path: root/Documentation
2011-02-03docs/sysfs: Update directory/kobject documentation.Bart Van Assche
Some time ago the way how sysfs stores a pointer to a kobject corresponding to a directory was modified. This patch brings the documentation again in sync with the implementation. Signed-off-by: Bart Van Assche <bvanassche@acm.org> Cc: Tejun Heo <tj@kernel.org> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-31NTFS: Fix invalid pointer dereference in ntfs_mft_record_alloc().Anton Altaparmakov
In ntfs_mft_record_alloc() when mapping the new extent mft record with map_extent_mft_record() we overwrite @m with the return value and on error, we then try to use the old @m but that is no longer there as @m now contains an error code instead so we crash when dereferencing the error code as if it were a pointer. The simple fix is to use a temporary variable to store the return value thus preserving the original @m for later use. This is a backport from the commercial Tuxera-NTFS driver and is well tested... Thanks go to Julia Lawall for pointing this out (whilst I had fixed it in the commercial driver I had failed to fix it in the Linux kernel). Signed-off-by: Anton Altaparmakov <anton@tuxera.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (43 commits) bnx2: Eliminate AER error messages on systems not supporting it cnic: Fix big endian bug xfrm6: Don't forget to propagate peer into ipsec route. tg3: Use new VLAN code bonding: update documentation - alternate configuration. TCP: fix a bug that triggers large number of TCP RST by mistake MAINTAINERS: remove Reinette Chatre as iwlwifi maintainer rt2x00: add device id for windy31 usb device mac80211: fix a crash in ieee80211_beacon_get_tim on change_interface ipv6: Revert 'administrative down' address handling changes. textsearch: doc - fix spelling in lib/textsearch.c. USB NET KL5KUSB101: Fix mem leak in error path of kaweth_download_firmware() pch_gbe: don't use flush_scheduled_work() bnx2: Always set ETH_FLAG_TXVLAN net: clear heap allocation for ethtool_get_regs() ipv6: Always clone offlink routes. dcbnl: make get_app handling symmetric for IEEE and CEE DCBx tcp: fix bug in listening_get_next() inetpeer: Use correct AVL tree base pointer in inet_getpeer(). GRO: fix merging a paged skb after non-paged skbs ...
2011-01-26Documentation: Fix kernel parameter orderingAlan Cox
A B C D E ... Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-25bonding: update documentation - alternate configuration.Nicolas de Pesloüan
The bonding documentation used to provide configuration details and examples for initscripts and sysconfig only. This patch describe the third possible configuration: /etc/network/interfaces. Signed-off-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-24Merge branch 'can/at91_can-for-net-2.6' of ↵David S. Miller
git://git.pengutronix.de/git/mkl/linux-2.6
2011-01-24can: at91_can: make can_id of mailbox 0 configurableMarc Kleine-Budde
Due to a chip bug (errata 50.2.6.3 & 50.3.5.3 in "AT91SAM9263 Preliminary 6249H-ATARM-27-Jul-09") the contents of mailbox 0 may be send under certain conditions (even if disabled or in rx mode). The workaround in the errata suggests not to use the mailbox and load it with an unused identifier. This patch implements the second part of the workaround. A sysfs entry "mb0_id" is introduced. While the interface is down it can be used to configure the can_id of mailbox 0. The default value id 0x7ff. In order to use an extended can_id add the CAN_EFF_FLAG (0x80000000U) to the can_id. Example: - standard id 0x7ff: echo 0x7ff > /sys/class/net/can0/mb0_id - extended id 0x1fffffff: echo 0x9fffffff > /sys/class/net/can0/mb0_id Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Acked-by: Wolfgang Grandegger <wg@grandegger.com> Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be> For the Documentation-part: Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2011-01-22docbook: fix broken serial to tty/serial movementRandy Dunlap
Fix move of drivers/serial/ to drivers/tty/, where it broke one of the docbook files: docproc: drivers/serial/serial_core.c: No such file or directory Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-21Merge branch 'media_fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'media_fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (101 commits) [media] staging/lirc: fix mem leaks and ptr err usage [media] hdpvr: reduce latency of i2c read/write w/recycled buffer [media] hdpvr: enable IR part [media] rc/mceusb: timeout should be in ns, not us [media] v4l2-device: fix 'use-after-freed' oops [media] v4l2-dev: don't memset video_device.dev [media] zoran: use video_device_alloc instead of kmalloc [media] w9966: zero device state after a detach [media] v4l: Fix a use-before-set in the control framework [media] v4l: Include linux/videodev2.h in media/v4l2-ctrls.h [media] DocBook/v4l: update V4L2 revision and update copyright years [media] DocBook/v4l: fix validation error in dev-rds.xml [media] v4l2-ctrls: queryctrl shouldn't attempt to replace V4L2_CID_PRIVATE_BASE IDs [media] v4l2-ctrls: fix missing 'read-only' check [media] pvrusb2: Provide more information about IR units to lirc_zilog and ir-kbd-i2c [media] ir-kbd-i2c: Add back defaults setting for Zilog Z8's at addr 0x71 [media] lirc_zilog: Update TODO.lirc_zilog [media] lirc_zilog: Add Andy Walls to copyright notice and authors list [media] lirc_zilog: Remove useless struct i2c_driver.command function [media] lirc_zilog: Remove unneeded tests for existence of the IR Tx function ...
2011-01-21Merge branch 'irq-cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (37 commits) um: Use generic irq Kconfig tile: Use generic irq Kconfig sparc: Use generic irq Kconfig score: Use generic irq Kconfig powerpc: Use generic irq Kconfig parisc: Use generic irq Kconfig mn10300: Use generic irq Kconfig microblaze: Use generic irq Kconfig m68knommu: Use generic irq Kconfig ia64: Use generic irq Kconfig frv: Use generic irq Kconfig blackfin: Use generic irq Kconfig alpha: Use generic irq Kconfig genirq: Remove __do_IRQ m32r: Convert to generic irq Kconfig m32r: Convert usrv platform irq handling m32r: Convert opsput_lcdpld irq chip m32r: Convert opsput lanpld irq chip m32r: Convert opsput pld irq chip m32r: Convert opsput irq chip ...
2011-01-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: hda - Fix EAPD to low on CZC P10T tablet computer with ALC662 ALSA: HDA: Add SKU ignore for another Thinkpad Edge 14 ALSA: hda - Fix "unused variable" compile warning ALSA: hda - Add quirk for HP Z-series workstation Revert "ALSA: HDA: Create mixers on ALC887" ASoC: PXA: Fix codec address on Zipit Z2 ASoC: PXA: Fix jack detection on Zipit Z2 ASoC: Blackfin: fix DAI/SPORT config dependency issues ASoC: Blackfin TDM: use external frame syncs ASoC: Blackfin AC97: fix build error after multi-component update ASoC: Blackfin TDM: fix missed snd_soc_dai_get_drvdata update ASoC: documentation updates ALSA: ice1712 delta - initialize SPI clock
2011-01-21genirq: Remove __do_IRQThomas Gleixner
All architectures are finally converted. Remove the cruft. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Mike Frysinger <vapier@gentoo.org> Cc: David Howells <dhowells@redhat.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Michal Simek <monstr@monstr.eu> Acked-by: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Jeff Dike <jdike@addtoit.com>
2011-01-21Merge branch 'fix/asoc' into for-linusTakashi Iwai
2011-01-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: virtio: remove virtio-pci root device LGUEST_GUEST: fix unmet direct dependencies (VIRTUALIZATION && VIRTIO) lguest: compile fixes lguest: Use this_cpu_ops lguest: document --rng in example Launcher lguest: example launcher to use guard pages, drop PROT_EXEC, fix limit logic lguest: --username and --chroot options
2011-01-20lguest: document --rng in example LauncherPhilip Sanderson
Rusty Russell wrote: > Ah, it will appear as /dev/hwrng. It's a weirdness of Linux that our actual > hardware number generators are not wired up to /dev/random... Reflected this in the documentation, thanks :-) Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-01-20lguest: example launcher to use guard pages, drop PROT_EXEC, fix limit logicPhilip Sanderson
PROT_EXEC seems to be completely unnecessary (as the lguest binary never executes there), and will allow it to work with SELinux (and more importantly, PaX :-) as they can/do forbid writable and executable mappings. Also, map PROT_NONE guard pages at start and end of guest memory for extra paranoia. I changed the length check to addr + size > guest_limit because >= is wrong (addr of 0, size of getpagesize() with a guest_limit of getpagesize() would false positive). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-01-20lguest: --username and --chroot optionsPhilip Sanderson
I've attached a patch which implements dropping to privileges and chrooting to a directory. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-01-19[media] DocBook/v4l: update V4L2 revision and update copyright yearsHans Verkuil
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-01-19[media] DocBook/v4l: fix validation error in dev-rds.xmlHans Verkuil
2011-01-19[media] v4l2-ctrls: v4l2_ctrl_handler_setup must set is_new to 1Hans Verkuil
Renamed has_new to is_new. Drivers can use the is_new field to determine if a new value was specified for a control. The v4l2_ctrl_handler_setup() must always set this to 1 since the setup has to force a full update of all controls. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-01-18hwmon: (lm93) Add support for LM94Guenter Roeck
This patch adds basic support for LM94 to the LM93 driver. LM94 specific sensors and features are not supported. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Jean Delvare <khali@linux-fr.org>
2011-01-18ASoC: documentation updatesSeungwhan Youn
This patch is only for RFC purpose of ASoC documentation updates which match with current ASoC codes with documents. Mostly modify features are modified to be sync with changes after multi-component patches. Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-01-17fallocate should be a file operationChristoph Hellwig
Currently all filesystems except XFS implement fallocate asynchronously, while XFS forced a commit. Both of these are suboptimal - in case of O_SYNC I/O we really want our allocation on disk, especially for the !KEEP_SIZE case where we actually grow the file with user-visible zeroes. On the other hand always commiting the transaction is a bad idea for fast-path uses of fallocate like for example in recent Samba versions. Given that block allocation is a data plane operation anyway change it from an inode operation to a file operation so that we have the file structure available that lets us check for O_SYNC. This also includes moving the code around for a few of the filesystems, and remove the already unnedded S_ISDIR checks given that we only wire up fallocate for regular files. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (23 commits) sanitize vfsmount refcounting changes fix old umount_tree() breakage autofs4: Merge the remaining dentry ops tables Unexport do_add_mount() and add in follow_automount(), not ->d_automount() Allow d_manage() to be used in RCU-walk mode Remove a further kludge from __do_follow_link() autofs4: Bump version autofs4: Add v4 pseudo direct mount support autofs4: Fix wait validation autofs4: Clean up autofs4_free_ino() autofs4: Clean up dentry operations autofs4: Clean up inode operations autofs4: Remove unused code autofs4: Add d_manage() dentry operation autofs4: Add d_automount() dentry operation Remove the automount through follow_link() kludge code from pathwalk CIFS: Use d_automount() rather than abusing follow_link() NFS: Use d_automount() rather than abusing follow_link() AFS: Use d_automount() rather than abusing follow_link() Add an AT_NO_AUTOMOUNT flag to suppress terminal automount ...
2011-01-15Unexport do_add_mount() and add in follow_automount(), not ->d_automount()David Howells
Unexport do_add_mount() and make ->d_automount() return the vfsmount to be added rather than calling do_add_mount() itself. follow_automount() will then do the addition. This slightly complicates things as ->d_automount() normally wants to add the new vfsmount to an expiration list and start an expiration timer. The problem with that is that the vfsmount will be deleted if it has a refcount of 1 and the timer will not repeat if the expiration list is empty. To this end, we require the vfsmount to be returned from d_automount() with a refcount of (at least) 2. One of these refs will be dropped unconditionally. In addition, follow_automount() must get a 3rd ref around the call to do_add_mount() lest it eat a ref and return an error, leaving the mount we have open to being expired as we would otherwise have only 1 ref on it. d_automount() should also add the the vfsmount to the expiration list (by calling mnt_set_expiry()) and start the expiration timer before returning, if this mechanism is to be used. The vfsmount will be unlinked from the expiration list by follow_automount() if do_add_mount() fails. This patch also fixes the call to do_add_mount() for AFS to propagate the mount flags from the parent vfsmount. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-15Allow d_manage() to be used in RCU-walk modeDavid Howells
Allow d_manage() to be called from pathwalk when it is in RCU-walk mode as well as when it is in Ref-walk mode. This permits __follow_mount_rcu() to call d_manage() directly. d_manage() needs a parameter to indicate that it is in RCU-walk mode as it isn't allowed to sleep if in that mode (but should return -ECHILD instead). autofs4_d_manage() can then be set to retain RCU-walk mode if the daemon accesses it and otherwise request dropping back to ref-walk mode. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-15Add a dentry op to allow processes to be held during pathwalk transitDavid Howells
Add a dentry op (d_manage) to permit a filesystem to hold a process and make it sleep when it tries to transit away from one of that filesystem's directories during a pathwalk. The operation is keyed off a new dentry flag (DCACHE_MANAGE_TRANSIT). The filesystem is allowed to be selective about which processes it holds and which it permits to continue on or prohibits from transiting from each flagged directory. This will allow autofs to hold up client processes whilst letting its userspace daemon through to maintain the directory or the stuff behind it or mounted upon it. The ->d_manage() dentry operation: int (*d_manage)(struct path *path, bool mounting_here); takes a pointer to the directory about to be transited away from and a flag indicating whether the transit is undertaken by do_add_mount() or do_move_mount() skipping through a pile of filesystems mounted on a mountpoint. It should return 0 if successful and to let the process continue on its way; -EISDIR to prohibit the caller from skipping to overmounted filesystems or automounting, and to use this directory; or some other error code to return to the user. ->d_manage() is called with namespace_sem writelocked if mounting_here is true and no other locks held, so it may sleep. However, if mounting_here is true, it may not initiate or wait for a mount or unmount upon the parameter directory, even if the act is actually performed by userspace. Within fs/namei.c, follow_managed() is extended to check with d_manage() first on each managed directory, before transiting away from it or attempting to automount upon it. follow_down() is renamed follow_down_one() and should only be used where the filesystem deliberately intends to avoid management steps (e.g. autofs). A new follow_down() is added that incorporates the loop done by all other callers of follow_down() (do_add/move_mount(), autofs and NFSD; whilst AFS, NFS and CIFS do use it, their use is removed by converting them to use d_automount()). The new follow_down() calls d_manage() as appropriate. It also takes an extra parameter to indicate if it is being called from mount code (with namespace_sem writelocked) which it passes to d_manage(). follow_down() ignores automount points so that it can be used to mount on them. __follow_mount_rcu() is made to abort rcu-walk mode if it hits a directory with DCACHE_MANAGE_TRANSIT set on the basis that we're probably going to have to sleep. It would be possible to enter d_manage() in rcu-walk mode too, and have that determine whether to abort or not itself. That would allow the autofs daemon to continue on in rcu-walk mode. Note that DCACHE_MANAGE_TRANSIT on a directory should be cleared when it isn't required as every tranist from that directory will cause d_manage() to be invoked. It can always be set again when necessary. ========================== WHAT THIS MEANS FOR AUTOFS ========================== Autofs currently uses the lookup() inode op and the d_revalidate() dentry op to trigger the automounting of indirect mounts, and both of these can be called with i_mutex held. autofs knows that the i_mutex will be held by the caller in lookup(), and so can drop it before invoking the daemon - but this isn't so for d_revalidate(), since the lock is only held on _some_ of the code paths that call it. This means that autofs can't risk dropping i_mutex from its d_revalidate() function before it calls the daemon. The bug could manifest itself as, for example, a process that's trying to validate an automount dentry that gets made to wait because that dentry is expired and needs cleaning up: mkdir S ffffffff8014e05a 0 32580 24956 Call Trace: [<ffffffff885371fd>] :autofs4:autofs4_wait+0x674/0x897 [<ffffffff80127f7d>] avc_has_perm+0x46/0x58 [<ffffffff8009fdcf>] autoremove_wake_function+0x0/0x2e [<ffffffff88537be6>] :autofs4:autofs4_expire_wait+0x41/0x6b [<ffffffff88535cfc>] :autofs4:autofs4_revalidate+0x91/0x149 [<ffffffff80036d96>] __lookup_hash+0xa0/0x12f [<ffffffff80057a2f>] lookup_create+0x46/0x80 [<ffffffff800e6e31>] sys_mkdirat+0x56/0xe4 versus the automount daemon which wants to remove that dentry, but can't because the normal process is holding the i_mutex lock: automount D ffffffff8014e05a 0 32581 1 32561 Call Trace: [<ffffffff80063c3f>] __mutex_lock_slowpath+0x60/0x9b [<ffffffff8000ccf1>] do_path_lookup+0x2ca/0x2f1 [<ffffffff80063c89>] .text.lock.mutex+0xf/0x14 [<ffffffff800e6d55>] do_rmdir+0x77/0xde [<ffffffff8005d229>] tracesys+0x71/0xe0 [<ffffffff8005d28d>] tracesys+0xd5/0xe0 which means that the system is deadlocked. This patch allows autofs to hold up normal processes whilst the daemon goes ahead and does things to the dentry tree behind the automouter point without risking a deadlock as almost no locks are held in d_manage() and none in d_automount(). Signed-off-by: David Howells <dhowells@redhat.com> Was-Acked-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-15Add a dentry op to handle automounting rather than abusing follow_link()David Howells
Add a dentry op (d_automount) to handle automounting directories rather than abusing the follow_link() inode operation. The operation is keyed off a new dentry flag (DCACHE_NEED_AUTOMOUNT). This also makes it easier to add an AT_ flag to suppress terminal segment automount during pathwalk and removes the need for the kludge code in the pathwalk algorithm to handle directories with follow_link() semantics. The ->d_automount() dentry operation: struct vfsmount *(*d_automount)(struct path *mountpoint); takes a pointer to the directory to be mounted upon, which is expected to provide sufficient data to determine what should be mounted. If successful, it should return the vfsmount struct it creates (which it should also have added to the namespace using do_add_mount() or similar). If there's a collision with another automount attempt, NULL should be returned. If the directory specified by the parameter should be used directly rather than being mounted upon, -EISDIR should be returned. In any other case, an error code should be returned. The ->d_automount() operation is called with no locks held and may sleep. At this point the pathwalk algorithm will be in ref-walk mode. Within fs/namei.c itself, a new pathwalk subroutine (follow_automount()) is added to handle mountpoints. It will return -EREMOTE if the automount flag was set, but no d_automount() op was supplied, -ELOOP if we've encountered too many symlinks or mountpoints, -EISDIR if the walk point should be used without mounting and 0 if successful. The path will be updated to point to the mounted filesystem if a successful automount took place. __follow_mount() is replaced by follow_managed() which is more generic (especially with the patch that adds ->d_manage()). This handles transits from directories during pathwalk, including automounting and skipping over mountpoints (and holding processes with the next patch). __follow_mount_rcu() will jump out of RCU-walk mode if it encounters an automount point with nothing mounted on it. follow_dotdot*() does not handle automounts as you don't want to trigger them whilst following "..". I've also extracted the mount/don't-mount logic from autofs4 and included it here. It makes the mount go ahead anyway if someone calls open() or creat(), tries to traverse the directory, tries to chdir/chroot/etc. into the directory, or sticks a '/' on the end of the pathname. If they do a stat(), however, they'll only trigger the automount if they didn't also say O_NOFOLLOW. I've also added an inode flag (S_AUTOMOUNT) so that filesystems can mark their inodes as automount points. This flag is automatically propagated to the dentry as DCACHE_NEED_AUTOMOUNT by __d_instantiate(). This saves NFS and could save AFS a private flag bit apiece, but is not strictly necessary. It would be preferable to do the propagation in d_set_d_op(), but that doesn't normally have access to the inode. [AV: fixed breakage in case if __follow_mount_rcu() fails and nameidata_drop_rcu() succeeds in RCU case of do_lookup(); we need to fall through to non-RCU case after that, rather than just returning with ungrabbed *path] Signed-off-by: David Howells <dhowells@redhat.com> Was-Acked-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-post-merge-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-post-merge-2.6: [SCSI] target: Add LIO target core v4.0.0-rc6 [SCSI] sd,sr: kill compat SDEV_MEDIA_CHANGE event [SCSI] sd: implement sd_check_events()
2011-01-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (47 commits) GRETH: resolve SMP issues and other problems GRETH: handle frame error interrupts GRETH: avoid writing bad speed/duplex when setting transfer mode GRETH: fixed skb buffer memory leak on frame errors GRETH: GBit transmit descriptor handling optimization GRETH: fix opening/closing GRETH: added raw AMBA vendor/device number to match against. cassini: Fix build bustage on x86. e1000e: consistent use of Rx/Tx vs. RX/TX/rx/tx in comments/logs e1000e: update Copyright for 2011 e1000: Avoid unhandled IRQ r8169: keep firmware in memory. netdev: tilepro: Use is_unicast_ether_addr helper etherdevice.h: Add is_unicast_ether_addr function ks8695net: Use default implementation of ethtool_ops::get_link ks8695net: Disable non-working ethtool operations USB CDC NCM: Don't deref NULL in cdc_ncm_rx_fixup() and don't use uninitialized variable. vxge: Remember to release firmware after upgrading firmware netdev: bfin_mac: Remove is_multicast_ether_addr use in netdev_for_each_mc_addr ipsec: update MAX_AH_AUTH_LEN to support sha512 ...
2011-01-14Merge branch 'for-2.6.38' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.38' of git://linux-nfs.org/~bfields/linux: (62 commits) nfsd4: fix callback restarting nfsd: break lease on unlink, link, and rename nfsd4: break lease on nfsd setattr nfsd: don't support msnfs export option nfsd4: initialize cb_per_client nfsd4: allow restarting callbacks nfsd4: simplify nfsd4_cb_prepare nfsd4: give out delegations more quickly in 4.1 case nfsd4: add helper function to run callbacks nfsd4: make sure sequence flags are set after destroy_session nfsd4: re-probe callback on connection loss nfsd4: set sequence flag when backchannel is down nfsd4: keep finer-grained callback status rpc: allow xprt_class->setup to return a preexisting xprt rpc: keep backchannel xprt as long as server connection rpc: move sk_bc_xprt to svc_xprt nfsd4: allow backchannel recovery nfsd4: support BIND_CONN_TO_SESSION nfsd4: modify session list under cl_lock Documentation: fl_mylease no longer exists ... Fix up conflicts in fs/nfsd/vfs.c with the vfs-scale work. The vfs-scale work touched some msnfs cases, and this merge removes support for that entirely, so the conflict was trivial to resolve.
2011-01-14[SCSI] target: Add LIO target core v4.0.0-rc6Nicholas Bellinger
LIO target is a full featured in-kernel target framework with the following feature set: High-performance, non-blocking, multithreaded architecture with SIMD support. Advanced SCSI feature set: * Persistent Reservations (PRs) * Asymmetric Logical Unit Assignment (ALUA) * Protocol and intra-nexus multiplexing, load-balancing and failover (MC/S) * Full Error Recovery (ERL=0,1,2) * Active/active task migration and session continuation (ERL=2) * Thin LUN provisioning (UNMAP and WRITE_SAMExx) Multiprotocol target plugins Storage media independence: * Virtualization of all storage media; transparent mapping of IO to LUNs * No hard limits on number of LUNs per Target; maximum LUN size ~750 TB * Backstores: SATA, SAS, SCSI, BluRay, DVD, FLASH, USB, ramdisk, etc. Standards compliance: * Full compliance with IETF (RFC 3720) * Full implementation of SPC-4 PRs and ALUA Significant code cleanups done by Christoph Hellwig. [jejb: fix up for new block bdev exclusive interface. Minor fixes from Randy Dunlap and Dan Carpenter.] Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-01-14revert documentaion update for memcg's dirty ratio.KAMEZAWA Hiroyuki
Subjct: Revert memory cgroup dirty_ratio Documentation. The commit ece72400c2a27a3d726cb0854449f991d9fcd2da adds documentation for memcg's dirty ratio. But the function is not implemented yet. Remove the documentation for avoiding confusing users. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Greg Thelen <gthelen@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (59 commits) ACPI / PM: Fix build problems for !CONFIG_ACPI related to NVS rework ACPI: fix resource check message ACPI / Battery: Update information on info notification and resume ACPI: Drop device flag wake_capable ACPI: Always check if _PRW is present before trying to evaluate it ACPI / PM: Check status of power resources under mutexes ACPI / PM: Rename acpi_power_off_device() ACPI / PM: Drop acpi_power_nocheck ACPI / PM: Drop acpi_bus_get_power() Platform / x86: Make fujitsu_laptop use acpi_bus_update_power() ACPI / Fan: Rework the handling of power resources ACPI / PM: Register power resource devices as soon as they are needed ACPI / PM: Register acpi_power_driver early ACPI / PM: Add function for updating device power state consistently ACPI / PM: Add function for device power state initialization ACPI / PM: Introduce __acpi_bus_get_power() ACPI / PM: Introduce function for refcounting device power resources ACPI / PM: Add functions for manipulating lists of power resources ACPI / PM: Prevent acpi_power_get_inferred_state() from making changes ACPICA: Update version to 20101209 ...
2011-01-13Merge branch 'vfs-scale-working' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/npiggin/linux-npiggin * 'vfs-scale-working' of git://git.kernel.org/pub/scm/linux/kernel/git/npiggin/linux-npiggin: fs: fix do_last error case when need_reval_dot nfs: add missing rcu-walk check fs: hlist UP debug fixup fs: fix dropping of rcu-walk from force_reval_path fs: force_reval_path drop rcu-walk before d_invalidate fs: small rcu-walk documentation fixes Fixed up trivial conflicts in Documentation/filesystems/porting
2011-01-14fs: small rcu-walk documentation fixesNick Piggin
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-13memcg: document cgroup dirty memory interfacesGreg Thelen
Document cgroup dirty memory interfaces and statistics. [akpm@linux-foundation.org: fix use_hierarchy description] Signed-off-by: Andrea Righi <arighi@develer.com> Signed-off-by: Greg Thelen <gthelen@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: transparent hugepage support documentationAndrea Arcangeli
Documentation/vm/transhuge.txt Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13oom: allow a non-CAP_SYS_RESOURCE proces to oom_score_adj downMandeep Singh Baines
We'd like to be able to oom_score_adj a process up/down as it enters/leaves the foreground. Currently, it is not possible to oom_adj down without CAP_SYS_RESOURCE. This patch allows a task to decrease its oom_score_adj back to the value that a CAP_SYS_RESOURCE thread set it to or its inherited value at fork. Assuming the thread that has forked it has oom_score_adj of 0, each process could decrease it back from 0 upon activation unless a CAP_SYS_RESOURCE thread elevated it to something higher. Alternative considered: * a setuid binary * a daemon with CAP_SYS_RESOURCE Since you don't wan't all processes to be able to reduce their oom_adj, a setuid or daemon implementation would be complex. The alternatives also have much higher overhead. This patch updated from original patch based on feedback from David Rientjes. Signed-off-by: Mandeep Singh Baines <msb@chromium.org> Acked-by: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13mm: smaps: export mlock informationNikanth Karthikesan
Currently there is no way to find whether a process has locked its pages in memory or not. And which of the memory regions are locked in memory. Add a new field "Locked" to export this information via the smaps file. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dmLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dm: (32 commits) dm: raid456 basic support dm: per target unplug callback support dm: introduce target callbacks and congestion callback dm mpath: delay activate_path retry on SCSI_DH_RETRY dm: remove superfluous irq disablement in dm_request_fn dm log: use PTR_ERR value instead of ENOMEM dm snapshot: avoid storing private suspended state dm snapshot: persistent make metadata_wq multithreaded dm: use non reentrant workqueues if equivalent dm: convert workqueues to alloc_ordered dm stripe: switch from local workqueue to system_wq dm: dont use flush_scheduled_work dm snapshot: remove unused dm_snapshot queued_bios_work dm ioctl: suppress needless warning messages dm crypt: add loop aes iv generator dm crypt: add multi key capability dm crypt: add post iv call to iv generator dm crypt: use io thread for reads only if mempool exhausted dm crypt: scale to multiple cpus dm crypt: simplify compatible table output ...
2011-01-13Revert "gpiolib: annotate gpio-intialization with __must_check"Linus Torvalds
This reverts commit 0fdae42d361bbb431ca0ab0efed5126a94821177, which wasn't really supposed to go in, and causes lots of annoying warnings. Quoth Andrew: "Complete brainfart - I meant to drop that patch ages ago." Quoth Greg: "Ick, yeah, that patch isn't ok to go in as-is, all of the callers need to be fixed up first, which is what I thought we had agreed on..." Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13dm: raid456 basic supportNeilBrown
This patch is the skeleton for the DM target that will be the bridge from DM to MD (initially RAID456 and later RAID1). It provides a way to use device-mapper interfaces to the MD RAID456 drivers. As with all device-mapper targets, the nominal public interfaces are the constructor (CTR) tables and the status outputs (both STATUSTYPE_INFO and STATUSTYPE_TABLE). The CTR table looks like the following: 1: <s> <l> raid \ 2: <raid_type> <#raid_params> <raid_params> \ 3: <#raid_devs> <meta_dev1> <dev1> .. <meta_devN> <devN> Line 1 contains the standard first three arguments to any device-mapper target - the start, length, and target type fields. The target type in this case is "raid". Line 2 contains the arguments that define the particular raid type/personality/level, the required arguments for that raid type, and any optional arguments. Possible raid types include: raid4, raid5_la, raid5_ls, raid5_rs, raid6_zr, raid6_nr, and raid6_nc. (again, raid1 is planned for the future.) The list of required and optional parameters is the same for all the current raid types. The required parameters are positional, while the optional parameters are given as key/value pairs. The possible parameters are as follows: <chunk_size> Chunk size in sectors. [[no]sync] Force/Prevent RAID initialization [rebuild <idx>] Rebuild the drive indicated by the index [daemon_sleep <ms>] Time between bitmap daemon work to clear bits [min_recovery_rate <kB/sec/disk>] Throttle RAID initialization [max_recovery_rate <kB/sec/disk>] Throttle RAID initialization [max_write_behind <value>] See '-write-behind=' (man mdadm) [stripe_cache <sectors>] Stripe cache size for higher RAIDs Line 3 contains the list of devices that compose the array in metadata/data device pairs. If the metadata is stored separately, a '-' is given for the metadata device position. If a drive has failed or is missing at creation time, a '-' can be given for both the metadata and data drives for a given position. Examples: # RAID4 - 4 data drives, 1 parity # No metadata devices specified to hold superblock/bitmap info # Chunk size of 1MiB # (Lines separated for easy reading) 0 1960893648 raid \ raid4 1 2048 \ 5 - 8:17 - 8:33 - 8:49 - 8:65 - 8:81 # RAID4 - 4 data drives, 1 parity (no metadata devices) # Chunk size of 1MiB, force RAID initialization, # min recovery rate at 20 kiB/sec/disk 0 1960893648 raid \ raid4 4 2048 min_recovery_rate 20 sync\ 5 - 8:17 - 8:33 - 8:49 - 8:65 - 8:81 Performing a 'dmsetup table' should display the CTR table used to construct the mapping (with possible reordering of optional parameters). Performing a 'dmsetup status' will yield information on the state and health of the array. The output is as follows: 1: <s> <l> raid \ 2: <raid_type> <#devices> <1 health char for each dev> <resync_ratio> Line 1 is standard DM output. Line 2 is best shown by example: 0 1960893648 raid raid4 5 AAAAA 2/490221568 Here we can see the RAID type is raid4, there are 5 devices - all of which are 'A'live, and the array is 2/490221568 complete with recovery. Cc: linux-raid@vger.kernel.org Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-01-13dm crypt: add multi key capabilityMilan Broz
This patch adds generic multikey handling to be used in following patch for Loop-AES mode compatibility. This patch extends mapping table to optional keycount and implements generic multi-key capability. With more keys defined the <key> string is divided into several <keycount> sections and these are used for tfms. The tfm is used according to sector offset (sector 0->tfm[0], sector 1->tfm[1], sector N->tfm[N modulo keycount]) (only power of two values supported for keycount here). Because of tfms per-cpu allocation, this mode can be take a lot of memory on large smp systems. Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: Max Vozeler <max@hinterhof.net>
2011-01-13Merge branch 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-block: (43 commits) block: ensure that completion error gets properly traced blktrace: add missing probe argument to block_bio_complete block cfq: don't use atomic_t for cfq_group block cfq: don't use atomic_t for cfq_queue block: trace event block fix unassigned field block: add internal hd part table references block: fix accounting bug on cross partition merges kref: add kref_test_and_get bio-integrity: mark kintegrityd_wq highpri and CPU intensive block: make kblockd_workqueue smarter Revert "sd: implement sd_check_events()" block: Clean up exit_io_context() source code. Fix compile warnings due to missing removal of a 'ret' variable fs/block: type signature of major_to_index(int) to major_to_index(unsigned) block: convert !IS_ERR(p) && p to !IS_ERR_NOR_NULL(p) cfq-iosched: don't check cfqg in choose_service_tree() fs/splice: Pull buf->ops->confirm() from splice_from_pipe actors cdrom: export cdrom_check_events() sd: implement sd_check_events() sr: implement sr_check_events() ...
2011-01-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (348 commits) ALSA: hda - Fix NULL-derefence with a single mic in STAC auto-mic detection ALSA: hda - Add missing NID 0x19 fixup for Sony VAIO ALSA: hda - Fix ALC275 enable hardware EQ for SONY VAIO ALSA: oxygen: fix Xonar DG input ALSA: hda - Fix EAPD on Lenovo NB ALC269 to low ALSA: hda - Fix missing EAPD for Acer 4930G ALSA: hda: Disable 4/6 channels on some NVIDIA GPUs. ALSA: hda - Add static_hdmi_pcm option to HDMI codec parser ALSA: hda - Don't refer ELD when unplugged ASoC: tpa6130a2: Fix compiler warning ASoC: tlv320dac33: Add DAPM selection for LOM invert ASoC: DMIC codec: Adding a generic DMIC codec ALSA: snd-usb-us122l: Fix missing NULL checks ALSA: snd-usb-us122l: Fix MIDI output ASoC: soc-cache: Fix invalid memory access during snd_soc_lzo_cache_sync() ASoC: Fix section mismatch in wm8995.c ALSA: oxygen: add S/PDIF source selection for Claro cards ALSA: oxygen: fix CD/MIDI for X-Meridian (2G) ASoC: fix migor audio build ALSA: include delay.h for msleep in Xonar DG support ...
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (41 commits) fs: add documentation on fallocate hole punching Gfs2: fail if we try to use hole punch Btrfs: fail if we try to use hole punch Ext4: fail if we try to use hole punch Ocfs2: handle hole punching via fallocate properly XFS: handle hole punching via fallocate properly fs: add hole punching to fallocate vfs: pass struct file to do_truncate on O_TRUNC opens (try #2) fix signedness mess in rw_verify_area() on 64bit architectures fs: fix kernel-doc for dcache::prepend_path fs: fix kernel-doc for dcache::d_validate sanitize ecryptfs ->mount() switch afs move internal-only parts of ncpfs headers to fs/ncpfs switch ncpfs switch 9p pass default dentry_operations to mount_pseudo() switch hostfs switch affs switch configfs ...
2011-01-13Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: hwmon: (dme1737) Minor cleanups hwmon: (dme1737) Add support for in7 for SCH5127 hwmon: (emc1403) Add EMC1423 support hwmon: (w83627hf) Document W83627THF voltage pin mapping hwmon: (w83793) Drop useless mutex hwmon: (fschmd) Drop useless mutex hwmon: (w83781d) Use pr_fmt and pr_<level> hwmon: (pc87427) Use pr_fmt and pr_<level> hwmon: (pc87360) Use pr_fmt and pr_<level> hwmon: (lm78) Use pr_fmt and pr_<level> hwmon: (it87) Use pr_fmt and pr_<level> hwmon: Schedule the removal of the old intrusion detection interfaces hwmon: (w83793) Implement the standard intrusion detection interface hwmon: (w83792d) Implement the standard intrusion detection interface hwmon: (adm9240) Implement the standard intrusion detection interface hwmon: (via686a) Initialize fan_div values hwmon: (w83795) Silent false warning from gcc hwmon: (ads7828) Update email contact details
2011-01-13Merge branch 'kvm-updates/2.6.38' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.38' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (142 commits) KVM: Initialize fpu state in preemptible context KVM: VMX: when entering real mode align segment base to 16 bytes KVM: MMU: handle 'map_writable' in set_spte() function KVM: MMU: audit: allow audit more guests at the same time KVM: Fetch guest cr3 from hardware on demand KVM: Replace reads of vcpu->arch.cr3 by an accessor KVM: MMU: only write protect mappings at pagetable level KVM: VMX: Correct asm constraint in vmcs_load()/vmcs_clear() KVM: MMU: Initialize base_role for tdp mmus KVM: VMX: Optimize atomic EFER load KVM: VMX: Add definitions for more vm entry/exit control bits KVM: SVM: copy instruction bytes from VMCB KVM: SVM: implement enhanced INVLPG intercept KVM: SVM: enhance mov DR intercept handler KVM: SVM: enhance MOV CR intercept handler KVM: SVM: add new SVM feature bit names KVM: cleanup emulate_instruction KVM: move complete_insn_gp() into x86.c KVM: x86: fix CR8 handling KVM guest: Fix kvm clock initialization when it's configured out ...
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
