SGI-PV: 981498
SGI-Modid: xfs-linux-melb:xfs-kern:31758a
Signed-off-by: Eric Sandeen <sandeen@sandeen.net>
Signed-off-by: Niv Sardi <xaiki@sgi.com>
Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
Looks like somehow xfs got missed in the conversion that took place in
e231c2ee64eb1c5cd3c63c31da9dac7d888dcf7f, "Convert ERR_PTR(PTR_ERR(p))
instances to ERR_CAST(p)
<http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commit
diff;h=e231c2ee64eb1c5cd3c63c31da9dac7d888dcf7f>"
SGI-PV: 981498
SGI-Modid: xfs-linux-melb:xfs-kern:31757a
Signed-off-by: Christoph Hellwig <hch@infradead.org>
Thanks to hch's endian work, INT_GET etc are no longer used, and may as
well be removed. INT_SET is still used in the acl code, though.
SGI-PV: 981498
SGI-Modid: xfs-linux-melb:xfs-kern:31756a
Move it from the attr code to the transaction code and make
the attr code call the new function.
We rolltrans is really usefull whenever we want to use rolling
transaction, should be generic, it isn't dependent on any part
of the attr code anyway.
We use this excuse to change all the:
if ((error = xfs_attr_rolltrans()))
calls into:
error = xfs_trans_roll();
if (error)
SGI-PV: 981498
SGI-Modid: xfs-linux-melb:xfs-kern:31729a
Add a helper to free the m_fsname/m_rtname/m_logname allocations and use
it properly for all mount failure cases. Also switch the allocations for
these to kstrdup while we're at it.
SGI-PV: 981498
SGI-Modid: xfs-linux-melb:xfs-kern:31728a
Signed-off-by: David Chinner <david@fromorbit.com>
We will need that to be able to calculate the size of log we need for a
specific attr (for Create+EA). The local flag is needed so that we can
fail if we run into ENOSPC when trying to alloc blocks.
SGI-PV: 981498
SGI-Modid: xfs-linux-melb:xfs-kern:31727a
Signed-off-by: Tim Shimmin <tes@sgi.com>
If we allow incore extent tree allocations to recurse into the
filesystem under memory pressure, new delayed allocations through
xfs_iomap_write_delay() can deadlock on themselves if memory
reclaim tries to write back dirty pages from that inode.
It will deadlock in xfs_iomap_write_allocate() trying to take the
ilock we already hold. This can also show up as complex ABBA deadlocks
when multiple threads are triggering memory reclaim when trying to
allocate extents.
The main cause of this is the fact that delayed allocation is not done in
a transaction, so KM_NOFS is not automatically added to the allocations to
prevent this recursion.
Mark all allocations done for the incore inode extent tree as KM_NOFS to
ensure they never recurse back into the filesystem.
Version 2: o KM_NOFS implies KM_SLEEP, so just use KM_NOFS
SGI-PV: 981498
SGI-Modid: xfs-linux-melb:xfs-kern:31726a
xfs_vtoi() is redundant and only unsed in small sections of code.
Replace them with widely used XFS_I() inline and kill xfs_vtoi().
SGI-PV: 981498
SGI-Modid: xfs-linux-melb:xfs-kern:31725a
Replace XFS_ITOV() with the new VFS_I() inline.
SGI-PV: 981498
SGI-Modid: xfs-linux-melb:xfs-kern:31724a
Replace XFS_ITOV_NULL() with the new VFS_I() inline.
SGI-PV: 981498
SGI-Modid: xfs-linux-melb:xfs-kern:31722a
In several places we directly convert from the XFS inode
to the linux (VFS) inode by a simple deference of ip->i_vnode.
We should not do this - a helper function should be used to
extract the VFS inode from the XFS inode.
Introduce the function VFS_I() to extract the VFS inode
from the XFS inode. The name was chosen to match XFS_I() which
is used to extract the XFS inode from the VFS inode.
SGI-PV: 981498
SGI-Modid: xfs-linux-melb:xfs-kern:31720a
We should not access a buffer after dropping it's reference count
otherwise we could race with another thread that releases the final
reference count and frees the buffer causing us to access potentially
unmapped memory. The bug this change fixes only occured on DEBUG XFS since
the offending code was in an ASSERT.
SGI-PV: 984429
SGI-Modid: xfs-linux-melb:xfs-kern:31715a
This keeps xfs_lowbit64 as it was since there aren't good generic helpers
there ... Patch inspired by Andi Kleen.
SGI-PV: 981498
SGI-Modid: xfs-linux-melb:xfs-kern:31472a
Signed-off-by: Donald Douwsma <donaldd@sgi.com>
* 'for-linus' of git://git.o-hand.com/linux-mfd:
mfd: tc6393 cleanup and update
mfd: have TMIO drivers and subdevices depend on ARM
mfd: TMIO MMC driver
mfd: driver for the TMIO NAND controller
mfd: t7l66 MMC platform data
mfd: tc6387 MMC platform data
mfd: Fix 7l66 and 6387 according to the new mfd-core API
mfd: Fix tc6393 according to the new tmio.h
mfd: driver for the TC6387XB TMIO controller.
mfd: driver for the T7L66XB TMIO SoC
mfd: TMIO MMC structures and accessors.
* 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6:
hwmon: (lm75) Drop legacy i2c driver
i2c: correct some size_t printk formats
i2c: Check for address business before creating clients
i2c: Let users select algorithm drivers manually again
i2c: Fix NULL pointer dereference in i2c_new_probed_device
i2c: Fix oops on bus multiplexer driver loading
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog:
[WATCHDOG] pcwd.c - fix open_allowed type.
[WATCHDOG] fix watchdog/ixp4xx_wdt.c compilation
[WATCHDOG] fix watchdog/wdt285.c compilation
[WATCHDOG] fix watchdog/at91rm9200_wdt.c compilation
[WATCHDOG] fix watchdog/shwdt.c compilation
[WATCHDOG] fix watchdog/txx9wdt.c compilation
[WATCHDOG] MAINTAINERS: remove ZF MACHZ WATCHDOG entry
[WATCHDOG] Fix build with CONFIG_ITCO_VENDOR_SUPPORT=n
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc:
powerpc: Remove include/linux/harrier_defs.h
powerpc: Do not ignore arch/powerpc/include
powerpc: Delete completed "ppc removal" task from feature removal file
powerpc/mm: Fix attribute confusion with htab_bolt_mapping()
powerpc/pci: Don't keep ISA memory hole resources in the tree
powerpc: Zero fill the return values of rtas argument buffer
powerpc/4xx: Update defconfig files for 2.6.27-rc1
powerpc/44x: Incorrect NOR offset in Warp DTS
powerpc/44x: Warp DTS changes for board updates
powerpc/4xx: Cleanup Warp for i2c driver changes.
powerpc/44x: Adjust warp-nand resource end address
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI: Limit VPD length for Broadcom 5708S
PCI PM: Export pci_pme_active to drivers
PCI: remove duplicate symbol from pci_ids.h
PCI: check the return value of device_create_bin_file() in pci_create_bus()
PCI: fully restore MSI state at resume time
DMA: make dma-coherent.c documentation kdoc-friendly
PCI: make pci_register_driver() a macro
PCI: add Broadcom 5708S to VPD length quirk
While testing our KVM code for s390 (starting and killall kvm in a loop)
I can reproduce the following oops:
Unable to handle kernel pointer dereference at virtual kernel address 6b6b6b6b6b6b6000 Oops: 0038 [#1] SMP
Modules linked in: dm_multipath sunrpc qeth_l3 qeth_l2 dm_mod qeth
ccwgroup CPU: 1 Not tainted 2.6.27-rc1 #54
Process kuli (pid: 4409, task: 00000000b6aa5940, ksp: 00000000b7343e10)
Krnl PSW : 0704e00180000000 00000000002e0b8c
(disassociate_ctty+0x1c0/0x288) R:0 T:1 IO:1 EX:1 Key:0 M:1 W:0 P:0 AS:3
CC:2 PM:0 EA:3 Krnl GPRS: 0000000000000000 6b6b6b6b6b6b6b6b
0000000000000001 00000000000003a6 00000000002e0a46 00000000004b4160
0000000000000001 00000000bbd79758 00000000b7343e58 00000000b8854148
00000000bd34dea0 00000000b7343c20 0000000000000001 00000000004b6d08
00000000002e0a46 00000000b7343c20 Krnl Code: 00000000002e0b7e:
eb9fb0a00004 lmg %r9,%r15,160(%r11) 00000000002e0b84:
07f4 bcr 15,%r4 00000000002e0b86:
e31090080004 lg %r1,8(%r9) >00000000002e0b8c:
d501109cd000 clc 156(2,%r1),0(%r13) 00000000002e0b92:
a784ff5d brc 8,2e0a4c 00000000002e0b96:
b9040029 lgr %r2,%r9 00000000002e0b9a:
c0e5fffff9c3 brasl %r14,2dff20 00000000002e0ba0:
a7f4ff56 brc 15,2e0a4c Call Trace:
([<00000000002e0a46>] disassociate_ctty+0x7a/0x288)
[<0000000000141fe6>] do_exit+0x212/0x8d4
[<0000000000142708>] do_group_exit+0x60/0xcc
[<0000000000150660>] get_signal_to_deliver+0x270/0x3ac
[<000000000010bfd6>] do_signal+0x8e/0x8dc
[<0000000000113772>] sysc_sigpending+0xe/0x22
[<000001ff0000b134>] 0x1ff0000b134
INFO: lockdep is turned off.
Last Breaking-Event-Address:
[<00000000002e0a48>] disassociate_ctty+0x7c/0x288
Kernel panic - not syncing: Fatal exception: panic_on_oops
It seems that tty was already free in disassocate_ctty when it tries
to dereference tty->driver.
After moving the lock_kernel before the mutex_unlock, I can no longer
reproduce the problem.
[ This is a temporary partial fix for the documented and long standing
race in disassociate_tty. This stops most problem cases for now.
For the next release the -next tree has an initial implementation of
kref counting for tty structures and this quickfix will be dropped.
- Alan ]
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by; Alan Cox <alan@redhat.com>
Wire up for m68k{,nommu} the system calls that were added in the last merge
window:
- 4006553b06306b34054529477b06b68a1c66249b ("flag parameters: inotify_init")
- ed8cae8ba01348bfd83333f4648dd807b04d7f08 ("flag parameters: pipe")
- 336dd1f70ff62d7dd8655228caed4c5bfc818c56 ("flag parameters: dup2")
- a0998b50c3f0b8fdd265c63e0032f86ebe377dbf ("flag parameters: epoll_create")
- 9fe5ad9c8cef9ad5873d8ee55d1cf00d9b607df0 ("flag parameters add-on: remove
epoll_create size param")
- b087498eb5605673b0f260a7620d91818cd72304 ("flag parameters: eventfd")
- 9deb27baedb79759c3ab9435a7d8b841842d56e9 ("flag parameters: signalfd")
Acked-by: Greg Ungerer <gerg@uclinux.org>
This reverts commit 2d04a4a72d7e1519b4838f24bdd4b5d0f3f426dc, which made
it impossible to make the softcursor use the highlight colors.
Yes, the fourth bit should be "blinking", but since we cannot reasonably
blink in fbcon, highlighting it with a bright background is preferable.
Reported-by: Pavel Machek <pavel@suse.cz>
Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Cc: Krzysztof Helt <krzysztof.h1@poczta.fm>
Cc: Antonino A. Daplas <adaplas@pol.net>
It was only used by code in arch/ppc, and arch/ppc is gone, so remove
the unused harrier_defs.h as well.
Back when .gitignore file was added to arch/powerpc/ in 06f2138 ([POWERPC]
Add files build to .gitignore, 2006-11-26), there indeed was nothing
tracked in the ignored hierarchy and ignoring everything made sense. But
we have very many tracked files there these days, and having a higher
level .gitignore that ignores everything is asking for future troubles..
This should have been part of b8b572e (powerpc: Move include files to
arch/powerpc/include/asm, 2008-08-01).
Signed-off-by: Junio C Hamano <gitster@pobox.com>
Acked-by: Stephen Rothwell <sfr@canb.auug.org.au>
The function htab_bolt_mapping() is used to create permanent
mappings in the MMU hash table, for example, in order to create
the linear mapping of vmemmap. It's also used by early boot
ioremap (before mem_init_done).
However, the way ioremap uses it is incorrect as it passes it the
protection flags in the "linux PTE" form while htab_bolt_mapping()
expects them in the hash table format. This is made more confusing by
the fact that some of those flags are actually in the same position in
both cases.
This fixes it all by making htab_bolt_mapping() take normal linux
protection flags instead, and use a little helper to convert them to
htab flags. Callers can now use the usual PAGE_* definitions safely.
arch/powerpc/include/asm/mmu-hash64.h | 2 -
arch/powerpc/mm/hash_utils_64.c | 65 ++++++++++++++++++++--------------
arch/powerpc/mm/init_64.c | 9 +---
3 files changed, 44 insertions(+), 32 deletions(-)
When we have an ISA memory hole (ie, a PCI window that allows us to
generate PCI memory cycles at low PCI address) mixed with other
resources using a different CPU <=> PCI mapping, we must not keep
the ISA hole in the bridge resource list.
If we do, things might start trying to allocate device resources
in there and will get the PCI addresses wrong.
This fixes it by arranging to remove the ISA memory hole resource in
this case. This fixes various cases of PCMCIA breakage on PowerBooks
using the MPC106 "grackle" bridge.
The kernel copy of the rtas args struct contains the return
value(s) for the specified rtas call. These are copied back
to user space with the assumption that every value has been
set by the rtas call, which turns out to be not always true.
Thus userspace can see random values and think the call failed
when in fact it succeeded, but for some reason didn't set one
of the return values.
This fixes the problem by zeroing out the return value fields
of the rtas args struct before processing the rtas call.
Signed-off-by: Nathan Fontenot <nfont@austin.ibm.com>
Fix following warnings:
drivers/watchdog/pcwd.c: In function 'pcwd_open':
drivers/watchdog/pcwd.c:703: warning: passing argument 2 of 'test_and_set_bit' from incompatible pointer type
drivers/watchdog/pcwd.c: In function 'pcwd_close':
drivers/watchdog/pcwd.c:723: warning: passing argument 2 of 'clear_bit' from incompatible pointer type
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
This patchset cleans up the TC6393XB support.
* Add provision for the MMC subdevice
* Disable / enable clocks on suspend / resume
* Remove fragments of badly merged code (eg. linux/fb include etc.)
* Use a device specific clock name to break dependancy on ARM/PXA2XX
* Drop unnecessary resource names
* Switch to tmio_io* accessors
Signed-off-by: Ian Molton <spyro@f2s.com>
Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
The TMIO chips are only found (and thus tested) on ARM machines.
Moreover, we don't want the TMIO cells to be built if one of the TMIO
driver is not selected (which indirectly make the TMIO cells drivers
depend on ARM as well).
This patch adds support for the MMC subdevice 'cell' commonly found in
TMIO based MFDs.
Acked-by: Pierre Ossman <drzeus@drzeus.cx>
This patch adds support for the NAND controller commonly found in
TMIO based MFDs.
Acked-By: David Woodhouse <David.Woodhouse@intel.com>
Drop the legacy lm75 driver, and add a detect callback to the
new-style driver to achieve the same functionality.
Cc: David Brownell <david-b@pacbell.net>
Fix various printk format strings where %zd was passed a size_t;
those should be %zu instead. (Courtesy of a version of GCC which
warns when these details are wrong.)
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
We check for address business in i2c_probe_address(),
i2c_detect_address() and i2c_new_probed_device(), but this isn't
sufficient. Drivers can call i2c_attach_client() and
i2c_new_device() on any address, so we must check the address there
as well.
This fixes bug #11239:
http://bugzilla.kernel.org/show_bug.cgi?id=11239
In kernel 2.6.26, the ability to select I2C algorithm drivers manually
was removed, as all in-kernel drivers do that automatically. However
there were some complaints that it was a problem for out-of-tree I2C
bus drivers. In order to address these complaints, let's allow manual
selection of these drivers again, but still hide them by default for
better general user experience.
This closes bug #11140:
http://bugzilla.kernel.org/show_bug.cgi?id=11140
Fix a NULL pointer dereference that happened when calling
i2c_new_probed_device on one of the addresses for which we use byte
reads instead of quick write for detection purpose (that is: 0x30-0x37
and 0x50-0x5f).
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
The two I2C bus multiplexer drivers (i2c-amd756-s4882 and
i2c-nforce2-s4985) make use of the bus they want to multiplex before
checking if it is really present. Swap the instructions to test for
presence first. This fixes a oops reported by Ingo Molnar.
This patch fixes the following compile error caused by
commit 20d35f3e50ea7e573f9568b9fce4e98523aaee5d
([WATCHDOG 22/57] ixp4xx_wdt: unlocked_ioctl):
<-- snip -->
CC drivers/watchdog/ixp4xx_wdt.o
ixp4xx_wdt.c:32: error: expected '=', ',', ';', 'asm' or '__attribute__'
ixp4xx_wdt.c: In function 'wdt_enable':
ixp4xx_wdt.c:41: error: 'wdt_lock' undeclared (first use in this
ixp4xx_wdt.c:41: error: (Each undeclared identifier is reported only
ixp4xx_wdt.c:41: error: for each function it appears in.)
ixp4xx_wdt.c: In function 'wdt_disable':
ixp4xx_wdt.c:52: error: 'wdt_lock' undeclared (first use in this
ixp4xx_wdt.c: In function 'ixp4xx_wdt_init':
ixp4xx_wdt.c:186: error: 'wdt_lock' undeclared (first use in this
make[3]: *** [drivers/watchdog/ixp4xx_wdt.o] Error 1
<-- snip -->
Reported-by: Adrian Bunk <bunk@kernel.org>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
commit d0e58eed05f9baf77c4f75e794ae245f6dae240a
([WATCHDOG 55/57] wdt285: switch to unlocked_ioctl and tidy up ...):
<-- snip -->
CC [M] drivers/watchdog/wdt285.o
wdt285.c: In function 'footbridge_watchdog_init':
wdt285.c:211: error: 'KERN_WARN' undeclared (first use in this function)
wdt285.c:211: error: (Each undeclared identifier is reported only once
wdt285.c:211: error: for each function it appears in.)
wdt285.c:212: error: expected ')' before string constant
make[3]: *** [drivers/watchdog/wdt285.o] Error 1
<-- snip -->
This patch fixes the following compile error:
<-- snip -->
CC drivers/watchdog/at91rm9200_wdt.o
at91rm9200_wdt.c:188: error: 'at91_wdt_ioctl' undeclared here (not in a
make[3]: *** [drivers/watchdog/at91rm9200_wdt.o] Error 1
<-- snip -->
This patch fixes the following compile errors caused by
commit 70b814ec1a484279a51bf9f7193551b996627247
([WATCHDOG 45/57] shwdt: coding style, cleanup, switch to unlocked_io):
<-- snip -->
CC drivers/watchdog/shwdt.o
shwdt.c:64: error: 'WTCSR_CKS_4096' undeclared here (not in a function)
shwdt.c: In function 'sh_wdt_start':
shwdt.c:92: error: 'wdt_lock' undeclared (first use in this function)
shwdt.c:92: error: (Each undeclared identifier is reported only once
shwdt.c:92: error: for each function it appears in.)
shwdt.c:97: error: implicit declaration of function 'sh_wdt_read_csr'
shwdt.c:98: error: 'WTCSR_WT' undeclared (first use in this function)
shwdt.c:99: error: implicit declaration of function 'sh_wdt_write_csr'
shwdt.c:101: error: implicit declaration of function 'sh_wdt_write_cnt'
shwdt.c:112: error: 'WTCSR_TME' undeclared (first use in this function)
shwdt.c:113: error: 'WTCSR_RSTS' undeclared (first use in this function)
shwdt.c: In function 'sh_wdt_stop':
shwdt.c:142: error: 'wdt_lock' undeclared (first use in this function)
shwdt.c:147: error: 'WTCSR_TME' undeclared (first use in this function)
shwdt.c: In function 'sh_wdt_keepalive':
shwdt.c:160: error: 'wdt_lock' undeclared (first use in this function)
shwdt.c: In function 'sh_wdt_set_heartbeat':
shwdt.c:176: error: 'wdt_lock' undeclared (first use in this function)
shwdt.c: In function 'sh_wdt_ping':
shwdt.c:192: error: 'wdt_lock' undeclared (first use in this function)
shwdt.c:197: error: 'WTCSR_IOVF' undeclared (first use in this function)
shwdt.c: At top level:
shwdt.c:417: error: conflicting type qualifiers for 'sh_wdt_info'
shwdt.c:71: error: previous declaration of 'sh_wdt_info' was here
make[3]: *** [drivers/watchdog/shwdt.o] Error 1
<-- snip -->
commit 8dc244f7deac4c0e95ce0ffd26f494bb6e1534c0
([WATCHDOG 48/57] txx9: Fix locking, switch to unlocked_ioctl):
<-- snip -->
CC drivers/watchdog/txx9wdt.o
txx9wdt.c:48: warning: type defaults to 'int' in declaration of
txx9wdt.c:48: warning: parameter names (without types) in function
txx9wdt.c: In function 'txx9wdt_ping':
txx9wdt.c:52: error: 'txx9_lock' undeclared (first use in this function)
txx9wdt.c:52: error: (Each undeclared identifier is reported only once
txx9wdt.c:52: error: for each function it appears in.)
txx9wdt.c: In function 'txx9wdt_start':
txx9wdt.c:59: error: 'txx9_lock' undeclared (first use in this function)
txx9wdt.c: In function 'txx9wdt_stop':
txx9wdt.c:71: error: 'txx9_lock' undeclared (first use in this function)
make[3]: *** [drivers/watchdog/txx9wdt.o] Error 1
<-- snip -->
- maintainer has not been active for years
- maintainer email bounces
- URL no longer exists
- covered by the WATCHDOG DEVICE DRIVERS entry
The problem is that iTCO_vendor_support.ko is still being built while
iTCO_vendor.h claims that its functions do not exist. The following
Makefile update fixes that. It causes iTCO_vendor_support.ko to no
longer be built if CONFIG_ITCO_VENDOR_SUPPORT=n.
The tmio MMC driver needs the cell to be passed as a platform data.
We need to pass the cell as the platform data.
This patch adds support for the TC6387XB. Unlike other TMIO devices this one
has only one subdevice and no interrupt mux, however using the MFD framework
allows it to share the TMIO MMC driver.
