Because of the global nature of garbage collection, and because of the
cost of per namespace hash tables unix_socket_table has been kept
global. With a filter added on lookups so we don't see sockets from
the wrong namespace.
Currently I don't fold the namesapce into the hash so multiple
namespaces using the same socket name will be guaranteed a hash
collision.
Changes from v1:
- fixed unix_seq_open
Signed-off-by: Denis V. Lunev <den@openvz.org>
This is done by making packet_sklist_lock and packet_sklist per
network namespace and adding an additional filter condition on
received packets to ensure they came from the proper network
namespace.
Changes from v1:
- prohibit to call inet_dgram_ops.ioctl in other than init_net
After the previous prep work this just consists of removing checks
limiting the code to work in the initial network namespace, and
updating rtmsg_ifinfo so we can generate events for devices in
something other then the initial network namespace.
Referring to network other network devices like the IFLA_LINK
and IFLA_MASTER attributes do, gets interesting if those network
devices happen to be in other network namespaces. Currently
ifindex numbers are allocated globally so I have taken the path
of least resistance and not still report the information even
though the devices they are talking about are invisible.
If applications start getting confused or when ifindex
numbers become local to the network namespace we may need
to do something different in the future.
Signed-off-by: Denis V. Lunev <den@openz.org>
After this patch none of the netlink callback support anything
except the initial network namespace but the rtnetlink infrastructure
now handles multiple network namespaces.
Changes from v2:
- IPv6 addrlabel processing
Changes from v1:
- no need for special rtnl_unlock handling
- fixed IPv6 ndisc
Before I can enable rtnetlink to work in all network namespaces I need
to be certain that something won't break. So this patch deliberately
disables all of the rtnletlink methods in everything except the
initial network namespace. After the methods have been audited this
extra check can be disabled.
Changes from v1:
- added IPv6 addrlabel protection
Only devices that are UP are in the hash, so macvlan_broadcast() doesn't
need to check for IFF_UP.
Based upon a suggestion by Francois Romieu.
With this patch the synced connections are created with their real state,
which can be changed on the next synchronizations if necessary. This way
on fail-over all the connections will be treated according to their actual
state, causing no scheduling problems (the active and the nonactive
connections have different weights in the schedulers).
The backwards compatibility is preserved and the existing tools will show
the true connection states even on the backup director.
Signed-off-by: Rumen G. Bogdanovski <rumen@voicecho.com>
Signed-off-by: Simon Horman <horms@verge.net.au>
This patch labels the sync-created connections with IP_VS_CONN_F_SYNC
flag and creates /proc/net/ip_vs_conn_sync to enable monitoring of the
origin of the connections, if they are local or created by the
synchronization.
This patch adds IEEE80211_MAX_FRAME_LEN which is useful for drivers trying
to determine how much to allocate for their RX buffers.
It also updates the comment on IEEE80211_MAX_DATA_LEN based on revisions
in 802.11e.
IEEE80211_MAX_FRAG_THRESHOLD and IEEE80211_MAX_RTS_THRESHOLD are also
revised due to the new maximum frame size.
Signed-off-by: Michael Wu <flamingice@sourmilk.net>
This changes the SIWTXPOWER ioctl to also accept a txpower setting of
"automatic". Since mac80211 currently cannot tell drivers to automatically
adjust tx power, we select the tx power level of the current channel. While
this is kind of a hack, it certainly saves some iwconfig users from headaches.
Signed-off-by: Mattias Nissler <mattias.nissler@gmx.de>
The rx_flags variable is redundant. Turning rx on/off is done
via setting the rx_np pointer.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
The local_mac is managed by the network device, no need to keep a
spare copy and all the management problems that could cause.
Restructure code slightly to improve readability:
* dereference device once
* change obvious while() loop
* let poll_napi() handle null list itself
Use standard routine for flushing queue.
Previously one of the in-block skip branches was missing it.
Also, drop it from tail-fully-processed case because the next
iteration will do exactly the same thing, i.e., process the
SACK block that contains the DSACK information.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
This patch adds documentation for the PF_CAN protocol family.
Signed-off-by: Oliver Hartkopp <oliver.hartkopp@volkswagen.de>
Signed-off-by: Urs Thuermann <urs.thuermann@volkswagen.de>
This patch adds entries in the CREDITS and MAINTAINERS file for CAN.
This patch adds the missing Kbuild entries and the missing Kbuild file
in include/linux/can for the CAN subsystem.
Signed-off-by: Oliver Hartkopp <oliver@hartkopp.net>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
This patch fixes the use of plain integers instead of __u32 in a struct
that is visible from kernel space and user space.
Thanks to Sam Ravnborg for pointing out the wrong plain int usage.
This patch adds the virtual CAN bus (vcan) network driver.
The vcan device is just a loopback device for CAN frames, no
real CAN hardware is involved.
This patch adds the CAN broadcast manager (bcm) protocol.
This patch adds the CAN raw protocol.
This patch adds the CAN core functionality but no protocols or drivers.
No protocol implementations are included here. They come as separate
patches. Protocol numbers are already in include/linux/can.h.
This patch adds a protocol/address family number, ARP hardware type,
ethernet packet type, and a line discipline number for the SocketCAN
implementation.
ip_rt_acct needs 4096 bytes per cpu to perform some accounting.
It is actually allocated as a single huge array [4096*NR_CPUS]
(rounded up to a power of two)
Converting it to a per cpu variable is wanted to :
- Save space on machines were num_possible_cpus() < NR_CPUS
- Better NUMA placement (each cpu gets memory on its node)
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Key points of this patch are:
- In case new SACK information is advance only type, no skb
processing below previously discovered highest point is done
- Optimize cases below highest point too since there's no need
to always go up to highest point (which is very likely still
present in that SACK), this is not entirely true though
because I'm dropping the fastpath_skb_hint which could
previously optimize those cases even better. Whether that's
significant, I'm not too sure.
Currently it will provide skipping by walking. Combined with
RB-tree, all skipping would become fast too regardless of window
size (can be done incrementally later).
Previously a number of cases in TCP SACK processing fails to
take advantage of costly stored information in sack_recv_cache,
most importantly, expected events such as cumulative ACK and new
hole ACKs. Processing on such ACKs result in rather long walks
building up latencies (which easily gets nasty when window is
huge). Those latencies are often completely unnecessary
compared with the amount of _new_ information received, usually
for cumulative ACK there's no new information at all, yet TCP
walks whole queue unnecessary potentially taking a number of
costly cache misses on the way, etc.!
Since the inclusion of highest_sack, there's a lot information
that is very likely redundant (SACK fastpath hint stuff,
fackets_out, highest_sack), though there's no ultimate guarantee
that they'll remain the same whole the time (in all unearthly
scenarios). Take advantage of this knowledge here and drop
fastpath hint and use direct access to highest SACKed skb as
a replacement.
Effectively "special cased" fastpath is dropped. This change
adds some complexity to introduce better coveraged "fastpath",
though the added complexity should make TCP behave more cache
friendly.
The current ACK's SACK blocks are compared against each cached
block individially and only ranges that are new are then scanned
by the high constant walk. For other parts of write queue, even
when in previously known part of the SACK blocks, a faster skip
function is used (if necessary at all). In addition, whenever
possible, TCP fast-forwards to highest_sack skb that was made
available by an earlier patch. In typical case, no other things
but this fast-forward and mandatory markings after that occur
making the access pattern quite similar to the former fastpath
"special case".
DSACKs are special case that must always be walked.
The local to recv_sack_cache copying could be more intelligent
w.r.t DSACKs which are likely to be there only once but that
is left to a separate patch.
Worker function that implements the main logic of
the inner-most loop of tcp_sacktag_write_queue().
Idea was originally presented by David S. Miller.
Highest_sack_end_seq is no longer calculated in the loop,
thus it can be pushed to the worker function altogether
making that function independent of the sacktag.
It is going to replace the sack fastpath hint quite soon... :-)
Many assumptions that are true when no reordering or other
strange events happen are not a part of the RFC3517. FACK
implementation is based on such assumptions. Previously (before
the rewrite) the non-FACK SACK was basically doing fast rexmit
and then it times out all skbs when first cumulative ACK arrives,
which cannot really be called SACK based recovery :-).
RFC3517 SACK disables these things:
- Per SKB timeouts & head timeout entry to recovery
- Marking at least one skb while in recovery (RFC3517 does this
only for the fast retransmission but not for the other skbs
when cumulative ACKs arrive in the recovery)
- Sacktag's loss detection flavors B and C (see comment before
tcp_sacktag_write_queue)
This does not implement the "last resort" rule 3 of NextSeg, which
allows retransmissions also when not enough SACK blocks have yet
arrived above a segment for IsLost to return true [RFC3517].
The implementation differs from RFC3517 in these points:
- Rate-halving is used instead of FlightSize / 2
- Instead of using dupACKs to trigger the recovery, the number
of SACK blocks is used as FACK does with SACK blocks+holes
(which provides more accurate number). It seems that the
difference can affect negatively only if the receiver does not
generate SACK blocks at all even though it claimed to be
SACK-capable.
- Dupthresh is not a constant one. Dynamical adjustments include
both holes and sacked segments (equal to what FACK has) due to
complexity involved in determining the number sacked blocks
between highest_sack and the reordered segment. Thus it's will
be an over-estimate.
Implementation note:
tcp_clean_rtx_queue doesn't need a lost_cnt tweak because head
skb at that point cannot be SACKED_ACKED (nor would such
situation last for long enough to cause problems).
This implements more accurately what is stated in sacktag's
overall comment:
"Both of these heuristics are not used in Loss state, when
we cannot account for retransmits accurately."
When CA_Loss state is entered, the state changer ensures that
undo_marker is only set if no TCPCB_RETRANS skbs were found,
thus having non-zero undo_marker in CA_Loss basically tells
that the R-bits still accurately reflect the current state
of TCP.
All intermediate conditions include it already, make them
simpler as well.
The sock_valbool_flag() helper is used in setsockopt to
set or reset some flag on the sock. This helper is required
in the net/socket.c only, so move it there.
Besides, patch two places in sys_setsockopt() that repeat
this helper functionality manually.
Since this is not a bugfix, but a trivial cleanup, I
prepared this patch against net-2.6.25, but it also
applies (with a single offset) to the latest net-2.6.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Some time ago a sockfd_lookup_light was introduced and
most of the socket.c file was patched to use it. However
two routines were left - sys_sendto and sys_recvfrom.
Patch them as well, since this helper does exactly what
these two need.
Acked-by: Patrick McHardy <kaber@trash.net>
Qdisc_class_ops are const, and Qdisc_ops are mostly read.
Using "const" and "__read_mostly" qualifiers helps to reduce false
sharing.
Policy table is implemented as an RCU linear list since we do not expect
large list nor frequent updates.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
This patch allows ifindex to be a key for address selection policy table.
This patch renames ipv6_saddr_label() to ipv6_addr_label() because
address label is used for both of source address and destination
address.
After changeset:
[NETFILTER]: Introduce NF_INET_ hook values
It always evaluates to NF_INET_POST_ROUTING.
The IPv4 and IPv6 hook values are identical, yet some code tries to figure
out the "correct" value by looking at the address family. Introduce NF_INET_*
values for both IPv4 and IPv6. The old values are kept in a #ifndef __KERNEL__
section for userspace compatibility.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
This patch adds support for async resumptions on input. To do so, the
transform would return -EINPROGRESS and subsequently invoke the
function xfrm_input_resume to resume processing.
The nhoff field isn't actually necessary in xfrm_input. For tunnel
mode transforms we now throw away the output IP header so it makes no
sense to fill in the nexthdr field. For transport mode we can now let
the function transport_finish do the setting and it knows where the
nexthdr field is.
The only other thing that needs the nexthdr field to be set is the
header extraction code. However, we can simply move the protocol
extraction out of the generic header extraction.
We want to minimise the amount of info we have to carry around between
transforms as this simplifies the resumption process for async crypto.
Currently x->lastused is u64 which means that it cannot be
read/written atomically on all architectures. David Miller observed
that the value stored in it is only an unsigned long which is always
atomic.
So based on his suggestion this patch changes the internal
representation from u64 to unsigned long while the user-interface
still refers to it as u64.
This patch releases the lock on the state before calling
x->type->input. It also adds the lock to the spots where they're
currently needed.
Most of those places (all except mip6) are expected to disappear with
async crypto.
