[ Upstream commit df467899da0b71465760b4e35127bce837244eee ]
Some drivers (like nand_hynix.c) call ->cmdfunc() with NAND_CMD_NONE
and a column address and expect the controller to only send address
cycles. Right now, the default ->cmdfunc() implementations provided by
the core do not filter out the command cycle in this case and forwards
the request to the controller driver through the ->cmd_ctrl() method.
The thing is, NAND controller drivers can get this wrong and send a
command cycle with a NAND_CMD_NONE opcode and since NAND_CMD_NONE is
-1, and the command field is usually casted to an u8, we end up sending
the 0xFF command which is actually a RESET operation.
Add conditions in nand_command[_lp]() functions to sending the initial
command cycle when command == NAND_CMD_NONE.
Signed-off-by: Miquel Raynal <miquel.raynal@free-electrons.com>
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
[ Upstream commit be8f8284cd897af2482d4e54fbc2bdfc15557259 ]
Currently it is possible to add or update socket policies, but
not clear them. Therefore, once a socket policy has been applied,
the socket cannot be used for unencrypted traffic.
This patch allows (privileged) users to clear socket policies by
passing in a NULL pointer and zero length argument to the
{IP,IPV6}_{IPSEC,XFRM}_POLICY setsockopts. This results in both
the incoming and outgoing policies being cleared.
The simple approach taken in this patch cannot clear socket
policies in only one direction. If desired this could be added
in the future, for example by continuing to pass in a length of
zero (which currently is guaranteed to return EMSGSIZE) and
making the policy be a pointer to an integer that contains one
of the XFRM_POLICY_{IN,OUT} enum values.
An alternative would have been to interpret the length as a
signed integer and use XFRM_POLICY_IN (i.e., 0) to clear the
input policy and -XFRM_POLICY_OUT (i.e., -1) to clear the output
policy.
Tested: https://android-review.googlesource.com/539816
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit 388b3b2b03701f3b3c10975c272892d7f78080df ]
This fixes undefined reference to struct adf7242_local *lp in
case DEBUG is defined.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Signed-off-by: Stefan Schmidt <stefan@osg.samsung.com>
[ Upstream commit 65c79230576873b312c3599479c1e42355c9f349 ]
The file /sys/module/firmware_class/parameters/path can be used
to set a custom firmware path. The fw_filesystem.sh script creates
a temporary directory to add a test firmware file to be used during
testing, in order for this to work it uses the custom path syfs file
and it was supposed to reset back the file on execution exit. The
script failed to do this due to a typo, it was using OLD_PATH instead
of OLD_FWPATH, since its inception since v3.17.
Its not as easy to just keep the old setting, it turns out that
resetting an empty setting won't actually do what we want, we need
to check if it was empty and set an empty space.
Without this we end up having the temporary path always set after
we run these tests.
Fixes: 0a8adf58475 ("test: add firmware_class loader test")
Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org>
[ Upstream commit a0982dfa03efca6c239c52cabebcea4afb93ea6b ]
The rcutorture test suite occasionally provokes a splat due to invoking
resched_cpu() on an offline CPU:
WARNING: CPU: 2 PID: 8 at /home/paulmck/public_git/linux-rcu/arch/x86/kernel/smp.c:128 native_smp_send_reschedule+0x37/0x40
Modules linked in:
CPU: 2 PID: 8 Comm: rcu_preempt Not tainted 4.14.0-rc4+ #1
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
task: ffff902ede9daf00 task.stack: ffff96c50010c000
RIP: 0010:native_smp_send_reschedule+0x37/0x40
RSP: 0018:ffff96c50010fdb8 EFLAGS: 00010096
RAX: 000000000000002e RBX: ffff902edaab4680 RCX: 0000000000000003
RDX: 0000000080000003 RSI: 0000000000000000 RDI: 00000000ffffffff
RBP: ffff96c50010fdb8 R08: 0000000000000000 R09: 0000000000000001
R10: 0000000000000000 R11: 00000000299f36ae R12: 0000000000000001
R13: ffffffff9de64240 R14: 0000000000000001 R15: ffffffff9de64240
FS: 0000000000000000(0000) GS:ffff902edfc80000(0000) knlGS:0000000000000000
CR2: 00000000f7d4c642 CR3: 000000001e0e2000 CR4: 00000000000006e0
Call Trace:
resched_curr+0x8f/0x1c0
resched_cpu+0x2c/0x40
rcu_implicit_dynticks_qs+0x152/0x220
force_qs_rnp+0x147/0x1d0
? sync_rcu_exp_select_cpus+0x450/0x450
rcu_gp_kthread+0x5a9/0x950
kthread+0x142/0x180
? force_qs_rnp+0x1d0/0x1d0
? kthread_create_on_node+0x40/0x40
ret_from_fork+0x27/0x40
Code: 14 01 0f 92 c0 84 c0 74 14 48 8b 05 14 4f f4 00 be fd 00 00 00 ff 90 a0 00 00 00 5d c3 89 fe 48 c7 c7 38 89 ca 9d e8 e5 56 08 00 <0f> ff 5d c3 0f 1f 44 00 00 8b 05 52 9e 37 02 85 c0 75 38 55 48
---[ end trace 26df9e5df4bba4ac ]---
This splat cannot be generated by expedited grace periods because they
always invoke resched_cpu() on the current CPU, which is good because
expedited grace periods require that resched_cpu() unconditionally
succeed. However, other parts of RCU can tolerate resched_cpu() acting
as a no-op, at least as long as it doesn't happen too often.
This commit therefore makes resched_cpu() invoke resched_curr() only if
the CPU is either online or is the current CPU.
[ Upstream commit 2fe2582649aa2355f79acddb86bd4d6c5363eb63 ]
rt_mutex_lock() which needs to boost the priority of a task currently
sitting on a runqueue that belongs to an offline CPU:
WARNING: CPU: 0 PID: 12 at /home/paulmck/public_git/linux-rcu/arch/x86/kernel/smp.c:128 native_smp_send_reschedule+0x37/0x40
Modules linked in:
CPU: 0 PID: 12 Comm: rcub/7 Not tainted 4.14.0-rc4+ #1
task: ffff9ed3de5f8cc0 task.stack: ffffbbf80012c000
RSP: 0018:ffffbbf80012fd10 EFLAGS: 00010082
RAX: 000000000000002f RBX: ffff9ed3dd9cb300 RCX: 0000000000000004
RDX: 0000000080000004 RSI: 0000000000000086 RDI: 00000000ffffffff
RBP: ffffbbf80012fd10 R08: 000000000009da7a R09: 0000000000007b9d
R10: 0000000000000001 R11: ffffffffbb57c2cd R12: 000000000000000d
R13: ffff9ed3de5f8cc0 R14: 0000000000000061 R15: ffff9ed3ded59200
FS: 0000000000000000(0000) GS:ffff9ed3dea00000(0000) knlGS:0000000000000000
CR2: 00000000080686f0 CR3: 000000001b9e0000 CR4: 00000000000006f0
Call Trace:
resched_curr+0x61/0xd0
switched_to_rt+0x8f/0xa0
rt_mutex_setprio+0x25c/0x410
task_blocks_on_rt_mutex+0x1b3/0x1f0
rt_mutex_slowlock+0xa9/0x1e0
rt_mutex_lock+0x29/0x30
rcu_boost_kthread+0x127/0x3c0
kthread+0x104/0x140
? rcu_report_unblock_qs_rnp+0x90/0x90
ret_from_fork+0x22/0x30
Code: f0 00 0f 92 c0 84 c0 74 14 48 8b 05 34 74 c5 00 be fd 00 00 00 ff 90 a0 00 00 00 5d c3 89 fe 48 c7 c7 a0 c6 fc b9 e8 d5 b5 06 00 <0f> ff 5d c3 0f 1f 44 00 00 8b 05 a2 d1 13 02 85 c0 75 38 55 48
But the target task's priority has already been adjusted, so the only
purpose of switched_to_rt() invoking resched_curr() is to wake up the
CPU running some task that needs to be preempted by the boosted task.
But the CPU is offline, which presumably means that the task must be
migrated to some other CPU, and that this other CPU will undertake any
needed preemption at the time of migration. Because the runqueue lock
is held when resched_curr() is invoked, we know that the boosted task
cannot go anywhere, so it is not necessary to invoke resched_curr()
in this particular case.
This commit therefore makes switched_to_rt() refrain from invoking
resched_curr() when the target CPU is offline.
[ Upstream commit 1b377924841df1e13ab5b225be3a83f807a92b52 ]
Trats2 uses gpf2-1 as the panel reset GPIO. gpy4-5 was only used
on early revisions of the board.
Fixes: 420ae8451a22 ("ARM: dts: exynos4412-trats2: add panel node")
Signed-off-by: Simon Shields <simon@lineageos.org>
Acked-by: Marek Szyprowski <m.szyprowski@samsung.com>
Tested-by: Marek Szyprowski <m.szyprowski@samsung.com>
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
[ Upstream commit 75eccf5ed83250c0aeaeeb76f7288254ac0a87b4 ]
According to the datasheet, in Meson-GXBB/GXL series,
The clock gate bit for SARADC is HHI_GCLK_MPEG2 bit[22],
while clock gate bit for SANA is HHI_GCLK_MPEG0 bit[10].
Test passed at gxl-s905x-p212 board.
The following published datasheets are wrong and should be updated
[1] GXBB v1.1.4
[2] GXL v0.3_20170314
Fixes: 738f66d3211d ("clk: gxbb: add AmLogic GXBB clk controller driver")
Tested-by: Xingyu Chen <xingyu.chen@amlogic.com>
Signed-off-by: Yixun Lan <yixun.lan@amlogic.com>
Signed-off-by: Jerome Brunet <jbrunet@baylibre.com>
[ Upstream commit 992172e3aec19e5b0ea5b757ba40a146b9282d1e ]
When we are in a search cycle, we try different combinations
of parameters. Those combinations are called 'columns'.
When we switch to a new column, we first need to check if
this column has a suitable rate, if not, we can't try it.
This means we must not erase the statistics we gathered
for the previous column until we are sure that we are
indeed switching column.
The code that tries to switch to a new column first sets
a whole bunch of things for the new column, and only then
checks that we can find suitable rates in that column.
While doing that, the code mistakenly erased the rate
statistics. This code was right until
struct iwl_scale_tbl_info grew up for TPC.
Fix this to make sure we don't erase the rate statistics
until we are sure that we can indeed switch to the new
column.
Note that this bug is really harmless since it causes a
change in the behavior only when we can't find any rate
in the new column which should really not happen. In the
case we do find a suitable we reset the rate statistics
a few lines later anyway.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
[ Upstream commit 9abd04af951e5734c9d5cfee9b49790844b734cf ]
ELO devices have one Button usage in GenDesk field, which makes hid-input map
it to BTN_LEFT; that confuses userspace, which then considers the device to be
a mouse/touchpad instead of touchscreen.
Fix that by unmapping BTN_LEFT and keeping only BTN_TOUCH in place.
[ Upstream commit 593f4b19a094c4426bd1e1e3cbab87a48bd13c71 ]
HDMI 2.0 Appendix F suggest that we should keep sending the infoframe
when switching from 3D to 2D mode, even if the infoframe isn't strictly
necessary (ie. not needed to transmit the VIC or stereo information).
This is a workaround against some sinks that fail to realize that they
should switch from 3D to 2D mode when the source stop transmitting
the infoframe.
v2: Handle unpack() as well
Pull the length calculation into a helper
Cc: Shashank Sharma <shashank.sharma@intel.com>
Cc: Andrzej Hajda <a.hajda@samsung.com>
Cc: Thierry Reding <thierry.reding@gmail.com>
Cc: Hans Verkuil <hans.verkuil@cisco.com>
Cc: linux-media@vger.kernel.org
Reviewed-by: Andrzej Hajda <a.hajda@samsung.com> #v1
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20171113170427.4150-2-ville.syrjala@linux.intel.com
Reviewed-by: Shashank Sharma <shashank.sharma@intel.com>
[ Upstream commit 1d1c36650752b7fb81cee515a9bba4131cac4b7c ]
Since drm_edid_to_eld() knows the connector type, we can set the type in
ELD while at it. Most connectors this gets called on are not DP
encoders, and with the HDMI type being 0, this does not change behaviour
for non-DP.
For i915 having this in place earlier would have saved a considerable
amount of debugging that lead to the fix 2d8f63297b9f ("drm/i915: always
update ELD connector type after get modes"). I don't see other drivers,
even the ones calling drm_edid_to_eld() on DP connectors, setting the
connector type in ELD.
Cc: Alex Deucher <alexander.deucher@amd.com>
Cc: Christian König <christian.koenig@amd.com>
Cc: Archit Taneja <architt@codeaurora.org>
Cc: Russell King <linux@armlinux.org.uk>
Cc: CK Hu <ck.hu@mediatek.com>
Cc: Philipp Zabel <p.zabel@pengutronix.de>
Cc: Ben Skeggs <bskeggs@redhat.com>
Cc: Mark Yao <mark.yao@rock-chips.com>
Cc: Benjamin Gaignard <benjamin.gaignard@linaro.org>
Cc: Vincent Abriou <vincent.abriou@st.com>
Cc: Eric Anholt <eric@anholt.net>
Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Acked-by: Thierry Reding <treding@nvidia.com>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/d527b31619528c477c2c136f25cdf118bc0cfc1d.1509545641.git.jani.nikula@intel.com
[ Upstream commit ecd7eb7c2bcf99f6c23d68ad56ce15949da848a1 ]
We have to use start port, for TX/RX of single packet,
instead of current aggregating port. This will fix SDIO
CMD53(TX/RX) returning -ETIMEDOUT and halting the data path.
Fixes: 0cb52aac4d19 ("mwifiex: do not set multiport flag for tx/rx single packet")
Signed-off-by: Ganapathi Bhat <gbhat@marvell.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
[ Upstream commit db49a71798a38f3ddf3f3462703328dca39b1ac7 ]
(This is a patch has been sitting in the Intel CQM/CMT driver series for
a while, despite not depend on it. Sending it now independently since
the series is being discarded.)
When an event is in error state, read() returns 0 instead of sizeof()
buffer. In certain modes, such as interval printing, ignoring the 0
return value may cause bogus count deltas to be computed and thus
invalid results printed.
This patch fixes this problem by modifying read_counters() to mark the
event as not scaled (scaled = -1) to force the printout routine to show
<NOT COUNTED>.
Signed-off-by: Stephane Eranian <eranian@google.com>
Reviewed-by: David Carrillo-Cisneros <davidcc@google.com>
Acked-by: Jiri Olsa <jolsa@redhat.com>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Mathieu Poirier <mathieu.poirier@linaro.org>
Cc: Paul Turner <pjt@google.com>
Cc: Wang Nan <wangnan0@huawei.com>
Link: http://lkml.kernel.org/r/20170412182301.44406-1-davidcc@google.com
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
[ Upstream commit 0f6edfe2bbbb59d161580cb4870fcc46f5490f85 ]
In case count is not multiple of 4, there is a read access in
wil_memcpy_toio_32() from outside src buffer boundary.
In wil_memcpy_fromio_32(), in case count is not multiple of 4, there is
a write access to outside dst io memory boundary.
Fix these issues with proper handling of the last 1 to 4 copied bytes.
Signed-off-by: Dedy Lansky <qca_dlansky@qca.qualcomm.com>
Signed-off-by: Maya Erez <qca_merez@qca.qualcomm.com>
Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com>
[ Upstream commit b819447dfc4bd120c9d6cd8521252d544fce8fe7 ]
Existing code that ignores connection events during
reset flow will never take effect since it locks the
same mutex taken by the reset flow.
In addition, in case of unsolicited disconnect events ignore
those as well since device is about to get reset.
Signed-off-by: Hamad Kadmany <qca_hkadmany@qca.qualcomm.com>
[ Upstream commit 62ca0690cd495bb7c1414cdf0cf790c2922a1d79 ]
In 'ath10k_ce_alloc_pipe' the compile time sanity check to
ensure that there is sufficient buffers in CE4 for HTT Tx
MSDU descriptors, but this did not take into account of the
case with 'peer flow control' enabled, fix this.
Cc: Michal Kazior <michal.kazior@tieto.com>
Signed-off-by: Mohammed Shafi Shajakhan <mohammed@qti.qualcomm.com>
[ Upstream commit 1d5e9f80ab021e3e1f9436627a4ad07a143ccb2c ]
When channel contexts are used, there's no global power level
(the power_level is always 0). Use the per-interface TX power
in mac80211_hwsim to have a proper setting for both cases.
This fixes the bgscan_simple and bgscan_learn test cases when
the number of channels advertised by hwsim is >1 by default.
[ Upstream commit d2891c4d071d807f01cc911dc42a68f4568d65cf ]
When adding 6lowpan devices very rapidly we sometimes see a crash:
[23122.306615] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 4.9.0-43-arm64 #1 Debian 4.9.9.linaro.43-1
[23122.315400] Hardware name: HiKey Development Board (DT)
[23122.320623] task: ffff800075443080 task.stack: ffff800075484000
[23122.326551] PC is at expire_timers+0x70/0x150
[23122.330907] LR is at run_timer_softirq+0xa0/0x1a0
[23122.335616] pc : [<ffff000008142dd8>] lr : [<ffff000008142f58>] pstate: 600001c5
This was due to add_peer_chan() unconditionally initializing the
lowpan_btle_dev->notify_peers delayed work structure, even if the
lowpan_btle_dev passed into add_peer_chan() had previously been
initialized.
Normally, this would go unnoticed as the delayed work timer is set for
100 msec, however when calling add_peer_chan() faster than 100 msec it
clears out a previously queued delay work causing the crash above.
To fix this, let add_peer_chan() know when a new lowpan_btle_dev is passed
in so that it only performs the delay work initialization when needed.
Signed-off-by: Michael Scott <michael.scott@linaro.org>
Acked-by: Jukka Rissanen <jukka.rissanen@linux.intel.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
[ Upstream commit 27bfbc21a0c0f711fa5382de026c7c0700c9ea28 ]
There is a race condition between a thread calling bt_accept_dequeue()
and a different thread calling bt_accept_unlink(). Protection against
concurrency is implemented using sk locking. However, sk locking causes
serialisation of the bt_accept_dequeue() and bt_accept_unlink() threads.
This serialisation can cause bt_accept_dequeue() to obtain the sk from the
parent list but becomes blocked waiting for the sk lock held by the
bt_accept_unlink() thread. bt_accept_unlink() unlinks sk and this thread
releases the sk lock unblocking bt_accept_dequeue() which potentially runs
bt_accept_unlink() again on the same sk causing a crash. The attempt to
double unlink the same sk from the parent list can cause a NULL pointer
dereference crash due to bt_sk(sk)->parent becoming NULL on the first
unlink, followed by the second unlink trying to execute
bt_sk(sk)->parent->sk_ack_backlog-- in bt_accept_unlink() which crashes.
When sk is in the parent list, bt_sk(sk)->parent will be not be NULL.
When sk is removed from the parent list, bt_sk(sk)->parent is set to
NULL. Therefore, add a defensive check for bt_sk(sk)->parent not being
NULL to ensure that sk is still in the parent list after the sk lock has
been taken in bt_accept_dequeue(). If bt_sk(sk)->parent is detected as
being NULL then restart the loop so that the loop variables are refreshed
to use the latest values. This is necessary as list_for_each_entry_safe()
is not thread safe so causing a risk of an infinite loop occurring as sk
could point to itself.
In addition, in bt_accept_dequeue() increase the sk reference count to
protect against early freeing of sk. Early freeing can be possible if the
bt_accept_unlink() thread calls l2cap_sock_kill() or rfcomm_sock_kill()
functions before bt_accept_dequeue() gets the sk lock.
For test purposes, the probability of failure can be increased by putting
a msleep of 1 second in bt_accept_dequeue() between getting the sk and
waiting for the sk lock. This exposes the fact that the loop
list_for_each_entry_safe(p, n, &bt_sk(parent)->accept_q) is not safe from
threads that unlink sk from the list in parallel with the loop which can
cause sk to become stale within the loop.
Signed-off-by: Dean Jenkins <Dean_Jenkins@mentor.com>
[ Upstream commit a62ca337b36e31621b582cbe8f17d9404a48e120 ]
Fix a typo which caused both vfe0 and vfe1 powerdomains to be
named as vfe0.
Signed-off-by: Rajendra Nayak <rnayak@codeaurora.org>
Fixes: 7e824d507909 ("clk: qcom: gdsc: Add mmcc gdscs for msm8996 family")
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: Michael Turquette <mturquette@baylibre.com>
[ Upstream commit 250b76f43f57d578ebff5e7211eb2c73aa5cd6ca ]
The rate of the PWM calculated as follows:
hz = NSEC_PER_SEC / period_ns;
rate = (rate + (hz / 2)) / hz;
This has the precision loss in lower PWM rate.
Change this to have more precision as:
hz = DIV_ROUND_CLOSEST_ULL(NSEC_PER_SEC * 100, period_ns);
rate = DIV_ROUND_CLOSEST(rate * 100, hz)
Example:
1. period_ns = 16672000, PWM clock rate is 200 KHz.
Based on old formula
= 1000000000ul/16672000
= 59 (59.98)
rate = (200K + 59/2)/59 = 3390
Based on new method:
hz = 5998
rate = DIV_ROUND_CLOSE(200000*100, 5998) = 3334
If we measure the PWM signal rate, we will get more accurate
period with rate value of 3334 instead of 3390.
2. period_ns = 16803898, PWM clock rate is 200 KHz.
Based on old formula:
hz = 59, rate = 3390
Based on new formula:
hz = 5951, rate = 3360
The PWM signal rate of 3360 is more near to requested period
than 3333.
Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
[ Upstream commit d0381c81c2f782fa2131178d11e0cfb23d50d631 ]
Set the pages which is used for kprobes' singlestep buffer
and optprobe's trampoline instruction buffer to readonly.
This can prevent unexpected (or unintended) instruction
modification.
This also passes rodata_test as below.
Without this patch, rodata_test shows a warning:
WARNING: CPU: 0 PID: 1 at arch/x86/mm/dump_pagetables.c:235 note_page+0x7a9/0xa20
x86/mm: Found insecure W+X mapping at address ffffffffa0000000/0xffffffffa0000000
With this fix, no W+X pages are found:
x86/mm: Checked W+X mappings: passed, no W+X pages found.
rodata_test: all tests were successful
Reported-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com>
Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: David S . Miller <davem@davemloft.net>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Ye Xiaolong <xiaolong.ye@intel.com>
Link: http://lkml.kernel.org/r/149076375592.22469.14174394514338612247.stgit@devbox
[ Upstream commit bd0b90676c30fe640e7ead919b3e38846ac88ab7 ]
Fix the kprobe-booster not to boost far call instruction,
because a call may store the address in the single-step
execution buffer to the stack, which should be modified
after single stepping.
Currently, this instruction will be filtered as not
boostable in resume_execution(), so this is not a
critical issue.
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Link: http://lkml.kernel.org/r/149076340615.22469.14066273186134229909.stgit@devbox
[ Upstream commit 12ee4022f67f8854061b46e5c0a7ad6258ab66c2 ]
Geminilake is Skylake family platform. So add it's id to skl_plus check.
Fixes: 126cfa2f5e15 ("ALSA: hda: Add Geminilake HDMI codec ID")
Signed-off-by: Subhransu S. Prusty <subhransu.s.prusty@intel.com>
Cc: Senthilnathan Veppur <senthilnathanx.veppur@intel.com>
Cc: Vinod Koul <vinod.koul@intel.com>
Cc: Takashi Iwai <tiwai@suse.de>
[ Upstream commit 97d27b0dd015e980ade63fda111fd1353276e28b ]
sg_remove_sfp_usercontext() is clearing any sg requests, but needs to
take 'rq_list_lock' when modifying the list.
Reported-by: Christoph Hellwig <hch@lst.de>
Signed-off-by: Hannes Reinecke <hare@suse.com>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Tested-by: Johannes Thumshirn <jthumshirn@suse.de>
[ Upstream commit 28676d869bbb5257b5f14c0c95ad3af3a7019dd5 ]
Check for a valid direction before starting the request, otherwise we
risk running into an assertion in the scsi midlayer checking for valid
requests.
[mkp: fixed typo]
Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de>
Link: http://www.spinics.net/lists/linux-scsi/msg104400.html
[ Upstream commit 3393af24b665cb0aea7353b05e522b03ab1e7d73 ]
This adds missing checking for kzalloc() return value.
Fixes: 4b6fad7097f8 ("powerpc/mm/iommu, vfio/spapr: Put pages on VFIO container shutdown")
Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Reviewed-by: David Gibson <david@gibson.dropbear.id.au>
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
[ Upstream commit 1282ba7fc28dbc66c3f0e4aaafaaa228361d1ae5 ]
The existing SPAPR TCE driver advertises both VFIO_SPAPR_TCE_IOMMU and
VFIO_SPAPR_TCE_v2_IOMMU types to the userspace and the userspace usually
picks the v2.
Normally the userspace would create a container, attach an IOMMU group
to it and only then set the IOMMU type (which would normally be v2).
However a specific IOMMU group may not support v2, in other words
it may not implement set_window/unset_window/take_ownership/
release_ownership and such a group should not be attached to
a v2 container.
This adds extra checks that a new group can do what the selected IOMMU
type suggests. The userspace can then test the return value from
ioctl(VFIO_SET_IOMMU, VFIO_SPAPR_TCE_v2_IOMMU) and try
VFIO_SPAPR_TCE_IOMMU.
[ Upstream commit 0973ad97c187e06aece61f685b9c3b2d93290a73 ]
Session sets a number parameters that rely on evlist. These parameters
are not used in pipe-mode and should not be set, since evlist is
unavailable. Fix that.
Signed-off-by: David Carrillo-Cisneros <davidcc@google.com>
Acked-by: Jiri Olsa <jolsa@kernel.org>
Cc: He Kuang <hekuang@huawei.com>
Cc: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Simon Que <sque@chromium.org>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/20170410201432.24807-6-davidcc@google.com
[ Check if file != NULL in perf_session__new(), like when used by builtin-top.c ]
[ Upstream commit 9269e5560b261eb9ee157497890dc0948db76cf8 ]
Many boards use i2c/spi expander gpio as phy-reset-gpios and these
gpios maybe registered after fec port, driver should check the return
value of .of_get_named_gpio().
Signed-off-by: Fugang Duan <B38611@freescale.com>
[ Upstream commit 1e0d4f0200e4dbdfc38d818f329d8a0955f7c6f5 ]
__perf_session__process_pipe_events reuses the same memory buffer to
process all events in the pipe.
When reordering is needed (e.g. -b option), events are not immediately
flushed, but kept around until reordering is possible, causing
memory corruption.
The problem is usually observed by a "Unknown sample error" output. It
can easily be reproduced by:
perf record -o - noploop | perf inject -b > output
Committer testing:
Before:
$ perf record -o - stress -t 2 -c 2 | perf inject -b > /dev/null
stress: info: [8297] dispatching hogs: 2 cpu, 0 io, 0 vm, 0 hdd
stress: info: [8297] successful run completed in 2s
[ perf record: Woken up 3 times to write data ]
[ perf record: Captured and wrote 0.000 MB - ]
Warning:
Found 1 unknown events!
Is this an older tool processing a perf.data file generated by a more recent tool?
If that is not the case, consider reporting to linux-kernel@vger.kernel.org.
After:
stress: info: [9027] dispatching hogs: 2 cpu, 0 io, 0 vm, 0 hdd
stress: info: [9027] successful run completed in 2s
no symbols found in /usr/bin/stress, maybe install a debug package?
Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Link: http://lkml.kernel.org/r/20170410201432.24807-3-davidcc@google.com
[ Upstream commit 7654137071fa706e5c91f4f27bc2a5cd7e435a9b ]
In armpmu_dispatch_irq() we look at arm_pmu::plat_device to acquire
platdata, so that we can defer to platform-specific IRQ handling,
required on some 32-bit parts. With the advent of ACPI we won't always
have a platform_device, and so we must avoid trying to dereference
fields from it.
This patch fixes up armpmu_dispatch_irq() to avoid doing so, introducing
a new armpmu_get_platdata() helper.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Tested-by: Jeremy Linton <jeremy.linton@arm.com>
[ Upstream commit 5cddd05c9cbe420436799716d009bc0372ef8268 ]
When receiving a frame, we currently pull in sizeof(*hdr) plus
some extra (crypto/snap), which is too much, most headers aren't
actually sizeof(*hdr) since that takes into account the 4-address
format but doesn't take into account QoS. As a result, a typical
frame will have 4 bytes of the payload in the SKB header already.
Fix this by calculating the correct header length, and now that
we have that, align the end of the SKB header to a multiple of 4
so that the IP header will be aligned properly when pulled in.
[ Upstream commit 32ccb130f5325abc81b32b1a538390f46e4860f6 ]
The kernel has a special check for a specific irq_vectors trace event.
TRACE_EVENT_PERF_PERM(irq_work_exit,
is_sampling_event(p_event) ? -EPERM : 0);
The perf-record fails for this irq_vectors event when it is present,
like when using a wildcard:
root@skl:/tmp# perf record -a -e irq_vectors:* sleep 2
Error:
You may not have permission to collect system-wide stats.
Consider tweaking /proc/sys/kernel/perf_event_paranoid,
which controls use of the performance events system by
unprivileged users (without CAP_SYS_ADMIN).
The current value is 2:
-1: Allow use of (almost) all events by all users
>= 0: Disallow raw tracepoint access by users without CAP_IOC_LOCK
>= 1: Disallow CPU event access by users without CAP_SYS_ADMIN
>= 2: Disallow kernel profiling by users without CAP_SYS_ADMIN
To make this setting permanent, edit /etc/sysctl.conf too, e.g.:
kernel.perf_event_paranoid = -1
This patch prints out the exact sub event that failed with EPERM for
wildcards to help in understanding what went wrong when this event is
present:
After the patch:
Error:
No permission to enable irq_vectors:irq_work_exit event.
Committer notes:
So we have a lot of irq_vectors events:
[root@jouet ~]# perf list irq_vectors:*
List of pre-defined events (to be used in -e):
irq_vectors:call_function_entry [Tracepoint event]
irq_vectors:call_function_exit [Tracepoint event]
irq_vectors:call_function_single_entry [Tracepoint event]
irq_vectors:call_function_single_exit [Tracepoint event]
irq_vectors:deferred_error_apic_entry [Tracepoint event]
irq_vectors:deferred_error_apic_exit [Tracepoint event]
irq_vectors:error_apic_entry [Tracepoint event]
irq_vectors:error_apic_exit [Tracepoint event]
irq_vectors:irq_work_entry [Tracepoint event]
irq_vectors:irq_work_exit [Tracepoint event]
irq_vectors:local_timer_entry [Tracepoint event]
irq_vectors:local_timer_exit [Tracepoint event]
irq_vectors:reschedule_entry [Tracepoint event]
irq_vectors:reschedule_exit [Tracepoint event]
irq_vectors:spurious_apic_entry [Tracepoint event]
irq_vectors:spurious_apic_exit [Tracepoint event]
irq_vectors:thermal_apic_entry [Tracepoint event]
irq_vectors:thermal_apic_exit [Tracepoint event]
irq_vectors:threshold_apic_entry [Tracepoint event]
irq_vectors:threshold_apic_exit [Tracepoint event]
irq_vectors:x86_platform_ipi_entry [Tracepoint event]
irq_vectors:x86_platform_ipi_exit [Tracepoint event]
And some may be sampled:
[root@jouet ~]# perf record -e irq_vectors:local* sleep 20s
[ perf record: Woken up 1 times to write data ]
[ perf record: Captured and wrote 0.020 MB perf.data (2 samples) ]
[root@jouet ~]# perf report -D | egrep 'stats:|events:'
Aggregated stats:
TOTAL events: 155
MMAP events: 144
COMM events: 2
EXIT events: 1
SAMPLE events: 2
MMAP2 events: 4
FINISHED_ROUND events: 1
TIME_CONV events: 1
irq_vectors:local_timer_entry stats:
TOTAL events: 1
SAMPLE events: 1
irq_vectors:local_timer_exit stats:
TOTAL events: 1
SAMPLE events: 1
[root@jouet ~]#
But, as shown in the tracepoint definition at the start of this message,
some, like "irq_vectors:irq_work_exit", may not be sampled, just counted,
i.e. if we try to sample, as when using 'perf record', we get an error:
[root@jouet ~]# perf record -e irq_vectors:irq_work_exit
Error:
<SNIP>
The error message is misleading, this patch will help in pointing out
what is the event causing such an error, but the error message needs
improvement, i.e. we need to figure out a way to check if a tracepoint
is counting only, like this one, when all we can do is to count it with
'perf stat', at most printing the delta using interval printing, as in:
[root@jouet ~]# perf stat -I 5000 -e irq_vectors:irq_work_*
# time counts unit events
5.000168871 0 irq_vectors:irq_work_entry
5.000168871 0 irq_vectors:irq_work_exit
10.000676730 0 irq_vectors:irq_work_entry
10.000676730 0 irq_vectors:irq_work_exit
15.001122415 0 irq_vectors:irq_work_entry
15.001122415 0 irq_vectors:irq_work_exit
20.001298051 0 irq_vectors:irq_work_entry
20.001298051 0 irq_vectors:irq_work_exit
25.001485020 1 irq_vectors:irq_work_entry
25.001485020 1 irq_vectors:irq_work_exit
30.001658706 0 irq_vectors:irq_work_entry
30.001658706 0 irq_vectors:irq_work_exit
^C 32.045711878 0 irq_vectors:irq_work_entry
32.045711878 0 irq_vectors:irq_work_exit
[root@jouet ~]#
But at least, when we use a wildcard, this patch helps a bit.
Signed-off-by: Yao Jin <yao.jin@linux.intel.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Kan Liang <kan.liang@intel.com>
Link: http://lkml.kernel.org/r/1491566932-503-1-git-send-email-yao.jin@linux.intel.com
dummy_hub_control()
[ Upstream commit 9f20dfb44d03745d0d3cef2ffb3abf8d8024fa61 ]
This fixes the commit: 1cd8fd2887e1 ("usb: gadget: dummy_hcd: add
SuperSpeed support").
In the case of ClearPortFeature and USB_PORT_FEAT_POWER, simply clear
the right bit regardless of what the wValue is.
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Yuyang Du <yuyang.du@intel.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
[ Upstream commit dad3f793f20fbb5c0c342f0f5a0bdf69a4d76089 ]
I had seen some odd behavior with HiKey's usb-gadget interface
that I finally seemed to have chased down. Basically every other
time I plugged in the OTG port, the gadget interface would
properly initialize. The other times, I'd get a big WARN_ON
in dwc2_hsotg_init_fifo() about the fifo_map not being clear.
Ends up if we don't disconnect the gadget state, the fifo-map
doesn't get cleared properly, which causes WARN_ON messages and
also results in the device not properly being setup as a gadget
every other time the OTG port is connected.
So this patch adds a call to dwc2_hsotg_disconnect() in the
reset path so the state is properly cleared.
With it, the gadget interface initializes properly on every
plug in.
Cc: Wei Xu <xuwei5@hisilicon.com>
Cc: Guodong Xu <guodong.xu@linaro.org>
Cc: Amit Pundir <amit.pundir@linaro.org>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: John Youn <johnyoun@synopsys.com>
Cc: Douglas Anderson <dianders@chromium.org>
Cc: Chen Yu <chenyu56@huawei.com>
Cc: Felipe Balbi <felipe.balbi@linux.intel.com>
Cc: linux-usb@vger.kernel.org
Acked-by: John Youn <johnyoun@synopsys.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
[ Upstream commit 4868e3508d1934d28961f940ed6b9f1e347ab52c ]
setup_initial_memory_limit() is called from early_init_devtree(), which
runs prior to feature patching. If the kernel is built with CONFIG_JUMP_LABEL=y
and CONFIG_JUMP_LABEL_FEATURE_CHECKS=y then we will potentially get the
wrong value.
If we also have CONFIG_JUMP_LABEL_FEATURE_CHECK_DEBUG=y we get a warning
and backtrace:
Warning! mmu_has_feature() used prior to jump label init!
CPU: 0 PID: 0 Comm: swapper Not tainted 4.11.0-rc4-gccN-next-20170331-g6af2434 #1
Call Trace:
[c000000000fc3d50] [c000000000a26c30] .dump_stack+0xa8/0xe8 (unreliable)
[c000000000fc3de0] [c00000000002e6b8] .setup_initial_memory_limit+0xa4/0x104
[c000000000fc3e60] [c000000000d5c23c] .early_init_devtree+0xd0/0x2f8
[c000000000fc3f00] [c000000000d5d3b0] .early_setup+0x90/0x11c
[c000000000fc3f90] [c000000000000520] start_here_multiplatform+0x68/0x80
Fix it by using early_mmu_has_feature().
Fixes: c12e6f24d413 ("powerpc: Add option to use jump label for mmu_has_feature()")
[ Upstream commit b670883bb9e55ba63a278d83e034faefc01ce2cf ]
md.c: it needs to release the mddev lock before
the array_size_store() returns.
Fixes: ab5a98b132fd ("md-cluster: change array_sectors and update size are not supported")
Signed-off-by: Zhilong Liu <zlliu@suse.com>
Reviewed-by: Guoqing Jiang <gqjiang@suse.com>
Signed-off-by: Shaohua Li <shli@fb.com>
[ Upstream commit 7471fb77ce4dc4cb81291189947fcdf621a97987 ]
When recoverying a single missing/failed device in a RAID6,
those stripes where the Q block is on the missing device are
handled a bit differently. In these cases it is easy to
check that the P block is correct, so we do. This results
in the P block be destroy. Consequently the P block needs
to be read a second time in order to compute Q. This causes
lots of seeks and hurts performance.
It shouldn't be necessary to re-read P as it can be computed
from the DATA. But we only compute blocks on missing
devices, since c337869d9501 ("md: do not compute parity
unless it is on a failed drive").
So relax the change made in that commit to allow computing
of the P block in a RAID6 which it is the only missing that
block.
This makes RAID6 recovery run much faster as the disk just
"before" the recovering device is no longer seeking
back-and-forth.
Reported-by-tested-by: Brad Campbell <lists2009@fnarfbargle.com>
Reviewed-by: Dan Williams <dan.j.williams@intel.com>
Signed-off-by: NeilBrown <neilb@suse.com>
[ Upstream commit 0c08aaf873174c95e674cf21ffcd041c589d2e5b ]
ISL9305_MAX_REGULATOR is the last index used to access the init_data[]
array, so we need to add one to this last index to obtain the necessary
array size.
This fixes the following smatch error:
drivers/regulator/isl9305.c:160 isl9305_i2c_probe() error: buffer overflow 'pdata->init_data' 3 <= 3
Fixes: dec38b5ce6a9edb4 ("regulator: isl9305: Add Intersil ISL9305/H driver")
Signed-off-by: Vincent Stehlé <vincent.stehle@laposte.net>
Cc: Mark Brown <broonie@kernel.org>
Signed-off-by: Mark Brown <broonie@kernel.org>
[ Upstream commit 1531a208ed861e4bd287444f9466ffcf98383de2 ]
The DRM object does not register the pipe with the WPF object. This is
used internally throughout the driver as a means of accessing the pipe.
As such this breaks operations which require access to the pipe from WPF
interrupts.
Register the pipe inside the WPF object after it has been declared as
the output.
Fixes: ff7e97c94d9f ("[media] v4l: vsp1: Store pipeline pointer in rwpf")
Signed-off-by: Kieran Bingham <kieran.bingham+renesas@ideasonboard.com>
Reviewed-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
[ Upstream commit 4461c84b52b4a952c657505ef7e4e06b016783df ]
With multiple inputs through the BRU it is feasible for the streams to
race each other at stream-on.
Multiple VIDIOC_STREAMON calls racing each other could have process
N-1 skipping over the pipeline setup section and then start the pipeline
early, if videobuf2 has already enqueued buffers to the driver for
process N but not called the .start_streaming() operation yet
In the case of the video pipelines, this
can present two serious issues.
1) A null-dereference if the pipe->dl is committed at the same time as
the vsp1_video_setup_pipeline() is processing
2) A hardware hang, where a display list is committed without having
called vsp1_video_setup_pipeline() first
Repair this issue, by ensuring that only the stream which configures the
pipeline is able to start it.
[ Upstream commit 411dac79cc2ed80f7e348ccc23eb4d8b0ba9f6d5 ]
Add missing clearing of BLTZALL and BGEZALL emulation counters in
function mipsr2_stats_clear_show().
Previously, it was not possible to reset BLTZALL and BGEZALL
emulation counters - their value remained the same even after
explicit request via debugfs. As far as other related counters
are concerned, they all seem to be properly cleared.
This change affects debugfs operation only, core R2 emulation
functionality is not affected.
Signed-off-by: Aleksandar Markovic <aleksandar.markovic@imgtec.com>
Reviewed-by: Paul Burton <paul.burton@imgtec.com>
Cc: james.hogan@imgtec.com
Cc: leonid.yegoshin@imgtec.com
Cc: douglas.leung@imgtec.com
Cc: petar.jovanovic@imgtec.com
Cc: miodrag.dinic@imgtec.com
Cc: goran.ferenc@imgtec.com
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/15517/
[ Upstream commit 5bba7aa4958e271c3ffceb70d47d3206524cf489 ]
Fix the problem of inaccurate identification of instructions BLEZL and
BGTZL in R2 emulation code by making sure all necessary encoding
specifications are met.
Previously, certain R6 instructions could be identified as BLEZL or
BGTZL. R2 emulation routine didn't take into account that both BLEZL
and BGTZL instructions require their rt field (bits 20 to 16 of
instruction encoding) to be 0, and that, at same time, if the value in
that field is not 0, the encoding may represent a legitimate MIPS R6
instruction.
This means that a problem could occur after emulation optimization,
when emulation routine tried to pipeline emulation, picked up a next
candidate, and subsequently misrecognized an R6 instruction as BLEZL
or BGTZL.
It should be said that for single pass strategy, the problem does not
happen because CPU doesn't trap on branch-compacts which share opcode
space with BLEZL/BGTZL (but have rt field != 0, of course).
Signed-off-by: Leonid Yegoshin <leonid.yegoshin@imgtec.com>
Signed-off-by: Miodrag Dinic <miodrag.dinic@imgtech.com>
Signed-off-by: Aleksandar Markovic <aleksandar.markovic@imgtech.com>
Reported-by: Douglas Leung <douglas.leung@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/15456/
[ Upstream commit a81507c79f4ae9a0f9fb1054b59b62a090620dd9 ]
o Socket data is unsigned, so use unsigned accessors instructions.
o Fix path result pointer generation arithmetic.
o Fix half-word byte swapping code for unsigned semantics.
Signed-off-by: David Daney <david.daney@cavium.com>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Alexei Starovoitov <ast@kernel.org>
Cc: Steven J. Hill <steven.hill@cavium.com>
Cc: netdev@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/15747/
[ Upstream commit 1ef0910cfd681f0bd0b81f8809935b2006e9cfb9 ]
If bpf_needs_clear_a() returns true, only actually clear it if it is
ever used. If it is not used, we don't save and restore it, so the
clearing has the nasty side effect of clobbering caller state.
Also, don't emit stack pointer adjustment instructions if the
adjustment amount is zero.
Patchwork: https://patchwork.linux-mips.org/patch/15745/
[ Upstream commit e61c38d85b7392e033ee03bca46f1d6006156175 ]
If the UART is operated in DTE mode and UCR3_DCD or UCR3_RI are 1 (which
is the reset default) and the opposite side pulls the respective line to
its active level the irq triggers after it is requested in .probe.
These irqs were already disabled in .startup but this might be too late.
Also setup of the UFCR_DCEDTE bit (currently done in .set_termios) is
done very late which is critical as it also controls direction of some
pins.
So setup UFCR_DCEDTE earlier (in .probe) and also disable the broken
irqs in DTE mode there before requesting irqs.
Acked-by: Lucas Stach <l.stach@pengutronix.de>
[ Upstream commit 7d05587c9e0e4611650bb403812e2d492c178a9f ]
On SMP systems, we see a lot of spurious TX interrupts when a
program generates a steady stream of output to the pl011 UART.
The problem can be easily seen when one CPU generates the output
while another CPU handles the pl011 interrupts, and the rate of
output is low enough not to fill the TX FIFO. The problem seems
to be:
-- CPU a -- -- CPU b --
(take port lock)
pl011_start_tx
pl011_start_tx_pio
enable TXIM in REG_IMSC -> causes uart tx intr (pl011_int)
pl011_tx_chars pl011_int
...tx chars, all done... (wait for port lock)
pl011_stop_tx .
disable TXIM .
(release port lock) -> (take port lock)
check for TXIM, not enabled
(release port lock)
return IRQ_NONE
Enabling the TXIM in pl011_start_tx_pio() causes the interrupt
to be generated and delivered to CPU b, even though pl011_tx_chars()
is able to complete the TX and then disable the tx interrupt.
Fix this by enabling TXIM only after pl011_tx_chars, if it is needed.
pl011_tx_chars will return a boolean indicating whether the TX
interrupts have to be enabled.
Debugged-by: Vijaya Kumar <Vijaya.Kumar@cavium.com>
Signed-off-by: Jayachandran C <jnair@caviumnetworks.com>
[ Upstream commit 7064dc7fc13b2994d33ae540ffb7a3a05ac463bf ]
I ran into a link error on ARM64 for lkdtm_rodata_do_nothing:
drivers/misc/built-in.o: In function `lkdtm_rodata_do_nothing':
:(.rodata+0x68c8): relocation truncated to fit: R_AARCH64_CALL26 against symbol `__sanitizer_cov_trace_pc' defined in .text section in kernel/built-in.o
I did not analyze this further, but my theory is that we would need a trampoline
to call __sanitizer_cov_trace_pc(), but the linker (correctly) only adds trampolines
for callers in executable sections.
Disabling KCOV for this one file avoids the build failure with no
other practical downsides I can think of.
The problem can only happen on kernels that contain both kcov and
lkdtm, so if we want to backport this, it should be in the earliest
version that has both (v4.8).
Fixes: 5c9a8750a640 ("kernel: add kcov code coverage")
Fixes: 9a49a528dcf3 ("lkdtm: add function for testing .rodata section")
Acked-by: Dmitry Vyukov <dvyukov@google.com>
