This patch adds a TCP_FASTOPEN socket option to get a max backlog on its
listener to getsockopt().
Signed-off-by: Kenjiro Nakayama <nakayamakenjiro@gmail.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
Use the generic bits from genphy_config_init() instead of implementing
the same functionality again.
Signed-off-by: Daniel Mack <zonque@gmail.com>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
This enables other drivers to call this generic implementation, and then
only do specific details on top of it.
Pull x86 fix from Ingo Molnar:
"This fixes the preemption-count imbalance crash reported by Owen
Kibel"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/mce: Fix CMCI preemption bugs
Pull scheduler fixes from Ingo Molnar:
"Two fixes:
- a SCHED_DEADLINE task selection fix
- a sched/numa related lockdep splat fix"
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched: Check for stop task appearance when balancing happens
sched/numa: Fix task_numa_free() lockdep splat
Pull perf fixes from Ingo Molnar:
"Two kernel side fixes:
- an Intel uncore PMU driver potential crash fix
- a kprobes/perf-call-graph interaction fix"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf/x86/intel: Use rdmsrl_safe() when initializing RAPL PMU
kprobes/x86: Fix page-fault handling logic
Pull drm fixes from Dave Airlie:
"Unfortunately this contains no easter eggs, its a bit larger than I'd
like, but I included a patch that just moves code from one file to
another and I'd like to avoid merge conflicts with that later, so it
makes it seem worse than it is,
Otherwise:
- radeon: fixes to use new microcode to stabilise some cards, use
some common displayport code, some runtime pm fixes, pll regression
fixes
- i915: fix for some context oopses, a warn in a used path, backlight
fixes
- nouveau: regression fix
- omap: a bunch of fixes"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (51 commits)
drm: bochs: drop unused struct fields
drm: bochs: add power management support
drm: cirrus: add power management support
drm: Split out drm_probe_helper.c from drm_crtc_helper.c
drm/plane-helper: Don't fake-implement primary plane disabling
drm/ast: fix value check in cbr_scan2
drm/nouveau/bios: fix a bit shift error introduced by 457e77b
drm/radeon/ci: make sure mc ucode is loaded before checking the size
drm/radeon/si: make sure mc ucode is loaded before checking the size
drm/radeon: improve PLL params if we don't match exactly v2
drm/radeon: memory leak on bo reservation failure. v2
drm/radeon: fix VCE fence command
drm/radeon: re-enable mclk dpm on R7 260X asics
drm/radeon: add support for newer mc ucode on CI (v2)
drm/radeon: add support for newer mc ucode on SI (v2)
drm/radeon: apply more strict limits for PLL params v2
drm/radeon: update CI DPM powertune settings
drm/radeon: fix runpm handling on APUs (v4)
drm/radeon: disable mclk dpm on R7 260X
drm/tegra: Remove gratuitous pad field
git://people.freedesktop.org/~deathsimple/linux into drm-next
Some i2c fixes over DisplayPort.
* 'drm-next-3.15-wip' of git://people.freedesktop.org/~deathsimple/linux:
drm/radeon: Improve vramlimit module param documentation
drm/radeon: fix audio pin counts for DCE6+ (v2)
drm/radeon/dp: switch to the common i2c over aux code
drm/dp/i2c: Update comments about common i2c over dp assumptions (v3)
drm/dp/i2c: send bare addresses to properly reset i2c connections (v4)
drm/radeon/dp: handle zero sized i2c over aux transactions (v2)
drm/i915: support address only i2c-over-aux transactions
drm/tegra: dp: Support address-only I2C-over-AUX transactions
Pull more networking fixes from David Miller:
1) Fix mlx4_en_netpoll implementation, it needs to schedule a NAPI
context, not synchronize it. From Chris Mason.
2) Ipv4 flow input interface should never be zero, it should be
LOOPBACK_IFINDEX instead. From Cong Wang and Julian Anastasov.
3) Properly configure MAC to PHY connection in mvneta devices, from
Thomas Petazzoni.
4) sys_recv should use SYSCALL_DEFINE. From Jan Glauber.
5) Tunnel driver ioctls do not use the correct namespace, fix from
Nicolas Dichtel.
6) Fix memory leak on seccomp filter attach, from Kees Cook.
7) Fix lockdep warning for nested vlans, from Ding Tianhong.
8) Crashes can happen in SCTP due to how the auth_enable value is
managed, fix from Vlad Yasevich.
9) Wireless fixes from John W Linville and co.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (45 commits)
net: sctp: cache auth_enable per endpoint
tg3: update rx_jumbo_pending ring param only when jumbo frames are enabled
vlan: Fix lockdep warning when vlan dev handle notification
seccomp: fix memory leak on filter attach
isdn: icn: buffer overflow in icn_command()
ip6_tunnel: use the right netns in ioctl handler
sit: use the right netns in ioctl handler
ip_tunnel: use the right netns in ioctl handler
net: use SYSCALL_DEFINEx for sys_recv
net: mdio-gpio: Add support for separate MDI and MDO gpio pins
net: mdio-gpio: Add support for active low gpio pins
net: mdio-gpio: Use devm_ functions where possible
ipv4, route: pass 0 instead of LOOPBACK_IFINDEX to fib_validate_source()
ipv4, fib: pass LOOPBACK_IFINDEX instead of 0 to flowi4_iif
mlx4_en: don't use napi_synchronize inside mlx4_en_netpoll
net: mvneta: properly configure the MAC <-> PHY connection in all situations
net: phy: add minimal support for QSGMII PHY
sfc:On MCDI timeout, issue an FLR (and mark MCDI to fail-fast)
mwifiex: fix hung task on command timeout
mwifiex: process event before command response
Pull cifs fixes from Steve French:
"A set of 5 small cifs fixes"
* 'for-next' of git://git.samba.org/sfrench/cifs-2.6:
cif: fix dead code
cifs: fix error handling cifs_user_readv
fs: cifs: remove unused variable.
Return correct error on query of xattr on file with empty xattrs
cifs: Wait for writebacks to complete before attempting write.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver fixes from Greg KH:
"Here are a few driver fixes for char/misc drivers that resolve
reported issues.
All have been in linux-next successfully for a few days"
* tag 'char-misc-3.15-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc:
Drivers: hv: vmbus: Negotiate version 3.0 when running on ws2012r2 hosts
Tools: hv: Handle the case when the target file exists correctly
vme_tsi148: Utilize to_pci_dev() macro
vme_tsi148: Fix PCI address mapping assumption
vme_tsi148: Fix typo in tsi148_slave_get()
w1: avoid recursive device_add
w1: fix netlink refcnt leak on error path
misc: Grammar s/addition/additional/
drivers: mcb: fix memory leak in chameleon_parse_cells() error path
mei: ignore client writing state during cb completion
mei: me: do not load the driver if the FW doesn't support MEI interface
GenWQE: Increase driver version number
GenWQE: Fix multithreading problems
GenWQE: Ensure rc is not returning an uninitialized value
GenWQE: Add wmb before DDCB is started
GenWQE: Enable access to VPD flash area
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core fixes from Greg KH:
"Here are some driver core fixes for 3.15-rc2. Also in here are some
documentation updates, as well as an API removal that had to wait for
after -rc1 due to the cleanups coming into you from multiple developer
trees (this one and the PPC tree.)
All have been in linux next successfully"
* tag 'driver-core-3.15-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
drivers/base/dd.c incorrect pr_debug() parameters
Documentation: Update stable address in Chinese and Japanese translations
topology: Fix compilation warning when not in SMP
Chinese: add translation of io_ordering.txt
stable_kernel_rules: spelling/word usage
sysfs, driver-core: remove unused {sysfs|device}_schedule_callback_owner()
kernfs: protect lazy kernfs_iattrs allocation with mutex
fs: Don't return 0 from get_anon_bdev
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging driver fixes from Greg KH:
"Here are a few staging driver fixes for issues that have been reported
for 3.15-rc2.
Also dominating the diffstat for the pull request is the removal of
the rtl8187se driver. It's no longer needed in staging as a "real"
driver for this hardware is now merged in the tree in the "correct"
location in drivers/net/
All of these patches have been tested in linux-next"
* tag 'staging-3.15-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging:
staging: r8188eu: Fix case where ethtype was never obtained and always be checked against 0
staging: r8712u: Fix case where ethtype was never obtained and always be checked against 0
staging: r8188eu: Calling rtw_get_stainfo() with a NULL sta_addr will return NULL
staging: comedi: fix circular locking dependency in comedi_mmap()
staging: r8723au: Add missing initialization of change_inx in sort algorithm
Staging: unisys: use after free in list_for_each()
staging: unisys: use after free in error messages
staging: speakup: fix misuse of kstrtol() in handle_goto()
staging: goldfish: Call free_irq in error path
staging: delete rtl8187se wireless driver
staging: rtl8723au: Fix buffer overflow in rtw_get_wfd_ie()
staging: gs_fpgaboot: remove __TIMESTAMP__ macro
staging: vme: fix memory leak in vme_user_probe()
staging: fpgaboot: clean up Makefile
staging/usbip: fix store_attach() sscanf return value check
staging/usbip: userspace - fix usbipd SIGSEGV from refresh_exported_devices()
staging: rtl8188eu: remove spaces, correct counts to unbreak P2P ioctls
staging/rtl8821ae: Fix OOM handling in _rtl_init_deferred_work()
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial driver fixes from Greg KH:
"Here are a number of small tty/serial driver fixes for 3.15-rc2. Also
in here are some Documentation file removals for drivers that we
removed a long time ago, no need to keep it around any longer.
All of these have been in linux-next for a bit"
* tag 'tty-3.15-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
Revert "serial: 8250, disable "too much work" messages"
serial: amba-pl011: fix regression, causing an Oops on rmmod
tty: Fix help text of SYNCLINK_CS
tty: fix memleak in alloc_pid
ttyprintk: Allow built as a module
ttyprintk: Fix wrong tty_unregister_driver() call in the error path
Documentation/serial: Delete obsolete driver documentation
serial: omap: Fix missing pm_runtime_resume handling by simplifying code
serial_core: Fix pm imbalance on unbind
serial: pl011: change Rx burst size to half of trigger level
serial: timberdale: Depend on X86_32
serial: st-asc: Fix SysRq char handling
Revert "serial: clps711x: Give a chance to perform useful tasks during wait loop"
serial_core: Fix conditional start_tx on ring buffer not empty
serial: efm32: use $vendor,$device scheme for compatible string
serial: omap: free the wakeup settings in remove
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg KH:
"Here are a number of tiny USB fixes and new device ids for 3.15-rc2.
Nothing major, just issues some people have reported.
All of these have been in linux-next"
* tag 'usb-3.15-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb:
uas: fix deadlocky memory allocations
uas: fix error handling during scsi_scan()
uas: fix GFP_NOIO under spinlock
uwb: adds missing error handling
USB: cdc-acm: Remove Motorola/Telit H24 serial interfaces from ACM driver
USB: ohci-jz4740: FEAT_POWER is a port feature, not a hub feature
USB: ohci-jz4740: Fix uninitialized variable warning
USB: EHCI: tegra: set txfill_tuning
usb: ehci-platform: Return immediately from suspend if ehci_suspend fails
usb: ehci-exynos: Return immediately from suspend if ehci_suspend fails
USB: fix crash during hotplug of PCI USB controller card
USB: cdc-acm: fix double usb_autopm_put_interface() in acm_port_activate()
usb: usb-common: fix typo for usb_state_string
USB: usb_wwan: fix handling of missing bulk endpoints
USB: pl2303: add ids for Hewlett-Packard HP POS pole displays
USB: cp210x: Add 8281 (Nanotec Plug & Drive)
usb: option driver, add support for Telit UE910v2
Revert "USB: serial: add usbid for dell wwan card to sierra.c"
USB: serial: ftdi_sio: add id for Brainboxes serial cards
Merge misc fixes from Andrew Morton:
"13 fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
thp: close race between split and zap huge pages
mm: fix new kernel-doc warning in filemap.c
mm: fix CONFIG_DEBUG_VM_RB description
mm: use paravirt friendly ops for NUMA hinting ptes
mips: export flush_icache_range
mm/hugetlb.c: add cond_resched_lock() in return_unused_surplus_pages()
wait: explain the shadowing and type inconsistencies
Shiraz has moved
Documentation/vm/numa_memory_policy.txt: fix wrong document in numa_memory_policy.txt
powerpc/mm: fix ".__node_distance" undefined
kernel/watchdog.c:touch_softlockup_watchdog(): use raw_cpu_write()
init/Kconfig: move the trusted keyring config option to general setup
vmscan: reclaim_clean_pages_from_list() must use mod_zone_page_state()
Sasha Levin has reported two THP BUGs[1][2]. I believe both of them
have the same root cause. Let's look to them one by one.
The first bug[1] is "kernel BUG at mm/huge_memory.c:1829!". It's
BUG_ON(mapcount != page_mapcount(page)) in __split_huge_page(). From my
testing I see that page_mapcount() is higher than mapcount here.
I think it happens due to race between zap_huge_pmd() and
page_check_address_pmd(). page_check_address_pmd() misses PMD which is
under zap:
CPU0 CPU1
zap_huge_pmd()
pmdp_get_and_clear()
__split_huge_page()
anon_vma_interval_tree_foreach()
__split_huge_page_splitting()
mm_find_pmd()
* We check if PMD present without taking ptl: no
* serialization against zap_huge_pmd(). We miss this PMD,
* it's not accounted to 'mapcount' in __split_huge_page().
pmd_present(pmd) == 0
BUG_ON(mapcount != page_mapcount(page)) // CRASH!!!
page_remove_rmap(page)
atomic_add_negative(-1, &page->_mapcount)
The second bug[2] is "kernel BUG at mm/huge_memory.c:1371!".
It's VM_BUG_ON_PAGE(!PageHead(page), page) in zap_huge_pmd().
This happens in similar way:
CPU0 CPU1
zap_huge_pmd()
__split_huge_page()
mm_find_pmd()
pmd_present(pmd) == 0 /* The same comment as above */
* No crash this time since we already decremented page->_mapcount in
* zap_huge_pmd().
* We split the compound page here into small pages without
__split_huge_page_refcount()
VM_BUG_ON_PAGE(!PageHead(page), page); // CRASH!!!
So my understanding the problem is pmd_present() check in mm_find_pmd()
without taking page table lock.
The bug was introduced by me commit with commit 117b0791ac42. Sorry for
that. :(
Let's open code mm_find_pmd() in page_check_address_pmd() and do the
check under page table lock.
Note that __page_check_address() does the same for PTE entires
if sync != 0.
I've stress tested split and zap code paths for 36+ hours by now and
don't see crashes with the patch applied. Before it took <20 min to
trigger the first bug and few hours for second one (if we ignore
first).
[1] https://lkml.kernel.org/g/<53440991.9090001@oracle.com>
[2] https://lkml.kernel.org/g/<5310C56C.60709@oracle.com>
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Tested-by: Sasha Levin <sasha.levin@oracle.com>
Cc: Bob Liu <lliubbo@gmail.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Dave Jones <davej@redhat.com>
Cc: <stable@vger.kernel.org> [3.13+]
Fix new kernel-doc warning in mm/filemap.c:
Warning(mm/filemap.c:2600): Excess function parameter 'ppos' description in '__generic_file_aio_write'
This appears to be a copy/paste error. Update the description to
reflect extra rbtree debug and checks for the config option instead of
duplicating CONFIG_DEBUG_VM.
Signed-off-by: Davidlohr Bueso <davidlohr@hp.com>
Cc: Aswin Chandramouleeswaran <aswin@hp.com>
David Vrabel identified a regression when using automatic NUMA balancing
under Xen whereby page table entries were getting corrupted due to the
use of native PTE operations. Quoting him
Xen PV guest page tables require that their entries use machine
addresses if the preset bit (_PAGE_PRESENT) is set, and (for
successful migration) non-present PTEs must use pseudo-physical
addresses. This is because on migration MFNs in present PTEs are
translated to PFNs (canonicalised) so they may be translated back
to the new MFN in the destination domain (uncanonicalised).
pte_mknonnuma(), pmd_mknonnuma(), pte_mknuma() and pmd_mknuma()
set and clear the _PAGE_PRESENT bit using pte_set_flags(),
pte_clear_flags(), etc.
In a Xen PV guest, these functions must translate MFNs to PFNs
when clearing _PAGE_PRESENT and translate PFNs to MFNs when setting
_PAGE_PRESENT.
His suggested fix converted p[te|md]_[set|clear]_flags to using
paravirt-friendly ops but this is overkill. He suggested an alternative
of using p[te|md]_modify in the NUMA page table operations but this is
does more work than necessary and would require looking up a VMA for
protections.
This patch modifies the NUMA page table operations to use paravirt
friendly operations to set/clear the flags of interest. Unfortunately
this will take a performance hit when updating the PTEs on
CONFIG_PARAVIRT but I do not see a way around it that does not break
Xen.
Acked-by: David Vrabel <david.vrabel@citrix.com>
Tested-by: David Vrabel <david.vrabel@citrix.com>
Cc: Peter Anvin <hpa@zytor.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Steven Noonan <steven@uplinklabs.net>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: Cyrill Gorcunov <gorcunov@gmail.com>
The lkdtm module performs tests against executable memory ranges, so it
needs to flush the icache for proper behaviors. Other architectures
already export this, so do the same for MIPS.
[akpm@linux-foundation.org: relocate export sites]
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Sanjay Lal <sanjayl@kymasys.com>
Cc: John Crispin <blogic@openwrt.org>
Cc: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
soft lockup in freeing gigantic hugepage fixed in commit 55f67141a892 "mm:
hugetlb: fix softlockup when a large number of hugepages are freed." can
happen in return_unused_surplus_pages(), so let's fix it.
Signed-off-by: Masayoshi Mizuma <m.mizuma@jp.fujitsu.com>
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Aneesh Kumar <aneesh.kumar@linux.vnet.ibm.com>
Stick in a comment before someone else tries to fix the sparse warning
this generates.
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/n/tip-o2ro6f3vkxklni0bc8f7m68s@git.kernel.org
shiraz.hashim@st.com email-id doesn't exist anymore as he has left the
company. Replace ST's id with shiraz.linux.kernel@gmail.com.
It also updates .mailmap file to fix address for 'git shortlog'.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Shiraz Hashim <shiraz.linux.kernel@gmail.com>
In document numa_memory_policy.txt, the following examples for flag
MPOL_F_RELATIVE_NODES are incorrect.
For example, consider a task that is attached to a cpuset with
mems 2-5 that sets an Interleave policy over the same set with
MPOL_F_RELATIVE_NODES. If the cpuset's mems change to 3-7, the
interleave now occurs over nodes 3,5-6. If the cpuset's mems
then change to 0,2-3,5, then the interleave occurs over nodes
0,3,5.
According to the comment of the patch adding flag MPOL_F_RELATIVE_NODES,
the nodemasks the user specifies should be considered relative to the
current task's mems_allowed.
(https://lkml.org/lkml/2008/2/29/428)
And according to numa_memory_policy.txt, if the user's nodemask includes
nodes that are outside the range of the new set of allowed nodes, then
the remap wraps around to the beginning of the nodemask and, if not
already set, sets the node in the mempolicy nodemask.
So in the example, if the user specifies 2-5, for a task whose
mems_allowed is 3-7, the nodemasks should be remapped the third, fourth,
fifth, sixth node in mems_allowed. like the following:
mems_allowed: 3 4 5 6 7
relative index: 0 1 2 3 4
5
So the nodemasks should be remapped to 3,5-7, but not 3,5-6.
And for a task whose mems_allowed is 0,2-3,5, the nodemasks should be
remapped to 0,2-3,5, but not 0,3,5.
mems_allowed: 0 2 3 5
4 5
Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Acked-by: David Rientjes <rientjes@google.com>
CHK include/config/kernel.release
CHK include/generated/uapi/linux/version.h
CHK include/generated/utsrelease.h
Building modules, stage 2.
WARNING: 1 bad relocations
c0000000013d6a30 R_PPC64_ADDR64 uprobes_fetch_type_table
WRAP arch/powerpc/boot/zImage.pseries
WRAP arch/powerpc/boot/zImage.epapr
MODPOST 1849 modules
ERROR: ".__node_distance" [drivers/block/nvme.ko] undefined!
make[1]: *** [__modpost] Error 1
make: *** [modules] Error 2
make: *** Waiting for unfinished jobs....
The reason is symbol "__node_distance" not been exported in powerpc.
Signed-off-by: Mike Qiu <qiudayu@linux.vnet.ibm.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: Nathan Fontenot <nfont@linux.vnet.ibm.com>
Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Cc: Jesse Larrew <jlarrew@linux.vnet.ibm.com>
Cc: Robert Jennings <rcj@linux.vnet.ibm.com>
Cc: Alistair Popple <alistair@popple.id.au>
Cc: Mike Qiu <qiudayu@linux.vnet.ibm.com>
Fix:
BUG: using __this_cpu_write() in preemptible [00000000] code: systemd-udevd/497
caller is __this_cpu_preempt_check+0x13/0x20
CPU: 3 PID: 497 Comm: systemd-udevd Tainted: G W 3.15.0-rc1 #9
Hardware name: Hewlett-Packard HP EliteBook 8470p/179B, BIOS 68ICF Ver. F.02 04/27/2012
Call Trace:
check_preemption_disabled+0xe1/0xf0
touch_nmi_watchdog+0x28/0x40
Reported-by: Luis Henriques <luis.henriques@canonical.com>
Tested-by: Luis Henriques <luis.henriques@canonical.com>
Cc: Eric Piel <eric.piel@tremplin-utc.net>
Cc: Robert Moore <robert.moore@intel.com>
Cc: Lv Zheng <lv.zheng@intel.com>
Cc: "Rafael J. Wysocki" <rafael.j.wysocki@intel.com>
Cc: Len Brown <lenb@kernel.org>
Cc: Christoph Lameter <cl@linux.com>
The SYSTEM_TRUSTED_KEYRING config option is not in any menu, causing it
to show up in the toplevel of the kernel configuration. Fix this by
moving it under the General Setup menu.
Signed-off-by: Peter Foley <pefoley2@pefoley.com>
Seems to be called with preemption enabled. Therefore it must use
mod_zone_page_state instead.
Signed-off-by: Christoph Lameter <cl@linux.com>
Reported-by: Grygorii Strashko <grygorii.strashko@ti.com>
Tested-by: Grygorii Strashko <grygorii.strashko@ti.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
Currently, it is possible to create an SCTP socket, then switch
auth_enable via sysctl setting to 1 and crash the system on connect:
Oops[#1]:
CPU: 0 PID: 0 Comm: swapper Not tainted 3.14.1-mipsgit-20140415 #1
task: ffffffff8056ce80 ti: ffffffff8055c000 task.ti: ffffffff8055c000
Call Trace:
[<ffffffff8043c4e8>] sctp_auth_asoc_set_default_hmac+0x68/0x80
[<ffffffff8042b300>] sctp_process_init+0x5e0/0x8a4
[<ffffffff8042188c>] sctp_sf_do_5_1B_init+0x234/0x34c
[<ffffffff804228c8>] sctp_do_sm+0xb4/0x1e8
[<ffffffff80425a08>] sctp_endpoint_bh_rcv+0x1c4/0x214
[<ffffffff8043af68>] sctp_rcv+0x588/0x630
[<ffffffff8043e8e8>] sctp6_rcv+0x10/0x24
[<ffffffff803acb50>] ip6_input+0x2c0/0x440
[<ffffffff8030fc00>] __netif_receive_skb_core+0x4a8/0x564
[<ffffffff80310650>] process_backlog+0xb4/0x18c
[<ffffffff80313cbc>] net_rx_action+0x12c/0x210
[<ffffffff80034254>] __do_softirq+0x17c/0x2ac
[<ffffffff800345e0>] irq_exit+0x54/0xb0
[<ffffffff800075a4>] ret_from_irq+0x0/0x4
[<ffffffff800090ec>] rm7k_wait_irqoff+0x24/0x48
[<ffffffff8005e388>] cpu_startup_entry+0xc0/0x148
[<ffffffff805a88b0>] start_kernel+0x37c/0x398
Code: dd0900b8 000330f8 0126302d <dcc60000> 50c0fff1 0047182a a48306a0
03e00008 00000000
---[ end trace b530b0551467f2fd ]---
Kernel panic - not syncing: Fatal exception in interrupt
What happens while auth_enable=0 in that case is, that
ep->auth_hmacs is initialized to NULL in sctp_auth_init_hmacs()
when endpoint is being created.
After that point, if an admin switches over to auth_enable=1,
the machine can crash due to NULL pointer dereference during
reception of an INIT chunk. When we enter sctp_process_init()
via sctp_sf_do_5_1B_init() in order to respond to an INIT chunk,
the INIT verification succeeds and while we walk and process
all INIT params via sctp_process_param() we find that
net->sctp.auth_enable is set, therefore do not fall through,
but invoke sctp_auth_asoc_set_default_hmac() instead, and thus,
dereference what we have set to NULL during endpoint
initialization phase.
The fix is to make auth_enable immutable by caching its value
during endpoint initialization, so that its original value is
being carried along until destruction. The bug seems to originate
from the very first days.
Fix in joint work with Daniel Borkmann.
Reported-by: Joshua Kinard <kumba@gentoo.org>
Signed-off-by: Vlad Yasevich <vyasevic@redhat.com>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Tested-by: Joshua Kinard <kumba@gentoo.org>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
John W. Linville says:
pull request: wireless 2014-04-17
Please pull this batch of fixes intended for the 3.15 stream...
For the mac80211 bits, Johannes says:
"We have a fix from Chun-Yeow to not look at management frame bitrates
that are typically really low, two fixes from Felix for AP_VLAN
interfaces, a fix from Ido to disable SMPS settings when a monitor
interface is enabled, a radar detection fix from Michał and a fix from
myself for a very old remain-on-channel bug."
For the iwlwifi bits, Emmanuel says:
"I have new device IDs and a new firmware API. These are the trivial
ones. The less trivial ones are Johannes's fix that delays the
enablement of an interrupt coalescing hardware until after association
- this fixes a few connection problems seen in the field. Eyal has a
bunch of rate control fixes. I decided to add these for 3.15 because
they fix some disconnection and packet loss scenarios which were
reported by the field. I also have a fix for a memory leak that
happens only with a very new NIC."
Along with those...
Amitkumar Karwar fixes a couple of problems relating to driver/firmware
interactions in mwifiex.
Christian Engelmayer avoids a couple of potential memory leaks in
the new rsi driver.
Eliad Peller provides a wl18xx mailbox alignment fix for problems
when using new firmware.
Frederic Danis adds a couple of missing debugging strings to the
cw1200 driver.
Geert Uytterhoeven adds a variable initialization inside of the
rsi driver.
Luciano Coelho patches the wlcore code to ignore dummy packet events
in PLT mode in order to work around a firmware bug.
The patch fixes a problem with dropped jumbo frames after usage of
'ethtool -G ... rx'.
Scenario:
1. ip link set eth0 up
2. ethtool -G eth0 rx N # <- This zeroes rx-jumbo
3. ip link set mtu 9000 dev eth0
The ethtool command set rx_jumbo_pending to zero so any received jumbo
packets are dropped and you need to use 'ethtool -G eth0 rx-jumbo N'
to workaround the issue.
The patch changes the logic so rx_jumbo_pending value is changed only if
jumbo frames are enabled (MTU > 1500).
Signed-off-by: Ivan Vecera <ivecera@redhat.com>
Acked-by: Michael Chan <mchan@broadcom.com>
When I open the LOCKDEP config and run these steps:
modprobe 8021q
vconfig add eth2 20
vconfig add eth2.20 30
ifconfig eth2 xx.xx.xx.xx
then the Call Trace happened:
[32524.386288] =============================================
[32524.386293] [ INFO: possible recursive locking detected ]
[32524.386298] 3.14.0-rc2-0.7-default+ #35 Tainted: G O
[32524.386302] ---------------------------------------------
[32524.386306] ifconfig/3103 is trying to acquire lock:
[32524.386310] (&vlan_netdev_addr_lock_key/1){+.....}, at: [<ffffffff814275f4>] dev_mc_sync+0x64/0xb0
[32524.386326]
[32524.386326] but task is already holding lock:
[32524.386330] (&vlan_netdev_addr_lock_key/1){+.....}, at: [<ffffffff8141af83>] dev_set_rx_mode+0x23/0x40
[32524.386341]
[32524.386341] other info that might help us debug this:
[32524.386345] Possible unsafe locking scenario:
[32524.386345]
[32524.386350] CPU0
[32524.386352] ----
[32524.386354] lock(&vlan_netdev_addr_lock_key/1);
[32524.386359] lock(&vlan_netdev_addr_lock_key/1);
[32524.386364]
[32524.386364] *** DEADLOCK ***
[32524.386364]
[32524.386368] May be due to missing lock nesting notation
[32524.386368]
[32524.386373] 2 locks held by ifconfig/3103:
[32524.386376] #0: (rtnl_mutex){+.+.+.}, at: [<ffffffff81431d42>] rtnl_lock+0x12/0x20
[32524.386387] #1: (&vlan_netdev_addr_lock_key/1){+.....}, at: [<ffffffff8141af83>] dev_set_rx_mode+0x23/0x40
[32524.386398]
[32524.386398] stack backtrace:
[32524.386403] CPU: 1 PID: 3103 Comm: ifconfig Tainted: G O 3.14.0-rc2-0.7-default+ #35
[32524.386409] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007
[32524.386414] ffffffff81ffae40 ffff8800d9625ae8 ffffffff814f68a2 ffff8800d9625bc8
[32524.386421] ffffffff810a35fb ffff8800d8a8d9d0 00000000d9625b28 ffff8800d8a8e5d0
[32524.386428] 000003cc00000000 0000000000000002 ffff8800d8a8e5f8 0000000000000000
[32524.386435] Call Trace:
[32524.386441] [<ffffffff814f68a2>] dump_stack+0x6a/0x78
[32524.386448] [<ffffffff810a35fb>] __lock_acquire+0x7ab/0x1940
[32524.386454] [<ffffffff810a323a>] ? __lock_acquire+0x3ea/0x1940
[32524.386459] [<ffffffff810a4874>] lock_acquire+0xe4/0x110
[32524.386464] [<ffffffff814275f4>] ? dev_mc_sync+0x64/0xb0
[32524.386471] [<ffffffff814fc07a>] _raw_spin_lock_nested+0x2a/0x40
[32524.386476] [<ffffffff814275f4>] ? dev_mc_sync+0x64/0xb0
[32524.386481] [<ffffffff814275f4>] dev_mc_sync+0x64/0xb0
[32524.386489] [<ffffffffa0500cab>] vlan_dev_set_rx_mode+0x2b/0x50 [8021q]
[32524.386495] [<ffffffff8141addf>] __dev_set_rx_mode+0x5f/0xb0
[32524.386500] [<ffffffff8141af8b>] dev_set_rx_mode+0x2b/0x40
[32524.386506] [<ffffffff8141b3cf>] __dev_open+0xef/0x150
[32524.386511] [<ffffffff8141b177>] __dev_change_flags+0xa7/0x190
[32524.386516] [<ffffffff8141b292>] dev_change_flags+0x32/0x80
[32524.386524] [<ffffffff8149ca56>] devinet_ioctl+0x7d6/0x830
[32524.386532] [<ffffffff81437b0b>] ? dev_ioctl+0x34b/0x660
[32524.386540] [<ffffffff814a05b0>] inet_ioctl+0x80/0xa0
[32524.386550] [<ffffffff8140199d>] sock_do_ioctl+0x2d/0x60
[32524.386558] [<ffffffff81401a52>] sock_ioctl+0x82/0x2a0
[32524.386568] [<ffffffff811a7123>] do_vfs_ioctl+0x93/0x590
[32524.386578] [<ffffffff811b2705>] ? rcu_read_lock_held+0x45/0x50
[32524.386586] [<ffffffff811b39e5>] ? __fget_light+0x105/0x110
[32524.386594] [<ffffffff811a76b1>] SyS_ioctl+0x91/0xb0
[32524.386604] [<ffffffff815057e2>] system_call_fastpath+0x16/0x1b
The reason is that all of the addr_lock_key for vlan dev have the same class,
so if we change the status for vlan dev, the vlan dev and its real dev will
hold the same class of addr_lock_key together, so the warning happened.
we should distinguish the lock depth for vlan dev and its real dev.
v1->v2: Convert the vlan_netdev_addr_lock_key to an array of eight elements, which
could support to add 8 vlan id on a same vlan dev, I think it is enough for current
scene, because a netdev's name is limited to IFNAMSIZ which could not hold 8 vlan id,
and the vlan dev would not meet the same class key with its real dev.
The new function vlan_dev_get_lockdep_subkey() will return the subkey and make the vlan
dev could get a suitable class key.
v2->v3: According David's suggestion, I use the subclass to distinguish the lock key for vlan dev
and its real dev, but it make no sense, because the difference for subclass in the
lock_class_key doesn't mean that the difference class for lock_key, so I use lock_depth
to distinguish the different depth for every vlan dev, the same depth of the vlan dev
could have the same lock_class_key, I import the MAX_LOCK_DEPTH from the include/linux/sched.h,
I think it is enough here, the lockdep should never exceed that value.
v3->v4: Add a huge array of locking keys will waste static kernel memory and is not a appropriate method,
we could use _nested() variants to fix the problem, calculate the depth for every vlan dev,
and use the depth as the subclass for addr_lock_key.
Signed-off-by: Ding Tianhong <dingtianhong@huawei.com>
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull infiniband/rdma updates from Roland Dreier:
- mostly cxgb4 fixes unblocked by the merge of some prerequisites via
the net tree
- drop deprecated MSI-X API use.
- a couple other miscellaneous things.
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
RDMA/cxgb4: Fix over-dereference when terminating
RDMA/cxgb4: Use uninitialized_var()
RDMA/cxgb4: Add missing debug stats
RDMA/cxgb4: Initialize reserved fields in a FW work request
RDMA/cxgb4: Use pr_warn_ratelimited
RDMA/cxgb4: Max fastreg depth depends on DSGL support
RDMA/cxgb4: SQ flush fix
RDMA/cxgb4: rmb() after reading valid gen bit
RDMA/cxgb4: Endpoint timeout fixes
RDMA/cxgb4: Use the BAR2/WC path for kernel QPs and T5 devices
IB/mlx5: Add block multicast loopback support
IB/mthca: Use pci_enable_msix_exact() instead of pci_enable_msix()
IB/qib: Use pci_enable_msix_range() instead of pci_enable_msix()
Commit 93ea02bb8435 ("arch: Clean up asm/barrier.h implementations")
wired generic barrier.h for ARC, but failed to delete the existing file.
In 3.15, due to rcupdate.h updates, this causes a build breakage on ARC:
CC arch/arc/kernel/asm-offsets.s
In file included from include/linux/sched.h:45:0,
from arch/arc/kernel/asm-offsets.c:9:
include/linux/rculist.h: In function __list_add_rcu:
include/linux/rculist.h:54:2: error: implicit declaration of function smp_store_release [-Werror=implicit-function-declaration]
rcu_assign_pointer(list_next_rcu(prev), new);
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"These are fixes for a powerpc NULL pointer dereference, an OF
interrupt mapping issue on some of the new host bridges, and a
DesignWare iATU issue.
Host bridge drivers
- Fix OF interrupt mapping for DesignWare, R-Car, Tegra (Lucas Stach)
- Fix DesignWare iATU programming (Mohit Kumar)
Miscellaneous
- Fix powerpc NULL dereference from list_for_each_entry() update (Mike Qiu)"
* tag 'pci-v3.15-fixes-1' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
PCI: tegra: Use new OF interrupt mapping when possible
PCI: rcar: Use new OF interrupt mapping when possible
PCI: designware: Use new OF interrupt mapping when possible
PCI: designware: Fix iATU programming for cfg1, io and mem viewport
PCI: designware: Fix comment for setting number of lanes
powerpc/PCI: Fix NULL dereference in sys_pciconfig_iobase() list traversal
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
Pull HID fixes from Jiri Kosina:
- fix for merge window mismerge in hid-sony, from Frank Praznik
- fix for Surface Type/Touch Cover 2 device, from Benjamin Tissoires
- quirk for ThinkPad Helix sensor hub from Stephen Chandler Paul
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid:
HID: core: do not scan constant input report
Revert "HID: microsoft: Add ID's for Surface Type/Touch Cover 2"
HID: sensor-hub: add sensor hub quirk for ThinkPad Helix
HID: sony: Fix cancel_work_sync mismerge
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"Just a copule of HD-audio device/codec-specific quirks, and a trivial
replacement of udelay() with mdelay() in the old es18xx driver code.
All should be safe to apply"
* tag 'sound-3.15-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: hda/realtek - Add headset Mic support for Dell machine
ALSA: hda - add headset mic detect quirk for a Dell laptop
ALSA: es18xx driver should use udelay error
ALSA: hda/realtek - Add support of ALC288 codec
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull devicetree fixes from Rob Herring:
- fix error handling in of_update_property
- fix section mismatch warnings in __reserved_mem_check_root
- add empty of_find_node_by_path for !OF builds
- add various missing binding documentation
* tag 'dt-fixes-for-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux:
of: add empty of_find_node_by_path() for !OF
of: Clean up of_update_property
DT: add vendor prefix for EBV Elektronik
of: Fix the section mismatch warnings.
of: Add vendor prefix for Digi International Inc.
DT: I2C: Add trivial bindings used by kirkwood boards
DT: Vendor: Add prefixes used by Kirkwood devices
DT: bindings: add missing Marvell Kirkwood SoC documentation
dt-bindings: add vendor-prefix for Newhaven Display
of: add vendor prefix for I2SE GmbH
of: add vendor prefix for ISEE 2007 S.L.
Pull xfs bug fixes from Dave Chinner:
"The fixes are for data corruption issues, memory corruption and
regressions for changes merged in -rc1.
Data corruption fixes:
- fix a bunch of delayed allocation state mismatches
- fix collapse/zero range bugs
- fix a direct IO block mapping bug @ EOF
Other fixes:
- fix a use after free on metadata IO error
- fix a use after free on IO error during unmount
- fix an incorrect error sign on direct IO write errors
- add missing O_TMPFILE inode security context initialisation"
* tag 'xfs-for-linus-3.15-rc2' of git://oss.sgi.com/xfs/xfs:
xfs: fix tmpfile/selinux deadlock and initialize security
xfs: fix buffer use after free on IO error
xfs: wrong error sign conversion during failed DIO writes
xfs: unmount does not wait for shutdown during unmount
xfs: collapse range is delalloc challenged
xfs: don't map ranges that span EOF for direct IO
xfs: zeroing space needs to punch delalloc blocks
xfs: xfs_vm_write_end truncates too much on failure
xfs: write failure beyond EOF truncates too much data
xfs: kill buffers over failed write ranges properly
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing fixes from Steven Rostedt:
"This contains two fixes.
The first is to remove a duplication of creating debugfs files that
already exist and causes an error report to be printed due to the
failure of the second creation.
The second is a memory leak fix that was introduced in 3.14"
* tag 'trace-fixes-v3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
tracing/uprobes: Fix uprobe_cpu_buffer memory leak
tracing: Do not try to recreated toplevel set_ftrace_* files
Add an empty version of of_find_node_by_path().
This fixes following build error for asoc tree:
sound/soc/fsl/fsl_ssi.c: In function 'fsl_ssi_probe':
sound/soc/fsl/fsl_ssi.c:1471:2: error: implicit declaration of function 'of_find_node_by_path' [-Werror=implicit-function-declaration]
sprop = of_get_property(of_find_node_by_path("/"), "compatible", NULL);
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
Signed-off-by: Rob Herring <robh@kernel.org>
CPUs which should support the RAPL counters according to
Family/Model/Stepping may still issue #GP when attempting to access
the RAPL MSRs. This may happen when Linux is running under KVM and
we are passing-through host F/M/S data, for example. Use rdmsrl_safe
to first access the RAPL_POWER_UNIT MSR; if this fails, do not
attempt to use this PMU.
Signed-off-by: Venkatesh Srinivas <venkateshs@google.com>
Link: http://lkml.kernel.org/r/1394739386-22260-1-git-send-email-venkateshs@google.com
Cc: zheng.z.yan@intel.com
Cc: eranian@google.com
Cc: ak@linux.intel.com
[ The patch also silently fixes another bug: rapl_pmu_init() didn't handle the memory alloc failure case previously. ]
Signed-off-by: Gerd Hoffmann <kraxel@redhat.com>
bochs kms driver lacks power management support, thus
the vga display doesn't work any more after S3 resume.
Fix this by adding suspend and resume functions.
cirrus kms driver lacks power management support, thus
Also make the mode_set function unblank the screen.
This is leftover stuff from my previous doc round which I kinda wanted
to do but didn't yet due to rebase hell.
The modeset helpers and the probing helpers a independent and e.g.
i915 uses the probing stuff but has its own modeset infrastructure. It
hence makes to split this up. While at it add a DOC: comment for the
probing libraray.
It would be rather neat to pull some of the DocBook documenting these
two helpers into in-line DOC: comments. But unfortunately kerneldoc
doesn't support markdown or something similar to make nice-looking
documentation, so the current state is better.
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
After thinking about this topic a bit more I've reached the conclusion
that implementing this doesn't make sense:
- The locking is all wrong: set_config(NULL) will also unlink encoders
and connectors, but those links are protected with the mode_config
mutex. In the ->disable_plane callback we only hold all modeset
locks, but eventually we want to switch to just grabbing the
per-crtc (and maybe per-plane) locks as needed, maybe based on
ww_mutexes. Having a callback which absolutely needs all modeset
locks is bad for this conversion.
Note that the same isn't true for the provided ->update_plane since
we've audited the crtc helpers to make sure that not encoder or
connector links are changed.
- There's no way to re-enable the plane with an ->update_plane: The
connectors/encoder links are lost and so we can't re-enable the
CRTC. Even without that issue the driver might have reassigned some
shared resources (as opposed to e.g. DPMS off, where drivers are not
allowed to do that to make sure the CRTC can be enabled again).
- The semantics don't make much sense: Userspace asked to scan out
black (or some other color if the driver supports a background
color), not that the screen be disabled.
- Implementing proper primary plane support (i.e. actually disabling
the primary plane without disabling the CRTC) is really simple, at
least if all the hw needs is flipping a bit. The big task is
auditing all the interactions with other ioctls when the CRTC is on
but there's no primary plane (e.g. pageflips). And some of that work
still needs to be done.
Cc: Matt Roper <matthew.d.roper@intel.com>
Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Reviewed-by: Matt Roper <matthew.d.roper@intel.com>
this is a typo vs the ums driver, fix to check correct value.
Found initially by Coverity.
Reported-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Commit 457e77b26428ab4a24998eecfb99f27fa4195397 added two checks applied to a
value received from nv_rd32(bios, 0x619f04). But after this new piece of code
is executed, the addr local variable does not hold the same value it used to
hold before the commit. Here is what is was assigned in the original code:
(u64)(nv_rd32(bios, 0x619f04) & 0xffffff00) << 8
in the committed code it ends up with this value:
(u64)(nv_rd32(bios, 0x619f04) >> 8) << 8
These expressions are obviously not equivalent.
My Nvidia video card does not show anything on the display when I boot a
kernel containing this commit.
The patch fixes the code so that the new checks are still done, but the
side effect of an incorrect addr value is gone.
Cc: Ben Skeggs <bskeggs@redhat.com>
Cc: Dave Airlie <airlied@redhat.com>
Signed-off-by: Sergei Antonov <saproj@gmail.com>
