2007-02-11[PATCH] scrub non-__GLIBC__ checks in linux/socket.h and linux/stat.hMike Frysinger
Userspace should be worrying about userspace, so having the socket.h and stat.h pollute the namespace in the non-glibc case is wrong and pretty much prevents any other libc from utilizing these headers sanely unless they set up the __GLIBC__ define themselves (which sucks) Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] consolidate line discipline number definitionsTilman Schmidt
The line discipline numbers N_* are currently defined for each architecture individually, but (except for a seeming mistake) identically, in asm/termios.h. There is no obvious reason why these numbers should be architecture specific, nor any apparent relationship with the termios structure. The total number of these, NR_LDISCS, is defined in linux/tty.h anyway. So I propose the following patch which moves the definitions of the individual line disciplines to linux/tty.h too. Three of these numbers (N_MASC, N_PROFIBUS_FDL, and N_SMSBLOCK) are unused in the current kernel, but the patch still keeps the complete set in case there are plans to use them yet. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] igrab() should check for I_CLEARJan Blunck
When igrab() is calling __iget() on an inode it should check if clear_inode() has been called on the inode already. Otherwise there is a race window between clear_inode() and destroy_inode() where igrab() calls __iget() which leads to already free inodes on the inode lists. Signed-off-by: Vandana Rungta <vandana@novell.com> Signed-off-by: Jan Blunck <jblunck@suse.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] lockdep: add graph depth information to /proc/lockdepJason Baron
Generate locking graph information into /proc/lockdep, for lock hierarchy documentation and visualization purposes. sample output: c089fd5c OPS: 138 FD: 14 BD: 1 --..: &tty->termios_mutex -> [c07a3430] tty_ldisc_lock -> [c07a37f0] &port_lock_key -> [c07afdc0] &rq->rq_lock_key#2 The lock classes listed are all the first-hop lock dependencies that lockdep has seen so far. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] lockdep: more unlock-on-error fixesJarek Poplawski
- returns after DEBUG_LOCKS_WARN_ON added in 3 places - debug_locks checking after lookup_chain_cache() added in __lock_acquire() - locking for testing and changing global variable max_lockdep_depth added in __lock_acquire() From: Ingo Molnar <mingo@elte.hu> My __acquire_lock() cleanup introduced a locking bug: on SMP systems we'd release a non-owned graph lock. Fix this by moving the graph unlock back, and by leaving the max_lockdep_depth variable update possibly racy. (we dont care, it's just statistics) Also add some minimal debugging code to graph_unlock()/graph_lock(), which caught this locking bug. Signed-off-by: Jarek Poplawski <jarkao2@o2.pl> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] lockdep: also check for freed locks in kmem_cache_free()Ingo Molnar
kmem_cache_free() was missing the check for freeing held locks. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] kill_pid_info: kill acquired_tasklist_lockOleg Nesterov
Kill acquired_tasklist_lock, sig_needs_tasklist() is very cheap nowadays. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Char: tty_wakeup cleanupJiri Slaby
tty_wakeup cleanup - remove wake_up_interruptible(&tty->write_wait) surrounding tty_wakup(tty); - substitute tty->ldisc.write_wakeup(tty) + wake_up() by tty_wakeup(tty); Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Char: isicom, correct probing/removingJiri Slaby
Don't forget to decrease card_count in fail paths and in remove function. Also null board->base in such cases to point out, that this structure is unused and thus can be reassigned. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Char: isicom, support higher ratesJiri Slaby
Add support for higher baud rates (coming from original isi driver). Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Char: isicom, check card state in isrJiri Slaby
Check if the card really interrupted us by reading its IO space and eventualy return IRQ_NONE. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Char: isicom, augment card_resetJiri Slaby
isicom, augment card_reset - add 0xee to signatures - change long delays to sleeps - make one sleep shorter not to wait 3s - portcount == 16 is also correct Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Char: isicom, fix locking in isrJiri Slaby
2 spin_unlocks are omitted in the interrupt handler. Put them there to fix up deadlocking on UP. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] make drivers/char/mxser_new.c:mxser_hangup() staticAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] mxser: remove ambiguous redefinition of INIT_WORKAndreas Jaggi
Removes an unused and ambiguous redefinition of INIT_WORK() Signed-off-by: Andreas Jaggi <andreas.jaggi@waterwave.ch> Acked-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] avoid one conditional branch in touch_atime()Eric Dumazet
I added IS_NOATIME(inode) macro definition in include/linux/fs.h, true if the inode superblock is marked readonly or noatime. This new macro is then used in touch_atime() instead of separatly testing MS_RDONLY and MS_NOATIME Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] struct vfsmount: keep mnt_count & mnt_expiry_mark away from mnt_flagsEric Dumazet
I noticed cache misses in touch_atime() that can be avoided if we keep mnt_count & mnt_expiry_mark in a different cache line than mnt_flags (mostly read) mnt_count & mnt_expiry_mark are modified each time a file is opened/closed in a file system. touch_atime() is called each time a file is read, and generally needs to read mnt_flags. Other fields of struct vfsmount are mostly read so I chose to move mnt_count & mnt_expiry_mark at the end of struct vfsmount. And adding a comment so that nobody tries to re-arrange fields to fill the holes :) On 64bits platforms, the new offsetof(mnt_count) is 0xC0 On 32bits platforms, it is 0x60, so I didnot add a ____cacheline_aligned_in_smp because it would have a too big impact on the size of this object (in particular if CONFIG_X86_L1_CACHE_SHIFT=7) Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Char: isicom, remove tty_{hang,wake}up bottomhalvesJiri Slaby
- tty_hangup() itself schedules work, so there is no need to schedule hangup in the driver - tty_wakeup(): it's safe to call it while in atomic, so that its schedule_work might be also wiped out Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] IOC3/IOC4: PCI mem space resourcesBrent Casavant
The SGI IOC3 and IOC4 PCI devices implement memory space apertures, not I/O space apertures. Use the appropriate region management functions. Signed-off-by: Brent Casavant <bcasavan@sgi.com> Cc: Pat Gefre <pfg@sgi.com> Cc: Stanislaw Skowronek <skylark@linux-mips.org> Cc: Brent Casavant <bcasavan@sgi.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] usr/gen_init_cpio.c: support for hard linksLuciano Rocha
Extend usr/gen_init_cpio.c "file" entry, adding support for hard links. Previous format: file <name> <location> <mode> <uid> <gid> New format: file <name> <location> <mode> <uid> <gid> [<hard links>] The hard links specification is optional, keeping the previous behaviour. All hard links are defined sequentially in the resulting cpio and the file data is present only in the last link. This is the behaviour of GNU's cpio and is supported by the kernel initramfs extractor. Signed-off-by: Luciano Rocha <strange@nsk.no-ip.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] disable init/initramfs.c: architecturesJean-Paul Saman
Update all arch/*/kernel/vmlinux.lds.S to not include space for initramfs when CONFIG_BLK_DEV_INITRAMFS is not selected. This saves another 4 kbytes on most platfoms (some reserve PAGE_SIZE for initramfs). Signed-off-by: Jean-Paul Saman <jean-paul.saman@nxp.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] disable init/initramfs.cJean-Paul Saman
The file init/initramfs.c is always compiled and linked in the kernel vmlinux even when BLK_DEV_RAM and BLK_DEV_INITRD are disabled and the system isn't using any form of an initramfs or initrd. In this situation the code is only used to unpack a (static) default initial rootfilesystem. The current init/initramfs.c code. usr/initramfs_data.o compiles to a size of ~15 kbytes. Disabling BLK_DEV_RAM and BLK_DEV_INTRD shrinks the kernel code size with ~60 Kbytes. This patch avoids compiling in the code and data for initramfs support if CONFIG_BLK_DEV_INITRD is not defined. Instead of the initramfs code and data it uses a small routine in init/noinitramfs.c to setup an initial static default environment for mounting a rootfilesystem later on in the kernel initialisation process. The new code is: 164 bytes of size. The patch is separated in two parts: 1) doesn't compile initramfs code when CONFIG_BLK_DEV_INITRD is not set 2) changing all plaforms vmlinux.lds.S files to not reserve an area of PAGE_SIZE when CONFIG_BLK_DEV_INITRD is not set. [deweerdt@free.fr: warning fix] Signed-off-by: Jean-Paul Saman <jean-paul.saman@nxp.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Frederik Deweerdt <frederik.deweerdt@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Char: tty, delete wake_up_interruptible after tty_wakeupJiri Slaby
tty_wakeup calls wake_up_interruptible(&tty->write_wait) itself, it's not needed to wake up again after tty_wakeup returns. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] count_vm_events-warning-fixAndrew Morton
- Prevent things like this: block/ll_rw_blk.c: In function 'submit_bio': block/ll_rw_blk.c:3222: warning: unused variable 'count' inlines are very, very preferable to macros. - remove unused get_cpu_vm_events() macro Cc: Christoph Lameter <clameter@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] remove include/linux/byteorder/pdp_endian.hAdrian Bunk
include/linux/byteorder/pdp_endian.h is completely unused, and the comment in the file itself states that it's both untested and only a proof-of-concept. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] sysctl_{,ms_}jiffies: fix oldlen semanticsAlexey Dobriyan
currently it's 1) if *oldlenp == 0, don't writeback anything 2) if *oldlenp >= table->maxlen, don't writeback more than table->maxlen bytes and rewrite *oldlenp don't look at underlying type granularity 3) if 0 < *oldlenp < table->maxlen, *cough* string sysctls don't writeback more than *oldlenp bytes. OK, that's because sizeof(char) == 1 int sysctls writeback anything in (0, table->maxlen] range Though accept integers divisible by sizeof(int) for writing. sysctl_jiffies and sysctl_ms_jiffies don't writeback anything but sizeof(int), which violates 1) and 2). So, make sysctl_jiffies and sysctl_ms_jiffies accept a) *oldlenp == 0, not doing writeback b) *oldlenp >= sizeof(int), writing one integer. -EINVAL still returned for *oldlenp == 1, 2, 3. Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] vt: refactor console SAK processingEric W. Biederman
This does several things. - It moves looking up of the current foreground console into process context where we can safely take the semaphore that protects this operation. - It uses the new flavor of work queue processing. - This generates a factor of do_SAK, __do_SAK that runs immediately. - This calls __do_SAK with the console semaphore held ensuring nothing else happens to the console while we process the SAK operation. - With the console SAK processing moved into process context this patch removes the xchg operations that I used to attempt to attomically update struct pid, because of the strange locking used in the SAK processing. With SAK using the normal console semaphore nothing special is needed. Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Add retain_initrd boot optionMichael Neuling
Add retain_initrd option to control freeing of initrd memory after extraction. By default, free memory as previously. The first boot will need to hold a copy of the in memory fs for the second boot. This image can be large (much larger than the kernel), hence we can save time when the memory loader is slow. Also, it reduces the memory footprint while extracting the first boot since you don't need another copy of the fs. Signed-off-by: Michael Neuling <mikey@neuling.org> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] drivers: add LCD supportMiguel Ojeda Sandonis
Add support for auxiliary displays, the ks0108 LCD controller, the cfag12864b LCD and adds a framebuffer device: cfag12864bfb. - Add a "auxdisplay/" folder in "drivers/" for auxiliary display drivers. - Add support for the ks0108 LCD Controller as a device driver. (uses parport interface) - Add support for the cfag12864b LCD as a device driver. (uses ks0108 LCD Controller driver) - Add a framebuffer device called cfag12864bfb. (uses cfag12864b LCD driver) - Add the usual Documentation, includes, Makefiles, Kconfigs, MAINTAINERS, CREDITS... - Miguel Ojeda will maintain all the stuff above. [rdunlap@xenotime.net: workqueue fixups] [akpm@osdl.org: kconfig fix] Signed-off-by: Miguel Ojeda Sandonis <maxextreme@gmail.com> Cc: Greg KH <greg@kroah.com> Acked-by: Paulo Marques <pmarques@grupopie.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] V850: user ARRAY_SIZE macro when appropriateAhmed S. Darwish
Use ARRAY_SIZE macro already defined in linux/kernel.h Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: x86_64 ptrace fixesJeff Dike
This patch fixes some missing ptrace bits on x86_64. PTRACE_ARCH_PRCTL is hooked up and implemented. This required generalizing arch_prctl_skas slightly to take a task_struct to modify. Previously, it always operated on current. Reading and writing the debug registers is also enabled by un-ifdefing the code that implements that. It turns out that x86_64 is identical to i386, so the same code can be used. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: x86_64 thread fixesJeff Dike
x86_64 needs some TLS fixes. What was missing was remembering the child thread id during clone and stuffing it into the child during each context switch. The %fs value is stored separately in the thread structure since the host controls what effect it has on the actual register file. The host also needs to store it in its own thread struct, so we need the value kept outside the register file. arch_prctl_skas was fixed to call PTRACE_ARCH_PRCTL appropriately. There is some saving and restoring of registers in the ARCH_SET_* cases so that the correct set of registers are changed on the host and restored to the process when it runs again. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: fix error output during early bootJeff Dike
The startup code panics a lot if anything goes wrong early on. This is wrong for several reasons, like the kernel isn't running, so you can't really be calling into it yet, but the harm comes from useful error messages being trapped in the printk ring where no one will ever see them. This patch changes these panics to perror and printf in wrappers which also exit. Normal, informational, prints are also wrapped so that fflush(stdout) is called after each one. This is so the output appears in the correct sequence in the event of an error. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: AIO locking and tidyingJeff Dike
Comment the lack of locking of data that's set up once at boot time. Also fixed a couple of bogus printks. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: register handling formatting fixesJeff Dike
Formatting fixes in the register handling code. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: ELF locking commentaryJeff Dike
Comment the lack of locking of the elf data extracted from the ELF headers passed to UML. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: umid tidyingJeff Dike
Add an error message when two umids are put on the command line. umid.h is kind of pointless since it only declares one thing, and that is already declared in os.h. Commented the lack of locking of some data in os-Linux/umid.h. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: SIGIO formatting fixesJeff Dike
Fix formatting in the sigio code. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: SIGIO locking commentJeff Dike
Comment the use of a mysterious-looking lock. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: IRQ handler tidyingJeff Dike
Tidying the irq code - make a variable static activate_fd can call kmalloc directly since it's now kernel code added a no-locking comment fixed a style violation Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: fix apparent "CONFIG_64_BIT" typo.Robert P. J. Day
Fix apparent typo, where CONFIG_64_BIT should read CONFIG_64BIT. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: fix style violationsJeff Dike
Fix a bunch of style violations in mem.c. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: libc-dependent code should call libc directlyJeff Dike
We shouldn't be using the os wrappers from os code - we can use libc directly. This patch replaces wrapper calls with libc calls. It turns out that os_sigio_async had only one caller, which was in startup.c, so that function is moved there and its name changed. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: style fixes in startup codeJeff Dike
Some style fixes in startup.c. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: locking comments in startup codeJeff Dike
Add a couple of comments about some non-locked data. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: locking comments in memory and tempfile codeJeff Dike
Locking comments and emacs comment removal in the low-level memory and temp file code. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: locking fixes in the ubd driverJeff Dike
Some small locking and formatting fixes in the ubd driver. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: add per-device queues and locks to ubd driverJeff Dike
Replace global queue and lock with per-device queues and locks. Mostly a straightforward replacement of ubd_io_lock with dev->lock and ubd_queue with dev->queue. Complications - There was no way to get a request struct (and queue) from the structure sent to the io_thread, so a pointer to the request was added. This is needed in ubd_handler in order to kick do_ubd_request to process another request. Queue initialization is moved from ubd_init to ubd_add. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: remove code controlled by non-existent config optionJeff Dike
CONFIG_HOST_TASK_SIZE doesn't exist any more. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: const a variableJeff Dike
kstack_depth_to_print can be made const. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
