path: root/Documentation/power
2005-11-22[PATCH] kernel Doc/ URL correctionsRandy Dunlap
Correct lots of URLs in Documentation/ Also a few minor whitespace cleanups and typo/spello fixes. Sadly there are still a lot of bad URLs remaining. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] suspend-to-ram: update docsPavel Machek
This adds few more working systems. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] swsusp: update documentationPavel Machek
This updates documentation a bit (mostly removing obsolete stuff), and marks swsusp as no longer experimental in config. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] swsusup with dm-crypt mini howtoAndreas Steinmetz
The attached patch contains a mini howto for using dm-crypt together with swsusp. Signed-off-by: Andreas Steinmetz <ast@domdv.de> Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] suspend: update documentationPavel Machek
Update suspend documentation. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] video doc: one more system where video works with S3Pavel Machek
One more system where video works with S3. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25Merge Christoph's freeze cleanup patchLinus Torvalds
2005-06-25[PATCH] Cleanup patch for process freezingChristoph Lameter
1. Establish a simple API for process freezing defined in linux/include/sched.h: frozen(process) Check for frozen process freezing(process) Check if a process is being frozen freeze(process) Tell a process to freeze (go to refrigerator) thaw_process(process) Restart process frozen_process(process) Process is frozen now 2. Remove all references to PF_FREEZE and PF_FROZEN from all kernel sources except sched.h 3. Fix numerous locations where try_to_freeze is manually done by a driver 4. Remove the argument that is no longer necessary from two function calls. 5. Some whitespace cleanup 6. Clear potential race in refrigerator (provides an open window of PF_FREEZE cleared before setting PF_FROZEN, recalc_sigpending does not check PF_FROZEN). This patch does not address the problem of freeze_processes() violating the rule that a task may only modify its own flags by setting PF_FREEZE. This is not clean in an SMP environment. freeze(process) is therefore not SMP safe! Signed-off-by: Christoph Lameter <christoph@lameter.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] Update video-after-suspend documentationPavel Machek
Update video-after-suspend documentation; few more machines are added. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] suspend: PCI power managment reference implementationpavel@ucw.cz
Added reference implementation of suspend and resume routines. From: Shaohua Li <shaohua.li@intel.com> build fix Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] acpi: fix video docsPavel Machek
This fixes typos/formatting in video_extension.txt. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] swsusp: documentation updatesPavel Machek
This updates documentation and fixes pointers in MAINTAINERS file. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] Driver Core: remove driver model detach_stateDavid Brownell
The driver model has a "detach_state" mechanism that: - Has never been used by any in-kernel drive; - Is superfluous, since driver remove() methods can do the same thing; - Became buggy when the suspend() parameter changed semantics and type; - Could self-deadlock when called from certain suspend contexts; - Is effectively wasted documentation, object code, and headspace. This removes that "detach_state" mechanism; net code shrink, as well as a per-device saving in the driver model and sysfs. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-05-03[PATCH] PCI: fix stale PCI pm docsPavel Machek
This fixes u32 vs. pm_message_t confusion in documentation, and removes references to no-longer-existing (*save_state), too. With exception of USB (I hope David will fix/apply my patch), this should fix last piece of this confusion... famous last words. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-04-16[PATCH] power/video.txt: update documentation with more systemsPavel Machek
This updates video.txt documentation with information about few more systems. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
