2015-01-09scsi: use per-cpu buffer for formatting scsi_print_result()Hannes Reinecke
Convert scsi_print_result() to use the per-cpu buffer for decoding the command result and disposition. Tested-by: Robert Elliott <elliott@hp.com> Reviewed-by: Robert Elliott <elliott@hp.com> Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-09scsi: use per-cpu buffer for formatting senseHannes Reinecke
Convert sense buffer logging to use the per-cpu buffer to avoid line breakup. Tested-by: Robert Elliott <elliott@hp.com> Reviewed-by: Robert Elliott <elliott@hp.com> Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-09libata: use __scsi_format_command()Hannes Reinecke
libata already uses an internal buffer, so we should be using __scsi_format_command() here. Tested-by: Robert Elliott <elliott@hp.com> Reviewed-by: Robert Elliott <elliott@hp.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-09scsi: use external buffer for command loggingHannes Reinecke
Use an external buffer for __scsi_print_command() and move command logging over to use the per-cpu logging buffer. With that we can guarantee the command always will always be formatted in one line. So we can even print out a variable length command correctly across several lines. Finally rename __scsi_print_command() to __scsi_format_comment() to better reflect the functionality. Tested-by: Robert Elliott <elliott@hp.com> Reviewed-by: Robert Elliott <elliott@hp.com> Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-09scsi: log request tag for scmd_printk()Hannes Reinecke
The request tag provides a concise identification of a SCSI command, so we should be printing that out for scmd_printk(). Suggested-by: Christoph Hellwig <hch@lst.de> Tested-by: Robert Elliott <elliott@hp.com> Reviewed-by: Robert Elliott <elliott@hp.com> Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-09scsi: Implement per-cpu logging bufferHannes Reinecke
Implement a per-cpu buffer for formatting messages to avoid line breaks up under high load. This patch implements scmd_printk() and sdev_prefix_printk() using the per-cpu buffer and makes sdev_printk() a wrapper for sdev_prefix_printk(). Tested-by: Robert Elliott <elliott@hp.com> Reviewed-by: Robert Elliott <elliott@hp.com> Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-09storvsc: force SPC-3 compliance on win8 and win8 r2 hostsK. Y. Srinivasan
On win8 and win8 r2 hosts force SPC-3 compliance for MSFT virtual disks. Ubuntu has been carrying a similar patch outside the tree for a while now. Starting with win10, the host will support SPC-3 compliance. Based on all the testing that has been done on win8 and win8 r2 hosts, we are comfortable claiming SPC-3 compliance on these hosts as well. This will enable TRIM support on these hosts. Suggested by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Long Li <longli@microsoft.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-09storvsc: fix a bug in storvsc limitsK. Y. Srinivasan
Commit 4cd83ecdac20d30725b4f96e5d7814a1e290bc7e changed the limits to reflect the values on the host. It turns out that WS2008R2 cannot correctly handle these new limits. Fix this bug by setting the limits based on the host. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Long Li <longli@microsoft.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-09storvsc: force discovery of LUNs that may have been removed.K. Y. Srinivasan
The host asks the guest to scan when a LUN is removed or added. The only way a guest can identify the removed LUN is when an I/O is attempted on a removed LUN - the SRB status code indicates that the LUN is invalid. We currently handle this SRB status and remove the device. Rather than waiting for an I/O to remove the device, force the discovery of LUNs that may have been removed prior to discovering LUNs that may have been added. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Long Li <longli@microsoft.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-09storvsc: in responce to a scan event, scan the hostK. Y. Srinivasan
The virtual HBA that storvsc implements can support multiple channels and targets. So, scan the host when the host notifies that a scan is needed. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Long Li <longli@microsoft.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-09storvsc: use cmd_size to allocate per-command dataChristoph Hellwig
STORVSC uses its own momory pool to manage device request data. However, the SCSI layer already has a mechanisim for allocating additional memory for each command issued to device driver. This patch removes the memory pool in STORVSC and makes it use SCSI layer to allocate memory for device request data. Reviewed-by: Long Li <longli@microsoft.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-09lpfc: correct device removal deadlock after link bounceJames Smart
This patch, applicable to 8G/4G/2G adapters, adds a call that resumes transmit operations after a link bounce. Without it, targets that tried to suspend exchanges after a link bounce (such as tape devices using sequence level error recovery) would never resume io operation, causing scan failures, and eventually deadlocks if a device removal request is made. Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: Dick Kennedy <dick.kennedy@emulex.com> Reviewed-by: Ewan D. Milne <emilne@redhat.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-09esp_scsi: remove check for ESP_MAX_TAGSHannes Reinecke
'num_tags' is an unsigned char, so the check for 'ESP_MAX_TAGS' (which is set to 256) is pointless. Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-09mpt3sas: issue_reset is uninitializedDan Carpenter
The "issue_reset" can be used uninitialized. It should be set to false at the start. Also I cleaned up the types a little by using bool. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Sreekanth Reddy <Sreekanth.Reddy@avagotech.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-09mpt2sas: issue_reset is uninitializedDan Carpenter
The "issue_reset" variable can be used uninitialized. It should be set to false at the start. Also I cleaned up the types by using bool. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Sreekanth Reddy <Sreekanth.Reddy@avagotech.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-093w-9xxx.c: Cleaning up missing null-terminate in conjunction with strncpyRickard Strandqvist
Replacing strncpy with strlcpy to avoid strings that lacks null terminate. And use the sizeof on the to string rather than strlen on the from string. Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se> Acked-by: Adam Radford <aradford@gmail.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-09scsi_debug: Implement WRITE BUFFER commandEwan D. Milne
Accept the WRITE BUFFER command and do nothing other than set the appropriate "microcode has been changed" UA on the LU. >From an earlier patch by Doug Gilbert. Signed-off-by: Ewan D. Milne <emilne@redhat.com> Acked-by: Douglas Gilbert <dgilbert@interlog.com> Tested-by: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-09scsi_debug: Add REPORTED LUNS DATA HAS CHANGED Unit AttentionEwan D. Milne
Generate a REPORTED LUNS DATA HAS CHANGED Unit Attention if sysfs "max_luns" is used to change the number of scsi_debug LUNs. This is only done if scsi_debug_scsi_level is SPC-3 or above. Additionally, implement SPC-4 behavior which only generates this Unit Attention on the first LUN on the target to receive a command after the change. This condition is cleared when a REPORT LUNS command is received. Signed-off-by: Ewan D. Milne <emilne@redhat.com> Acked-by: Douglas Gilbert <dgilbert@interlog.com> Tested-by: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-09ses: Add power_status to SES device slotSong Liu
Add power_status to SES device slot, so we can power on/off the HDDs behind the enclosure. Check firmware status in ses_set_* before sending control pages to firmware. Signed-off-by: Song Liu <songliubraving@fb.com> Acked-by: Dan Williams <dan.j.williams@intel.com> Reviewed-by: Jens Axboe <axboe@fb.com> Cc: Hannes Reinecke <hare@suse.de> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-09ses: add reliable slot attributeDan Williams
The name provided by firmware is in a vendor specific format, publish the slot number to have a reliable mechanism for identifying slots across firmware implementations. If the enclosure does not provide a slot number fallback to the component number which is guaranteed unique, and usually mirrors the slot number. Cleaned up the unused ses_component.desc in the process. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Song Liu <songliubraving@fb.com> Reviewed-by: Jens Axboe <axboe@fb.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-09ses: add enclosure logical idDan Williams
Export the NAA logical id for the enclosure. This is optionally available from the sas_transport_class, but it is really a property of the enclosure. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Song Liu <songliubraving@fb.com> Reviewed-by: Jens Axboe <axboe@fb.com> Cc: Hannes Reinecke <hare@suse.de> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-09ses: generate KOBJ_CHANGE on enclosure attachDan Williams
In support of a /dev/disk/by-slot populated with data from the enclosure and ses modules udev needs notification when the new interface files/links are available. Otherwise, any udev rules specified for the disk cannot assume that the enclosure topology has settled. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Song Liu <songliubraving@fb.com> Reviewed-by: Jens Axboe <axboe@fb.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-09ses: close potential registration raceDan Williams
The slot and address fields have a small window of instability when userspace can read them before initialization. Separate enclosure_component allocation from registration. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Song Liu <songliubraving@fb.com> Reviewed-by: Jens Axboe <axboe@fb.com> Cc: Hannes Reinecke <hare@suse.de> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-09scsi: retry report-luns when reported LU count requres more memoryRob Evers
Update scsi_report_lun_scan to initially always report up to 511 LUs, as the previous default max_report_luns did. Retry in a loop if not enough memory is available for the number of LUs reported. Parameter max_report_luns is removed as it is no longer used. Signed-off-by: Rob Evers <revers@redhat.com> Reviewed-by: Ewan D. Milne <emilne@redhat.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-09scsi: use set/get_unaligned_be32 in report_lunsRob Evers
2015-01-09scsi: avoid unnecessary GFP_ATOMIC allocation in scsi_report_lun_scanRob Evers
2015-01-09scsi: fix scsi_error.c kernel-doc warningRandy Dunlap
Fix kernel-doc warning in scsi_error.c: Warning(..//drivers/scsi/scsi_error.c:887): No description found for parameter 'hostt' Fixes: 883a030f989a17b81167f3a181cf93d741fa98b4 (scsi: document scsi_try_to_abort_cmd) Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-09scsi: asc/ascq codes, sync to T10 2014/12/21Douglas Gilbert
The last time these SCSI asc/ascq codes were synced with T10 was 2013/06/05. Sync the SCSI ASC/ASCQ number to string tables with those found at http://www.t10.org/lists/asc-num.txt dated 2014/12/21. Signed-off-by: Douglas Gilbert <dgilbert@interlog.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-09scsi: ->queue_rq can't sleepChristoph Hellwig
The blk-mq ->queue_rq method is always called from process context, but might have preemption disabled. This means we still always have to use GFP_ATOMIC for memory allocations, and thus need to revert part of commit 3c356bde1 ("scsi: stop passing a gfp_mask argument down the command setup path"). Signed-off-by: Christoph Hellwig <hch@lst.de> Reported-by: Sasha Levin <sasha.levin@oracle.com> Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Tested-by: Alexei Starovoitov <alexei.starovoitov@gmail.com>
2015-01-09MAINTAINERS: Update maintainer list for qla4xxxNilesh Javali
Signed-off-by: Nilesh Javali <nilesh.javali@qlogic.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-05qla2xxx: fix busy wait regressionBruno Prémont
Commit e05fe29248 (qla2xxx: Honor FCP_RSP retry delay timer field.) causes systems to busy-wait for about 3 minutes after boot prior to detecting SAN disks. During this wait period one kworker is running full-time (though /proc/<pid>/stack has no useful data). Another kworker is waiting for IO to complete during that whole time period. Looking at drivers/scsi/qla2xxx/qla_os.c, fcport->retry_delay_timestamp has a special value of 0 though that 0 value forces system to wait when jiffies is very large value (e.g. 4294952605 - "negative" value when signed on 32bit systems). Signed-off-by: Bruno Prémont <bonbons@linux-vserver.org> Acked-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-04Merge branch 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/umlLinus Torvalds
Pull UML fixes from Richard Weinberger: "Two fixes for UML regressions. Nothing exciting" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/uml: x86, um: actually mark system call tables readonly um: Skip futex_atomic_cmpxchg_inatomic() test
2015-01-04Revert "ARM: 7830/1: delay: don't bother reporting bogomips in /proc/cpuinfo"Pavel Machek
Commit 9fc2105aeaaf ("ARM: 7830/1: delay: don't bother reporting bogomips in /proc/cpuinfo") breaks audio in python, and probably elsewhere, with message FATAL: cannot locate cpu MHz in /proc/cpuinfo I'm not the first one to hit it, see for example https://theredblacktree.wordpress.com/2014/08/10/fatal-cannot-locate-cpu-mhz-in-proccpuinfo/ https://devtalk.nvidia.com/default/topic/765800/workaround-for-fatal-cannot-locate-cpu-mhz-in-proc-cpuinf/?offset=1 Reading original changelog, I have to say "Stop breaking working setups. You know who you are!". Signed-off-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-01-04x86, um: actually mark system call tables readonlyDaniel Borkmann
Commit a074335a370e ("x86, um: Mark system call tables readonly") was supposed to mark the sys_call_table in UML as RO by adding the const, but it doesn't have the desired effect as it's nevertheless being placed into the data section since __cacheline_aligned enforces sys_call_table being placed into .data..cacheline_aligned instead. We need to use the ____cacheline_aligned version instead to fix this issue. Before: $ nm -v arch/x86/um/sys_call_table_64.o | grep -1 "sys_call_table" U sys_writev 0000000000000000 D sys_call_table 0000000000000000 D syscall_table_size After: $ nm -v arch/x86/um/sys_call_table_64.o | grep -1 "sys_call_table" U sys_writev 0000000000000000 R sys_call_table 0000000000000000 D syscall_table_size Fixes: a074335a370e ("x86, um: Mark system call tables readonly") Cc: H. Peter Anvin <hpa@zytor.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: Richard Weinberger <richard@nod.at>
2015-01-04um: Skip futex_atomic_cmpxchg_inatomic() testRichard Weinberger
futex_atomic_cmpxchg_inatomic() does not work on UML because it triggers a copy_from_user() in kernel context. On UML copy_from_user() can only be used if the kernel was called by a real user space process such that UML can use ptrace() to fetch the value. Reported-by: Miklos Szeredi <miklos@szeredi.hu> Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Richard Weinberger <richard@nod.at> Tested-by: Daniel Walter <d.walter@0x90.at>
2015-01-02Merge tag 'scsi-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull SCSI fixes from James Bottomley: "This is a set of three fixes: one to correct an abort path thinko causing failures (and a panic) in USB on device misbehaviour, One to fix an out of order issue in the fnic driver and one to match discard expectations to qemu which otherwise cause Linux to behave badly as a guest" * tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: SCSI: fix regression in scsi_send_eh_cmnd() fnic: IOMMU Fault occurs when IO and abort IO is out of order sd: tweak discard heuristics to work around QEMU SCSI issue
2015-01-02Merge tag 'sound-3.19-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Nothing too exciting as a new year's start here: most of fixes are for ASoC, a boot crash fix on OMAP for deferred probe, a few driver specific fixes (Intel, dwc, rockchip, rt5677), in addition to typo fixes in kerneldoc comments for PCM" * tag 'sound-3.19-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: pcm: Fix kerneldoc for params_*() functions ASoC: rockchip: i2s: fix maxburst of dma data to 4 ASoC: rockchip: i2s: fix error defination of transmit data level ASoC: Intel: correct the fixed free block allocation ASoC: rt5677: fixed rt5677_dsp_vad_put rt5677_dsp_vad_get panic ASoC: Intel: Fix BYTCR machine driver MODULE_ALIAS ASoC: Intel: Fix BYTCR firmware name ASoC: dwc: Iterate over all channels ASoC: dwc: Ensure FIFOs are flushed to prevent channel swap ASoC: Intel: Add I2C dependency to two new machines ASoC: dapm: Remove snd_soc_of_parse_audio_routing() due to deferred probe
2015-01-02Merge tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhostLinus Torvalds
Pull vhost cleanup and virtio bugfix "There's a single change here, fixing a vhost bug where vhost initialization fails due to used ring alignment check being too strict" * tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost: vhost: relax used address alignment virtio_ring: document alignment requirements
2014-12-31Merge branch 'upstream' of git://git.infradead.org/users/pcmoore/auditLinus Torvalds
Pull audit fix from Paul Moore: "One audit patch to resolve a panic/oops when recording filenames in the audit log, see the mail archive link below. The fix isn't as nice as I would like, as it involves an allocate/copy of the filename, but it solves the problem and the overhead should only affect users who have configured audit rules involving file names. We'll revisit this issue with future kernels in an attempt to make this suck less, but in the meantime I think this fix should go into the next release of v3.19-rcX. [ https://marc.info/?t=141986927600001&r=1&w=2 ]" * 'upstream' of git://git.infradead.org/users/pcmoore/audit: audit: create private file name copies when auditing inodes
2014-12-31Revert "Input: atmel_mxt_ts - use deep sleep mode when stopped"Linus Torvalds
This reverts commit 9d469d033d135d80742a4e39e6bbb4519dd5eee1. It breaks the Chromebook Pixel touchpad (and touchscreen). Reported-by: Dirk Hohndel <dirk@hohndel.org> Bisected-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Nick Dyer <nick.dyer@itdev.co.uk> Cc: Benson Leung <bleung@chromium.org> Cc: Yufeng Shen <miletus@chromium.org> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: stable@vger.kernel.org # v3.16+ Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-31Merge tag 'nios2-fixes-v3.19-rc3' of ↵Linus Torvalds
git://git.rocketboards.org/linux-socfpga-next Pull arch/nios2 fixes from Ley Foon Tan: - fix compilation error when enable CONFIG_PREEMPT - initialize cpuinfo.mmu variable supplied by the device tree * tag 'nios2-fixes-v3.19-rc3' of git://git.rocketboards.org/linux-socfpga-next: nios2: Use preempt_schedule_irq nios2: Initialize cpuinfo.mmu
2014-12-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto fix from Herbert Xu: "Fix a use-after-free crash in the user-space crypto API" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: af_alg - fix backlog handling
2014-12-31nios2: Use preempt_schedule_irqTobias Klauser
Follow aa0d53260596 ("ia64: Use preempt_schedule_irq") and use preempt_schedule_irq instead of enabling/disabling interrupts and messing around with PREEMPT_ACTIVE in the nios2 low-level preemption code ourselves. Also get rid of the now needless re-check for TIF_NEED_RESCHED, preempt_schedule_irq will already take care of rescheduling. This also fixes the following build error when building with CONFIG_PREEMPT: arch/nios2/kernel/built-in.o: In function `need_resched': arch/nios2/kernel/entry.S:374: undefined reference to `PREEMPT_ACTIVE' Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Acked-by: Ley Foon Tan <lftan@altera.com>
2014-12-31nios2: Initialize cpuinfo.mmuWalter Goossens
This patch initializes the mmu field of the cpuinfo structure to the value supplied by the devicetree. Signed-off-by: Walter Goossens <waltergoossens@home.nl> Acked-by: Ley Foon Tan <lftan@altera.com>
2014-12-30Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Arnd Bergmann: "A very small set of fixes for 3.19, as everyone was out. The clocksource patch was something I missed for the merge window after the change that broke arm64 was merged through arm-soc. The other two patches are a fix for an undetected merge problem in mvebu and a defconfig change to make some exynos boards work with the normal multi_v7_defconfig" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: Add USB_EHCI_EXYNOS to multi_v7_defconfig ARM: mvebu: Fix pinctrl configuration for Armada 370 DB clocksource: arch_timer: Only use the virtual counter (CNTVCT) on arm64
2014-12-30Merge tag 'fbdev-fixes-3.19' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux Pull fbdev fixes from Tomi Valkeinen: - Fix regression with Nokia N900 display - Fix crash on fbdev using freed __initdata logos - Fix fb_deferred_io_fsync() return value. * tag 'fbdev-fixes-3.19' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: OMAPDSS: SDI: fix output port_num video/fbdev: fix defio's fsync video/logo: prevent use of logos after they have been freed OMAPDSS: pll: NULL dereference in error handling OMAPDSS: HDMI: remove double initializer entries
2014-12-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input layer fixes from Dmitry Torokhov: "Fixes for v7 protocol for ALPS devices and few other driver fixes. Also users can request input events to be stamped with boot time timestamps, in addition to real and monotonic timestamps" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: hil_kbd - fix incorrect use of init_completion Input: alps - v7: document the v7 touchpad packet protocol Input: alps - v7: fix finger counting for > 2 fingers on clickpads Input: alps - v7: sometimes a single touch is reported in mt[1] Input: alps - v7: ignore new packets Input: evdev - add CLOCK_BOOTTIME support Input: psmouse - expose drift duration for IBM trackpoints Input: stmpe - bias keypad columns properly Input: stmpe - enforce device tree only mode mfd: stmpe: add pull up/down register offsets for STMPE Input: optimize events_per_packet count calculation Input: edt-ft5x06 - fixed a macro coding style issue Input: gpio_keys - replace timer and workqueue with delayed workqueue Input: gpio_keys - allow separating gpio and irq in device tree
2014-12-30Revert "cfg80211: make WEXT compatibility unselectable"Jiri Kosina
This reverts commit 24a0aa212ee2dbe44360288684478d76a8e20a0a. It's causing severe userspace breakage. Namely, all the utilities from wireless-utils which are relying on CONFIG_WEXT (which means tools like 'iwconfig', 'iwlist', etc) are not working anymore. There is a 'iw' utility in newer wireless-tools, which is supposed to be a replacement for all the "deprecated" binaries, but it's far away from being massively adopted. Please see [1] for example of the userspace breakage this is causing. In addition to that, Larry Finger reports [2] that this patch is also causing ipw2200 driver being impossible to build. To me this clearly shows that CONFIG_WEXT is far, far away from being "deprecated enough" to be removed. [1] http://thread.gmane.org/gmane.linux.kernel/1857010 [2] http://thread.gmane.org/gmane.linux.network/343688 Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix double SKB free in bluetooth 6lowpan layer, from Jukka Rissanen. 2) Fix receive checksum handling in enic driver, from Govindarajulu Varadarajan. 3) Fix NAPI poll list corruption in virtio_net and caif_virtio, from Herbert Xu. Also, add code to detect drivers that have this mistake in the future. 4) Fix doorbell endianness handling in mlx4 driver, from Amir Vadai. 5) Don't clobber IP6CB() before xfrm6_policy_check() is called in TCP input path,f rom Nicolas Dichtel. 6) Fix MPLS action validation in openvswitch, from Pravin B Shelar. 7) Fix double SKB free in vxlan driver, also from Pravin. 8) When we scrub a packet, which happens when we are switching the context of the packet (namespace, etc.), we should reset the secmark. From Thomas Graf. 9) ->ndo_gso_check() needs to do more than return true/false, it also has to allow the driver to clear netdev feature bits in order for the caller to be able to proceed properly. From Jesse Gross. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (62 commits) genetlink: A genl_bind() to an out-of-range multicast group should not WARN(). netlink/genetlink: pass network namespace to bind/unbind ne2k-pci: Add pci_disable_device in error handling bonding: change error message to debug message in __bond_release_one() genetlink: pass multicast bind/unbind to families netlink: call unbind when releasing socket netlink: update listeners directly when removing socket genetlink: pass only network namespace to genl_has_listeners() netlink: rename netlink_unbind() to netlink_undo_bind() net: Generalize ndo_gso_check to ndo_features_check net: incorrect use of init_completion fixup neigh: remove next ptr from struct neigh_table net: xilinx: Remove unnecessary temac_property in the driver net: phy: micrel: use generic config_init for KSZ8021/KSZ8031 net/core: Handle csum for CHECKSUM_COMPLETE VXLAN forwarding openvswitch: fix odd_ptr_err.cocci warnings Bluetooth: Fix accepting connections when not using mgmt Bluetooth: Fix controller configuration with HCI_QUIRK_INVALID_BDADDR brcmfmac: Do not crash if platform data is not populated ipw2200: select CFG80211_WEXT ...
2014-12-30Merge tag 'linux-kselftest-3.19-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest Pull kselftest fix from Shuah Khan: "Fix exec test compile warnings" * tag 'linux-kselftest-3.19-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest: selftests/exec: Use %zu to format size_t
