path: root/arch/arm/kernel/dma-isa.c
2006-05-16[ARM] arch/arm/kernel/dma-isa.c: named initializersAdrian Bunk
This patch converts struct dma_resources to named initializers. Besides fixing a compile error in -mm, it didn't sound like a bad idea. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Alexander Schulz <alex@shark-linux.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-04[ARM] Remove '__address' from scatterlist and convert to DMA APIRussell King
The old __address element in struct scatterlist remained from older kernels because the ARM DMA emulation code made use of it. Move this field into struct dma_struct, and convert DMA emulation code to setup a SG entry as required. Also, convert DMA emulation code to use the new DMA API rather than the PCI DMA API. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
