path: root/Documentation/filesystems/sysfs-pci.txt
2005-05-17[PATCH] Driver Core: remove driver model detach_stateDavid Brownell
The driver model has a "detach_state" mechanism that: - Has never been used by any in-kernel drive; - Is superfluous, since driver remove() methods can do the same thing; - Became buggy when the suspend() parameter changed semantics and type; - Could self-deadlock when called from certain suspend contexts; - Is effectively wasted documentation, object code, and headspace. This removes that "detach_state" mechanism; net code shrink, as well as a per-device saving in the driver model and sysfs. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
