2008-01-11[CRYPTO] doc: Update api-intro.txtHerbert Xu
This patch updates the list of transforms we support and clarifies that the Block Ciphers interface in fact supports all ciphers including stream ciphers. It also removes the obsolete Configuration Notes section and adds the linux-crypto mailing list as the primary bug reporting address. Finally it documents the fact that setkey should only be called from user context. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] scatterwalk: Use generic scatterlist chainingHerbert Xu
This patch converts the crypto scatterwalk code to use the generic scatterlist chaining rather the version specific to crypto. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] hifn: Add missing includesAndrew Morton
alpha: drivers/crypto/hifn_795x.c: In function 'ablkcipher_walk_init': drivers/crypto/hifn_795x.c:1231: error: implicit declaration of function 'sg_init_table' drivers/crypto/hifn_795x.c:1243: error: implicit declaration of function 'sg_set_page' drivers/crypto/hifn_795x.c: In function 'ablkcipher_walk_exit': drivers/crypto/hifn_795x.c:1257: error: implicit declaration of function 'sg_page' drivers/crypto/hifn_795x.c:1257: warning: passing argument 1 of '__free_pages' makes pointer from integer without a cast drivers/crypto/hifn_795x.c: In function 'ablkcipher_add': drivers/crypto/hifn_795x.c:1278: warning: passing argument 1 of 'kmap_atomic' makes pointer from integer without a cast drivers/crypto/hifn_795x.c: In function 'ablkcipher_walk': drivers/crypto/hifn_795x.c:1336: warning: passing argument 1 of 'kmap_atomic' makes pointer from integer without a cast drivers/crypto/hifn_795x.c: In function 'hifn_setup_session': drivers/crypto/hifn_795x.c:1465: warning: assignment makes pointer from integer without a cast drivers/crypto/hifn_795x.c:1469: warning: assignment makes pointer from integer without a cast drivers/crypto/hifn_795x.c:1472: warning: assignment makes pointer from integer without a cast drivers/crypto/hifn_795x.c: In function 'ablkcipher_get': drivers/crypto/hifn_795x.c:1593: warning: passing argument 1 of 'kmap_atomic' makes pointer from integer without a cast {standard input}: Assembler messages: {standard input}:7: Warning: setting incorrect section attributes for .got drivers/crypto/hifn_795x.c: In function 'hifn_process_ready': drivers/crypto/hifn_795x.c:1653: warning: passing argument 1 of 'kmap_atomic' makes pointer from integer without a cast drivers/crypto/hifn_795x.c: In function 'hifn_probe': drivers/crypto/hifn_795x.c:2438: error: 'DMA_32BIT_MASK' undeclared (first use in this function) drivers/crypto/hifn_795x.c:2438: error: (Each undeclared identifier is reported only once drivers/crypto/hifn_795x.c:2438: error: for each function it appears in.) drivers/crypto/hifn_795x.c:2443: warning: format '%d' expects type 'int', but argument 4 has type 'long int' drivers/crypto/hifn_795x.c:2443: warning: format '%d' expects type 'int', but argument 4 has type 'long int' Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] hifn: Make Kconfig option depend on PCIJan Glauber
The HIFN driver is currently selectable on s390 but wont compile. Since it looks like HIFN needs PCI make the Kconfig dependent on PCI, which is not available on s390. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Acked-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] hifn: Schedule callback invocation to tasklet.Evgeniy Polyakov
This patch forces HIFN driver to invoke crypto request callbacks from tasklet (softirq context) instead of hardirq context, since network stack expects it to be called from bottom halves. It is done by simply scheduling callback invocation via dedicated tasklet. Workqueue solution was dropped because of tooo slow rescheduling performance (7 times slower than tasklet, for mode details one can check this link: http://tservice.net.ru/~s0mbre/blog/devel/other/2007_11_09.html). Driver passed all AES and DES tests in tcryt.c module. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] sha256-generic: Extend sha256_generic.c to support SHA-224Jonathan Lynch
Resubmitting this patch which extends sha256_generic.c to support SHA-224 as described in FIPS 180-2 and RFC 3874. HMAC-SHA-224 as described in RFC4231 is then supported through the hmac interface. Patch includes test vectors for SHA-224 and HMAC-SHA-224. SHA-224 chould be chosen as a hash algorithm when 112 bits of security strength is required. Patch generated against the 2.6.24-rc1 kernel and tested against 2.6.24-rc1-git14 which includes fix for scatter gather implementation for HMAC. Signed-off-by: Jonathan Lynch <jonathan.lynch@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] geode: Add fallback for unsupported modesSebastian Siewior
The Geode AES crypto engine supports only 128 bit long key. This patch adds fallback for other key sizes which are required by the AES standard. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Acked-by: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] aes-i586: Remove setkeySebastian Siewior
The setkey() function can be shared with the generic algorithm. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] ctr: Remove default MSebastian Siewior
NO other block mode is M by default. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] aes-x86-64: Remove setkeySebastian Siewior
2008-01-11[CRYPTO] aes-generic: Make key generation exportableSebastian Siewior
This patch exports four tables and the set_key() routine. This ressources can be shared by other AES implementations (aes-x86_64 for instance). The decryption key has been turned around (deckey[0] is the first piece of the key instead of deckey[keylen+20]). The encrypt/decrypt functions are looking now identical (except they are using different tables and key). Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] aes-generic: Coding style cleanupSebastian Siewior
2008-01-11[CRYPTO] ctr: Add countersizeJoy Latten
This patch adds countersize to CTR mode. The template is now ctr(algo,noncesize,ivsize,countersize). For example, ctr(aes,4,8,4) indicates the counterblock will be composed of a salt/nonce that is 4 bytes, an iv that is 8 bytes and the counter is 4 bytes. When noncesize + ivsize < blocksize, CTR initializes the last block - ivsize - noncesize portion of the block to zero. Otherwise the counter block is composed of the IV (and nonce if necessary). If noncesize + ivsize == blocksize, then this indicates that user is passing in entire counterblock. Thus countersize indicates the amount of bytes in counterblock to use as the counter for incrementing. CTR will increment counter portion by 1, and begin encryption with that value. Note that CTR assumes the counter portion of the block that will be incremented is stored in big endian. Signed-off-by: Joy Latten <latten@austin.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] camellia: De-unrollingDenys Vlasenko
Move huge unrolled pieces of code (3 screenfuls) at the end of 128/256 key setup routines into common camellia_setup_tail(), convert it to loop there. Loop is still unrolled six times, so performance hit is very small, code size win is big. Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Acked-by: Noriaki TAKAMIYA <takamiya@po.ntts.co.jp> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] camellia: Code cleanupDenys Vlasenko
Optimize GETU32 to use 4-byte memcpy (modern gcc will convert such memcpy to single move instruction on i386). Original GETU32 did four byte fetches, and shifted/XORed those. Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Acked-by: Noriaki TAKAMIYA <takamiya@po.ntts.co.jp> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
Rename some macros to shorter names: CAMELLIA_RR8 -> ROR8, making it easier to understand that it is just a right rotation, nothing camellia-specific in it. CAMELLIA_SUBKEY_L() -> SUBKEY_L() - just shorter. Move be32 <-> cpu conversions out of en/decrypt128/256 and into camellia_en/decrypt - no reason to have that code duplicated twice. Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Acked-by: Noriaki TAKAMIYA <takamiya@po.ntts.co.jp> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
Move code blocks around so that related pieces are closer together: e.g. CAMELLIA_ROUNDSM macro does not need to be separated from the rest of the code by huge array of constants. Remove unused macros (COPY4WORD, SWAP4WORD, XOR4WORD[2]) Drop SUBL(), SUBR() macros which only obscure things. Same for CAMELLIA_SP1110() macro and KEY_TABLE_TYPE typedef. Remove useless comments: /* encryption */ -- well it's obvious enough already! void camellia_encrypt128(...) Combine swap with copying at the beginning/end of encrypt/decrypt. Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Acked-by: Noriaki TAKAMIYA <takamiya@po.ntts.co.jp> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] twofish: Do not unroll big stuff in twofish key setupDenys Vlasenko
Currently twofish cipher key setup code has unrolled loops - approximately 70-100 instructions are repeated 40 times. As a result, twofish module is the biggest module in crypto/*. Unrolling produces x2.5 more code (+18k on i386), and speeds up key setup by 7%: unrolled: twofish_setkey/sec: 41128 loop: twofish_setkey/sec: 38148 CALC_K256: ~100 insns each CALC_K192: ~90 insns CALC_K: ~70 insns Attached patch removes this unrolling. $ size */twofish_common.o text data bss dec hex filename 37920 0 0 37920 9420 crypto.org/twofish_common.o 13209 0 0 13209 3399 crypto/twofish_common.o Run tested (modprobe tcrypt reports ok). Please apply. Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] geode: move defines into a headerfileSebastian Siewior
This patch moves macros in geode-aes.c into geode-aes.h. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] geode: relax in busy loop and care about return valueSebastian Siewior
The code waits in a busy loop until the hardware finishes the encryption or decryption process. This wants a cpu_relax() :) The busy loop finishes either if the encryption is done or if the counter is zero. If the latter is true than the hardware failed. Since this should not happen, leave sith a BUG(). Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] geode: use consistent IV copySebastian Siewior
It is enough if the IV is copied before and after the while loop. With DM-Crypt is seems not be required to save the IV after encrytion because a new one is used in the request (dunno about other users). It is not save to load the IV within while loop and not save afterwards because we mill end up with the wrong IV if the request goes consists of more than one page. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] aes: Move common defines into a header fileSebastian Siewior
This three defines are used in all AES related hardware. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] geode: remove aliasSebastian Siewior
alias isn't required because the module provides PCI ids. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] hifn_795x: Detect weak keysEvgeniy Polyakov
HIFN driver update to use DES weak key checks (exported in this patch). Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] des: Create header file for common macrosEvgeniy Polyakov
This patch creates include/crypto/des.h for common macros shared between DES implementations. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] hifn_795x: HIFN 795x driverEvgeniy Polyakov
This is a driver for HIFN 795x crypto accelerator chips. It passed all tests for AES, DES and DES3_EDE except weak test for DES, since hardware can not determine weak keys. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] ctr: Add CTR (Counter) block cipher modeJoy Latten
This patch implements CTR mode for IPsec. It is based off of RFC 3686. Please note: 1. CTR turns a block cipher into a stream cipher. Encryption is done in blocks, however the last block may be a partial block. A "counter block" is encrypted, creating a keystream that is xor'ed with the plaintext. The counter portion of the counter block is incremented after each block of plaintext is encrypted. Decryption is performed in same manner. 2. The CTR counterblock is composed of, nonce + IV + counter The size of the counterblock is equivalent to the blocksize of the cipher. sizeof(nonce) + sizeof(IV) + sizeof(counter) = blocksize The CTR template requires the name of the cipher algorithm, the sizeof the nonce, and the sizeof the iv. ctr(cipher,sizeof_nonce,sizeof_iv) So for example, ctr(aes,4,8) specifies the counterblock will be composed of 4 bytes from a nonce, 8 bytes from the iv, and 4 bytes for counter since aes has a blocksize of 16 bytes. 3. The counter portion of the counter block is stored in big endian for conformance to rfc 3686. Signed-off-by: Joy Latten <latten@austin.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] padlock: Fix alignment fault in aes_crypt_copyHerbert Xu
The previous patch fixed spurious read faults from occuring by copying the data if we happen to have a single block at the end of a page. It appears that gcc cannot guarantee 16-byte alignment in the kernel with __attribute__. The following report from Torben Viets shows a buffer that's only 8-byte aligned: > eneral protection fault: 0000 [#1] > Modules linked in: xt_TCPMSS xt_tcpmss iptable_mangle ipt_MASQUERADE > xt_tcpudp xt_mark xt_state iptable_nat nf_nat nf_conntrack_ipv4 > iptable_filter ip_tables x_tables pppoe pppox af_packet ppp_generic slhc > aes_i586 > CPU: 0 > EIP: 0060:[<c035b828>] Not tainted VLI > EFLAGS: 00010292 (2.6.23.12 #7) > EIP is at aes_crypt_copy+0x28/0x40 > eax: f7639ff0 ebx: f6c24050 ecx: 00000001 edx: f6c24030 > esi: f7e89dc8 edi: f7639ff0 ebp: 00010000 esp: f7e89dc8 Since the hardware must have 16-byte alignment, the following patch fixes this by open coding the alignment adjustment. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-12-28[CRYPTO] padlock: Fix spurious ECB page faultHerbert Xu
The xcryptecb instruction always processes an even number of blocks so we need to ensure th existence of an extra block if we have to process an odd number of blocks. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-11-23[CRYPTO] api: Fix potential race in crypto_remove_spawnHerbert Xu
As it is crypto_remove_spawn may try to unregister an instance which is yet to be registered. This patch fixes this by checking whether the instance has been registered before attempting to remove it. It also removes a bogus cra_destroy check in crypto_register_instance as 1) it's outside the mutex; 2) we have a check in __crypto_register_alg already. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-11-23[CRYPTO] authenc: Move initialisations up to shut up gccHerbert Xu
It seems that newer versions of gcc have regressed in their abilities to analyse initialisations. This patch moves the initialisations up to avoid the warnings. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-11-17Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86 * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86: x86: simplify "make ARCH=x86" and fix kconfig all.config x86: reboot fixup for wrap2c board x86: check boundary in count setup resource x86: fix reboot with no keyboard attached x86: add hpet sanity checks x86: on x86_64, correct reading of PC RTC when update in progress in time_64.c x86: fix freeze in x86_64 RTC update code in time_64.c ntp: fix typo that makes sync_cmos_clock erratic Remove x86 merge artifact from top Makefile x86: fixup cpu_info array conversion x86: show cpuinfo only for online CPUs x86: fix cpu-hotplug regression x86: ignore the sys_getcpu() tcache parameter x86: voyager use correct header file name x86: fix smp init sections x86: fix voyager_cat_init section x86: fix bogus memcpy in es7000_check_dsdt()
2007-11-17x86: simplify "make ARCH=x86" and fix kconfig all.configSam Ravnborg
Simplify "make ARCH=x86" and fix kconfig so we again can set 64BIT in all.config. For a fix the diffstat is nice: 6 files changed, 3 insertions(+), 36 deletions(-) The patch reverts these commits: - 0f855aa64b3f63d35a891510cf7db932a435c116 ("kconfig: add helper to set config symbol from environment variable") - 2a113281f5cd2febbab21a93c8943f8d3eece4d3 ("kconfig: use $K64BIT to set 64BIT with all*config targets") Roman Zippel pointed out that kconfig supported string compares so the additional complexity introduced by the above two patches were not needed. With this patch we have following behaviour: # make {allno,allyes,allmod,rand}config [ARCH=...] option \ host arch | 32bit | 64bit ===================================================== ./. | 32bit | 64bit ARCH=x86 | 32bit | 32bit ARCH=i386 | 32bit | 32bit ARCH=x86_64 | 64bit | 64bit The general rule are that ARCH= and native architecture takes precedence over the configuration. So make ARCH=i386 [whatever] will always build a 32-bit kernel no matter what the configuration says. The configuration will be updated to 32-bit if it was configured to 64-bit and the other way around. This behaviour is consistent with previous behaviour so no suprises here. make ARCH=x86 will per default result in a 32-bit kernel but as the only ARCH= value x86 allow the user to select between 32-bit and 64-bit using menuconfig. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andreas Herrmann <aherrman@arcor.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
Simplify "make ARCH=x86" and fix kconfig so we again can set 64BIT in all.config. For a fix the diffstat is nice: 6 files changed, 3 insertions(+), 36 deletions(-) The patch reverts these commits: 0f855aa64b3f63d35a891510cf7db932a435c116 -> kconfig: add helper to set config symbol from environment variable 2a113281f5cd2febbab21a93c8943f8d3eece4d3 -> kconfig: use $K64BIT to set 64BIT with all*config targets Roman Zippel pointed out that kconfig supported string compares so the additional complexity introduced by the above two patches were not needed. With this patch we have following behaviour: # make {allno,allyes,allmod,rand}config [ARCH=...] option \ host arch | 32bit | 64bit ===================================================== ./. | 32bit | 64bit ARCH=x86 | 32bit | 32bit ARCH=i386 | 32bit | 32bit ARCH=x86_64 | 64bit | 64bit The general rule are that ARCH= and native architecture takes precedence over the configuration. So make ARCH=i386 [whatever] will always build a 32-bit kernel no matter what the configuration says. The configuration will be updated to 32-bit if it was configured to 64-bit and the other way around. This behaviour is consistent with previous behaviour so no suprises here. make ARCH=x86 will per default result in a 32-bit kernel but as the only ARCH= value x86 allow the user to select between 32-bit and 64-bit using menuconfig. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andreas Herrmann <aherrman@arcor.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com>
2007-11-17x86: reboot fixup for wrap2c boardDenys
Needed to make the wireless board, WRAP2C reboot. Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-11-17x86: check boundary in count setup resourceYinghai Lu
need to check info->res_num less than PCI_BUS_NUM_RESOURCES, so info->bus->resource[info->res_num] = res will not beyond of bus resource array when acpi returns too many resource entries. Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Gary Hade <gary.hade@us.ibm.com> Cc: Len Brown <lenb@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-11-17x86: fix reboot with no keyboard attachedTruxton Fulton
Attempt to fix http://bugzilla.kernel.org/show_bug.cgi?id=8378 Hiroto Shibuya wrote to tell me that he has a VIA EPIA-EK10000 which suffers from the reboot problem when no keyboard is attached. My first patch works for him: http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commit;h=59f4e7d572980a521b7bdba74ab71b21f5995538 But the latest patch does not work for him : http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commit;h=8b93789808756bcc1e5c90c99f1b1ef52f839a51 We found that it was necessary to also set the "disable keyboard" flag in the command byte, as the first patch was doing. The second patch tries to minimally modify the command byte, but it is not enough. Please consider this simple one-line patch to help people with low end VIA motherboards reboot when no keyboard is attached. Hiroto Shibuya has verified that this works for him (as I no longer have an afflicted machine). Additional discussion: Note that original patch from Truxton DOES disable keyboard and this has been in main tree since 2.6.14, thus it must have quite a bit of air time already. http://git.kernel.org/?p=linux/kernel/git/stable/linux-2.6.14.y.git;a=commit;h=59f4e7d572980a521b7bdba74ab71b21f5995538 Note that he only mention "System flag" in the description and comment, but in the code, "disable keyboard" flag is set. outb(0x14, 0x60); /* set "System flag" */ In 2.6.23, he made a change to read the current byte and then mask the flags, but along this change, he only set the "System flag" and dropped the setting of "disable keyboard" flag. http://git.kernel.org/?p=linux/kernel/git/stable/linux-2.6.23.y.git;a=commit;h=8b93789808756bcc1e5c90c99f1b1ef52f839a51 outb(cmd | 0x04, 0x60); /* set "System flag" */ So my request is to restore the setting of disable keyboard flag which has been there since 2.6.14 but disappeared in 2.6.23. Cc: Lee Garrett <lee-in-berlin@web.de> Cc: "Hiroto Shibuya" <hiroto.shibuya@gmail.com> Cc: Natalie Protasevich <protasnb@gmail.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Aristeu Rozanski <aris@ruivo.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-11-17x86: add hpet sanity checksThomas Gleixner
Some BIOSes advertise HPET at 0x0. We really do no want to allocate a resource there. Check for it and leave early. Other BIOSes tell us the HPET is at 0xfed0000000000000 instead of 0xfed00000. Add a check and fix it up with a warning on user request. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-11-17x86: on x86_64, correct reading of PC RTC when update in progress in time_64.cDavid P. Reed
Correct potentially unstable PC RTC time register reading in time_64.c Stop the use of an incorrect technique for reading the standard PC RTC timer, which is documented to "disconnect" time registers from the bus while updates are in progress. The use of UIP flag while interrupts are disabled to protect a 244 microsecond window is one of the Motorola spec sheet's documented ways to read the RTC time registers reliably. tglx: removed locking changes from original patch, as they gain nothing (read_persistent_clock is only called during boot, suspend, resume - so no hot path affected) and conflict with the paravirt locking scheme (see 32bit code), which we do not want to complicate for no benefit. Signed-off-by: David P. Reed <dpreed@reed.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-11-17x86: fix freeze in x86_64 RTC update code in time_64.cDavid P. Reed
Fix hard freeze on x86_64 when the ntpd service calls update_persistent_clock() A repeatable but randomly timed freeze has been happening in Fedora 6 and 7 for the last year, whenever I run the ntpd service on my AMD64x2 HP Pavilion dv9000z laptop. This freeze is due to the use of spin_lock(&rtc_lock) under the assumption (per a bad comment) that set_rtc_mmss is called only with interrupts disabled. The call from ntp.c to update_persistent_clock is made with interrupts enabled. Signed-off-by: David P. Reed <dpreed@reed.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-11-17ntp: fix typo that makes sync_cmos_clock erraticDavid P. Reed
Fix a typo in ntp.c that has caused updating of the persistent (RTC) clock when synced to NTP to behave erratically. When debugging a freeze that arises on my AMD64 machines when I run the ntpd service, I added a number of printk's to monitor the sync_cmos_clock procedure. I discovered that it was not syncing to cmos RTC every 11 minutes as documented, but instead would keep trying every second for hours at a time. The reason turned out to be a typo in sync_cmos_clock, where it attempts to ensure that update_persistent_clock is called very close to 500 msec. after a 1 second boundary (required by the PC RTC's spec). That typo referred to "xtime" in one spot, rather than "now", which is derived from "xtime" but not equal to it. This makes the test erratic, creating a "coin-flip" that decides when update_persistent_clock is called - when it is called, which is rarely, it may be at any time during the one second period, rather than close to 500 msec, so the value written is needlessly incorrect, too. Signed-off-by: David P. Reed Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-11-17Remove x86 merge artifact from top MakefileThomas Gleixner
The x86 merge modified the tags target to handle the two separate source directories. Remove it now that i386/x86_64 are gone completely. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-11-17x86: fixup cpu_info array conversionThomas Gleixner
92cb7612aee39642d109b8d935ad265e602c0563 sets cpu_info->cpu_index to zero for no reason. Referencing cpu_info->cpu_index now points always to CPU#0, which is apparently not what we want. Remove it. Spotted-by: Zou Nan hai <nanhai.zou@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-11-17x86: show cpuinfo only for online CPUsAndreas Herrmann
Fix regressions introduced with 92cb7612aee39642d109b8d935ad265e602c0563. It can happen that cpuinfo is displayed for CPUs that are not online or even worse for CPUs not present at all. As an example, following was shown for a "second" CPU of a single core K8 variant: processor : 0 vendor_id : unknown cpu family : 0 model : 0 model name : unknown stepping : 0 cache size : 0 KB fpu : yes fpu_exception : yes cpuid level : 0 wp : yes flags : bogomips : 0.00 clflush size : 0 cache_alignment : 0 address sizes : 0 bits physical, 0 bits virtual power management: Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-11-17x86: fix cpu-hotplug regressionAndreas Herrmann
Commit d435d862baca3e25e5eec236762a43251b1e7ffc ("cpu hotplug: mce: fix cpu hotplug error handling") changed the error handling in mce_cpu_callback. In cases where not all CPUs are brought up during boot (e.g. using maxcpus and additional_cpus parameters) mce_cpu_callback now returns NOTFIY_BAD because for such CPUs cpu_data is not completely filled when the notifier is called. Thus mce_create_device fails right at its beginning: if (!mce_available(&cpu_data[cpu])) return -EIO; As a quick fix I suggest to check boot_cpu_data for MCE. To reproduce this regression: (1) boot with maxcpus=2 addtional_cpus=2 on a 4 CPU x86-64 system (2) # echo 1 >/sys/devices/system/cpu/cpu2/online -bash: echo: write error: Invalid argument dmesg shows: _cpu_up: attempt to bring up CPU 2 failed Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-11-17x86: ignore the sys_getcpu() tcache parameterIngo Molnar
dont use the vgetcpu tcache - it's causing problems with tasks migrating, they'll see the old cache up to a jiffy after the migration, further increasing the costs of the migration. In the worst case they see a complete bogus information from the tcache, when a sys_getcpu() call "invalidated" the cache info by incrementing the jiffies _and_ the cpuid info in the cache and the following vdso_getcpu() call happens after vdso_jiffies have been incremented. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-11-17x86: voyager use correct header file nameRandy Dunlap
Fix header file name for Voyager build. In file included from arch/x86/kernel/setup_32.c:61: include/asm-x86/mach-voyager/setup_arch.h:2:26: error: asm/setup_32.h: No such file or directory make[1]: *** [arch/x86/kernel/setup_32.o] Error 1 Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-11-17x86: fix smp init sectionsRandy Dunlap
Fix Voyager section mismatch due to using __devinit instead of __cpuinit. WARNING: vmlinux.o(.text+0xd943): Section mismatch: reference to .init.text:init_gdt (between 'voyager_smp_prepare_boot_cpu' and 'smp_vic_cmn_interrupt') Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-11-17x86: fix voyager_cat_init sectionRandy Dunlap
Fix Voyager section mismatches: voyager_cat_init() should be __init. WARNING: vmlinux.o(.text+0xee83): Section mismatch: reference to .init.data:eprom_buf (between 'voyager_cat_init' and 'aes_enc_blk') WARNING: vmlinux.o(.text+0xeea6): Section mismatch: reference to .init.data: (between 'voyager_cat_init' and 'aes_enc_blk') WARNING: vmlinux.o(.text+0xeeac): Section mismatch: reference to .init.data: (between 'voyager_cat_init' and 'aes_enc_blk') WARNING: vmlinux.o(.text+0xeeb2): Section mismatch: reference to .init.data: (between 'voyager_cat_init' and 'aes_enc_blk') WARNING: vmlinux.o(.text+0xef4c): Section mismatch: reference to .init.data: (between 'voyager_cat_init' and 'aes_enc_blk') WARNING: vmlinux.o(.text+0xef56): Section mismatch: reference to .init.data: (between 'voyager_cat_init' and 'aes_enc_blk') WARNING: vmlinux.o(.text+0xf10f): Section mismatch: reference to .init.data:eprom_buf (between 'voyager_cat_init' and 'aes_enc_blk') WARNING: vmlinux.o(.text+0xf13b): Section mismatch: reference to .init.data: (between 'voyager_cat_init' and 'aes_enc_blk') WARNING: vmlinux.o(.text+0xf14b): Section mismatch: reference to .init.data: (between 'voyager_cat_init' and 'aes_enc_blk') WARNING: vmlinux.o(.text+0xf159): Section mismatch: reference to .init.data: (between 'voyager_cat_init' and 'aes_enc_blk') WARNING: vmlinux.o(.text+0xf1b1): Section mismatch: reference to .init.data:eprom_buf (between 'voyager_cat_init' and 'aes_enc_blk') WARNING: vmlinux.o(.text+0xf1bb): Section mismatch: reference to .init.data: (between 'voyager_cat_init' and 'aes_enc_blk') WARNING: vmlinux.o(.text+0xf1c1): Section mismatch: reference to .init.data:eprom_buf (between 'voyager_cat_init' and 'aes_enc_blk') WARNING: vmlinux.o(.text+0xf1c7): Section mismatch: reference to .init.data:eprom_buf (between 'voyager_cat_init' and 'aes_enc_blk') WARNING: vmlinux.o(.text+0xf1e6): Section mismatch: reference to .init.data: (between 'voyager_cat_init' and 'aes_enc_blk') Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-11-17x86: fix bogus memcpy in es7000_check_dsdt()Thomas Gleixner
es7000_check_dst() contains a memcpy from 0, which probably should have been a memset. Remove it and check the retunr value from acpi_get_table_header. Noticed by: Joe Perches <joe@perches.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
