2016-06-30Remove last traces of ->sync_pageMatthew Wilcox
Commit 7eaceaccab5f removed ->sync_page, but a few mentions of it still existed in documentation and comments, Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-06-30new helper: d_same_name()Al Viro
2016-06-30dentry_cmp(): use lockless_dereference() instead of smp_read_barrier_depends()He Kuang
lockless_dereference() was added which can be used in place of hard-coding smp_read_barrier_depends(). Signed-off-by: He Kuang <hekuang@huawei.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-06-30Merge branch 'for-linus' into work.miscAl Viro
2016-06-30namespace: update event counter when umounting a deleted dentryAndrey Ulanov
- m_start() in fs/namespace.c expects that ns->event is incremented each time a mount added or removed from ns->list. - umount_tree() removes items from the list but does not increment event counter, expecting that it's done before the function is called. - There are some codepaths that call umount_tree() without updating "event" counter. e.g. from __detach_mounts(). - When this happens m_start may reuse a cached mount structure that no longer belongs to ns->list (i.e. use after free which usually leads to infinite loop). This change fixes the above problem by incrementing global event counter before invoking umount_tree(). Change-Id: I622c8e84dcb9fb63542372c5dbf0178ee86bb589 Cc: stable@vger.kernel.org Signed-off-by: Andrey Ulanov <andreyu@google.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-06-309p: use file_dentry()Miklos Szeredi
v9fs may be used as lower layer of overlayfs and accessing f_path.dentry can lead to a crash. In this case it's a NULL pointer dereference in p9_fid_create(). Fix by replacing direct access of file->f_path.dentry with the file_dentry() accessor, which will always return a native object. Reported-by: Alessio Igor Bogani <alessioigorbogani@gmail.com> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com> Tested-by: Alessio Igor Bogani <alessioigorbogani@gmail.com> Fixes: 4bacc9c9234c ("overlayfs: Make f_path always point to the overlay and f_inode to the underlay") Cc: <stable@vger.kernel.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-06-24ceph: fix d_obtain_alias() misusesAl Viro
on failure d_obtain_alias() will have done iput() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-06-20lockless next_positive()Al Viro
2016-06-20libfs.c: new helper - next_positive()Al Viro
Return nth positive child after given or NULL if there's less than n left. dcache_readdir() and dcache_dir_lseek() switched to it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-06-20dcache_{readdir,dir_lseek}(): don't bother with nested ->d_lockAl Viro
Make sure that directory is locked shared in dcache_dir_lseek(); for dcache_readdir() it's already tru, and that's enough to make simple_positive() stable. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-06-20fix idiotic braino in d_alloc_parallel()Al Viro
Check for d_unhashed() while searching in in-lookup hash was absolutely wrong. Worse, it masked a deadlock on dget() done under bitlock that nests inside ->d_lock. Thanks to J. R. Okajima for spotting it. Spotted-by: "J. R. Okajima" <hooanon05g@gmail.com> Wearing-brown-paperbag: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-06-12autofs racesAl Viro
* make autofs4_expire_indirect() skip the dentries being in process of expiry * do *not* mess with list_move(); making sure that dentry with AUTOFS_INF_EXPIRING are not picked for expiry is enough. * do not remove NO_RCU when we set EXPIRING, don't bother with smp_mb() there. Clear it at the same time we clear EXPIRING. Makes a bunch of tests simpler. * rename NO_RCU to WANT_EXPIRE, which is what it really is. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-06-10much milder d_walk() raceAl Viro
d_walk() relies upon the tree not getting rearranged under it without rename_lock being touched. And we do grab rename_lock around the places that change the tree topology. Unfortunately, branch reordering is just as bad from d_walk() POV and we have two places that do it without touching rename_lock - one in handling of cursors (for ramfs-style directories) and another in autofs. autofs one is a separate story; this commit deals with the cursors. * mark cursor dentries explicitly at allocation time * make __dentry_kill() leave ->d_child.next pointing to the next non-cursor sibling, making sure that it won't be moved around unnoticed before the parent is relocked on ascend-to-parent path in d_walk(). * make d_walk() skip cursors explicitly; strictly speaking it's not necessary (all callbacks we pass to d_walk() are no-ops on cursors), but it makes analysis easier. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-06-07coredump: fix dumping through pipesMateusz Guzik
The offset in the core file used to be tracked with ->written field of the coredump_params structure. The field was retired in favour of file->f_pos. However, ->f_pos is not maintained for pipes which leads to breakage. Restore explicit tracking of the offset in coredump_params. Introduce ->pos field for this purpose since ->written was already reused. Fixes: a00839395103 ("get rid of coredump_params->written"). Reported-by: Zbigniew Jędrzejewski-Szmek <zbyszek@in.waw.pl> Signed-off-by: Mateusz Guzik <mguzik@redhat.com> Reviewed-by: Omar Sandoval <osandov@fb.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-06-07fix a regression in atomic_open()Al Viro
open("/foo/no_such_file", O_RDONLY | O_CREAT) on should fail with EACCES when /foo is not writable; failing with ENOENT is obviously wrong. That got broken by a braino introduced when moving the creat_error logics from atomic_open() to lookup_open(). Easy to fix, fortunately. Spotted-by: "Yan, Zheng" <ukernel@gmail.com> Tested-by: "Yan, Zheng" <ukernel@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-06-07fix d_walk()/non-delayed __d_free() raceAl Viro
Ascend-to-parent logics in d_walk() depends on all encountered child dentries not getting freed without an RCU delay. Unfortunately, in quite a few cases it is not true, with hard-to-hit oopsable race as the result. Fortunately, the fix is simiple; right now the rule is "if it ever been hashed, freeing must be delayed" and changing it to "if it ever had a parent, freeing must be delayed" closes that hole and covers all cases the old rule used to cover. Moreover, pipes and sockets remain _not_ covered, so we do not introduce RCU delay in the cases which are the reason for having that delay conditional in the first place. Cc: stable@vger.kernel.org # v3.2+ (and watch out for __d_materialise_dentry()) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-06-05autofs braino fix for do_last()Al Viro
It's an analogue of commit 7500c38a (fix the braino in "namei: massage lookup_slow() to be usable by lookup_one_len_unlocked()"). The same problem (->lookup()-returned unhashed negative dentry just might be an autofs one with ->d_manage() that would wait until the daemon makes it positive) applies in do_last() - we need to do follow_managed() first. Fortunately, remaining callers of follow_managed() are OK - only autofs has that weirdness (negative dentry that does not mean an instant -ENOENT)) and autofs never has its negative dentries hashed, so we can't pick one from a dcache lookup. ->d_manage() is a bloody mess ;-/ Cc: stable@vger.kernel.org # v4.6 Spotted-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-06-04fix EOPENSTALE bug in do_last()Al Viro
EOPENSTALE occuring at the last component of a trailing symlink ends up with do_last() retrying its lookup. After the symlink body has been discarded. The thing is, all this retry_lookup logics in there is not needed at all - the upper layers will do the right thing if we simply return that -EOPENSTALE as we would with any other error. Trying to microoptimize in do_last() is a lot of headache for no good reason. Cc: stable@vger.kernel.org # v4.2+ Tested-by: Oleg Drokin <green@linuxhacker.ru> Reviewed-and-Tested-by: Jeff Layton <jlayton@poochiereds.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-05-29binfmt_misc: ->s_root is not going anywhereAl Viro
... no need to dget/dput it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-05-29drop redundant ->owner initializationsAl Viro
it's not needed for file_operations of inodes located on fs defined in the hosting module and for file_operations that go into procfs. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-05-29ufs: get rid of redundant checksAl Viro
ufs_check_page() makes sure there's no entries with zero ->reclen Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-05-29orangefs: constify inode_operationsAl Viro
2016-05-29missed comment updates from ->direct_IO() prototype changeAl Viro
2016-05-29file_inode(f)->i_mapping is f->f_mappingAl Viro
2016-05-29trim fsnotify hooks a bitAl Viro
fsnotify_d_move()/__fsnotify_d_instantiate()/__fsnotify_update_dcache_flags() are identical to each other, regardless of the config. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-05-299p: new helper - v9fs_parent_fid()Al Viro
2016-05-29debugfs: ->d_parent is never NULL or negativeAl Viro
2016-05-29nfs_lookup(): remove debris left over from old sillyunlink exclusionAl Viro
2016-05-29orangefs: don't open-code %pd2Al Viro
2016-05-29tracefs: ->d_parent is never NULL or negative...Al Viro
2016-05-29securityfs: ->d_parent is never NULL or negativeAl Viro
2016-05-29drbd: ->d_parent is never NULL or negativeAl Viro
2016-05-29undo "fs: allow d_instantiate to be called with negative parent dentry"Al Viro
Background: spufs used to mangle the order in which it had been building dentry trees. It was broken in a lot of ways, but most of them required the right timing to trigger until an fsnotify change had added one more - the one that was always triggered. Unfortunately, insteading of fixing their long-standing bug the spufs folks had chosen to paper over the fsnotify trigger. Eventually said bug had been spotted and killed off, but the pointless check in fsnotify has remained, complete with the implication that one *could* do that kind of crap. Again, a parent of any dentry should always be positive. Any code can rely upon that and anything violating that assert is a bug, *not* something to be accomodated. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-05-29Linux 4.7-rc1Linus Torvalds
2016-05-29hash_string: Fix zero-length case for !DCACHE_WORD_ACCESSGeorge Spelvin
The self-test was updated to cover zero-length strings; the function needs to be updated, too. Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: George Spelvin <linux@sciencehorizons.net> Fixes: fcfd2fbf22d2 ("fs/namei.c: Add hashlen_string() function") Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-28Rename other copy of hash_string to hashlen_stringGeorge Spelvin
The original name was simply hash_string(), but that conflicted with a function with that name in drivers/base/power/trace.c, and I decided that calling it "hashlen_" was better anyway. But you have to do it in two places. [ This caused build errors for architectures that don't define CONFIG_DCACHE_WORD_ACCESS - Linus ] Signed-off-by: George Spelvin <linux@sciencehorizons.net> Reported-by: Guenter Roeck <linux@roeck-us.net> Fixes: fcfd2fbf22d2 ("fs/namei.c: Add hashlen_string() function") Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-28hpfs: implement the show_options methodMikulas Patocka
The HPFS filesystem used generic_show_options to produce string that is displayed in /proc/mounts. However, there is a problem that the options may disappear after remount. If we mount the filesystem with option1 and then remount it with option2, /proc/mounts should show both option1 and option2, however it only shows option2 because the whole option string is replaced with replace_mount_options in hpfs_remount_fs. To fix this bug, implement the hpfs_show_options function that prints options that are currently selected. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-28affs: fix remount failure when there are no options changedMikulas Patocka
Commit c8f33d0bec99 ("affs: kstrdup() memory handling") checks if the kstrdup function returns NULL due to out-of-memory condition. However, if we are remounting a filesystem with no change to filesystem-specific options, the parameter data is NULL. In this case, kstrdup returns NULL (because it was passed NULL parameter), although no out of memory condition exists. The mount syscall then fails with ENOMEM. This patch fixes the bug. We fail with ENOMEM only if data is non-NULL. The patch also changes the call to replace_mount_options - if we didn't pass any filesystem-specific options, we don't call replace_mount_options (thus we don't erase existing reported options). Fixes: c8f33d0bec99 ("affs: kstrdup() memory handling") Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: stable@vger.kernel.org # v4.1+ Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-28hpfs: fix remount failure when there are no options changedMikulas Patocka
Commit ce657611baf9 ("hpfs: kstrdup() out of memory handling") checks if the kstrdup function returns NULL due to out-of-memory condition. However, if we are remounting a filesystem with no change to filesystem-specific options, the parameter data is NULL. In this case, kstrdup returns NULL (because it was passed NULL parameter), although no out of memory condition exists. The mount syscall then fails with ENOMEM. This patch fixes the bug. We fail with ENOMEM only if data is non-NULL. The patch also changes the call to replace_mount_options - if we didn't pass any filesystem-specific options, we don't call replace_mount_options (thus we don't erase existing reported options). Fixes: ce657611baf9 ("hpfs: kstrdup() out of memory handling") Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-28Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull more MIPS updates from Ralf Baechle: "This is the secondnd batch of MIPS patches for 4.7. Summary: CPS: - Copy EVA configuration when starting secondary VPs. EIC: - Clear Status IPL. Lasat: - Fix a few off by one bugs. lib: - Mark intrinsics notrace. Not only are the intrinsics uninteresting, it would cause infinite recursion. MAINTAINERS: - Add file patterns for MIPS BRCM device tree bindings. - Add file patterns for mips device tree bindings. MT7628: - Fix MT7628 pinmux typos. - wled_an pinmux gpio. - EPHY LEDs pinmux support. Pistachio: - Enable KASLR VDSO: - Build microMIPS VDSO for microMIPS kernels. - Fix aliasing warning by building with `-fno-strict-aliasing' for debugging but also tracing them might result in recursion. Misc: - Add missing FROZEN hotplug notifier transitions. - Fix clk binding example for varioius PIC32 devices. - Fix cpu interrupt controller node-names in the DT files. - Fix XPA CPU feature separation. - Fix write_gc0_* macros when writing zero. - Add inline asm encoding helpers. - Add missing VZ accessor microMIPS encodings. - Fix little endian microMIPS MSA encodings. - Add 64-bit HTW fields and fix its configuration. - Fix sigreturn via VDSO on microMIPS kernel. - Lots of typo fixes. - Add definitions of SegCtl registers and use them" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (49 commits) MIPS: Add missing FROZEN hotplug notifier transitions MIPS: Build microMIPS VDSO for microMIPS kernels MIPS: Fix sigreturn via VDSO on microMIPS kernel MIPS: devicetree: fix cpu interrupt controller node-names MIPS: VDSO: Build with `-fno-strict-aliasing' MIPS: Pistachio: Enable KASLR MIPS: lib: Mark intrinsics notrace MIPS: Fix 64-bit HTW configuration MIPS: Add 64-bit HTW fields MAINTAINERS: Add file patterns for mips device tree bindings MAINTAINERS: Add file patterns for mips brcm device tree bindings MIPS: Simplify DSP instruction encoding macros MIPS: Add missing tlbinvf/XPA microMIPS encodings MIPS: Fix little endian microMIPS MSA encodings MIPS: Add missing VZ accessor microMIPS encodings MIPS: Add inline asm encoding helpers MIPS: Spelling fix lets -> let's MIPS: VR41xx: Fix typo MIPS: oprofile: Fix typo MIPS: math-emu: Fix typo ...
2016-05-28fs: fix binfmt_aout.c build errorGuenter Roeck
Various builds (such as i386:allmodconfig) fail with fs/binfmt_aout.c:133:2: error: expected identifier or '(' before 'return' fs/binfmt_aout.c:134:1: error: expected identifier or '(' before '}' token [ Oops. My bad, I had stupidly thought that "allmodconfig" covered this on x86-64 too, but it obviously doesn't. Egg on my face. - Linus ] Fixes: 5d22fc25d4fc ("mm: remove more IS_ERR_VALUE abuses") Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-28Merge branch 'hash' of git://ftp.sciencehorizons.net/linuxLinus Torvalds
Pull string hash improvements from George Spelvin: "This series does several related things: - Makes the dcache hash (fs/namei.c) useful for general kernel use. (Thanks to Bruce for noticing the zero-length corner case) - Converts the string hashes in <linux/sunrpc/svcauth.h> to use the above. - Avoids 64-bit multiplies in hash_64() on 32-bit platforms. Two 32-bit multiplies will do well enough. - Rids the world of the bad hash multipliers in hash_32. This finishes the job started in commit 689de1d6ca95 ("Minimal fix-up of bad hashing behavior of hash_64()") The vast majority of Linux architectures have hardware support for 32x32-bit multiply and so derive no benefit from "simplified" multipliers. The few processors that do not (68000, h8/300 and some models of Microblaze) have arch-specific implementations added. Those patches are last in the series. - Overhauls the dcache hash mixing. The patch in commit 0fed3ac866ea ("namei: Improve hash mixing if CONFIG_DCACHE_WORD_ACCESS") was an off-the-cuff suggestion. Replaced with a much more careful design that's simultaneously faster and better. (My own invention, as there was noting suitable in the literature I could find. Comments welcome!) - Modify the hash_name() loop to skip the initial HASH_MIX(). This would let us salt the hash if we ever wanted to. - Sort out partial_name_hash(). The hash function is declared as using a long state, even though it's truncated to 32 bits at the end and the extra internal state contributes nothing to the result. And some callers do odd things: - fs/hfs/string.c only allocates 32 bits of state - fs/hfsplus/unicode.c uses it to hash 16-bit unicode symbols not bytes - Modify bytemask_from_count to handle inputs of 1..sizeof(long) rather than 0..sizeof(long)-1. This would simplify users other than full_name_hash" Special thanks to Bruce Fields for testing and finding bugs in v1. (I learned some humbling lessons about "obviously correct" code.) On the arch-specific front, the m68k assembly has been tested in a standalone test harness, I've been in contact with the Microblaze maintainers who mostly don't care, as the hardware multiplier is never omitted in real-world applications, and I haven't heard anything from the H8/300 world" * 'hash' of git://ftp.sciencehorizons.net/linux: h8300: Add <asm/hash.h> microblaze: Add <asm/hash.h> m68k: Add <asm/hash.h> <linux/hash.h>: Add support for architecture-specific functions fs/namei.c: Improve dcache hash function Eliminate bad hash multipliers from hash_32() and hash_64() Change hash_64() return value to 32 bits <linux/sunrpc/svcauth.h>: Define hash_str() in terms of hashlen_string() fs/namei.c: Add hashlen_string() function Pull out string hash to <linux/stringhash.h>
2016-05-28h8300: Add <asm/hash.h>George Spelvin
This will improve the performance of hash_32() and hash_64(), but due to complete lack of multi-bit shift instructions on H8, performance will still be bad in surrounding code. Designing H8-specific hash algorithms to work around that is a separate project. (But if the maintainers would like to get in touch...) Signed-off-by: George Spelvin <linux@sciencehorizons.net> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: uclinux-h8-devel@lists.sourceforge.jp
2016-05-28microblaze: Add <asm/hash.h>George Spelvin
Microblaze is an FPGA soft core that can be configured various ways. If it is configured without a multiplier, the standard __hash_32() will require a call to __mulsi3, which is a slow software loop. Instead, use a shift-and-add sequence for the constant multiply. GCC knows how to do this, but it's not as clever as some. Signed-off-by: George Spelvin <linux@sciencehorizons.net> Cc: Alistair Francis <alistair.francis@xilinx.com> Cc: Michal Simek <michal.simek@xilinx.com>
2016-05-28m68k: Add <asm/hash.h>George Spelvin
This provides a multiply by constant GOLDEN_RATIO_32 = 0x61C88647 for the original mc68000, which lacks a 32x32-bit multiply instruction. Yes, the amount of optimization effort put in is excessive. :-) Shift-add chain found by Yevgen Voronenko's Hcub algorithm at http://spiral.ece.cmu.edu/mcm/gen.html Signed-off-by: George Spelvin <linux@sciencehorizons.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greg Ungerer <gerg@linux-m68k.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Cc: Philippe De Muyter <phdm@macq.eu> Cc: linux-m68k@lists.linux-m68k.org
2016-05-28<linux/hash.h>: Add support for architecture-specific functionsGeorge Spelvin
This is just the infrastructure; there are no users yet. This is modelled on CONFIG_ARCH_RANDOM; a CONFIG_ symbol declares the existence of <asm/hash.h>. That file may define its own versions of various functions, and define HAVE_* symbols (no CONFIG_ prefix!) to suppress the generic ones. Included is a self-test (in lib/test_hash.c) that verifies the basics. It is NOT in general required that the arch-specific functions compute the same thing as the generic, but if a HAVE_* symbol is defined with the value 1, then equality is tested. Signed-off-by: George Spelvin <linux@sciencehorizons.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greg Ungerer <gerg@linux-m68k.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Cc: Philippe De Muyter <phdm@macq.eu> Cc: linux-m68k@lists.linux-m68k.org Cc: Alistair Francis <alistai@xilinx.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: uclinux-h8-devel@lists.sourceforge.jp
2016-05-28fs/namei.c: Improve dcache hash functionGeorge Spelvin
Patch 0fed3ac866 improved the hash mixing, but the function is slower than necessary; there's a 7-instruction dependency chain (10 on x86) each loop iteration. Word-at-a-time access is a very tight loop (which is good, because link_path_walk() is one of the hottest code paths in the entire kernel), and the hash mixing function must not have a longer latency to avoid slowing it down. There do not appear to be any published fast hash functions that: 1) Operate on the input a word at a time, and 2) Don't need to know the length of the input beforehand, and 3) Have a single iterated mixing function, not needing conditional branches or unrolling to distinguish different loop iterations. One of the algorithms which comes closest is Yann Collet's xxHash, but that's two dependent multiplies per word, which is too much. The key insights in this design are: 1) Barring expensive ops like multiplies, to diffuse one input bit across 64 bits of hash state takes at least log2(64) = 6 sequentially dependent instructions. That is more cycles than we'd like. 2) An operation like "hash ^= hash << 13" requires a second temporary register anyway, and on a 2-operand machine like x86, it's three instructions. 3) A better use of a second register is to hold a two-word hash state. With careful design, no temporaries are needed at all, so it doesn't increase register pressure. And this gets rid of register copying on 2-operand machines, so the code is smaller and faster. 4) Using two words of state weakens the requirement for one-round mixing; we now have two rounds of mixing before cancellation is possible. 5) A two-word hash state also allows operations on both halves to be done in parallel, so on a superscalar processor we get more mixing in fewer cycles. I ended up using a mixing function inspired by the ChaCha and Speck round functions. It is 6 simple instructions and 3 cycles per iteration (assuming multiply by 9 can be done by an "lea" instruction): x ^= *input++; y ^= x; x = ROL(x, K1); x += y; y = ROL(y, K2); y *= 9; Not only is this reversible, two consecutive rounds are reversible: if you are given the initial and final states, but not the intermediate state, it is possible to compute both input words. This means that at least 3 words of input are required to create a collision. (It also has the property, used by hash_name() to avoid a branch, that it hashes all-zero to all-zero.) The rotate constants K1 and K2 were found by experiment. The search took a sample of random initial states (I used 1023) and considered the effect of flipping each of the 64 input bits on each of the 128 output bits two rounds later. Each of the 8192 pairs can be considered a biased coin, and adding up the Shannon entropy of all of them produces a score. The best-scoring shifts also did well in other tests (flipping bits in y, trying 3 or 4 rounds of mixing, flipping all 64*63/2 pairs of input bits), so the choice was made with the additional constraint that the sum of the shifts is odd and not too close to the word size. The final state is then folded into a 32-bit hash value by a less carefully optimized multiply-based scheme. This also has to be fast, as pathname components tend to be short (the most common case is one iteration!), but there's some room for latency, as there is a fair bit of intervening logic before the hash value is used for anything. (Performance verified with "bonnie++ -s 0 -n 1536:-2" on tmpfs. I need a better benchmark; the numbers seem to show a slight dip in performance between 4.6.0 and this patch, but they're too noisy to quote.) Special thanks to Bruce fields for diligent testing which uncovered a nasty fencepost error in an earlier version of this patch. [checkpatch.pl formatting complaints noted and respectfully disagreed with.] Signed-off-by: George Spelvin <linux@sciencehorizons.net> Tested-by: J. Bruce Fields <bfields@redhat.com>
2016-05-28Eliminate bad hash multipliers from hash_32() and hash_64()George Spelvin
The "simplified" prime multipliers made very bad hash functions, so get rid of them. This completes the work of 689de1d6ca. To avoid the inefficiency which was the motivation for the "simplified" multipliers, hash_64() on 32-bit systems is changed to use a different algorithm. It makes two calls to hash_32() instead. drivers/media/usb/dvb-usb-v2/af9015.c uses the old GOLDEN_RATIO_PRIME_32 for some horrible reason, so it inherits a copy of the old definition. Signed-off-by: George Spelvin <linux@sciencehorizons.net> Cc: Antti Palosaari <crope@iki.fi> Cc: Mauro Carvalho Chehab <m.chehab@samsung.com>
2016-05-28Change hash_64() return value to 32 bitsGeorge Spelvin
That's all that's ever asked for, and it makes the return type of hash_long() consistent. It also allows (upcoming patch) an optimized implementation of hash_64 on 32-bit machines. I tried adding a BUILD_BUG_ON to ensure the number of bits requested was never more than 32 (most callers use a compile-time constant), but adding <linux/bug.h> to <linux/hash.h> breaks the tools/perf compiler unless tools/perf/MANIFEST is updated, and understanding that code base well enough to update it is too much trouble. I did the rest of an allyesconfig build with such a check, and nothing tripped. Signed-off-by: George Spelvin <linux@sciencehorizons.net>
2016-05-28<linux/sunrpc/svcauth.h>: Define hash_str() in terms of hashlen_string()George Spelvin
Finally, the first use of previous two patches: eliminate the separate ad-hoc string hash functions in the sunrpc code. Now hash_str() is a wrapper around hash_string(), and hash_mem() is likewise a wrapper around full_name_hash(). Note that sunrpc code *does* call hash_mem() with a zero length, which is why the previous patch needed to handle that in full_name_hash(). (Thanks, Bruce, for finding that!) This also eliminates the only caller of hash_long which asks for more than 32 bits of output. The comment about the quality of hashlen_string() and full_name_hash() is jumping the gun by a few patches; they aren't very impressive now, but will be improved greatly later in the series. Signed-off-by: George Spelvin <linux@sciencehorizons.net> Tested-by: J. Bruce Fields <bfields@redhat.com> Acked-by: J. Bruce Fields <bfields@redhat.com> Cc: Jeff Layton <jlayton@poochiereds.net> Cc: linux-nfs@vger.kernel.org
