path: root/arch/arc/kernel/irq.c
2015-06-19ARC: intc: split into ARCompact ISA specific, common bitsVineet Gupta
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2014-07-23ARC: [intc] mask/unmask can be hidden againVineet Gupta
2014-07-23ARC: [intc] don't mask all IRQ by defaultVineet Gupta
Hardware keeps them enabled on reset, and Linux needs to keep status quo. Any spurious interrupts will be reported/blocked by genirq. This helps remove a SMP IRQ quirk (next commit), where a peripheral IRQ is hard wired to core0, and request_irq()->unmask() happens on core1, keeping the IRQ masked on core0, needing an explicit unmask. Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2014-07-23ARC: [SMP] unify cpu private IRQ requests (TIMER/IPI)Vineet Gupta
The current cpu-private IRQ registration is ugly as it requires need to expose arch_unmask_irq() outside of intc code. So switch to percpu IRQ APIs: -request_percpu_irq [boot core] -enable_percpu_irq [all cores] Encapsulated in helper arc_request_percpu_irq() Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2014-05-05ARC: [SMP] ISS SMP extension bitrotVineet Gupta
* Move extension specific code out of common SMP code * Don't enable it by default for SMP Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2013-11-06arc: remove '__init' for get_hw_config_num_irq()Chen Gang
get_hw_config_num_irq() may be called by normal iss_model_init_smp() which is a function pointer for 'init_smp' which may be called by first_lines_of_secondary() which also need be normal too. The related warning (with allmodconfig): MODPOST vmlinux.o WARNING: vmlinux.o(.text+0x5814): Section mismatch in reference from the function iss_model_init_smp() to the function .init.text:get_hw_config_num_irq() The function iss_model_init_smp() references the function __init get_hw_config_num_irq(). This is often because iss_model_init_smp lacks a __init annotation or the annotation of get_hw_config_num_irq is wrong. Signed-off-by: Chen Gang <gang.chen@asianux.com>
2013-11-06ARC: Reset the value of Interrupt Priority RegisterVineet Gupta
In case bootloader has changed the priority of one/more IRQ lines Reported-by: Noam Camus <noamc@ezchip.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2013-09-12ARC: SMP failed to boot due to missing IVT setupNoam Camus
Commit 05b016ecf5e7a "ARC: Setup Vector Table Base in early boot" moved the Interrupt vector Table setup out of arc_init_IRQ() which is called for all CPUs, to entry point of boot cpu only, breaking booting of others. Fix by adding the same to entry point of non-boot CPUs too. read_arc_build_cfg_regs() printing IVT Base Register didn't help the casue since it prints a synthetic value if zero which is totally bogus, so fix that to print the exact Register. [vgupta: Remove the now stale comment from header of arc_init_IRQ and also added the commentary for halt-on-reset] Cc: Gilad Ben-Yossef <gilad@benyossef.com> Cc: Cc: <stable@vger.kernel.org> #3.11 Signed-off-by: Noam Camus <noamc@ezchip.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-27arc: delete __cpuinit usage from all arc filesPaul Gortmaker
The __cpuinit type of throwaway sections might have made sense some time ago when RAM was more constrained, but now the savings do not offset the cost and complications. For example, the fix in commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time") is a good example of the nasty type of bugs that can be created with improper use of the various __init prefixes. After a discussion on LKML[1] it was decided that cpuinit should go the way of devinit and be phased out. Once all the users are gone, we can then finally remove the macros themselves from linux/init.h. Note that some harmless section mismatch warnings may result, since notify_cpu_starting() and cpu_up() are arch independent (kernel/cpu.c) are flagged as __cpuinit -- so if we remove the __cpuinit from arch specific callers, we will also get section mismatch warnings. As an intermediate step, we intend to turn the linux/init.h cpuinit content into no-ops as early as possible, since that will get rid of these warnings. In any case, they are temporary and harmless. This removes all the arch/arc uses of the __cpuinit macros from all C files. Currently arc does not have any __CPUINIT used in assembly files. [1] https://lkml.org/lkml/2013/5/20/589 Cc: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2013-06-26ARC: Setup Vector Table Base in early bootVineet Gupta
Otherwise early boot exceptions such as instructions errors due to configuration mismatch between kernel and hardware go off to la-la land, as opposed to hitting the handler and panic()'ing properly. Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2013-06-22ARC: More code beautification with IS_ENABLED()Vineet Gupta
2013-05-07ARC: Prepare interrupt code for external controllersChristian Ruppert
This patch adds some room for CPU-external interrupt controllers in the Linux interrupt space. Until now, only the 32 CPU internal interrupt lines were supported which does not allow for external interrupt controllers such as GPIO modules etc. Signed-off-by: Christian Ruppert <christian.ruppert@abilis.com> Signed-off-by: Pierrick Hascoet <pierrick.hascoet@abilis.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2013-05-07ARC: Allow embedded arc-intc to be properly placed in DT intc hierarchyVineet Gupta
arc-intc is initialized in arc common code as it is applicable to all platforms. However platforms with their own external intc still need to refer to it for correct DT interrupt tree hierarchy setup, e.g. static struct of_device_id __initdata tb10x_irq_ids[] = { { .compatible = "snps,arc700-intc", .data = dummy_init_irq }, { .compatible = "abilis,tb10x_ictl", .data = tb10x_init_irq }, {}, }; The fix is to use the generic irqchip framework to tie all irqchips in a special linker section and then call irqchip_init() which calls the DT of_irq_init() for all the intc in one go. That way the platform code need not be aware of arc-intc at all. Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2013-04-09ARC: [build] Fix warnings with CONFIG_DEBUG_SECTION_MISMATCHVineet Gupta
2013-04-09ARC: Fix coding style issuesSachin Kamat
Fixes the following coding style issues as detected by checkpatch: ERROR: space required before the open parenthesis '(' ERROR: "foo * bar" should be "foo *bar" WARNING: space prohibited between function name and open parenthesis '(' WARNING: please, no spaces at the start of a line Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2013-02-15ARC: [Review] Multi-platform image #3: switch to board callbackVineet Gupta
-platform API is retired and instead callbacks are used Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Cc: Arnd Bergmann <arnd@arndb.de> Acked-by: Arnd Bergmann <arnd@arndb.de>
2013-02-15ARC: [Review] Multi-platform image #2: Board callback InfrastructureVineet Gupta
The orig platform code orgnaization was singleton design pattern - only one platform (and board thereof) would build at a time. Thus any platform/board specific code (e.g. irq init, early init ...) expected by ARC common code was exported as well defined set of APIs, with only ONE instance building ever. Now with multiple-platform build requirement, that design of code no longer holds - multiple board specific calls need to build at the same time - so ARC common code can't use the API approach, it needs a callback based design where each board registers it's specific set of functions, and at runtime, depending on board detection, the callbacks are used from the registry. This commit adds all the infrastructure, where board specific callbacks are specified as a "maThine description". All the hooks are placed in right spots, no board callbacks registered yet (with MACHINE_STARt/END constructs) so the hooks will not run. Next commit will actually convert the platform to this infrastructure. Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Cc: Arnd Bergmann <arnd@arndb.de> Acked-by: Arnd Bergmann <arnd@arndb.de>
2013-02-15ARC: SMP supportVineet Gupta
ARC common code to enable a SMP system + ISS provided SMP extensions. ARC700 natively lacks SMP support, hence some of the core features are are only enabled if SoCs have the necessary h/w pixie-dust. This includes: -Inter Processor Interrupts (IPI) -Cache coherency -load-locked/store-conditional ... The low level exception handling would be completely broken in SMP because we don't have hardware assisted stack switching. Thus a fair bit of this code is repurposing the MMU_SCRATCH reg for event handler prologues to keep them re-entrant. Many thanks to Rajeshwar Ranga for his initial "major" contributions to SMP Port (back in 2008), and to Noam Camus and Gilad Ben-Yossef for help with resurrecting that in 3.2 kernel (2012). Note that this platform code is again singleton design pattern - so multiple SMP platforms won't build at the moment - this deficiency is addressed in subsequent patches within this series. Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rajeshwar Ranga <rajeshwar.ranga@gmail.com> Cc: Noam Camus <noamc@ezchip.com> Cc: Gilad Ben-Yossef <gilad@benyossef.com>
2013-02-15ARC: Support for high priority interrupts in the in-core intcVineet Gupta
There is a bit of hack/kludge right now where we disable preemption if a L2 (High prio) IRQ is taken while L1 (Low prio) is active. Need to revisit this Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2013-02-15ARC: [plat-arcfpga]: Enabling DeviceTree for Angel4 boardVineet Gupta
* arc-uart platform device now populated dynamically, using of_platform_populate() - applies to any other device whatsoever. * uart in turn requires incore arc-intc to be also present in DT * A irq-domain needs to be instantiated for IRQ requests by DT probed device (e.g. arc-uart) TODO: switch over to linear irq domain once all devs have been transitioned to DT Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Arnd Bergmann <arnd@arndb.de>
2013-02-11ARC: Interrupt HandlingVineet Gupta
This contains: -bootup arch IRQ init: init_IRQ(), arc_init_IRQ() -generic IRQ subsystem glue: arch_do_IRQ() -basic IRQ chip setup for in-core intc Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Cc: Thomas Gleixner <tglx@linutronix.de>
2013-02-11ARC: irqflags - Interrupt enabling/disabling at in-core intcVineet Gupta
ARC700 has an in-core intc which provides 2 priorities (a.k.a.) "levels" of interrupts (per IRQ) hencforth referred to as L1/L2 interrupts. CPU flags register STATUS32 has Interrupt Enable bits per level (E1/E2) to globally enable (or disable) all IRQs at a level. Hence the implementation of arch_local_irq_{save,restore,enable,disable}( ) The STATUS32 reg can be r/w only using the AUX Interface of ARC, hence the use of LR/SR instructions. Further, E1/E2 bits in there can only be updated using the FLAG insn. The intc supports 32 interrupts - and per IRQ enabling is controlled by a bit in the AUX_IENABLE register, hence the implmentation of arch_{,un}mask_irq( ) routines. Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Cc: Thomas Gleixner <tglx@linutronix.de>
