2012-12-17backlight: corgi_lcd: fix checkpatch error and warningJingoo Han
This patch fixes the checkpatch error and warning as below: WARNING: please, no space before tabs WARNING: quoted string split across lines ERROR: space required before the open parenthesis '(' Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17backlight: atmel-pwm-bl: fix checkpatch warningJingoo Han
This patch fixes the checkpatch warning as below: WARNING: quoted string split across lines Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17backlight: 88pm860x_bl: fix checkpatch warningJingoo Han
2012-12-17backlight: da903x_bl: use dev_get_drvdata() instead of platform_get_drvdata()Jingoo Han
dev_get_drvdata() can be used instead of platform_get_drvdata() to make the code smaller. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17MAINTAINERS: adjust for UAPI: firewireStefan Richter
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17Corentin has movedCorentin Chary
Signed-off-by: Corentin Chary <corentin.chary@gmail.com> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17MAINTAINERS: remove include/linux/ext3*Cesar Eduardo Barros
Moved to fs/ext3/ext3.h by commit 4613ad180d19 ("ext3: move headers to fs/ext3/"). Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17MAINTAINERS: CHINESE MAINTAINERS mailing list is subscribers onlyJoe Perches
Mark it so. Signed-off-by: Joe Perches <joe@perches.com> Cc: Harry Wei <harryxiyou@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17lib/vsprintf.c: fix handling of %zd when using ssize_tJason Gunthorpe
Documentation/printk-formats.txt says to use %zd for a ssize_t argument and some drivers do. Unfortunately this prints a positive number for negative values eg: tpm_tis 70030000.tpm_tis: tpm_transmit: tpm_send: error 4294967234 Add a case to va_args a ssize_t type if the interpretation should be signed. Tested on PPC32. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17printk: boot_delay should only affect outputAndrew Cooks
The boot_delay parameter affects all printk(), even if the log level prevents visible output from the call. It results in delays greater than the user intended without purpose. This patch changes the behaviour of boot_delay to only delay output. Signed-off-by: Andrew Cooks <acooks@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17dmatest: check for dma mapping errorAndy Shevchenko
The kernel emits a warning if CONFIG_DMA_API_DEBUG=y: WARNING: at lib/dma-debug.c:933 check_unmap+0x5d6/0x6ac() dw_dmac dw_dmac.0: DMA-API: device driver failed to check map error[device address=0x0000000035698305] [size=14365 bytes] [mapped as single] Fix this by adding the required checking of the dma_map_single() return value. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org> Cc: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17dmatest: implement two helpers to unmap dma memoryAndy Shevchenko
The unmap_src() and unmap_dst() will be used later as well. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org> Cc: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17watchdog: store the watchdog sample period as a variableChuansheng Liu
Currently getting the sample period is always thru a complex calculation: get_softlockup_thresh() * ((u64)NSEC_PER_SEC / 5). We can store the sample period as a variable, and set it as __read_mostly type. Signed-off-by: liu chuansheng <chuansheng.liu@intel.com> Cc: Don Zickus <dzickus@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17usb: musb: use io{read,write}*_rep accessorsMatthew Leach
The {read,write}s{b,w,l} operations are not defined by all architectures and are being removed from the asm-generic/io.h interface. This patch replaces the usage of these string functions in the musb accessors with io{read,write}{8,16,32}_rep calls instead. Signed-off-by: Matthew Leach <matthew@mattleach.net> Signed-off-by: Will Deacon <will.deacon@arm.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Ben Herrenschmidt <benh@kernel.crashing.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17musb: tusb6010: use io{read,write}*_rep accessorsMatthew Leach
The {read,write}s{b,w,l} operations are not defined by all architectures and are being removed from the asm-generic/io.h interface. This patch replaces the usage of these string functions in the tusb6010 accessors with io{read,write}{8,16,32}_rep calls instead. Signed-off-by: Matthew Leach <matthew@mattleach.net> Signed-off-by: Will Deacon <will.deacon@arm.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Ben Herrenschmidt <benh@kernel.crashing.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17asm-generic: io: don't perform swab during {in,out} string functionsWill Deacon
The {in,out}s{b,w,l} functions are designed to operate on a stream of bytes and therefore should not perform any byte-swapping, regardless of the CPU byte order. This patch fixes the generic IO header so that {in,out}s{b,w,l} call the __raw_{read,write} functions directly rather than going via the endian-correcting accessors. Signed-off-by: Will Deacon <will.deacon@arm.com> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Ben Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17.gitignore: remove stale entry for generated version.hJonathan Austin
Since userspace headers were moved to generated/uapi it possible to have a stale copy of linux/version.h at that file's old location. This causes confusion after building an older kernel version, then checking out and building a new one; the old (stale) version header will still get picked up until it is manually removed. This upsets the C library. Since the uapi changes, include/linux/version.h is no longer generated and should not be ignored, so this patch removes it from .gitignore. Signed-off-by: Jonathan Austin <jonathan.austin@arm.com> Reported-by: Kevin Petit <kevin.petit@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17fs/notify/inode_mark.c: make fsnotify_find_inode_mark_locked() staticTushar Behera
Fixes following sparse warning: fs/notify/inode_mark.c:127:22: warning: symbol 'fsnotify_find_inode_mark_locked' was not declared. Should it be static? Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Cc: Eric Paris <eparis@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17lseek: the "whence" argument is called "whence"Andrew Morton
But the kernel decided to call it "origin" instead. Fix most of the sites. Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17drivers: remove reference to feature-removal-schedule.txtTao Ma
In commit 9c0ece069b32 ("Get rid of Documentation/feature-removal.txt"), Linus removed feature-removal-schedule.txt from Documentation, but there is still some reference to this file. So remove them. Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17sound: remove reference to feature-removal-schedule.txtTao Ma
2012-12-17kernel: remove reference to feature-removal-schedule.txtTao Ma
2012-12-17Documentation: remove reference to feature-removal-schedule.txtTao Ma
2012-12-17include/linux/init.h: use the stringify operator for the __define_initcall macroMatthew Leach
Currently the __define_initcall() macro takes three arguments, fn, id and level. The level argument is exactly the same as the id argument but wrapped in quotes. To overcome this need to specify three arguments to the __define_initcall macro, where one argument is the stringification of another, we can just use the stringification macro instead. Signed-off-by: Matthew Leach <matthew@mattleach.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17Documentation/kernel-parameters.txt: update mem= option's spec according to ↵Wen Congyang
its implementation Current mem= implementation seems buggy because the specification and implementation don't match. The current mem= has been working for many years and it's not buggy - it works as expected. So we should update the specification. Signed-off-by: Wen Congyang <wency@cn.fujitsu.com> Cc: Rob Landley <rob@landley.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17frv: properly use the declarations provided by <asm/sections.h>Geert Uytterhoeven
- Remove the superfluous address-of ('&') operators, - Remove the unneeded casts, use %p to format pointers instead. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17frv: fix use of extinct _sbss and _ebss in debug codeGeert Uytterhoeven
Nowadays it should probably use __bss_start and __bss_stop Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17mm/memory.c: suppress warningAndrew Morton
gcc-4.4.4 screws this up. mm/memory.c: In function 'do_pmd_numa_page': mm/memory.c:3594: warning: no return statement in function returning non-void Cc: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17create non-empty arch/x86/include/uapi/asm/ filesAndrew Morton
patch(1) doesn't create zero-length files, so my kernel didn't compile. Put something in these files so patch(1) actually creates them. Cc: David Howells <dhowells@redhat.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17Revert "bdi: add a user-tunable cpu_list for the bdi flusher threads"Linus Torvalds
This reverts commit 8fa72d234da9b6b473bbb1f74d533663e4996e6b. People disagree about how this should be done, so let's revert this for now so that nobody starts using the new tuning interface. Tejun is thinking about a more generic interface for thread pool affinity. Requested-by: Tejun Heo <tj@kernel.org> Acked-by: Jeff Moyer <jmoyer@redhat.com> Acked-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull ext3, udf, quota fixes from Jan Kara: "Some ext3 & quota cleanups and couple of udf fixes" * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: quota: Use the pre-processor to compile out quotactl_cmd_write when !CONFIG_BLOCK ext3: drop if around WARN_ON ext3: get rid of the duplicate code on ext3_fill_super udf: remove un-needed variable from inode_getblk udf: don't increment lenExtents while writing to a hole udf: fix memory leak while allocating blocks during write
2012-12-17Merge branch 'for-3.8/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block layer core updates from Jens Axboe: "Here are the core block IO bits for 3.8. The branch contains: - The final version of the surprise device removal fixups from Bart. - Don't hide EFI partitions under advanced partition types. It's fairly wide spread these days. This is especially dangerous for systems that have both msdos and efi partition tables, where you want to keep them in sync. - Cleanup of using -1 instead of the proper NUMA_NO_NODE - Export control of bdi flusher thread CPU mask and default to using the home node (if known) from Jeff. - Export unplug tracepoint for MD. - Core improvements from Shaohua. Reinstate the recursive merge, as the original bug has been fixed. Add plugging for discard and also fix a problem handling non pow-of-2 discard limits. There's a trivial merge in block/blk-exec.c due to a fix that went into 3.7-rc at a later point than -rc4 where this is based." * 'for-3.8/core' of git://git.kernel.dk/linux-block: block: export block_unplug tracepoint block: add plug for blkdev_issue_discard block: discard granularity might not be power of 2 deadline: Allow 0ms deadline latency, increase the read speed partitions: enable EFI/GPT support by default bsg: Remove unused function bsg_goose_queue() block: Make blk_cleanup_queue() wait until request_fn finished block: Avoid scheduling delayed work on a dead queue block: Avoid that request_fn is invoked on a dead queue block: Let blk_drain_queue() caller obtain the queue lock block: Rename queue dead flag bdi: add a user-tunable cpu_list for the bdi flusher threads block: use NUMA_NO_NODE instead of -1 block: recursive merge requests block CFQ: avoid moving request to different queue
2012-12-17Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull DRM updates from Dave Airlie: "This is the one and only next pull for 3.8, we had a regression we found last week, so I was waiting for that to resolve itself, and I ended up with some Intel fixes on top as well. Highlights: - new driver: nvidia tegra 20/30/hdmi support - radeon: add support for previously unused DMA engines, more HDMI regs, eviction speeds ups and fixes - i915: HSW support enable, agp removal on GEN6, seqno wrapping - exynos: IPP subsystem support (image post proc), HDMI - nouveau: display class reworking, nv20->40 z compression - ttm: start of locking fixes, rcu usage for lookups, - core: documentation updates, docbook integration, monotonic clock usage, move from connector to object properties" * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (590 commits) drm/exynos: add gsc ipp driver drm/exynos: add rotator ipp driver drm/exynos: add fimc ipp driver drm/exynos: add iommu support for ipp drm/exynos: add ipp subsystem drm/exynos: support device tree for fimd radeon: fix regression with eviction since evict caching changes drm/radeon: add more pedantic checks in the CP DMA checker drm/radeon: bump version for CS ioctl support for async DMA drm/radeon: enable the async DMA rings in the CS ioctl drm/radeon: add VM CS parser support for async DMA on cayman/TN/SI drm/radeon/kms: add evergreen/cayman CS parser for async DMA (v2) drm/radeon/kms: add 6xx/7xx CS parser for async DMA (v2) drm/radeon: fix htile buffer size computation for command stream checker drm/radeon: fix fence locking in the pageflip callback drm/radeon: make indirect register access concurrency-safe drm/radeon: add W|RREG32_IDX for MM_INDEX|DATA based mmio accesss drm/exynos: support extended screen coordinate of fimd drm/exynos: fix x, y coordinates for right bottom pixel drm/exynos: fix fb offset calculation for plane ...
2012-12-17sched: numa: Fix build error if CONFIG_NUMA_BALANCING && ↵Mel Gorman
!CONFIG_TRANSPARENT_HUGEPAGE Michal Hocko reported that the following build error occurs if CONFIG_NUMA_BALANCING is set without THP support kernel/sched/fair.c: In function ‘task_numa_work’: kernel/sched/fair.c:932:55: error: call to ‘__build_bug_failed’ declared with attribute error: BUILD_BUG failed The problem is that HPAGE_PMD_SHIFT triggers a BUILD_BUG() on !CONFIG_TRANSPARENT_HUGEPAGE. This patch addresses the problem. Reported-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-16mm: fix kernel BUG at huge_memory.c:1474!Hugh Dickins
Andrea's autonuma-benchmark numa01 hits kernel BUG at huge_memory.c:1474! in change_huge_pmd called from change_protection from change_prot_numa from task_numa_work. That BUG, introduced in the huge zero page commit cad7f613c4d0 ("thp: change_huge_pmd(): make sure we don't try to make a page writable") was trying to verify that newprot never adds write permission to an anonymous huge page; but Automatic NUMA Balancing's 4b10e7d562c9 ("mm: mempolicy: Implement change_prot_numa() in terms of change_protection()") adds a new prot_numa path into change_huge_pmd(), which makes no use of the newprot provided, and may retain the write bit in the pmd. Just move the BUG_ON(pmd_write(entry)) up into the !prot_numa block. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-16Merge tag 'mfd-3.8-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 Pull MFS update from Samuel Ortiz: "This is the MFD patch set for the 3.8 merge window. We have several new drivers, most of the time coming with their sub devices drivers: - Austria Microsystem's AS3711 - Nano River's viperboard - TI's TPS80031, AM335x TS/ADC, - Realtek's MMC/memstick card reader - Nokia's retu We also got some notable cleanups and improvements: - tps6586x got converted to IRQ domains. - tps65910 and tps65090 moved to the regmap IRQ API. - STMPE is now Device Tree aware. - A general twl6040 and twl-core cleanup, with moves to the regmap I/O and IRQ APIs and a conversion to the recently added PWM framework. - sta2x11 gained regmap support. Then the rest is mostly tiny cleanups and fixes, among which we have Mark's wm5xxx and wm8xxx patchset." Far amount of annoying but largely trivial conflicts. Many due to __devinit/exit removal, others due to one or two of the new drivers also having come in through another tree. * tag 'mfd-3.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (119 commits) mfd: tps6507x: Convert to devm_kzalloc mfd: stmpe: Update DT support for stmpe driver mfd: wm5102: Add readback of DSP status 3 register mfd: arizona: Log if we fail to create the primary IRQ domain mfd: tps80031: MFD_TPS80031 needs to select REGMAP_IRQ mfd: tps80031: Add terminating entry for tps80031_id_table mfd: sta2x11: Fix potential NULL pointer dereference in __sta2x11_mfd_mask() mfd: wm5102: Add tuning for revision B mfd: arizona: Defer patch initialistation until after first device boot mfd: tps65910: Fix wrong ack_base register mfd: tps65910: Remove unused data mfd: stmpe: Get rid of irq_invert_polarity mfd: ab8500-core: Fix invalid free of devm_ allocated data mfd: wm5102: Mark DSP memory regions as volatile mfd: wm5102: Correct default for LDO1_CONTROL_2 mfd: arizona: Register haptics devices mfd: wm8994: Make current device behaviour the default mfd: tps65090: MFD_TPS65090 needs to select REGMAP_IRQ mfd: Fix stmpe.c build when OF is not enabled mfd: jz4740-adc: Use devm_kzalloc ...
2012-12-16Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu Pull m68knommu updates from Greg Ungerer: "This one has a major restructuring of the non-mmu 68000 support. It merges all the related SoC types that use the original 68000 cpu core internally so they can share the same core code. It also allows for supporting the original stand alone 68000 cpu in its own right. There is also a generalization of the clock support of the ColdFire parts, some merging of common ColdFire code, and a couple of bug fixes as well." * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu: m68knommu: modify clock code so it can be used by all ColdFire CPU types m68knommu: add clock definitions for 54xx ColdFire CPU types m68knommu: add clock definitions for 5407 ColdFire CPU types m68knommu: add clock definitions for 5307 ColdFire CPU types m68knommu: add clock definitions for 528x ColdFire CPU types m68knommu: add clock definitions for 527x ColdFire CPU types m68knommu: add clock definitions for 5272 ColdFire CPU types m68knommu: add clock definitions for 525x ColdFire CPU types m68knommu: add clock definitions for 5249 ColdFire CPU types m68knommu: add clock definitions for 523x ColdFire CPU types m68knommu: add clock definitions for 5206 ColdFire CPU types m68knommu: add clock creation support macro for other ColdFire CPUs m68k: fix unused variable warning in mempcy.c m68knommu: make non-MMU page_to_virt() return a void * m68knommu: merge ColdFire 5249 and 525x definitions m68knommu: disable MC68000 cpu target when MMU is selected m68knommu: allow for configuration of true 68000 based systems m68knommu: platform code merge for 68000 core cpus
2012-12-16Merge branch 'i2c-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging Pull i2c update from Jean Delvare: "This is my last pull request for the i2c subsystem. It includes all the patches I collected between kernel v3.7-rc1 and me passing i2c maintenance duties over to Wolfram. Future patches to the many i2c bus drivers I still maintain will go through Wolfram's tree." * 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: i2c: Mention functionality flags in SMBus protocol documentation i2c-piix4: Convert dev_printk(KERN_<LEVEL> to dev_<level>( i2c-i801: Enable interrupts for all post-ICH5 chips i2c-i801: Add device tree support MAINTAINERS: Fix drivers/i2c/busses/i2c-stub.c
2012-12-16Merge tag 'stable/for-linus-3.8-rc0-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb Pull swiotlb update from Konrad Rzeszutek Wilk: "Feature: - Use dma addresses instead of the virt_to_phys and vice versa functions. Remove the multitude of phys_to_virt/virt_to_phys calls and instead operate on the physical addresses instead of virtual in many of the internal functions. This does provide a speed up in interrupt handlers that do DMA operations and use SWIOTLB." * tag 'stable/for-linus-3.8-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb: swiotlb: Do not export swiotlb_bounce since there are no external consumers swiotlb: Use physical addresses instead of virtual in swiotlb_tbl_sync_single swiotlb: Use physical addresses for swiotlb_tbl_unmap_single swiotlb: Return physical addresses when calling swiotlb_tbl_map_single swiotlb: Make io_tlb_overflow_buffer a physical address swiotlb: Make io_tlb_start a physical address instead of a virtual one swiotlb: Make io_tlb_end a physical address instead of a virtual one
2012-12-16Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 update from Ted Ts'o: "There are two major features for this merge window. The first is inline data, which allows small files or directories to be stored in the in-inode extended attribute area. (This requires that the file system use inodes which are at least 256 bytes or larger; 128 byte inodes do not have any room for in-inode xattrs.) The second new feature is SEEK_HOLE/SEEK_DATA support. This is enabled by the extent status tree patches, and this infrastructure will be used to further optimize ext4 in the future. Beyond that, we have the usual collection of code cleanups and bug fixes." * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (63 commits) ext4: zero out inline data using memset() instead of empty_zero_page ext4: ensure Inode flags consistency are checked at build time ext4: Remove CONFIG_EXT4_FS_XATTR ext4: remove unused variable from ext4_ext_in_cache() ext4: remove redundant initialization in ext4_fill_super() ext4: remove redundant code in ext4_alloc_inode() ext4: use sync_inode_metadata() when syncing inode metadata ext4: enable ext4 inline support ext4: let fallocate handle inline data correctly ext4: let ext4_truncate handle inline data correctly ext4: evict inline data out if we need to strore xattr in inode ext4: let fiemap work with inline data ext4: let ext4_rename handle inline dir ext4: let empty_dir handle inline dir ext4: let ext4_delete_entry() handle inline data ext4: make ext4_delete_entry generic ext4: let ext4_find_entry handle inline data ext4: create a new function search_dir ext4: let ext4_readdir handle inline data ext4: let add_dir_entry handle inline data properly ...
2012-12-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "A quiet cycle for the security subsystem with just a few maintenance updates." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: Smack: create a sysfs mount point for smackfs Smack: use select not depends in Kconfig Yama: remove locking from delete path Yama: add RCU to drop read locking drivers/char/tpm: remove tasklet and cleanup KEYS: Use keyring_alloc() to create special keyrings KEYS: Reduce initial permissions on keys KEYS: Make the session and process keyrings per-thread seccomp: Make syscall skipping and nr changes more consistent key: Fix resource leak keys: Fix unreachable code KEYS: Add payload preparsing opportunity prior to key instantiate or update
2012-12-16ARM: OMAP: Fix drivers to depend on omap for internal devicesTony Lindgren
These devices are not available on other architectures, so let's limit them to omap. If the driver subsystem maintainers want to build test system wide changes without building for each target, it's easy to carry a test patch that just strips out the depends entries from Kconfig files. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-16Merge tag 'balancenuma-v11' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mel/linux-balancenuma Pull Automatic NUMA Balancing bare-bones from Mel Gorman: "There are three implementations for NUMA balancing, this tree (balancenuma), numacore which has been developed in tip/master and autonuma which is in aa.git. In almost all respects balancenuma is the dumbest of the three because its main impact is on the VM side with no attempt to be smart about scheduling. In the interest of getting the ball rolling, it would be desirable to see this much merged for 3.8 with the view to building scheduler smarts on top and adapting the VM where required for 3.9. The most recent set of comparisons available from different people are mel: https://lkml.org/lkml/2012/12/9/108 mingo: https://lkml.org/lkml/2012/12/7/331 tglx: https://lkml.org/lkml/2012/12/10/437 srikar: https://lkml.org/lkml/2012/12/10/397 The results are a mixed bag. In my own tests, balancenuma does reasonably well. It's dumb as rocks and does not regress against mainline. On the other hand, Ingo's tests shows that balancenuma is incapable of converging for this workloads driven by perf which is bad but is potentially explained by the lack of scheduler smarts. Thomas' results show balancenuma improves on mainline but falls far short of numacore or autonuma. Srikar's results indicate we all suffer on a large machine with imbalanced node sizes. My own testing showed that recent numacore results have improved dramatically, particularly in the last week but not universally. We've butted heads heavily on system CPU usage and high levels of migration even when it shows that overall performance is better. There are also cases where it regresses. Of interest is that for specjbb in some configurations it will regress for lower numbers of warehouses and show gains for higher numbers which is not reported by the tool by default and sometimes missed in treports. Recently I reported for numacore that the JVM was crashing with NullPointerExceptions but currently it's unclear what the source of this problem is. Initially I thought it was in how numacore batch handles PTEs but I'm no longer think this is the case. It's possible numacore is just able to trigger it due to higher rates of migration. These reports were quite late in the cycle so I/we would like to start with this tree as it contains much of the code we can agree on and has not changed significantly over the last 2-3 weeks." * tag 'balancenuma-v11' of git://git.kernel.org/pub/scm/linux/kernel/git/mel/linux-balancenuma: (50 commits) mm/rmap, migration: Make rmap_walk_anon() and try_to_unmap_anon() more scalable mm/rmap: Convert the struct anon_vma::mutex to an rwsem mm: migrate: Account a transhuge page properly when rate limiting mm: numa: Account for failed allocations and isolations as migration failures mm: numa: Add THP migration for the NUMA working set scanning fault case build fix mm: numa: Add THP migration for the NUMA working set scanning fault case. mm: sched: numa: Delay PTE scanning until a task is scheduled on a new node mm: sched: numa: Control enabling and disabling of NUMA balancing if !SCHED_DEBUG mm: sched: numa: Control enabling and disabling of NUMA balancing mm: sched: Adapt the scanning rate if a NUMA hinting fault does not migrate mm: numa: Use a two-stage filter to restrict pages being migrated for unlikely task<->node relationships mm: numa: migrate: Set last_nid on newly allocated page mm: numa: split_huge_page: Transfer last_nid on tail page mm: numa: Introduce last_nid to the page frame sched: numa: Slowly increase the scanning period as NUMA faults are handled mm: numa: Rate limit setting of pte_numa if node is saturated mm: numa: Rate limit the amount of memory that is migrated between nodes mm: numa: Structures for Migrate On Fault per NUMA migration rate limiting mm: numa: Migrate pages handled during a pmd_numa hinting fault mm: numa: Migrate on reference policy ...
2012-12-16i2c: Mention functionality flags in SMBus protocol documentationJean Delvare
While the mapping between I2C adapter functionality flags and i2c_smbus_*() helper functions is rather obvious, let's still document it for clarity. Also drop the reference to 2 command byte I2C block reads, there is no support for that in the kernel at the moment. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-12-16i2c-piix4: Convert dev_printk(KERN_<LEVEL> to dev_<level>(Joe Perches
dev_<level> calls take less code than dev_printk(KERN_<LEVEL> and reducing object size is good. Coalesce formats for easier grep. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-12-16i2c-i801: Enable interrupts for all post-ICH5 chipsJean Delvare
I did not receive a single bug report after interrupt support was added for a limited number of chips. So I'd say the code is good and should be enabled for all supported chips, that is: ICH5 and later. Signed-off-by: Jean Delvare <khali@linux-fr.org> Reviewed-by: Daniel Kurtz <djkurtz@chromium.org>
2012-12-16i2c-i801: Add device tree supportThierry Reding
Add support for probing slave devices parsed from the device tree. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-12-16MAINTAINERS: Fix drivers/i2c/busses/i2c-stub.cCesar Eduardo Barros
This file was moved to drivers/i2c/i2c-stub.c by commit 31d178b (i2c-stub: Move to drivers/i2c). Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-12-16Merge branch 'drm-intel-fixes' of ↵Dave Airlie
git://people.freedesktop.org/~danvet/drm-intel into drm-next Daniel writes: A few leftover fixes for 3.8: - VIC support for hdmi infoframes with the associated drm helper, fixes some black TVs (Paulo Zanoni) - Modeset state check (and fixup if the BIOS messed with the hw) for lid-open. modeset-rework fallout. Somehow the original reporter went awol, so this stalled for way too long until we've found a new victim^Wreporter with broken BIOS. - seqno wrap fixes from Mika and Chris. - Some minor fixes all over from various people. - Another race fix in the pageflip vs. unpin code from Chris. - hsw vga resume support and a few more fdi link fixes (only used for vga on hsw) from Paulo. - Regression fix for DMAR from Zhenyu Wang - I've scavenged memory from my DMAR for a while and it broke right away :( - Regression fix from Takashi Iwai for ivb lvds - some w/a needs to be (partially) moved back into place. Note that these are regressions in -next. - One more fix for ivb 3 pipe support - it now actually seems to work. * 'drm-intel-fixes' of git://people.freedesktop.org/~danvet/drm-intel: (25 commits) drm/i915: Fix missed needs_dmar setting drm/i915: Fix shifted screen on top of LVDS on IVY laptop drm/i915: disable cpt phase pointer fdi rx workaround drm/i915: set the LPT FDI RX polarity reversal bit when needed drm/i915: add lpt_init_pch_refclk drm/i915: add support for mPHY destination on intel_sbi_{read, write} drm/i915: reject modes the LPT FDI receiver can't handle drm/i915: fix hsw_fdi_link_train "retry" code drm/i915: Close race between processing unpin task and queueing the flip drm/i915: fixup l3 parity sysfs access check drm/i915: Clear the existing watermarks for g4x when modifying the cursor sr drm/i915: do not access BLC_PWM_CTL2 on pre-gen4 hardware drm/i915: Don't allow ring tail to reach the same cacheline as head drm/i915: Decouple the object from the unbound list before freeing pages drm/i915: Set sync_seqno properly after seqno wrap drm/i915: Include the last semaphore sync point in the error-state drm/i915: Rearrange code to only have a single method for waiting upon the ring drm/i915: Simplify flushing activity on the ring drm/i915: Preallocate next seqno before touching the ring drm/i915: force restore on lid open ...
2012-12-16Merge branch 'exynos-drm-next' of ↵Dave Airlie
git://git.kernel.org/pub/scm/linux/kernel/git/daeinki/drm-exynos into drm-next Inki writes: "- add dmabuf attach/detach feature . This patch would resolve performance deterioration issue when v4l2-based driver is using the buffer imported from gem. - drm/exynos: use DMA_ATTR_NO_KERNEL_MAPPING attribute . With gem allocation, kernel space mapping isn't allocated and also physical pages aren't mapped with the kernel space. The physical pages are mapped with kernel space though vmap function only for console framebuffer. - add the below two patches I missed. drm: exynos: moved exynos drm device registration to drm driver drm: exynos: moved exynos drm hdmi device registration to drm driver - add IPP subsystem framework and its-based device drivers. . This patch set includes fimc, rotator and gsc drivers to perform image scaling, rotation and color space conversion. - add runtime pm support to hdmi driver. - And fixups and cleanups." * 'exynos-drm-next' of git://git.kernel.org/pub/scm/linux/kernel/git/daeinki/drm-exynos: (30 commits) drm/exynos: add gsc ipp driver drm/exynos: add rotator ipp driver drm/exynos: add fimc ipp driver drm/exynos: add iommu support for ipp drm/exynos: add ipp subsystem drm/exynos: support device tree for fimd drm/exynos: support extended screen coordinate of fimd drm/exynos: fix x, y coordinates for right bottom pixel drm/exynos: fix fb offset calculation for plane drm/exynos: hdmi: Fix potential NULL pointer dereference error drm/exynos: hdmi: Add CONFIG_OF and use of_match_ptr() macro drm/exynos: add support for hdmiphy power control for exynos5 drm/exynos: add runtime pm support for mixer drm/exynos: added runtime pm support for hdmi drm/exynos: fix allocation and cache mapping type drm/exynos: reorder framebuffer init sequence drm/exynos/iommu: fix return value check in drm_create_iommu_mapping() drm/exynos: remove unused vaddr member drm/exynos: use DMA_ATTR_NO_KERNEL_MAPPING attribute drm/exynos: add exception codes to exynos_drm_fbdev_create() ...
