in board files, which are all use the platform_device_id "arm-pmu" and must all be handled by the same driver. To enable splitting the ARMv6, ARMv7, and XScale PMU drivers we need board files to identify which variant they provide. As a first step, this patch adds new platform_device_id values: "armv6-pmu", "armv7-pmu, and "xscale-pmu". Once board files are moved over and all existing uses of "arm-pmu" are gone, we can split the existing driver apart. Acked-by: Will Deacon <will.deacon@arm.com> Tested-by: Christopher Covington <cov@codeaurora.org> Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2014-07-02arm: perf: clean up PMU namesMark Rutland
The perf userspace tools can't handle dashes or spaces in PMU names, which conflicts with the current naming scheme in the arm perf backend. This prevents these PMUs from being accessed by name from the perf tools. Additionally the ARMv6 pmus are named "v6", which does not fully distinguish them in the sys/bus/event_source namespace. This patch renames the PMUs consistently to a lower case form with underscores, e.g. "armv6_1176", "armv7_cortex_a9". This is both readily accepted by today's perf tool, and far easier to type than the (apparently unused) convention in use previously. The OProfile name conversion code is updated to handle this. Due to a copy-paste error involving two "xscale1" entries, "xscale2" has never been matched by the name OProfile name mapping. While we're updating names, this is corrected. Acked-by: Will Deacon <will.deacon@arm.com> Tested-by: Christopher Covington <cov@codeaurora.org> Signed-off-by: Mark Rutland <mark.rutland@arm.com> [sachin: fixed missing semicolons in armv6 backend] Signed-off-by: Sachin Kamat <sachin.kamat@samsung.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2014-06-12Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull more perf updates from Ingo Molnar: "A second round of perf updates: - wide reaching kprobes sanitization and robustization, with the hope of fixing all 'probe this function crashes the kernel' bugs, by Masami Hiramatsu. - uprobes updates from Oleg Nesterov: tmpfs support, corner case fixes and robustization work. - perf tooling updates and fixes from Jiri Olsa, Namhyung Ki, Arnaldo et al: * Add support to accumulate hist periods (Namhyung Kim) * various fixes, refactorings and enhancements" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (101 commits) perf: Differentiate exec() and non-exec() comm events perf: Fix perf_event_comm() vs. exec() assumption uprobes/x86: Rename arch_uprobe->def to ->defparam, minor comment updates perf/documentation: Add description for conditional branch filter perf/x86: Add conditional branch filtering support perf/tool: Add conditional branch filter 'cond' to perf record perf: Add new conditional branch filter 'PERF_SAMPLE_BRANCH_COND' uprobes: Teach copy_insn() to support tmpfs uprobes: Shift ->readpage check from __copy_insn() to uprobe_register() perf/x86: Use common PMU interrupt disabled code perf/ARM: Use common PMU interrupt disabled code perf: Disable sampled events if no PMU interrupt perf: Fix use after free in perf_remove_from_context() perf tools: Fix 'make help' message error perf record: Fix poll return value propagation perf tools: Move elide bool into perf_hpp_fmt struct perf tools: Remove elide setup for SORT_MODE__MEMORY mode perf tools: Fix "==" into "=" in ui_browser__warning assignment perf tools: Allow overriding sysfs and proc finding with env var perf tools: Consider header files outside perf directory in tags target ...
2014-06-05perf/ARM: Use common PMU interrupt disabled codeVince Weaver
Make the ARM perf code use the new common PMU interrupt disabled code. This allows perf to work on ARM machines without a working PMU interrupt (for example, raspberry pi). Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Vince Weaver <vincent.weaver@maine.edu> [peterz: applied changes suggested by Will] Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Grant Likely <grant.likely@linaro.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Rob Herring <robh+dt@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Will Deacon <will.deacon@arm.com> Cc: devicetree@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1405161712190.11099@vincent-weaver-1.umelst.maine.edu [ Small readability tweaks to the code. ] Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-25ARM: 8054/1: perf: add support for the Cortex-A17 PMUWill Deacon
The Cortex-A17 PMU is identical to that of the A12, so wire up a new compatible string to the existing event structures. Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-02-21ARM: perf: add support for the Cortex-A12 PMUAlbin Tonnerre
Cortex-A12 implements Performance Monitors compliant with the PMUv2 architecture. This patch adds support for the Cortex-A12 PMU to the ARM perf backend. Signed-off-by: Albin Tonnerre <albin.tonnerre@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2014-02-21ARM: perf: remove unused PMU probing codeMark Rutland
The ARM perf backend can discover the type of PMU it needs to drive either from DT or by probing a CPU it is running on. For Cortex-A{5,7,15} there are no platforms in mainline not using dt, and this probing won't work well for big.LITTLE systems with heterogeneous PMUs. This patch drops the probing for those CPUs, relying on information from dt instead. Future platforms should describe their PMU(s) with dt. Suggested-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2014-02-21ARM: perf: add basic support for Krait CPU PMUsStephen Boyd
Add basic support for the Krait CPU PMU. This allows us to use the architected functionality of the PMU. This is based on code originally written by Ashwin Chaugule and Neil Leeder [1]. [1] https://www.codeaurora.org/cgit/quic/la/kernel/msm/tree/arch/arm/kernel/perf_event_msm_krait.c?h=msm-3.4 Cc: Neil Leeder <nleeder@codeaurora.org> Cc: Ashwin Chaugule <ashwinc@codeaurora.org> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Will Deacon <will.deacon@arm.com>
2014-02-21ARM: perf: assign pdev pointer earlier for CPU PMUsStephen Boyd
We want to inspect the of_node that the pdev is pointing to in the Krait CPU specific PMU initialization function. Assign it earlier so that we don't crash with a NULL pointer dereference. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Will Deacon <will.deacon@arm.com>
2014-02-21ARM: perf: support percpu irqs for the CPU PMUStephen Boyd
Some CPU PMUs are wired up with one PPI for all the CPUs instead of with a different SPI for each CPU. Add support for these devices. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Will Deacon <will.deacon@arm.com>
2014-01-11ARM: 7937/1: perf_event: Silence sparse warningStephen Boyd
arch/arm/kernel/perf_event_cpu.c:274:25: warning: incorrect type in assignment (different modifiers) arch/arm/kernel/perf_event_cpu.c:274:25: expected int ( *init_fn )( ... ) arch/arm/kernel/perf_event_cpu.c:274:25: got void const *const data Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-10-29ARM: 7862/1: pcpu: replace __get_cpu_var_usesChristoph Lameter
This is the ARM part of Christoph's patchset cleaning up the various uses of __get_cpu_var across the tree. The idea is to convert __get_cpu_var into either an explicit address calculation using this_cpu_ptr() or into a use of this_cpu operations that use the offset. Thereby address calculations are avoided and fewer registers are used when code is generated. [will: fixed debug ref counting checks and pcpu array accesses] Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-08-20ARM: 7813/1: Mark pmu interupt IRQF_NO_THREADThomas Gleixner
PMU interrupts must not be threaded. Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-07-14arm: delete __cpuinit/__CPUINIT usage from all ARM usersPaul Gortmaker
The __cpuinit type of throwaway sections might have made sense some time ago when RAM was more constrained, but now the savings do not offset the cost and complications. For example, the fix in commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time") is a good example of the nasty type of bugs that can be created with improper use of the various __init prefixes. After a discussion on LKML[1] it was decided that cpuinit should go the way of devinit and be phased out. Once all the users are gone, we can then finally remove the macros themselves from linux/init.h. Note that some harmless section mismatch warnings may result, since notify_cpu_starting() and cpu_up() are arch independent (kernel/cpu.c) and are flagged as __cpuinit -- so if we remove the __cpuinit from the arch specific callers, we will also get section mismatch warnings. As an intermediate step, we intend to turn the linux/init.h cpuinit related content into no-ops as early as possible, since that will get rid of these warnings. In any case, they are temporary and harmless. This removes all the ARM uses of the __cpuinit macros from C code, and all __CPUINIT from assembly code. It also had two ".previous" section statements that were paired off against __CPUINIT (aka .section ".cpuinit.text") that also get removed here. [1] https://lkml.org/lkml/2013/5/20/589 Cc: Russell King <linux@arm.linux.org.uk> Cc: Will Deacon <will.deacon@arm.com> Cc: linux-arm-kernel@lists.infradead.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2013-01-18ARM: perf: handle armpmu_register failingMark Rutland
Currently perf_pmu_register may fail for several reasons (e.g. being unable to allocate memory for the struct device it associates with each PMU), and while any error is propagated by armpmu_register, it is ignored by cpu_pmu_device_probe and not propagated to the caller. This also results in a leak of a struct arm_pmu. This patch adds cleanup if armpmu_register fails, and updates the info messages to better differentiate this type of failure from a failure to probe the PMU type from the hardware or dt. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2013-01-14ARM: perf: remove redundant NULL check on cpu_pmuWill Deacon
cpu_pmu has already been dereferenced before we consider invoking the ->reset function, so remove the redundant NULL check. Reported-by: Cong Ding <dinggnu@gmail.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2013-01-11ARM: Use implementor and part defines from cputype.hChristoffer Dall
Instead of decoding implementor numbers, part numbers and Xscale architecture masks inline in the pmu probing function, use defines and accessor functions from cputype.h, which can also be shared by other subsystems, such as KVM. Signed-off-by: Christoffer Dall <c.dall@virtualopensystems.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2013-01-03ARM: drivers: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-09ARM: perf: consistently use arm_pmu->name for PMU nameWill Deacon
Perf has three ways to name a PMU: either by passing an explicit char *, reading arm_pmu->name or accessing arm_pmu->pmu.name. Just use arm_pmu->name consistently in the ARM backend. Signed-off-by: Will Deacon <will.deacon@arm.com>
2012-11-09ARM: perf: return NOTIFY_DONE from cpu notifier when no available PMUWill Deacon
When attempting to reset the PMU state for either a NULL PMU or a PMU implementation without a reset function, return NOTIFY_DONE from the CPU notifier as we don't care about the hotplug event. Signed-off-by: Will Deacon <will.deacon@arm.com>
2012-11-09ARM: perf: register cpu_notifier at driver initMark Rutland
The current practice of registering the cpu hotplug notifier at PMU registration time won't be safe with multiple PMUs, as we'll repeatedly attempt to register the notifier. This has the unfortunate effect of silently corrupting the notifier list, leading to boot stalling. Instead, register the notifier at init time. Its sanity checks will prevent anything bad from happening if the notifier is called before we have any PMUs registered. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2012-11-09ARM: perf: consistently use struct perf_event in arm_pmu functionsSudeep KarkadaNagesha
The arm_pmu functions have wildly varied parameters which can often be derived from struct perf_event. This patch changes the arm_pmu function prototypes so that struct perf_event pointers are passed in preference to fields that can be derived from the event. Signed-off-by: Sudeep KarkadaNagesha <Sudeep.KarkadaNagesha@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2012-11-09ARM: perf: allocate CPU PMU dynamically at probe timeSudeep KarkadaNagesha
Supporting multiple, heterogeneous CPU PMUs requires us to allocate the arm_pmu structures dynamically as the devices are probed. This patch removes the static structure definitions for each CPU PMU type and instead passes pointers to the PMU-specific init functions. Signed-off-by: Sudeep KarkadaNagesha <Sudeep.KarkadaNagesha@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2012-08-23ARM: perf: move irq registration into pmu implementationSudeep KarkadaNagesha
This patch moves the CPU-specific IRQ registration and parsing code into the CPU PMU backend. This is required because a PMU may have more than one interrupt, which in turn can be either PPI (per-cpu) or SPI (requiring strict affinity setting at the interrupt distributor). Signed-off-by: Sudeep KarkadaNagesha <Sudeep.KarkadaNagesha@arm.com> [will: cosmetic edits and reworked interrupt dispatching] Signed-off-by: Will Deacon <will.deacon@arm.com>
