2015-03-24drm/omap: handle incompatible buffer stride and pixel sizeTomi Valkeinen
omapdrm doesn't check if the pitch of the framebuffer and the color format's bits-per-pixel are compatible. omapdss requires that the stride of a buffer is an integer number of pixels For example, when using modetest with a display that has x resolution of 1280, and using packed 24 RGB mode (3 bytes per pixel), modetest allocates a buffer with a byte stride of 4 * 1280 = 5120. But 5120 / 3 = 1706.666... pixels, which causes wrong colors and a tilt on the screen. Add a check into omapdrm to return an error if the user tries to use such a combination. Note: this is not a HW requirement at least for non-rotation use cases, but a SW driver requirement. In the future we should study if also rotation use cases are fine with any stride size, and if so, change the driver to allow these strides. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-03-24drm/omap: fix error handling in omap_framebuffer_create()Tomi Valkeinen
When an error happens in omap_framebuffer_create(), omap_framebuffer_create() calls omap_framebuffer_destroy() if the fb struct has been allocated. However, that crashes, as omap_framebuffer_destroy(), which calls drm_framebuffer_cleanup(), should only be called after drm_framebuffer_init() Fix this by just calling kfree() for the allocated fb when an error happens. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-03-24drm/omap: fix operation without fbdevTomi Valkeinen
omapdrm should work fine even if fbdev is missing. The current driver crashes in that case, though, as it is missing checks for the fbdev. Add the checks so that we don't free fbdev or restore fbdev mode when there's no fbdev. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-03-24drm/omap: add a comment why locking is missingTomi Valkeinen
unpin_worker() calls omap_framebuffer_unpin() without any locks, which looks very suspicious. However, both pin and unpin are always called via the driver's private workqueue, so the access is synchronized that way. Add a comment to make this clear. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-03-24drm/omap: add pin refcounting to omap_framebufferTomi Valkeinen
omap_framebuffer_pin() and omap_framebuffer_unpin() are currently broken, as they cannot be called multiple times (i.e. pin, pin, unpin, unpin), which is what happens in certain cases. This issue causes the driver to possibly use 0 as an address for a displayed buffer, leading to OCP error from DSS. This patch fixes the issue by adding a simple pin_count, used to track the number of pins. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-03-24drm/omap: clear omap_obj->paddr in omap_gem_put_paddr()Tomi Valkeinen
Clear omap_obj's paddr when unmapping the memory, so that it's easier to catch bad use of the paddr. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-03-24drm/omap: page_flip: return -EBUSY if flip pendingTomi Valkeinen
The DRM documentation says: "If a page flip is already pending, the page_flip operation must return -EBUSY." Currently omapdrm returns -EINVAL instead. Fix omapdrm by returning -EBUSY. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-03-24drm/omap: fix encoder-crtc mappingTomi Valkeinen
OMAP DSS hardware supports changing the output port to which an overlay manager's video stream goes. For example, DPI video stream can come from any of the four overlay managers on OMAP5. However, as it's difficult to manage the change in the driver, the omapdss driver does not support that at the moment, and has a hardcoded overlay manager per output. omapdrm, on the other hand, uses the hardware features to find out which overlay manager to use for an output, which causes problems. For example, on OMAP5, omapdrm tries to use DIGIT overlay manager for DPI output, instead of the LCD3 required by the omapdss driver. This patch changes the omapdrm to use the omapdss driver's hardcoded overlay managers, which fixes the issue. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-03-20drm: omapdrm: Reorder CRTC functionsLaurent Pinchart
The next commit will need functions to be reordered. Do it separately to help review. This only moves functions without any change to the code. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
2015-03-20drm: omapdrm: Planes are already disabled when destroyedLaurent Pinchart
Planes are destroyed after framebuffers, which has the side effect of disabling all planes. There is thus no need to disable planes explicitly when destroying them. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
2015-03-20drm: omapdrm: Pass integer source coordinates to omap_plane_mode_set()Laurent Pinchart
The function will convert the Q16 source coordinates to integers, avoid converting integers to Q16 first and perform the opposite conversion. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
2015-03-20drm: omapdrm: Prefix all plane functions with omap_plane_Laurent Pinchart
This matches the rest of the file and clarifies the functions' purpose. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
2015-03-20drm: omapdrm: Avoid function forward declaration in omap_crtc.cLaurent Pinchart
Move the set_enabled function to avoid the forward declaration. While at it prefix it with omap_crtc_ like most other functions in the file, and fix the comment stating in which contexts the function is called. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
2015-03-20drm: omapdrm: Remove omap_crtc->full_update fieldLaurent Pinchart
The full_update field is always set to true before calling omap_crtc_appy(), resulting in its value always being true in the single location where it is tested, in omap_crtc_pre_apply(). Remove it. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
2015-03-20drm: omapdrm: Remove manual update display supportLaurent Pinchart
All the manual update display code implements eventually ends up to just calls to omap_connector_flush(), currently implemented as an empty TODO stub. Remove it, the code can always be revived and implemented later if interest in manual update displays becomes a reality. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
2015-03-20drm: omapdrm: Fix race condition between GO and vblank IRQLaurent Pinchart
The vblank interrupt is used by the driver as a completion signal when applying new settings. A race condition exist between enabling the vblank interrupt and applying new settings to the hardware by setting the GO bit. If a vblank interrupt occurs in-between, the driver will incorrectly consider the new settings to be applied. Fix this by enabling the interrupt after setting the GO bit. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
2015-03-20drm: omapdrm: Reset the zorder property when disabling a planeLaurent Pinchart
Whether to reset plane properties at disable time isn't well-defined in DRM, but resetting only part of them is probably as bad as it can get. Make the behaviour coherent by resetting the zorder property in addition to the rotation property. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
2015-03-20drm: omapdrm: Rename omap_plane_dpms() to omap_plane_set_enable()Laurent Pinchart
The planes don't care about DPMS states, don't propagate it unnecessarily to the plane functions. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
2015-03-20drm: omapdrm: Switch to the universal plane APILaurent Pinchart
Remove the CRTC private planes by switching to the universal plane API. This results in a merge of the CRTC private plane created by the driver (omap_crtc->plane) and the CRTC primary plane created by the DRM core (crtc->primary). Reference counting of the framebuffers in the update plane operation is thus simplified as no reference needs to be stored in the private plane anymore. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
2015-03-20drm: omapdrm: Remove unused variablesLaurent Pinchart
The ilace variable is unused and the replication variable is assigned to false and just passed to a function. Remove them. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
2015-03-20drm: omapdrm: Refactor CRTC creation codeLaurent Pinchart
Create a omap_modeset_create_crtc() function to avoid duplicating plane and CRTC creation code. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
2015-03-20drm: omapdrm: Fix indentation of structure and array initializersLaurent Pinchart
Indenting by one tab is enough. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
2015-03-19Merge branch 'drm_next' of https://github.com/markyzq/kernel-drm-rockchip ↵Dave Airlie
into drm-next rockchip fixes. * 'drm_next' of https://github.com/markyzq/kernel-drm-rockchip: drm/rockchip: vop: power off until vop standby take effect drm/rockchip: vop: set vop enabled after enable iommu drm/rockchip: vop use is_enabled instead of dpms mode drm/rockchip: vop: fix vop vsync/hsync polarity drm/rockchip: Only alloc a kmap for fbdev gem object
2015-03-19Merge tag 'topic/drm-misc-2015-03-18' of ↵Dave Airlie
git://anongit.freedesktop.org/drm-intel into drm-next Another drm-misch pull request. Mostly the fbdev sizes deconfusion series from Rob, everything else is small stuff all over. And the large i2c over aux transfers patch, too. * tag 'topic/drm-misc-2015-03-18' of git://anongit.freedesktop.org/drm-intel: drm: check that planes types are correct while initializing CRTC drm: change connector to tmp_connector drm: Fix some typo mistake of the annotations drm: Silence sparse warnings drm: %pF is only for function pointers drm/fb: handle tiled connectors better drm/fb: small cleanup drm/rockchip: use correct fb width/height drm/exynos: use correct fb width/height drm/cma: use correct fb width/height drm/atomic: minor kerneldoc typo fix drm/fb: document drm_fb_helper_surface_size drm/dp: Use large transactions for I2C over AUX drm/plane-helper: Fixup mismerge drm/atomic: Constify a bunch of functions pointer structs
2015-03-17drm: check that planes types are correct while initializing CRTCBenjamin Gaignard
Be warned if primary or cursor planes haven't the correct type Signed-off-by: Benjamin Gaignard <benjamin.gaignard@linaro.org> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2015-03-17drm: change connector to tmp_connectorJohn Hunter
This wasn't too harmful since we already look at connector, which has the same effect as the loop for any non-cloned configs. Only when we have a cloned configuration is it important to look at other connectors. Furthermore existing userspace always changes dpms on all of them anyway. Signed-off-by: JohnHunter <zhjwpku@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2015-03-17drm: Fix some typo mistake of the annotationsJohn Hunter
There are some mistakes that the function name in the annotaions is not matching the real function name. And some duplication word in annotations Signed-off-by: John Hunter <zhjwpku@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2015-03-16drm/rockchip: vop: power off until vop standby take effectMark Yao
Vop standby will take effect at end of current frame, if dsp_hold_valid_irq happen, it means vop standby complete. we must wait standby complete when we want to disable aclk, if not, memory bus maybe dead. Reviewed-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Daniel Kurtz <djkurtz@chromium.org> Signed-off-by: Mark Yao <mark.yao@rock-chips.com>
2015-03-16drm/rockchip: vop: set vop enabled after enable iommuMark Yao
there is a Bug that: vop_enable()->drm_vblank_on, drm_vblank_on may call vop enable vblank. if it happen, vblank enable would failed, then cause irq status error. because is_enabled value is set after drm_vblank_on. after enable vop clocks and iommu regs, we can sure that R/W vop regs and do vop plane flip is safe, so place is_enabled = true after enable iommu is suitable. Signed-off-by: Mark Yao <mark.yao@rock-chips.com>
2015-03-16drm/rockchip: vop use is_enabled instead of dpms modeMark Yao
drm dpms have many power modes: ON,OFF,SUSPEND,STANDBY, etc. but vop only have enable/disable mode, maybe case such bug: --> DRM_DPMS_ON: power on vop --> DRM_DPMS_SUSPEND: power off vop --> DRM_DPMS_OFF: already power off at SUSPEND, crash so use a bool val is more suitable. Signed-off-by: Mark Yao <mark.yao@rock-chips.com>
2015-03-16drm/rockchip: vop: fix vop vsync/hsync polarityMark Yao
Vop set wrong vsync/hsync polarity, it may cause some display problem. known problem is that caused HDMI hdcp authenticate failed, caused pixel offset with hdmi display. the polarity description at RK3288 TRM doc: dsp_vsync_pol VSYNC polarity 1'b0 : negative 1'b1 : positive dsp_hsync_pol HSYNC polarity 1'b0 : negative 1'b1 : positive Signed-off-by: Mark Yao <mark.yao@rock-chips.com> Reviewed-by: Daniel Kurtz <djkurtz@chromium.org> Tested-by: Caesar Wang <wxt@rock-chips.com> Tested-by: Heiko Stuebner <heiko@sntech.de>
2015-03-16drm/rockchip: Only alloc a kmap for fbdev gem objectDaniel Kurtz
In general, the data in drm/rockchip GEM objects is never accessed by the kernel. The objects are either accessed by a GPU, by display controller DMA, or by mmap'ing them to user space. Thus, these buffers need not be mapped into kernel address space. The only exception is the fbdev framebuffer(s), which may be written in-kernel by fbcon. Signed-off-by: Daniel Kurtz <djkurtz@chromium.org> Signed-off-by: Mark Yao <mark.yao@rock-chips.com>
2015-03-13drm: Silence sparse warningsVille Syrjälä
../drivers/gpu/drm/drm_vm.c:405:6: warning: symbol 'drm_vm_open_locked' was not declared. Should it be static? ../drivers/gpu/drm/drm_vm.c:431:6: warning: symbol 'drm_vm_close_locked' was not declared. Should it be static? ../drivers/gpu/drm/drm_vm.c:681:5: warning: symbol 'drm_vma_info' was not declared. Should it be static? ../drivers/gpu/drm/drm_pci.c:146:5: warning: symbol 'drm_pci_set_unique' was not declared. Should it be static? ../drivers/gpu/drm/drm_pci.c:216:5: warning: symbol 'drm_irq_by_busid' was not declared. Should it be static? ../drivers/gpu/drm/drm_info.c:47:5: warning: symbol 'drm_name_info' was not declared. Should it be static? ../drivers/gpu/drm/drm_info.c:72:5: warning: symbol 'drm_vm_info' was not declared. Should it be static? ../drivers/gpu/drm/drm_info.c:116:5: warning: symbol 'drm_bufs_info' was not declared. Should it be static? ../drivers/gpu/drm/drm_info.c:159:5: warning: symbol 'drm_clients_info' was not declared. Should it be static? ../drivers/gpu/drm/drm_info.c:209:5: warning: symbol 'drm_gem_name_info' was not declared. Should it be static? ../drivers/gpu/drm/drm_ioc32.c:1019:20: warning: symbol 'drm_compat_ioctls' was not declared. Should it be static? ../drivers/gpu/drm/drm_bridge.c:52:12: warning: function 'drm_bridge_attach' with external linkage has definition Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2015-03-13drm: %pF is only for function pointersScott Wood
Use %pS for actual addresses, otherwise you'll get bad output on arches like ppc64 where %pF expects a function descriptor. Signed-off-by: Scott Wood <scottwood@freescale.com> Cc: dri-devel@lists.freedesktop.org Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2015-03-11drm/fb: handle tiled connectors betterRob Clark
We don't want tile 0,0 to artificially constrain the size of the legacy fbdev device. Instead when reducing fb_size to be the minimum of all displays, only consider the rightmost and bottommost tiles. Signed-off-by: Rob Clark <robdclark@gmail.com> Tested-by: Hai Li <hali@codeaurora.org> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2015-03-11drm/fb: small cleanupRob Clark
Flip conditional to reduce indentation level of rest of fxn, and use min/max to make the code clearer. v2: surface_width -> surface_height typo Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Daniel Kurtz <djkurtz@chromium.org> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2015-03-11drm/rockchip: use correct fb width/heightRob Clark
What is passed to drm_fb_helper_fill_var() should be fb_width/fb_height, rather than the surface size. Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2015-03-11drm/exynos: use correct fb width/heightRob Clark
2015-03-11drm/cma: use correct fb width/heightRob Clark
2015-03-11drm/atomic: minor kerneldoc typo fixRob Clark
2015-03-11drm/fb: document drm_fb_helper_surface_sizeRob Clark
There has been some confusion about this struct. Lack of documentation probably didn't help. Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2015-03-11drm/dp: Use large transactions for I2C over AUXSimon Farnsworth
Older DisplayPort to DVI-D Dual Link adapters designed by Bizlink have bugs in their I2C over AUX implementation (fixed in newer revisions). They work fine with Windows, but fail with Linux. It turns out that they cannot keep an I2C transaction open unless the previous read was 16 bytes; shorter reads can only be followed by a zero byte transfer ending the I2C transaction. Copy Windows's behaviour, and read 16 bytes at a time. If we get a short reply, assume that there's a hardware bottleneck, and shrink our read size to match. For this purpose, use the algorithm in the DisplayPort 1.2 spec, in the hopes that it'll be closest to what Windows does. Also provide an unsafe module parameter for testing smaller transfer sizes, in case there are sinks out there that cannot work with Windows. Note also that despite the previous comment in drm_dp_i2c_xfer, this speeds up native DP EDID reads; Ville Syrjälä <ville.syrjala@linux.intel.com> found the following changes in his testing: Device under test: old -> with this patch DP->DVI (OUI 001cf8): 40ms -> 35ms DP->VGA (OUI 0022b9): 45ms -> 38ms Zotac DP->2xHDMI: 25ms -> 4ms Asus PB278 monitor: 22ms -> 3ms A back of the envelope calculation shows that peak theoretical transfer rate for 1 byte reads is around 60 kbit/s; with 16 byte reads, this increases to around 500 kbit/s, which explains the increase in speed. Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=55228 Tested-by: Aidan Marks <aidanamarks@gmail.com> (v3) Signed-off-by: Simon Farnsworth <simon.farnsworth@onelan.co.uk> Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2015-03-11drm/plane-helper: Fixup mismergeDaniel Vetter
I somehow manage to screw up applying Laurent's patch in eca93e28c256: "drm: Check in setcrtc if the primary plane supports the fb pixel format". It was a conflict with commit 3461b30b3e171e16498f3d7bc59ab703aec475c8 Author: Daniel Vetter <daniel.vetter@ffwll.ch> Date: Thu Mar 5 10:32:44 2015 +0100 drm/plane-helper: unexport drm_primary_helper_create_plane and I just didn't check that the solution from wiggle made sense. Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: laurent.pinchart@ideasonboard.com Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: laurent.pinchart@ideasonboard.com Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
2015-03-11drm/atomic: Constify a bunch of functions pointer structsVille Syrjälä
Make the helper function pointer structs const to make it clear they should not be modified. Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2015-03-11Merge tag 'topic/drm-misc-2015-03-10' of ↵Dave Airlie
git://anongit.freedesktop.org/drm-intel into drm-next Another pile of misc drm patches all over, mostly polish for atomic. Last minute rebase was to avoid the broken merge. * tag 'topic/drm-misc-2015-03-10' of git://anongit.freedesktop.org/drm-intel: drm: Check in setcrtc if the primary plane supports the fb pixel format drm: Lighten sysfs connector 'status' drm/plane-helper: unexport drm_primary_helper_create_plane drm: Share plane pixel format check code between legacy and atomic drm: Fix trivial typos in comments drm/dp: add DPCD definitions from eDP 1.4 drm/dp: add DPCD definitions from DP 1.1 and 1.2a drm: Fixup racy refcounting in plane_force_disable drm/i915: Rotation property is now handled in DRM core drm: Complete moving rotation property to core drm/dp: add DPCD definitions from eDP 1.2 drm/dp: indentation and ordering cleanups drm/atomic-helper: Fix kerneldoc for prepare_planes drm: Remove redundant code in the getencoder ioctl
2015-03-10drm: Check in setcrtc if the primary plane supports the fb pixel formatLaurent Pinchart
Drivers implementing the universal planes API report the list of supported pixel formats for the primary plane. Make sure the fb passed to the setcrtc ioctl is compatible. Drivers not implementing the universal planes API will have no format reported for the primary plane, skip the check in that case. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2015-03-10drm: Lighten sysfs connector 'status'Chris Wilson
Since the beginning, sysfs/connector/status has done a heavyweight detection of the current connector status. But no user, such as upowerd or logind, has ever desired to initiate a probe. Move the probing into a new attribute so that existing readers get the behaviour they desire. v2: David Herrmann suggested using "echo detect > /sys/.../status" to trigger the probing, which is a fine idea. This extends that to also allow the user to apply the force detection overrides at runtime. v3: Now with airlied's email address fixed! Requires sysfs_streq() Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: David Herrmann <dh.herrmann@gmail.com> Cc: Dave Airlie <airlied@redhat.com> Cc: Alex Deucher <alexdeucher@gmail.com> Reviewed-by: David Herrmann <dh.herrmann@gmail.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2015-03-10drm/plane-helper: unexport drm_primary_helper_create_planeDaniel Vetter
We shouldn't tempt driver writers into using this since it uses a default format list which is likely wrong. And when that's done we can simplify the code a bit, too. Noticed while reviewing a patch from Laurent. Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Cc: Matt Roper <matthew.d.roper@intel.com> Reviewed-by: Matt Roper <matthew.d.roper@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
2015-03-10drm: Share plane pixel format check code between legacy and atomicLaurent Pinchart
Both the legacy and atomic helpers need to check whether a plane supports a given pixel format. The code is currently duplicated, share it. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> [danvet: Slightly extend the docbook.] Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2015-03-10drm: Fix trivial typos in commentsYannick Guerrini
Change 'pixes' to 'pixels' Change 'enabel' to 'enable' Change 'enabeling' to 'enabling' Signed-off-by: Yannick Guerrini <yguerrini@tomshardware.fr> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
