Implement function for setting one tag if another tag is set for each item
in given range.
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Verify the refcounting doesn't go wrong, and resurrect the check in
__page_check_anon_rmap as in old anon-vma code.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Signed-off-by: Rik van Riel <riel@redhat.com>
With root anon-vma it's trivial to keep doing the usual check as in
old-anon-vma code.
Always use anon_vma->root pointer instead of anon_vma_chain.prev.
Also optimize the map-paths, if a mapping is already established no need
to overwrite it with root anon-vma list, we can keep the more finegrined
anon-vma and skip the overwrite: see the PageAnon check in !exclusive
case. This is also the optimization that hidden the ksm bug as this tends
to make ksm_might_need_to_copy skip the copy, but only the proper fix to
ksm_might_need_to_copy guarantees not triggering the ksm bug unless ksm is
in use. this is an optimization only...
[kamezawa.hiroyu@jp.fujitsu.com: fix false positive BUG_ON in __page_set_anon_rmap]
The new anon-vma code, was suboptimal and it lead to erratic invocation of
ksm_does_need_to_copy. That leads to host hangs or guest vnc lockup, or
weird behavior. It's unclear why ksm_does_need_to_copy is unstable but
the point is that when KSM is not in use, ksm_does_need_to_copy must never
run or we bounce pages for no good reason. I suspect the same hangs will
happen with KVM swaps. But this at least fixes the regression in the
new-anon-vma code and it only let KSM bugs triggers when KSM is in use.
The code in do_swap_page likely doesn't cope well with a not-swapcache,
especially the memcg code.
Cc: Izik Eidus <ieidus@yahoo.com>
Cc: Avi Kivity <avi@redhat.com>
Make sure to always add new VMAs at the end of the list. This is
important so rmap_walk does not miss a VMA that was created during the
rmap_walk.
The old code got this right most of the time due to luck, but was buggy
when anon_vma_prepare reused a mergeable anon_vma.
There's no anon-vma related mangling happening inside __vma_link anymore
so no need of anon_vma locking there.
I'm running a shmem pagefault test case (see attached file) under a 64 CPU
system. Profile shows shmem_inode_info->lock is heavily contented and
100% CPUs time are trying to get the lock. In the pagefault (no swap)
case, shmem_getpage gets the lock twice, the last one is avoidable if we
prealloc a page so we could reduce one time of locking. This is what
below patch does.
The result of the test case:
2.6.35-rc3: ~20s
2.6.35-rc3 + patch: ~12s
so this is 40% improvement.
One might argue if we could have better locking for shmem. But even shmem
is lockless, the pagefault will soon have pagecache lock heavily contented
because shmem must add new page to pagecache. So before we have better
locking for pagecache, improving shmem locking doesn't have too much
improvement. I did a similar pagefault test against a ramfs file, the
test result is ~10.5s.
[akpm@linux-foundation.org: fix comment, clean up code layout, elimintate code duplication]
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Cc: "Zhang, Yanmin" <yanmin.zhang@intel.com>
Cc: Tim Chen <tim.c.chen@linux.intel.com>
The current implementation of tmpfs is not scalable. We found that
stat_lock is contended by multiple threads when we need to get a new page,
leading to useless spinning inside this spin lock.
This patch makes use of the percpu_counter library to maintain local count
of used blocks to speed up getting and returning of pages. So the
acquisition of stat_lock is unnecessary for getting and returning blocks,
improving the performance of tmpfs on system with large number of cpus.
On a 4 socket 32 core NHM-EX system, we saw improvement of 270%.
The implementation below has a slight chance of race between threads
causing a slight overshoot of the maximum configured blocks. However, any
overshoot is small, and is bounded by the number of cpus. This happens
when the number of used blocks is slightly below the maximum configured
blocks when a thread checks the used block count, and another thread
allocates the last block before the current thread does. This should not
be a problem for tmpfs, as the overshoot is most likely to be a few blocks
and bounded. If a strict limit is really desired, then configured the max
blocks to be the limit less the number of cpus in system.
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
Add percpu_counter_compare that allows for a quick but accurate comparison
of percpu_counter with a given value.
A rough count is provided by the count field in percpu_counter structure,
without accounting for the other values stored in individual cpu counters.
The actual count is a sum of count and the cpu counters. However, count
field is never different from the actual value by a factor of
batch*num_online_cpu. We do not need to get actual count for comparison
if count is different from the given value by this factor and allows for
quick comparison without summing up all the per cpu counters.
No real bugs, just some dead code and some fixups.
Avoid quite a lot of warnings in header files in a gcc 4.6 -Wall builds
As explained in commit 1c0fe6e3bd ("mm: invoke oom-killer from page
fault") , we want to call the architecture independent oom killer when
getting an unexplained OOM from handle_mm_fault, rather than simply
killing current.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Acked-by: David Rientjes <rientjes@google.com>
migrate_pages() is using >500 bytes stack. Reduce it.
mm/mempolicy.c: In function 'sys_migrate_pages':
mm/mempolicy.c:1344: warning: the frame size of 528 bytes is larger than 512 bytes
[akpm@linux-foundation.org: don't play with a might-be-NULL pointer]
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
Define stubs for the numa_*_id() generic percpu related functions for
non-NUMA configurations in <asm-generic/topology.h> where the other
non-numa stubs live.
Fixes ia64 !NUMA build breakage -- e.g., tiger_defconfig
Back out now unneeded '#ifndef CONFIG_NUMA' guards from ia64 smpboot.c
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Tested-by: Tony Luck <tony.luck@intel.com>
Acked-by: Tony Luck <tony.luck@intel.com>
get_zone_counts() was dropped from kernel tree, see:
http://www.mail-archive.com/mm-commits@vger.kernel.org/msg07313.html but
its prototype remains.
The sum_vm_events passes cpumask for for_each_cpu(). But it's useless
since we have for_each_online_cpu. Althougth it's tirival overhead, it's
not good about coding consistency.
Let's use for_each_online_cpu instead of for_each_cpu with cpumask
argument.
Signed-off-by: Minchan Kim <minchan.kim@gmail.com>
Acked-by: Christoph Lameter <cl@linux-foundation.org>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
__out_of_memory() only has a single caller, so fold it into
out_of_memory() and add a comment about locking for its call to
oom_kill_process().
Signed-off-by: David Rientjes <rientjes@google.com>
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
select_bad_process() and __out_of_memory() doe not need their enum
oom_constraint arguments: it's possible to pass a NULL nodemask if
constraint == CONSTRAINT_MEMORY_POLICY in the caller, out_of_memory().
We have been used naming try_set_zone_oom and clear_zonelist_oom.
The role of functions is to lock of zonelist for preventing parallel
OOM. So clear_zonelist_oom makes sense but try_set_zone_oome is rather
awkward and unmatched with clear_zonelist_oom.
Let's change it with try_set_zonelist_oom.
Remove the redundancy in __oom_kill_task() since:
- init can never be passed to this function: it will never be PF_EXITING
or selectable from select_bad_process(), and
- it will never be passed a task from oom_kill_task() without an ->mm
and we're unconcerned about detachment from exiting tasks, there's no
reason to protect them against SIGKILL or access to memory reserves.
Also moves the kernel log message to a higher level since the verbosity is
not always emitted here; we need not print an error message if an exiting
task is given a longer timeslice.
__oom_kill_task() only has a single caller, so it can be merged into that
function at the same time.
The three oom killer sysctl variables (sysctl_oom_dump_tasks,
sysctl_oom_kill_allocating_task, and sysctl_panic_on_oom) are better
declared in include/linux/oom.h rather than kernel/sysctl.c.
It is possible to remove the special pagefault oom handler by simply oom
locking all system zones and then calling directly into out_of_memory().
All populated zones must have ZONE_OOM_LOCKED set, otherwise there is a
parallel oom killing in progress that will lead to eventual memory freeing
so it's not necessary to needlessly kill another task. The context in
which the pagefault is allocating memory is unknown to the oom killer, so
this is done on a system-wide level.
If a task has already been oom killed and hasn't fully exited yet, this
will be a no-op since select_bad_process() recognizes tasks across the
system with TIF_MEMDIE set.
Acked-by: Nick Piggin <npiggin@suse.de>
There are various points in the oom killer where the kernel must determine
whether to panic or not. It's better to extract this to a helper function
to remove all the confusion as to its semantics.
Also fix a call to dump_header() where tasklist_lock is not read- locked,
as required.
There's no functional change with this patch.
If memory has been depleted in lowmem zones even with the protection
afforded to it by /proc/sys/vm/lowmem_reserve_ratio, it is unlikely that
killing current users will help. The memory is either reclaimable (or
migratable) already, in which case we should not invoke the oom killer at
all, or it is pinned by an application for I/O. Killing such an
application may leave the hardware in an unspecified state and there is no
guarantee that it will be able to make a timely exit.
Lowmem allocations are now failed in oom conditions when __GFP_NOFAIL is
not used so that the task can perhaps recover or try again later.
Previously, the heuristic provided some protection for those tasks with
CAP_SYS_RAWIO, but this is no longer necessary since we will not be
killing tasks for the purposes of ISA allocations.
high_zoneidx is gfp_zone(gfp_flags), meaning that ZONE_NORMAL will be the
default for all allocations that are not __GFP_DMA, __GFP_DMA32,
__GFP_HIGHMEM, and __GFP_MOVABLE on kernels configured to support those
flags. Testing for high_zoneidx being less than ZONE_NORMAL will only
return true for allocations that have either __GFP_DMA or __GFP_DMA32.
The oom killer tasklist dump, enabled with the oom_dump_tasks sysctl, is
very helpful information in diagnosing why a user's task has been killed.
It emits useful information such as each eligible thread's memory usage
that can determine why the system is oom, so it should be enabled by
default.
The oom killer presently kills current whenever there is no more memory
free or reclaimable on its mempolicy's nodes. There is no guarantee that
current is a memory-hogging task or that killing it will free any
substantial amount of memory, however.
In such situations, it is better to scan the tasklist for nodes that are
allowed to allocate on current's set of nodes and kill the task with the
highest badness() score. This ensures that the most memory-hogging task,
or the one configured by the user with /proc/pid/oom_adj, is always
selected in such scenarios.
When a task is chosen for oom kill, the oom killer first attempts to
sacrifice a child not sharing its parent's memory instead. Unfortunately,
this often kills in a seemingly random fashion based on the ordering of
the selected task's child list. Additionally, it is not guaranteed at all
to free a large amount of memory that we need to prevent additional oom
killing in the very near future.
Instead, we now only attempt to sacrifice the worst child not sharing its
parent's memory, if one exists. The worst child is indicated with the
highest badness() score. This serves two advantages: we kill a
memory-hogging task more often, and we allow the configurable
/proc/pid/oom_adj value to be considered as a factor in which child to
kill.
Reviewers may observe that the previous implementation would iterate
through the children and attempt to kill each until one was successful and
then the parent if none were found while the new code simply kills the
most memory-hogging task or the parent. Note that the only time
oom_kill_task() fails, however, is when a child does not have an mm or has
a /proc/pid/oom_adj of OOM_DISABLE. badness() returns 0 for both cases,
so the final oom_kill_task() will always succeed.
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Tasks that do not share the same set of allowed nodes with the task that
triggered the oom should not be considered as candidates for oom kill.
Tasks in other cpusets with a disjoint set of mems would be unfairly
penalized otherwise because of oom conditions elsewhere; an extreme
example could unfairly kill all other applications on the system if a
single task in a user's cpuset sets itself to OOM_DISABLE and then uses
more memory than allowed.
Killing tasks outside of current's cpuset rarely would free memory for
current anyway. To use a sane heuristic, we must ensure that killing a
task would likely free memory for current and avoid needlessly killing
others at all costs just because their potential memory freeing is
unknown. It is better to kill current than another task needlessly.
It's unnecessary to SIGKILL a task that is already PF_EXITING and can
actually cause a NULL pointer dereference of the sighand if it has already
been detached. Instead, simply set TIF_MEMDIE so it has access to memory
reserves and can quickly exit as the comment implies.
It's possible to livelock the page allocator if a thread has mm->mmap_sem
and fails to make forward progress because the oom killer selects another
thread sharing the same ->mm to kill that cannot exit until the semaphore
is dropped.
The oom killer will not kill multiple tasks at the same time; each oom
killed task must exit before another task may be killed. Thus, if one
thread is holding mm->mmap_sem and cannot allocate memory, all threads
sharing the same ->mm are blocked from exiting as well. In the oom kill
case, that means the thread holding mm->mmap_sem will never free
additional memory since it cannot get access to memory reserves and the
thread that depends on it with access to memory reserves cannot exit
because it cannot acquire the semaphore. Thus, the page allocators
livelocks.
When the oom killer is called and current happens to have a pending
SIGKILL, this patch automatically gives it access to memory reserves and
returns. Upon returning to the page allocator, its allocation will
hopefully succeed so it can quickly exit and free its memory. If not, the
page allocator will fail the allocation if it is not __GFP_NOFAIL.
When find_lock_task_mm() returns a thread other than p in dump_tasks(),
its name should be displayed instead. This is the thread that will be
targeted by the oom killer, not its mm-less parent.
This also allows us to safely dereference task->comm without needing
get_task_comm().
While we're here, remove the cast on task_cpu(task) as Andrew suggested.
Cc: Balbir Singh <balbir@in.ibm.com>
The comments in dump_tasks() should be updated to be more clear about why
tasks are filtered and how they are filtered by its argument.
An unnecessary comment concerning a check for is_global_init() is removed
since it isn't of importance.
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
dump_task() should use find_lock_task_mm() too. It is necessary for
protecting task-exiting race.
dump_tasks() currently filters any task that does not have an attached
->mm since it incorrectly assumes that it must either be in the process of
exiting and has detached its memory or that it's a kernel thread;
multithreaded tasks may actually have subthreads that have a valid ->mm
pointer and thus those threads should actually be displayed. This change
finds those threads, if they exist, and emit their information along with
the rest of the candidate tasks for kill.
Almost all ->mm == NULL checks in oom_kill.c are wrong.
The current code assumes that the task without ->mm has already released
its memory and ignores the process. However this is not necessarily true
when this process is multithreaded, other live sub-threads can use this
->mm.
- Remove the "if (!p->mm)" check in select_bad_process(), it is
just wrong.
- Add the new helper, find_lock_task_mm(), which finds the live
thread which uses the memory and takes task_lock() to pin ->mm
- change oom_badness() to use this helper instead of just checking
->mm != NULL.
- As David pointed out, select_bad_process() must never choose the
task without ->mm, but no matter what oom_badness() returns the
task can be chosen if nothing else has been found yet.
Change oom_badness() to return int, change it to return -1 if
find_lock_task_mm() fails, and change select_bad_process() to
check points >= 0.
Note! This patch is not enough, we need more changes.
- oom_badness() was fixed, but oom_kill_task() still ignores
- oom_forkbomb_penalty() should use find_lock_task_mm() too,
and it also needs other changes to actually find the first
first-descendant children
This will be addressed later.
[kosaki.motohiro@jp.fujitsu.com: use in badness(), __oom_kill_task()]
select_bad_process() checks PF_EXITING to detect the task which is going
to release its memory, but the logic is very wrong.
- a single process P with the dead group leader disables
select_bad_process() completely, it will always return
ERR_PTR() while P can live forever
- if the PF_EXITING task has already released its ->mm
it doesn't make sense to expect it is goiing to free
more memory (except task_struct/etc)
Change the code to ignore the PF_EXITING tasks without ->mm.
select_bad_process() thinks a kernel thread can't have ->mm != NULL, this
is not true due to use_mm().
Change the code to check PF_KTHREAD.
The comment suggests that when b_count equals zero it is calling
__wait_no_buffer to trigger some debug, but as there is no debug in
__wait_on_buffer the whole thing is redundant.
AFAICT from the git log this has been the case for at least 5 years, so
it seems safe just to remove this.
Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk>
Cc: Jeff Mahoney <jeffm@suse.com>
KSM reference counts can cause an anon_vma to exist after the processe it
belongs to have already exited. Because the anon_vma lock now lives in
the root anon_vma, we need to ensure that the root anon_vma stays around
until after all the "child" anon_vmas have been freed.
The obvious way to do this is to have a "child" anon_vma take a reference
to the root in anon_vma_fork. When the anon_vma is freed at munmap or
process exit, we drop the refcount in anon_vma_unlink and possibly free
the root anon_vma.
The KSM anon_vma reference count function also needs to be modified to
deal with the possibility of freeing 2 levels of anon_vma. The easiest
way to do this is to break out the KSM magic and make it generic.
When compiling without CONFIG_KSM, this code is compiled out.
Tested-by: Larry Woodman <lwoodman@redhat.com>
Acked-by: Larry Woodman <lwoodman@redhat.com>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Acked-by: Mel Gorman <mel@csn.ul.ie>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Tested-by: Dave Young <hidave.darkstar@gmail.com>
Always (and only) lock the root (oldest) anon_vma whenever we do something
in an anon_vma. The recently introduced anon_vma scalability is due to
the rmap code scanning only the VMAs that need to be scanned. Many common
operations still took the anon_vma lock on the root anon_vma, so always
taking that lock is not expected to introduce any scalability issues.
However, always taking the same lock does mean we only need to take one
lock, which means rmap_walk on pages from any anon_vma in the vma is
excluded from occurring during an munmap, expand_stack or other operation
that needs to exclude rmap_walk and similar functions.
Also add the proper locking to vma_adjust.
Track the root (oldest) anon_vma in each anon_vma tree. Because we only
take the lock on the root anon_vma, we cannot use the lock on higher-up
anon_vmas to lock anything. This makes it impossible to do an indirect
lookup of the root anon_vma, since the data structures could go away from
under us.
However, a direct pointer is safe because the root anon_vma is always the
last one that gets freed on munmap or exit, by virtue of the same_vma list
order and unlink_anon_vmas walking the list forward.
[akpm@linux-foundation.org: fix typo]
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Subsitute a direct call of spin_lock(anon_vma->lock) with an inline
function doing exactly the same.
This makes it easier to do the substitution to the root anon_vma lock in a
following patch.
We will deal with the handful of special locks (nested, dec_and_lock, etc)
separately.
Rename anon_vma_lock to vma_lock_anon_vma. This matches the naming style
used in page_lock_anon_vma and will come in really handy further down in
this patch series.
kunmap_atomic() is currently at level -4 on Rusty's "Hard To Misuse"
list[1] ("Follow common convention and you'll get it wrong"), except in
some architectures when CONFIG_DEBUG_HIGHMEM is set[2][3].
kunmap() takes a pointer to a struct page; kunmap_atomic(), however, takes
takes a pointer to within the page itself. This seems to once in a while
trip people up (the convention they are following is the one from
kunmap()).
Make it much harder to misuse, by moving it to level 9 on Rusty's list[4]
("The compiler/linker won't let you get it wrong"). This is done by
refusing to build if the type of its first argument is a pointer to a
struct page.
The real kunmap_atomic() is renamed to kunmap_atomic_notypecheck()
(which is what you would call in case for some strange reason calling it
with a pointer to a struct page is not incorrect in your code).
The previous version of this patch was compile tested on x86-64.
[1] http://ozlabs.org/~rusty/index.cgi/tech/2008-04-01.html
[2] In these cases, it is at level 5, "Do it right or it will always
break at runtime."
[3] At least mips and powerpc look very similar, and sparc also seems to
share a common ancestor with both; there seems to be quite some
degree of copy-and-paste coding here. The include/asm/highmem.h file
for these three archs mention x86 CPUs at its top.
[4] http://ozlabs.org/~rusty/index.cgi/tech/2008-03-30.html
[5] As an aside, could someone tell me why mn10300 uses unsigned long as
the first parameter of kunmap_atomic() instead of void *?
Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net>
Cc: Russell King <linux@arm.linux.org.uk> (arch/arm)
Cc: Ralf Baechle <ralf@linux-mips.org> (arch/mips)
Cc: David Howells <dhowells@redhat.com> (arch/frv, arch/mn10300)
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> (arch/mn10300)
Cc: Kyle McMartin <kyle@mcmartin.ca> (arch/parisc)
Cc: Helge Deller <deller@gmx.de> (arch/parisc)
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> (arch/parisc)
Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> (arch/powerpc)
Cc: Paul Mackerras <paulus@samba.org> (arch/powerpc)
Cc: "David S. Miller" <davem@davemloft.net> (arch/sparc)
Cc: Thomas Gleixner <tglx@linutronix.de> (arch/x86)
Cc: Ingo Molnar <mingo@redhat.com> (arch/x86)
Cc: "H. Peter Anvin" <hpa@zytor.com> (arch/x86)
Cc: Arnd Bergmann <arnd@arndb.de> (include/asm-generic)
Cc: Rusty Russell <rusty@rustcorp.com.au> ("Hard To Misuse" list)
When a copy-on-write occurs, we take one of two paths in handle_mm_fault:
through handle_pte_fault for normal pages, or through hugetlb_fault for
huge pages.
In the normal page case, we eventually get to do_wp_page and call mmu
notifiers via ptep_clear_flush_notify. There is no callout to the mmmu
notifiers in the huge page case. This patch fixes that.
Signed-off-by: Doug Doan <dougd@cray.com>
Provide an INIT_MM_CONTEXT intializer macro which can be used to
statically initialize mm_struct:mm_context of init_mm. This way we can
get rid of code which will do the initialization at run time (on s390).
In addition the current code can be found at a place where it is not
expected. So let's have a common initializer which architectures
can use if needed.
This is based on a patch from Suzuki Poulose.
Cc: Suzuki Poulose <suzuki@in.ibm.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Use ERR_CAST(x) rather than ERR_PTR(PTR_ERR(x)). The former makes more
clear what is the purpose of the operation, which otherwise looks like a
no-op.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
type T;
T x;
identifier f;
T f (...) { <+...
- ERR_PTR(PTR_ERR(x))
+ x
expression x;
+ ERR_CAST(x)
// </smpl>
Use memdup_user when user data is immediately copied into the
allocated region.
// <smpl>
expression from,to,size,flag;
position p;
identifier l1,l2;
- to = \(kmalloc@p\|kzalloc@p\)(size,flag);
+ to = memdup_user(from,size);
if (
- to==NULL
+ IS_ERR(to)
<+... when != goto l1;
- -ENOMEM
+ PTR_ERR(to)
- if (copy_from_user(to, from, size) != 0) {
- <+... when != goto l2;
- -EFAULT
// </smpl>
The start/stop_critical_timing functions for preemptirqsoff, preemptoff
and irqsoff tracers contain atomic_inc() and atomic_dec() operations.
Atomic operations use local_irq_save/restore macros to ensure atomic
access but they are traced by the same function which is causing recursion
problem.
The reason is when these tracers are turn ON then the
local_irq_save/restore macros are changed in include/linux/irqflags.h to
call trace_hardirqs_on/off which call start/stop_critical_timing.
Microblaze was affected because it uses generic atomic implementation.
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Fix a build failure "error: void value not ignored as it ought to be"
by removing an assignment of a void return value. The functionality of
the code is not changed.
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
Acked-by: Henrik Kretzschmar <henne@nachtwindheim.de>
Cc: <stable@kernel.org>
