2011-01-10ext4: reorder ext4_inode_info structure elements to remove unneeded paddingTheodore Ts'o
By reordering the elements in the ext4_inode_info structure, we can reduce the padding needed on an x86_64 system by 16 bytes. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-01-10ext4: drop ec_type from the ext4_ext_cache structureTheodore Ts'o
We can encode the ec_type information by using ee_len == 0 to denote EXT4_EXT_CACHE_NO, ee_start == 0 to denote EXT4_EXT_CACHE_GAP, and if neither is true, then the cache type must be EXT4_EXT_CACHE_EXTENT. This allows us to reduce the size of ext4_ext_inode by another 8 bytes. (ec_type is 4 bytes, plus another 4 bytes of padding) Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-01-10ext4: use ext4_lblk_t instead of sector_t for logical blocksTheodore Ts'o
This fixes a number of places where we used sector_t instead of ext4_lblk_t for logical blocks, which for ext4 are still 32-bit data types. No point wasting space in the ext4_inode_info structure, and requiring 64-bit arithmetic on 32-bit systems, when it isn't necessary. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-01-10ext4: replace i_delalloc_reserved_flag with EXT4_STATE_DELALLOC_RESERVEDTheodore Ts'o
Remove the short element i_delalloc_reserved_flag from the ext4_inode_info structure and replace it a new bit in i_state_flags. Since we have an ext4_inode_info for every ext4 inode cached in the inode cache, any savings we can produce here is a very good thing from a memory utilization perspective. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-01-10ext4: fix 32bit overflow in ext4_ext_find_goal()Kazuya Mio
ext4_ext_find_goal() returns an ideal physical block number that the block allocator tries to allocate first. However, if a required file offset is smaller than the existing extent's one, ext4_ext_find_goal() returns a wrong block number because it may overflow at "block - le32_to_cpu(ex->ee_block)". This patch fixes the problem. ext4_ext_find_goal() will also return a wrong block number in case a file offset of the existing extent is too big. In this case, the ideal physical block number is fixed in ext4_mb_initialize_context(), so it's no problem. reproduce: # dd if=/dev/zero of=/mnt/mp1/tmp bs=127M count=1 oflag=sync # dd if=/dev/zero of=/mnt/mp1/file bs=512K count=1 seek=1 oflag=sync # filefrag -v /mnt/mp1/file Filesystem type is: ef53 File size of /mnt/mp1/file is 1048576 (256 blocks, blocksize 4096) ext logical physical expected length flags 0 128 67456 128 eof /mnt/mp1/file: 2 extents found # rm -rf /mnt/mp1/tmp # echo $((512*4096)) > /sys/fs/ext4/loop0/mb_stream_req # dd if=/dev/zero of=/mnt/mp1/file bs=512K count=1 oflag=sync conv=notrunc result (linux-2.6.37-rc2 + ext4 patch queue): # filefrag -v /mnt/mp1/file Filesystem type is: ef53 File size of /mnt/mp1/file is 1048576 (256 blocks, blocksize 4096) ext logical physical expected length flags 0 0 33280 128 1 128 67456 33407 128 eof /mnt/mp1/file: 2 extents found result(apply this patch): # filefrag -v /mnt/mp1/file Filesystem type is: ef53 File size of /mnt/mp1/file is 1048576 (256 blocks, blocksize 4096) ext logical physical expected length flags 0 0 66560 128 1 128 67456 66687 128 eof /mnt/mp1/file: 2 extents found Signed-off-by: Kazuya Mio <k-mio@sx.jp.nec.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-01-10ext4: add more error checks to ext4_mkdir()Namhyung Kim
Check return value of ext4_journal_get_write_access, ext4_journal_dirty_metadata and ext4_mark_inode_dirty. Move brelse() under 'out_stop' to release bh properly in case of journal error. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-01-10ext4: ext4_ext_migrate should use NULL not 0Eric Paris
ext4_ext_migrate() calls ext4_new_inode() and passes 0 instead of a pointer to a struct qstr. This patch uses NULL, to make it obvious to the caller that this was a pointer. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-01-10ext4: Use ext4_error_file() to print the pathname to the corrupted inodeTheodore Ts'o
Where the file pointer is available, use ext4_error_file() instead of ext4_error_inode(). Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-01-10ext4: use IS_ERR() to check for errors in ext4_error_fileDan Carpenter
d_path() returns an ERR_PTR and it doesn't return NULL. This is in ext4_error_file() and no one actually calls ext4_error_file(). Signed-off-by: Dan Carpenter <error27@gmail.com>
2011-01-10ext4: test the correct variable in ext4_init_pageio()Dan Carpenter
This is a copy and paste error. The intent was to check "io_page_cachep". We tested "io_page_cachep" earlier. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-01-10ext2: remove dead code in ext2_xattr_getWang Sheng-Hui
Reviewed-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Wang Sheng-Hui <crosslonelyover@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-01-10ext2,ext3,ext4: clarify comment for extN_xattr_set_handleWang Sheng-Hui
2011-01-10ext4: clean up ext4_xattr_list()'s error code checking and return strategyTheodore Ts'o
Any time you see code that tries to add error codes together, you should want to claw your eyes out... Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-01-10ext4: remove warning message from ext4_issue_discard helperLukas Czerner
ext4_issue_discard is supposed to be helper for calling discard, however in case that underlying device does not support discard it prints out the warning message and clears the DISCARD t_mount_opt flag. Since it can be (and is) used by others, it should not do anything and let the caller to handle the error case. This commit removes warning message and flag setting from ext4_issue_discard and use it just in place where it is really needed (release_blocks_on_commit). FITRIM ioctl should not set any flags nor it should print out warning messages, so get rid of the warning as well. Signed-off-by: Lukas Czerner <lczerner@redhat.com>
2011-01-10ext4: fix possible overflow in ext4_trim_fs()Lukas Czerner
When determining last group through ext4_get_group_no_and_offset() the result may be wrong in cases when range->start and range-len are too big, because it may overflow when summing up those two numbers. Fix that by checking range->len and limit its value to ext4_blocks_count(). This commit was tested by myself with expected result. Signed-off-by: Lukas Czerner <lczerner@redhat.com>
2010-12-20ext4: Add error checking to kmem_cache_alloc() call in ext4_free_blocks()Theodore Ts'o
2010-12-19ext4: Use printf extension %pVJoe Perches
Using %pV reduces the number of printk calls and eliminates any possible message interleaving from other printk calls. In function __ext4_grp_locked_error also added KERN_CONT to some printks. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-12-19ext4: Use vzalloc in ext4_fill_flex_info()Joe Perches
2010-12-19ext4: zero out nanosecond timestamps for small inodesEric Sandeen
When nanosecond timestamp resolution isn't supported on an ext4 partition (inode size = 128), stat() appears to be returning uninitialized garbage in the nanosecond component of timestamps. EXT4_INODE_GET_XTIME should zero out tv_nsec when EXT4_FITS_IN_INODE evaluates to false. Reported-by: Jordan Russell <jr-list-2010@quo.to> Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-12-19ext4: optimize ext4_check_dir_entry() with unlikely() annotationsTheodore Ts'o
This function gets called a lot for large directories, and the answer is almost always "no, no, there's no problem". This means using unlikely() is a good thing. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-12-19ext4: use kmem_cache_zalloc() in ext4_init_io_end()Jesper Juhl
Use advantage of kmem_cache_zalloc() to remove a memset() call in ext4_init_io_end() and save a few bytes. Before: [jj@dragon linux-2.6]$ size fs/ext4/page-io.o text data bss dec hex filename 3016 0 624 3640 e38 fs/ext4/page-io.o After: [jj@dragon linux-2.6]$ size fs/ext4/page-io.o text data bss dec hex filename 3000 0 624 3624 e28 fs/ext4/page-io.o Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-12-19ext4: Remove redundant unlikely()Tobias Klauser
IS_ERR() already implies unlikely(), so it can be omitted here. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-12-18jbd2: simplify return path of journal_init_commonTheodore Ts'o
2010-12-18jbd2: move debug message into debug #ifdefTheodore Ts'o
This is a port to jbd2 of a patch which Namhyung Kim <namhyung@gmail.com> originally made to fs/jbd. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-12-18jbd2: remove unnecessary goto statementTheodore Ts'o
2010-12-18jbd2: use offset_in_page() instead of manual calculationTheodore Ts'o
2010-12-18jbd2: Fix a debug message in do_get_write_access()Theodore Ts'o
'buffer_head' should be 'journal_head' This is a port of a patch which Namhyung Kim <namhyung@gmail.com> made to fs/jbd to jbd2. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-12-17jbd2: Use pr_notice_ratelimited() in journal_alloc_journal_head()Theodore Ts'o
We had an open-coded version of printk_ratelimited(); use the provided abstraction to make the code cleaner and easier to understand. Based on a similar patch for fs/jbd from Namhyung Kim <namhyung@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-12-17ext4: Use pr_warning_ratelimited() instead of printk_ratelimit()Theodore Ts'o
printk_ratelimit() is deprecated since it is a global instead of a per-printk ratelimit. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-12-16ext4: Fix up comments in inode.cTheodore Ts'o
This fixes up some broken argument descriptions that Namhyung Kim had originally submitted for ext3. This fixes the comments that were still applicable in ext4. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-12-15ext4: Add second mount options field since the s_mount_opt is full upTheodore Ts'o
2010-12-15ext4: Move struct ext4_mount_options from ext4.h to super.cTheodore Ts'o
Move the ext4_mount_options structure definition from ext4.h, since it is only used in super.c. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-12-15ext4: Simplify the usage of clear_opt() and set_opt() macrosTheodore Ts'o
Change clear_opt() and set_opt() to take a superblock pointer instead of a pointer to EXT4_SB(sb)->s_mount_opt. This makes it easier for us to support a second mount option field. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-12-15Linux 2.6.37-rc6v2.6.37-rc6Linus Torvalds
2010-12-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: ghash-intel - ghash-clmulni-intel_glue needs err.h
2010-12-15Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: fix typo which broke '..' detection in ext4_find_entry() ext4: Turn off multiple page-io submission by default
2010-12-15xen: Provide a variant of __RING_SIZE() that is an integer constant expressionJeremy Fitzhardinge
Without this, gcc 4.5 won't compile xen-netfront and xen-blkfront, where this is being used to specify array sizes. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: David Miller <davem@davemloft.net> Cc: Stable Kernel <stable@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-15MAINTAINERS: update MSM git treeDaniel Walker
The MSM main git tree has changed over to this new address. Signed-off-by: Daniel Walker <dwalker@codeaurora.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-15install_special_mapping skips security_file_mmap check.Tavis Ormandy
The install_special_mapping routine (used, for example, to setup the vdso) skips the security check before insert_vm_struct, allowing a local attacker to bypass the mmap_min_addr security restriction by limiting the available pages for special mappings. bprm_mm_init() also skips the check, and although I don't think this can be used to bypass any restrictions, I don't see any reason not to have the security check. $ uname -m x86_64 $ cat /proc/sys/vm/mmap_min_addr 65536 $ cat install_special_mapping.s section .bss resb BSS_SIZE section .text global _start _start: mov eax, __NR_pause int 0x80 $ nasm -D__NR_pause=29 -DBSS_SIZE=0xfffed000 -f elf -o install_special_mapping.o install_special_mapping.s $ ld -m elf_i386 -Ttext=0x10000 -Tbss=0x11000 -o install_special_mapping install_special_mapping.o $ ./install_special_mapping & [1] 14303 $ cat /proc/14303/maps 0000f000-00010000 r-xp 00000000 00:00 0 [vdso] 00010000-00011000 r-xp 00001000 00:19 2453665 /home/taviso/install_special_mapping 00011000-ffffe000 rwxp 00000000 00:00 0 [stack] It's worth noting that Red Hat are shipping with mmap_min_addr set to 4096. Signed-off-by: Tavis Ormandy <taviso@google.com> Acked-by: Kees Cook <kees@ubuntu.com> Acked-by: Robert Swiecki <swiecki@google.com> [ Changed to not drop the error code - akpm ] Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-15crypto: ghash-intel - ghash-clmulni-intel_glue needs err.hRandy Dunlap
Add missing header file: arch/x86/crypto/ghash-clmulni-intel_glue.c:256: error: implicit declaration of function 'IS_ERR' arch/x86/crypto/ghash-clmulni-intel_glue.c:257: error: implicit declaration of function 'PTR_ERR' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-12-14Merge branch 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: It is likely that WORKER_NOT_RUNNING is true MAINTAINERS: Add workqueue entry workqueue: check the allocation of system_unbound_wq
2010-12-14Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: md: protect against NULL reference when waiting to start a raid10. md: fix bug with re-adding of partially recovered device. md: fix possible deadlock in handling flush requests. md: move code in to submit_flushes. md: remove handling of flush_pending in md_submit_flush_data
2010-12-14dw_spi: Fix missing final read in some polling situationsMajor Lee
There is a possibility that the last word of a transaction will be lost if data is not ready. Re-read in poll_transfer() to solve this issue when poll_mode is enabled. Verified on SPI touch screen device. Signed-off-by: Major Lee <major_lee@wistron.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-14i2c_intel_mid: Fix slash in sysfs nameAlan Cox
This gets caught by the new sanity check code. Instead of the slash use a different symbol. This was originally found by Major Lee who proposed a rather more complex patch which changed the name according to the chip type. On the basis that we are in a late -rc and making Linus grumpy isn't always a good idea (however fun) this is a simple alternative. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-14ext4: fix typo which broke '..' detection in ext4_find_entry()Aaro Koskinen
There should be a check for the NUL character instead of '0'. Fortunately the only thing that cares about this is NFS serving, which is why we didn't notice this in the merge window testing. Reported-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-12-14Merge branch 'sh-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'sh-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: sh: wire up accept4 syscall (non-multiplexed path) sh: Enable deprecated IRQ chip APIs for MFD and GPIOLIB drivers.
2010-12-14Merge branch 'omap-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: OMAP2: PRCM: fix some SHIFT macros that were actually bitmasks OMAP2+: PM/serial: fix console semaphore acquire during suspend OMAP1: SRAM: fix size for OMAP1611 SoCs arm: omap2: io: fix clk_get() error check arm: plat-omap: counter_32k: use IS_ERR() instead of NULL check omap: nand: remove hardware ECC as default omap: zoom: wl1271 slot is MMC_CAP_POWER_OFF_CARD omap: PM debug: fix wake-on-timer debugfs dependency
2010-12-14Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6535/1: V6 MPCore v6_dma_inv_range and v6_dma_flush_range RWFO fix ARM: 6534/1: Make CONFIG_FPE_NWFPE depend on !CONFIG_THUMB2_KERNEL ARM: 6533/1: Thumb-2: Make CONFIG_THUMB2_KERNEL depend on !CPU_V6 Change bcmring Maintainer list. ARM: Update mach-types ARM: 6528/1: Use CTR for the I-cache line size on ARMv7 ARM: 6527/1: Use CTR instead of CCSIDR for the D-cache line size on ARMv7 ARM: pxa/palm: fix ifdef around gen_nand driver registration ARM: pxa: fix pxa2xx-flash section mismatch ARM: mmp2: remove not used clk_rtc
2010-12-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc: Write to prom console using indirect buffer. sparc: Delete prom_*getchar(). sparc: Pass buffer pointer all the way down to prom_{get,put}char(). sparc: Do not export prom_nb{get,put}char(). sparc64: Delete prom_setcallback(). sparc64: Unexport prom_service_exists(). sparc: Kill prom devops_{32,64}.c sparc: Remove prom_pathtoinode() sparc64: Delete prom_puts() unused. SPARC/LEON: removed constant timer initialization as if HZ=100, now it reflects the value of HZ
2010-12-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (75 commits) pppoe.c: Fix kernel panic caused by __pppoe_xmit WAN: Fix a TX IRQ causing BUG() in PC300 and PCI200SYN drivers. bnx2x: Advance a version number to 1.60.01-0 bnx2x: Fixed a compilation warning bnx2x: LSO code was broken on BE platforms qlge: Fix deadlock when cancelling worker. net: fix skb_defer_rx_timestamp() cxgb4vf: Ingress Queue Entry Size needs to be 64 bytes phy: add the IC+ IP1001 driver atm: correct sysfs 'device' link creation and parent relationships MAINTAINERS: remove me from tulip SCTP: Fix SCTP_SET_PEER_PRIMARY_ADDR to accpet v4mapped address enic: Bug Fix: Pass napi reference to the isr that services receive queue ipv6: fix nl group when advertising a new link connector: add module alias net: Document the kernel_recvmsg() function r8169: Fix runtime power management hso: IP checksuming doesn't work on GE0301 option cards xfrm: Fix xfrm_state_migrate leak net: Convert netpoll blocking api in bonding driver to be a counter ...
