2014-01-23fs/proc: don't use module_init for non-modular core codePaul Gortmaker
PROC_FS is a bool, so this code is either present or absent. It will never be modular, so using module_init as an alias for __initcall is rather misleading. Fix this up now, so that we can relocate module_init from init.h into module.h in the future. If we don't do this, we'd have to add module.h to obviously non-modular code, and that would be ugly at best. Note that direct use of __initcall is discouraged, vs. one of the priority categorized subgroups. As __initcall gets mapped onto device_initcall, our use of fs_initcall (which makes sense for fs code) will thus change these registrations from level 6-device to level 5-fs (i.e. slightly earlier). However no observable impact of that small difference has been observed during testing, or is expected. Also note that this change uncovers a missing semicolon bug in the registration of vmcore_init as an initcall. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23fs/proc_namespace.c: simplify testing nsp and nsp->mnt_nsAxel Lin
Trivial cleanup to eliminate a goto. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23fs/proc/proc_devtree.c: remove empty /proc/device-tree when no openfirmware ↵Dave Jones
exists. Distribution kernels might want to build in support for /proc/device-tree for kernels that might end up running on hardware that doesn't support openfirmware. This results in an empty /proc/device-tree existing. Remove it if the OFW root node doesn't exist. This situation actually confuses grub2, resulting in install failures. grub2 sees the /proc/device-tree and picks the wrong install target cf. http://bzr.savannah.gnu.org/lh/grub/trunk/grub/annotate/4300/util/grub-install.in#L311 grub should be more robust, but still, leaving an empty proc dir seems pointless. Addresses https://bugzilla.redhat.com/show_bug.cgi?id=818378. Signed-off-by: Dave Jones <davej@redhat.com> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Paul Mackerras <paulus@samba.org> Cc: Josh Boyer <jwboyer@fedoraproject.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23proc: set attributes of pde using accessor functionsRui Xiang
Use existing accessors proc_set_user() and proc_set_size() to set attributes. Just a cleanup. Signed-off-by: Rui Xiang <rui.xiang@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23proc: fix ->f_pos overflows in first_tid()Oleg Nesterov
1. proc_task_readdir()->first_tid() path truncates f_pos to int, this is wrong even on 64bit. We could check that f_pos < PID_MAX or even INT_MAX in proc_task_readdir(), but this patch simply checks the potential overflow in first_tid(), this check is nop on 64bit. We do not care if it was negative and the new unsigned value is huge, all we need to ensure is that we never wrongly return !NULL. 2. Remove the 2nd "nr != 0" check before get_nr_threads(), nr_threads == 0 is not distinguishable from !pid_task() above. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Sameer Nanda <snanda@chromium.org> Cc: Sergey Dyasly <dserrg@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23proc: don't (ab)use ->group_leader in proc_task_readdir() pathsOleg Nesterov
proc_task_readdir() does not really need "leader", first_tid() has to revalidate it anyway. Just pass proc_pid(inode) to first_tid() instead, it can do pid_task(PIDTYPE_PID) itself and read ->group_leader only if necessary. The patch also extracts the "inode is dead" code from pid_delete_dentry(dentry) into the new trivial helper, proc_inode_is_dead(inode), proc_task_readdir() uses it to return -ENOENT if this dir was removed. This is a bit racy, but the race is very inlikely and the getdents() after openndir() can see the empty "." + ".." dir only once. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Sameer Nanda <snanda@chromium.org> Cc: Sergey Dyasly <dserrg@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23proc: change first_tid() to use while_each_thread() rather than next_thread()Oleg Nesterov
Rerwrite the main loop to use while_each_thread() instead of next_thread(). We are going to fix or replace while_each_thread(), next_thread() should be avoided whenever possible. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Sameer Nanda <snanda@chromium.org> Cc: Sergey Dyasly <dserrg@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23proc: fix the potential use-after-free in first_tid()Oleg Nesterov
proc_task_readdir() verifies that the result of get_proc_task() is pid_alive() and thus its ->group_leader is fine too. However this is not necessarily true after rcu_read_unlock(), we need to recheck this again after first_tid() does rcu_read_lock(). Otherwise leader->thread_group.next (used by next_thread()) can be invalid if the rcu grace period expires in between. The race is subtle and unlikely, but still it is possible afaics. To simplify lets ignore the "likely" case when tid != 0, f_version can be cleared by proc_task_operations->llseek(). Suppose we have a main thread M and its subthread T. Suppose that f_pos == 3, iow first_tid() should return T. Now suppose that the following happens between rcu_read_unlock() and rcu_read_lock(): 1. T execs and becomes the new leader. This removes M from ->thread_group but next_thread(M) is still T. 2. T creates another thread X which does exec as well, T goes away. 3. X creates another subthread, this increments nr_threads. 4. first_tid() does next_thread(M) and returns the already dead T. Note also that we need 2. and 3. only because of get_nr_threads() check, and this check was supposed to be optimization only. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Sameer Nanda <snanda@chromium.org> Cc: Sergey Dyasly <dserrg@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23proc: cleanup/simplify get_task_state/task_state_arrayOleg Nesterov
get_task_state() and task_state_array[] look confusing and suboptimal, it is not clear what it can actually report to user-space and task_state_array[] blows .data for no reason. 1. state = (tsk->state & TASK_REPORT) | tsk->exit_state is not clear. TASK_REPORT is self-documenting but it is not clear what ->exit_state can add. Move the potential exit_state's (EXIT_ZOMBIE and EXIT_DEAD) into TASK_REPORT and use it to calculate the final result. 2. With the change above it is obvious that task_state_array[] has the unused entries just to make BUILD_BUG_ON() happy. Change this BUILD_BUG_ON() to use TASK_REPORT rather than TASK_STATE_MAX and shrink task_state_array[]. 3. Turn the "while (state)" loop into fls(state). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: David Laight <David.Laight@ACULAB.COM> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23coredump: make __get_dumpable/get_dumpable inline, kill fs/coredump.hOleg Nesterov
1. Remove fs/coredump.h. It is not clear why do we need it, it only declares __get_dumpable(), signal.c includes it for no reason. 2. Now that get_dumpable() and __get_dumpable() are really trivial make them inline in linux/sched.h. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Kees Cook <keescook@chromium.org> Cc: Alex Kelly <alex.page.kelly@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Petr Matousek <pmatouse@redhat.com> Cc: Vasily Kulikov <segoon@openwall.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23coredump: kill MMF_DUMPABLE and MMF_DUMP_SECURELYOleg Nesterov
Nobody actually needs MMF_DUMPABLE/MMF_DUMP_SECURELY, they are only used to enforce the encoding of SUID_DUMP_* enum in mm->flags & MMF_DUMPABLE_MASK. Now that set_dumpable() updates both bits atomically we can kill them and simply store the value "as is" in 2 lower bits. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Kees Cook <keescook@chromium.org> Cc: Alex Kelly <alex.page.kelly@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Petr Matousek <pmatouse@redhat.com> Cc: Vasily Kulikov <segoon@openwall.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23coredump: set_dumpable: fix the theoretical race with itselfOleg Nesterov
set_dumpable() updates MMF_DUMPABLE_MASK in a non-trivial way to ensure that get_dumpable() can't observe the intermediate state, but this all can't help if multiple threads call set_dumpable() at the same time. And in theory commit_creds()->set_dumpable(SUID_DUMP_ROOT) racing with sys_prctl()->set_dumpable(SUID_DUMP_DISABLE) can result in SUID_DUMP_USER. Change this code to update both bits atomically via cmpxchg(). Note: this assumes that it is safe to mix bitops and cmpxchg. IOW, if, say, an architecture implements cmpxchg() using the locking (like arch/parisc/lib/bitops.c does), then it should use the same locks for set_bit/etc. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Kees Cook <keescook@chromium.org> Cc: Alex Kelly <alex.page.kelly@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Petr Matousek <pmatouse@redhat.com> Cc: Vasily Kulikov <segoon@openwall.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23Documentation/cpu-hotplug.txt: fix a typo in example codeSangjung Woo
As the notifier_block name (i.e. foobar_cpu_notifer) is different from the parameter (i.e.foobar_cpu_notifier) of register function, that is definitely error and it also makes readers confused. Signed-off-by: Sangjung Woo <sangjung.woo@samsung.com> Reviewed-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23Kconfig: update flightly outdated CONFIG_SMP documentationRobert Graffham
Remove an outdated reference to "most personal computers" having only one CPU, and change the use of "singleprocessor" and "single processor" in CONFIG_SMP's documentation to "uniprocessor" across all arches where that documentation is present. Signed-off-by: Robert Graffham <psquid@psquid.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23Documentation/filesystems/00-INDEX: updatesFabian Frederick
Add the following documentation-files with description : -autofs4-mount-control.txt -btrfs.txt -debugfs.txt -devpts.txt -fiemap.txt -gfs2-glocks.txt -gfs2-uevents.txt -omfs.txt -path-lookup.txt -qnx6.txt -quota.txt -squashfs.txt -sysfs-tagging.txt -ubifs.txt -xfs-delayed-logging-design.txt -xfs-self-describing-metadata.txt Add the following documentation directories with description : -caching -cifs (replacing cifs.txt) -pohmelfs Remove the following documentation-files reference: -dentry-locking.txt -reiser4.txt Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23Documentation/blockdev/ramdisk.txt: updatesFabian Frederick
- ramdisk_blocksize doesn't exist anymore - Module parameters added to documentation Signed-off-by: Fabian Frederick <fabf@skynet.be> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23Documentation/filesystems/sysfs.txt: fix device_attribute declarationAndre Richter
Fix a wrong device_attribute declaration example. Signed-off-by: Andre Richter <andre.o.richter@gmail.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23hfsplus: remove hfsplus_file_lookup()Sougata Santra
HFS+ resource fork lookup breaks opendir() library function. Since opendir first calls open() with O_DIRECTORY flag set. O_DIRECTORY means "refuse to open if not a directory". The open system call in the kernel does a check for inode->i_op->lookup and returns -ENOTDIR. So if hfsplus_file_lookup is set it allows opendir() for plain files. Also resource fork lookup in HFS+ does not work. Since it is never invoked after VFS permission checking. It will always return with -EACCES. When we call opendir() on a file, it does not return NULL. opendir() library call is based on open with O_DIRECTORY flag passed and then layered on top of getdents() system call. O_DIRECTORY means "refuse to open if not a directory". The open() system call in the kernel does a check for: do_sys_open() -->..--> can_lookup() i.e it only checks inode->i_op->lookup and returns ENOTDIR if this function pointer is not set. In OSX, we can open "file/rsrc" to get the resource fork of "file". This behavior is emulated inside hfsplus on Linux, which means that to some degree every file acts like a directory. That is the reason lookup() inode operations is supported for files, and it is possible to do a lookup on this specific name. As a result of this open succeeds without returning ENOTDIR for HFS+ Please see the LKML discussion thread on this issue: http://marc.info/?l=linux-fsdevel&m=122823343730412&w=2 I tried to test file/rsrc lookup in HFS+ driver and the feature does not work. From OSX: $ touch test $ echo "1234" > test/..namedfork/rsrc $ ls -l test..namedfork/rsrc --rw-r--r-- 1 tuxera staff 5 10 dec 12:59 test/..namedfork/rsrc [sougata@ultrabook tmp]$ id uid=1000(sougata) gid=1000(sougata) groups=1000(sougata),5(tty),18(dialout),1001(vboxusers) [sougata@ultrabook tmp]$ mount /dev/sdb1 on /mnt/tmp type hfsplus (rw,relatime,umask=0,uid=1000,gid=1000,nls=utf8) [sougata@ultrabook tmp]$ ls -l test/rsrc ls: cannot access test/rsrc: Permission denied According to this LKML thread it is expected behavior. http://marc.info/?t=121139033800008&r=1&w=4 I guess now that permission checking happens in vfs generic_permission() ? So it turns out that even though the lookup() inode_operation exists for HFS+ files. It cannot really get invoked ?. So if we can disable this feature to make opendir() work for HFS+. Signed-off-by: Sougata Santra <sougata@tuxera.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Anton Altaparmakov <aia21@cam.ac.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23nilfs2: add comments for ioctlsVyacheslav Dubeyko
Add comments for ioctls in fs/nilfs2/ioctl.c file and describe NILFS2 specific ioctls in Documentation/filesystems/nilfs2.txt. Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Reviewed-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Wenliang Fan <fanwlexca@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23fs/nilfs2: fix integer overflow in nilfs_ioctl_wrap_copy()Wenliang Fan
The local variable 'pos' in nilfs_ioctl_wrap_copy function can overflow if a large number was passed to argv->v_index from userspace and the sum of argv->v_index and argv->v_nmembs exceeds the maximum value of __u64 type integer (= ~(__u64)0 = 18446744073709551615). Here, argv->v_index is a 64-bit width argument to specify the start position of target data items (such as segment number, checkpoint number, or virtual block address of nilfs), and argv->v_nmembs gives the total number of the items that userland programs (such as lssu, lscp, or cleanerd) want to get information about, which also gives the maximum element count of argv->v_base[] array. nilfs_ioctl_wrap_copy() calls dofunc() repeatedly and increments the position variable 'pos' at the end of each iteration if dofunc() itself didn't update 'pos': if (pos == ppos) pos += n; This patch prevents the overflow here by rejecting pairs of a start position (argv->v_index) and a total count (argv->v_nmembs) which leads to the overflow. [konishi.ryusuke@lab.ntt.co.jp: fix signedness issue] Signed-off-by: Wenliang Fan <fanwlexca@gmail.com> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23fs/pipe.c: skip file_update_time on frozen fsDmitry Monakhov
Pipe has no data associated with fs so it is not good idea to block pipe_write() if FS is frozen, but we can not update file's time on such filesystem. Let's use same idea as we use in touch_time(). Addresses https://bugzilla.kernel.org/show_bug.cgi?id=65701 Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23drivers/rtc/rtc-rx8581.c: add SMBus-only adapters supportAndreas Werner
Add support for SMBus-only adapters (e.g. i2c-piix4). The driver has implemented only support for I2C adapters which implement the I2C_FUNC_SMBUS_I2C_BLOCK functionality before. With this patch it is possible to load and use the RTC driver with I2C and SMBUS adapters like the rtc-ds1307 does. Tested on AMD G Series Platform (i2c-piix4 adapter driver). Signed-off-by: Andreas Werner <andreas.werner@men.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23drivers/rtc/rtc-s5m.c: s5m_rtc_{suspend,resume}() should depend on ↵Geert Uytterhoeven
CONFIG_PM_SLEEP If CONFIG_PM_SLEEP=n: drivers/rtc/rtc-s5m.c:643: warning: `s5m_rtc_resume' defined but not used drivers/rtc/rtc-s5m.c:654: warning: `s5m_rtc_suspend' defined but not used Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23rtc: max8907: weekday encoding fixesStephen Warren
The current MAX8907 driver has two issues related to weekday value handling: 1) The HW WEEKDAY register has range 0..6 rather than 1..7 as documented. Note that I validated the actual HW range by observing the HW register roll from 6->0 rather than 6->7->1 as would otherwise be expected. This matches Linux's tm_wday range of 0..6. When the CMOS RAM content is lost, the date returned from the device is 2007-01-01 00:00:00, which is a Monday. The WEEKDAY register reads 1 in this case. This matches the numbering in Linux's tm_wday field. Hence we should write Linux's tm_wday value to the register without modifying it. Hence, remove the +1/-1 calculations for WEEKDAY/tm_wday. 2) There's no need to make alarms match on the WEEKDAY register, since the other fields together uniquely define the alarm date/time. Ignoring the WEEKDAY value in the match isolates the driver from any incorrect value in the current time copy of the WEEKDAY register. Each change individually, or both together, solves an issue that I observed; "hwclock -r" would time out waiting for its alarm to fire if the CMOS RAM content had been lost, and hence the WEEKDAY register value mismatched what the driver expected it to be. "hwclock -w" would solve this by over-writing the HW default WEEKDAY register value with what the driver expected. Signed-off-by: Stephen Warren <swarren@nvidia.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23drivers/rtc/rtc-hym8563.c: staticize local symbolSachin Kamat
'hym8563_clkout_ops' is used only in this file. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23drivers/rtc/rtc-hym8563.c: remove redundant of_match_ptr() helperSachin Kamat
'hym8563_dt_idtable' is always compiled in. Hence the helper macro is not needed. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23drivers/rtc/rtc-ds1742.c: remove redundant of_match_ptr() helperSachin Kamat
'ds1742_rtc_of_match' is always compiled in. Hence the helper macro is not needed. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23drivers/rtc/rtc-cmos.c: propagate hpet_register_irq_handler() failureAndrew Morton
If hpet_register_irq_handler() fails, cmos_do_probe() will incorrectly return 0. Reported-by: Julia Lawall <julia.lawall@lip6.fr> Cc: John Stultz <john.stultz@linaro.org> Cc: Grant Likely <grant.likely@linaro.org> Cc: Rob Herring <robh+dt@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23rtc: honor device tree /alias entries when assigning IDsStephen Warren
Assign RTC device IDs based on device tree /aliases entries if present, falling back to the existing numbering scheme if there is no /aliases entry (which includes when the system isn't booted using DT), or there is a numbering conflict. This is useful in systems with multiple RTC devices, to ensure that the best RTC device is selected as /dev/rtc0, which provides the overall system time. For example, Tegra has an on-SoC RTC that is not battery backed, typically coupled with an off-SoC RTC that is battery backed. Only the latter is useful for populating the system time, yet the former is useful e.g. for wakeup timing, since the time is not lost when the system is sleeps. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23drivers/rtc/rtc-pcf2127.c: replace IS_ERR and PTR_ERR with PTR_ERR_OR_ZERODuan Jiong
Fix a coccinelle error regarding usage of IS_ERR and PTR_ERR instead of PTR_ERR_OR_ZERO. Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23drivers/rtc/Kconfig: disable RTC_DRV_CMOS on AtariGeert Uytterhoeven
On ARAnyM (emulating an Atari Falcon, which doesn't have an RTC IRQ, as the Second Multi Function Peripheral MFP 68901 is available on Atari TT only), rtc-cmos doesn't work well: - The date is of by 32 years (2045 instead of 2013): rtc_cmos rtc_cmos: setting system clock to 2045-12-02 10:56:17 UTC (2395824977) - The hwclock utility doesn't work: hwclock: ioctl() to /dev/rtc to turn on update interrupts failed unexpectedly, errno=5: Input/output error. As rtc-generic works fine for the RTC part, and nvram works for the NVRAM part, we'll continue on using that. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23drivers/rtc/rtc-cmos.c: remove superfluous name castGeert Uytterhoeven
device_driver.name is "const char *" Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23rtc: add hym8563 rtc-driverHeiko Stuebner
The Haoyu Microelectronics HYM8563 provides rtc and alarm functions as well as a clock output of up to 32kHz. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Ian Campbell <ijc+devicetree@hellion.org.uk> Cc: Grant Likely <grant.likely@linaro.org> Cc: Mike Turquette <mturquette@linaro.org> Cc: Richard Weinberger <richard.weinberger@gmail.com> Cc: Mark Brown <broonie@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23dt-bindings: add hym8563 bindingHeiko Stuebner
Add binding documentation for the hym8563 rtc chip. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Ian Campbell <ijc+devicetree@hellion.org.uk> Cc: Grant Likely <grant.likely@linaro.org> Cc: Mike Turquette <mturquette@linaro.org> Cc: Richard Weinberger <richard.weinberger@gmail.com> Cc: Mark Brown <broonie@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23drivers/rtc/rtc-vr41xx.c: use devm_*() functionsJingoo Han
Use devm_*() functions to make cleanup paths simpler, and remove unnecessary remove(). Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Yoichi Yuasa <yuasa@linux-mips.org> Cc: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23drivers/rtc/rtc-twl.c: use devm_*() functionsJingoo Han
2014-01-23drivers/rtc/rtc-ds1742.c: add devicetree supportAlexander Shiyan
This patch allows the driver to be enabled with devicetree. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Acked-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23drivers/rtc/rtc-mxc.c: check the return value from clk_prepare_enable()Fabio Estevam
clk_prepare_enable() may fail, so let's check its return value and propagate it in the case of error. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23drivers/rtc/rtc-mxc.c: remove unneeded labelFabio Estevam
There is no need to jump to the 'exit_free_pdata' label when devm_clk_get() fails, as we can directly return the error and simplify the code a bit. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23drivers/rtc/rtc-ds1305.c: remove unnecessary spi_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure. Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23drivers/rtc/rtc-as3722: use devm for rtc and irq registrationLaxman Dewangan
Use devm_* calls for rtc and irq registration and get rid of remove callback for platform driver. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Cc: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23autofs: fix symlinks aren't checked for expiryIan Kent
The autofs4 module doesn't consider symlinks for expire as it did in the older autofs v3 module (so it's actually a long standing regression). The user space daemon has focused on the use of bind mounts instead of symlinks for a long time now and that's why this has not been noticed. But with the future addition of amd map parsing to automount(8), not to mention amd itself (of am-utils), symlink expiry will be needed. The direct and offset mount types can't be symlinks and the tree mounts of version 4 were always real mounts so only indirect mounts need expire symlinks. Since the current users of the autofs4 module haven't reported this as a problem to date this patch probably isn't a candidate for backport to stable. Signed-off-by: Ian Kent <ikent@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23autofs: use IS_ROOT to replace root dentry checksRui Xiang
Use the helper macro !IS_ROOT to replace parent != dentry->d_parent. Just clean up. Signed-off-by: Rui Xiang <rui.xiang@huawei.com> Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23autofs: fix the return value of autofs4_fill_superRui Xiang
While kzallocing sbi/ino fails, it should return -ENOMEM. And it should return the err value from autofs_prepare_pipe. Signed-off-by: Rui Xiang <rui.xiang@huawei.com> Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23autofs4: translate pids to the right namespace for the daemonMiklos Szeredi
The PID and the TGID of the process triggering the mount are sent to the daemon. Currently the global pid values are sent (ones valid in the initial pid namespace) but this is wrong if the autofs daemon itself is not running in the initial pid namespace. So send the pid values that are valid in the namespace of the autofs daemon. The namespace to use is taken from the oz_pgrp pid pointer, which was set at mount time to the mounting process' pid namespace. If the pid translation fails (the triggering process is in an unrelated pid namespace) then the automount fails with ENOENT. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Cc: Eric Biederman <ebiederm@xmission.com> Acked-by: Ian Kent <raven@themaw.net> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23autofs4: allow autofs to work outside the initial PID namespaceSukadev Bhattiprolu
Enable autofs4 to work in a "container". oz_pgrp is converted from pid_t to struct pid and this is stored at mount time based on the "pgrp=" option or if the option is missing then the current pgrp. The "pgrp=" option is interpreted in the PID namespace of the current process. This option is flawed in that it doesn't carry the namespace information, so it should be deprecated. AFAICS the autofs daemon always sends the current pgrp, which is the default anyway. The oz_pgrp is also set from the AUTOFS_DEV_IOCTL_SETPIPEFD_CMD ioctl. This ioctl sets oz_pgrp to the current pgrp. It is not allowed to change the pid namespace. oz_pgrp is used mainly to determine whether the process traversing the autofs mount tree is the autofs daemon itself or not. This function now compares the pid pointers instead of the pid_t values. One other use of oz_pgrp is in autofs4_show_options. There is shows the virtual pid number (i.e. the one that is valid inside the PID namespace of the calling process) For debugging printk convert oz_pgrp to the value in the initial pid namespace. Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Cc: Eric Biederman <ebiederm@xmission.com> Acked-by: Ian Kent <raven@themaw.net> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23init: fix possible format string bugTetsuo Handa
Use constant format string in case message changes. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23init/main.c: remove unused declaration of tc_init()Geert Uytterhoeven
Its user was removed in v2.5.2.4. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23fs/ramfs: move ramfs_aops to inode.cAxel Lin
ramfs_aops is identical in file-mmu.c and file-nommu.c. Thus move it to fs/ramfs/inode.c and make it static. Signed-off-by: Axel Lin <axel.lin@ingics.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23fs/ramfs/file-nommu.c: make ramfs_nommu_get_unmapped_area() and ↵Axel Lin
ramfs_nommu_mmap() static Since commit 853ac43ab194 ("shmem: unify regular and tiny shmem"), ramfs_nommu_get_unmapped_area() and ramfs_nommu_mmap() are not directly referenced outside of file-nommu.c. Thus make them static. Signed-off-by: Axel Lin <axel.lin@ingics.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
