toradex_4.14-2.0.x-imx-next
Enable the code from commit 'aa5fc842bb05 usb: chipidea: use of extcon
framework to work for non OTG case' if ID and/or VBUS signals are taken
from extcon.
Otherwise (observed on a Colibri iMX6ULL) when booting in the ROLE_HOST
and then changing to ROLE_GADGET the gadget does not appear on the bus
and switching back to ROLE_HOST does also no longer detect any connected
USB devices.
Related-to: #50573
(cherry picked from commit b80233b2f3ec91920bba3712dcc929dc913caf15)
This reverts commit c3b206c34b2eccdde14fee1012d85ef3e9448c3e.
With the forward port to 4.9 this is now obsolete. The following commit
already added this:
'5c256b68348e usb: phy: mxs: add "fsl,imx6ul-usbphy" compatible string'
(cherry picked from commit 4adfcec131baf1deb92b5f23c0871cff32307cc1)
The pci-imx6 driver reads the fsl,max-link-speed property.
Change to the correct name.
With the 'Revert "MLK-18433 PCI: imx: remove the lpcg_xxx clocks in driver"'
The pcie_per clock is again needed. So add it also to the overriding
clock property.
This reverts commit 68a026f4d3d8d79185c0b1bcc1e74985e1322466.
The clock pcie_per is required to be held to avoid crash of pcie driver
on system suspend.
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
The driver tries to modify registers after disable important clocks.
This causes the crash a driver:
[ 67.083289] Synchronous External Abort: synchronous external abort (0x96000210) at 0xffff00000d9c0008
[ 67.092620] Internal error: : 96000210 [#1] PREEMPT SMP
[ 67.097935] Modules linked in: 8021q garp stp mrp crc32_ce crct10dif_ce mwifiex_pcie mwifiex galcore(O)
[ 67.107447] Process sh (pid: 4032, stack limit = 0xffff00001a668000)
[ 67.113897] CPU: 3 PID: 4032 Comm: sh Tainted: G O 4.14.117-3.0.2+ge43e3a26e1b7 #1
[ 67.122691] Hardware name: Toradex Colibri iMX8QXP/DX on Colibri Evaluation Board V3 (DT)
[ 67.130963] task: ffff8000761b4380 task.stack: ffff00001a668000
[ 67.136983] PC is at regmap_mmio_read32le+0x8/0x20
[ 67.141866] LR is at regmap_mmio_read+0x2c/0x68
[ 67.146484] pc : [<ffff0000086db108>] lr : [<ffff0000086db1e4>] pstate: 000001c5
[ 67.153971] sp : ffff00001a66b990
[ 67.157372] x29: ffff00001a66b990 x28: 0000000000000000
[ 67.162778] x27: 0000000000000002 x26: ffff0000096de000
[ 67.168183] x25: 0000000000000000 x24: 0000000000000000
[ 67.173589] x23: 0000000000000200 x22: ffff00001a66ba4c
[ 67.178994] x21: ffff80007ab83400 x20: ffff00001a66ba4c
[ 67.184400] x19: ffff80007aab0680 x18: 0000000000000001
[ 67.189805] x17: 0000ffff8d856160 x16: 0000000000000000
[ 67.195210] x15: 0000000000000010 x14: ffff80007ff6bd80
[ 67.200615] x13: 0000000000000004 x12: 0000000000000000
[ 67.206023] x11: 0000000000000001 x10: 0000000000000980
[ 67.211428] x9 : ffff00001a66b920 x8 : ffff8000761b4d60
[ 67.216833] x7 : 0000000000000004 x6 : 0000000000000000
[ 67.222238] x5 : 0000000000000000 x4 : 0000000000000000
[ 67.227644] x3 : ffff0000086db1b8 x2 : ffff0000086db100
[ 67.233047] x1 : 00000000000c0008 x0 : ffff00000d9c0008
[ 67.238454] Call trace:
[ 67.240987] Exception stack(0xffff00001a66b850 to 0xffff00001a66b990)
[ 67.247521] b840: ffff00000d9c0008 00000000000c0008
[ 67.255448] b860: ffff0000086db100 ffff0000086db1b8 0000000000000000 0000000000000000
[ 67.263373] b880: 0000000000000000 0000000000000004 ffff8000761b4d60 ffff00001a66b920
[ 67.271300] b8a0: 0000000000000980 0000000000000001 0000000000000000 0000000000000004
[ 67.279226] b8c0: ffff80007ff6bd80 0000000000000010 0000000000000000 0000ffff8d856160
[ 67.287152] b8e0: 0000000000000001 ffff80007aab0680 ffff00001a66ba4c ffff80007ab83400
[ 67.295079] b900: ffff00001a66ba4c 0000000000000200 0000000000000000 0000000000000000
[ 67.303005] b920: ffff0000096de000 0000000000000002 0000000000000000 ffff00001a66b990
[ 67.310932] b940: ffff0000086db1e4 ffff00001a66b990 ffff0000086db108 00000000000001c5
[ 67.318858] b960: ffff80007ab838f0 0000000000000000 0000ffffffffffff 0000000000000002
[ 67.326785] b980: ffff00001a66b990 ffff0000086db108
[ 67.331756] [<ffff0000086db108>] regmap_mmio_read32le+0x8/0x20
[ 67.337681] [<ffff0000086d4134>] _regmap_bus_reg_read+0x14/0x20
[ 67.343693] [<ffff0000086d5a40>] _regmap_read+0x60/0xe0
[ 67.349011] [<ffff0000086d5e34>] _regmap_update_bits+0x9c/0xe8
[ 67.354937] [<ffff0000086d6e58>] regmap_update_bits_base+0x60/0x90
[ 67.361214] [<ffff0000084de284>] pci_imx_suspend_noirq+0x1dc/0x270
[ 67.367490] [<ffff0000086c0f30>] pm_generic_suspend_noirq+0x28/0x40
[ 67.373853] [<ffff0000086ce250>] genpd_finish_suspend+0xd0/0xf8
[ 67.379865] [<ffff0000086ce2a0>] pm_genpd_suspend_noirq+0x10/0x18
[ 67.386052] [<ffff0000086c5670>] dpm_run_callback.isra.7+0x40/0xa0
[ 67.392326] [<ffff0000086c5ca8>] __device_suspend_noirq+0xb0/0x148
[ 67.398598] [<ffff0000086c6f78>] dpm_noirq_suspend_devices+0x100/0x200
[ 67.405220] [<ffff0000086c709c>] dpm_suspend_noirq+0x24/0x60
[ 67.410975] [<ffff0000081122ec>] suspend_devices_and_enter+0x144/0x560
[ 67.417595] [<ffff000008112a14>] pm_suspend+0x30c/0x354
[ 67.422913] [<ffff0000081114d8>] state_store+0x88/0xf8
[ 67.428146] [<ffff000008d5c92c>] kobj_attr_store+0x14/0x28
[ 67.433727] [<ffff000008287b90>] sysfs_kf_write+0x40/0x58
[ 67.439219] [<ffff000008286e54>] kernfs_fop_write+0xcc/0x1e0
[ 67.444975] [<ffff00000820b1e8>] __vfs_write+0x18/0x118
[ 67.450292] [<ffff00000820b4d4>] vfs_write+0xa4/0x1a8
[ 67.455438] [<ffff00000820b77c>] SyS_write+0x44/0xa0
[ 67.460492] Exception stack(0xffff00001a66bec0 to 0xffff00001a66c000)
[ 67.467028] bec0: 0000000000000001 0000aaaacb49e7d0 0000000000000004 0000ffffb585cf68
[ 67.474953] bee0: 0000000000000000 5551000454000000 0000000000000003 000000000000006d
[ 67.482883] bf00: 0000000000000040 0000000000000001 0000ffffc12f3c30 0000000000000000
[ 67.490808] bf20: 0000000000000000 0000000000000018 0000000000000001 0000000000000008
[ 67.498736] bf40: 0000aaaab6c698e8 0000ffffb575c540 0000000000000fff 0000000000000001
[ 67.506663] bf60: 0000aaaacb49e7d0 0000ffffb5859588 0000000000000004 0000aaaacb49e7d0
[ 67.514591] bf80: 0000000000000004 0000ffffb5859670 0000aaaab6c32000 0000000000000000
[ 67.522519] bfa0: 0000aaaab6c6a000 0000ffffc12f3c70 0000ffffb575f930 0000ffffc12f3c70
[ 67.530444] bfc0: 0000ffffb57b13dc 0000000020000000 0000000000000001 0000000000000040
[ 67.538371] bfe0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 67.546300] [<ffff000008083b18>] __sys_trace_return+0x0/0x4
[ 67.551968] Code: b5000001 d65f03c0 f9400000 8b214000 (b9400000)
[ 67.558157] ---[ end trace 72215c33ce658969 ]---
Using runtime PM across suspend/resume fixes this crash.
Still need to convert all clock work into runtime PM carefully.
Adding epdev_on-supply leads a crash of pcie driver on system suspend.
Warn customers about it.
This commit makes sure to use low-drive mode on all sd pins as
suggested by our hardware team.
Commit f014b5b3b3ab added an additional clock to ahci_imx.c used
on i.MX8. Add a dummy clock to imx6q.dtsi so that i.MX6 which doesn't
need the clock the driver keeps working.
Fixes:
[ 2.053942] ahci-imx 2200000.sata: can't get sata_ext clock.
[ 2.053962] ahci-imx: probe of 2200000.sata failed with error -2
Fixes: commit: 5d2a26667010640e33ca0a52c73310f158179711
This commit unifys the backlight settings. All displays sold by Toradex
are now supporting 150Hz as a PWM backlight typical frequency.
Use this value for all SoM's and put also some better default values
for different brightness.
This commit adds a 3rd pwm paramter that can be used for PWM polarity
inversion with dt-bindings/pwm/pwm.h PWM_POLARITY_INVERTED
sgtl5000 goes to fail state after suspend system:
[ 60.308603] sgtl5000 16-000a: ASoC: Failed to turn on bias: -5
[ 60.309264] sgtl5000 16-000a: Unable to sync registers 0x2-0x6. -5
To fix it, mclk is forced to reenable on system resume.
i.MX8QM/i.MX8QXP clock enabling/disabling callbacks are non-atomic,
so we can't use them in interrupt/atomic context.
According to manual of I2C bus, both signals sda/scl are "open drain".
Fix flags for all affected Toradex boards.
This fixes the following error during boot:
[ 1.588204] fsl_lpspi 5a020000.lpspi: chipselect 0 already in use
[ 1.594461] spi_master spi0: spi_device register error
/lpspi@5a020000/spidev@0
[ 1.601850] spi_master spi0: Failed to create SPI device for
This fixes the following systemd error during boot:
[ 4.225226] systemd[1]: File /lib/systemd/system/systemd-journald.
service:36 configures an IP firewall (IPAddressDeny=any), but the local
system does not support BPF/cgroup based firewalling.
[ 4.242360] systemd[1]: Proceeding WITHOUT firewalling in effect!
(This warning is only shown for the first loaded unit using IP
firewalling.)
scl-gpios should be (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN) since
commit d2d0ad2aec4a ("i2c: imx: use open drain for recovery GPIO")
Fix on-boot warning:
"enforced open drain please flag it properly in DT/ACPI DSDT/board file"
Disable CAAM SM Test which is a Keystore Test/Example meant for
development. This gets rid of lots of messages in the kernel log.
Enable deprecated/obsolete ARMv8 instructions emulation. This allows
to run ARMv6 binaries (e.g. Raspberry Pi) on ARMv8 machines.
The driver got converted to a I2C device, DDC/EDID and HPD handling is added.
Also delete the no longer needed hardcoded timings.
While at it remove commented out fragments.
While at it remove double execution of MIPI RX soft reset.
If the ddc-i2c-bus property exists, that bus is used to read EDID from an
attached monitor and set the list of available modes.
Commit "680eee23d001 imx-hdp.c: fix default resolution" changed the default
resolution to 1080p.
The same mode timings were used to detect a 4k mode and then reconfigure for
HDMI2.0 SCDC. Rework the code to correctly detect a 4k mode.
- Remove Lontium V1.0 board settings
- Disable RGB display
- Add eval.dtsi
And remove unnecessary enabled hardware
This commit only creates fsl-imx8qxp-colibri-eval-v3.dtsi and moves
code.
It does not change code.
This commit hooks the panel directly onto adma_lcdif and leaves out
lcd_display as it is not compatible with mxsfb-drm.
Move display and camera related enables out of SoM level into carrier
board level.
Those settings belong to carrier board as only the carrier board knows
wich connectors it has and therefore what it needs enabled.
This commit adds proper sleep state muxing, needed for carrier boards
that have a vmmc switch in there so we can prevent backfeeding.
Disabling write protection as this pin is not routed.
Remove ext_io from pinmuxing of the extcon_usbc_det. It is not used
and actually misleading.
And give the SoM level its naming.
This patch also puts some comments.
