2009-09-14net: constify struct inet6_protocolAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-14net: constify struct net_protocolAlexey Dobriyan
Remove long removed "inet_protocol_base" declaration. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-14netdev: smc91x: drop Blackfin cruftMichael Hennerich
Now that all Blackfin boards are using the board resources, we don't need to keep the arch/board specific crap in the driver header. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-14net-next-2.6 [PATCH 1/1] dccp: ccids whitespace-cleanup / CodingStyleGerrit Renker
No code change, cosmetical changes only: * whitespace cleanup via scripts/cleanfile, * remove self-references to filename at top of files, * fix coding style (extraneous brackets), * fix documentation style (kernel-doc-nano-HOWTO). Thanks are due to Ivo Augusto Calado who raised these issues by submitting good-quality patches. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-14genetlink: fix netns vs. netlink table lockingJohannes Berg
Since my commits introducing netns awareness into genetlink we can get this problem: BUG: scheduling while atomic: modprobe/1178/0x00000002 2 locks held by modprobe/1178: #0: (genl_mutex){+.+.+.}, at: [<ffffffff8135ee1a>] genl_register_mc_grou #1: (rcu_read_lock){.+.+..}, at: [<ffffffff8135eeb5>] genl_register_mc_g Pid: 1178, comm: modprobe Not tainted 2.6.31-rc8-wl-34789-g95cb731-dirty # Call Trace: [<ffffffff8103e285>] __schedule_bug+0x85/0x90 [<ffffffff81403138>] schedule+0x108/0x588 [<ffffffff8135b131>] netlink_table_grab+0xa1/0xf0 [<ffffffff8135c3a7>] netlink_change_ngroups+0x47/0x100 [<ffffffff8135ef0f>] genl_register_mc_group+0x12f/0x290 because I overlooked that netlink_table_grab() will schedule, thinking it was just the rwlock. However, in the contention case, that isn't actually true. Fix this by letting the code grab the netlink table lock first and then the RCU for netns protection. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-14Have atalk_route_packet() return NET_RX_SUCCESS not NET_XMIT_SUCCESSMark Smith
Have atalk_route_packet() return NET_RX_SUCCESS not NET_XMIT_SUCCESS atalk_route_packet() returns NET_RX_DROP if it's call to aarp_send_ddp() returns NET_XMIT_DROP. If aarp_send_ddp() returns anything else atalk_route_packet() should return NET_RX_SUCCESS, not NET_XMIT_SUCCESS. Signed-off-by: Mark Smith <markzzzsmith@yahoo.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-14Merge branch 'osync_cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'osync_cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: fsync: wait for data writeout completion before calling ->fsync vfs: Remove generic_osync_inode() and sync_page_range{_nolock}() fat: Opencode sync_page_range_nolock() pohmelfs: Use new syncing helper xfs: Convert sync_page_range() to simple filemap_write_and_wait_range() ocfs2: Update syncing after splicing to match generic version ntfs: Use new syncing helpers and update comments ext4: Remove syncing logic from ext4_file_write ext3: Remove syncing logic from ext3_file_write ext2: Update comment about generic_osync_inode vfs: Introduce new helpers for syncing after writing to O_SYNC file or IS_SYNC inode vfs: Rename generic_file_aio_write_nolock ocfs2: Use __generic_file_aio_write instead of generic_file_aio_write_nolock pohmelfs: Use __generic_file_aio_write instead of generic_file_aio_write_nolock vfs: Remove syncing from generic_file_direct_write() and generic_file_buffered_write() vfs: Export __generic_file_aio_write() and add some comments vfs: Introduce filemap_fdatawait_range
2009-09-14Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-nmw * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-nmw: GFS2: Whitespace fixes GFS2: Remove unused sysfs file GFS2: Be extra careful about deallocating inodes GFS2: Remove no_formal_ino generating code GFS2: Rename eattr.[ch] as xattr.[ch] GFS2: Clean up of extended attribute support GFS2: Add explanation of extended attr on-disk format GFS2: Add "-o errors=panic|withdraw" mount options GFS2: jumping to wrong label? GFS2: free disk inode which is deleted by remote node -V2 GFS2: Add a document explaining GFS2's uevents GFS2: Add sysfs link to device GFS2: Replace assertion with proper error handling GFS2: Improve error handling in inode allocation GFS2: Add some more info to uevents GFS2: Add online uevent to GFS2
2009-09-14Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-udf-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-udf-2.6: udf: Fix possible corruption when close races with write udf: Perform preallocation only for regular files udf: Remove wrong assignment in udf_symlink udf: Remove dead code
2009-09-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2: (21 commits) fs/Kconfig: move nilfs2 outside misc filesystems nilfs2: convert nilfs_bmap_lookup to an inline function nilfs2: allow btree code to directly call dat operations nilfs2: add update functions of virtual block address to dat nilfs2: remove individual gfp constants for each metadata file nilfs2: stop zero-fill of btree path just before free it nilfs2: remove unused btree argument from btree functions nilfs2: remove nilfs_dat_abort_start and nilfs_dat_abort_free nilfs2: shorten freeze period due to GC in write operation v3 nilfs2: add more check routines in mount process nilfs2: An unassigned variable is assigned to a never used structure member nilfs2: use GFP_NOIO for bio_alloc instead of GFP_NOWAIT nilfs2: stop using periodic write_super callback nilfs2: clean up nilfs_write_super nilfs2: fix disorder of nilfs_write_super in nilfs_sync_fs nilfs2: remove redundant super block commit nilfs2: implement nilfs_show_options to display mount options in /proc/mounts nilfs2: always lookup disk block address before reading metadata block nilfs2: use semaphore to protect pointer to a writable FS-instance nilfs2: fix format string compile warning (ino_t) ...
2009-09-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: cifs: consolidate reconnect logic in smb_init routines cifs: Replace wrtPending with a real reference count cifs: protect GlobalOplock_Q with its own spinlock cifs: use tcon pointer in cifs_show_options cifs: send IPv6 addr in upcall with colon delimiters [CIFS] Fix checkpatch warnings PATCH] cifs: fix broken mounts when a SSH tunnel is used (try #4) [CIFS] Memory leak in ntlmv2 hash calculation [CIFS] potential NULL dereference in parse_DFS_referrals()
2009-09-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-next-2.6: (21 commits) sparc64: Initial niagara2 perf counter support. sparc64: Perf counter 'nop' event is not constant. sparc64: Provide a way to specify a perf counter overflow IRQ enable bit. sparc64: Provide hypervisor tracing bit support for perf counters. sparc64: Initial hw perf counter support. sparc64: Implement a real set_perf_counter_pending(). sparc64: Use nmi_enter() and nmi_exit(), as needed. sparc64: Provide extern decls for sparc_??u_type strings. sparc64: Make touch_nmi_watchdog() actually work. sparc64: Kill unnecessary cast in profile_timer_exceptions_notify(). sparc64: Manage NMI watchdog enabling like x86. sparc: add basic support for 'perf' sparc: convert /proc/io_map, /proc/dvma_map to seq_file sparc, leon: sparc-leon specific SRMMU initialization and bootup fixes. sparc,leon: Added support for AMBAPP bus. sparc,leon: Introduce the sparc-leon CPU type. sparc,leon: Redefine MMU register access asi if CONFIG_LEON sparc,leon: CONFIG_SPARC_LEON option and leon specific files. sparc64: cheaper asm/uaccess.h inclusion SPARC: fix duplicate declaration ...
2009-09-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1623 commits) netxen: update copyright netxen: fix tx timeout recovery netxen: fix file firmware leak netxen: improve pci memory access netxen: change firmware write size tg3: Fix return ring size breakage netxen: build fix for INET=n cdc-phonet: autoconfigure Phonet address Phonet: back-end for autoconfigured addresses Phonet: fix netlink address dump error handling ipv6: Add IFA_F_DADFAILED flag net: Add DEVTYPE support for Ethernet based devices mv643xx_eth.c: remove unused txq_set_wrr() ucc_geth: Fix hangs after switching from full to half duplex ucc_geth: Rearrange some code to avoid forward declarations phy/marvell: Make non-aneg speed/duplex forcing work for 88E1111 PHYs drivers/net/phy: introduce missing kfree drivers/net/wan: introduce missing kfree net: force bridge module(s) to be GPL Subject: [PATCH] appletalk: Fix skb leak when ipddp interface is not loaded ... Fixed up trivial conflicts: - arch/x86/include/asm/socket.h converted to <asm-generic/socket.h> in the x86 tree. The generic header has the same new #define's, so that works out fine. - drivers/net/tun.c fix conflict between 89f56d1e9 ("tun: reuse struct sock fields") that switched over to using 'tun->socket.sk' instead of the redundantly available (and thus removed) 'tun->sk', and 2b980dbd ("lsm: Add hooks to the TUN driver") which added a new 'tun->sk' use. Noted in 'next' by Stephen Rothwell.
2009-09-14Merge branch 'x86-xen-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-xen-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: split __phys_addr out into separate file xen: use stronger barrier after unlocking lock xen: only enable interrupts while actually blocking for spinlock xen: make -fstack-protector work under Xen
2009-09-14udf: Fix possible corruption when close races with writeJan Kara
When we close a file, we remove preallocated blocks from it. But this truncation was not protected by i_mutex and thus it could have raced with a write through a different fd and cause crashes or even filesystem corruption. Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14udf: Perform preallocation only for regular filesJan Kara
So far we preallocated blocks also for directories but that brings a problem, when to get rid of preallocated blocks we don't need. So far we removed them in udf_clear_inode() which has a disadvantage that 1) blocks are unavailable long after writing to a directory finished and thus one can get out of space unnecessarily early 2) releasing blocks from udf_clear_inode is problematic because VFS does not expect us to redirty inode there and it also slows down memory reclaim. So preallocate blocks only for regular files where we can drop preallocation in udf_release_file. Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14udf: Remove wrong assignment in udf_symlinkJan Kara
Recomputation of the pointer was wrong (it should have been just increment). Luckily, we never use the computed value. Remove it. Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14udf: Remove dead codeJan Kara
Remove code that gets never used. Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14fsync: wait for data writeout completion before calling ->fsyncChristoph Hellwig
Currenly vfs_fsync(_range) first calls filemap_fdatawrite to write out the data, the calls into ->fsync to write out the metadata and then finally calls filemap_fdatawait to wait for the data I/O to complete. What sounds like a clever micro-optimization actually is nast trap for many filesystems. For many modern filesystems i_size or other inode information is only updated on I/O completion and we need to wait for I/O to finish before we can write out the metadata. For old fashionen filesystems that instanciate blocks during the actual write and also update the metadata at that point it opens up a large window were we could expose uninitialized blocks after a crash. While a few filesystems that need it already wait for the I/O to finish inside their ->fsync methods it is rather suboptimal as it is done under the i_mutex and also always for the whole file instead of just a part as we could do for O_SYNC handling. Here is a small audit of all fsync instances in the tree: - spufs_mfc_fsync: - ps3flash_fsync: - vol_cdev_fsync: - printer_fsync: - fb_deferred_io_fsync: - bad_file_fsync: - simple_sync_file: don't care - filesystems/drivers do't use the page cache or are purely in-memory. - simple_fsync: - file_fsync: - affs_file_fsync: - fat_file_fsync: - jfs_fsync: - ubifs_fsync: - reiserfs_dir_fsync: - reiserfs_sync_file: never touch pagecache themselves. We need to wait before if we do not want to expose stale data after an allocation. - afs_fsync: - fuse_fsync_common: do the waiting writeback itself in awkward ways, would benefit from proper semantics - block_fsync: Does a filemap_write_and_wait on the block device inode. Because we now have f_mapping that is the same inode we call it on in vfs_fsync. So just removing it and letting the VFS do the work in one go would be an improvement. - btrfs_sync_file: - cifs_fsync: - xfs_file_fsync: need the wait first and currently do it themselves. would benefit from doing it outside i_mutex. - coda_fsync: - ecryptfs_fsync: - exofs_file_fsync: - shm_fsync: only passes the fsync through to the lower layer - ext3_sync_file: doesn't seem to care, comments are confusing. - ext4_sync_file: would need the wait to work correctly for delalloc mode with late i_size updates. Otherwise the ext3 comment applies. currently implemens it's own writeback and wait in an odd way, could benefit from doing it properly. - gfs2_fsync: not needed for journaled data mode, but probably harmless there. Currently writes back data asynchronously itself. Needs some major audit. - hostfs_fsync: just calls fsync/datasync on the host FD. Without the wait before data might not even be inflight yet if we're unlucky. - hpfs_file_fsync: - ncp_fsync: no-ops. Dangerous before and after. - jffs2_fsync: just calls jffs2_flush_wbuf_gc, not sure how this relates to data. - nfs_fsync_dir: just increments stats, claims all directory operations are synchronous - nfs_file_fsync: only writes out data??? Looks very odd. - nilfs_sync_file: looks like it expects all data done, but not sure from the code - ntfs_dir_fsync: - ntfs_file_fsync: appear to do their own data writeback. Very convoluted code. - ocfs2_sync_file: does it's own data writeback, but no wait. probably needs the wait. - smb_fsync: according to a comment expects all pages written already, probably needs the wait before. This patch only changes vfs_fsync_range, removal of the wait in the methods that have it is left to the filesystem maintainers. Note that most filesystems really do need an audit for their fsync methods given the gems found in this very brief audit. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14vfs: Remove generic_osync_inode() and sync_page_range{_nolock}()Jan Kara
Remove these three functions since nobody uses them anymore. Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14fat: Opencode sync_page_range_nolock()Jan Kara
fat_cont_expand() is the only user of sync_page_range_nolock(). It's also the only user of generic_osync_inode() which does not have a file open. So opencode needed actions for FAT so that we can convert generic_osync_inode() to a standard syncing path. Update a comment about generic_osync_inode(). CC: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14pohmelfs: Use new syncing helperJan Kara
Use new generic_write_sync() helper instead of sync_page_range(). Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14xfs: Convert sync_page_range() to simple filemap_write_and_wait_range()Jan Kara
Christoph Hellwig says that it is enough for XFS to call filemap_write_and_wait_range() instead of sync_page_range() because we do all the metadata syncing when forcing the log. CC: Felix Blyakher <felixb@sgi.com> CC: xfs@oss.sgi.com CC: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14ocfs2: Update syncing after splicing to match generic versionJan Kara
Update ocfs2 specific splicing code to use generic syncing helper. The sync now does not happen under rw_lock because generic_write_sync() acquires i_mutex which ranks above rw_lock. That should not matter because standard fsync path does not hold it either. Acked-by: Joel Becker <Joel.Becker@oracle.com> Acked-by: Mark Fasheh <mfasheh@suse.com> CC: ocfs2-devel@oss.oracle.com Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14ntfs: Use new syncing helpers and update commentsJan Kara
Use new syncing helpers in .write and .aio_write functions. Also remove superfluous syncing in ntfs_file_buffered_write() and update comments about generic_osync_inode(). CC: Anton Altaparmakov <aia21@cantab.net> CC: linux-ntfs-dev@lists.sourceforge.net Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14ext4: Remove syncing logic from ext4_file_writeJan Kara
The syncing is now properly handled by generic_file_aio_write() so no special ext4 code is needed. CC: linux-ext4@vger.kernel.org CC: tytso@mit.edu Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14ext3: Remove syncing logic from ext3_file_writeJan Kara
Syncing is now properly done by generic_file_aio_write() so no special logic is needed in ext3. CC: linux-ext4@vger.kernel.org Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14ext2: Update comment about generic_osync_inodeJan Kara
We rely on generic_write_sync() now. CC: linux-ext4@vger.kernel.org Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14vfs: Introduce new helpers for syncing after writing to O_SYNC file or ↵Jan Kara
IS_SYNC inode Introduce new function for generic inode syncing (vfs_fsync_range) and use it from fsync() path. Introduce also new helper for syncing after a sync write (generic_write_sync) using the generic function. Use these new helpers for syncing from generic VFS functions. This makes O_SYNC writes to block devices acquire i_mutex for syncing. If we really care about this, we can make block_fsync() drop the i_mutex and reacquire it before it returns. CC: Evgeniy Polyakov <zbr@ioremap.net> CC: ocfs2-devel@oss.oracle.com CC: Joel Becker <joel.becker@oracle.com> CC: Felix Blyakher <felixb@sgi.com> CC: xfs@oss.sgi.com CC: Anton Altaparmakov <aia21@cantab.net> CC: linux-ntfs-dev@lists.sourceforge.net CC: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> CC: linux-ext4@vger.kernel.org CC: tytso@mit.edu Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14vfs: Rename generic_file_aio_write_nolockChristoph Hellwig
generic_file_aio_write_nolock() is now used only by block devices and raw character device. Filesystems should use __generic_file_aio_write() in case generic_file_aio_write() doesn't suit them. So rename the function to blkdev_aio_write() and move it to fs/blockdev.c. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14ocfs2: Use __generic_file_aio_write instead of generic_file_aio_write_nolockJan Kara
Use the new helper. We have to submit data pages ourselves in case of O_SYNC write because __generic_file_aio_write does not do it for us. OCFS2 developpers might think about moving the sync out of i_mutex which seems to be easily possible but that's out of scope of this patch. CC: ocfs2-devel@oss.oracle.com Acked-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14pohmelfs: Use __generic_file_aio_write instead of generic_file_aio_write_nolockJan Kara
Use new helper __generic_file_aio_write(). Since the fs takes care of syncing by itself afterwards, there are no more changes needed. CC: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14vfs: Remove syncing from generic_file_direct_write() and ↵Jan Kara
generic_file_buffered_write() generic_file_direct_write() and generic_file_buffered_write() called generic_osync_inode() if it was called on O_SYNC file or IS_SYNC inode. But this is superfluous since generic_file_aio_write() does the syncing as well. Also XFS and OCFS2 which call these functions directly handle syncing themselves. So let's have a single place where syncing happens: generic_file_aio_write(). We slightly change the behavior by syncing only the range of file to which the write happened for buffered writes but that should be all that is required. CC: ocfs2-devel@oss.oracle.com CC: Joel Becker <joel.becker@oracle.com> CC: Felix Blyakher <felixb@sgi.com> CC: xfs@oss.sgi.com Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14vfs: Export __generic_file_aio_write() and add some commentsJan Kara
Rename __generic_file_aio_write_nolock() to __generic_file_aio_write(), add comments to write helpers explaining how they should be used and export __generic_file_aio_write() since it will be used by some filesystems. CC: ocfs2-devel@oss.oracle.com CC: Joel Becker <joel.becker@oracle.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14vfs: Introduce filemap_fdatawait_rangeJan Kara
This simple helper saves some filesystems conversion from byte offset to page numbers and also makes the fdata* interface more complete. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14Merge branch 'x86-setup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-setup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, e820: Guard against array overflowed in __e820_add_region() x86, setup: remove obsolete pre-Kconfig CONFIG_VIDEO_ variables
2009-09-14Merge branch 'x86-percpu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-percpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, percpu: Collect hot percpu variables into one cacheline x86, percpu: Fix DECLARE/DEFINE_PER_CPU_PAGE_ALIGNED() x86, percpu: Add 'percpu_read_stable()' interface for cacheable accesses
2009-09-14Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, highmem_32.c: Clean up comment x86, pgtable.h: Clean up types x86: Clean up dump_pagetable()
2009-09-14Merge branch 'x86-kbuild-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-kbuild-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Simplify the Makefile in a minor way through use of cc-ifversion
2009-09-14Merge branch 'x86-fpu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86-64: move clts into batch cpu state updates when preloading fpu x86-64: move unlazy_fpu() into lazy cpu state part of context switch x86-32: make sure clts is batched during context switch x86: split out core __math_state_restore
2009-09-14Merge branch 'x86-debug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Decrease the level of some NUMA messages to KERN_DEBUG
2009-09-14Merge branch 'x86-cpu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (22 commits) x86: Fix code patching for paravirt-alternatives on 486 x86, msr: change msr-reg.o to obj-y, and export its symbols x86: Use hard_smp_processor_id() to get apic id for AMD K8 cpus x86, sched: Workaround broken sched domain creation for AMD Magny-Cours x86, mcheck: Use correct cpumask for shared bank4 x86, cacheinfo: Fixup L3 cache information for AMD multi-node processors x86: Fix CPU llc_shared_map information for AMD Magny-Cours x86, msr: Fix msr-reg.S compilation with gas 2.16.1, on 32-bit too x86: Move kernel_fpu_using to irq_fpu_usable in asm/i387.h x86, msr: fix msr-reg.S compilation with gas 2.16.1 x86, msr: Export the register-setting MSR functions via /dev/*/msr x86, msr: Create _on_cpu helpers for {rw,wr}msr_safe_regs() x86, msr: Have the _safe MSR functions return -EIO, not -EFAULT x86, msr: CFI annotations, cleanups for msr-reg.S x86, asm: Make _ASM_EXTABLE() usable from assembly code x86, asm: Add 32-bit versions of the combined CFI macros x86, AMD: Disable wrongly set X86_FEATURE_LAHF_LM CPUID bit x86, msr: Rewrite AMD rd/wrmsr variants x86, msr: Add rd/wrmsr interfaces with preset registers x86: add specific support for Intel Atom architecture ...
2009-09-14Merge branch 'x86-cleanups-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Make memtype_seq_ops const x86: uv: Clean up uv_ptc_init(), use proc_create() x86: Use printk_once() x86/cpu: Clean up various files a bit x86: Remove duplicated #include x86, ipi: Clean up safe_smp_processor_id() by using the cpu_has_apic() macro helper x86: Clean up idt_descr and idt_tableby using NR_VECTORS instead of hardcoded number x86: Further clean up of mtrr/generic.c x86: Clean up mtrr/main.c x86: Clean up mtrr/state.c x86: Clean up mtrr/mtrr.h x86: Clean up mtrr/if.c x86: Clean up mtrr/generic.c x86: Clean up mtrr/cyrix.c x86: Clean up mtrr/cleanup.c x86: Clean up mtrr/centaur.c x86: Clean up mtrr/amd.c: x86: ds.c fix invalid assignment
2009-09-14Merge branch 'x86-asm-generic-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-asm-generic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: remove all now-duplicate header files x86: convert termios.h to the asm-generic version x86: convert almost generic headers to asm-generic version x86: convert trivial headers to asm-generic version x86: add copies of some headers to convert to asm-generic
2009-09-14Merge branch 'x86-asm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86/i386: Put aligned stack-canary in percpu shared_aligned section x86/i386: Make sure stack-protector segment base is cache aligned x86: Detect stack protector for i386 builds on x86_64 x86: allow "=rm" in native_save_fl() x86: properly annotate alternatives.c x86: Introduce GDT_ENTRY_INIT(), initialize bad_bios_desc statically x86, 32-bit: Use generic sys_pipe() x86: Introduce GDT_ENTRY_INIT(), fix APM x86: Introduce GDT_ENTRY_INIT() x86: Introduce set_desc_base() and set_desc_limit() x86: Remove unused patch_espfix_desc() x86: Use get_desc_base()
2009-09-14Merge branch 'x86-apic-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-apic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (24 commits) ACPI, x86: expose some IO-APIC routines when CONFIG_ACPI=n x86, apic: Slim down stack usage in early_init_lapic_mapping() x86, ioapic: Get rid of needless check and simplify ioapic_setup_resources() x86, ioapic: Define IO_APIC_DEFAULT_PHYS_BASE constant x86: Fix x86_model test in es7000_apic_is_cluster() x86, apic: Move dmar_table_init() out of enable_IR() x86, ioapic: Panic on irq-pin binding only if needed x86/apic: Enable x2APIC without interrupt remapping under KVM x86, apic: Drop redundant bit assignment x86, ioapic: Throw BUG instead of NULL dereference x86, ioapic: Introduce for_each_irq_pin() helper x86: Remove superfluous NULL pointer check in destroy_irq() x86/ioapic.c: unify ioapic_retrigger_irq() x86/ioapic.c: convert __target_IO_APIC_irq to conventional for() loop x86/ioapic.c: clean up replace_pin_at_irq_node logic and comments x86/ioapic.c: convert replace_pin_at_irq_node to conventional for() loop x86/ioapic.c: simplify add_pin_to_irq_node() x86/ioapic.c: convert io_apic_level_ack_pending loop to normal for() loop x86/ioapic.c: move lost comment to what seems like appropriate place x86/ioapic.c: remove redundant declaration of irq_pin_list ...
2009-09-14fs/Kconfig: move nilfs2 outside misc filesystemsRyusuke Konishi
Some people asked me questions like the following: On Wed, 15 Jul 2009 13:11:21 +0200, Leon Woestenberg wrote: > just wondering, any reasons why NILFS2 is one of the miscellaneous > filesystems and, for example, btrfs, is not in Kconfig? Actually, nilfs is NOT a filesystem came from other operating systems, but a filesystem created purely for Linux. Nor is it a flash filesystem but that for generic block devices. So, this moves nilfs outside the misc category as I responded in LKML "Re: Why does NILFS2 hide under Miscellaneous filesystems?" (Message-Id: <20090716.002526.93465395.ryusuke@osrg.net>). Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-09-14nilfs2: convert nilfs_bmap_lookup to an inline functionRyusuke Konishi
The nilfs_bmap_lookup() is now a wrapper function of nilfs_bmap_lookup_at_level(). This moves the nilfs_bmap_lookup() to a header file converting it to an inline function and gives an opportunity for optimization. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-09-14nilfs2: allow btree code to directly call dat operationsRyusuke Konishi
The current btree code is written so that btree functions call dat operations via wrapper functions in bmap.c when they allocate, free, or modify virtual block addresses. This abstraction requires additional function calls and causes frequent call of nilfs_bmap_get_dat() function since it is used in the every wrapper function. This removes the wrapper functions and makes them available from btree.c and direct.c, which will increase the opportunity of compiler optimization. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-09-14nilfs2: add update functions of virtual block address to datRyusuke Konishi
This is a preparation for the successive cleanup ("nilfs2: allow btree to directly call dat operations"). This adds functions bundling a few operations to change an entry of virtual block address on the dat file. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
