2008-03-24[NETNS]: Add namespace parameter to ip_cmsg_send.Denis V. Lunev
Pass the init_net there for now. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-24[NETNS]: Add namespace parameter to ip_options_get(...).Denis V. Lunev
2008-03-24[NETNS]: Add namespace parameter to ip_options_compile.Denis V. Lunev
ip_options_compile uses inet_addr_type which requires a namespace. The packet argument is optional, so parameter is the only way to obtain it. Pass the init_net there for now. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-24[NETNS]: /proc/net/arp namespacing.Denis V. Lunev
Seqfile operation showing /proc/net/arp are already namespace aware. All we need is to register this file for each namespace. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-24[NETNS]: Process ARP in the context of the correct namespace.Denis V. Lunev
Get namespace from a device and pass it to the routing engine. Enable ARP packet processing and device notifiers after that. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-24[NETNS]: Minor information leak via /proc/net/ptype file.Pavel Emelyanov
This file displays the registered packet types, but some of them (packet sockets creates such) can be bound to a net device and showing them in a wrong namespace is not correct. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-24[NETNS][UDP-Lite]: Register /proc/net/udplite(6) in a namespace.Pavel Emelyanov
UDP-Lite sockets are displayed in another files, rather than UDP ones, so make the present in namespaces as well. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-24[UDP-Lite]: Clean up proc creation a bit.Pavel Emelyanov
Just introduce a helper to remove ifdefs from inside the udplite4_register function. This will help to make the next patch nicer. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-24[NETNS][TCP]: Register /proc/net/tcp in a namespace.Pavel Emelyanov
After the commit f40c8174d3c21bf178283f3ef3aa8c7bf238fdec ([NETNS][IPV4] tcp - make proc handle the network namespaces) it is now possible to make this file present in newly created namespaces. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-24[NETNS][UDP]: Register /proc/net/udp in a namespace.Pavel Emelyanov
After the commit a91275eff43a527e1a25d6d034cbcd19ee323e64 ([NETNS][IPV6] udp - make proc handle the network namespace) it is now possible to make this file present in newly created namespaces. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-23Merge branch 'master' of ../net-2.6/David S. Miller
Conflicts: net/ipv6/ndisc.c
2008-03-23[CASSINI]: Use shorter list_splice_init() macro for brevity.Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-23[SCTP]: Remove redundant wrapper functions.Florian Westphal
sctp_datamsg_free and sctp_datamsg_track are just aliases for sctp_datamsg_put and sctp_chunk_hold, respectively. Saves 32 Bytes on x86. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-23[SCTP]: Replace char msg[] with static const char[].Florian Westphal
133886 2004 220 136110 213ae sctp.new/sctp.o 134018 2004 220 136242 21432 sctp.old/sctp.o Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-23fib_trie: print information on all routing tablesStephen Hemminger
Make /proc/net/fib_trie and /proc/net/fib_triestat display all routing tables, not just local and main. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-23[AF_PACKET]: Remove unused variable.Jiri Olsa
Signed-off-by: Jiri Olsa <olsajiri@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-23[TCP]: Shrink syncookie_secret by 8 byte.Florian Westphal
the first u32 copied from syncookie_secret is overwritten by the minute-counter four lines below. After adjusting the destination address, the size of syncookie_secret can be reduced accordingly. AFAICS, the only other user of syncookie_secret[] is the ipv6 syncookie support. Because ipv6 syncookies only grab 44 bytes from syncookie_secret[], this shouldn't affect them in any way. With fixes from Glenn Griffin. Signed-off-by: Florian Westphal <fw@strlen.de> Acked-by: Glenn Griffin <ggriffin.kernel@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-23[NET]: include/linux/udp.h - remove duplicate includeJoe Perches
Remove duplicate #include <linux/types.h> Combine #ifdef __KERNEL__ blocks Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-23[NET]: include/linux/igmp.h - remove duplicate includeJoe Perches
Removed duplicate #include <linux/skbuff.h> Combined #ifdef __KERNEL__ blocks Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-23[NET]: include/linux/atalk.h - remove duplicate includeJoe Perches
2008-03-23[NET]: include/net/route.h - remove duplicate includeJoe Perches
2008-03-23sch_htb: fix "too many events" situationMartin Devera
HTB is event driven algorithm and part of its work is to apply scheduled events at proper times. It tried to defend itself from livelock by processing only limited number of events per dequeue. Because of faster computers some users already hit this hardcoded limit. This patch limits processing up to 2 jiffies (why not 1 jiffie ? because it might stop prematurely when only fraction of jiffie remains). Signed-off-by: Martin Devera <devik@cdi.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-23[IPV6]: Remove unused code in ndisc_send_redirect().Rami Rosen
This patches removes unused code in ndisc_send_redirect() method in net/ipv6/ndisc.c. Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-23connector: convert to single-threaded workqueueEvgeniy Polyakov
From: Evgeniy Polyakov <johnpol@2ka.mipt.ru> We don't need one cqueue thread for each CPU. cqueue is used for receiving userspace datagrams, which are very rare and thus will happily live with a single queue. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-23[ATM]: When proc_create() fails, do some error handling work and return -ENOMEM.Wang Chen
Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-23[SUNGEM]: Fix NAPI assertion failure.David S. Miller
As reported by Johannes Berg: I started getting this warning with recent kernels: [ 773.908927] ------------[ cut here ]------------ [ 773.908954] Badness at net/core/dev.c:2204 ... If we loop more than once in gem_poll(), we'll use more than the real budget in our gem_rx() calls, thus eventually trigger the caller's assertions in net_rx_action(). Subtract "work_done" from "budget" for the second arg to gem_rx() to fix the bug. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-23BNX2X: prevent ethtool from setting port typeEliezer Tamir
On 10GBaseT boards setting the type to TP will cause the driver to try to configure 1GBaseT. Since there are currently no boards that support setting of the port type, disable this for now. Signed-off-by: Eliezer Tamir <eliezert@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-22[8390]: Fix build error.David S. Miller
module_init() function reference is wrong. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-22Merge branch 'upstream-net26' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 Conflicts: drivers/s390/net/qeth_main.c
2008-03-22[9P] net/9p/trans_fd.c: remove unused variableJulia Lawall
The variable cb is initialized but never used otherwise. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ type T; identifier i; constant C; @@ ( extern T i; | - T i; <+... when != i - i = C; ...+> ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-22[IPV6] net/ipv6/ndisc.c: remove unused variableJulia Lawall
The variable hlen is initialized but never used otherwise. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ type T; identifier i; constant C; @@ ( extern T i; | - T i; <+... when != i - i = C; ...+> ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-22[IPV4] fib_trie: fix warning from rcu_assign_poingerStephen Hemminger
This gets rid of a warning caused by the test in rcu_assign_pointer. I tried to fix rcu_assign_pointer, but that devolved into a long set of discussions about doing it right that came to no real solution. Since the test in rcu_assign_pointer for constant NULL would never succeed in fib_trie, just open code instead. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-22[IPV4] route: use read_mostlyStephen Hemminger
The route table parameters are set based on system memory and sysctl values that almost never change. Also the genid only changes every 10 minutes. RTprint is defined by never used. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-22[IPV4]: sk parameter is unused in ipv4_dst_blackhole.Denis V. Lunev
Just remove it. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-22[NET]: NPROTO is redundant; it's equal to AF_MAX/PF_MAX.Rusty Russell
DaveM pointed out NPROTO exposed to userspace, so keep it around, just make sure it stays in sync. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-22[RAW]: Add raw_hashinfo member on struct proto.Pavel Emelyanov
Sorry for the patch sequence confusion :| but I found that the similar thing can be done for raw sockets easily too late. Expand the proto.h union with the raw_hashinfo member and use it in raw_prot and rawv6_prot. This allows to drop the protocol specific versions of hash and unhash callbacks. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-22[UDP]: Make full use of proto.h.udp_hash innovation.Pavel Emelyanov
After this we have only udp_lib_get_port to get the port and two stubs for ipv4 and ipv6. No difference in udp and udplite except for initialized h.udp_hash member. I tried to find a graceful way to drop the only difference between udp_v4_get_port and udp_v6_get_port (i.e. the rcv_saddr comparison routine), but adding one more callback on the struct proto didn't appear such :( Maybe later. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-22[SOCK]: Add udp_hash member to struct proto.Pavel Emelyanov
Inspired by the commit ab1e0a13 ([SOCK] proto: Add hashinfo member to struct proto) from Arnaldo, I made similar thing for UDP/-Lite IPv4 and -v6 protocols. The result is not that exciting, but it removes some levels of indirection in udpxxx_get_port and saves some space in code and text. The first step is to union existing hashinfo and new udp_hash on the struct proto and give a name to this union, since future initialization of tcpxxx_prot, dccp_vx_protinfo and udpxxx_protinfo will cause gcc warning about inability to initialize anonymous member this way. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-22[IPV4]: Always pass ip_options pointer into ip_options_compile.Denis V. Lunev
This makes code a bit more uniform and straigthforward. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-22[IPV4]: Remove unused ip_options->is_data.Denis V. Lunev
ip_options->is_data is assigned only and never checked. The structure is not a part of kernel interface to the userspace. So, it is safe to remove this field. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-22[IPV4]: Remove unnecessary check for opt->is_data in ip_options_compile.Denis V. Lunev
There is the only way to reach ip_options compile with opt != NULL: ip_options_get_finish opt->is_data = 1; ip_options_compile(opt, NULL) So, checking for is_data inside opt != NULL branch is not needed. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-22[TCP]: Let skbs grow over a page on fast peersHerbert Xu
While testing the virtio-net driver on KVM with TSO I noticed that TSO performance with a 1500 MTU is significantly worse compared to the performance of non-TSO with a 16436 MTU. The packet dump shows that most of the packets sent are smaller than a page. Looking at the code this actually is quite obvious as it always stop extending the packet if it's the first packet yet to be sent and if it's larger than the MSS. Since each extension is bound by the page size, this means that (given a 1500 MTU) we're very unlikely to construct packets greater than a page, provided that the receiver and the path is fast enough so that packets can always be sent immediately. The fix is also quite obvious. The push calls inside the loop is just an optimisation so that we don't end up doing all the sending at the end of the loop. Therefore there is no specific reason why it has to do so at MSS boundaries. For TSO, the most natural extension of this optimisation is to do the pushing once the skb exceeds the TSO size goal. This is what the patch does and testing with KVM shows that the TSO performance with a 1500 MTU easily surpasses that of a 16436 MTU and indeed the packet sizes sent are generally larger than 16436. I don't see any obvious downsides for slower peers or connections, but it would be prudent to test this extensively to ensure that those cases don't regress. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-21[TCP]: TCP_DEFER_ACCEPT updates - process as establishedPatrick McManus
Change TCP_DEFER_ACCEPT implementation so that it transitions a connection to ESTABLISHED after handshake is complete instead of leaving it in SYN-RECV until some data arrvies. Place connection in accept queue when first data packet arrives from slow path. Benefits: - established connection is now reset if it never makes it to the accept queue - diagnostic state of established matches with the packet traces showing completed handshake - TCP_DEFER_ACCEPT timeouts are expressed in seconds and can now be enforced with reasonable accuracy instead of rounding up to next exponential back-off of syn-ack retry. Signed-off-by: Patrick McManus <mcmanus@ducksong.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-21[TCP]: TCP_DEFER_ACCEPT updates - dont retxmt synackPatrick McManus
a socket in LISTEN that had completed its 3 way handshake, but not notified userspace because of SO_DEFER_ACCEPT, would retransmit the already acked syn-ack during the time it was waiting for the first data byte from the peer. Signed-off-by: Patrick McManus <mcmanus@ducksong.com> Acked-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-21[TCP]: TCP_DEFER_ACCEPT updates - defer timeout conflicts with max_threshPatrick McManus
timeout associated with SO_DEFER_ACCEPT wasn't being honored if it was less than the timeout allowed by the maximum syn-recv queue size algorithm. Fix by using the SO_DEFER_ACCEPT value if the ack has arrived. Signed-off-by: Patrick McManus <mcmanus@ducksong.com> Acked-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-21[DLCI]: Fix tiny race between module unload and sock_ioctl.Pavel Emelyanov
This is a narrow pedantry :) but the dlci_ioctl_hook check and call should not be parted with the mutex lock. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-21socket: SOCK_DEBUG type checkingStephen Hemminger
Use the inline trick (same as pr_debug) to get checking of debug statements even if no code is generated. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-21[NET]: NULL pointer dereference and other nasty things in /proc/net/(tcp|udp)[6]Pavel Emelyanov
Commits f40c81 ([NETNS][IPV4] tcp - make proc handle the network namespaces) and a91275 ([NETNS][IPV6] udp - make proc handle the network namespace) both introduced bad checks on sockets and tw buckets to belong to proper net namespace. I.e. when checking for socket to belong to given net and family the do { sk = sk_next(sk); } while (sk && sk->sk_net != net && sk->sk_family != family); constructions were used. This is wrong, since as soon as the sk->sk_net fits the net the socket is immediately returned, even if it belongs to other family. As the result four /proc/net/(udp|tcp)[6] entries show wrong info. The udp6 entry even oopses when dereferencing inet6_sk(sk) pointer: static void udp6_sock_seq_show(struct seq_file *seq, struct sock *sp, int bucket) { ... struct ipv6_pinfo *np = inet6_sk(sp); ... dest = &np->daddr; /* will be NULL for AF_INET sockets */ ... seq_printf(... dest->s6_addr32[0], dest->s6_addr32[1], dest->s6_addr32[2], dest->s6_addr32[3], ... Fix it by converting && to ||. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-21netlink: make socket filters work on netlinkStephen Hemminger
Make socket filters work for netlink unicast and notifications. This is useful for applications like Zebra that get overrun with messages that are then ignored. Note: netlink messages are in host byte order, but packet filter state machine operations are done as network byte order. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-21[SCTP]: Fix build warnings with IPV6 disabled.David S. Miller
Introduced by 270637abff0cdf848b910b9f96ad342e1da61c66 ("[SCTP]: Fix a race between module load and protosw access") Reported by Gabriel C: In file included from net/sctp/sm_statetable.c:50: include/net/sctp/sctp.h: In function 'sctp_v6_pf_init': include/net/sctp/sctp.h:392: warning: 'return' with a value, in function returning void In file included from net/sctp/sm_statefuns.c:62: include/net/sctp/sctp.h: In function 'sctp_v6_pf_init': include/net/sctp/sctp.h:392: warning: 'return' with a value, in function returning void ... Signed-off-by: David S. Miller <davem@davemloft.net>
