path: root/Documentation
2009-02-13PCI: Documentation: fix minor PCIe HOWTO thinkoAlex Chiang
Update doc to correctly refer to replacing the pci_register_driver API, and not the non-existent "pci_module_init" API. Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (32 commits) wimax: fix oops in wimax_dev_get_by_genl_info() when looking up non-wimax iface net: 4 bytes kernel memory disclosure in SO_BSDCOMPAT gsopt try #2 netxen: fix compile waring "label ‘set_32_bit_mask’ defined but not used" on IA64 platform bnx2: Update version to 1.9.2 and copyright. bnx2: Fix jumbo frames error handling. bnx2: Update 5709 firmware. bnx2: Update 5706/5708 firmware. 3c505: do not set pcb->data.raw beyond its size Documentation/connector/cn_test.c: don't use gfp_any() net: don't use in_atomic() in gfp_any() IRDA: cnt is off by 1 netxen: remove pcie workaround sun3: print when lance_open() fails qlge: bugfix: Add missing rx buf clean index on early exit. qlge: bugfix: Fix RX scaling values. qlge: bugfix: Fix TSO breakage. qlge: bugfix: Add missing dev_kfree_skb_any() call. qlge: bugfix: Add missing put_page() call. qlge: bugfix: Fix fatal error recovery hang. qlge: bugfix: Use netif_receive_skb() and vlan_hwaccel_receive_skb(). ...
2009-02-12Documentation/connector/cn_test.c: don't use gfp_any()Andrew Morton
cn_test_timer_func() is a timer handler and can never use GFP_KERNEL - there's no point in using gfp_any() here. Also, use setup_timer(). Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-11kernel-doc: preferred ending marker and examplesRandy Dunlap
Fix kernel-doc-nano-HOWTO.txt to use */ as the ending marker in kernel-doc examples and state that */ is the preferred ending marker. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Reported-by: Robert Love <robert.w.love@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-11Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: ptrace, x86: fix the usage of ptrace_fork() i8327: fix outb() parameter order x86: fix math_emu register frame access x86: math_emu info cleanup x86: include correct %gs in a.out core dump x86, vmi: put a missing paravirt_release_pmd in pgd_dtor x86: find nr_irqs_gsi with mp_ioapic_routing x86: add clflush before monitor for Intel 7400 series x86: disable intel_iommu support by default x86: don't apply __supported_pte_mask to non-present ptes x86: fix grammar in user-visible BIOS warning x86/Kconfig.cpu: make Kconfig help readable in the console x86, 64-bit: print DMI info in the oops trace
2009-02-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI PM: make the PM core more careful with drivers using the new PM framework PCI PM: Read power state from device after trying to change it on resume PCI PM: Do not disable and enable bridges during suspend-resume PCI: PCIe portdrv: Simplify suspend and resume PCI PM: Fix saving of device state in pci_legacy_suspend PCI PM: Check if the state has been saved before trying to restore it PCI PM: Fix handling of devices without drivers PCI: return error on failure to read PCI ROMs PCI: properly clean up ASPM link state on device remove
2009-02-05x86: disable intel_iommu support by defaultKyle McMartin
Due to recurring issues with DMAR support on certain platforms. There's a number of filesystem corruption incidents reported: https://bugzilla.redhat.com/show_bug.cgi?id=479996 http://bugzilla.kernel.org/show_bug.cgi?id=12578 Provide a Kconfig option to change whether it is enabled by default. If disabled, it can still be reenabled by passing intel_iommu=on to the kernel. Keep the .config option off by default. Signed-off-by: Kyle McMartin <kyle@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-By: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-04PCI: return error on failure to read PCI ROMsTimothy S. Nelson
This patch makes the ROM reading code return an error to user space if the size of the ROM read is equal to 0. The patch also emits a warnings if the contents of the ROM are invalid, and documents the effects of the "enable" file on ROM reading. Signed-off-by: Timothy S. Nelson <wayland@wayland.id.au> Acked-by: Alex Villacis-Lasso <a_villacis@palosanto.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-04ACPI: cpufreq: Remove deprecated /proc/acpi/processor/../performance proc ↵Thomas Renninger
entries They were long enough set deprecated... Update Documentation/cpu-freq/users-guide.txt: The deprecated files listed there seen not to exist for some time anymore already. Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-03Merge branch 'linux-next' of git://git.infradead.org/ubifs-2.6Linus Torvalds
* 'linux-next' of git://git.infradead.org/ubifs-2.6: UBIFS: remove fast unmounting UBIFS: return sensible error codes UBIFS: remount ro fixes UBIFS: spelling fix 'date' -> 'data' UBIFS: sync wbufs after syncing inodes and pages UBIFS: fix LPT out-of-space bug (again) UBIFS: fix no_chk_data_crc UBIFS: fix assertions UBIFS: ensure orphan area head is initialized UBIFS: always clean up GC LEB space UBIFS: add re-mount debugging checks UBIFS: fix LEB list freeing UBIFS: simplify locking UBIFS: document dark_wm and dead_wm better UBIFS: do not treat all data as short term UBIFS: constify operations UBIFS: do not commit twice
2009-02-02Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: fbdev/atyfb: Fix DSP config on some PowerMacs & PowerBooks powerpc: Fix oops on some machines due to incorrect pr_debug() powerpc/ps3: Printing fixups for l64 to ll64 convserion drivers/net powerpc/5200: update device tree binding documentation powerpc/5200: Bugfix for PCI mapping of memory and IMMR powerpc/5200: update defconfigs
2009-02-02Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (45 commits) V4L/DVB (10411): s5h1409: Perform s5h1409 soft reset after tuning V4L/DVB (10403): saa7134-alsa: saa7130 doesn't support digital audio V4L/DVB (10229): ivtv: fix memory leak V4L/DVB (10385): gspca - main: Fix memory leak when USB disconnection while streaming. V4L/DVB (10325): em28xx: Fix for fail to submit URB with IRQs and Pre-emption Disabled V4L/DVB (10317): radio-mr800: fix radio->muted and radio->stereo V4L/DVB (10314): cx25840: ignore TUNER_SET_CONFIG in the command callback. V4L/DVB (10288): af9015: bug fix: stick does not work always when plugged V4L/DVB (10287): af9015: fix second FE V4L/DVB (10270): saa7146: fix unbalanced mutex_lock/unlock V4L/DVB (10265): budget.c driver: Kernel oops: "BUG: unable to handle kernel paging request at ffffffff V4L/DVB (10261): em28xx: fix kernel panic on audio shutdown V4L/DVB (10257): em28xx: Fix for KWorld 330U Board V4L/DVB (10256): em28xx: Fix for KWorld 330U AC97 V4L/DVB (10254): em28xx: Fix audio URB transfer buffer race condition V4L/DVB (10250): cx25840: fix regression: fw not loaded on first use V4L/DVB (10248): v4l-dvb: fix a bunch of compile warnings. V4L/DVB (10243): em28xx: fix compile warning V4L/DVB (10240): Fix obvious swapped names in v4l2_subdev logic V4L/DVB (10233): [PATCH] Terratec Cinergy DT XS Diversity new USB ID (0ccd:0081) ...
2009-02-02block: add text file detailing queue/ sysfs filesJens Axboe
2009-01-30Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: cfq-iosched: Allow RT requests to pre-empt ongoing BE timeslice block: add sysfs file for controlling io stats accounting Mark mandatory elevator functions in the biodoc.txt include/linux: Add bsg.h to the Kernel exported headers block: silently error an unsupported barrier bio block: Fix documentation for blkdev_issue_flush() block: add bio_rw_flagged() for testing bio->bi_rw block: seperate bio/request unplug and sync bits block: export SSD/non-rotational queue flag through sysfs Fix small typo in bio.h's documentation block: get rid of the manual directory counting in blktrace block: Allow empty integrity profile block: Remove obsolete BUG_ON block: Don't verify integrity metadata on read error
2009-01-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (29 commits) tulip: fix 21142 with 10Mbps without negotiation drivers/net/skfp: if !capable(CAP_NET_ADMIN): inverted logic gianfar: Fix Wake-on-LAN support smsc911x: timeout reaches -1 smsc9420: fix interrupt signalling test failures ucc_geth: Change uec phy id to the same format as gianfar's wimax: fix build issue when debugfs is disabled netxen: fix memory leak in drivers/net/netxen_nic_init.c tun: Add some missing TUN compat ioctl translations. ipv4: fix infinite retry loop in IP-Config net: update documentation ip aliases net: Fix OOPS in skb_seq_read(). net: Fix frag_list handling in skb_seq_read netxen: revert jumbo ringsize ath5k: fix locking in ath5k_config cfg80211: print correct intersected regulatory domain cfg80211: Fix sanity check on 5 GHz when processing country IE iwlwifi: fix kernel oops when ucode DMA memory allocation failure rtl8187: Fix error in setting OFDM power settings for RTL8187L mac80211: remove Michael Wu as maintainer ...
2009-01-30powerpc/5200: update device tree binding documentationGrant Likely
This patch updates the mpc5200 binding documentation to match actual usage conventions, to remove incorrect information, and to remove topics which are more thoroughly described elsewhere. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de>
2009-01-30Mark mandatory elevator functions in the biodoc.txtNikanth Karthikesan
biodoc.txt mentions that elevator functions marked with * are mandatory, but no function is marked with *. Mark the 3 functions which should be implemented by any io scheduler. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-01-29Documentation/Changes: add required versions for new filesystemsBill Nottingham
btrfs requires version 0.18 of its tools, and squashfs requires 4.0. ext3 should use and ext4 requires v1.41.4 of e2fsprogs. Signed-off-by: Bill Nottingham <notting@redhat.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> cc: Ted Tso <tytso@mit.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-29fix emacs indenting howto filename expansionDan Carpenter
I don't think emacs understands tilde expansion, so use "expand-file-name" to do that. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-29Documentation: update CodingStyle tips for Emacs usersTeemu Likonen
With the previous Emacs tips example the kernel style was made available for files in the kernel-tree only. This patch updates the tip to add a separate cc-mode indent style ("linux-tabs-only"). This makes it easy to switch between different indent styles and also makes the kernel style easily available for any filetype mode (c++, awk, ...) that is managed by the Emacs cc-mode. Signed-off-by: Teemu Likonen <tlikonen@iki.fi> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-29Documentation: move DMA-mapping.txt to Doc/PCI/Randy Dunlap
Move DMA-mapping.txt to Documentation/PCI/. DMA-mapping.txt was supposed to be moved from Documentation/ to Documentation/PCI/. The 00-INDEX files in those two directories were updated, along with a few other text files, but the file itself somehow escaped being moved, so move it and update more text files and source files with its new location. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: driver-core: fix kernel-doc parameter name UIO: Add missing documentation of features added recently Sync patch for jp_JP/stable_kernel_rules.txt
2009-01-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: lguest: Fix a memory leak with the lg object during launcher close lguest: disable the FORTIFY for lguest. lguest: typos fix
2009-01-29memcg: update document to mention that swapoff should be testedKAMEZAWA Hiroyuki
Considering the recently found problem "memcg: fix refcnt handling at swapoff", it's better to mention swapoff behavior in the memcg_test document. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-29mm: OOM documentation updateEvgeniy Polyakov
Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net> Acked-by: David Rientjes <rientjes@google.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-30lguest: disable the FORTIFY for lguest.Tim 'mithro' Ansell
Makes all the warnings go away when compiling lguest on Ubuntu on Intrepid or greater. Signed-off-by: Timothy R Ansell <mithro@mithis.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-01-29net: update documentation ip aliasesStephen Hemminger
This documentation is old. Add a short note to describe why aliases are no long necessary, and remove the old contact/edit info. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-29UBIFS: remove fast unmountingArtem Bityutskiy
This UBIFS feature has never worked properly, and it was a mistake to add it because we simply have no use-cases. So, lets still accept the fast_unmount mount option, but ignore it. This does not change much, because UBIFS commit in sync_fs anyway, and sync_fs is called while unmounting. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2009-01-29V4L/DVB (10210): Fix a bug on v4lgrab.cSimon Harrison
v4lgrab breaks the fputc macro on some systems, because of #defined FILE. Also, I also added comments because it was not at all clear that to get gspca cameras to work with this application you need v4l1compat. Signed-off-by: Simon Harrison <si1356@yahoo.co.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-28UIO: Add missing documentation of features added recentlyHans J. Koch
The following features were added to the UIO framework in the near past: * Generic drivers for platform devices (uio_pdrv, uio_pdrv_genirq) * an "offset" sysfs attribute for memory mappings Unfortunately, all this went in without documentation (won't happen again...) This patch updates UIO documentation. Signed-off-by: Hans J. Koch <hjk@linutronix.de> Acked-by: Uwe Kleine-König <ukleinek@strlen.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-28Sync patch for jp_JP/stable_kernel_rules.txtTsugikazu Shibata
Updated jp_JP/stable_kernel_rules.txt due to changes in the main version of the file. Also, this patch is already reviewed by Japanese translation community called JF. Signed-off-by: Tsugikazu Shibata <tshibata@ab.jp.nec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27update port number in NFS/RDMA documentationJames Lentini
Update the NFS/RDMA documentation to use the new port number assigned by IANA. Signed-off-by: James Lentini <jlentini@netapp.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes: kbuild: fix kbuild.txt typos kbuild: print usage with no arguments in scripts/config Revert "kbuild: strip generated symbols from *.ko"
2009-01-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (92 commits) gianfar: Revive VLAN support vlan: Export symbols as non GPL symbols. bnx2x: tx_has_work should not wait for FW netxen: reduce memory footprint netxen: fix vlan tso/checksum offload net: Fix linux/if_frad.h's suitability for userspace. net: Move config NET_NS to from net/Kconfig to init/Kconfig isdn: Fix missing ifdef in isdn_ppp networking: document "nc" in addition to "netcat" in netconsole.txt e1000e: workaround hw errata af_key: initialize xfrm encap_oa virtio_net: Fix MAX_PACKET_LEN to support 802.1Q VLANs lcs: fix compilation for !CONFIG_IP_MULTICAST rtl8187: Add termination packet to prevent stall iwlwifi: fix rs_get_rate WARN_ON() p54usb: fix packet loss with first generation devices sctp: Fix another socket race during accept/peeloff sctp: Properly timestamp outgoing data chunks for rtx purposes sctp: Correctly start rtx timer on new packet transmissions. sctp: Fix crc32c calculations on big-endian arhes. ...
2009-01-26networking: document "nc" in addition to "netcat" in netconsole.txtJesse Barnes
It always annoyed me that the netconsole documentation didn't give me the correct command for my distro. Update it with a command line that actually works on my Fedora install. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-23Merge branch 'fix/hda' into for-linusTakashi Iwai
2009-01-23ALSA: hda: Add STAC92HD83XXX_PWR_REF quirkMatthew Ranostay
Some revisions of the 92hd8xxx codec's not supporting port power downs in which the using of it causes capture and also randomly playback streams to not function at all. Thus by disabling it by default and adding a option to enable it manually will fix all issue on current and future revisions. Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-18sound: Remove removed OSS kernel parameters from docHenrik Kretzschmar
Remove removed OSS kernel parameters from kernel-parameters.txt Remove the kernel parameters from the OSS drivers of the chips es1371 (removed 10-2007/2.6.24) and cs4232 (removed 02-2008/2.6.25) from the kernel parameters documentation. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-16Merge branch 'thinkpad-acpi' into releaseLen Brown
2009-01-15Merge branch 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: hwmon: (abituguru3) Fix CONFIG_DMI=n fallback to probe hwmon: (abituguru3) Enable DMI probing feature on IN9 32X MAX hwmon: (abituguru3) Match partial DMI board name strings hwmon: Add a driver for the ADT7475 hardware monitoring chip hwmon: (k8temp) Fix temperature reporting for (most) K8 RevG CPUs hwmon: (k8temp) Fix wrong sensor selection for AMD K8 RevF/RevG CPUs hwmon: (k8temp) Warn about fam F rev F errata
2009-01-15lis3: fix documentation to fit into 80 columnsPavel Machek
Fix lis3 documentation to fit into 80 columns. Signed-off-by: Pavel Machek <pavel@suse.cz> Cc: Éric Piel <eric.piel@tremplin-utc.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15Documentation/accounting/getdelays.c: fix endless loopMarcus Meissner
When no option is passed to getdelays it just hangs, waiting for a reply which will never come. This patch prints usage() when no output marker is specified. Signed-off-by: Marcus Meissner <meissner@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15cgroups: consolidate cgroup documentsLi Zefan
Move Documentation/cpusets.txt and Documentation/controllers/* to Documentation/cgroups/ Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15sysrq documentation: document why the command header only is shownAndy Whitcroft
Document the interactions between loglevel and the sysrq output. Also document how to work round it should output be required on the console. Signed-off-by: Andy Whitcroft <apw@canonical.com> Cc: Martin Mares <mj@ucw.cz> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15sysrq documentation: remove the redundant updated dateAndy Whitcroft
git is maintaining the last update time much more accuratly than the internal update time. Remove it. Signed-off-by: Andy Whitcroft <apw@canonical.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15Update of Documentation: vm.txt and proc.txtPeter W Morreale
Update Documentation/sysctl/vm.txt and Documentation/filesystems/proc.txt. More specifically, the section on /proc/sys/vm in Documentation/filesystems/proc.txt was removed and a link to Documentation/sysctl/vm.txt added. Most of the verbiage from proc.txt was simply moved in vm.txt, with new addtional text for "swappiness" and "stat_interval". Signed-off-by: Peter W Morreale <pmorreale@novell.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15hwmon: Add a driver for the ADT7475 hardware monitoring chipJordan Crouse
Hwmon driver for the ADT7475 chip. Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-01-15Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] SN specific version of dma_get_required_mask() [IA64] generic_defconfig: Enable SATA_VITESSE [IA64] dump stack on kernel unaligned warnings [IA64] Turn on CONFIG_HAVE_UNSTABLE_CLOCK [IA64] Update to use account_{steal,idle}_ticks
2009-01-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: hda - Fix invalid amp value for STAC925x ASoC: Fix the power update function for snd_soc_dapm_value_mux sound: virtuoso: do not overwrite EEPROM on Xonar D2/D2X ALSA: hda - Fix HP dv5 mic input ALSA: hda - Fix missing initialization of NID 0x0e for STAC925x ALSA: USB quirk for Logitech Quickcam Pro 9000 name ALSA: hda - Fix stac92hd83xxx_amp_nids[] ALSA: hda - Add automatic model setting for Samsung Q45 ALSA: hda - Don't reset HP pinctl in patch_sigmatel.c ALSA: hda: stac92hd8xxx amp mixers ALSA: hda - Fix silent headphone output on Panasonic CF-74 ALSA: hda - Update model descriptions in patch_sigmatel.c ALSA: hda - Use queue_delayed_work() ALSA: hda - Add quirk for another HP dv5 ALSA: hda - Add support of NVidia MCP78 HDMI ALSA: hda - Fix a typo ALSA: hda - More fixes on Gateway entries ALSA: patch_sigmatel: Add missing Gateway entries and autodetection ALSA: hda - Add a new function to seek for a codec ID
2009-01-15ACPI: thinkpad-acpi: bump up version to 0.22Henrique de Moraes Holschuh
It is about time to bump up the version. Features added since 0.21: fan suspend/resume support, preserve radio state across power off (for some radio types), built-in UWB radio rfkill support and thermal alarm events support. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Len Brown <len.brown@intel.com>
