path: root/Documentation
2005-10-28[PATCH] i2c: Documentation updateJean Delvare
Update the i2c documentation: kzalloc should be used instead of kmalloc. I also fixed a couple other things nearby in writing-clients, as several past changes had never been reported there. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] i2c: New Xicor X1205 RTC driverAlessandro Zummo
New driver for the Xicor X1205 RTC chip. Signed-off-by: Alessandro Zummo <alessandro.zummo@towertech.it> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] hwmon: New device ID for the smsc47b397 driverMark M. Hoffman
This patch adds a new ID to the SMSC LPC47B397-NC hardware monitoring driver - for a chip that is claimed to be 100% compatible otherwise. Signed-off-by: Bryan Young (Utilitek Systems, Inc.) Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] hwmon: Drop legacy ISA address support from it87Jean Delvare
Drop legacy ISA address support from the it87 driver. All supported chips are Super-I/O chips, so the device ISA address can be safely read from Super-I/O space rather than blindly assumed. Two nearby inaccurate documentation statements have been fixed as well: * The IT8705F doesn't have an SMBus interface. * The SiS950 doesn't have a distinct prefix. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] i2c: Documentation fixesJean Delvare
i2c documentation fixes. >From Hideki Iwamoto: * i2c_smbus_read_i2c_block_data is not deleted in 2.6.10. It still exists. * The name which can be set to i2c_driver is up to 31 characters. >From Jean Delvare: * Reword the paragraph about i2c_driver.name, to reflect the "new" naming policy. * Delete the out-of-date note about now gone inc_use and dec_use fields. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] i2c-viapro: Update supported devices listJean Delvare
Make it clearer which chips are supported by the i2c-viapro driver, and which support I2C block transactions. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Documentation/i2c/busses/i2c-viapro | 12 ++++++------ drivers/i2c/busses/i2c-viapro.c | 22 +++++++++++++--------- 2 files changed, 19 insertions(+), 15 deletions(-)
2005-10-28[PATCH] i2c-viapro: Implement I2C Block transactionsJean Delvare
Implement the I2C block transactions on VIA chips which support them: VT82C686B, VT8233, VT8233A, VT8235 and VT8237R. This speeds up EEPROM accesses by a factor 10 or so. I would like to thank Antonino A. Daplas, Hinko Kocevar, Salah Coronya and Andreas Henriksson for their help in testing this new feature. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Documentation/i2c/busses/i2c-viapro | 7 +++++- drivers/i2c/busses/i2c-viapro.c | 39 +++++++++++++++++++++++++++++++++--- 2 files changed, 42 insertions(+), 4 deletions(-)
2005-10-28[PATCH] i2c-viapro: Coding style fixesJean Delvare
Before I go on cleaning up and improving the i2c-viapro driver, let's fix all the coding style issues: mostly trailing white space, and spaces used where tabs should be. Signed-off-by: Jean Delvare <khali@linux-fr> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Documentation/i2c/busses/i2c-viapro | 12 ++--- drivers/i2c/busses/i2c-viapro.c | 76 ++++++++++++++++++------------------ 2 files changed, 43 insertions(+), 45 deletions(-)
2005-10-28[PATCH] i2c: Fix I2C_FUNC_PROTOCOL_MANGLING documentationHideki Iwamoto
Fix the description of I2C_FUNC_PROTOCOL_MANGLING. From: Hideki Iwamoto <h-iwamoto@kit.hi-ho.ne.jp> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Documentation/i2c/functionality | 7 ++++--- 1 file changed, 4 insertions(+), 3 deletions(-)
2005-10-28[PATCH] hwmon: Do not forcibly enable via686a by defaultJean Delvare
Do not enable the VIA VT82C686A/B integrated sensors by default, as disabled sensors usually means that this feature is not used so the values won't make any sense. This has been confusing many users in the past: http://www2.lm-sensors.nu/~lm78/readticket.cgi?ticket=1786 http://www2.lm-sensors.nu/~lm78/readticket.cgi?ticket=1811 http://www2.lm-sensors.nu/~lm78/readticket.cgi?ticket=2052 It is still possible to forcibly enable the sensors by using the force_addr module parameter. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Documentation/hwmon/via686a | 17 +++++++++++++++-- drivers/hwmon/via686a.c | 18 +++++++++++------- 2 files changed, 26 insertions(+), 9 deletions(-)
2005-10-28Merge ../bleed-2.6Greg KH
2005-10-28[PATCH] Fix documentation of driver suspend/resume callbacksTakashi Iwai
Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] DRIVER MODEL: Get rid of the obsolete tri-level suspend/resume callbacksRussell King
In PM v1, all devices were called at SUSPEND_DISABLE level. Then all devices were called at SUSPEND_SAVE_STATE level, and finally SUSPEND_POWER_DOWN level. However, with PM v2, to maintain compatibility for platform devices, I arranged for the PM v2 suspend/resume callbacks to call the old PM v1 suspend/resume callbacks three times with each level in order so that existing drivers continued to work. Since this is obsolete infrastructure which is no longer necessary, we can remove it. Here's an (untested) patch to do exactly that. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] Driver Core: Big kfree NULL check cleanup - DocumentationJesper Juhl
This is the Documentation/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in example code in Documentation/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] update required version of udevGreg Kroah-Hartman
The 071 release is needed to handle the input changes. Older versions will work properly with module-based systems, but not for users that build input stuff into the kernel. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] changes device to driver in porting.txtErik Hovland
The document porting.txt in Documentation/driver-model says: When a device is successfully bound to a device I think it should say: When a device is successfully bound to a driver Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28Merge branch 'upstream' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
2005-10-28[PATCH] 05/05 update biodoc to match new generic dispatch apiTejun Heo
Updates biodoc to reflect changes in elevator API Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2005-10-26Merge branch 'master'Jeff Garzik
2005-10-23[PATCH] kernel-parameters cleanupRandy Dunlap
Fix typos & trailing whitespace. Add blank lines in a few places. Remove "AM53C974=" option: driver does not exist. Restrict to < 80 columns in most places (but don't split formatted command-line arguments). Add a few option arguments for completeness. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-18[PATCH] bonding: fix typos in bonding documentationJohn W. Linville
Fix some simple typos in the bonding.txt file. The typos are in areas relating to loading the bonding driver multiple times. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-13Merge branch 'master'Jeff Garzik
2005-10-13[CONNECTOR]: Update documentation to match reality.Evgeniy Polyakov
Updated documentation to reflect 2.6.14 netlink changes about socket options, multicasting and group number. Please concider for 2.6.14. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-11[PATCH] dell_rbu: changes in packet update mechanismAbhay Salunke
In the current dell_rbu code ver 2.0 the packet update mechanism makes the user app dump every individual packet in to the driver. This adds in efficiency as every packet update makes the /sys/class/firmware/dell_rbu/loading and data files to disappear and reappear again. Thus the user app needs to wait for the files to reappear to dump another packet. This slows down the packet update tremendously in case of large number of packets. I am submitting a new patch for dell_rbu which will change the way we do packet updates; In the new method the user app will create a new single file which has already packetized the rbu image and all the packets are now staged in this file. This driver also creates a new entry in /sys/devices/platform/dell_rbu/packet_size ; the user needs to echo the packet size here before downloading the packet file. The user should do the following: create one single file which has all the packets stacked together. echo the packet size in to /sys/devices/platform/dell_rbu/packet_size. echo 1 > /sys/class/firmware/dell_rbu/loading cat the packetfile > /sys/class/firmware/dell_rbu/data echo 0 > /sys/class/firmware/dell_rbu/loading The driver takes the file which came through /sys/class/firmware/dell_rbu/data and takes chunks of paket_size data from it and place in contiguous memory. This makes packet update process very efficient and fast. As all the packet update happens in one single operation. The user can still read back the downloaded file from /sys/devices/platform/dell_rbu/data. Signed-off-by: Abhay Salunke <abhay_salunke@dell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-11Merge branch 'master'Jeff Garzik
2005-10-08[PATCH] Keys: Add request-key process documentationDavid Howells
The attached patch adds documentation for the process by which request-key works, including how it permits helper processes to gain access to the requestor's keyrings. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-08Merge branch 'master'Jeff Garzik
2005-10-03[PATCH] libata: add ATA exceptions chapter to docTejun Heo
Hello, Jeff. This patch adds ATA errors & exceptions chapter to Documentation/DocBook/libata.tmpl. As suggested, the chapter is placed before low level driver specific chapters. Contents are unchanged from the last posting. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-03Merge branch 'master'Jeff Garzik
2005-10-03[IPV4]: Update icmp sysctl docs and disable broadcast ECHO/TIMESTAMP by defaultDavid S. Miller
It's not a good idea to be smurf'able by default. The few people who need this can turn it on. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-03[PATCH] Document patch subject line betterPaul Jackson
Improve explanation of the Subject line fields in Documentation/SubmittingPatches Canonical Patch Format. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-02[PATCH] Document from line in patch formatPaul Jackson
Document more details of patch format such as the "from" line and the "---" marker line, and provide more references for patch guidelines. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-28libata: move EH docs to separate DocBook chapterJeff Garzik
2005-09-28[PATCH] libata EH document updateTejun Heo
2005-09-28[PATCH] Keys: Add possessor permissions to keys [try #3]David Howells
The attached patch adds extra permission grants to keys for the possessor of a key in addition to the owner, group and other permissions bits. This makes SUID binaries easier to support without going as far as labelling keys and key targets using the LSM facilities. This patch adds a second "pointer type" to key structures (struct key_ref *) that can have the bottom bit of the address set to indicate the possession of a key. This is propagated through searches from the keyring to the discovered key. It has been made a separate type so that the compiler can spot attempts to dereference a potentially incorrect pointer. The "possession" attribute can't be attached to a key structure directly as it's not an intrinsic property of a key. Pointers to keys have been replaced with struct key_ref *'s wherever possession information needs to be passed through. This does assume that the bottom bit of the pointer will always be zero on return from kmem_cache_alloc(). The key reference type has been made into a typedef so that at least it can be located in the sources, even though it's basically a pointer to an undefined type. I've also renamed the accessor functions to be more useful, and all reference variables should now end in "_ref". Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-28[PATCH] fuse: add required version infoMiklos Szeredi
Add information about required version of the userspace library/utilities to Documentation/Changes. Also add pointer to this and to FUSE documentation from Kconfig. Thanks to Anton Altaparmakov for the reminder. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-23[PATCH] documentation: sparse no longer uses bk, but gitHarald Welte
Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] Add dm-snapshot tutorial in DocumentationPaolo 'Blaisorblade' Giarrusso
I've recently discovered the real functionality of device-mapper snapshots, and since they are not well known, I've decided to write some docs for them. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] USB: Update Documentation/usb/URB.txtAlan Stern
This patch (as564) updates Documentation/usb/URB.txt, bringing it roughly up to the current level. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-21[PATCH] fixup Documentation/DocBook/kernel-hacking.tmplChristoph Hellwig
__FUNCTION__ is the prefered kernel idiom, __func__ is not supported by gcc 2.95 (we actually map __FUNCTION__ to __func__ for more recent compilers, but it should never be used directly) Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-17[PATCH] CodingStyle: memory allocationPekka J Enberg
This patch adds a new chapter on memory allocation to Documentation/CodingStyle. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-17[PATCH] dell_rbu: enhancements and fixesAbhay Salunke
BUG fixes: The driver used to allocate memory with spinlock held which has been fixed in this patch. The driver was printing the entire buffer when it received a invalid entry in image_type. The fix is to only print a warning message and not the buffer. Usability enhancements: It is possible that due to user error the /sys/class/firmware/dell_rbu entries might be missing, this can happen if the user does the following echo 1 > /sys/class/firmware/dell_rbu/loading echo 0 > /sys/class/firmware/dell_rbu/loading This will make the entries in /sys/class/firmware/ to disappear and the only way get them back was bby unloading and loading the driver. This patch makes the user recreate these entries by echoing init in to image_type. This patch has been tested with Libsmbios and Dell OpenManage. Signed-off-by: Abhay Salunke <Abhay_Salunke@dell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-17[PATCH] relayfs documentation typoMarcelo Tosatti
Small typo in relayfs documentation. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-16[IA64] Add Documentation/ia64/mca.txtKeith Owens
Add Documentation/ia64/mca.txt, an ad-hoc collection of notes on IA64 MCA and INIT processing. Signed-off-by: Keith Owens <kaos@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-09-13Merge master.kernel.org:/pub/scm/linux/kernel/git/perex/alsa-current Linus Torvalds
2005-09-13[PATCH] feature removal of io_remap_page_range()Randy Dunlap
As written in Documentation/feature-removal-schedule.txt, remove the io_remap_page_range() kernel API. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] More documentation, minor cleanup in kdump.txtVivek Goyal
Added clarification on the root device format to be used for second kernel, as well as specifying initrd if drivers are built as modules. Signed-off-by: Kishore Sampathkumar <kishore.sampathkumar@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] Tell people not to use pm_register()Pavel Machek
Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
