This patch fixes a typo introduced by
commit f37f46eb1c0bd0b11c34ef06c7365658be989d80
([ARM] nommu: add ARM946E-S core support).
Reported-by: Robert P. J. Day <rpjday@crashcourse.ca>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Acked-by: Hyok S. Choi <hyok.choi@samsung.com>
arch/arm/mm/Kconfig
'omap-reviewed', 'rpc', 'rtc' and 's3c' into devel
This patch adds basic mach support for the mx2 processor family, based
on the original freescale code and adapted to mainline kernel coding
style.
This part adds the global build only.
Signed-off-by: Juergen Beisert <j.beisert@pengutronix.de>
The config option for building drivers/acorn/char/defkeymap-l7200.c is
not present since at least kernel 2.6.0.
arch/arm/Kconfig
The Marvell Discovery Duo (MV78xx0) is a family of ARM SoCs featuring
(depending on the model) one or two Feroceon CPU cores with 512K of L2
cache and VFP coprocessors running at (depending on the model) between
800 MHz and 1.2 GHz, and features a DDR2 controller, two PCIe
interfaces that can each run either in x4 or quad x1 mode, three USB
2.0 interfaces, two 3Gb/s SATA II interfaces, a SPI interface, two
TWSI interfaces, a crypto accelerator, IDMA/XOR engines, a SPI
interface, four UARTs, and depending on the model, two or four gigabit
ethernet interfaces.
This patch adds basic support for the platform, and allows booting
on the MV78x00 development board, with functional UARTs, SATA, PCIe,
GigE and USB ports.
Signed-off-by: Stanislav Samsonov <samsonov@marvell.com>
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
The Marvell Kirkwood (88F6000) is a family of ARM SoCs based on a
Shiva CPU core, and features a DDR2 controller, a x1 PCIe interface,
a USB 2.0 interface, a SPI controller, a crypto accelerator, a TS
interface, and IDMA/XOR engines, and depending on the model, also
features one or two Gigabit Ethernet interfaces, two SATA II
interfaces, one or two TWSI interfaces, one or two UARTs, a
TDM/SLIC interface, a NAND controller, an I2S/SPDIF interface, and
an SDIO interface.
This patch adds supports for the Marvell DB-88F6281-BP Development
Board and the RD-88F6192-NAS and the RD-88F6281 Reference Designs,
enabling support for the PCIe interface, the USB interface, the
ethernet interfaces, the SATA interfaces, the TWSI interfaces, the
UARTs, and the NAND controller.
Signed-off-by: Saeed Bishara <saeed@marvell.com>
The Marvell Loki (88RC8480) is an ARM SoC based on a Feroceon CPU
core running at between 400 MHz and 1.0 GHz, and features a 64 bit
DDR controller, 512K of internal SRAM, two x4 PCI-Express ports,
two Gigabit Ethernet ports, two 4x SAS/SATA controllers, two UARTs,
two TWSI controllers, and IDMA/XOR engines.
This patch adds support for the Marvell LB88RC8480 Development
Board, enabling the use of the PCIe interfaces, the ethernet
interfaces, the TWSI interfaces and the UARTs.
Trying to compile a kerel for ARCH_CO285 fails with the following error:
<-- snip -->
CC arch/arm/mach-footbridge/dc21285.o
/home/bunk/linux/kernel-2.6/git/linux-2.6/arch/arm/mach-footbridge/dc21285.c:
In function 'dc21285_base_address':
/home/bunk/linux/kernel-2.6/git/linux-2.6/arch/arm/mach-footbridge/dc21285.c:54: error: 'PCICFG0_BASE' undeclared (first use in this function)
/home/bunk/linux/kernel-2.6/git/linux-2.6/arch/arm/mach-footbridge/dc21285.c:54: error: (Each undeclared identifier is reported only once
/home/bunk/linux/kernel-2.6/git/linux-2.6/arch/arm/mach-footbridge/dc21285.c:54: error: for each function it appears in.)
/home/bunk/linux/kernel-2.6/git/linux-2.6/arch/arm/mach-footbridge/dc21285.c:57: error: 'PCICFG1_BASE' undeclared (first use in this function)
In function 'dc21285_scan_bus':
/home/bunk/linux/kernel-2.6/git/linux-2.6/arch/arm/mach-footbridge/dc21285.c:286: error: implicit declaration of function 'pci_scan_bus'
make[2]: *** [arch/arm/mach-footbridge/dc21285.o] Error 1
<-- snip -->
This does not seem to be a recent breakage.
The ARCH_CO285 support is old - kernel 2.2.0 contains first traces of
it, an it seems to have been pretty complete in later 2.2 kernels.
Since it seems to be completely dead code now this patch therefore
removes it.
'ns9x', 'orion', 'pxa', 'sa1100', 's3c' and 'sparsemem' into devel
Signed-off-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com>
Do a global s/orion/orion5x/ of the Orion 5x-specific bits (i.e.
not the plat-orion bits.)
Reviewed-by: Tzachi Perelstein <tzachi@marvell.com>
Acked-by: Saeed Bishara <saeed@marvell.com>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Signed-off-by: Nicolas Pitre <nico@marvell.com>
Create arch/arm/plat-orion/, for peripherals shared between various
Marvell Orion SoCs.
* orion: (26 commits)
[ARM] Orion: implement power-off method for QNAP TS-109/209
[ARM] Orion: add support for QNAP TS-109/TS-209
[ARM] Orion: I2C support
[I2C] i2c-mv64xxx: Don't set i2c_adapter.retries
[I2C] Split mv643xx I2C platform support
[ARM] Orion: enable CONFIG_RTC_DRV_M41T80 for D-Link DNS-323
[ARM] Orion defconfig
[ARM] Orion: add support for Orion/MV88F5181 based D-Link DNS-323
[ARM] Orion: MV88F5181 support bits
[ARM] Orion: Buffalo/Revogear Kurobox Pro support
[ARM] OrionNAS RD board support
[ARM] Orion: support for Marvell Orion-2 (88F5281) Development Board
[ARM] Orion: common platform setup for Gigabit Ethernet port
[ARM] Orion: platform device registration for UART, USB and NAND
[ARM] Orion: system timer support
[ARM] Orion edge GPIO IRQ support
[ARM] Orion: IRQ support
[ARM] Orion: provide GPIO method for enabling hardware assisted blinking
[ARM] Orion: GPIO support
[ARM] Orion: programable address map support
arch/arm/Kconfig
arch/arm/Makefile
The Marvell Orion is a family of ARM SoCs with a DDR/DDR2 memory
controller, 10/100/1000 ethernet MAC, and USB 2.0 interfaces,
and, depending on the specific model, PCI-E interface, PCI-X
interface, SATA controllers, crypto unit, SPI interface, SDIO
interface, device bus, NAND controller, DMA engine and/or XOR
engine.
This contains the basic structure and architecture register definitions.
Signed-off-by: Tzachi Perelstein <tzachi@marvell.com>
Reviewed-by: Nicolas Pitre <nico@marvell.com>
Reviewed-by: Lennert Buytenhek <buytenh@marvell.com>
- core header files for arch-msm
- Kconfig and Makefiles to enable ARCH_MSM7X00A builds
- MSM7X00A specific arch_idle
- peripheral iomap and irq number definitions
Signed-off-by: Brian Swetland <swetland@google.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: (40 commits)
kbuild: introduce ccflags-y, asflags-y and ldflags-y
kbuild: enable 'make CPPFLAGS=...' to add additional options to CPP
kbuild: enable use of AFLAGS and CFLAGS on commandline
kbuild: enable 'make AFLAGS=...' to add additional options to AS
kbuild: fix AFLAGS use in h8300 and m68knommu
kbuild: check for wrong use of CFLAGS
kbuild: enable 'make CFLAGS=...' to add additional options to CC
kbuild: fix up CFLAGS usage
kbuild: make modpost detect unterminated device id lists
kbuild: call export_report from the Makefile
kbuild: move Kai Germaschewski to CREDITS
kconfig/menuconfig: distinguish between selected-by-another options and comments
kconfig: tristate choices with mixed tristate and boolean values
include/linux/Kbuild: remove duplicate entries
kbuild: kill backward compatibility checks
kbuild: kill EXTRA_ARFLAGS
kbuild: fix documentation in makefiles.txt
kbuild: call make once for all targets when O=.. is used
kbuild: pass -g to assembler under CONFIG_DEBUG_INFO
kbuild: update _shipped files for kconfig syntax cleanup
Fix up conflicts in arch/um/sys-{x86_64,i386}/Makefile manually.
The variable CPPFLAGS is a wellknown variable and the usage by
kbuild may result in unexpected behaviour.
This patch replace use of CPPFLAGS with KBUILD_CPPFLAGS all over the
tree and enabling one to use:
make CPPFLAGS=...
to specify additional CPP commandline options.
Patch was tested on following architectures:
alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k, s390
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
The variable AFLAGS is a wellknown variable and the usage by
On top of that several people over time has asked for a way to
pass in additional flags to gcc.
This patch replace use of AFLAGS with KBUILD_AFLAGS all over
the tree.
The variable CFLAGS is a wellknown variable and the usage by
This patch replace use of CFLAGS with KBUILD_CFLAGS all over the
make CFLAGS=...
to specify additional gcc commandline options.
One usecase is when trying to find gcc bugs but other
use cases has been requested too.
Test was simple to do a defconfig build, apply the patch and check
that nothing got rebuild.
Newer versions of binutils support --build-id, which adds an ELF
note section called ".note.gnu.build-id" to the output. On the ARM
kernel build, because there is no explicit mention of this section
in the shipped ld script, this section is placed at vaddr 0x00000000
(whereas the normal kernel text/data typically starts at vaddr
0xc0008000), causing the output of objcopy (Image) to produce a 3G+
file.
This patch makes objcopy strip the .note.gnu.build-id section from
the Image file along with all other note sections, which fixes the
build.
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org>
This patch adds the foundation pieces for
the Freescale MXC platforms, including
i.MX2 and i.MX3 based systems.
The bare-bones MX31 support in this patch
boots to the rootdev panic with 8250 serial
console configured "console=ttyS0,115200".
It assumes that Redboot is the boot loader.
Signed-off-by: Quinn Jensen <quinn.jensen@freescale.com>
Acked-by: Lennert Buytenhek <buytenh@wantstofly.org>
Add core support for the Kendin/Micrel KS8695 processor family.
It is an ARM922-T based SoC with integrated USART, 4-port Ethernet
Switch, WAN Ethernet port, and optional PCI Host bridge, etc.
http://www.micrel.com/page.do?page=product-info/sys_on_chip.jsp
This patch is based on earlier patches from Lennert Buytenhek, Ben
Dooks and Greg Ungerer posted to the arm-linux-kernel mailing list in
March 2006; and Micrel's 2.6.9 port.
Signed-off-by: Andrew Victor <andrew@sanpeople.com>
Add base kernel support for the TI DaVinci platform.
This patch only includes interrupts, timers, CPU identification,
serial support and basic power and sleep controller init. More
drivers to come.
Signed-off-by: Kevin Hilman <khilman@mvista.com>
This patch adds the necessary lines to the Makefile and Kconfig files for
enabling the compilation of the ARMv7 CPU support.
The rename of the AT91 subtree from mach-at91rm9200 to mach-at91
(to accomodate at91sam926x processors) was incomplete. It needs
this patch to be able to build again.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Fixed conflicts:
arch/arm/Makefile
arch/arm/mm/Kconfig
Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de>
Add arch/arm/mach-s3c2443 for support of the Samsung S3C2443 SoC
This patch adds the core CPU support, clock framework, times
and initial IRQ support, as well as adding the directory into
the build tree.
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
The following patch and script moves the arch/arm/mach-s3c2410
directory into arch/arm/plat-s3c24xx for the generic core code
and inti arch/arm/mach-s3c{cpu} for the cpu/machine support files
Include directory include/asm-arm/plat-s3c24xx is added for the
core include files.
Now that Linux includes support for the Atmel AT91SAM9260 and
AT91SAM9261 processors in addition to the original Atmel AT91RM9200
(with support for more AT91 processors pending), the "mach-at91rm9200"
and "arch-at91rm9200" directories should be renamed to indicate their
more generic nature.
The following git commands should be run BEFORE applying this patch:
git-mv arch/arm/mach-at91rm9200 arch/arm/mach-at91
git-mv include/asm-arm/arch-at91rm9200 include/asm-arm/arch-at91
Merge:
Atmel AT91RM9200 and AT91SAM9260 changes
General ARM developments
Disconfiguous memory cleanups
64-bit/32-bit division and sched_clock extension patches
EP93xx support changes
IOP support changes
The iop348 processor integrates an Xscale (XSC3 512KB L2 Cache) core with a
Serial Attached SCSI (SAS) controller, multi-ported DDR2 memory
controller, 3 Application Direct Memory Access (DMA) controllers, a 133Mhz
PCI-X interface, a x8 PCI-Express interface, and other peripherals to form
a system-on-a-chip RAID subsystem engine.
The iop342 processor replaces the SAS controller with a second Xscale core
for dual core embedded applications.
The iop341 processor is the single core version of iop342.
This patch supports the two Intel customer reference platforms iq81340mc
for external storage and iq81340sc for direct attach (HBA) development.
The developer's manual is available here:
ftp://download.intel.com/design/iio/docs/31503701.pdf
Changelog:
* removed virtual addresses from resource definitions
* cleaned up some unnecessary #include's
Do not assume that the ARM GCC toolchain defaults to building for the
32-bit ARM ISA (-marm) case. Instead, explicitly select -marm in CFLAGS
since the toolchain default can be for the 16-bit Thumb ISA (-mthumb) in
some odd/rare cases.
Signed-off-by: George G. Davis <gdavis@mvista.com>
Add support for KBUILD_IMAGE on ARM. This takes the usual target
specifiers (zImage/Image/etc) in the same way that powerpc does
(iow, without the arch/arm/boot prefix).
This patch adds ARM946E-S core support which has typically 8KB I&D cache.
It has a MPU and supports ARMv5TE instruction set.
Because the ARM946E-S core can be synthesizable with various cache size,
CONFIG_CPU_DCACHE_SIZE is defined for vendor specific configurations.
Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com>
This patch adds ARM940T core support which has 4KB D-cache, 4KB I-cache
and a MPU.
This patch adds ARM9TDMI core support which has no cache and no CP15
register(no memory control unit).
This patch adds ARM740T core support which has a MPU and 4KB or 8KB cache.
This patch adds ARM7TDMI core support which has no cache and no CP15
Introduce the arch/arm/plat-iop directory, for code shared between the
iop32x and iop33x, and move the common memory map setup bits there.
Split the iop3xx mach type into iop32x and iop33x -- split the config
symbols, and move the code in the mach-iop3xx directory to the mach-iop32x
and mach-iop33x directories.
userspace helpers
Patch from Lennert Buytenhek
On armv4t systems, we have always compiled the kernel with -march=armv4
instead of -march=armv4t, which means that any use of bx will bomb out.
Commit ba9b5d76372dc290b6ca04dad93927a22c2ac49a introduced the use of
bx in the kernel, which means we need to compile with -march=armv4t on
armv4t systems now.
Patch from Andrew Victor
This prepares the way for adding support for the new Atmel AT91SAM926x
processors.
Major changes:
- Rename time.c to at91rm9200_time.c
- Rename common.c to at91rm9200.c
- Introduce ARCH_AT91, of which ARCH_AT91RM9200, ARCH_AT91SAM9260 and
ARCH_AT91SAM9261 are dependent.
kbuild: trivial fixes in Makefile
kbuild: adding symbols in Kconfig and defconfig to TAGS
kbuild: replace abort() with exit(1)
kbuild: support for %.symtypes files
kbuild: fix silentoldconfig recursion
kbuild: add option for stripping modules while installing them
kbuild: kill some false positives from modpost
kbuild: export-symbol usage report generator
kbuild: fix make -rR breakage
kbuild: append -dirty for updated but uncommited changes
kbuild: append git revision for all untagged commits
kbuild: fix module.symvers parsing in modpost
kbuild: ignore make's built-in rules & variables
kbuild: bugfix with initramfs
kbuild: modpost build fix
kbuild: check license compatibility when building modules
kbuild: export-type enhancement to modpost.c
kbuild: add dependency on kernel.release to the package targets
kbuild: `make kernelrelease' speedup
kconfig: KCONFIG_OVERWRITECONFIG
Patch from Sascha Hauer
This patch adds the base support for Hilscher's netX network
processors.
Signed-off-by: Robert Schwebel <r.schwebel@pengutronix.de>
