path: root/arch/arm/common
2011-10-15ARM: 7128/1: vic: Don't write to the read-only register VIC_IRQ_STATUSZoltan Devai
This is unneeded and causes an abort on the SPMP8000 platform. Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Zoltan Devai <zoss@devai.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-29Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: remove printks about disabled bridge windows PCI: fold pci_calc_resource_flags() into decode_bar() PCI: treat mem BAR type "11" (reserved) as 32-bit, not 64-bit, BAR PCI: correct pcie_set_readrq write size PCI: pciehp: change wait time for valid configuration access x86/PCI: Preserve existing pci=bfsort whitelist for Dell systems PCI: ARI is a PCIe v2 feature x86/PCI: quirks: Use pci_dev->revision PCI: Make the struct pci_dev * argument of pci_fixup_irqs const. PCI hotplug: cpqphp: use pci_dev->vendor PCI hotplug: cpqphp: use pci_dev->subsystem_{vendor|device} x86/PCI: config space accessor functions should not ignore the segment argument PCI: Assign values to 'pci_obff_signal_type' enumeration constants x86/PCI: reduce severity of host bridge window conflict warnings PCI: enumerate the PCI device only removed out PCI hieratchy of OS when re-scanning PCI PCI: PCIe AER: add aer_recover_queue x86/PCI: select direct access mode for mmconfig option PCI hotplug: Rename is_ejectable which also exists in dock.c
2011-07-26Merge branch 'next/devel' of ↵Linus Torvalds
ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/devel' of ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (128 commits) ARM: S5P64X0: External Interrupt Support ARM: EXYNOS4: Enable MFC on Samsung NURI ARM: EXYNOS4: Enable MFC on universal_c210 ARM: S5PV210: Enable MFC on Goni ARM: S5P: Add support for MFC device ARM: EXYNOS4: Add support FIMD on SMDKC210 ARM: EXYNOS4: Add platform device and helper functions for FIMD ARM: EXYNOS4: Add resource definition for FIMD ARM: EXYNOS4: Change devname for FIMD clkdev ARM: SAMSUNG: Add IRQ_I2S0 definition ARM: SAMSUNG: Add platform device for idma ARM: EXYNOS4: Add more registers to be saved and restored for PM ARM: EXYNOS4: Add more register addresses of CMU ARM: EXYNOS4: Add platform device for dwmci driver ARM: EXYNOS4: configure rtc-s3c on NURI ARM: EXYNOS4: configure MAX8903 secondary charger on NURI ARM: EXYNOS4: configure ADC on NURI ARM: EXYNOS4: configure MAX17042 fuel gauge on NURI ARM: EXYNOS4: configure regulators and PMIC(MAX8997) on NURI ARM: EXYNOS4: Increase NR_IRQS for devices with more IRQs ... Fix up tons of silly conflicts: - arch/arm/mach-davinci/include/mach/psc.h - arch/arm/mach-exynos4/Kconfig - arch/arm/mach-exynos4/mach-smdkc210.c - arch/arm/mach-exynos4/pm.c - arch/arm/mach-imx/mm-imx1.c - arch/arm/mach-imx/mm-imx21.c - arch/arm/mach-imx/mm-imx25.c - arch/arm/mach-imx/mm-imx27.c - arch/arm/mach-imx/mm-imx31.c - arch/arm/mach-imx/mm-imx35.c - arch/arm/mach-mx5/mm.c - arch/arm/mach-s5pv210/mach-goni.c - arch/arm/mm/Kconfig
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-22Merge branches 'btc', 'dma', 'entry', 'fixes', 'linker-layout', 'misc', ↵Russell King
'mmci', 'suspend' and 'vfp' into for-next
2011-07-22PCI: Make the struct pci_dev * argument of pci_fixup_irqs const.Ralf Baechle
Aside of the usual motivation for constification, this function has a history of being abused a hook for interrupt and other fixups so I turned this function const ages ago in the MIPS code but it should be done treewide. Due to function pointer passing in varous places a few other functions had to be constified as well. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> To: Anton Vorontsov <avorontsov@mvista.com> To: Chris Metcalf <cmetcalf@tilera.com> To: Colin Cross <ccross@android.com> Acked-by: "David S. Miller" <davem@davemloft.net> To: Eric Miao <eric.y.miao@gmail.com> To: Erik Gilling <konkers@android.com> Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> To: "H. Peter Anvin" <hpa@zytor.com> To: Imre Kaloz <kaloz@openwrt.org> To: Ingo Molnar <mingo@redhat.com> To: Ivan Kokshaysky <ink@jurassic.park.msu.ru> To: Jesse Barnes <jbarnes@virtuousgeek.org> To: Krzysztof Halasa <khc@pm.waw.pl> To: Lennert Buytenhek <kernel@wantstofly.org> To: Matt Turner <mattst88@gmail.com> To: Nicolas Pitre <nico@fluxnic.net> To: Olof Johansson <olof@lixom.net> Acked-by: Paul Mundt <lethal@linux-sh.org> To: Richard Henderson <rth@twiddle.net> To: Russell King <linux@arm.linux.org.uk> To: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-alpha@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: linux-pci@vger.kernel.org Cc: linux-sh@vger.kernel.org Cc: linux-tegra@vger.kernel.org Cc: sparclinux@vger.kernel.org Cc: x86@kernel.org Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-07-21ARM: GIC: avoid routing interrupts to offline CPUsRussell King
The irq_set_affinity() method can be called with masks which include offline CPUs. This allows offline CPUs to have interrupts routed to them by writing to /proc/irq/*/smp_affinity after hotplug has taken a CPU offline. Fix this by ensuring that we select a target CPU present in both the required affinity and the online CPU mask. Ensure that we return IRQ_SET_MASK_OK (which happens to be 0) on success to ensure generic code copies the new mask into the irq_data structure. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-21ARM: CPU hotplug: fix abuse of irqdesc->nodeRussell King
irqdesc's node member is supposed to mark the numa node number for the interrupt. Our use of it is non-standard. Remove this, replacing the functionality with a test of the affinity mask. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-20ARM: GIC: move gic_chip_data structure declaration to headerChanghwan Youn
Since Samsung EXYNOS4210 cannot support register banking in GIC, so needs to update CPU interface base address. The 'gic_chip_data' is used for it, this patch moves gic_chip_data structure declaraton to arch/arm/include/asm/hardware/gic.h to use it. Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Changhwan Youn <chaos.youn@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-11Merge branch 'master' into for-nextJiri Kosina
Sync with Linus' tree to be able to apply pending patches that are based on newer code already present upstream.
2011-07-04ARM: dmabounce: no need to check dev->bus type in needs_bounce functionRussell King
As the needs_bounce function is passed at DMA bounce register time, we already know what the device bus type is, so we don't need to check it each time the needs_bounce function is called. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-04ARM: dmabounce: get rid of dma_needs_bounce global functionRussell King
Pass the device type specific needs_bounce function in at dmabounce register time, avoiding the need for a platform specific global function to do this. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-03ARM: dmabounce: correct unmap_single dev_dbgRussell King
DMA addresses should not be casted to void * for printing. Fix that to be consistent with the rest of the file. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-03ARM: dmabounce: check pointer against NULL not 0Russell King
Pointers should be checked against NULL rather than 0, otherwise we get sparse warnings. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-03ARM: dmabounce: remove useless pr_errRussell King
We already check that dev != NULL, so this won't be reached. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-03ARM: dmabounce: move decision for bouncing into __dma_map_page()Russell King
Move the decision whether to bounce into __dma_map_page(), before the check for high pages. This avoids triggering the high page check for devices which aren't using dmabounce. Fix the unmap path to cope too. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-03ARM: dmabounce: separate out decision to bounceRussell King
Move the decision to perform DMA bouncing out of map_single() into its own stand-alone function. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-03ARM: dmabounce: avoid needless valid_dma_direction() checkRussell King
This check is done at the DMA API level, so there's no point repeating it here. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-03ARM: dma-mapping: define dma_(un)?map_single in terms of dma_(un)?map_pageRussell King
Use dma_map_page()/dma_unmap_page() internals to handle dma_map_single() and dma_unmap_single(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-03ARM: dmabounce: fix map_single() error return valueRussell King
When map_single() is unable to obtain a safe buffer, we must return the dma_addr_t error value, which is ~0 rather than 0. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-25Merge branch 'for-rmk' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into devel-stable Conflicts: arch/arm/Kconfig arch/arm/mach-exynos4/mach-nuri.c
2011-05-23Merge branch 'devel-stable' into for-linusRussell King
Conflicts: arch/arm/Kconfig arch/arm/mach-ns9xxx/include/mach/uncompress.h
2011-05-23Merge branches 'consolidate-clksrc', 'consolidate-flash', ↵Russell King
'consolidate-generic', 'consolidate-smp', 'consolidate-stmp' and 'consolidate-zones' into consolidate
2011-05-23clockevents: ARM sp804: obtain sp804 timer rate via clksRussell King
This allows platforms to specify the rate of the SP804 clockevent via the clk subsystem. While ARM boards clock these at 1MHz, BCMRing also has SP804 timers but are clocked at different rates. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-23clockevents: ARM sp804: allow clockevent name to be specifiedRussell King
This allows platforms to specify the clcokevent name upon registration. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-23clocksource: ARM sp804: obtain sp804 timer rate via clksRussell King
This allows platforms to specify the rate of the SP804 clocksource via the clk subsystem. While ARM boards clock these at 1MHz, BCMRing also has SP804 timers but are clocked at different rates. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-23clocksource: ARM sp804: allow clocksource name to be specifiedRussell King
This allows platforms to specify the clocksource name upon registration, which is necessary should they wish to register more than one sp804 clocksource. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-23clocksource: convert ARM 32-bit down counting clocksourcesRussell King
Convert SP804, MXC, Nomadik and Orion 32-bit down-counting clocksources to generic mmio clocksource infrastructure. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: Alessandro Rubini <rubini@unipv.it> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Lennert Buytenhek <kernel@wantstofly.org> Acked-by: Nicolas Pitre <nico@fluxnic.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-12ARM: use ARM_DMA_ZONE_SIZE to adjust the zone sizesRussell King
Rather than each platform providing its own function to adjust the zone sizes, use the new ARM_DMA_ZONE_SIZE definition to perform this adjustment. This ensures that the actual DMA zone size and the ISA_DMA_THRESHOLD/MAX_DMA_ADDRESS definitions are consistent with each other, and moves this complexity out of the platform code. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-12ARM: S5P6442: Removing ARCH_S5P6442Kukjin Kim
2011-05-11ARM: GIC: Convert GIC library to use the IO relaxed operationsSantosh Shilimkar
The GIC register accesses today make use of readl()/writel() which prove to be very expensive when used along with mandatory barriers. This mandatory barriers also introduces an un-necessary and expensive l2x0_sync() operation. On Cortex-A9 MP cores, GIC IO accesses from CPU are direct and doesn't go through L2X0 write buffer. A DSB before writel_relaxed() in gic_raise_softirq() is added to be compliant with the Barrier Litmus document - the mailbox scenario. Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com>
2011-05-11ARM: gic: use handle_fasteoi_irq for SPIsWill Deacon
Currently, the gic uses handle_level_irq for handling SPIs (Shared Peripheral Interrupts), requiring active interrupts to be masked at the distributor level during IRQ handling. On a virtualised system, only the CPU interfaces are virtualised in hardware. Accesses to the distributor must be trapped by the hypervisor, adding latency to the critical interrupt path in Linux. This patch modifies the GIC code to use handle_fasteoi_irq for handling interrupts, which only requires us to signal EOI to the CPU interface when handling is complete. Cascaded IRQ handling is also updated to use the chained IRQ enter/exit functions to honour the flow control of the parent chip. Note that commit 846afbd1 ("GIC: Dont disable INT in ack callback") broke cascading interrupts by forgetting to add IRQ masking. This is no longer an issue because the unmask call is now unnecessary. Tested on Versatile Express and Realview EB (1176 w/ cascaded GICs). Tested-and-reviewed-by: Abhijeet Dharmapurikar <adharmap@codeaurora.org> Tested-and-acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2011-04-24ARM: Use struct syscore_ops instead of sysdevs for PM in common codeRafael J. Wysocki
Convert some ARM architecture's common code to using struct syscore_ops objects for power management instead of sysdev classes and sysdevs. This simplifies the code and reduces the kernel's memory footprint. It also is necessary for removing sysdevs from the kernel entirely in the future. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-13Merge branch 'fix' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into fixes
2011-04-10ARM: 6872/1: arch:common:Makefile Remove unused config in the Makefile.Justin P. Mattock
The patch below removes an unused config variable found by using a kernel cleanup script. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-03-29arm: Fold irq_set_chip/irq_set_handlerThomas Gleixner
Use irq_set_chip_and_handler() instead. Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Reorder irq_set_ function callsThomas Gleixner
Reorder irq_set_chip() irq_set_chip_data() irq_set_handler() to irq_set_chip() irq_set_handler() irq_set_chip_data() so the next patch can combine irq_set_chip() and irq_set_handler() to irq_set_chip_and_handler(). Automated conversion with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: gic: Use proper accessor functionsThomas Gleixner
2011-03-16Merge branch 'misc' into develRussell King
2011-03-09ARM: 6777/1: gic: Add hooks for architecture specific extensionsSantosh Shilimkar
Few architectures combine the GIC with an external interrupt controller. On such systems it may be necessary to update both the GIC registers and the external controller's registers to control IRQ behavior. This can be addressed in couple of possible methods. 1. Export common GIC routines along with 'struct irq_chip gic_chip' and allow architectures to have custom function by override. 2. Provide architecture specific function pointer hooks within GIC library and leave platforms to add the necessary code as part of these hooks. First one might be non-intrusive but have few shortcomings like arch needs to have there own custom gic library. Locks used should be common since it caters to same IRQs etc. Maintenance point of view also it leads to multiple file fixes. The second probably is cleaner and portable. It ensures that all the common GIC infrastructure is not touched and also provides archs to address their specific issue. Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Colin Cross <ccross@android.com> Tested-by: Colin Cross <ccross@android.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-26ARM: 6762/1: Update number of VIC for S5P6442 and S5PC100Kukjin Kim
The S5P6442 and S5PC100 SoCs have 4 VICs. However, default VIC number is defined 2 in arch/arm/common. So can be happened some problem on it. Basically, it requires for suspend and resume. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-26ARM: 6761/1: Update number of VIC for S5PV210Kukjin Kim
The S5PV210 SoC have 4 VICs. It requires for suspend and resume. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-23ARM: irq migration: update GIC migration codeRussell King
This cleans up after the conversion to irq_data. Rename the function to match the method, and remove the now useless lookup of the irq descriptor which is never used. Move the bitmask calculation out of the irq_controller_lock region. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-15Merge branch 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (161 commits) ARM: pxa: fix building issue of missing physmap.h ARM: mmp: PXA910 drive strength FAST using wrong value ARM: mmp: MMP2 drive strength FAST using wrong value ARM: pxa: fix recursive calls in pxa_low_gpio_chip AT91: Support for gsia18s board AT91: Acme Systems FOX Board G20 board files AT91: board-sam9m10g45ek.c: Remove duplicate inclusion of mach/hardware.h ARM: pxa: fix suspend/resume array index miscalculation ARM: pxa: use cpu_has_ipr() consistently in irq.c ARM: pxa: remove unused variable in clock-pxa3xx.c ARM: pxa: fix warning in zeus.c ARM: sa1111: fix typo in sa1111_retrigger_lowirq() ARM mxs: clkdev related compile fixes ARM i.MX mx31_3ds: Fix MC13783 regulator names ARM: plat-stmp3xxx: irq_data conversion. ARM: plat-spear: irq_data conversion. ARM: plat-orion: irq_data conversion. ARM: plat-omap: irq_data conversion. ARM: plat-nomadik: irq_data conversion. ARM: plat-mxc: irq_data conversion. ... Fix up trivial conflict in arch/arm/plat-omap/gpio.c (Lennert Buytenhek's irq_data conversion clashing with some omap irq updates)
2011-01-14ARM: sa1111: fix typo in sa1111_retrigger_lowirq()Pavel Machek
Signed-off-by: Pavel Machek <pma@sysgo.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2011-01-13ARM: vic: irq_data conversion.Lennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
