path: root/arch/alpha/lib
2007-06-24alpha: fix alignment problem in csum_ipv6_magic()Ivan Kokshaysky
Hopefully this fixes http://bugzilla.kernel.org/show_bug.cgi?id=8635 The struct in6_addr passed to csum_ipv6_magic() is 4 byte aligned, so we can't use the regular 64-bit loads. Since the cost of handling of 4 byte and 1 byte aligned 64-bit data is roughly the same, this code can cope with any src/dst [mis]alignment. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Dustin Marquess <jailbird@alcatraz.fdf.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-30alpha: cleanup in bitops.hRichard Henderson
Remove 2 functions private to the alpha implemetation, in favor of similar functions in <linux/log2.h>. Provide a more efficient version of the fls64 function for pre-ev67 alphas. Signed-off-by: Richard Henderson <rth@twiddle.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-26[STRING]: Move strcasecmp/strncasecmp to lib/string.cDavid S. Miller
We have several platforms using local copies of identical code. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Alpha checksum annotations and cleanups.Al Viro
* sanitize prototypes and annotate * kill useless access_ok() in csum_partial_copy_from_user() (the only caller checks it already). * do_csum_partial_copy_from_user() is not needed now * replace htons(len) with len << 8 - they are the same wrt checksums on little-endian. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-04-25[PATCH] Alpha: strncpy() fixIvan Kokshaysky
As it turned out after recent SCSI changes, strncpy() was broken - it mixed up the return values from __stxncpy() in registers $24 and $27. Thanks to Mathieu Chouquet-Stringer for tracking down the problem and providing an excellent test case. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: alpha: use config options instead of __alpha_fix__ and ↵Akinobu Mita
__alpha_cix__ Use config options instead of gcc builtin definition to tell the use of instruction set extensions (CIX and FIX). This is introduced to tell the kbuild system the use of opmized hweight*() routines on alpha architecture. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09kbuild: alpha,x86_64 use generic asm-offsets.h supportSam Ravnborg
Delete obsolete stuff from arch makefiles Rename .h file to asm-offsets.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
