path: root/Documentation/filesystems/nfs
2012-03-21pnfs-obj: autologin: Add support for protocol autologinSachin Bhamare
The pnfs-objects protocol mandates that we autologin into devices not present in the system, according to information specified in the get_device_info returned from the server. The Protocol specifies two login hints. 1. An IP address:port combination 2. A string URI which is constructed as a URL with a protocol prefix followed by :// and a string as address. For each protocol prefix the string-address format might be different. We only support the second option. The first option is just redundant to the second one. NOTE: The Kernel part of autologin does not parse the URI string. It just channels it to a user-mode script. So any new login protocols should only update the user-mode script which is a part of the nfs-utils package, but the Kernel need not change. We implement the autologin by using the call_usermodehelper() API. (Thanks to Steve Dickson <steved@redhat.com> for pointing it out) So there is no running daemon needed, and/or special setup. We Add the osd_login_prog Kernel module parameters which defaults to: /sbin/osd_login Kernel try's to upcall the program specified in osd_login_prog. If the file is not found or the execution fails Kernel will disable any farther upcalls, by zeroing out osd_login_prog, Until Admin re-enables it by setting the osd_login_prog parameter to a proper program. Also add text about the osd_login program command line API to: Documentation/filesystems/nfs/pnfs.txt and documentation of the new osd_login_prog module parameter to: Documentation/kernel-parameters.txt TODO: Add timeout option in the case osd_login program gets stuck Signed-off-by: Sachin Bhamare <sbhamare@panasas.com> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-02-06NFS: Update idmapper documentationBryan Schumaker
Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-11-07NFSD: Added fault injection documentationBryan Schumaker
Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-09-27doc: fix broken referencesPaul Bolle
There are numerous broken references to Documentation files (in other Documentation files, in comments, etc.). These broken references are caused by typo's in the references, and by renames or removals of the Documentation files. Some broken references are simply odd. Fix these broken references, sometimes by dropping the irrelevant text they were part of. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-07-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: merge fchmod() and fchmodat() guts, kill ancient broken kludge xfs: fix misspelled S_IS...() xfs: get rid of open-coded S_ISREG(), etc. vfs: document locking requirements for d_move, __d_move and d_materialise_unique omfs: fix (mode & S_IFDIR) abuse btrfs: S_ISREG(mode) is not mode & S_IFREG... ima: fmode_t misspelled as mode_t... pci-label.c: size_t misspelled as mode_t jffs2: S_ISLNK(mode & S_IFMT) is pointless snd_msnd ->mode is fmode_t, not mode_t v9fs_iop_get_acl: get rid of unused variable vfs: dont chain pipe/anon/socket on superblock s_inodes list Documentation: Exporting: update description of d_splice_alias fs: add missing unlock in default_llseek()
2011-07-26Documentation: Exporting: update description of d_splice_aliasPhillip Lougher
Following commits a904937 and 0c1aa9a update the d_splice_alias desciption. Signed-off-by: Phillip Lougher <phillip@squashfs.org.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25Merge branch 'for-3.1' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-3.1' of git://linux-nfs.org/~bfields/linux: nfsd: don't break lease on CLAIM_DELEGATE_CUR locks: rename lock-manager ops nfsd4: update nfsv4.1 implementation notes nfsd: turn on reply cache for NFSv4 nfsd4: call nfsd4_release_compoundargs from pc_release nfsd41: Deny new lock before RECLAIM_COMPLETE done fs: locks: remove init_once nfsd41: check the size of request nfsd41: error out when client sets maxreq_sz or maxresp_sz too small nfsd4: fix file leak on open_downgrade nfsd4: remember to put RW access on stateid destruction NFSD: Added TEST_STATEID operation NFSD: added FREE_STATEID operation svcrpc: fix list-corrupting race on nfsd shutdown rpc: allow autoloading of gss mechanisms svcauth_unix.c: quiet sparse noise svcsock.c: include sunrpc.h to quiet sparse noise nfsd: Remove deprecated nfsctl system call and related code. NFSD: allow OP_DESTROY_CLIENTID to be only op in COMPOUND Fix up trivial conflicts in Documentation/feature-removal-schedule.txt
2011-07-18nfsd4: update nfsv4.1 implementation notesJ. Bruce Fields
Update documentation to reflect recent progress. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-06-13doc: fix wrong arch/i386 referencesWanlong Gao
Change all "arch/i386" to "arch/x86" in Documentaion/, since the directory has changed. Also update the files which have changed their filename in the meantime accordingly. Signed-off-by: Wanlong Gao <wanlong.gao@gmail.com> [jkosina@suse.cz: reword changelog] Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-19Create Documentation/security/,Randy Dunlap
move LSM-, credentials-, and keys-related files from Documentation/ to Documentation/security/, add Documentation/security/00-INDEX, and update all occurrences of Documentation/<moved_file> to Documentation/security/<moved_file>.
2011-03-11NFSv4.1: lseg documentationFred Isaman
Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-10-26NFS: rename nfs.upcall -> nfs.idmapBryan Schumaker
This patch renames the idmapper upcall program from nfs.upcall to nfs.idmap in the NFS documentation. This is because the program has been renamed in the nfs-utils source. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-10-24NFSv4.1: pnfs: full mount/umount infrastructureFred Isaman
Allow a module implementing a layout type to register, and have its mount/umount routines called for filesystems that the server declares support it. Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: Andy Adamson<andros@netapp.com> Signed-off-by: Bian Naimeng <biannm@cn.fujitsu.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-10-07NFS: new idmapperBryan Schumaker
This patch creates a new idmapper system that uses the request-key function to place a call into userspace to map user and group ids to names. The old idmapper was single threaded, which prevented more than one request from running at a single time. This means that a user would have to wait for an upcall to finish before accessing a cached result. The upcall result is stored on a keyring of type id_resolver. See the file Documentation/filesystems/nfs/idmapper.txt for instructions. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> [Trond: fix up the return value of nfs_idmap_lookup_name and clean up code] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-09-17NFS: Allow NFSROOT debugging messages to be enabled dynamicallyChuck Lever
As a convenience, introduce a kernel command line option to enable NFSROOT debugging messages. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-06-03ipconfig: document DHCP hostname and DNS recordWu Fengguang
Now it's possible to update the DNS record for $HOST_NAME with ip=::::$HOST_NAME::dhcp CC: Andi Kleen <ak@linux.intel.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (44 commits) vlynq: make whole Kconfig-menu dependant on architecture add descriptive comment for TIF_MEMDIE task flag declaration. EEPROM: max6875: Header file cleanup EEPROM: 93cx6: Header file cleanup EEPROM: Header file cleanup agp: use NULL instead of 0 when pointer is needed rtc-v3020: make bitfield unsigned PCI: make bitfield unsigned jbd2: use NULL instead of 0 when pointer is needed cciss: fix shadows sparse warning doc: inode uses a mutex instead of a semaphore. uml: i386: Avoid redefinition of NR_syscalls fix "seperate" typos in comments cocbalt_lcdfb: correct sections doc: Change urls for sparse Powerpc: wii: Fix typo in comment i2o: cleanup some exit paths Documentation/: it's -> its where appropriate UML: Fix compiler warning due to missing task_struct declaration UML: add kernel.h include to signal.c ...
2010-05-13nfsd4: implement reclaim_completeJ. Bruce Fields
This is a mandatory operation. Also, here (not in open) is where we should be committing the reboot recovery information. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2010-04-23Documentation/: it's -> its where appropriateFrancis Galiegue
Fix obvious cases of "it's" being used when "its" was meant. Signed-off-by: Francis Galiegue <fgaliegue@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-01-20nfsd: 4.1 has an rfc numberJ. Bruce Fields
No need to refer to an internet draft; there's an RFC now. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-11-06nfs: move more to Documentation/filesystems/nfsJ. Bruce Fields
Oops: I missed two files in the first commit that created this directory. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-10-27nfs: new subdir Documentation/filesystems/nfsJ. Bruce Fields
We're adding enough nfs documentation that it may as well have its own subdirectory. Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
