Cc: Davidlohr Bueso <davidlohr@hp.com>
Cc: Karel Zak <kzak@redhat.com>
Cc: Matt Fleming <matt.fleming@intel.com>
Trivial coding style cleanups - still plenty left.
Signed-off-by: Davidlohr Bueso <davidlohr@hp.com>
Reviewed-by: Karel Zak <kzak@redhat.com>
Acked-by: Matt Fleming <matt.fleming@intel.com>
I love emacs, but these settings for coding style are annoying when trying
to open the efi.h file. More important, we already have checkpatch for
that.
When verifying GPT header integrity, make sure that first usable LBA is
smaller than last usable LBA.
The partition that has the 0xEE (GPT protective), must have the size in
lba field set to the lesser of the size of the disk minus one or
0xFFFFFFFF for larger disks.
One of the biggest problems with GPT is compatibility with older, non-GPT
systems. The problem is addressed by creating hybrid mbrs, an extension,
or variant, of the traditional protective mbr. This contains, apart from
the 0xEE partition, up three additional primary partitions that point to
the same space marked by up to three GPT partitions. The result is that
legacy OSs can see the three required MBR partitions and at the same time
ignore the GPT-aware partitions that protect the GPT structures.
While hybrid MBRs are hacks, workarounds and simply not part of the GPT
standard, they do exist and we have no way around them. For instance, by
default, OSX creates a hybrid scheme when using multi-OS booting.
In order for Linux to properly discover protective MBRs, it must be made
aware of devices that have hybrid MBRs. No functionality is changed by
this patch, just a debug message informing the user of the MBR scheme that
is being used.
When detecting a valid protective MBR, the Linux kernel isn't picky about
the partition (1-4) the 0xEE is at, but, unlike other operating systems,
it does require it to begin at the second sector (sector 1). This check,
apart from it not being enforced by UEFI, and causing Linux to potentially
fail to detect any *valid* partitions on the disk, can present problems
when dealing with hybrid MBRs[1].
For compatibility reasons, if the first partition is hybridized, the 0xEE
partition must be small enough to ensure that it only protects the GPT
data structures - as opposed to the the whole disk in a protective MBR.
This problem is very well described by Rod Smith[1]: where MBR-only
partitioning programs (such as older versions of fdisk) can see some of
the disk space as unallocated, thus loosing the purpose of the 0xEE
partition's protection of GPT data structures.
By dropping this check, this patch enables Linux to be more flexible when
probing for GPT disklabels.
[1] http://www.rodsbooks.com/gdisk/hybrid.html#reactions
Per the UEFI Specs 2.4, June 2013, the starting lba of the partition that
has the EFI GPT (0xEE) must be set to 0x00000001 - this is obviously the
LBA of the GPT Partition Header.
The kernel's GPT implementation currently uses the generic 'struct
partition' type for dealing with legacy MBR partition records. While this
is is useful for disklabels that we designed for CHS addressing, such as
msdos, it doesn't adapt well to newer standards that use LBA instead, such
as GUID partition tables. Furthermore, these generic partition structures
do not have all the required fields to properly follow the UEFI specs.
While a CHS address can be translated to LBA, it's much simpler and
cleaner to just replace the partition type. This patch adds a new
'gpt_record' type that is fully compliant with EFI and will allow, in the
next patches, to add more checks to properly verify a protective MBR,
which is paramount to probing a device that makes use of GPT.
Modify the s390 copy_oldmem_page() and remap_oldmem_pfn_range() function
for zfcpdump to read from the HSA memory if memory below HSA_SIZE bytes is
requested. Otherwise real memory is used.
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Cc: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com>
Cc: Jan Willeke <willeke@de.ibm.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
The patch "s390/vmcore: Implement remap_oldmem_pfn_range for s390" allows
now to use mmap also on s390.
So enable mmap for s390 again.
Introduce the s390 specific way to map pages from oldmem. The memory area
below OLDMEM_SIZE is mapped with offset OLDMEM_BASE. The other old memory
is mapped directly.
Signed-off-by: Jan Willeke <willeke@de.ibm.com>
For zfcpdump we can't map the HSA storage because it is only available via
a read interface. Therefore, for the new vmcore mmap feature we have
introduce a new mechanism to create mappings on demand.
This patch introduces a new architecture function remap_oldmem_pfn_range()
that should be used to create mappings with remap_pfn_range() for oldmem
areas that can be directly mapped. For zfcpdump this is everything
besides of the HSA memory. For the areas that are not mapped by
remap_oldmem_pfn_range() a generic vmcore a new generic vmcore fault
handler mmap_vmcore_fault() is called.
This handler works as follows:
* Get already available or new page from page cache (find_or_create_page)
* Check if /proc/vmcore page is filled with data (PageUptodate)
* If yes:
Return that page
* If no:
Fill page using __vmcore_read(), set PageUptodate, and return page
Acked-by: Vivek Goyal <vgoyal@redhat.com>
Exchange the old relocate mechanism with the new arch function call
override mechanism that allows to create the ELF core header in the 2nd
kernel.
For s390 we want to use /proc/vmcore for our SCSI stand-alone dump
(zfcpdump). We have support where the first HSA_SIZE bytes are saved into
a hypervisor owned memory area (HSA) before the kdump kernel is booted.
When the kdump kernel starts, it is restricted to use only HSA_SIZE bytes.
The advantages of this mechanism are:
* No crashkernel memory has to be defined in the old kernel.
* Early boot problems (before kexec_load has been done) can be dumped
* Non-Linux systems can be dumped.
We modify the s390 copy_oldmem_page() function to read from the HSA memory
if memory below HSA_SIZE bytes is requested.
Since we cannot use the kexec tool to load the kernel in this scenario,
we have to build the ELF header in the 2nd (kdump/new) kernel.
So with the following patch set we would like to introduce the new
function that the ELF header for /proc/vmcore can be created in the 2nd
kernel memory.
The following steps are done during zfcpdump execution:
1. Production system crashes
2. User boots a SCSI disk that has been prepared with the zfcpdump tool
3. Hypervisor saves CPU state of boot CPU and HSA_SIZE bytes of memory into HSA
4. Boot loader loads kernel into low memory area
5. Kernel boots and uses only HSA_SIZE bytes of memory
6. Kernel saves registers of non-boot CPUs
7. Kernel does memory detection for dump memory map
8. Kernel creates ELF header for /proc/vmcore
9. /proc/vmcore uses this header for initialization
10. The zfcpdump user space reads /proc/vmcore to write dump to SCSI disk
- copy_oldmem_page() copies from HSA for memory below HSA_SIZE
- copy_oldmem_page() copies from real memory for memory above HSA_SIZE
Currently for s390 we create the ELF core header in the 2nd kernel with a
small trick. We relocate the addresses in the ELF header in a way that
for the /proc/vmcore code it seems to be in the 1st kernel (old) memory
and the read_from_oldmem() returns the correct data. This allows the
/proc/vmcore code to use the ELF header in the 2nd kernel.
This patch:
Exchange the old mechanism with the new and much cleaner function call
override feature that now offcially allows to create the ELF core header
in the 2nd kernel.
To use the new feature the following function have to be defined
by the architecture backend code to read from new memory:
* elfcorehdr_alloc: Allocate ELF header
* elfcorehdr_free: Free the memory of the ELF header
* elfcorehdr_read: Read from ELF header
* elfcorehdr_read_notes: Read from ELF notes
Code can not run here forever, so remove the unnecessary return.
Signed-off-by: Xishi Qiu <qiuxishi@huawei.com>
Suggested-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Reviewed-by: Simon Horman <horms@verge.net.au>
Reviewed-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
The error hanling and ret-from-loop look confusing and inconsistent.
- "retval >= 0" simply returns
- "!bprm->file" returns too but with read_unlock() because
binfmt_lock was already re-acquired
- "retval != -ENOEXEC || bprm->mm == NULL" does "break" and
relies on the same check after the main loop
Consolidate these checks into a single if/return statement.
need_retry still checks "retval == -ENOEXEC", but this and -ENOENT before
the main loop are not needed. This is only for pathological and
impossible list_empty(&formats) case.
It is not clear why do we check "bprm->mm == NULL", probably this
should be removed.
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Cc: Evgeniy Polyakov <zbr@ioremap.net>
Cc: Zach Levis <zml@linux.vnet.ibm.com>
A separate one-liner for better documentation.
It doesn't make sense to retry if request_module() fails to exec
/sbin/modprobe, add the additional "request_module() < 0" check.
However, this logic still doesn't look exactly right:
1. It would be better to check "request_module() != 0", the user
space modprobe process should report the correct exit code.
But I didn't dare to add the user-visible change.
2. The whole ENOEXEC logic looks suboptimal. Suppose that we try
to exec a "#!path-to-unsupported-binary" script. In this case
request_module() + "retry" will be done twice: first by the
"depth == 1" code, and then again by the "depth == 0" caller
which doesn't make sense.
3. And note that in the case above bprm->buf was already changed
by load_script()->prepare_binprm(), so this looks even more
ugly.
search_binary_handler() uses "for (try=0; try<2; try++)" to avoid "goto"
but the code looks too complicated and horrible imho. We still need to
check "try == 0" before request_module() and add the additional "break"
for !CONFIG_MODULES case.
Kill this loop and use a simple "bool need_retry" + "goto retry". The
code looks much simpler and we do not even need ifdef's, gcc can optimize
out the "if (need_retry)" block if !IS_ENABLED().
search_binary_handler() checks ->load_binary != NULL for no reason, this
method should be always defined. Turn this check into WARN_ON() and move
it into __register_binfmt().
Also, kill the function pointer. The current code looks confusing, as if
->load_binary can go away after read_unlock(&binfmt_lock). But we rely on
module_get(fmt->module), this fmt can't be changed or unregistered,
otherwise this code is buggy anyway.
When search_binary_handler() succeeds it does allow_write_access() and
fput(), then it clears bprm->file to ensure the caller will not do the
same.
We can simply move this code to exec_binprm() which is called only once.
In fact we could move this to free_bprm() and remove the same code in
do_execve_common's error path.
A separate one-liner with the minor fix.
PROC_EVENT_EXEC reports the "exec" event, but this message is sent at
least twice if search_binary_handler() is called by ->load_binary()
recursively, say, load_script().
Move it to exec_binprm(), this is "depth == 0" code too.
Nobody except search_binary_handler() should touch ->recursion_depth, "int
depth" buys nothing but complicates the code, kill it.
Probably we should also kill "fn" and the !NULL check, ->load_binary
should be always defined. And it can not go away after read_unlock() or
task_pid_nr_ns() and trace/ptrace code in the middle of the recursive
search_binary_handler() looks confusing and imho annoying. We only need
this code if "depth == 0", lets add a simple helper which calls
search_binary_handler() and does trace_sched_process_exec() +
ptrace_event().
The patch also moves the setting of task->did_exec, we need to do this
only once.
Note: we can kill either task->did_exec or PF_FORKNOEXEC.
proc_fd_permission() says "process can still access /proc/self/fd after it
has executed a setuid()", but the "task_pid() = proc_pid() check only
helps if the task is group leader, /proc/self points to
/proc/<leader-pid>.
Change this check to use task_tgid() so that the whole thread group can
access its /proc/self/fd or /proc/<tid-of-sub-thread>/fd.
Notes:
- CLONE_THREAD does not require CLONE_FILES so task->files
can differ, but I don't think this can lead to any security
problem. And this matches same_thread_group() in
__ptrace_may_access().
- /proc/self should probably point to /proc/<thread-tid>, but
it is too late to change the rules. Perhaps it makes sense
to add /proc/thread though.
Test-case:
void *tfunc(void *arg)
assert(opendir("/proc/self/fd"));
return NULL;
int main(void)
pthread_t t;
pthread_create(&t, NULL, tfunc, NULL);
pthread_join(t, NULL);
return 0;
fails if, say, this executable is not readable and suid_dumpable = 0.
mpol_to_str() may fail, and not fill the buffer (e.g. -EINVAL), so need
check about it, or buffer may not be zero based, and next seq_printf()
will cause issue.
The failure return need after mpol_cond_put() to match get_vma_policy().
Signed-off-by: Chen Gang <gang.chen@asianux.com>
Cc: Cyrill Gorcunov <gorcunov@gmail.com>
Committed_AS
Fix mistake in the description of Committed_AS in kernel documentation.
Signed-off-by: Minto Joseph <mvaliyav@redhat.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Andrey Vagin <avagin@openvz.org>
Add a new %P variable to be used in core_pattern. This variable contains
the global PID (PID in the init namespace) as %p contains the PID in the
current namespace which isn't always what we want.
The main use for this is to make it easier to handle crashes that happened
within a container. With that new variables it's possible to have the
crashes dumped into the container or forwarded to the host with the right
PID (from the host's point of view).
Signed-off-by: Stéphane Graber <stgraber@ubuntu.com>
Reported-by: Hans Feldt <hans.feldt@ericsson.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Andy Whitcroft <apw@canonical.com>
Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com>
__ptrace_may_access() checks get_dumpable/ptrace_has_cap/etc if task !=
current, this can can lead to surprising results.
For example, a sub-thread can't readlink("/proc/self/exe") if the
executable is not readable. setup_new_exec()->would_dump() notices that
inode_permission(MAY_READ) fails and then it does
set_dumpable(suid_dumpable). After that get_dumpable() fails.
(It is not clear why proc_pid_readlink() checks get_dumpable(), perhaps we
could add PTRACE_MODE_NODUMPABLE)
Change __ptrace_may_access() to use same_thread_group() instead of "task
== current". Any security check is pointless when the tasks share the
same ->mm.
Signed-off-by: Mark Grondona <mgrondona@llnl.gov>
Signed-off-by: Ben Woodard <woodard@redhat.com>
Integrate implemented POSIX ACLs support into hfsplus driver.
Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Cc: Hin-Tak Leung <htl10@users.sourceforge.net>
Implement POSIX ACLs support in hfsplus driver.
This patchset implements POSIX ACLs support in hfsplus driver.
Mac OS X beginning with version 10.4 ("Tiger") support NFSv4 ACLs, which
are part of the NFSv4 standard. HFS+ stores ACLs in the form of
specially named extended attributes (com.apple.system.Security).
But this patchset doesn't use "com.apple.system.Security" extended
attributes. It implements support of POSIX ACLs in the form of extended
attributes with names "system.posix_acl_access" and
"system.posix_acl_default". These xattrs are treated only under Linux.
POSIX ACLs doesn't mean something under Mac OS X. Thereby, this patch
set provides opportunity to use POSIX ACLs under Linux on HFS+
filesystem.
This patch:
Add CONFIG_HFSPLUS_FS_POSIX_ACL kernel configuration option, DBG_ACL_MOD
debugging flag and acl.h file with declaration of essential functions
for support POSIX ACLs in hfsplus driver.
Convert the composition of devm_request_mem_region and devm_ioremap to a
single call to devm_ioremap_resource. The associated call to
platform_get_resource is also simplified and moved next to the new call
This was done using a combination of the semantic patches
devm_ioremap_resource.cocci and devm_request_and_ioremap.cocci, found in
the scripts/coccinelle/api directory.
In rtc-lpc32xx.c and rtc-mv.c, the local variable size is no longer needed.
In rtc-ds1511.c the size field of the local structure is not useful any
more, and is deleted.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Let RTC core decide if the retrieved time is invalid, instead of
processing errors in the driver.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
Cc: Jingoo Han <jg1.han@samsung.com>
Private field "rtc" is not used outside "probe", so there is no reason to
keep it.
Replace devm_request_mem_region() and devm_ioremap() with
devm_ioremap_resource().
enable_irq_wake() might fail, if so, we will see kernel warning in resume
entries due to it always calls disable_irq_wake().
WARNING: at kernel/irq/manage.c:529 irq_set_irq_wake+0xc4/0xf0()
Unbalanced IRQ 52 wake disable
Modules linked in: ipv6 libcomposite configfs
CPU: 0 PID: 1591 Comm: ash Tainted: G W 3.10.0-00854-gdbd86d4-dirty #100
(unwind_backtrace+0x0/0xf8) from (show_stack+0x10/0x14)
(show_stack+0x10/0x14) from (warn_slowpath_common+0x54/0x68)
(warn_slowpath_common+0x54/0x68) from (warn_slowpath_fmt+0x30/0x40)
(warn_slowpath_fmt+0x30/0x40) from (irq_set_irq_wake+0xc4/0xf0)
(irq_set_irq_wake+0xc4/0xf0) from (sirfsoc_rtc_restore+0x30/0x38)
(sirfsoc_rtc_restore+0x30/0x38) from (platform_pm_restore+0x2c/0x50)
(platform_pm_restore+0x2c/0x50) from (dpm_run_callback.clone.6+0x30/0xb0)
(dpm_run_callback.clone.6+0x30/0xb0) from (device_resume+0x88/0x134)
(device_resume+0x88/0x134) from (dpm_resume+0x114/0x230)
(dpm_resume+0x114/0x230) from (hibernation_snapshot+0x178/0x1d0)
(hibernation_snapshot+0x178/0x1d0) from (hibernate+0x130/0x1dc)
(hibernate+0x130/0x1dc) from (state_store+0xb4/0xc0)
(state_store+0xb4/0xc0) from (kobj_attr_store+0x14/0x20)
(kobj_attr_store+0x14/0x20) from (sysfs_write_file+0xfc/0x17c)
(sysfs_write_file+0xfc/0x17c) from (vfs_write+0xc8/0x194)
(vfs_write+0xc8/0x194) from (SyS_write+0x40/0x6c)
(SyS_write+0x40/0x6c) from (ret_fast_syscall+0x0/0x30)
To avoid unbalanced "IRQ wake disable", ensure that disable_irq_wake() is
called only when enable_irq_wake() have been successfully enabled.
Signed-off-by: Xianglong Du <Xianglong.Du@csr.com>
Signed-off-by: Barry Song <Baohua.Song@csr.com>
check_rtc_access_enable() returns pointer, thus NULL should be used
instead of 0 in order to fix the following sparse warning:
drivers/rtc/rtc-nuc900.c:102:16: warning: Using plain integer as NULL pointer
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Fix a read of the wrong register when checking whether the RTC timer has
reached the alarm time.
Signed-off-by: Sangjung Woo <sangjung.woo@samsung.com>
Signed-off-by: Myugnjoo Ham <myungjoo.ham@samsung.com>
Reviewed-by: Jonghwa Lee <jonghwa3.lee@samsung.com>
fails
Stop processing hid input when registering the RTC fails and handle a NULL
returned from devm_rtc_device_register() as a failure too.
Signed-off-by: Alexander Holler <holler@ahsoftware.de>
Palmas series device like TPS65913, TPS80036 supports the backup battery
for powering the RTC when no other energy source is available.
The backup battery is optional, connected to the VBACKUP pin, and can be
nonrechargeable or rechargeable. The rechargeable battery can be charged
from the system supply using the backup battery charger.
Add support for enabling charging of this backup battery. Also add the DT
binding document and the new properties to have this support.
Reviewed-by: Felipe Balbi <balbi@ti.com>
Acked-by: Kumar Gala <galak@codeaurora.org>
On some platforms (like AM33xx), a special register (RTC_IRQWAKEEN) is
available to enable Alarm Wakeup feature. This register needs to be
properly handled for the rtcwake to work properly.
Platforms using such IP should set "ti,am3352-rtc" in rtc device dt
compatibility node.
Signed-off-by: Hebbar Gururaja <gururaja.hebbar@ti.com>
Acked-by: Kevin Hilman <khilman@linaro.org>
Acked-by: Sekhar Nori <nsekhar@ti.com>
Cc: Grant Likely <grant.likely@linaro.org>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Rob Landley <rob@landley.net>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Add RTC driver for MOXA ART SoCs.
Signed-off-by: Jonas Jensen <jonas.jensen@gmail.com>
Reviewed-by: Mark Brown <broonie@linaro.org>
The 'remove' function is empty and does not do anything. Delete it.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
automatically
In order to get the module automatically loaded by hotplug mechanisms a
MODULE_DEVICE_TABLE is needed.
Therefore add one.
This makes it also possible to use a module name other than
HID-SENSOR-2000a0 which isn't very descriptive in kernel messages.
With the general-instruction extension facility (z10) a couple of
instructions with a pc-relative long displacement were introduced. The
kprobes support for these instructions however was never implemented.
In result, if anybody ever put a probe on any of these instructions the
result would have been random behaviour after the instruction got executed
within the insn slot.
So lets add the missing handling for these instructions. Since all of the
new instructions have 32 bit signed displacement the easiest solution is
to allocate an insn slot that is within the same 2GB area like the
original instruction and patch the displacement field.
Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
The current two insn slot caches both use module_alloc/module_free to
allocate and free insn slot cache pages.
For s390 this is not sufficient since there is the need to allocate insn
slots that are either within the vmalloc module area or within dma memory.
Therefore add a mechanism which allows to specify an own allocator for an
own insn slot cache.
Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
The current kpropes insn caches allocate memory areas for insn slots
with module_alloc(). The assumption is that the kernel image and module
area are both within the same +/- 2GB memory area.
This however is not true for s390 where the kernel image resides within
the first 2GB (DMA memory area), but the module area is far away in the
vmalloc area, usually somewhere close below the 4TB area.
For new pc relative instructions s390 needs insn slots that are within
+/- 2GB of each area. That way we can patch displacements of
pc-relative instructions within the insn slots just like x86 and
powerpc.
The module area works already with the normal insn slot allocator,
however there is currently no way to get insn slots that are within the
first 2GB on s390 (aka DMA area).
Therefore this patch set modifies the kprobes insn slot cache code in
order to allow to specify a custom allocator for the insn slot cache
pages. In addition architecure can now have private insn slot caches
withhout the need to modify common code.
Patch 1 unifies and simplifies the current insn and optinsn caches
implementation. This is a preparation which allows to add more
insn caches in a simple way.
Patch 2 adds the possibility to specify a custom allocator.
Patch 3 makes s390 use the new insn slot mechanisms and adds support for
pc-relative instructions with long displacements.
This patch (of 3):
The two insn caches (insn, and optinsn) each have an own mutex and
alloc/free functions (get_[opt]insn_slot() / free_[opt]insn_slot()).
Since there is the need for yet another insn cache which satifies dma
allocations on s390, unify and simplify the current implementation:
- Move the per insn cache mutex into struct kprobe_insn_cache.
- Move the alloc/free functions to kprobe.h so they are simply
wrappers for the generic __get_insn_slot/__free_insn_slot functions.
The implementation is done with a DEFINE_INSN_CACHE_OPS() macro
which provides the alloc/free functions for each cache if needed.
- move the struct kprobe_insn_cache to kprobe.h which allows to generate
architecture specific insn slot caches outside of the core kprobes
code.
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
As reported by Joe Perches: OOM messages generally aren't useful.
dmi_alloc is either a trivial front-end to kzalloc, and kzalloc already
does a dump_stack() when OOM, or for x86, dmi_alloc uses extend_brk
which BUGs when unsuccessful.
So we can remove all 6 such log messages in the dmi_scan driver, to
shrink the binary size (by 528 bytes on x86_64.)
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Reported-by: Joe Perches <joe@perches.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
