2014-01-07extcon: gpio: Request gpio pin before modifying its stateGuenter Roeck
Commit 338de0ca (extcon: gpio: Use gpio driver/chip debounce if supported) introduced a call to gpio_set_debounce() before actually requesting the respective gpio pin from the gpio subsystem. The gpio subsystem expects that a gpio pin was requested before modifying its state. Not doing so results in a warning from gpiolib, and the gpio pin is auto-requested. This in turn causes the subsequent devm_gpio_request_one() to fail. So devm_gpio_request_one() must be called prior to calling gpio_set_debounce(). Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2013-12-15Linux 3.13-rc4v3.13-rc4Linus Torvalds
2013-12-15null_blk: mem garbage on NUMA systems during initMatias Bjorling
For NUMA systems, initializing the blk-mq layer and using per node hctx. We initialize submit queues to 1, while blk-mq nr_hw_queues is initialized to the number of NUMA nodes. This makes the null_init_hctx function overwrite memory outside of what it allocated. In my case it lead to writing garbage into struct request_queue's mq_map. Signed-off-by: Matias Bjorling <m@bjorling.me> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-15radeon_pm: fix oops in hwmon_attributes_visible() and ↵Sergey Senozhatsky
radeon_hwmon_show_temp_thresh() Since commit ec39f64bba34 ("drm/radeon/dpm: Convert to use devm_hwmon_register_with_groups") radeon_hwmon_init() is using hwmon_device_register_with_groups(), which sets `rdev' as a device private driver_data, while hwmon_attributes_visible() and radeon_hwmon_show_temp_thresh() are still waiting for `drm_device'. Fix them by using dev_get_drvdata(), in order to avoid this oops: BUG: unable to handle kernel paging request at 0000000000001e28 IP: [<ffffffffa02ae8b4>] hwmon_attributes_visible+0x18/0x3d [radeon] PGD 15057e067 PUD 151a8e067 PMD 0 Oops: 0000 [#1] PREEMPT SMP Call Trace: internal_create_group+0x114/0x1d9 sysfs_create_group+0xe/0x10 sysfs_create_groups+0x22/0x5f device_add+0x34f/0x501 device_register+0x15/0x18 hwmon_device_register_with_groups+0xb5/0xed radeon_hwmon_init+0x56/0x7c [radeon] radeon_pm_init+0x134/0x7e5 [radeon] radeon_modeset_init+0x75f/0x8ed [radeon] radeon_driver_load_kms+0xc6/0x187 [radeon] drm_dev_register+0xf9/0x1b4 [drm] drm_get_pci_dev+0x98/0x129 [drm] radeon_pci_probe+0xa3/0xac [radeon] pci_device_probe+0x6e/0xcf driver_probe_device+0x98/0x1c4 __driver_attach+0x5c/0x7e bus_for_each_dev+0x7b/0x85 driver_attach+0x19/0x1b bus_add_driver+0x104/0x1ce driver_register+0x89/0xc5 __pci_register_driver+0x58/0x5b drm_pci_init+0x86/0xea [drm] radeon_init+0x97/0x1000 [radeon] do_one_initcall+0x7f/0x117 load_module+0x1583/0x1bb4 SyS_init_module+0xa0/0xaf Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Alexander Deucher <Alexander.Deucher@amd.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Revert CHECKSUM_COMPLETE optimization in pskb_trim_rcsum(), I can't figure out why it breaks things. 2) Fix comparison in netfilter ipset's hash_netnet4_data_equal(), it was basically doing "x == x", from Dave Jones. 3) Freescale FEC driver was DMA mapping the wrong number of bytes, from Sebastian Siewior. 4) Blackhole and prohibit routes in ipv6 were not doing the right thing because their ->input and ->output methods were not being assigned correctly. Now they behave properly like their ipv4 counterparts. From Kamala R. 5) Several drivers advertise the NETIF_F_FRAGLIST capability, but really do not support this feature and will send garbage packets if fed fraglist SKBs. From Eric Dumazet. 6) Fix long standing user triggerable BUG_ON over loopback in RDS protocol stack, from Venkat Venkatsubra. 7) Several not so common code paths can potentially try to invoke packet scheduler actions that might be NULL without checking. Shore things up by either 1) defining a method as mandatory and erroring on registration if that method is NULL 2) defininig a method as optional and the registration function hooks up a default implementation when NULL is seen. From Jamal Hadi Salim. 8) Fix fragment detection in xen-natback driver, from Paul Durrant. 9) Kill dangling enter_memory_pressure method in cg_proto ops, from Eric W Biederman. 10) SKBs that traverse namespaces should have their local_df cleared, from Hannes Frederic Sowa. 11) IOCB file position is not being updated by macvtap_aio_read() and tun_chr_aio_read(). From Zhi Yong Wu. 12) Don't free virtio_net netdev before releasing all of the NAPI instances. From Andrey Vagin. 13) Procfs entry leak in xt_hashlimit, from Sergey Popovich. 14) IPv6 routes that are no cached routes should not count against the garbage collection limits. We had this almost right, but were missing handling addrconf generated routes properly. From Hannes Frederic Sowa. 15) fib{4,6}_rule_suppress() have to consider potentially seeing NULL route info when they are called, from Stefan Tomanek. 16) TUN and MACVTAP have had truncated packet signalling for some time, fix from Jason Wang. 17) Fix use after frrr in __udp4_lib_rcv(), from Eric Dumazet. 18) xen-netback does not interpret the NAPI budget properly for TX work, fix from Paul Durrant. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (132 commits) igb: Fix for issue where values could be too high for udelay function. i40e: fix null dereference xen-netback: fix gso_prefix check net: make neigh_priv_len in struct net_device 16bit instead of 8bit drivers: net: cpsw: fix for cpsw crash when build as modules xen-netback: napi: don't prematurely request a tx event xen-netback: napi: fix abuse of budget sch_tbf: use do_div() for 64-bit divide udp: ipv4: must add synchronization in udp_sk_rx_dst_set() net:fec: remove duplicate lines in comment about errata ERR006358 Revert "8390 : Replace ei_debug with msg_enable/NETIF_MSG_* feature" 8390 : Replace ei_debug with msg_enable/NETIF_MSG_* feature xen-netback: make sure skb linear area covers checksum field net: smc91x: Fix device tree based configuration so it's usable udp: ipv4: fix potential use after free in udp_v4_early_demux() macvtap: signal truncated packets tun: unbreak truncated packet signalling net: sched: htb: fix the calculation of quantum net: sched: tbf: fix the calculation of max_size micrel: add support for KSZ8041RNLI ...
2013-12-15Merge branch 'x86/urgent' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Peter Anvin: "This is a pretty small batch: The biggest single change is to stop using EFI time services on 32-bit platforms. This matches our current behavior on 64-bit platforms as we already had ruled them out there as being too unreliable. Turns out that affects 32-bit platforms, too. One NULL pointer fix for SGI UV. Two minor build fixes, one of which only affects icc and the other which affects icc and future versions or nonstandard default settings of gcc" * 'x86/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, efi: Don't use (U)EFI time services on 32 bit x86, build, icc: Remove uninitialized_var() from compiler-intel.h x86/UV: Fix NULL pointer dereference in uv_flush_tlb_others() if the 'nobau' boot option is used x86, build: Pass in additional -mno-mmx, -mno-sse options
2013-12-15Merge tag 'pci-v3.13-fixes-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "PCI device hotplug - Move device_del() from pci_stop_dev() to pci_destroy_dev() (Rafael Wysocki) Host bridge drivers - Update maintainers for DesignWare, i.MX6, Armada, R-Car (Bjorn Helgaas) - mvebu: Return 'unsupported' for Interrupt Line and Interrupt Pin (Jason Gunthorpe) Miscellaneous - Avoid unnecessary CPU switch when calling .probe() (Alexander Duyck) - Revert "workqueue: allow work_on_cpu() to be called recursively" (Bjorn Helgaas) - Disable Bus Master only on kexec reboot (Khalid Aziz) - Omit PCI ID macro strings to shorten quirk names for LTO (Michal Marek)" * tag 'pci-v3.13-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: MAINTAINERS: Add DesignWare, i.MX6, Armada, R-Car PCI host maintainers PCI: Disable Bus Master only on kexec reboot PCI: mvebu: Return 'unsupported' for Interrupt Line and Interrupt Pin PCI: Omit PCI ID macro strings to shorten quirk names PCI: Move device_del() from pci_stop_dev() to pci_destroy_dev() Revert "workqueue: allow work_on_cpu() to be called recursively" PCI: Avoid unnecessary CPU switch when calling driver .probe() method
2013-12-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull SELinux fixes from James Morris. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: selinux: process labeled IPsec TCP SYN-ACK packets properly in selinux_ip_postroute() selinux: look for IPsec labels on both inbound and outbound packets selinux: handle TCP SYN-ACK packets correctly in selinux_ip_postroute() selinux: handle TCP SYN-ACK packets correctly in selinux_ip_output() selinux: fix possible memory leak
2013-12-15Revert "selinux: consider filesystem subtype in policies"Linus Torvalds
This reverts commit 102aefdda4d8275ce7d7100bc16c88c74272b260. Tom London reports that it causes sync() to hang on Fedora rawhide: https://bugzilla.redhat.com/show_bug.cgi?id=1033965 and Josh Boyer bisected it down to this commit. Reverting the commit in the rawhide kernel fixes the problem. Eric Paris root-caused it to incorrect subtype matching in that commit breaking fuse, and has a tentative patch, but by now we're better off retrying this in 3.14 rather than playing with it any more. Reported-by: Tom London <selinux@gmail.com> Bisected-by: Josh Boyer <jwboyer@fedoraproject.org> Acked-by: Eric Paris <eparis@redhat.com> Cc: James Morris <jmorris@namei.org> Cc: Anand Avati <avati@redhat.com> Cc: Paul Moore <paul@paul-moore.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-14igb: Fix for issue where values could be too high for udelay function.Carolyn Wyborny
This patch changes the igb_phy_has_link function to check the value of the parameter before deciding to use udelay or mdelay in order to be sure that the value is not too high for udelay function. CC: stable kernel <stable@vger.kernel.org> # 3.9+ Signed-off-by: Sunil K Pandey <sunil.k.pandey@intel.com> Signed-off-by: Kevin B Smith <kevin.b.smith@intel.com> Signed-off-by: Carolyn Wyborny <carolyn.wyborny@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-14i40e: fix null dereferenceJesse Brandeburg
If the vsi->tx_rings structure is NULL we don't want to panic. Change-Id: Ic694f043701738c434e8ebe0caf0673f4410dc10 Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Tested-by: Kavindya Deegala <kavindya.s.deegala@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-14Merge tag 'edac_fixes_for_3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp Pull EDAC fix from Borislav Petkov: "Silence a compiler warning in sb_edac" * tag 'edac_fixes_for_3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp: sb_edac: Shut up compiler warning when EDAC_DEBUG is enabled
2013-12-13Merge branch 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "This resolves some further issues with the dma mask changes on ARM which have been found by TI and others, and also some corner cases with the updates to the virtual to physical address translations. Konstantin also found some problems with the unwinder, which now performs tighter verification that the stack is valid while unwinding" * 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: ARM: fix asm/memory.h build error ARM: 7917/1: cacheflush: correctly limit range of memory region being flushed ARM: 7913/1: fix framepointer check in unwind_frame ARM: 7912/1: check stack pointer in get_wchan ARM: 7909/1: mm: Call setup_dma_zone() post early_paging_init() ARM: 7908/1: mm: Fix the arm_dma_limit calculation ARM: another fix for the DMA mapping checks
2013-12-13Merge tag 'arc-fixes-for-3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc Pull ARC fixes from Vineet Gupta: "These are couple of weeks old already, but I just couldn't get them to you earlier. - couple of fixes for recently added perf code - build time extable sort" * tag 'arc-fixes-for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc: ARC: [perf] Fix a few thinkos ARC: Add guard macro to uapi/asm/unistd.h ARC: extable: Enable sorting at build time
2013-12-13Merge tag 'dm-3.13-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm Pull device mapper fixes from Mike Snitzer: "A set of device-mapper fixes for 3.13. A fix for possible memory corruption during DM table load, fix a possible leak of snapshot space in case of a crash, fix a possible deadlock due to a shared workqueue in the delay target, fix to initialize read-only module parameters that are used to export metrics for dm stats and dm bufio. Quite a few stable fixes were identified for both the thin- provisioning and caching targets as a result of increased regression testing using the device-mapper-test-suite (dmts). The most notable of these are the reference counting fixes for the space map btree that is used by the dm-array interface -- without these the dm-cache metadata will leak, resulting in dm-cache devices running out of metadata blocks. Also, some important fixes related to the thin-provisioning target's transition to read-only mode on error" * tag 'dm-3.13-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm: dm array: fix a reference counting bug in shadow_ablock dm space map: disallow decrementing a reference count below zero dm stats: initialize read-only module parameter dm bufio: initialize read-only module parameters dm cache: actually resize cache dm cache: update Documentation for invalidate_cblocks's range syntax dm cache policy mq: fix promotions to occur as expected dm thin: allow pool in read-only mode to transition to read-write mode dm thin: re-establish read-only state when switching to fail mode dm thin: always fallback the pool mode if commit fails dm thin: switch to read-only mode if metadata space is exhausted dm thin: switch to read only mode if a mapping insert fails dm space map metadata: return on failure in sm_metadata_new_block dm table: fail dm_table_create on dm_round_up overflow dm snapshot: avoid snapshot space leak on crash dm delay: fix a possible deadlock due to shared workqueue
2013-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull HID fixes from Jiri Kosina: - Genius Gx Imperator Keyboard regression fix (missing break in case), by Ben Hutchings - duplicate sysfs entry error fix for hid-sensor-hub driver, by Srinivas Pandruvada * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: hid-sensor-hub: fix duplicate sysfs entry error HID: kye: Fix missing break in kye_report_fixup()
2013-12-13ARM: fix asm/memory.h build errorRussell King
Jason Gunthorpe reports a build failure when ARM_PATCH_PHYS_VIRT is not defined: In file included from arch/arm/include/asm/page.h:163:0, from include/linux/mm_types.h:16, from include/linux/sched.h:24, from arch/arm/kernel/asm-offsets.c:13: arch/arm/include/asm/memory.h: In function '__virt_to_phys': arch/arm/include/asm/memory.h:244:40: error: 'PHYS_OFFSET' undeclared (first use in this function) arch/arm/include/asm/memory.h:244:40: note: each undeclared identifier is reported only once for each function it appears in arch/arm/include/asm/memory.h: In function '__phys_to_virt': arch/arm/include/asm/memory.h:249:13: error: 'PHYS_OFFSET' undeclared (first use in this function) Fixes: ca5a45c06cd4 ("ARM: mm: use phys_addr_t appropriately in p2v and v2p conversions") Tested-By: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-12-13Merge tag 'regulator-v3.13-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator Pull regulator fixes from Mark Brown: "A small set of driver fixes plus one larger core change which changes the way we check to see if we're using DT so that there aren't any races between deciding we're using DT and the regulator subsystem noticing. This makes the new support for substituting a dummy regulator and optional regulators work a lot better on DT systems since it ensures that we don't trigger probe deferral when we shouldn't which was causing bugs in clients" * tag 'regulator-v3.13-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: regulator: pfuze100: allow misprogrammed ID regulator: pfuze100: Fix address of FABID regulator: as3722: set the correct current limit regulator: core: Check for DT every time we check full constraints regulator: core: Replace checks of have_full_constraints with a function
2013-12-13Merge tag 'regmap-v3.13-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap Pull regmap fixes from Mark Brown: "Two small changes to fix some error handling and checking (both of which would be quite serious if the errors trigger) plus a trivial documentation fix" * tag 'regmap-v3.13-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap: regmap: use IS_ERR() to check clk_get() results regmap: make sure we unlock on failure in regmap_bulk_write regmap: trivial comment fix (copy'n'paste error)
2013-12-13Merge branch 'i2c/for-current' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c fixes from Wolfram Sang: "Here are two simple but wanted fixes for the i2c subsystem" * 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: i2c: imx: Check the return value from clk_prepare_enable() i2c: mux: Inherit retry count and timeout from parent for muxed bus
2013-12-13Merge tag 'for-linus-20131212' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD fixes from Brian Norris: "Two MTD fixes, for the pxa3xx-nand driver: - This driver was not ready to fully Armada 370 NAND, with particularly notable problems seen on flash with 2KB page sizes. This "compatible" entry really should have been held back until 3.14 or later. - Fix a bug seen in rare cases on the error path of a failed probe attempt, where we free unallocated DMA resources" * tag 'for-linus-20131212' of git://git.infradead.org/linux-mtd: mtd: nand: pxa3xx: Use info->use_dma to release DMA resources Partially revert "mtd: nand: pxa3xx: Introduce 'marvell,armada370-nand' compatible string"
2013-12-13Merge branch 'fixes' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine fixes from Vinod Koul: "Here is the common fixes PULL for dmaengine. Dan has been working on fixing the build issues in bunch of drivers. Here we have one fixing s3c24xx-dma, along with fix from Russell on pl08x. Also we have Kuninori rcar dma fixes. The s3c24xx-dma which was added in last merge window missed updates to usage of DMA_COMPLETE so converting the last driver" * 'fixes' of git://git.infradead.org/users/vkoul/slave-dma: dma: fix build breakage in s3c24xx-dma Fix pl08x warnings rcar-hpbdma: initialise plane information when halted rcar-hpbdma: fixup channel busy check for double plane rcar-hpbdma: add max transfer size dma: mmp_pdma: add missing platform_set_drvdata() in mmp_pdma_probe() dmaengine: s3c24xx-dma: use DMA_COMPLETE for dma completion status
2013-12-13dm array: fix a reference counting bug in shadow_ablockJoe Thornber
An old array block could have its reference count decremented below zero when it is being replaced in the btree by a new array block. The fix is to increment the old ablock's reference count just before inserting a new ablock into the btree. Signed-off-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Cc: stable@vger.kernel.org # 3.9+
2013-12-13dm space map: disallow decrementing a reference count below zeroJoe Thornber
The old behaviour, returning -EINVAL if a ref_count of 0 would be decremented, was removed in commit f722063 ("dm space map: optimise sm_ll_dec and sm_ll_inc"). To fix this regression we return an error code from the mutator function pointer passed to sm_ll_mutate() and have dec_ref_count() return -EINVAL if the old ref_count is 0. Add a DMERR to reflect the potential seriousness of this error. Also, add missing dm_tm_unlock() to sm_ll_mutate()'s error path. With this fix the following dmts regression test now passes: dmtest run --suite cache -n /metadata_use_kernel/ The next patch fixes the higher-level dm-array code that exposed this regression. Signed-off-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Cc: stable@vger.kernel.org # 3.12+
2013-12-13Merge remote-tracking branch 'regulator/topic/constraints' into regulator-linusMark Brown
2013-12-13Merge branch 'master' of git://git.infradead.org/users/pcmoore/selinux_fixes ↵James Morris
into for-linus
2013-12-12Merge branch 'akpm' (fixes from Andrew)Linus Torvalds
Merge patches from Andrew Morton: "13 fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: mm: memcg: do not allow task about to OOM kill to bypass the limit mm: memcg: fix race condition between memcg teardown and swapin thp: move preallocated PTE page table on move_huge_pmd() mfd/rtc: s5m: fix register updating by adding regmap for RTC rtc: s5m: enable IRQ wake during suspend rtc: s5m: limit endless loop waiting for register update rtc: s5m: fix unsuccesful IRQ request during probe drivers/rtc/rtc-s5m.c: fix info->rtc assignment include/linux/kernel.h: make might_fault() a nop for !MMU drivers/rtc/rtc-at91rm9200.c: correct alarm over day/month wrap procfs: also fix proc_reg_get_unmapped_area() for !MMU case mm: memcg: do not declare OOM from __GFP_NOFAIL allocations include/linux/hugetlb.h: make isolate_huge_page() an inline
2013-12-12mm: memcg: do not allow task about to OOM kill to bypass the limitJohannes Weiner
Commit 4942642080ea ("mm: memcg: handle non-error OOM situations more gracefully") allowed tasks that already entered a memcg OOM condition to bypass the memcg limit on subsequent allocation attempts hoping this would expedite finishing the page fault and executing the kill. David Rientjes is worried that this breaks memcg isolation guarantees and since there is no evidence that the bypass actually speeds up fault processing just change it so that these subsequent charge attempts fail outright. The notable exception being __GFP_NOFAIL charges which are required to bypass the limit regardless. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reported-by: David Rientjes <rientjes@google.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-bt: David Rientjes <rientjes@google.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-12mm: memcg: fix race condition between memcg teardown and swapinJohannes Weiner
There is a race condition between a memcg being torn down and a swapin triggered from a different memcg of a page that was recorded to belong to the exiting memcg on swapout (with CONFIG_MEMCG_SWAP extension). The result is unreclaimable pages pointing to dead memcgs, which can lead to anything from endless loops in later memcg teardown (the page is charged to all hierarchical parents but is not on any LRU list) or crashes from following the dangling memcg pointer. Memcgs with tasks in them can not be torn down and usually charges don't show up in memcgs without tasks. Swapin with the CONFIG_MEMCG_SWAP extension is the notable exception because it charges the cgroup that was recorded as owner during swapout, which may be empty and in the process of being torn down when a task in another memcg triggers the swapin: teardown: swapin: lookup_swap_cgroup_id() rcu_read_lock() mem_cgroup_lookup() css_tryget() rcu_read_unlock() disable css_tryget() call_rcu() offline_css() reparent_charges() res_counter_charge() (hierarchical!) css_put() css_free() pc->mem_cgroup = dead memcg add page to dead lru Add a final reparenting step into css_free() to make sure any such raced charges are moved out of the memcg before it's finally freed. In the longer term it would be cleaner to have the css_tryget() and the res_counter charge under the same RCU lock section so that the charge reparenting is deferred until the last charge whose tryget succeeded is visible. But this will require more invasive changes that will be harder to evaluate and backport into stable, so better defer them to a separate change set. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-12thp: move preallocated PTE page table on move_huge_pmd()Kirill A. Shutemov
Andrey Wagin reported crash on VM_BUG_ON() in pgtable_pmd_page_dtor() with fallowing backtrace: free_pgd_range+0x2bf/0x410 free_pgtables+0xce/0x120 unmap_region+0xe0/0x120 do_munmap+0x249/0x360 move_vma+0x144/0x270 SyS_mremap+0x3b9/0x510 system_call_fastpath+0x16/0x1b The crash can be reproduce with this test case: #define _GNU_SOURCE #include <sys/mman.h> #include <stdio.h> #include <unistd.h> #define MB (1024 * 1024UL) #define GB (1024 * MB) int main(int argc, char **argv) { char *p; int i; p = mmap((void *) GB, 10 * MB, PROT_READ | PROT_WRITE, MAP_PRIVATE | MAP_ANONYMOUS | MAP_FIXED, -1, 0); for (i = 0; i < 10 * MB; i += 4096) p[i] = 1; mremap(p, 10 * MB, 10 * MB, MREMAP_FIXED | MREMAP_MAYMOVE, 2 * GB); return 0; } Due to split PMD lock, we now store preallocated PTE tables for THP pages per-PMD table. It means we need to move them to other PMD table if huge PMD moved there. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reported-by: Andrey Vagin <avagin@openvz.org> Tested-by: Andrey Vagin <avagin@openvz.org> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-12mfd/rtc: s5m: fix register updating by adding regmap for RTCKrzysztof Kozlowski
Rename old regmap field of "struct sec_pmic_dev" to "regmap_pmic" and add new regmap for RTC. On S5M8767A registers were not properly updated and read due to usage of the same regmap as the PMIC. This could be observed in various hangs, e.g. in infinite loop during waiting for UDR field change. On this chip family the RTC has different I2C address than PMIC so additional regmap is needed. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Mark Brown <broonie@linaro.org> Acked-by: Sangbeom Kim <sbkim73@samsung.com> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Lee Jones <lee.jones@linaro.org> Cc: Liam Girdwood <lgirdwood@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-12rtc: s5m: enable IRQ wake during suspendKrzysztof Kozlowski
Add PM suspend/resume ops to rtc-s5m driver and enable IRQ wake during suspend so the RTC would act like a wake up source. This allows waking up from suspend to RAM on RTC alarm interrupt. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Mark Brown <broonie@linaro.org> Acked-by: Sangbeom Kim <sbkim73@samsung.com> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Lee Jones <lee.jones@linaro.org> Cc: Liam Girdwood <lgirdwood@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-12rtc: s5m: limit endless loop waiting for register updateKrzysztof Kozlowski
After setting alarm or time the driver is waiting for UDR register to be cleared indicating that registers data have been transferred. Limit the endless loop to only 5 retries. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Mark Brown <broonie@linaro.org> Acked-by: Sangbeom Kim <sbkim73@samsung.com> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Lee Jones <lee.jones@linaro.org> Cc: Liam Girdwood <lgirdwood@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-12rtc: s5m: fix unsuccesful IRQ request during probeKrzysztof Kozlowski
Probe failed for rtc-s5m: s5m-rtc s5m-rtc: Failed to request alarm IRQ: 12: -22 s5m-rtc: probe of s5m-rtc failed with error -22 Fix rtc-s5m interrupt request by using regmap_irq_get_virq() for mapping the IRQ. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Mark Brown <broonie@linaro.org> Acked-by: Sangbeom Kim <sbkim73@samsung.com> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Lee Jones <lee.jones@linaro.org> Cc: Liam Girdwood <lgirdwood@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-12drivers/rtc/rtc-s5m.c: fix info->rtc assignmentGeert Uytterhoeven
Fix this warning: drivers/rtc/rtc-s5m.c: In function `s5m_rtc_probe': drivers/rtc/rtc-s5m.c:545: warning: assignment from incompatible pointer type struct s5m_rtc_info.rtc has type "struct regmap *", while struct sec_pmic_dev.rtc has type "struct i2c_client *". Probably the author wanted to assign "struct sec_pmic_dev.regmap", which has the correct type. Also, as "rtc" doesn't make much sense as a name for a regmap, rename it to "regmap". Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Sangbeom Kim <sbkim73@samsung.com> Cc: Sachin Kamat <sachin.kamat@linaro.org> Tested-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-12include/linux/kernel.h: make might_fault() a nop for !MMUAxel Lin
The machine cannot fault if !MUU, so make might_fault() a nop for !MMU. This fixes below build error if !CONFIG_MMU && (CONFIG_PROVE_LOCKING=y || CONFIG_DEBUG_ATOMIC_SLEEP=y): arch/arm/kernel/built-in.o: In function `arch_ptrace': arch/arm/kernel/ptrace.c:852: undefined reference to `might_fault' arch/arm/kernel/built-in.o: In function `restore_sigframe': arch/arm/kernel/signal.c:173: undefined reference to `might_fault' ... arch/arm/kernel/built-in.o:arch/arm/kernel/signal.c:177: more undefined references to `might_fault' follow make: *** [vmlinux] Error 1 Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-12drivers/rtc/rtc-at91rm9200.c: correct alarm over day/month wrapLinus Pizunski
Update month and day of month to the alarm month/day instead of current day/month when setting the RTC alarm mask. Signed-off-by: Linus Pizunski <linus@narrativeteam.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-12procfs: also fix proc_reg_get_unmapped_area() for !MMU caseJan Beulich
Commit fad1a86e25e0 ("procfs: call default get_unmapped_area on MMU-present architectures"), as its title says, took care of only the MMU case, leaving the !MMU side still in the regressed state (returning -EIO in all cases where pde->proc_fops->get_unmapped_area is NULL). From the fad1a86e25e0 changelog: "Commit c4fe24485729 ("sparc: fix PCI device proc file mmap(2)") added proc_reg_get_unmapped_area in proc_reg_file_ops and proc_reg_file_ops_no_compat, by which now mmap always returns EIO if get_unmapped_area method is not defined for the target procfs file, which causes regression of mmap on /proc/vmcore. To address this issue, like get_unmapped_area(), call default current->mm->get_unmapped_area on MMU-present architectures if pde->proc_fops->get_unmapped_area, i.e. the one in actual file operation in the procfs file, is not defined" Signed-off-by: Jan Beulich <jbeulich@suse.com> Cc: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: David S. Miller <davem@davemloft.net> Cc: <stable@vger.kernel.org> [3.12.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-12mm: memcg: do not declare OOM from __GFP_NOFAIL allocationsJohannes Weiner
Commit 84235de394d9 ("fs: buffer: move allocation failure loop into the allocator") started recognizing __GFP_NOFAIL in memory cgroups but forgot to disable the OOM killer. Any task that does not fail allocation will also not enter the OOM completion path. So don't declare an OOM state in this case or it'll be leaked and the task be able to bypass the limit until the next userspace-triggered page fault cleans up the OOM state. Reported-by: William Dauchy <wdauchy@gmail.com> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: <stable@vger.kernel.org> [3.12.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-12include/linux/hugetlb.h: make isolate_huge_page() an inlineNaoya Horiguchi
With CONFIG_HUGETLBFS=n: mm/migrate.c: In function `do_move_page_to_node_array': include/linux/hugetlb.h:140:33: warning: statement with no effect [-Wunused-value] #define isolate_huge_page(p, l) false ^ mm/migrate.c:1170:4: note: in expansion of macro `isolate_huge_page' isolate_huge_page(page, &pagelist); Reported-by: Borislav Petkov <bp@alien8.de> Tested-by: Borislav Petkov <bp@alien8.de> Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-12Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull kvm fixes from Paolo Bonzini: "Four security fixes for KVM on x86. Thanks to Andrew Honig and Lars Bull from Google for reporting them" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: x86: fix guest-initiated crash with x2apic (CVE-2013-6376) KVM: x86: Convert vapic synchronization to _cached functions (CVE-2013-6368) KVM: x86: Fix potential divide by 0 in lapic (CVE-2013-6367) KVM: Improve create VCPU parameter (CVE-2013-4587)
2013-12-12Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "Another week, another batch of fixes. Again, OMAP regressions due to move to DT is the bulk of the changes here, but this should be the last of it for 3.13. There are also a handful of OMAP hwmod changes (power management, reset handling) for USB on OMAP3 that fixes some longish-standing bugs around USB resets. There are a couple of other changes that also add up line count a bit: One is a long-standing bug with the keyboard layout on one of the PXA platforms. The other is a fix for highbank that moves their power-off/reset button handling to be done in-kernel since relying on userspace to handle it was fragile and awkward" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: sun6i: dt: Fix interrupt trigger types ARM: sun7i: dt: Fix interrupt trigger types MAINTAINERS: merge IMX6 entry into IMX ARM: tegra: add missing break to fuse initialization code ARM: pxa: prevent PXA270 occasional reboot freezes ARM: pxa: tosa: fix keys mapping ARM: OMAP2+: omap_device: add fail hook for runtime_pm when bad data is detected ARM: OMAP2+: hwmod: Fix usage of invalid iclk / oclk when clock node is not present ARM: OMAP3: hwmod data: Don't prevent RESET of USB Host module ARM: OMAP2+: hwmod: Fix SOFTRESET logic ARM: OMAP4+: hwmod data: Don't prevent RESET of USB Host module ARM: dts: Fix booting for secure omaps ARM: OMAP2+: Fix the machine entry for am3517 ARM: dts: Fix missing entries for am3517 ARM: OMAP2+: Fix overwriting hwmod data with data from device tree ARM: davinci: Fix McASP mem resource names ARM: highbank: handle soft poweroff and reset key events ARM: davinci: fix number of resources passed to davinci_gpio_register() gpio: davinci: fix check for unbanked gpio
2013-12-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "This is a small collection of fixes. It was rebased this morning, but I was just fixing signed-off-by tags with the wrong email" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: fix access_ok() check in btrfs_ioctl_send() Btrfs: make sure we cleanup all reloc roots if error happens Btrfs: skip building backref tree for uuid and quota tree when doing balance relocation Btrfs: fix an oops when doing balance relocation Btrfs: don't miss skinny extent items on delayed ref head contention btrfs: call mnt_drop_write after interrupted subvol deletion Btrfs: don't clear the default compression type
2013-12-12Merge branch 'for-3.13' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd reply cache bugfix from Bruce Fields: "One bugfix for nfsd crashes" * 'for-3.13' of git://linux-nfs.org/~bfields/linux: nfsd: when reusing an existing repcache entry, unhash it first
2013-12-12mtd: nand: pxa3xx: Use info->use_dma to release DMA resourcesEzequiel Garcia
In commit: commit 62e8b851783138a11da63285be0fbf69530ff73d Author: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Date: Fri Oct 4 15:30:38 2013 -0300 mtd: nand: pxa3xx: Allocate data buffer on detected flash size the way the buffer is allocated was changed: the first READ_ID is issued with a small kmalloc'ed buffer. Only once the flash page size is detected the DMA buffers are allocated, and info->use_dma is set. Currently, if the device detection fails, the driver checks the 'use_dma' module parameter and tries to release unallocated DMA resources. Fix this by checking the proper indicator of the DMA allocation, which is 'info->use_dma'. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2013-12-12Partially revert "mtd: nand: pxa3xx: Introduce 'marvell,armada370-nand' ↵Ezequiel Garcia
compatible string" This partially reverts c0f3b8643a6fa2461d70760ec49d21d2b031d611. The "armada370-nand" compatible support is not complete, and it was mistake to add it. Revert it and postpone the support until the infrastructure is in place. Cc: <stable@vger.kernel.org> # 3.12 Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Acked-by: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2013-12-12selinux: process labeled IPsec TCP SYN-ACK packets properly in ↵Paul Moore
selinux_ip_postroute() Due to difficulty in arriving at the proper security label for TCP SYN-ACK packets in selinux_ip_postroute(), we need to check packets while/before they are undergoing XFRM transforms instead of waiting until afterwards so that we can determine the correct security label. Reported-by: Janak Desai <Janak.Desai@gtri.gatech.edu> Cc: stable@vger.kernel.org Signed-off-by: Paul Moore <pmoore@redhat.com>
2013-12-12selinux: look for IPsec labels on both inbound and outbound packetsPaul Moore
Previously selinux_skb_peerlbl_sid() would only check for labeled IPsec security labels on inbound packets, this patch enables it to check both inbound and outbound traffic for labeled IPsec security labels. Reported-by: Janak Desai <Janak.Desai@gtri.gatech.edu> Cc: stable@vger.kernel.org Signed-off-by: Paul Moore <pmoore@redhat.com>
2013-12-12selinux: handle TCP SYN-ACK packets correctly in selinux_ip_postroute()Paul Moore
In selinux_ip_postroute() we perform access checks based on the packet's security label. For locally generated traffic we get the packet's security label from the associated socket; this works in all cases except for TCP SYN-ACK packets. In the case of SYN-ACK packet's the correct security label is stored in the connection's request_sock, not the server's socket. Unfortunately, at the point in time when selinux_ip_postroute() is called we can't query the request_sock directly, we need to recreate the label using the same logic that originally labeled the associated request_sock. See the inline comments for more explanation. Reported-by: Janak Desai <Janak.Desai@gtri.gatech.edu> Tested-by: Janak Desai <Janak.Desai@gtri.gatech.edu> Cc: stable@vger.kernel.org Signed-off-by: Paul Moore <pmoore@redhat.com>
2013-12-12selinux: handle TCP SYN-ACK packets correctly in selinux_ip_output()Paul Moore
In selinux_ip_output() we always label packets based on the parent socket. While this approach works in almost all cases, it doesn't work in the case of TCP SYN-ACK packets when the correct label is not the label of the parent socket, but rather the label of the larval socket represented by the request_sock struct. Unfortunately, since the request_sock isn't queued on the parent socket until *after* the SYN-ACK packet is sent, we can't lookup the request_sock to determine the correct label for the packet; at this point in time the best we can do is simply pass/NF_ACCEPT the packet. It must be said that simply passing the packet without any explicit labeling action, while far from ideal, is not terrible as the SYN-ACK packet will inherit any IP option based labeling from the initial connection request so the label *should* be correct and all our access controls remain in place so we shouldn't have to worry about information leaks. Reported-by: Janak Desai <Janak.Desai@gtri.gatech.edu> Tested-by: Janak Desai <Janak.Desai@gtri.gatech.edu> Cc: stable@vger.kernel.org Signed-off-by: Paul Moore <pmoore@redhat.com>
