2005-10-30[PATCH] cfq-iosched: move tasklist walk to elevator.cChristoph Hellwig
We're trying to get rid of as much as possible tasklist walks, or at least moving them to core code. This patch falls into the second category. Instead of walking the tasklist in cfq-iosched move that into elv_unregister. The added benefit is that with this change the as ioscheduler might be might unloadable more easily aswell. The new code uses read_lock instead of read_lock_irq because the tasklist_lock only needs irq disabling for writers. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] introduce setup_timer() helperOleg Nesterov
Every user of init_timer() also needs to initialize ->function and ->data fields. This patch adds a simple setup_timer() helper for that. The schedule_timeout() is patched as an example of usage. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] little de_thread() cleanupOleg Nesterov
Trivial, saves one 'if' branch in de_thread(). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] reiserfs: [kv]free() checking cleanupJames Lamanna
Signed-off-by: James Lamanna <jlamanna@gmail.com> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] ext3: Fix unmapped buffers in transaction's listsJan Kara
Fix the problem (BUG 4964) with unmapped buffers in transaction's t_sync_data list. The problem is we need to call filesystem's own invalidatepage() from block_write_full_page(). block_write_full_page() must call filesystem's invalidatepage(). Otherwise following nasty race can happen: proc 1 proc 2 ------ ------ - write some new data to 'offset' => bh gets to the transactions data list - starts truncate => i_size set to new size - mpage_writepages() - ext3_ordered_writepage() to 'offset' - block_write_full_page() - page->index > end_index+1 - block_invalidatepage() - discard_buffer() - clear_buffer_mapped() - commit triggers and finds unmapped buffer - BOOM! Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] smsc-ircc2: PM cleanup - do not close device when suspendingDmitry Torokhov
smsc-ircc2 - avoid closing network device when suspending; just release interrupt and disable DMA ourselves. Also make sure to reset chip when resuming. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Cc: Jean Tourrilhes <jt@bougret.hpl.hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] ide-scsi highmem cleanupAndrew Morton
It's not necessary to test PageHighmem in here - kmap_atomic() does the right thing. Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] s390, ccw - export modaliasBastian Blank
This patch exports modalias for ccw devices. So you can do: modprobe `echo /sys/device/path_to_device/modalias` and the proper driver will automatically be loaded by userspace. Signed-off-by: Bastian Blank <waldi@debian.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] s390: export ipl device parametersHeiko Carstens
Sysfs interface to export ipl device parameters. Dependent on the ipl type the interface will look like this: - ccw ipl: /sys/firmware/ipl/device /ipl_type - fcp ipl: /sys/firmware/ipl/binary_parameter /bootprog /br_lba /device /ipl_type /lun /scp_data /wwpn - otherwise (unknown that is): /sys/firmware/ipl/ipl_type Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] s390: 3270 fullscreen viewRichard Hitt
Martin Schwidefsky <schwidefsky@de.ibm.com> Fix fullscreen view of the 3270 device driver. Signed-off-by: Richard Hitt <rbh00@utsglobal.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] i386: use -mcpu, not -mtune, for GCCs older than 3.4Paolo 'Blaisorblade' Giarrusso
I just noted that -mtune is used, which is only supported on recent GCCs; by reading http://gcc.gnu.org/gcc-3.4/changes.html, you see "-mcpu has been renamed to -mtune.", so for GCC < 3.4 we're not using any specific tuning in the appropriate cases. However -mcpu is deprecated, so use -mtune when possible. This was introduced by commit e9d4dce954a60dc23dd1d967766ca2347b780e54 of the old tree (between 2.6.10-rc3 and 2.6.10) by Linus Torvalds, to remove the use of -march, since that could trigger gcc using SSE on its own. But no attention was used about using -mcpu vs. -mtune. And btw, the old 2.6.4 code (for instance) was: cflags-$(CONFIG_MPENTIUMII) += $(call check_gcc,-march=pentium2,-march=i686) cflags-$(CONFIG_MPENTIUMIII) += $(call check_gcc,-march=pentium3,-march=i686) cflags-$(CONFIG_MPENTIUMM) += $(call check_gcc,-march=pentium3,-march=i686) cflags-$(CONFIG_MPENTIUM4) += $(call check_gcc,-march=pentium4,-march=i686) Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] uml: remove old UM_FASTCALL, and make the thing work againPaolo 'Blaisorblade' Giarrusso
This was used in the old dark age of 2.4, ARCH_CFLAGS doesn't work any more since some time, and UM_FASTCALL was never used in 2.6. Instead, reintroduce the thing more properly now, directly in include/asm-um/linkage.h. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] uml: fix "reuse i386 cpu optimizations"Paolo 'Blaisorblade' Giarrusso
Remove RWSEM_GENERIC_SPINLOCK, it's now defined (only if needed) by the underlying arch/i386/Kconfig.cpu. Leave it only for x86_64. Even there, it's totally wrong, as they even have the code to support XCHG_ADD. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] uml: reuse i386 cpu-specific tuningPaolo 'Blaisorblade' Giarrusso
Make UML share the underlying cpu-specific tuning done on i386. Actually, for now many config options aren't used a lot - but that can be done later. Also, UML relies on GCC optimization for things like memcpy and such more than i386, so specifying the correct -march and -mtune should be enough. Later, we may want to correct some other stuff. For instance, since FPU context switching, for us, is done (at least partially, i.e. between our kernelspace and userspace) by the host, we may allow usage of FPU operations by GCC. This doesn't hold for kernelspace vs. kernelspace, but we don't support preemption. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] m32r: SMC91x driver updateHirokazu Takata
Update SMC91x driver for m32r. - Remove needless NONCACHE_OFFSET adjustment. > [PATCH 2.6.14-rc4] m32r: NONCACHE_OFFSET in _port2addr > Change _port2addr() not to add NONCACHE_OFFSET. > Adding NONCACHE_OFFSET requires needless address adjusting by a driver > using ioremap() like a SMC91x driver. - Fix lots of warnings as following: /usr/src/ctest/git/kernel/drivers/net/smc91x.c: In function `smc_reset': /usr/src/ctest/git/kernel/drivers/net/smc91x.c:324: warning: passing arg 2 of `_outw' makes integer from pointer without a cast /usr/src/ctest/git/kernel/drivers/net/smc91x.c:325: warning: passing arg 2 of `_outw' makes integer from pointer without a cast /usr/src/ctest/git/kernel/drivers/net/smc91x.c:341: warning: passing arg 2 of `_outw' makes integer from pointer without a cast /usr/src/ctest/git/kernel/drivers/net/smc91x.c:342: warning: passing arg 2 of `_outw' makes integer from pointer without a cast : /usr/src/ctest/git/kernel/drivers/net/smc91x.c:1915: warning: passing arg 1 of `_inw' makes integer from pointer without a cast /usr/src/ctest/git/kernel/drivers/net/smc91x.c:1915: warning: passing arg 1 of `_inw' makes integer from pointer without a cast Signed-off-by: Hayato Fujiwara <fujiwara@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] m32r: NONCACHE_OFFSET in _port2addrHirokazu Takata
Change _port2addr() not to add NONCACHE_OFFSET. Adding NONCACHE_OFFSET requires needless address adjusting by a driver using ioremap() like a SMC91x driver. Signed-off-by: Hayato Fujiwara <fujiwara@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] m32r: fix #if warningsHirokazu Takata
Fix warnings for #if directives. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] m32r: remove unused instructionsHirokazu Takata
Remove unused instructions for debugging. Signed-off-by: Naoto Sugai <sugai@isl.melco.co.jp> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] introduce .valid callback for pm_opsShaohua Li
Add pm_ops.valid callback, so only the available pm states show in /sys/power/state. And this also makes an earlier states error report at enter_state before we do actual suspend/resume. Signed-off-by: Shaohua Li<shaohua.li@intel.com> Acked-by: Pavel Machek<pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] swsusp: two simplificationsRafael J. Wysocki
The following patch simplifies the progress meter in disk.c:free_some_memory() and makes disk.c:pm_suspend_disk() call device_resume() explicitly in the suspend path. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] swsusp: get rid of unnecessary wrapper functionRafael J. Wysocki
The following patch merges two functions in a trivial way. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] swsusp: cleanupsPavel Machek
Reduce number of ifdefs somehow, and fix whitespace a bit. No real code changes. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] swsusp: remove unneccessary includesPavel Machek
Cleanup comments and remove unneccessary includes. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] swsusp: rework memory freeing on resumeRafael J. Wysocki
The following patch makes swsusp use the PG_nosave and PG_nosave_free flags to mark pages that should be freed in case of an error during resume. This allows us to simplify the code and to use swsusp_free() in all of the swsusp's resume error paths, which makes them actually work. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] swsusp: reduce the use of global variablesRafael J. Wysocki
2005-10-30[PATCH] swsusp: move snapshot functionality to separate fileRafael J. Wysocki
The following patch moves the functionality of swsusp related to creating and handling the snapshot of memory to a separate file, snapshot.c This should enable us to untangle the code in the future and eventually to implement some parts of swsusp.c in the user space. The patch does not change the code. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] swsusp: rework image freeingRafael J. Wysocki
The following patch makes swsusp use PG_nosave and PG_nosave_free flags to mark pages that should be freed after the state of the system has been restored from the image (or in case of an error during suspend). This allows us to avoid storing metadata in swap twice and to reduce the amount of memory needed by swsusp.  Additionally, it allows us to simplify the code by removing a couple of functions that are no longer necessary. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] create and destroy cpufreq sysfs entries based on cpu notifiersAshok Raj
cpufreq entries in sysfs should only be populated when CPU is online state. When we either boot with maxcpus=x and then boot the other cpus by echoing to sysfs online file, these entries should be created and destroyed when CPU_DEAD is notified. Same treatement as cache entries under sysfs. We place the processor in the lowest frequency, so hw managed P-State transitions can still work on the other threads to save power. Primary goal was to just make these directories appear/disapper dynamically. There is one in this patch i had to do, which i really dont like myself but probably best if someone handling the cpufreq infrastructure could give this code right treatment if this is not acceptable. I guess its probably good for the first cut. - Converting lock_cpu_hotplug()/unlock_cpu_hotplug() to disable/enable preempt. The locking was smack in the middle of the notification path, when the hotplug is already holding the lock. I tried another solution to avoid this so avoid taking locks if we know we are from notification path. The solution was getting very ugly and i decided this was probably good for this iteration until someone who understands cpufreq could do a better job than me. (akpm: export cpucontrol to GPL modules: drivers/cpufreq/cpufreq_stats.c now does lock_cpu_hotplug()) Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Zwane Mwaikambo <zwane@holomorphy.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] Remove cpu_sys_devices in cpufreq subsystem.Ashok Raj
cpu_sys_devices is redundant with the new API get_cpu_sysdev(). So nuking this usage since its not needed. Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Zwane Mwaikambo <zwane@holomorphy.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] create and destroy cache sysfs entries based on cpu notifiersAshok Raj
cpu cache entries should be populated only when cpu is online and removed when they are logically offlined. Without which entries are not removed when cpu is offlined, or dont appear when we boot with maxcpus=1 and then kick the rest of the cpus via echo 1 to the sysfs online file. - Changed __devinit to __cpuinit for consistency. - Changed sysfs_driver_register to register_cpu_notifier. Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Zwane Mwaikambo <zwane@holomorphy.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] introduce get_cpu_sysdev() to retrieve a sysfs entry for a cpu.Ashok Raj
Some modules creating sysfs entries under /sys/devices/system/cpu/cpuX/ need to know the parent sysfs entry to make devices under them. This will just return the sysfs entry for a given cpu. sysfs entries showing under each cpu sysfs can be easily created if such entries can be created by registering a sysfs driver for cpuclass. The issue is when the entry is created the CPU may not be online, hence we would need to defer the creation until the online notification comes. Current users: cache entries for Intel CPU's and cpufreq subsystem. Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Zwane Mwaikambo <zwane@holomorphy.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] i386: srat on non-acpi hw fixMagnus Damm
This patch adds a check for the return value of acpi_find_root_pointer(). Without this patch systems without ACPI support such as QEMU crashes when booting a NUMA kernel with CONFIG_ACPI_SRAT=y. Signed-off-by: Magnus Damm <magnus@valinux.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] i386 mpparse: Only ignore lapic information we can't storeEric W. Biederman
After staring at mpparse.c for a little longer I noticed that when we hit our limit of num_processors we are filtering out information about other processors that we can still store. This patch just reorders the code so we store everything we can. This should avoid the incorrect warning about our boot CPU not being listed by the BIOS that we are now getting in the kexec on panic case, and it should allow us to detect all apicid conflicts even when our physical number of cpus exceeds maxcpus. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] kdump/i386: apic verification failure fixVivek Goyal
o Removes the unnecessary call to local_irq_disable(). o Kdump was failing while second kernel was coming up. Check for presence of boot cpu apic id was failing in (apic_id_registered), hence hitting BUG(). o This should not have failed because before calling setup_local_APIC(), it is ensured that even if BIOS has not reported boot cpu, then hard set the prence of it. Problem happens because of usage of hard_smp_processor_id() which is hardcoded to zero in case of non SMP kernel. In kdump case second kernel can boot on a cpu whose boot cpu id is not zero. o Using boot_cpu_physical_apicid instead to hard set the presence of boot cpu. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] x86: inline spin_unlock if !CONFIG_DEBUG_SPINLOCK and !CONFIG_PREEMPTIngo Molnar
Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] Clean up mtrr compat ioctl codeBrian Gerst
Handle 32-bit mtrr ioctls in the mtrr driver instead of the ia32 compatability layer. Signed-off-by: Brian Gerst <bgerst@didntduck.org> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] x86: vmx cpu feature detectionKamble, Nitin A
If VMX feature is available in the CPU, this patch will make it visible in the /proc/cpuinfo with the cpuid detection. Signed-Off-By: Nitin A Kamble <nitin.a.kamble@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] i386 kexec-on-panic: Don't shutdown the apics.Eric W. Biederman
It is dangerous to shutdown the apics in machine_crash_shutdown. With my previous patch to initialize apics in init_IRQ we should be able to boot a kernel without this. As long as we reinitialize the APICs we don't care what state they were in during bootup. This should make machine_crash_shutdown noticeably more reliable. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] i386: move apic init in init_IRQsEric W. Biederman
All kinds of ugliness exists because we don't initialize the apics during init_IRQs. - We calibrate jiffies in non apic mode even when we are using apics. - We have to have special code to initialize the apics when non-smp. - The legacy i8259 must exist and be setup correctly, even when we won't use it past initialization. - The kexec on panic code must restore the state of the io_apics. - init/main.c needs a special case for !smp smp_init on x86 In addition to pure code movement I needed a couple of non-obvious changes: - Move setup_boot_APIC_clock into APIC_late_time_init for simplicity. - Use cpu_khz to generate a better approximation of loops_per_jiffies so I can verify the timer interrupt is working. - Call setup_apic_nmi_watchdog again after cpu_khz is initialized on the boot cpu. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] i386 nmi_watchdog: Merge check_nmi_watchdog fixes from x86_64Eric W. Biederman
The per cpu nmi watchdog timer is based on an event counter. idle cpus don't generate events so the NMI watchdog doesn't fire and the test to see if the watchdog is working fails. - Add nmi_cpu_busy so idle cpus don't mess up the test. - kmalloc prev_nmi_count to keep kernel stack usage bounded. - Improve the error message on failure so there is enough information to debug problems. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] i386 io_apic.c: Memorize at bootup where the i8259 is connectedEric W. Biederman
Currently we attempt to restore virtual wire mode on reboot, which only works if we can figure out where the i8259 is connected. This is very useful when we kexec another kernel and likely helpful when dealing with a BIOS that make assumptions about how the system is setup. Since the acpi MADT table does not provide the location where the i8259 is connected we have to look at the hardware to figure it out. Most systems have the i8259 connected the local apic of the cpu so won't be affected but people running Opteron and some serverworks chipsets should be able to use kexec now. In addition this patch removes the hard coded assumption that the io_apic that delivers isa interrups is always known to the kernel as io_apic 0. As there does not appear to be anything to guarantee that assumption is true. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] ES7000 platform updateNatalie.Protasevich@unisys.com
This is platform code update for ES7000: disables IRQ overrides for the recent ES7000 (Rascal/Zorro), cleans up the compile warning. The patch only affects the ES7000 subarch. Signed-off-by: <Natalie.Protasevich@unisys.com> Acked-by: Zwane Mwaikambo <zwane@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] x86: when L3 is present show its size in /proc/cpuinfoVenkatesh Pallipadi
The code that prints the cache size assumes that L3 always lives in chipset and is shared across CPUs. Which is not really true. I think all the cachesizes reported by cpuid are in the processor itself. The attached patch changes the code to reflect that. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] fixup bogus e820 entry with mem=Dave Hansen
This was reported because someone was getting oopses reading /proc/iomem. It was tracked down to a zero-sized 'struct resource' entry which was located right at 4GB. You need two conditions to hit this bug: a BIOS E820_RAM area starting at exactly the boundary where you specify mem= (to get a zero-sized entry), and for the legacy_init_iomem_resources() loop to skip that resource (which only happens at exactly 4G). I think the killing zero-sized e820 entry is the easiest way to fix this. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] asus vt8235 router buggy bios workaroundaleksey_gorelov@phoenix.com
Hopefully fix http://bugzilla.kernel.org/show_bug.cgi?id=5235 Similar problem has been reported before here: http://groups.google.com/group/linux.kernel/browse_thread/thread/def4ca19dbc3cd4/5cffbf349f2c87a4?tvc=2&q=Aleksey+Gorelov&hl=en#5cffbf349f2c87a4 and was related to bug in BIOS reporting 82C686 router compatible to 586. I suspect BIOS on this board has similar issue: reports VT8235 router to be compatible with 586 one - which is obviously not true. Patch from the link above has already incorporated in both 2.6 & 2.4 series, but might not work in this particular case. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] x86: bug fix in P6 Machine check initializationVenkatesh Pallipadi
Make P6 MCA initialization code complaint with guidelines in IA-32 SDM Vol3. Bank 0 control register should not be set by OS and clear status registers on all banks on reset. This will prevent false MCE alarms on the systems that has some non-MCE information left-over in MC0_STATUS on reboot. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] x86: add an accessor function for getting the per-CPU gdtZachary Amsden
Add an accessor function for getting the per-CPU gdt. Callee must already have the CPU. Signed-off-by: Zachary Amsden <zach@vmware.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] x86: bogus tls from gdtZachary Amsden
The per-CPU initialization code is copying in bogus data into thread->tls_array. Note that it copies &per_cpu(cpu_gdt_table, cpu), not &per_cpu(cpu_gdt_table, cpu)[GDT_ENTRY_TLS_MIN). That is totally broken and unnecessary. Make the initialization explicitly NULL. Signed-off-by: Zachary Amsden <zach@vmware.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] x86: hot plug CPU to support physical add of new processorsNatalie Protasevich
The patch allows physical bring-up of new processors (not initially present in the configuration) from facilities such as driver/utility implemented on a platform. The actual method of making processors available is up to the platform implementation. Signed-off-by: Natalie Protasevich <Natalie.Protasevich@unisys.com> Cc: Shaohua Li <shaohua.li@intel.com> Cc: Ashok Raj <ashok.raj@intel.com> Cc: Zwane Mwaikambo <zwane@holomorphy.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] i386: little pgtable.h consolidation vs 2/3levelPaolo 'Blaisorblade' Giarrusso
Join together some common functions (pmd_page{,_kernel}) over 2level and 3level pages. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
