Move remaining definitions and declarations from include/linux/bootmem.h
into include/linux/memblock.h and remove the redundant header.
The includes were replaced with the semantic patch below and then
semi-automated removal of duplicated '#include <linux/memblock.h>
- #include <linux/bootmem.h>
+ #include <linux/memblock.h>
[sfr@canb.auug.org.au: dma-direct: fix up for the removal of linux/bootmem.h]
Link: http://lkml.kernel.org/r/20181002185342.133d1680@canb.auug.org.au
[sfr@canb.auug.org.au: powerpc: fix up for removal of linux/bootmem.h]
Link: http://lkml.kernel.org/r/20181005161406.73ef8727@canb.auug.org.au
[sfr@canb.auug.org.au: x86/kaslr, ACPI/NUMA: fix for linux/bootmem.h removal]
Link: http://lkml.kernel.org/r/20181008190341.5e396491@canb.auug.org.au
Link: http://lkml.kernel.org/r/1536927045-23536-30-git-send-email-rppt@linux.vnet.ibm.com
Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com>
Cc: Chris Zankel <chris@zankel.net>
Cc: Greentime Hu <green.hu@gmail.com>
Cc: Guan Xuetao <gxt@pku.edu.cn>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Ley Foon Tan <lftan@altera.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Palmer Dabbelt <palmer@sifive.com>
Cc: Paul Burton <paul.burton@mips.com>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: Richard Weinberger <richard@nod.at>
Cc: Rich Felker <dalias@libc.org>
Cc: Russell King <linux@armlinux.org.uk>
Cc: Serge Semin <fancer.lancer@gmail.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
The conversion is done using
sed -i 's@free_all_bootmem@memblock_free_all@' \
$(git grep -l free_all_bootmem)
Link: http://lkml.kernel.org/r/1536927045-23536-26-git-send-email-rppt@linux.vnet.ibm.com
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
Now mem_init() for both Alpha UMA and Alpha NUMA are the same, so unify it
to reduce duplicated code.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Prepare for removing num_physpages and simplify mem_init().
Concentrate code to modify totalram_pages into the mm core, so the arch
memory initialized code doesn't need to take care of it. With these
changes applied, only following functions from mm core modify global
variable totalram_pages: free_bootmem_late(), free_all_bootmem(),
free_all_bootmem_node(), adjust_managed_page_count().
With this patch applied, it will be much more easier for us to keep
totalram_pages and zone->managed_pages in consistence.
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: <sworddragon2@aol.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Jianguo Wu <wujianguo@huawei.com>
Cc: Joonsoo Kim <js1304@gmail.com>
Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Tang Chen <tangchen@cn.fujitsu.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Wen Congyang <wency@cn.fujitsu.com>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Address more review comments from last round of code review.
1) Enhance free_reserved_area() to support poisoning freed memory with
pattern '0'. This could be used to get rid of poison_init_mem()
on ARM64.
2) A previous patch has disabled memory poison for initmem on s390
by mistake, so restore to the original behavior.
3) Remove redundant PAGE_ALIGN() when calling free_reserved_area().
Change signature of free_reserved_area() according to Russell King's
suggestion to fix following build warnings:
arch/arm/mm/init.c: In function 'mem_init':
arch/arm/mm/init.c:603:2: warning: passing argument 1 of 'free_reserved_area' makes integer from pointer without a cast [enabled by default]
free_reserved_area(__va(PHYS_PFN_OFFSET), swapper_pg_dir, 0, NULL);
In file included from include/linux/mman.h:4:0,
from arch/arm/mm/init.c:15:
include/linux/mm.h:1301:22: note: expected 'long unsigned int' but argument is of type 'void *'
extern unsigned long free_reserved_area(unsigned long start, unsigned long end,
mm/page_alloc.c: In function 'free_reserved_area':
>> mm/page_alloc.c:5134:3: warning: passing argument 1 of 'virt_to_phys' makes pointer from integer without a cast [enabled by default]
In file included from arch/mips/include/asm/page.h:49:0,
from include/linux/mmzone.h:20,
from include/linux/gfp.h:4,
from include/linux/mm.h:8,
from mm/page_alloc.c:18:
arch/mips/include/asm/io.h:119:29: note: expected 'const volatile void *' but argument is of type 'long unsigned int'
mm/page_alloc.c: In function 'free_area_init_nodes':
mm/page_alloc.c:5030:34: warning: array subscript is below array bounds [-Warray-bounds]
Also address some minor code review comments.
Use common help functions to free reserved pages. Also include
<asm/sections.h> to avoid local declarations.
Disintegrate asm/system.h for Alpha.
cc: linux-alpha@vger.kernel.org
Fold all the mmu_gather rework patches into one for submission
Reported-by: Hugh Dickins <hughd@google.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Namhyung Kim <namhyung@gmail.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Commit 96177299416dbccb73b54e6b344260154a445375 ("Drop free_pages()")
modified nr_free_pages() to return 'unsigned long' instead of 'unsigned
int'. This made the casts to 'unsigned long' in most callers superfluous,
so remove them.
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: Chris Zankel <zankel@tensilica.com>
Impact: fix build
Add missing 'o' in variable name. Compile tested.
Reported-by: Ingo Molnar <mingo@elte.hu>
Impact: allow larger alignment for early vmalloc area allocation
Some early vmalloc users might want larger alignment, for example, for
custom large page mapping. Add @align to vm_area_register_early().
While at it, drop docbook comment on non-existent @size.
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Impact: allow multiple early vm areas
There are places where kernel VM area needs to be allocated before
vmalloc is initialized. This is done by allocating static vm_struct,
initializing several fields and linking it to vmlist and later vmalloc
initialization picking up these from vmlist. This is currently done
manually and if there's more than one such areas, there's no defined
way to arbitrate who gets which address.
This patch implements vm_area_register_early(), which takes vm_area
struct with flags and size initialized, assigns address to it and puts
it on the vmlist. This way, multiple early vm areas can determine
which addresses they should use. The only current user - alpha mm
init - is converted to use it.
As it's just a single call to __get_free_page().
Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Remove arch-specific show_mem() in favor of the generic version.
This also removes the following redundant information display:
- free pages, printed by show_free_areas()
- free swap pages, printed by show_swap_cache_info()
- pages in swapcache, printed by show_swap_cache_info()
where show_mem() calls show_free_areas(), which calls
show_swap_cache_info().
Signed-off-by: Johannes Weiner <hannes@saeurebad.de>
Spelling fixes in arch/alpha/.
Signed-off-by: Simon Arlott <simon@fire.lp0.eu>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Fix the following section mismatch warnings:
WARNING: o-alpha/vmlinux.o(.text+0x1a4d4): Section mismatch: reference to .init.text:free_area_init (between 'paging_init' and 'srm_paging_stop')
WARNING: o-alpha/vmlinux.o(.text+0x1a4dc): Section mismatch: reference to .init.text:free_area_init (between 'paging_init' and 'srm_paging_stop')
One instance of paging_init() was declared __init but not the other one -
used by defconfig. Fixed by declaring the second instance ___init too.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Fix array initialization in lots of arches
The number of zones may now be reduced from 4 to 2 for many arches. Fix the
array initialization for the zones array for all architectures so that it is
not initializing a fixed number of elements.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
set_page_count usage outside mm/ is limited to setting the refcount to 1.
Remove set_page_count from outside mm/, and replace those users with
init_page_count() and set_page_refcounted().
This allows more debug checking, and tighter control on how code is allowed
to play around with page->_count.
Signed-off-by: Nick Piggin <npiggin@suse.de>
- create one common dump_thread() prototype in kernel.h
- dump_thread() is only used in fs/binfmt_aout.c and can therefore be
removed on all architectures where CONFIG_BINFMT_AOUT is not
available
infrastructure for it.
Let it rip!
