2012-07-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 changes from Martin Schwidefsky: "No new functions, a few changes to make the code more robust, some cleanups and bug fixes." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (21 commits) s390/vtimer: rework virtual timer interface s390/dis: Add the servc instruction to the disassembler. s390/comments: unify copyright messages and remove file names s390/lgr: Add init check to lgr_info_log() s390/cpu init: use __get_cpu_var instead of per_cpu s390/idle: reduce size of s390_idle_data structure s390/idle: fix sequence handling vs cpu hotplug s390/ap: resend enable adapter interrupt request. s390/hypfs: Add missing get_next_ino() s390/dasd: add shutdown action s390/ipl: Fix ipib handling for "dumpreipl" shutdown action s390/smp: make absolute lowcore / cpu restart parameter accesses more robust s390/vmlogrdr: cleanup driver attribute usage s390/vmlogrdr: cleanup device attribute usage s390/ccwgroup: remove unused ccwgroup_device member s390/cio/chp: cleanup attribute usage s390/sigp: use sigp order code defines in assembly code s390/smp: use sigp cpu status definitions s390/smp/kvm: unifiy sigp definitions s390/smp: remove redundant check ...
git://git.kernel.org/pub/scm/linux/kernel/git/lliubbo/blackfin Pull blackfin changes from Bob Liu: "The big changes are adding PM and HDMI support for bf60x, other patches are various bug fix and code cleanup." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lliubbo/blackfin: (48 commits) bf60x: fix build warning PM: add BF60x flash suspend and resume support blackfin: twi: read twi mmr via bfin_read macro dpm: deepsleep: reserve stack bf60x: cpufreq: fix anomaly 05000273 bf609: add adv7511 display support blackfin: cplb-nompu: fix ROM cplb size for bf609-ezkit bf60x: Add double fault, hardware error and NMI SEC handler bf60x: update anomaly id in serial and twi driver headers. bf60x: vs6624 pin update bf60x: add default anomaly setting. bf60x: update bf60x anomaly list. bf60x: sec: Enable sec interrupt source priority configuration. bf60x: sec: Clean up interrupt initialization code for SEC. bf609: reuse bf5xx-i2s-pcm.c as i2s pcm driver bf561: add capabilities in adv7183_inputs bf609: convert vs6624 blank_clocks to black_pixels blackfin: fix musb macro name cleanup: sec and linkport only built on bf60x bfin: pint: add pint suspend and resume ...
2012-07-24Merge tag 'for-linus' of git://linux-c6x.org/git/projects/linux-c6x-upstreamingLinus Torvalds
Pull C6X changes from Mark Salter: - remove use of legacy irqs which really wasn't needed - add support for C66x SoC on EVMC6678 board - clean up compiler warning * tag 'for-linus' of git://linux-c6x.org/git/projects/linux-c6x-upstreaming: C6X: clean up compiler warning C6X: add basic support for TMS320C6678 SoC C6X: remove dependence on legacy IRQs C6X: remove megamod-pic requirement on direct-mapped core pic
2012-07-24bf60x: fix build warningBob Liu
Fix several build warning while using bf609-ezkit_defconfig. Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24PM: add BF60x flash suspend and resume supportSteven Miao
Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24blackfin: twi: read twi mmr via bfin_read macroSonic Zhang
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24dpm: deepsleep: reserve stackSteven Miao
Reserve 12 bytes on the stack for deepsleep use. Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bf60x: cpufreq: fix anomaly 05000273Sonic Zhang
Anomaly 05000273 doesn't apply to bf60x. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bf609: add adv7511 display supportScott Jiang
Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24blackfin: cplb-nompu: fix ROM cplb size for bf609-ezkitBob Liu
In user xip test, there is a cplb error when ROMKERNEL try to mount romfs using 'mount -t romfs /dev/mtdblock2 /mnt', becasue the CPLB setting is not correct. Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bf60x: Add double fault, hardware error and NMI SEC handlerSonic Zhang
2012-07-24bf60x: update anomaly id in serial and twi driver headers.Sonic Zhang
2012-07-24bf60x: vs6624 pin updateVivi Li
Change ce pin to PE4 according to new adaptor board and re-define ppi for vs6624 to avoid gpio conflict. Signed-off-by: Vivi Li <vivi.li@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bf60x: add default anomaly setting.Sonic Zhang
2012-07-24bf60x: update bf60x anomaly list.Sonic Zhang
2012-07-24bf60x: sec: Enable sec interrupt source priority configuration.Sonic Zhang
Customize the SEC interrupt priority array in machine ints-priority.c. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bf60x: sec: Clean up interrupt initialization code for SEC.Sonic Zhang
Turn SEC related macro CONFIG_BF60x into SEC_GCTL. Move machine specific GPIO_PINT macros to machine gpio header. Split SEC init_arch_irq() and vec_to_irq() from old SIC. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bf609: reuse bf5xx-i2s-pcm.c as i2s pcm driverScott Jiang
It's the same for both bf5xx and bf6xx soc. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bf561: add capabilities in adv7183_inputsScott Jiang
Add capabilities in adv7183_inputs to indicate that S_STD is supported. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bf609: convert vs6624 blank_clocks to black_pixelsScott Jiang
PPI driver has changed blank units from clocks to pixels. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24blackfin: fix musb macro nameBob Liu
Musb can't work since the marco name has been changed. Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24cleanup: sec and linkport only built on bf60xSteven Miao
2012-07-24bfin: pint: add pint suspend and resumeSteven Miao
Add pint suspend and resume if defined BFIN_GPIO_PINT. Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bf60x: pm: add pint suspend and resume supportSteven Miao
save and restore pint sec CTL save and restore pint registers add pint suspend and resume when suspend to mem Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bf609: add HDMI support for adv7842Scott Jiang
2012-07-24bf609: add CVBS and S-Video support for adv7842Scott Jiang
2012-07-24gpiokeys: add gpio keyboard platform deviceSteven Miao
2012-07-24bf60x: pm: pass wakeup paramSteven Miao
Pass wake up source mask and wakeup source polarity to deepsleep and hibernate. Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bf60x: pm: add smc nor flash syscore opsSteven Miao
2012-07-24bfin: simple_timer: add READ_COUNTER ioctl and add NOIRQ timer modeSteven Miao
2012-07-24blackfin: bf609-ezkit: add probe_type for norflashBob Liu
Set .probe_type = "map_rom" for norflash so that xip_test can run correctly. Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24i2c: i2c-bfin-twi: Always access 16 bit MMR by bfin 16 bit access Macro.Sonic Zhang
Otherwise, the compiler may optimize assemble code into 8bit access instruction when target register is 8 bit width. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bf609: add ssm2602 support on bf609 platformScott Jiang
2012-07-24blackfin: mach-common: ints-priority add irq_set_wakeBob Liu
Add irq_set_wake to bfin_sec_irqchip, drivers like stmmac need it. Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24v4l2: add adv7842 video decoder driverScott Jiang
2012-07-24cache: enable L2 sram icache in menuconfigSteven Miao
2012-07-24cpufreq: change debug message level to show clock change errorSteven Miao
2012-07-24bf60x: Add wake up latency bench for deep sleep mode.Sonic Zhang
2012-07-24bfin: pm: add deepsleep for bf60xSonic Zhang
Add add deepsleep for bf60x. 1. Call DMC init functions to enter and exit DDR self refresh mode. 2. Wait till CGU PLL is locked after wake up and exit DDR self refresh mode. 3. Make asessembly function enter_deepsleep comply with C funtion ABI in order to call other C functions. 4. Switch kernel stack by register EX_SCRATCH_REG. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24irq: set cgu event handle to fasteoi handleSteven Miao
2012-07-24blackfin: Kconfig: fix ROM range for bf60xBob Liu
ROM range of bf60x is above 0xb0000000. Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bfin: reorg clock init steps for bf609Bob Liu
So that user can set the clocks through menuconfig. Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bfin-dma: only use MDMA3 on bf609Steven Miao
2012-07-24bf609: bfin_crc: Remove unused CRC TX DMA platform resources.Sonic Zhang
2012-07-24pm: dpmc macro typo fixSteven Miao
2012-07-24bf60x: bfin_crc: move structure bfin_crc out of head file.Sonic Zhang
2012-07-24bf60x: Enable Blackfin CRC crypto driver by default.Sonic Zhang
2012-07-24bf609: crypto: Add blackfin crypto crc driver platform data.Sonic Zhang
2012-07-24blackfin: Call sg_for_each to pass through the whole sg list.Sonic Zhang
Otherwise, chained sg list may be missed. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bfin: add 32M, 16M and 8M uncached DMA region optionsScott Jiang
We need larger DMA region to support HD video. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
