2015-03-31ipv6: coding style: comparison for inequality with NULLIan Morris
The ipv6 code uses a mixture of coding styles. In some instances check for NULL pointer is done as x != NULL and sometimes as x. x is preferred according to checkpatch and this patch makes the code consistent by adopting the latter form. No changes detected by objdiff. Signed-off-by: Ian Morris <ipm@chirality.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31ipv6: coding style: comparison for equality with NULLIan Morris
The ipv6 code uses a mixture of coding styles. In some instances check for NULL pointer is done as x == NULL and sometimes as !x. !x is preferred according to checkpatch and this patch makes the code consistent by adopting the latter form. No changes detected by objdiff. Signed-off-by: Ian Morris <ipm@chirality.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31Merge branch 'bnx2x-next'David S. Miller
Yuval Mintz says: ==================== bnx2x: link and protection changes This patch series contains 2 small additions to link configuration, as well as a safeguard against loading the device on a hardware at a failed state. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31bnx2x: Prevent probe as early as possibleYuval Mintz
It's possible that due to errors [either on PCI or on device itself] registers reads would fail, returning all-Fs. This adds a check as early as possible so that driver will not read junk values and make incorrect probe decisions according to them; instead, gracefully fail the probe. Signed-off-by: Yuval Mintz <Yuval.Mintz@qlogic.com> Signed-off-by: Ariel Elior <Ariel.Elior@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31bnx2x: Count number of link changesYaniv Rosner
Number of link changes are now being stored in shared memory [by all possible link owners], for management use [as well as possible debug information for dumps]. Signed-off-by: Yaniv Rosner <Yaniv.Rosner@qlogic.com> Signed-off-by: Yuval Mintz <Yuval.Mintz@qlogic.com> Signed-off-by: Ariel Elior <Ariel.Elior@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31bnx2x: Configure IFir et al. according to nvramYaniv Rosner
Enable controlling Post2, coeff, IPreDriver and IFir according to NVRAM setup. Signed-off-by: Yaniv Rosner <Yaniv.Rosner@qlogic.com> Signed-off-by: Yuval Mintz <Yuval.Mintz@qlogic.com> Signed-off-by: Ariel Elior <Ariel.Elior@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31bonding: Remove hardcoded initializationMahesh Bandewar
Signed-off-by: Mahesh Bandewar <maheshb@google.com> Signed-off-by: Andy Gospodarek <gospo@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31fib_trie: Cleanup ip_fib_net_exit code pathAlexander Duyck
While fixing a recent issue I noticed that we are doing some unnecessary work inside the loop for ip_fib_net_exit. As such I am pulling out the initialization to NULL for the locally stored fib_local, fib_main, and fib_default. In addition I am restoring the original code for flushing the table as there is no need to split up the fib_table_flush and hlist_del work since the code for packing the tnodes with multiple key vectors was dropped. Signed-off-by: Alexander Duyck <alexander.h.duyck@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31fib_trie: Fix warning on fib4_rules_exitAlexander Duyck
This fixes the following warning: BUG: sleeping function called from invalid context at mm/slub.c:1268 in_atomic(): 1, irqs_disabled(): 0, pid: 6, name: kworker/u8:0 INFO: lockdep is turned off. CPU: 3 PID: 6 Comm: kworker/u8:0 Tainted: G W 4.0.0-rc5+ #895 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 Workqueue: netns cleanup_net 0000000000000006 ffff88011953fa68 ffffffff81a203b6 000000002c3a2c39 ffff88011952a680 ffff88011953fa98 ffffffff8109daf0 ffff8801186c6aa8 ffffffff81fbc9e5 00000000000004f4 0000000000000000 ffff88011953fac8 Call Trace: [<ffffffff81a203b6>] dump_stack+0x4c/0x65 [<ffffffff8109daf0>] ___might_sleep+0x1c3/0x1cb [<ffffffff8109db70>] __might_sleep+0x78/0x80 [<ffffffff8117a60e>] slab_pre_alloc_hook+0x31/0x8f [<ffffffff8117d4f6>] __kmalloc+0x69/0x14e [<ffffffff818ed0e1>] ? kzalloc.constprop.20+0xe/0x10 [<ffffffff818ed0e1>] kzalloc.constprop.20+0xe/0x10 [<ffffffff818ef622>] fib_trie_table+0x27/0x8b [<ffffffff818ef6bd>] fib_trie_unmerge+0x37/0x2a6 [<ffffffff810b06e1>] ? arch_local_irq_save+0x9/0xc [<ffffffff818e9793>] fib_unmerge+0x2d/0xb3 [<ffffffff818f5f56>] fib4_rule_delete+0x1f/0x52 [<ffffffff817f1c3f>] ? fib_rules_unregister+0x30/0xb2 [<ffffffff817f1c8b>] fib_rules_unregister+0x7c/0xb2 [<ffffffff818f64a1>] fib4_rules_exit+0x15/0x18 [<ffffffff818e8c0a>] ip_fib_net_exit+0x23/0xf2 [<ffffffff818e91f8>] fib_net_exit+0x32/0x36 [<ffffffff817c8352>] ops_exit_list+0x45/0x57 [<ffffffff817c8d3d>] cleanup_net+0x13c/0x1cd [<ffffffff8108b05d>] process_one_work+0x255/0x4ad [<ffffffff8108af69>] ? process_one_work+0x161/0x4ad [<ffffffff8108b4b1>] worker_thread+0x1cd/0x2ab [<ffffffff8108b2e4>] ? process_scheduled_works+0x2f/0x2f [<ffffffff81090686>] kthread+0xd4/0xdc [<ffffffff8109ec8f>] ? local_clock+0x19/0x22 [<ffffffff810905b2>] ? __kthread_parkme+0x83/0x83 [<ffffffff81a2c0c8>] ret_from_fork+0x58/0x90 [<ffffffff810905b2>] ? __kthread_parkme+0x83/0x83 The issue was that as a part of exiting the default rules were being deleted which resulted in the local trie being unmerged. By moving the freeing of the FIB tables up we can avoid the unmerge since there is no local table left when we call the fib4_rules_exit function. Fixes: 0ddcf43d5d4a ("ipv4: FIB Local/MAIN table collapse") Reported-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Alexander Duyck <alexander.h.duyck@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31Merge branch 'for-upstream' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth-next Johan Hedberg says: ==================== pull request: bluetooth-next 2015-03-27 Here's another set of Bluetooth & 802.15.4 patches for 4.1: - New API to control LE advertising data (i.e. peripheral role) - mac802154 & at86rf230 cleanups - Support for toggling quirks from debugfs (useful for testing) - Memory leak fix for LE scanning - Extra version info reading support for Broadcom controllers Please let me know if there are any issues pulling. Thanks. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31Merge branch 'ptp-2038'David S. Miller
Fixed two warnings in e1000e and igb, when switching to timespec64 some printf formats started to not match. In theses cases actually the new type is __kernel_time_t which is __kernel_long_t which unfortunately can be either "long" or "long long". So to solve this I cases the arguments to "long long". -DaveM Richard Cochran says: ==================== ptp: get ready for 2038 This series converts the core driver methods of the PTP Hardware Clock (PHC) subsystem to use the 64 bit version of the timespec structure, making the core API ready for the year 2038. In addition, I reviewed how each driver and device represents the time value at the hardware register level. Most of the drivers are ready, but a few will need some work before the year 2038, as shown: Patch Driver ------------------------------------------------ 12 drivers/net/ethernet/intel/igb/igb_ptp.c 15 ? drivers/net/ethernet/sfc/ptp.c 16 drivers/net/ethernet/stmicro/stmmac/stmmac_ptp.c The commit log messages document how each driver is ready or why it is not ready. For patch 15, I could not easily find out the hardware representation of the time value, and so the SFC maintainers will have to review their low level code in order to resolve any remaining issues. * ChangeLog ** V3 - dp83640: use timespec64 throughout per Arnd's suggestion - tilegx: use timespec64 throughout per Chris' suggestion - add Jeff's acked-bys ** V2 - use the new methods in the posix clock code right away (patch #3) ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31ptp: remove 32 bit get/set methods.Richard Cochran
All of the PHC drivers have been converted to the new methods. This patch converts the three remaining callers within the core code and removes the older methods for good. As a result, the core PHC code is ready for the year 2038. However, some of the PHC drivers are not quite ready yet. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31ptp: pch: convert to the 64 bit get/set time methods.Richard Cochran
The device has a 64 bit clock register, where each clock tick is 32 nanoseconds, and so with this patch the driver is ready for the year 2038. Compile tested only. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31ptp: ixp46x: convert to the 64 bit get/set time methods.Richard Cochran
The device has a 64 bit clock register, where each clock tick is 16 nanoseconds, and so with this patch the driver is ready for the year 2038. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31ptp: dp83640: convert to the 64 bit get/set time methods.Richard Cochran
This device stores the number of seconds in a 32 bit register, and the stored value is unsigned. Therefore this driver and device are ready for the year 2038. However, more work will be needed prior to 2106. Compile tested only. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31ptp: tilegx: convert to the 64 bit get/set time methods.Richard Cochran
This driver is 64 bit only, and so this driver and device are ready for 2038. This patch changes the driver to the new PHC and also carries the timespec64 parameter on out to the gxio_mpipe_get- set_timestamp functions, making explicit the fact that the tv_sec field is 64 bits wide. Not even compile tested. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Acked-by: Chris Metcalf <cmetcalf@ezchip.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31ptp: cpts: convert to the 64 bit get/set time methods.Richard Cochran
This driver's clock is implemented using a timecounter, and so with this patch the driver is ready for the year 2038. Compile tested only. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31ptp: stmmac: convert to the 64 bit get/set time methods.Richard Cochran
This device stores the number of seconds in a 32 bit register. So more work is needed on this driver before the year 2038 comes around. Compile tested only. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31ptp: sfc: convert to the 64 bit get/set time methods.Richard Cochran
This patch changes the driver to use the newer API. Depending on how the hardware represents a time value, this driver may or may not yet be ready for the year 2038. Compile tested only. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31ptp: mlx4: convert to the 64 bit get/set time methods.Richard Cochran
2015-03-31ptp: ixgbe: convert to the 64 bit get/set time methods.Richard Cochran
This driver's clock is implemented using a timecounter, and so with this patch the driver is ready for the year 2038. Compile tested only. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31ptp: igb: convert to the 64 bit get/set time methods.Richard Cochran
For the 82576, the driver's clock is implemented using a timecounter, and so with this patch that device is ready for the year 2038. However, in the case of the i210, the device stores the number of seconds in a 32 bit register. Therefore, more work is needed on this driver before the year 2038 comes around. Compile tested only. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31ptp: i40e: convert to the 64 bit get/set time methods.Richard Cochran
The device appears to use a 64 bit nanoseconds register, and so with this patch the driver should be ready for the year 2038. Compile tested only. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31ptp: fm10k: convert to the 64 bit get/set time methods.Richard Cochran
2015-03-31ptp: e1000e: convert to the 64 bit get/set time methods.Richard Cochran
2015-03-31ptp: gianfar: convert to the 64 bit get/set time methods.Richard Cochran
The device features a 64 bit nanoseconds register, and so with this patch the driver is ready for the year 2038. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31ptp: fec: convert to the 64 bit get/set time methods.Richard Cochran
2015-03-31ptp: tg3: convert to the 64 bit get/set time methods.Richard Cochran
The device appears to use a 64 bit nanoseconds register, and so with this patch the driver should be ready for the year 2038. Compile tested only. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31ptp: bnx2x: convert to the 64 bit get/set time methods.Richard Cochran
This driver's clock is implemented using a timecounter, and so with this patch the driver is ready for the year 2038. Compile tested only. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Acked-by: Sony Chacko <sony.chacko@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31ptp: xgbe: convert to the 64 bit get/set time methods.Richard Cochran
2015-03-31ptp: blackfin: convert to the 64 bit get/set time methods.Richard Cochran
The device uses 64 bit nanoseconds register, and so with this patch the driver is ready for the year 2038. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31ptp: use the 64 bit get/set time methods for the posix clock.Richard Cochran
This patch changes the posix clock code to prefer the new methods whenever they are implemented by the PHC drivers. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31ptp: use the 64 bit gettime method for the SYS_OFFSET ioctl.Richard Cochran
This patch changes the code to use the new method whenever implemented by the PHC driver. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31ptp: introduce get/set time methods with explicit 64 bit seconds.Richard Cochran
Converting the PHC drivers over to the new methods is one step along the way to making them ready for 2038. Once all the drivers are up to date, then the old methods will be removed. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-29tipc: fix two bugs in secondary destination lookupJon Paul Maloy
A message sent to a node after a successful name table lookup may still find that the destination socket has disappeared, because distribution of name table updates is non-atomic. If so, the message will be rejected back to the sender with error code TIPC_ERR_NO_PORT. If the source socket of the message has disappeared in the meantime, the message should be dropped. However, in the currrent code, the message will instead be subject to an unwanted tertiary lookup, because the function tipc_msg_lookup_dest() doesn't check if there is an error code present in the message before performing the lookup. In the worst case, the message may now find the old destination again, and be redirected once more, instead of being dropped directly as it should be. A second bug in this function is that the "prev_node" field in the message is not updated after successful lookup, something that may have unpredictable consequences. The problems arising from those bugs occur very infrequently. The third change in this function; the test on msg_reroute_msg_cnt() is purely cosmetic, reflecting that the returned value never can be negative. This commit corrects the two bugs described above. Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-29Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/jkirsher/next-queue Jeff Kirsher says: ==================== Intel Wired LAN Driver Updates 2015-03-27 This series contains updates to i40e and i40evf. Jesse adds new device IDs to handle the new 20G speed for KR2. Mitch provides a fix for an issue that shows up as a panic or memory corruption when the device is brought down while under heavy stress. This is resolved by delaying the releasing of resources until we receive acknowledgment from the PF driver that the rings have indeed been stopped. Also adds firmware version information to ethtool reporting to align with ixgbevf behavior. Akeem increases the polling loop limiter, sine we found that in certain circumstances the firmware can take longer to be ready after a reset. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-29Merge branch 'stacked_vlan_tso'David S. Miller
Toshiaki Makita says: ==================== Stacked vlan TSO On the basis of Netdev 0.1 discussion[1], I made a patch set to enable TSO for packets with multiple vlans. Currently, packets with multiple vlans are always segmented by software, which is caused by that netif_skb_features() drops most feature flags for multiple tagged packets. To allow NICs to segment them, we need to get rid of that check from core. Fortunately, recently introduced ndo_features_check() can be used to move the check to each driver, and this patch set is based on the idea. For the initial patch set, I chose 3 drivers, bonding, team, and igb, as candidates to enable TSO. I tested them and confirmed they works fine with this change. Here are samples of performance test results. As I expected, %sys gets pretty lower than before. * TEST1: vlan (.1Q) on vlan (.1ad) on igb (I350) - before $ netperf -t TCP_STREAM -H 192.168.10.1 -l 60 Recv Send Send Socket Socket Message Elapsed Size Size Size Time Throughput bytes bytes bytes secs. 10^6bits/sec 87380 16384 16384 60.02 933.72 Average: CPU %user %nice %system %iowait %steal %idle Average: all 0.13 0.00 11.28 0.01 0.00 88.58 - after $ netperf -t TCP_STREAM -H 192.168.10.1 -l 60 Recv Send Send Socket Socket Message Elapsed Size Size Size Time Throughput bytes bytes bytes secs. 10^6bits/sec 87380 16384 16384 60.01 936.13 Average: CPU %user %nice %system %iowait %steal %idle Average: all 0.24 0.00 4.17 0.01 0.00 95.58 * TEST2: vlan (.1Q) on bridge (.1ad vlan filtering) on team on igb (I350) - before $ netperf -t TCP_STREAM -H 192.168.10.1 -l 60 Recv Send Send Socket Socket Message Elapsed Size Size Size Time Throughput bytes bytes bytes secs. 10^6bits/sec 87380 16384 16384 60.01 936.28 Average: CPU %user %nice %system %iowait %steal %idle Average: all 0.41 0.00 11.57 0.01 0.00 88.01 - after $ netperf -t TCP_STREAM -H 192.168.10.1 -l 60 Recv Send Send Socket Socket Message Elapsed Size Size Size Time Throughput bytes bytes bytes secs. 10^6bits/sec 87380 16384 16384 60.02 935.72 Average: CPU %user %nice %system %iowait %steal %idle Average: all 0.14 0.00 7.66 0.01 0.00 92.19 In addition to above, I tested these configurations: - vlan (.1Q) on vlan (1.ad) on bonding on igb (I350) - vlan (.1Q) on vlan (1.Q) on igb (I350) - vlan (.1Q) on vlan (1.Q) on team on igb (I350) And didn't find any problem. [1] https://netdev01.org/sessions/18 https://netdev01.org/docs/netdev01_bof_8021ad_makita_150212.pdf ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-29igb: Enable TSO for stacked vlanToshiaki Makita
As datasheets for igb (I210, I350, 82576, etc.) say, maclen can be from 14 to 127, which is enough for reasonable number of vlan tags. My netperf test showed I350's TSO works pretty fine with multiple vlans. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-29team: Don't segment multiple tagged packets on team deviceToshiaki Makita
Team devices don't need to segment multiple tagged packets since their slaves can segment them. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-29bonding: Don't segment multiple tagged packets on bonding deviceToshiaki Makita
Bonding devices don't need to segment multiple tagged packets since their slaves can segment them. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-29net: Introduce passthru_features_checkToshiaki Makita
As there are a number of (especially virtual) devices that don't need the multiple vlan check, introduce passthru_features_check() for convenience. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-29net: Move check for multiple vlans to driversToshiaki Makita
To allow drivers to handle the features check for multiple tags, move the check to ndo_features_check(). As no drivers currently handle multiple tagged TSO, introduce dflt_features_check() and call it if the driver does not have ndo_features_check(). Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-29vlan: Introduce helper functions to check if skb is taggedToshiaki Makita
Separate the two checks for single vlan and multiple vlans in netif_skb_features(). This allows us to move the check for multiple vlans to another function later. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-29vlan: Add features for stacked vlan deviceToshiaki Makita
Stacked vlan devices curretly have few features (GRO, HIGHDMA, LLTX). Since we have software fallbacks in case the NIC can not handle some features for multiple vlans, we can add the same features as the lower vlan devices for stacked vlan devices. This allows stacked vlan devices to create large (GSO) packets and not to segment packets. Those packets will be segmented by software on the real device, or even can be segmented by the NIC once TSO for multiple vlans becomes enabled by the following patches. The exception is those related to FCoE, which does not have a software fallback. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-29tc: bpf: generalize pedit actionAlexei Starovoitov
existing TC action 'pedit' can munge any bits of the packet. Generalize it for use in bpf programs attached as cls_bpf and act_bpf via bpf_skb_store_bytes() helper function. Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Reviewed-by: Jiri Pirko <jiri@resnulli.us> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-29Merge branch 'dsa-hw-bridging'David S. Miller
Guenter Roeck says: ==================== net: dsa: HW bridging, EEE support Patch 1 to 7 of this series prepare the drivers using the mv88e6xxx code for HW bridging support, without adding the code itself. For the most part this factors out common port initialization code. There is no functional change except for patch 3, which disables the message port bit for the CPU port to prevent packet duplication if HW bridging is configured. Patch 8 adds the infrastructure for hardware bridging support to the mv88e6xxx code. Patch 9 wires the MV88E6352 driver to support hardware bridging. Patches 10 to 12 add support for ndo_fdb functions to the dsa subsystem, and wire up the MV88E6352 driver to support those functions. Patches 13 to 16 add EEE support and HW bridging support to the mv88e6171 driver. This set of patches is from Andrew, applied on top of the first set of patches. The series applies to net-next as of 3/24/2015. Thanks a lot to Andrew Lunn for testing and valuable feedback. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-29net: dsa: mv88e6171: Add support for hardware bridgingAndrew Lunn
Wire up the common code for setting up hardware bridging and access to the forwarding database. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-29net: dsa: mv88e6171: Add EEE support to the mv88e6172Andrew Lunn
The mv88e6172 has support for EEE. Check for the product ID and call the common code if applicable. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-29net: dsa: mv88e6171: Add defines for switch product IDsAndrew Lunn
Make the code more readable by using defines for the switch IDs. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-29net: dsa: Centralise getting switch idAndrew Lunn
Get the switch id and save it away in the private mv88x6xxx structure in a centralised piece of code, rather than each driver doing it itself. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: David S. Miller <davem@davemloft.net>
