Commit c52c2ddc1dfa ("alpha: switch osf_sigprocmask() to use of
sigprocmask()") had several problems. The more obvious compile issues
got fixed in commit 0f44fbd297e1 ("alpha: fix compile problem in
arch/alpha/kernel/signal.c"), but it also caused a regression.
Since _BLOCKABLE is already the set of signals that can be blocked, the
code should do "newmask & _BLOCKABLE" rather than inverting _BLOCKABLE
before masking.
Reported-by: Michael Cree <mcree@orcon.net.nz>
Patch-by: Al Viro <viro@zeniv.linux.org.uk>
Patch-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Tssk. Apparently Al hadn't checked commit c52c2ddc1dfa ("alpha: switch
osf_sigprocmask() to use of sigprocmask()") at all. It doesn't compile.
Fixed as per suggestions from Michael Cree.
Cc: Al Viro <viro@ftp.linux.org.uk>
get rid of a useless wrapper, while we are at it
rdusp() gives us the right value only for the current thread...
We want interrupts disabled on all paths leading to RESTORE_ALL;
otherwise, we are risking an IRQ coming between the updates of
alpha_mv->hae_cache and *alpha_mv->hae_register and set_hae()
within the IRQ getting badly confused.
RESTORE_ALL used to play with disabling IRQ itself, but that got
removed back in 2002, without making sure we had them disabled
on all paths. It's cheaper to make sure we have them disabled than
to revert to original variant...
Remove the detritus left from that commit back in 2002; we used to
need a reload of $0 and $1 since swpipl would change those, but
doing that had become pointless when we stopped doing swpipl in
there...
Unlike the other targets, alpha sets _one_ sigframe and
buggers off until the next syscall/interrupt, even if
more signals are pending. It leads to quite a few unpleasant
inconsistencies, starting with SIGSEGV potentially arriving
not where it should and including e.g. mess with sigsuspend();
consider two pending signals blocked until sigsuspend()
unblocks them. We pick the first one; then, if we are hit
by interrupt while in the handler, we process the second one
as well. If we are not, and if no syscalls had been made,
we get out of the first handler and leave the second signal
pending; normally sigreturn() would've picked it anyway, but
here it starts with restoring the original mask and voila -
the second signal is blocked again. On everything else we
get both delivered consistently.
It's actually easy to fix; the only thing to watch out for
is prevention of double syscall restart. Fortunately, the
idea I've nicked from arm fix by rmk works just fine...
Testcase demonstrating the behaviour in question; on alpha
we get one or both flags set (usually one), on everything
else both are always set.
#include <signal.h>
#include <stdio.h>
int had1, had2;
void f1(int sig) { had1 = 1; }
void f2(int sig) { had2 = 1; }
main()
sigset_t set1, set2;
sigemptyset(&set1);
sigemptyset(&set2);
sigaddset(&set2, 1);
sigaddset(&set2, 2);
signal(1, f1);
signal(2, f2);
sigprocmask(SIG_SETMASK, &set2, NULL);
raise(1);
raise(2);
sigsuspend(&set1);
printf("had1:%d had2:%d\n", had1, had2);
Tested-by: Michael Cree <mcree@orcon.net.nz>
Signed-off-by: Matt Turner <mattst88@gmail.com>
The way sigreturn() is implemented on alpha breaks PTRACE_SYSCALL,
all way back to 1.3.95 when alpha has grown PTRACE_SYSCALL support.
What happens is direct return to ret_from_syscall, in order to bypass
mangling of a3 (error indicator) and prevent other mutilations of
registers (e.g. by syscall restart). That's fine, but... the entire
TIF_SYSCALL_TRACE codepath is kept separate on alpha and post-syscall
stopping/notifying the tracer is after the syscall. And the normal
path we are forcibly switching to doesn't have it.
So we end up with *one* stop in traced sigreturn() vs. two in other
syscalls. And yes, strace is visibly broken by that; try to strace
the following
#include <signal.h>
#include <stdio.h>
void f(int sig) {}
main()
signal(SIGHUP, f);
raise(SIGHUP);
write(1, "eeeek\n", 6);
and watch the show. The
close(1) = 405
in the end of strace output is coming from return value of write() (6 ==
__NR_close on alpha) and syscall number of exit_group() (__NR_exit_group ==
405 there).
The fix is fairly simple - the only thing we end up missing is the call
of syscall_trace() and we can tell whether we'd been called from the
SYSCALL_TRACE path by checking ra value. Since we are setting the
switch_stack up (that's what sys_sigreturn() does), we have the right
environment for calling syscall_trace() - just before we call
undo_switch_stack() and return. Since undo_switch_stack() will overwrite
s0 anyway, we can use it to store the result of "has it been called from
SYSCALL_TRACE path?" check. The same thing applies in rt_sigreturn().
Old code used to set regs->r0 and regs->r19 to force the right
return value. Leaving that after switch to ERESTARTNOHAND
was a Bad Idea(tm), since now that screws the restart - if we
hit the case when get_signal_to_deliver() returns 0, we will
step back to syscall insn, with v0 set to EINTR and a3 to 1.
The latter won't matter, since EINTR is 4, aka __NR_write.
Testcase:
#include <signal.h>
#define _GNU_SOURCE
#include <unistd.h>
#include <sys/syscall.h>
main()
sigset_t mask;
sigemptyset(&mask);
sigaddset(&mask, SIGCONT);
sigprocmask(SIG_SETMASK, &mask, NULL);
kill(0, SIGCONT);
syscall(__NR_sigsuspend, 1, "b0rken\n", 7);
results on alpha in immediate message to stdout...
Fix is obvious; moreover, since we don't need regs anymore, we can
switch to normal prototypes for these guys and lose the wrappers.
Even better, rt_sigsuspend() is identical to generic version in
kernel/signal.c now.
same thing as had been done on other targets back in 2003 -
move setting ->restart_block.fn into {rt_,}sigreturn().
Pending work from the performance event subsystem is executed in
the timer interrupt. This patch shifts the call to
perf_event_do_pending() before the call to update_process_times()
as the latter may call back into the perf event subsystem and it
is prudent to have the pending work executed first.
Signed-off-by: Michael Cree <mcree@orcon.net.nz>
The 2.6.36-rc kernel added three new system calls:
fanotify_init, fanotify_mark, and prlimit64. This
patch wires them up on Alpha.
Built and booted on an XP900. Untested beyond that.
Signed-off-by: Mikael Pettersson <mikpe@it.uu.se>
All uses of the BKL on alpha are totally bogus, nothing
is really protected by this. Remove the remaining users
so we don't have to mark alpha as 'depends on BKL'.
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: linux-alpha@vger.kernel.org
Acked-by: Jan-Benedict Glaw <jbglaw@lug-owl.de>
Signed-off-by: matt mooney <mfm@muteddisk.com>
Acked-by: Richard Henderson <rth@twiddle.net>
When compiling alpha generic build get errors such as:
arch/alpha/kernel/err_marvel.c: In function ‘marvel_print_err_cyc’:
arch/alpha/kernel/err_marvel.c:119: error: format ‘%ld’ expects type ‘long int’, but argument 6 has type ‘u64’
Replaced a number of %ld format specifiers with %lld since u64
is unsigned long long.
Updates the Alpha perf_event code to match the changes
recently made to the core perf_event code in commit
e78505958cf123048fb48cb56b79cebb8edd15fb.
This patch fixes the failure to compile Alpha Generic because of
previously overlooked calls to ns87312_enable_ide(). The function has
been replaced by newer SuperIO code.
Signed-off-by: Morten H. Larsen <m-larsen@post6.tele.dk>
Fix a comma that got accidentally deleted from sys_osf_statfs() leading to the
following warning:
arch/alpha/kernel/osf_sys.c: In function 'SYSC_osf_statfs':
arch/alpha/kernel/osf_sys.c:255: error: syntax error before 'buffer'
Make do_execve() take a const filename pointer so that kernel_execve() compiles
correctly on ARM:
arch/arm/kernel/sys_arm.c:88: warning: passing argument 1 of 'do_execve' discards qualifiers from pointer target type
This also requires the argv and envp arguments to be consted twice, once for
the pointer array and once for the strings the array points to. This is
because do_execve() passes a pointer to the filename (now const) to
copy_strings_kernel(). A simpler alternative would be to cast the filename
pointer in do_execve() when it's passed to copy_strings_kernel().
do_execve() may not change any of the strings it is passed as part of the argv
or envp lists as they are some of them in .rodata, so marking these strings as
const should be fine.
Further kernel_execve() and sys_execve() need to be changed to match.
This has been test built on x86_64, frv, arm and mips.
Tested-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Mark arguments to certain system calls as being const where they should be but
aren't. The list includes:
(*) The filename arguments of various stat syscalls, execve(), various utimes
syscalls and some mount syscalls.
(*) The filename arguments of some syscall helpers relating to the above.
(*) The buffer argument of various write syscalls.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits)
no need for list_for_each_entry_safe()/resetting with superblock list
Fix sget() race with failing mount
vfs: don't hold s_umount over close_bdev_exclusive() call
sysv: do not mark superblock dirty on remount
sysv: do not mark superblock dirty on mount
btrfs: remove junk sb_dirt change
BFS: clean up the superblock usage
AFFS: wait for sb synchronization when needed
AFFS: clean up dirty flag usage
cifs: truncate fallout
mbcache: fix shrinker function return value
mbcache: Remove unused features
add f_flags to struct statfs(64)
pass a struct path to vfs_statfs
update VFS documentation for method changes.
All filesystems that need invalidate_inode_buffers() are doing that explicitly
convert remaining ->clear_inode() to ->evict_inode()
Make ->drop_inode() just return whether inode needs to be dropped
fs/inode.c:clear_inode() is gone
fs/inode.c:evict() doesn't care about delete vs. non-delete paths now
Fix up trivial conflicts in fs/nilfs2/super.c
This implements hardware performance events for the EV67 and later CPUs
within the Linux performance events subsystem. Only using the performance
monitoring unit in HP/Compaq's so called "Aggregrate mode" is supported.
The code has been implemented in a manner that makes extension to other
older Alpha CPUs relatively straightforward should some mug wish to
indulge themselves.
Cc: Matt Turner <mattst88@gmail.com>
Cc: Jay Estabrook <jay.estabrook@hp.com>
The following patches implement hardware performance events for the Alpha
EV67 and later CPUs. I have had this running on a Compaq XP1000 (EV67,
single CPU) for a few days now. Pretty cool -- discovered that the glibc
exp2() library routine uses on average 985 cycles to execute 777 CPU
instructions whereas Compaq's CPML library version of exp2() uses on
average 32 cycles to execute 47 CPU instructions to achieve the same
thing!
This patch:
Add performance monitor interrupt counternd and export the count to user
space via /proc/interrupts.
We'll need the path to implement the flags field for statvfs support.
We do have it available in all callers except:
- ecryptfs_statfs. This one doesn't actually need vfs_statfs but just
needs to do a caller to the lower filesystem statfs method.
- sys_ustat. Add a non-exported statfs_by_dentry helper for it which
doesn't won't be able to fill out the flags field later on.
In addition rename the helpers for statfs vs fstatfs to do_*statfs instead
of the misleading vfs prefix.
This patch probes for the Super IO chip and reserves the IO range when
found. It avoids enabling the IDE interface on the Avanti family, since
none has IDE. It enables the Enhanced Parallel Port v1.9 feature.
Caused by 2c3c8bea608866d8bd9dcf92657d57fdcac011c5 which was clearly not
even compile tested.
Alpha has a tsc like rpcc counter that it uses to manage time.
This can be converted to an actual clocksource instead of utilizing
the arch_gettimeoffset method that is really only there for legacy
systems with no continuous counter.
Further cleanups could be made if alpha converted to the clockevent
model.
CC: Thomas Gleixner <tglx@linutronix.de>
CC: Richard Henderson <rth@twiddle.net>
Acked-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Tested-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Signed-off-by: John Stultz <johnstul@us.ibm.com>
This allows bin_attr->read,write,mmap callbacks to check file specific data
(such as inode owner) as part of any privilege validation.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
* 'timers-for-linus-cleanups' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
avr32: Fix typo in read_persistent_clock()
sparc: Convert sparc to use read/update_persistent_clock
cris: Convert cris to use read/update_persistent_clock
m68k: Convert m68k to use read/update_persistent_clock
m32r: Convert m32r to use read/update_peristent_clock
blackfin: Convert blackfin to use read/update_persistent_clock
ia64: Convert ia64 to use read/update_persistent_clock
avr32: Convert avr32 to use read/update_persistent_clock
h8300: Convert h8300 to use read/update_persistent_clock
frv: Convert frv to use read/update_persistent_clock
mn10300: Convert mn10300 to use read/update_persistent_clock
alpha: Convert alpha to use read/update_persistent_clock
xtensa: Fix unnecessary setting of xtime
time: Clean up direct xtime usage in xen
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Signed-off-by: Frans Pop <elendil@planet.nl>
Replace open-coded rate limiting logic with __ratelimit().
This patch converts the alpha architecture to use the generic
read_persistent_clock and update_persistent_clock interfaces, reducing
the amount of arch specific code we have to maintain, and allowing for
further cleanups in the future.
I have not built or tested this patch, so help from arch maintainers
would be appreciated.
LKML-Reference: <1267675049-12337-2-git-send-email-johnstul@us.ibm.com>
This converts Alpha to use include/linux/pci-dma-compat.h. Alpha is the
only architecutre that implements the PCI DMA API in the own way. That
makes it difficult to implement the generic DMA API via the PCI bus
specific DMA API.
The generic DMA API calls the PCI DMA API implementation in
arch/alpha/kernel/pci_iommu.c on non Jensen systems. It calls the DMA API
in arch/alpha/kernel/pci-noop.c on Jensen systems.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Greg KH <greg@kroah.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
Use the generic ptrace_resume code for PTRACE_SYSCALL, PTRACE_CONT,
PTRACE_KILL and PTRACE_SINGLESTEP. This implies defining
arch_has_single_step in <asm/ptrace.h> and implementing the
user_enable_single_step and user_disable_single_step functions, which also
causes the breakpoint information to be cleared on fork, which could be
considered a bug fix.
Also the TIF_SYSCALL_TRACE thread flag is now cleared on PTRACE_KILL which
it previously wasn't, which is consistent with all architectures using the
modern ptrace code.
Cc: Roland McGrath <roland@redhat.com>
Acked-by: Matt Turner <mattst88@gmail.com>
The initial -EINVAL value is overwritten by `retval = PTR_ERR(name)'. If
this isn't an error pointer and typenr is not 1, 6 or 9, then this retval,
a pointer cast to a long, is returned.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Now that we return the new resource start position, there is no
need to update "struct resource" inside the align function.
Therefore, mark the struct resource as const.
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Yinghai Lu <yhlu.kernel@gmail.com>
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
As suggested by Linus, align functions should return the start
of a resource, not void. An update of "res->start" is no longer
necessary.
In the kernel the patch enables configuration of the perf event
option, adds the perf_event_open syscall, and includes a minimal
architecture specific asm/perf_event.h header file.
This wire up the: fallocate, timerfd_create, timerfd_settime,
timerfd_gettime, signalfd4, eventfd2, epoll_create1, dup3, pipe2,
inotify_init1, preadv, pwritev and rt_tgsigqueueinfo syscalls for
the alpha port.
For umount2, alpha have an "old" and "new" version called: oldumount and
umount; so ignore umount2.
Rebased on top of 6e17e8b9fb74b9fb9f6ea331f7f4a049c5b4c4b8 by Matt
Turner.
Signed-off-by: Daniele Calore <orkaan@orkaan.org>
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (26 commits)
clockevents: Convert to raw_spinlock
clockevents: Make tick_device_lock static
debugobjects: Convert to raw_spinlocks
perf_event: Convert to raw_spinlock
hrtimers: Convert to raw_spinlocks
genirq: Convert irq_desc.lock to raw_spinlock
smp: Convert smplocks to raw_spinlocks
rtmutes: Convert rtmutex.lock to raw_spinlock
sched: Convert pi_lock to raw_spinlock
sched: Convert cpupri lock to raw_spinlock
sched: Convert rt_runtime_lock to raw_spinlock
sched: Convert rq->lock to raw_spinlock
plist: Make plist debugging raw_spinlock aware
bkl: Fixup core_lock fallout
locking: Cleanup the name space completely
locking: Further name space cleanups
alpha: Fix fallout from locking changes
locking: Implement new raw_spinlock
locking: Convert raw_rwlock functions to arch_rwlock
locking: Convert raw_rwlock to arch_rwlock
Convert code away from ->read_proc/->write_proc interfaces. Switch to
proc_create()/proc_create_data() which make addition of proc entries
reliable wrt NULL ->proc_fops, NULL ->data and so on.
Problem with ->read_proc et al is described here commit
786d7e1612f0b0adb6046f19b906609e4fe8b1ba "Fix rmmod/read/write races in
/proc entries"
Convert locks which cannot be sleeping locks in preempt-rt to
raw_spinlocks.
Acked-by: Peter Zijlstra <peterz@infradead.org>
spin_* functions are mostly static inline now. That causes the alpha
compile to fail:
CC arch/alpha/kernel/sys_sable.o
cc1: warnings being treated as errors
In file included from arch/alpha/kernel/sys_sable.c:25:
arch/alpha/include/asm/core_t2.h: In function 't2_readb':
arch/alpha/include/asm/core_t2.h:451: error: 'spinlock_check' is static but \
used in inline function 't2_readb' which is not static
arch/alpha/include/asm/core_t2.h:456: error: 'spin_unlock_irqrestore' is \
static but used in inline function 't2_readb' which is not static
That's caused by the "extern inline" magic which is used for the
subarch specific read/write[bwl] functions. I tried to distangle the
uncountable macro onion layers, but failed miserably.
Last resort solution: switch the t2_hae_lock to raw_spinlock_t so the
lock functions are pure macros and function calls again.
New helper - sys_mmap_pgoff(); switch syscalls to using it.
net/mac80211/ht.c
The typename member of struct irq_chip was kept for migration purposes
and is obsolete since more than 2 years. Fix up the leftovers.
Check that the result of kmalloc is not NULL before passing it to other
functions.
The semantic match that finds this problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
expression *x;
identifier f;
constant char *C;
x = \(kmalloc\|kcalloc\|kzalloc\)(...);
... when != x == NULL
when != x != NULL
when != (x || ...)
kfree(x)
f(...,C,...,x,...)
*f(...,x,...)
*x->f
// </smpl>
The kernel.h macro DIV_ROUND_CLOSEST performs the computation (x + d/2)/d
but is perhaps more readable.
The semantic patch that makes this change is as follows:
// <smpl>
@haskernel@
@depends on haskernel@
expression x,__divisor;
- (((x) + ((__divisor) / 2)) / (__divisor))
+ DIV_ROUND_CLOSEST(x,__divisor)
// </smpl>
