path: root/Documentation
2010-08-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-linus: Squashfs: fix checkpatch.pl warnings Squashfs: fix filename typo Squashfs: update Kconfig and documentation for LZO Squashfs: fix block size use in LZO decompressor Squashfs: Add LZO compression support squashfs: fix filename in header comment Squashfs: Make XATTR config name consistent with other file systems squashfs: fix compiler inline warning
2010-08-11kfifo: replace the old non generic APIStefani Seibold
Simply replace the whole kfifo.c and kfifo.h files with the new generic version and fix the kerneldoc API template file. Signed-off-by: Stefani Seibold <stefani@seibold.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11panic: keep blinking in spite of long spin timer modeTAMUKI Shoichi
To keep panic_timeout accuracy when running under a hypervisor, the current implementation only spins on long time (1 second) calls to mdelay. That brings a good effect, but the problem is the keyboard LEDs don't blink at all on that situation. This patch changes to call to panic_blink_enter() between every mdelay and keeps blinking in spite of long spin timer mode. The time to call to mdelay is now 100ms. Even this change will keep panic_timeout accuracy enough when running under a hypervisor. Signed-off-by: TAMUKI Shoichi <tamuki@linet.gr.jp> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Anton Blanchard <anton@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11dma-mapping: add DMA_xxBIT_MASK to feature-removal-schedule.txtFUJITA Tomonori
DMA_xxBIT_MASK macros were marked as deprecated in June 2009. One more year is long enough, I think. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11pci: add PCI DMA unamp state API to feature-removal-schedule.txtFUJITA Tomonori
It was replaced with the DMA unamp state API (which can be used for any bus). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11Documentation: DMA-API-HOWTO.txt: add multiple types of IOMMUs supportFUJITA Tomonori
2010-08-11dma-mapping: remove dma_is_consistent APIFUJITA Tomonori
Architectures implement dma_is_consistent() in different ways (some misinterpret the definition of API in DMA-API.txt). So it hasn't been so useful for drivers. We have only one user of the API in tree. Unlikely out-of-tree drivers use the API. Even if we fix dma_is_consistent() in some architectures, it doesn't look useful at all. It was invented long ago for some old systems that can't allocate coherent memory at all. It's better to export only APIs that are definitely necessary for drivers. Let's remove this API. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11Documentation/padata.txt: fix typos etc.Randy Dunlap
Fix typos & grammar. Use CPU instead of cpu in text. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11Documentation/00-INDEX: remove reference to exception.txtHuang Shijie
The exception.txt has been removed from the Documentation directory. So update the index file for it. Signed-off-by: Huang Shijie <shijie8@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11docbook: need xmldoclinks for all doc typesBen Hutchings
$ rm -rf build $ mkdir build $ cp .config build $ make O=build htmldocs ... xmlto: linux-2.6/build/Documentation/DocBook/media.xml does not validate (status 3) xmlto: Fix document syntax or use --skip-validation option linux-2.6/build/Documentation/DocBook/media.xml:4: warning: failed to load external entity "linux-2.6/build/Documentation/DocBook/media-entities.tmpl" We need the xmldoclinks built for any document types built from the XML sources. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Andy Whitcroft <apw@canonical.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11Documentation/networking/wavelan.txt: deleted, not in treeJoe Perches
Commit 1d794e3b353b ("Staging: wavelan: delete the driver") removed the source, so remove the documentation as well. Signed-off-by: Joe Perches <joe@perches.com> Cc: Jean Tourrilhes <jt@hpl.hp.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11gpiolib: decouple might_sleep_if() from DEBUGDavid Brownell
Be more consistent about runtime programming interface abuse warnings, which can reduce some confusion and trigger bugfixes. Based on an observation and patch from Jani Nikula. Also update doc to highlight some sleeping-call issues and to match some recent changes. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Jani Nikula <ext-jani.1.nikula@nokia.com> Cc: "Ryan Mallon" <ryan@bluewatersys.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11dts: add sdhci,auto-cmd12 field for p4080 device treeRoy Zang
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Cc: Jerry Huang <Chang-Ming.Huang@freescale.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kumar Gala <galak@gate.crashing.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-10docbook: fixup media support files for htmldocs alsoRandy Dunlap
'make htmldocs' produces errors due to missing a supporting media file, so add 'xmldoclinks' to the htmldocs dependencies so that the needed supporting file will be present. Documentation/DocBook/media.xml:4: warning: failed to load external entity "Documentation/DocBook/media-entities.tmpl" Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-10Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (94 commits) V4L/DVB: tvp7002: fix write to H-PLL Feedback Divider LSB register V4L/DVB: dvb: siano: free spinlock before schedule() V4L/DVB: media: video: pvrusb2: remove custom hex_to_bin() V4L/DVB: drivers: usbvideo: remove custom implementation of hex_to_bin() V4L/DVB: Report supported QAM modes on bt8xx V4L/DVB: media: ir-keytable: null dereference in debug code V4L/DVB: ivtv: convert to the new control framework V4L/DVB: ivtv: convert gpio subdev to new control framework V4L/DVB: wm8739: convert to the new control framework V4L/DVB: cs53l32a: convert to new control framework V4L/DVB: wm8775: convert to the new control framework V4L/DVB: cx2341x: convert to the control framework V4L/DVB: cx25840: convert to the new control framework V4L/DVB: cx25840/ivtv: replace ugly priv control with s_config V4L/DVB: saa717x: convert to the new control framework V4L/DVB: msp3400: convert to the new control framework V4L/DVB: saa7115: convert to the new control framework V4L/DVB: v4l2: hook up the new control framework into the core framework V4L/DVB: Documentation: add v4l2-controls.txt documenting the new controls API V4L/DVB: v4l2-ctrls: Whitespace cleanups ...
2010-08-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (148 commits) USB: serial: fix stalled writes USB: remove fake "address-of" expressions USB: fix thread-unsafe anchor utiliy routines USB: usbtest: support test device with only one iso-in or iso-out endpoint USB: usbtest: avoid to free coherent buffer in atomic context USB: xhci: Set DMA mask for host. USB: xhci: Don't flush doorbell writes. USB: xhci: Reduce reads and writes of interrupter registers. USB: xhci: Make xhci_set_hc_event_deq() static. USB: xhci: Minimize HW event ring dequeue pointer writes. USB: xhci: Make xhci_handle_event() static. USB: xhci: Remove unnecessary reads of IRQ_PENDING register. USB: xhci: Performance - move xhci_work() into xhci_irq() USB: xhci: Performance - move interrupt handlers into xhci-ring.c USB: xhci: Performance - move functions that find ep ring. USB:: fix linux/usb.h kernel-doc warnings USB: add USB serial ssu100 driver USB: usb-storage: implement autosuspend USB: ehci: fix remove of ehci debugfs dir USB: Add USB 2.0 to ssb ohci driver ...
2010-08-10USB: gadget: storage: optional SCSI WRITE FUA bitAndy Shevchenko
MS Windows mounts removable storage in "Removal optimized mode" by default. All the writes to the media are synchronous which is achieved by setting FUA (Force Unit Access) bit in SCSI WRITE(10,12) commands. This prevents I/O requests aggregation in block layer dramatically decreasing performance. This patch brings an option to accept or ignore mentioned bit a) via specifying module parameter "nofua", or b) through sysfs entry /sys/devices/platform/_UDC_/gadget/gadget-lunX/nofua (_UDC_ is the name of the USB Device Controller driver) Patch is based on the work that was done by Denis Karpov for Maemo 5 platform. Signed-off-by: Andy Shevchenko <ext-andriy.shevchenko@nokia.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Cc: Denis Karpov <ext-denis.2.karpov@nokia.com> Cc: Adrian Hunter <adrian.hunter@nokia.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: gadget: g_multi: added documentation and INF filesMichal Nazarewicz
A short documentation of the g_multi driver along with INF files for Windows XP SP3 are provided. Signed-off-by: Michal Nazarewicz <m.nazarewicz@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: gadget: g_serial: INF file updatedMichal Nazarewicz
Updated the INF file for g_serial gadget. It should work with most recent Windows systems now. Signed-off-by: Michal Nazarewicz <m.nazarewicz@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: gadget: g_ether: updated INF fileMichal Nazarewicz
Updated the INF file for the g_ether gadget. It should work with most recent Windows systems now. Signed-off-by: Michal Nazarewicz <m.nazarewicz@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: Documentation/usb/linux.inf: Checkpatch cleanupAndrea Gelmini
Documentation/usb/linux.inf:66: ERROR: trailing whitespace Documentation/usb/linux.inf:67: ERROR: trailing whitespace Documentation/usb/linux.inf:98: ERROR: trailing whitespace Documentation/usb/linux.inf:99: ERROR: trailing whitespace Documentation/usb/linux.inf:115: ERROR: trailing whitespace Documentation/usb/linux.inf:116: ERROR: trailing whitespace Documentation/usb/linux.inf:120: ERROR: trailing whitespace Documentation/usb/linux.inf:121: ERROR: trailing whitespace Documentation/usb/linux.inf:122: ERROR: trailing whitespace Documentation/usb/linux.inf:123: ERROR: trailing whitespace Documentation/usb/linux.inf:144: ERROR: trailing whitespace Documentation/usb/linux.inf:145: ERROR: trailing whitespace Documentation/usb/linux.inf:146: ERROR: trailing whitespace Documentation/usb/linux.inf:147: ERROR: trailing whitespace Documentation/usb/linux.inf:158: ERROR: trailing whitespace Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: Documentation/usb/hotplug.txt: Checkpatch cleanupAndrea Gelmini
Documentation/usb/hotplug.txt:13: ERROR: trailing whitespace Documentation/usb/hotplug.txt:87: ERROR: trailing whitespace Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: Documentation/usb/ehci.txt: Checkpatch cleanupAndrea Gelmini
Documentation/usb/ehci.txt:12: ERROR: trailing whitespace Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10serial: MMIO32 support for 8250_early.cSamium Gromoff
Provide MMIO32 support in 8250_early (aka earlycon) [randy.dunlap@oracle.com: fix printk format warnings] [akpm@linux-foundation.org: fix printk args some more] Signed-off-by: Samium Gromoff <_deepfire@feelingofgreen.ru> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10Merge branch 'for-linus' of git://git.infradead.org/users/eparis/notifyLinus Torvalds
* 'for-linus' of git://git.infradead.org/users/eparis/notify: (132 commits) fanotify: use both marks when possible fsnotify: pass both the vfsmount mark and inode mark fsnotify: walk the inode and vfsmount lists simultaneously fsnotify: rework ignored mark flushing fsnotify: remove global fsnotify groups lists fsnotify: remove group->mask fsnotify: remove the global masks fsnotify: cleanup should_send_event fanotify: use the mark in handler functions audit: use the mark in handler functions dnotify: use the mark in handler functions inotify: use the mark in handler functions fsnotify: send fsnotify_mark to groups in event handling functions fsnotify: Exchange list heads instead of moving elements fsnotify: srcu to protect read side of inode and vfsmount locks fsnotify: use an explicit flag to indicate fsnotify_destroy_mark has been called fsnotify: use _rcu functions for mark list traversal fsnotify: place marks on object in order of group memory address vfs/fsnotify: fsnotify_close can delay the final work in fput fsnotify: store struct file not struct path ... Fix up trivial delete/modify conflict in fs/notify/inotify/inotify.c.
2010-08-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits) no need for list_for_each_entry_safe()/resetting with superblock list Fix sget() race with failing mount vfs: don't hold s_umount over close_bdev_exclusive() call sysv: do not mark superblock dirty on remount sysv: do not mark superblock dirty on mount btrfs: remove junk sb_dirt change BFS: clean up the superblock usage AFFS: wait for sb synchronization when needed AFFS: clean up dirty flag usage cifs: truncate fallout mbcache: fix shrinker function return value mbcache: Remove unused features add f_flags to struct statfs(64) pass a struct path to vfs_statfs update VFS documentation for method changes. All filesystems that need invalidate_inode_buffers() are doing that explicitly convert remaining ->clear_inode() to ->evict_inode() Make ->drop_inode() just return whether inode needs to be dropped fs/inode.c:clear_inode() is gone fs/inode.c:evict() doesn't care about delete vs. non-delete paths now ... Fix up trivial conflicts in fs/nilfs2/super.c
2010-08-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (59 commits) igbvf.txt: Add igbvf Documentation igb.txt: Add igb documentation e100/e1000*/igb*/ixgb*: Add missing read memory barrier ixgbe: fix build error with FCOE_CONFIG without DCB_CONFIG netxen: protect tx timeout recovery by rtnl lock isdn: gigaset: use after free isdn: gigaset: add missing unlock solos-pci: Fix race condition in tasklet RX handling pkt_sched: Fix sch_sfq vs tcf_bind_filter oops net: disable preemption before call smp_processor_id() tcp: no md5sig option size check bug iwlwifi: fix locking assertions iwlwifi: fix TX tracer isdn: fix information leak net: Fix napi_gro_frags vs netpoll path usbnet: remove noisy and hardly useful printk rtl8180: avoid potential NULL deref in rtl8180_beacon_work ath9k: Remove myself from the MAINTAINERS list libertas: scan before assocation if no BSSID was given libertas: fix association with some APs by using extended rates ...
2010-08-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin: (32 commits) Blackfin: gpio: add a debounce stub Blackfin: update defconfigs Blackfin: remove CONFIG_MEM_GENERIC_BOARD Blackfin: dpmc: punt unnecessary RTC_ISTAT clearing Blackfin: unify rotary encoder bitmasks Blackfin: unify SDH/RSI bitmasks Blackfin: BF54x: tweak DMAC MMR naming to match other ports Blackfin: TWI: clean up the MMR names Blackfin: add EVT_OVERRIDE/IPRIO core MMR helpers Blackfin: add support for dynamic ftrace Blackfin: add support for LZO compressed kernels Blackfin: portmux: fix peripheral map overflow when requesting pins Blackfin: document SPI CS limitations with CPHA=0 Blackfin: remove useless and outdated documentation Blackfin: BF51x/BF52x: support GPIO Hysteresis/Schmitt Trigger options Blackfin: gpio/portmux: clean up whitespace corruption Blackfin: make sure mmiowb inserts a write barrier with SSYNC Blackfin: fix DMA/cache bug when resuming from suspend to RAM Blackfin: BF51x: fix handling of PH8 (the "internal" SPI0SEL4 pin) Blackfin: add a GPIO_DEFAULT_BOOT_SPI_CS ...
2010-08-09hwmon: f71882fg: add support for the Fintek F71808EGiel van Schijndel
Allow device probing to recognise the Fintek F71808E. Sysfs interface: * Fan/pwm control is the same as for F71889FG * Temperature and voltage sensor handling is largely the same as for the F71889FG - Has one temperature sensor less (doesn't have temp3) - Misses one voltage sensor (doesn't have V6, thus in6_input refers to what in7_input refers for F71889FG) For the purpose of the sysfs interface fxxxx_in_temp_attr[] is split up such that it can largely be reused. Signed-off-by: Giel van Schijndel <me@mortis.eu> Cc: Jean Delvare <khali@linux-fr.org> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09hwmon: coretemp: documentation update and cleanupChen Gong
Update coretemp supported CPU TjMax lists and some cleanup work. Signed-off-by: Chen Gong <gong.chen@linux.intel.com> Cc: Rudolf Marek <r.marek@assembler.cz> Cc: Huaxu Wan <huaxu.wan@intel.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09hwmon: add support for JEDEC JC 42.4 compliant temperature sensorsGuenter Roeck
[akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09hwmon: driver for SMM665 Six-Channel Active DC Output Controller/MonitorGuenter Roeck
This driver adds support for the monitoring features of the Summit Microelectronics SMM665 Six-Channel Active DC Output Controller/Monitor. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Cc: Jean Delvare <khali@linux-fr.org> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09hmc6352: add driver for the HMC6352 compassKalhan Trisal
This driver will report the heading values in degrees to the sysfs interface. The values returned are headings . e.g. 245.6 Alan: Cleanups requested now all folded in and a sysfs description to keep Andrew happy. The sysfs description now resembles hwmon. Signed-off-by: Kalhan Trisal <kalhan.trisal@intel.com> Reviewed-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09drivers/misc: support for the pressure sensor BMP085 from Bosch SensortecChristoph Mair
This driver adds support for the BMP085 digital pressure sensor from Bosch Sensortec. It exposes a sysfs api to userspace where pressure and temperature measurement results can be read from the pressure0_input and temp0_input file. The chip is able to calculate the average of up to eight samples to increase the accuracy. This feature can be controlled by writing to the oversampling file. The BMP085 digital pressure sensor can measure ambient air pressure and temperature. Both values can be obtained from sysfs files. The pressure is measured by reading from pressure0_input. Valid values range from 30000 to 110000 pascal with a resolution of 1 pascal (=0.01 millibar). temp0_input holds the current temperature in degree celsius, multiplied by 10. This results in a resolution of a tenth degree celsius. Values range from -400 to 850. To increase the accuracy, this chip can calculate the average of 1, 2, 4 or 8 samples. This behavior is controlled through the oversampling sysfs file. Two to the power of the value written to that file specifies how many samples will be used. Valid values: 0..3. [akpm@linux-foundation.org: fix typo] [shubhrajyoti@ti.com: optimize the wait time for the pressure sensor, definition of long is arch dependent so make it u32] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Christoph Mair <christoph.mair@gmail.com> Signed-off-by: Shubhrajyoti D <shubhrajyoti@ti.com> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Cc: Stefan Schmidt <stefan@datenfreihafen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09SubmittingPatches: add more about patch descriptionsRandy Dunlap
Add more information about patch descriptions. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09oom: deprecate oom_adj tunableDavid Rientjes
/proc/pid/oom_adj is now deprecated so that that it may eventually be removed. The target date for removal is August 2012. A warning will be printed to the kernel log if a task attempts to use this interface. Future warning will be suppressed until the kernel is rebooted to prevent spamming the kernel log. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Nick Piggin <npiggin@suse.de> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09oom: badness heuristic rewriteDavid Rientjes
This a complete rewrite of the oom killer's badness() heuristic which is used to determine which task to kill in oom conditions. The goal is to make it as simple and predictable as possible so the results are better understood and we end up killing the task which will lead to the most memory freeing while still respecting the fine-tuning from userspace. Instead of basing the heuristic on mm->total_vm for each task, the task's rss and swap space is used instead. This is a better indication of the amount of memory that will be freeable if the oom killed task is chosen and subsequently exits. This helps specifically in cases where KDE or GNOME is chosen for oom kill on desktop systems instead of a memory hogging task. The baseline for the heuristic is a proportion of memory that each task is currently using in memory plus swap compared to the amount of "allowable" memory. "Allowable," in this sense, means the system-wide resources for unconstrained oom conditions, the set of mempolicy nodes, the mems attached to current's cpuset, or a memory controller's limit. The proportion is given on a scale of 0 (never kill) to 1000 (always kill), roughly meaning that if a task has a badness() score of 500 that the task consumes approximately 50% of allowable memory resident in RAM or in swap space. The proportion is always relative to the amount of "allowable" memory and not the total amount of RAM systemwide so that mempolicies and cpusets may operate in isolation; they shall not need to know the true size of the machine on which they are running if they are bound to a specific set of nodes or mems, respectively. Root tasks are given 3% extra memory just like __vm_enough_memory() provides in LSMs. In the event of two tasks consuming similar amounts of memory, it is generally better to save root's task. Because of the change in the badness() heuristic's baseline, it is also necessary to introduce a new user interface to tune it. It's not possible to redefine the meaning of /proc/pid/oom_adj with a new scale since the ABI cannot be changed for backward compatability. Instead, a new tunable, /proc/pid/oom_score_adj, is added that ranges from -1000 to +1000. It may be used to polarize the heuristic such that certain tasks are never considered for oom kill while others may always be considered. The value is added directly into the badness() score so a value of -500, for example, means to discount 50% of its memory consumption in comparison to other tasks either on the system, bound to the mempolicy, in the cpuset, or sharing the same memory controller. /proc/pid/oom_adj is changed so that its meaning is rescaled into the units used by /proc/pid/oom_score_adj, and vice versa. Changing one of these per-task tunables will rescale the value of the other to an equivalent meaning. Although /proc/pid/oom_adj was originally defined as a bitshift on the badness score, it now shares the same linear growth as /proc/pid/oom_score_adj but with different granularity. This is required so the ABI is not broken with userspace applications and allows oom_adj to be deprecated for future removal. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Nick Piggin <npiggin@suse.de> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09vmscan: tracing: add a postprocessing script for reclaim-related ftrace eventsMel Gorman
Add a simple post-processing script for the reclaim-related trace events. It can be used to give an indication of how much traffic there is on the LRU lists and how severe latencies due to reclaim are. Example output looks like the following Reclaim latencies expressed as order-latency_in_ms uname-3942 9-200.179000000004 9-98.7900000000373 9-99.8330000001006 kswapd0-311 0-662.097999999998 0-2.79700000002049 \ 0-149.100000000035 0-3295.73600000003 0-9806.31799999997 0-35528.833 \ 0-10043.197 0-129740.979 0-3.50500000000466 0-3.54899999999907 \ 0-9297.78999999992 0-3.48499999998603 0-3596.97999999998 0-3.92799999995623 \ 0-3.35000000009313 0-16729.017 0-3.57799999997951 0-47435.0630000001 \ 0-3.7819999998901 0-5864.06999999995 0-18635.334 0-10541.289 9-186011.565 \ 9-3680.86300000001 9-1379.06499999994 9-958571.115 9-66215.474 \ 9-6721.14699999988 9-1962.15299999993 9-1094806.125 9-2267.83199999994 \ 9-47120.9029999999 9-427653.886 9-2.6359999999404 9-632.148999999976 \ 9-476.753000000026 9-495.577000000048 9-8.45900000003166 9-6.6820000000298 \ 9-1.30500000016764 9-251.746000000043 9-383.905000000028 9-80.1419999999925 \ 9-281.160000000149 9-14.8780000000261 9-381.45299999998 9-512.07799999998 \ 9-49.5519999999087 9-167.439000000013 9-183.820999999996 9-239.527999999933 \ 9-19.9479999998584 9-148.747999999905 9-164.583000000101 9-16.9480000000913 \ 9-192.376000000164 9-64.1010000000242 9-1.40800000005402 9-3.60800000000745 \ 9-17.1359999999404 9-4.69500000006519 9-2.06400000001304 9-1582488.554 \ 9-6244.19499999983 9-348153.812 9-2.0999999998603 9-0.987999999895692 \ 0-32218.473 0-1.6140000000596 0-1.28100000019185 0-1.41300000017509 \ 0-1.32299999985844 0-602.584000000032 0-1.34400000004098 0-1.6929999999702 \ 1-22101.8190000001 9-174876.724 9-16.2420000000857 9-175.165999999736 \ 9-15.8589999997057 9-0.604999999981374 9-3061.09000000032 9-479.277000000235 \ 9-1.54499999992549 9-771.985000000335 9-4.88700000010431 9-15.0649999999441 \ 9-0.879999999888241 9-252.01500000013 9-1381.03600000031 9-545.689999999944 \ 9-3438.0129999998 9-3343.70099999988 bench-stresshig-3942 9-7063.33900000004 9-129960.482 9-2062.27500000002 \ 9-3845.59399999992 9-171.82799999998 9-16493.821 9-7615.23900000006 \ 9-10217.848 9-983.138000000035 9-2698.39999999991 9-4016.1540000001 \ 9-5522.37700000009 9-21630.429 \ 9-15061.048 9-10327.953 9-542.69700000016 9-317.652000000002 \ 9-8554.71699999995 9-1786.61599999992 9-1899.31499999994 9-2093.41899999999 \ 9-4992.62400000007 9-942.648999999976 9-1923.98300000001 9-3.7980000001844 \ 9-5.99899999983609 9-0.912000000011176 9-1603.67700000014 9-1.98300000000745 \ 9-3.96500000008382 9-0.902999999932945 9-2802.72199999983 9-1078.24799999991 \ 9-2155.82900000014 9-10.058999999892 9-1984.723 9-1687.97999999998 \ 9-1136.05300000007 9-3183.61699999985 9-458.731000000145 9-6.48600000003353 \ 9-1013.25200000009 9-8415.22799999989 9-10065.584 9-2076.79600000009 \ 9-3792.65699999989 9-71.2010000001173 9-2560.96999999997 9-2260.68400000012 \ 9-2862.65799999982 9-1255.81500000018 9-15.7440000001807 9-4.33499999996275 \ 9-1446.63800000004 9-238.635000000009 9-60.1790000000037 9-4.38800000003539 \ 9-639.567000000039 9-306.698000000091 9-31.4070000001229 9-74.997999999905 \ 9-632.725999999791 9-1625.93200000003 9-931.266000000061 9-98.7749999999069 \ 9-984.606999999844 9-225.638999999966 9-421.316000000108 9-653.744999999879 \ 9-572.804000000004 9-769.158999999985 9-603.918000000063 9-4.28499999991618 \ 9-626.21399999992 9-1721.25 9-0.854999999981374 9-572.39599999995 \ 9-681.881999999983 9-1345.12599999993 9-363.666999999899 9-3823.31099999999 \ 9-2991.28200000012 9-4.27099999994971 9-309.76500000013 9-3068.35700000008 \ 9-788.25 9-3515.73999999999 9-2065.96100000013 9-286.719999999972 \ 9-316.076000000117 9-344.151000000071 9-2.51000000000931 9-306.688000000082 \ 9-1515.00099999993 9-336.528999999864 9-793.491999999853 9-457.348999999929 \ 9-13620.155 9-119.933999999892 9-35.0670000000391 9-918.266999999993 \ 9-828.569000000134 9-4863.81099999999 9-105.222000000067 9-894.23900000006 \ 9-110.964999999851 9-0.662999999942258 9-12753.3150000002 9-12.6129999998957 \ 9-13368.0899999999 9-12.4199999999255 9-1.00300000002608 9-1.41100000008009 \ 9-10300.5290000001 9-16.502000000095 9-30.7949999999255 9-6283.0140000002 \ 9-4320.53799999994 9-6826.27300000004 9-3.07299999985844 9-1497.26799999992 \ 9-13.4040000000969 9-3.12999999988824 9-3.86100000003353 9-11.3539999998175 \ 9-0.10799999977462 9-21.780999999959 9-209.695999999996 9-299.647000000114 \ 9-6.01699999999255 9-20.8349999999627 9-22.5470000000205 9-5470.16800000006 \ 9-7.60499999998137 9-0.821000000229105 9-1.56600000010803 9-14.1669999998994 \ 9-0.209000000031665 9-1.82300000009127 9-1.70000000018626 9-19.9429999999702 \ 9-124.266999999993 9-0.0389999998733401 9-6.71400000015274 9-16.7710000001825 \ 9-31.0409999999683 9-0.516999999992549 9-115.888000000035 9-5.19900000002235 \ 9-222.389999999898 9-11.2739999999758 9-80.9050000000279 9-8.14500000001863 \ 9-4.44599999999627 9-0.218999999808148 9-0.715000000083819 9-0.233000000007451 \ 9-48.2630000000354 9-248.560999999987 9-374.96800000011 9-644.179000000004 \ 9-0.835999999893829 9-79.0060000000522 9-128.447999999858 9-0.692000000039116 \ 9-5.26500000013039 9-128.449000000022 9-2.04799999995157 9-12.0990000001621 \ 9-8.39899999997579 9-10.3860000001732 9-11.9310000000987 9-53.4450000000652 \ 9-0.46999999997206 9-2.96299999998882 9-17.9699999999721 9-0.776000000070781 \ 9-25.2919999998994 9-33.1110000000335 9-0.434000000124797 9-0.641000000061467 \ 9-0.505000000121072 9-1.12800000002608 9-149.222000000067 9-1.17599999997765 \ 9-3247.33100000001 9-10.7439999999478 9-153.523000000045 9-1.38300000014715 \ 9-794.762000000104 9-3.36199999996461 9-128.765999999829 9-181.543999999994 \ 9-78149.8229999999 9-176.496999999974 9-89.9940000001807 9-9.12700000009499 \ 9-250.827000000048 9-0.224999999860302 9-0.388999999966472 9-1.16700000036508 \ 9-32.1740000001155 9-12.6800000001676 9-0.0720000001601875 9-0.274999999906868 \ 9-0.724000000394881 9-266.866000000387 9-45.5709999999963 9-4.54399999976158 \ 9-8.27199999988079 9-4.38099999958649 9-0.512000000104308 9-0.0640000002458692 \ 9-5.20000000018626 9-0.0839999997988343 9-12.816000000108 9-0.503000000026077 \ 9-0.507999999914318 9-6.23999999975786 9-3.35100000025705 9-18.8530000001192 \ 9-25.2220000000671 9-68.2309999996796 9-98.9939999999478 9-0.441000000108033 \ 9-4.24599999981001 9-261.702000000048 9-3.01599999982864 9-0.0749999997206032 \ 9-0.0370000000111759 9-4.375 9-3.21800000034273 9-11.3960000001825 \ 9-0.0540000000037253 9-0.286000000312924 9-0.865999999921769 \ 9-0.294999999925494 9-6.45999999996275 9-4.31099999975413 9-128.248999999836 \ 9-0.282999999821186 9-102.155000000261 9-0.0860000001266599 \ 9-0.0540000000037253 9-0.935000000055879 9-0.0670000002719462 \ 9-5.8640000000596 9-19.9860000000335 9-4.18699999991804 9-0.566000000108033 \ 9-2.55099999997765 9-0.702000000048429 9-131.653999999631 9-0.638999999966472 \ 9-14.3229999998584 9-183.398000000045 9-178.095999999903 9-3.22899999981746 \ 9-7.31399999978021 9-22.2400000002235 9-11.7979999999516 9-108.10599999968 \ 9-99.0159999998286 9-102.640999999829 9-38.414000000339 Process Direct Wokeup Pages Pages Pages details Rclms Kswapd Scanned Sync-IO ASync-IO cc1-30800 0 1 0 0 0 wakeup-0=1 cc1-24260 0 1 0 0 0 wakeup-0=1 cc1-24152 0 12 0 0 0 wakeup-0=12 cc1-8139 0 1 0 0 0 wakeup-0=1 cc1-4390 0 1 0 0 0 wakeup-0=1 cc1-4648 0 7 0 0 0 wakeup-0=7 cc1-4552 0 3 0 0 0 wakeup-0=3 dd-4550 0 31 0 0 0 wakeup-0=31 date-4898 0 1 0 0 0 wakeup-0=1 cc1-6549 0 7 0 0 0 wakeup-0=7 as-22202 0 17 0 0 0 wakeup-0=17 cc1-6495 0 9 0 0 0 wakeup-0=9 cc1-8299 0 1 0 0 0 wakeup-0=1 cc1-6009 0 1 0 0 0 wakeup-0=1 cc1-2574 0 2 0 0 0 wakeup-0=2 cc1-30568 0 1 0 0 0 wakeup-0=1 cc1-2679 0 6 0 0 0 wakeup-0=6 sh-13747 0 12 0 0 0 wakeup-0=12 cc1-22193 0 18 0 0 0 wakeup-0=18 cc1-30725 0 2 0 0 0 wakeup-0=2 as-4392 0 2 0 0 0 wakeup-0=2 cc1-28180 0 14 0 0 0 wakeup-0=14 cc1-13697 0 2 0 0 0 wakeup-0=2 cc1-22207 0 8 0 0 0 wakeup-0=8 cc1-15270 0 179 0 0 0 wakeup-0=179 cc1-22011 0 82 0 0 0 wakeup-0=82 cp-14682 0 1 0 0 0 wakeup-0=1 as-11926 0 2 0 0 0 wakeup-0=2 cc1-6016 0 5 0 0 0 wakeup-0=5 make-18554 0 13 0 0 0 wakeup-0=13 cc1-8292 0 12 0 0 0 wakeup-0=12 make-24381 0 1 0 0 0 wakeup-1=1 date-18681 0 33 0 0 0 wakeup-0=33 cc1-32276 0 1 0 0 0 wakeup-0=1 timestamp-outpu-2809 0 253 0 0 0 wakeup-0=240 wakeup-1=13 date-18624 0 7 0 0 0 wakeup-0=7 cc1-30960 0 9 0 0 0 wakeup-0=9 cc1-4014 0 1 0 0 0 wakeup-0=1 cc1-30706 0 22 0 0 0 wakeup-0=22 uname-3942 4 1 306 0 17 direct-9=4 wakeup-9=1 cc1-28207 0 1 0 0 0 wakeup-0=1 cc1-30563 0 9 0 0 0 wakeup-0=9 cc1-22214 0 10 0 0 0 wakeup-0=10 cc1-28221 0 11 0 0 0 wakeup-0=11 cc1-28123 0 6 0 0 0 wakeup-0=6 kswapd0-311 0 7 357302 0 34233 wakeup-0=7 cc1-5988 0 7 0 0 0 wakeup-0=7 as-30734 0 161 0 0 0 wakeup-0=161 cc1-22004 0 45 0 0 0 wakeup-0=45 date-4590 0 4 0 0 0 wakeup-0=4 cc1-15279 0 213 0 0 0 wakeup-0=213 date-30735 0 1 0 0 0 wakeup-0=1 cc1-30583 0 4 0 0 0 wakeup-0=4 cc1-32324 0 2 0 0 0 wakeup-0=2 cc1-23933 0 3 0 0 0 wakeup-0=3 cc1-22001 0 36 0 0 0 wakeup-0=36 bench-stresshig-3942 287 287 80186 6295 12196 direct-9=287 wakeup-9=287 cc1-28170 0 7 0 0 0 wakeup-0=7 date-7932 0 92 0 0 0 wakeup-0=92 cc1-22222 0 6 0 0 0 wakeup-0=6 cc1-32334 0 16 0 0 0 wakeup-0=16 cc1-2690 0 6 0 0 0 wakeup-0=6 cc1-30733 0 9 0 0 0 wakeup-0=9 cc1-32298 0 2 0 0 0 wakeup-0=2 cc1-13743 0 18 0 0 0 wakeup-0=18 cc1-22186 0 4 0 0 0 wakeup-0=4 cc1-28214 0 11 0 0 0 wakeup-0=11 cc1-13735 0 1 0 0 0 wakeup-0=1 updatedb-8173 0 18 0 0 0 wakeup-0=18 cc1-13750 0 3 0 0 0 wakeup-0=3 cat-2808 0 2 0 0 0 wakeup-0=2 cc1-15277 0 169 0 0 0 wakeup-0=169 date-18317 0 1 0 0 0 wakeup-0=1 cc1-15274 0 197 0 0 0 wakeup-0=197 cc1-30732 0 1 0 0 0 wakeup-0=1 Kswapd Kswapd Order Pages Pages Pages Instance Wakeups Re-wakeup Scanned Sync-IO ASync-IO kswapd0-311 91 24 357302 0 34233 wake-0=31 wake-1=1 wake-9=59 rewake-0=10 rewake-1=1 rewake-9=13 Summary Direct reclaims: 291 Direct reclaim pages scanned: 437794 Direct reclaim write sync I/O: 6295 Direct reclaim write async I/O: 46446 Wake kswapd requests: 2152 Time stalled direct reclaim: 519.163009000002 ms Kswapd wakeups: 91 Kswapd pages scanned: 357302 Kswapd reclaim write sync I/O: 0 Kswapd reclaim write async I/O: 34233 Time kswapd awake: 5282.749757 ms Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Larry Woodman <lwoodman@redhat.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Christoph Hellwig <hch@infradead.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Michael Rubin <mrubin@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09oom: enable oom tasklist dump by defaultDavid Rientjes
The oom killer tasklist dump, enabled with the oom_dump_tasks sysctl, is very helpful information in diagnosing why a user's task has been killed. It emits useful information such as each eligible thread's memory usage that can determine why the system is oom, so it should be enabled by default. Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09update VFS documentation for method changes.Al Viro
2010-08-09update documentation for the new truncate sequenceChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-08igbvf.txt: Add igbvf DocumentationJeff Kirsher
Adds documentation for the igbvf (igb virtual function driver). v2: - Removed trailing white space - Removed Ethtool version info Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-08igb.txt: Add igb documentationJeff Kirsher
Add documentation for the igb networking driver. v2: - Removed trailing white space - Removed Ethtool version info - Removed LRO kernel version info Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-08V4L/DVB: Documentation: add v4l2-controls.txt documenting the new controls APIHans Verkuil
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-08V4L/DVB: v4l: Add driver for Samsung S5P SoC video postprocessorSylwester Nawrocki
This driver exports a video device node per each camera interface/ video postprocessor (FIMC) device contained in Samsung S5P SoC series. The driver is based on v4l2-mem2mem framework. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Pawel Osciak <p.osciak@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-08V4L/DVB: IR: extend interfaces to support more device settingsMaxim Levitsky
LIRC: add new IOCTL that enables learning mode (wide band receiver) Still missing features: carrier report & timeout reports. Will need to pack these into ir_raw_event Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: (82 commits) firewire: core: add forgotten dummy driver methods, remove unused ones firewire: add isochronous multichannel reception firewire: core: small clarifications in core-cdev firewire: core: remove unused code firewire: ohci: release channel in error path firewire: ohci: use memory barriers to order descriptor updates tools/firewire: nosy-dump: increment program version tools/firewire: nosy-dump: remove unused code tools/firewire: nosy-dump: use linux/firewire-constants.h tools/firewire: nosy-dump: break up a deeply nested function tools/firewire: nosy-dump: make some symbols static or const tools/firewire: nosy-dump: change to kernel coding style tools/firewire: nosy-dump: work around segfault in decode_fcp tools/firewire: nosy-dump: fix it on x86-64 tools/firewire: add userspace front-end of nosy firewire: nosy: note ioctls in ioctl-number.txt firewire: nosy: use generic printk macros firewire: nosy: endianess fixes and annotations firewire: nosy: annotate __user pointers and __iomem pointers firewire: nosy: fix device shutdown with active client ...
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (214 commits) ALSA: hda - Add pin-fix for HP dc5750 ALSA: als4000: Fix potentially invalid DMA mode setup ALSA: als4000: enable burst mode ALSA: hda - Fix initial capsrc selection in patch_alc269() ASoC: TWL4030: Capture route runtime DAPM ordering fix ALSA: hda - Add PC-beep whitelist for an Intel board ALSA: hda - More relax for pending period handling ALSA: hda - Define AC_FMT_* constants ALSA: hda - Fix beep frequency on IDT 92HD73xx and 92HD71Bxx codecs ALSA: hda - Add support for HDMI HBR passthrough ALSA: hda - Set Stream Type in Stream Format according to AES0 ALSA: hda - Fix Thinkpad X300 so SPDIF is not exposed ALSA: hda - FIX to not expose SPDIF on Thinkpad X301, since it does not have the ability to use SPDIF ASoC: wm9081: fix resource reclaim in wm9081_register error path ASoC: wm8978: fix a memory leak if a wm8978_register fail ASoC: wm8974: fix a memory leak if another WM8974 is registered ASoC: wm8961: fix resource reclaim in wm8961_register error path ASoC: wm8955: fix resource reclaim in wm8955_register error path ASoC: wm8940: fix a memory leak if wm8940_register return error ASoC: wm8904: fix resource reclaim in wm8904_register error path ...
git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2: (45 commits) nilfs2: reject filesystem with unsupported block size nilfs2: avoid rec_len overflow with 64KB block size nilfs2: simplify nilfs_get_page function nilfs2: reject incompatible filesystem nilfs2: add feature set fields to super block nilfs2: clarify byte offset in super block format nilfs2: apply read-ahead for nilfs_btree_lookup_contig nilfs2: introduce check flag to btree node buffer nilfs2: add btree get block function with readahead option nilfs2: add read ahead mode to nilfs_btnode_submit_block nilfs2: fix buffer head leak in nilfs_btnode_submit_block nilfs2: eliminate inline keywords in btree implementation nilfs2: get maximum number of child nodes from bmap object nilfs2: reduce repetitive calculation of max number of child nodes nilfs2: optimize calculation of min/max number of btree node children nilfs2: remove redundant pointer checks in bmap lookup functions nilfs2: get rid of nilfs_bmap_union nilfs2: unify bmap set_target_v operations nilfs2: get rid of nilfs_btree uses nilfs2: get rid of nilfs_direct uses ...
2010-08-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: [DNS RESOLVER] Minor typo correction DNS: Fixes for the DNS query module cifs: Include linux/err.h for IS_ERR and PTR_ERR DNS: Make AFS go to the DNS for AFSDB records for unknown cells DNS: Separate out CIFS DNS Resolver code cifs: account for new creduid=0x%x parameter in spnego upcall string cifs: reduce false positives with inode aliasing serverino autodisable CIFS: Make cifs_convert_address() take a const src pointer and a length cifs: show features compiled in as part of DebugData cifs: update README Fix up trivial conflicts in fs/cifs/cifsfs.c due to workqueue changes
